Recover my fritzbox ata 1020 fails [solved]
MaxMuster schrieb:
o.k., I just tried to translate it, so maybe you can compare it to what you did:
You will need a http server on your PC to serve the image file (try this one). So, in my example your PC (our http server ;-)) has the IP 192.168.178.20, the image file is fritz.box_fon_ata.11.04.01.image.
prepare_fwupgrade start_from_internet
wget -q -O - http://192.168.178.20/fritz.box_fon_ata.11.04.01.image 2> /dev/null | tar -C / -x
prepare_fwupgrade end
/var/install
/var/post_install
reboot
Jörg
It is working now.
Thank you very much for your help.:D
Without you I couldn't fix this.
Mashti
You're welcome! Glad it worked.
Could you please edit the title and add "[solved]" to it?
Just go to the first post, use "Ändern" -> "Erweitert" and you can change the title.
Jörg
linus1991
