Hi all,
In order to take advantage of a low cost mobile to mobile plan I have,
I route calls to certain mobiles from a 7270 to a spa3102 with a gsm terminal at it's FXO.
I added the spa ip as a new internet number proxy and modified the voip config file in the FritzBox so it does not try to register all the time.
I also set up the spa for one stage voip to pstn (gsm now) dialing.
So, if I specifically use this internet number (like *125#mobile number) it works fine.
But if i just add a dialing rule to use this internet number for the mobile numbers I want, the Fritz uses the next registered internet number instead, thinking the one I want is unavailable because it is not registered.
Is it possible to force the Fritz to use that number anyway?
Thanks in advance.
PS. As a workaround for the time being I send the calls to pbxes.org first, then from there to the spa3102.
Thanks in advance.
