PPTP VPN passthrough und SPA2100
MrVenus
19 Sep 2004
hat schon jemand mal ne vpn verbindung über dem spa2100 zum laufen gebracht? ....sollte normalerweise seit firmware 2.0.5 (a) funktionieren .....habe aber keine einstellmöglichkeit für PPTP VPN passthrough gefunden ....mit portforwarding TCP 1723 ...klappts ned ....hat jemand ne idee?
-- Since 2.0.5 (a) --
.If SDP in successive 183 response to the SPA contains different
RTP IP address, then the SPA might not be able to receive further
streaming audio from the new RTP IP address.
.Using SPA-2100 lan ip as dns server maynot work all the time.
.SPA-2100 cannot translate ICMP echo request reliably
.Port forwarding doesn't work all the time for outgoing traffic.
Feature Enhancement
. If the WAN IP address and LAN IP address were in the same
subnet (a.b.c.d), the SPA-2100 will automatically use the next
class C subnet (a.b.c+1.d) to solve the conflict.
. Added new IVR option 210# to check the LAN IP address
. [glow=red:21d34ebb34]Added PPTP VPN passthrough support [/glow:21d34ebb34]
. Allow VLAN ID 0 and 0x0FFF to be used
. Added <Referor Bye Delay>, , and
parameters for Line 1/2, to control when SPA sends BYE to terminate
stale call legs on transfer completion as the Referor, Referee, and
Refer Target respectively.
. Added <Refer-To Target Contact> Line 1/2 parameter
. Added <Stats In BYE> parameter (under SIP tab). If enabled, SPA will include
P-RTP-Stat header a BYE or response to a BYE message. This header contains
RTP statistics of the current call.
. Added <Escape Display Name> option (under [SIP] tab). If enabled,
SPA will enclose the configured <Display Name> parameter inside a
double-quotes. If parameter contains BACKSLASH (\) or DOUBLE-QUOTES ("), they
will be replaced (escaped) by \\ and \" respectively.
. Support escaping within double-quotes in SIP messages
. Support profile parameter in a SIP NOTIFY/Event:resync message with
the following format: Event: resync[;profile=<profile-rule>]
If profile parameter is not specified, the SPA will resync with the
currently configured profile rule. If profile parameter is specified,
SPA will resync (1-time) with the given profile rule.
Hi Venus,
bist Du sicher, dass es nicht einfach nur bedeutet, dass Du nun VPN-Verbindungen von intern nach extern aufbauen kannst?
Andersherum müsstest Du ja noch das GRE-Protokoll zusätzlich zum TCP-Port 1723 mappen können.
C.
....stimm ich zu ....
...GRE geht leider nicht ....und nach aussen bekomm ich auch keine verbindung.... ....bin grad motiviert probiere mal ein bisserl...danke für die antwort...
bihni1990
