cake*CLI> show application Playback
cake*CLI>
-= Info about application 'Playback' =-
[Synopsis]:
Play a file
[Description]:
Playback(filename[|option]): Plays back a given filename (do not put
extension). Options may also be included following a pipe symbol. The 'skip'
option causes the playback of the message to be skipped if the channel
is not in the 'up' state (i.e. it hasn't been answered yet. If 'skip' is
specified, the application will return immediately should the channel not be
off hook. Otherwise, unless 'noanswer' is specified, the channel channel will
be answered before the sound is played. Not all channels support playing
messages while still hook. Returns -1 if the channel was hung up, or if the
file does not exist. Returns 0 otherwise.
cake*CLI> show applications
-= Registered Asterisk Applications =-
AbsoluteTimeout: Set absolute maximum time of call
AddQueueMember: Dynamically adds queue members
ADSIProg: Load Asterisk ADSI Scripts into phone
AgentCallbackLogin: Call agent callback login
AgentLogin: Call agent login
AgentMonitorOutgoing: Record agent's outgoing call
AGI: Executes an AGI compliant application
AlarmReceiver: Provide support for receving alarm reports from a burglar or fire alarm panel
Answer: Answer a channel if ringing
AppendCDRUserField: Append to the CDR user field
Authenticate: Authenticate a user
Autoanswer: Autoanswer a call
AutoanswerLogin: Log in for autoanswer
BackGround: Play a file while awaiting extension
BackgroundDetect: Background a file with talk detect
Busy: Indicate busy condition and stop
CallingPres: Change the presentation for the callerid
ChangeMonitor: Change monitoring filename of a channel
ChanIsAvail: Check if channel is available
CheckGroup: CheckGroup(max[@category])
Congestion: Indicate congestion and stop
ControlPlayback: Play a file with fast forward and rewind
Cut: Cut(newvar=varname|delimiter|fieldspec)
DateTime: Says a specified time in a custom format
DBdel: Delete a key from the database
DBdeltree: Delete a family or keytree from the database
DBget: Retrieve a value from the database
DBput: Store a value in the database
DeadAGI: Executes AGI on a hungup channel
Dial: Place a call and connect to the current channel
DigitTimeout: Set maximum timeout between digits
Directory: Provide directory of voicemail extensions
DISA: DISA (Direct Inward System Access)
EAGI: Executes an EAGI compliant application
Echo: Echo audio read back to the user
EnumLookup: Lookup number in ENUM
Eval: Eval(newvar=somestring)
Exec: Exec(Appname(arguments))
Festival: Say text to the user
Flash: Flashes a Zap Trunk
ForkCDR: Forks the Call Data Record
GetCPEID: Get ADSI CPE ID
GetGroupCount: GetGroupCount([groupname][@category])
Goto: Goto a particular priority, extension, or context
GotoIf: Conditional goto
GotoIfTime: Conditional goto on current time
Hangup: Unconditional hangup
HasNewVoicemail: Conditionally branches to priority + 101
HasVoicemail: Conditionally branches to priority + 101
HoldedCall: Answer a parked call
ICES: Encode and stream using 'ices'
LookupBlacklist: Look up Caller*ID name/number from blacklist database
LookupCIDName: Look up CallerID Name from local database
Macro: Macro Implementation
MailboxExists: Check if vmbox exists
MeetMe: MeetMe conference bridge
MeetMeAdmin: MeetMe conference Administration
MeetMeCount: MeetMe participant count
Milliwatt: Generate a Constant 1000Hz tone at 0dbm (mu-law)
Monitor: Monitor a channel
MP3Player: Play an MP3 file or stream
MusicOnHold: Play Music On Hold indefinitely
NBScat: Play an NBS local stream
NoCDR: Make sure asterisk doesn't save CDR for a certain call
NoOp: No operation
Park: Park yourself
ParkAndAnnounce: Park and Announce
ParkedCall: Answer a parked call
PickDown: Channel independent call pickdown.
PickUp: Channel independent call pickup.
PickupChan: Channel independent call pickup.
Playtones: Play a tone list
Prefix: Prepend leading digits
PrivacyManager: Require phone number to be entered, if no CallerID sent
Progress: Indicate progress
Queue: Queue a call for a call queue
Random: Conditionally branches, based upon a probability
Read: Read a variable
Record: Record to a file
RemoveQueueMember: Dynamically removes queue members
ResetCDR: Resets the Call Data Record
ResponseTimeout: Set maximum timeout awaiting response
Ringing: Indicate ringing tone
SayAlpha: Say Alpha
SayDigits: Say Digits
SayNumber: Say Number
SayPhonetic: Say Phonetic
SayUnixTime: Says a specified time in a custom format
SendDTMF: Sends arbitrary DTMF digits
SendImage: Send an image file
SendText: Send a Text Message
SendURL: Send a URL
SetAccount: Sets account code
SetAMAFlags: Sets AMA Flags
SetCallerID: Set CallerID
SetCallerPres: Set CallerID Presentation
SetCDRUserField: Set the CDR user field
SetCIDName: Set CallerID Name
SetCIDNum: Set CallerID Number
SetGlobalVar: Set global variable to value
SetGroup: SetGroup(groupname[@category])
SetLanguage: Sets user language
SetMusicOnHold: Set default Music On Hold class
SetVar: Set variable to value
SIPDtmfMode: Change the dtmfmode for a SIP call
SMS: Communicates with SMS service centres and SMS capable analogue phones
SoftHangup: Soft Hangup Application
Steal: Channel independent call stealing. Just like pickup but for answered channels.
StopMonitor: Stop monitoring a channel
StopPlaytones: Stop playing a tone list
StripLSD: Strip Least Significant Digits
StripMSD: Strip leading digits
SubString: (Deprecated) Save substring digits in a given variable
Suffix: Append trailing digits
System: Execute a system command
TestClient: Execute Interface Test Client
TestServer: Execute Interface Test Server
Transfer: Transfer caller to remote extension
TrySystem: Try executing a system command
TXTCIDName: Lookup caller name from TXT record
UserEvent: Send an arbitrary event to the manager interface
Verbose: Send arbitrary text to verbose output
VoiceMail: Leave a voicemail message
VoiceMail2: Leave a voicemail message
VoiceMailMain: Enter voicemail system
VoiceMailMain2: Enter voicemail system
Wait: Waits for some time
WaitExten: Waits for some time
WaitForRing: Wait for Ring Application
WaitMusicOnHold: Wait, playing Music On Hold
Zapateller: Block telemarketers with SIT
ZapBarge: Barge in (monitor) Zap channel
ZapRAS: Executes Zaptel ISDN RAS application
ZapScan: Scan Zap channels to monitor calls
