problem mit asterisk-addons
wurtzel
7 Mrz 2006
Hallo
Ich habe folgendes Problem
Auf meinem Rechner kann ich das res_config_mysql mnodule nicht compilieren
Suse 10 mit Mysql 5.0.19 bzw 5.1.7 beta
./mkdep -fPIC -I../asterisk -D_GNU_SOURCE  -I/usr/include/mysql   `ls *.c`
make -C format_mp3 all
make[1]: Entering directory `/usr/src/asterisk-addons-1.2.2/format_mp3'
gcc -pipe -fPIC -Wall -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations   -D_REENTRANT -D_GNU_SOURCE  -O6 -m64   -c -o common.o common.c
gcc -pipe -fPIC -Wall -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations   -D_REENTRANT -D_GNU_SOURCE  -O6 -m64   -c -o dct64_i386.o dct64_i386.c
gcc -pipe -fPIC -Wall -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations   -D_REENTRANT -D_GNU_SOURCE  -O6 -m64   -c -o decode_ntom.o decode_ntom.c
gcc -pipe -fPIC -Wall -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations   -D_REENTRANT -D_GNU_SOURCE  -O6 -m64   -c -o layer3.o layer3.c
gcc -pipe -fPIC -Wall -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations   -D_REENTRANT -D_GNU_SOURCE  -O6 -m64   -c -o tabinit.o tabinit.c
gcc -pipe -fPIC -Wall -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations   -D_REENTRANT -D_GNU_SOURCE  -O6 -m64   -c -o interface.o interface.c
gcc -pipe -fPIC -Wall -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations   -D_REENTRANT -D_GNU_SOURCE  -O6 -m64   -c -o format_mp3.o format_mp3.c
gcc -pipe -fPIC -Wall -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations   -D_REENTRANT -D_GNU_SOURCE  -O6 -m64 -shared -Xlinker -x -o format_mp3.so common.o dct64_i386.o decode_ntom.o layer3.o tabinit.o interface.o format_mp3.                                                     o
make[1]: Leaving directory `/usr/src/asterisk-addons-1.2.2/format_mp3'
cc -fPIC -I../asterisk -D_GNU_SOURCE  -I/usr/include/mysql     -c -o app_saycountpl.o app_saycountpl.c
cc -shared -Xlinker -x -o app_saycountpl.so app_saycountpl.o
cc -fPIC -I../asterisk -D_GNU_SOURCE  -I/usr/include/mysql     -c -o cdr_addon_mysql.o cdr_addon_mysql.c
cc -shared -Xlinker -x -o cdr_addon_mysql.so cdr_addon_mysql.o -lmysqlclient -lz   -L/usr/lib/mysql -L/usr/lib64/mysql
/usr/lib64/gcc/x86_64-suse-linux/4.0.2/../../../../x86_64-suse-linux/bin/ld: /usr/lib64/mysql/libmysqlclient.a(libmysql.o): relocation R_X86_64_32 against `a local symbol' can not be used when making a shared object; recompile with -fPIC
/usr/lib64/mysql/libmysqlclient.a: could not read symbols: Bad value
collect2: ld returned 1 exit status
make: *** [cdr_addon_mysql.so] Error 1
rm app_saycountpl.o
ich würde sagen, da fehlen die mysql-client Development Bibliotheken
wenns nur so einfach währe
installierte rpms
MySQL-bench-5.0.19-0.glibc23.x86_64.rpm
MySQL-server-5.0.19-0.glibc23.x86_64.rpm
MySQL-client-5.0.19-0.glibc23.x86_64.rpm
MySQL-shared-5.0.19-0.glibc23.x86_64.rpm
MySQL-Max-5.0.19-0.glibc23.x86_64.rpm
MySQL-devel-5.0.19-0.glibc23.x86_64.rpm
MySQL-shared-compat-5.0.19-0.glibc23.x86_64.rpm
willst Du denn auf Deinem Asterisk überhaupt mit MySQL Anbindung arbeiten ? Ansonsten kannst Du die Addons einfach weglassen.
Wenn doch - wie gesagt, es handelt sich um MySQL-Client :!:
Wobei ich im Moment nicht sagen kann, ob Asterisk schon mit MySQL 5 arbeiten kann oder besser mit MySQL 4 zurechtkommt.
ich will astbill für die konfigeration nutzen das braucht mysql 5
Installiere mal das MySQL-devel-5.0.19-0.glibc23.x86_64.rpm und probier dann nochmal
ist schon installiert siehe oben
sorry - aus Deiner nichtssagenden Liste da oben, war beim besten Willen nicht erkennbar, ob das nun bereits installierte Pakete oder zur Installation verfügbare Pakete sind :rolleyes:
ja suse 10 64bit auf atlon64 3000+
hmmm, die Konstellation funktionierte bei mir auch nicht richtig. Ich habe damals die 32 bit Version genommen (Suse+rpms) und dann hat es funktioniert. Ist zwar keine richtige Lösung, aber so funktionierte es wenigstens.
mg Guard-X
Also Asterisk kann mit MySQL 5 das weiss ich mit Sicherheit da ich es so laufen habe. Aber auch auf 32bit, 64 hab ich nicht probiert.
finger weg von 64bit - misdn macht auch probleme
hier ist der Hund begraben:
Also in das Makefile und: recompile with -fPIC
viel spass bei der suche...
also solltest du ruhig bei 32bit bleiben - mir hat es einen TAG gekostet - bin wieder zurück zu 32bit
so nu ist es die 32bit version auf dem server und es geht
Reischitz
