Probleme 1.2.4 zu kompilieren...
*-tuxi
28 Sep 2005
N'Abend...
habe gerade versucht, Asterisk-1.2.4 zu kompilieren.
Beim make-Lauf kommt folgender Fehler:
./gentone ringtone 440 480
Wavelength 1 (in samples):   18.18182
Minimum samples (1): 200 (11.000000.3 wavelengths)
Wavelength 1 (in samples):   16.66667
Minimum samples (1): 50 (3.000000.3 wavelengths)
Need 200 samples
Wrote ringtone.h
gcc  -pipe  -Wall -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -g3  -Iinclude -I../include -D_REENTRANT -D_GNU_SOURCE  -O6 -march=i686 -DZAPTEL_OPTIMIZATIONS         -fomit-frame-pointer  -Wno-missing-prototypes -Wno-missing-declarations -DZAPATA_PRI -DIAX_TRUNKING -DCRYPTO -fPIC    -c -o chan_oss.o chan_oss.c
gcc -shared -Xlinker -x -o chan_oss.so  chan_oss.o  -ldl -lpthread -lncurses -lm -lresolv   -lssl
gcc  -pipe  -Wall -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -g3  -Iinclude -I../include -D_REENTRANT -D_GNU_SOURCE  -O6 -march=i686 -DZAPTEL_OPTIMIZATIONS         -fomit-frame-pointer  -Wno-missing-prototypes -Wno-missing-declarations -DZAPATA_PRI -DIAX_TRUNKING -DCRYPTO -fPIC    -c -o chan_phone.o chan_phone.c
gcc -shared -Xlinker -x -o chan_phone.so  chan_phone.o  -ldl -lpthread -lncurses -lm -lresolv   -lssl
gcc  -pipe  -Wall -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -g3  -Iinclude -I../include -D_REENTRANT -D_GNU_SOURCE  -O6 -march=i686 -DZAPTEL_OPTIMIZATIONS         -fomit-frame-pointer  -Wno-missing-prototypes -Wno-missing-declarations -DZAPATA_PRI -DIAX_TRUNKING -DCRYPTO -fPIC    -c -o chan_alsa.o chan_alsa.c
gcc -shared -Xlinker -x -o chan_alsa.so chan_alsa.o -lasound -lm -ldl
gcc -c  -pipe  -Wall -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -g3  -Iinclude -I../include -D_REENTRANT -D_GNU_SOURCE  -O6 -march=i686 -DZAPTEL_OPTIMIZATIONS         -fomit-frame-pointer  -Wno-missing-prototypes -Wno-missing-declarations -DZAPATA_PRI -DIAX_TRUNKING -DCRYPTO -fPIC  -o chan_zap.o chan_zap.c
chan_zap.c:66:2: error: #error "You need newer libpri"
chan_zap.c: In function âzt_callâ:
chan_zap.c:2263: warning: implicit declaration of function âpri_facility_enableâ
chan_zap.c:2298: warning: implicit declaration of function âpri_sr_set_redirectingâ
chan_zap.c:8197:2: error: #error "Upgrade your libpri"
chan_zap.c: In function âpri_dchannelâ:
chan_zap.c:8535: warning: implicit declaration of function âpri_shutdownâ
chan_zap.c:8544: warning: implicit declaration of function âpri_restartâ
chan_zap.c:8723: error: âPRI_EVENT_KEYPAD_DIGITâ undeclared (first use in this function)
chan_zap.c:8723: error: (Each undeclared identifier is reported only once
chan_zap.c:8723: error: for each function it appears in.)
chan_zap.c:8724: error: âunion <anonymous>â has no member named âdigitâ
chan_zap.c:8727: error: âunion <anonymous>â has no member named âdigitâ
chan_zap.c:8729: error: âunion <anonymous>â has no member named âdigitâ
chan_zap.c:8733: error: âunion <anonymous>â has no member named âdigitâ
chan_zap.c:8735: error: âunion <anonymous>â has no member named âdigitâ
chan_zap.c:8739: error: âunion <anonymous>â has no member named âdigitâ
chan_zap.c:8877: error: âstruct zt_pvtâ has no member named âcid_aniâ
chan_zap.c:8882: error: âpri_event_ringâ has no member named âcallingplanrdnisâ
chan_zap.c:9026: error: âpri_event_ringâ has no member named âcallinganiâ
chan_zap.c:9028: error: âpri_event_ringâ has no member named âcallinganiâ
chan_zap.c:9044: error: âpri_event_ringâ has no member named âredirectingreasonâ
chan_zap.c:9045: error: âpri_event_ringâ has no member named âredirectingreasonâ
chan_zap.c:9082: error: âpri_event_ringâ has no member named âredirectingreasonâ
chan_zap.c:9083: error: âpri_event_ringâ has no member named âredirectingreasonâ
chan_zap.c:9100: error: âpri_event_ringâ has no member named âcallinganiâ
chan_zap.c:9102: error: âpri_event_ringâ has no member named âcallinganiâ
chan_zap.c:9155: error: âpri_event_ringingâ has no member named âprogressâ
chan_zap.c:9188: error: âpri_event_proceedingâ has no member named âprogressâ
chan_zap.c:9215: error: âpri_event_proceedingâ has no member named âprogressâ
chan_zap.c:9247: error: âpri_event_proceedingâ has no member named âprogressâ
chan_zap.c:9694: error: âpri_event_hangupâ has no member named âaoc_unitsâ
chan_zap.c:9697: error: âpri_event_hangupâ has no member named âaoc_unitsâ
chan_zap.c:9767: error: âpri_event_hangupâ has no member named âaoc_unitsâ
chan_zap.c:9770: error: âpri_event_hangupâ has no member named âaoc_unitsâ
chan_zap.c:8350: warning: unused variable âplancallinganiâ
chan_zap.c: In function âstart_priâ:
chan_zap.c:10141: error: too many arguments to function âpri_newâ
chan_zap.c: In function âhandle_pri_set_debug_fileâ:
chan_zap.c:10249: warning: implicit declaration of function âpri_set_debug_fdâ
chan_zap.c: In function âapp_zapCDâ:
chan_zap.c:10476: warning: implicit declaration of function âpri_deflectâ
chan_zap.c: In function âsetup_zapâ:
chan_zap.c:11772: error: âPRI_SWITCH_QSIGâ undeclared (first use in this function)
chan_zap.c: In function âload_moduleâ:
chan_zap.c:12059: warning: passing argument 1 of âpri_set_errorâ from incompatible pointer type
chan_zap.c:12060: warning: passing argument 1 of âpri_set_messageâ from incompatible pointer type
make[1]: *** [chan_zap.o] Error 1
make[1]: Leaving directory `/admin/voip/asterisk-1.2.4/bristuff-0.3.0-PRE-1k/asterisk-1.2.4/channels'
make: *** [subdirs] Error 1
sip:/admin/voip/asterisk-1.2.4/bristuff-0.3.0-PRE-1k/asterisk-1.2.4 #
Auf welchen error muss ich mich berufen? Auf den ersten, weil die nächsten Folgefehler sind??
Falls dem so ist, was soll mir --> #error "You need newer libpri" <-- sagen?
Ich kann doch auch nicht mehr tun, als die v1.2.2 von asterisk.org laden... Hat jemand denn bitte eine neuere Version für mich?
Ich habe alles im Verzeichnis bristuff (v0.3.0-PRE-1k) in den entsprechenden Unterverzeichnissen.
zaptel, libpri und zaphfc mit florz wurden alle gepatcht, die patches liefen alle 100%ig durch. Alle liefen anständig beim make-Lauf durch, nur beim letzten, beim asterisk-1.2.4, da hakt es jetzt.
Alle Versionen vorhin geladen und daher aktuell.
Hat jemand eine Idee??
Michael
Hat denn niemand eine Idee hierzu?
Michael
Schau mal ob die libpri.h in
/usr/include/
bzw.
/usr/local/include/
die selbe ist wie unter usr/src/.../libpri-1.2.2
Wenn nicht, kopiere die aus dem libpri-1.2.2 verzeichnis in usr/include/
/usr/include/
bzw.
/usr/local/include/
habe es heute endlich geschafft, meinen Asterisk von SUSE 10.0-Standard-Paketen auf 1.2.4 mit Florz-Patch upzudaten.
Der von mir oben gepostete Fehler lag ganz einfach darin begründet, dass ich nur die make-Läufe gestartet hatte, aber nichts (zaptel, libpri, zaphfc) installiert hatte.
Dadurch konnte die libpri.h auch nicht die sein, die Asterisk zum make-Lauf erwartet (nämlich die neuere von libpri-1.2.2)... ;-)
Also ganz logisch eigentlich... ;-)
Nun läuft's erstmal, jetzt muss ich den dialplan für 1.2 umschreiben...
--> Gibt es da zufällig eine Seite, in der die Änderungen von 1.0 zu 1.2 zusammengefasst wurden, insbesondere im Hinblick auf die Änderungen, die im dialplan nun erfolgen müssen???
Michael
krautsourced
