Remove unusud image
Fabbbio
23 Okt 2007
Only 2 question:
1.
With mobile costumizer I remove all wallpaper image except the first ...
but in menu - display -wallpaper--select wallpaper... I see something like this:
01
Select gallery
01
Select gallery
01
and if I press select and I use arrow key up and down I can see the 6 wallpaper
2.
I change the poeweron image. I replace the 6 .art file with an image but can I remove all art power on image and leave only 01.art image?
to 1) I don't remember, but I beleave I don't have any wallpaper. I still have 01.bmp, 02.bmp, [..], 06.bmp as options, but selecting that renders messed up pictures. I use the jpg pictures in the gallery as background.
to 2) I had no problems leaving some picutres away, but your boot up will look messed up. Try keeping 1 and 6 if that is fine for you.
Take care
I try without wallpaper and I remove it from ini file.
But in menu........wallpaper I see everything blank but with up down arrow keys I see the wallpeper...
I think uploading a firmware without wallpaper don't overwrite the memory locations where the wallpaper are, Is it possible?
yes I also think that the memory is not being overwritten, but you get more free memory. What do you mean with remove from ini-file? Sip-Profile guide talks of deleting files. Take care
I remove from configuration file data_service.ini section wallpaper
[Wallpaper Setting]
WallpaperType=0
WallpaperId=0
WallpaperImg=
I think the best way is to build a firmware with m0 extension like in "Dpl10-Flash R_3.99d_PIR_EN_DE.exe" so we rewrite all the file system...I think!!!
dbip
