Seit 11.03.90 FBF ATA teilweise Tot
herschi
17 Aug 2004
Seit ich auf die neue Firmware abgedatet habe klappt nichts mehr.
anbei ein Telnet log als ich versuchte den Anrufbeantworter anzurufen.
Nov 13 01:15:52 voipd[501]: incoming(4:appl=3 plci=0x104 ncci=0x0 incoming): 11  <- 0
Nov 13 01:15:52 voipd[501]: telapp_incoming - running (voip=0)
Nov 13 01:15:52 voipd[501]: 0: connected    vcc 0/0/RBE/14 stay online 1
Nov 13 01:15:52 voipd[501]: 0: ip 192.168.5.20/192.168.5.10 mtu 1500 dns 195.70.224.61/195.70.224.62
Nov 13 01:15:52 voipd[501]: disconnected(appl=3 plci=0x104 ncci=0x0 incoming): remote: 0x0000 (0x0000) -
Nov 13 01:15:57 voipd[501]: incoming(4:appl=3 plci=0x104 ncci=0x0 incoming): 11 50000 <- 0
Nov 13 01:15:57 voipd[501]: telapp_incoming - running (voip=0)
Nov 13 01:15:57 voipd[501]: 0: connected    vcc 0/0/RBE/14 stay online 1
Nov 13 01:15:57 voipd[501]: 0: ip 192.168.5.20/192.168.5.10 mtu 1500 dns 195.70.224.61/195.70.224.62
Nov 13 01:15:57 voipd[501]: STUN: udp 5060 -> 212.152.132.251:5060
Nov 13 01:15:57 voipd[501]: STUN: udp 7078 -> 212.152.132.251:7078
Nov 13 01:15:58 voipd[501]: STUN: udp 7079 -> 212.152.132.251:7079
Nov 13 01:15:58 voipd[501]: allowed bandwidth 272000 for sip:[email protected]
Nov 13 01:15:58 voipd[501]: >>> Request: INVITE sip:[email protected]
Nov 13 01:15:58 voipd[501]: <<< Status: 407 Proxy Authentication Required
Nov 13 01:15:58 voipd[501]: >>> Request: ACK sip:[email protected]
Nov 13 01:15:58 voipd[501]: <<< Status: 100 trying -- your call is important to us
Nov 13 01:15:58 voipd[501]: <<< Status: 503 Service Unavailable
Nov 13 01:15:58 voipd[501]: ocfree: fail 0 normal 0 small 0 large 0
Nov 13 01:15:58 voipd[501]:         underrun 0 max_ackqueuelen 0
Nov 13 01:15:58 voipd[501]:         small packets merged 0, output 0 and consumed from CNG 0
Nov 13 01:15:58 voipd[501]: ocmode: normal 0 merged 0 delayed 0
Nov 13 01:15:58 voipd[501]: dropped 0 packets with 0 samples and 1 sample in 0 packets
Nov 13 01:15:58 voipd[501]: generated noise: 0
Nov 13 01:15:58 voipd[501]:         capiqueue[0]: 0 (  0.0%)
Nov 13 01:15:58 voipd[501]:         capiqueue[1]: 0 (  0.0%)
Nov 13 01:15:58 voipd[501]:         capiqueue[2]: 0 (  0.0%)
Nov 13 01:15:58 voipd[501]:         capiqueue[3]: 0 (  0.0%)
Nov 13 01:15:58 voipd[501]:         capiqueue[4]: 0 (  0.0%)
Nov 13 01:15:58 voipd[501]:         capiqueue[5]: 0 (  0.0%)
Nov 13 01:15:58 voipd[501]:         capiqueue[6]: 0 (  0.0%)
Nov 13 01:15:58 voipd[501]:         capiqueue[7]: 0 (  0.0%)
Nov 13 01:15:58 voipd[501]:        txqueue[0ms]: 0 (  0.0%)
Nov 13 01:15:58 voipd[501]:        txqueue[10ms]: 0 (  0.0%)
Nov 13 01:15:58 voipd[501]:        txqueue[20ms]: 0 (  0.0%)
Nov 13 01:15:58 voipd[501]:        txqueue[30ms]: 0 (  0.0%)
Nov 13 01:15:58 voipd[501]:        txqueue[40ms]: 0 (  0.0%)
Nov 13 01:15:58 voipd[501]:        txqueue[50ms]: 0 (  0.0%)
Nov 13 01:15:58 voipd[501]:        txqueue[60ms]: 0 (  0.0%)
Nov 13 01:15:58 voipd[501]:        txqueue[70ms]: 0 (  0.0%)
Nov 13 01:15:58 voipd[501]:        txqueue[80ms]: 0 (  0.0%)
Nov 13 01:15:58 voipd[501]:        txqueue[90ms]: 0 (  0.0%)
Nov 13 01:15:58 voipd[501]:        txqueue[100ms]: 0 (  0.0%)
Nov 13 01:15:58 voipd[501]:        txqueue[110ms]: 0 (  0.0%)
Nov 13 01:15:58 voipd[501]:        txqueue[120ms]: 0 (  0.0%)
Nov 13 01:15:58 voipd[501]:        txqueue[130ms]: 0 (  0.0%)
Nov 13 01:15:58 voipd[501]:        txqueue[140ms]: 0 (  0.0%)
Nov 13 01:15:58 voipd[501]:        txqueue[150ms]: 0 (  0.0%)
Nov 13 01:15:58 voipd[501]:        txqueue[160ms]: 0 (  0.0%)
Nov 13 01:15:58 voipd[501]:        txqueue[170ms]: 0 (  0.0%)
Nov 13 01:15:58 voipd[501]:        txqueue[180ms]: 0 (  0.0%)
Nov 13 01:15:58 voipd[501]:        txqueue[190ms]: 0 (  0.0%)
Nov 13 01:15:58 voipd[501]:        txqueue[200ms]: 0 (  0.0%)
Nov 13 01:15:58 voipd[501]:        txqueue[210ms]: 0 (  0.0%)
Nov 13 01:15:58 voipd[501]:        txqueue[220ms]: 0 (  0.0%)
Nov 13 01:15:58 voipd[501]:        txqueue[230ms]: 0 (  0.0%)
Nov 13 01:15:58 voipd[501]: CONNECT_RESP with sip value 503
Nov 13 01:15:58 voipd[501]: call to sip:[email protected] terminated (503)
Nov 13 01:15:58 voipd[501]: EVENT(78): Internettelefonie mit 50000 über sipgate.at fehlgeschlagen. Fehlergrund: Service Unavailable (503)
Nov 13 01:15:59 voipd[501]: <<< Status: 503 Service Unavailable
Nov 13 01:15:59 voipd[501]: >>> Request: ACK sip:[email protected]
Nov 13 01:16:01 voipd[501]: <<< Status: 503 Service Unavailable
Nov 13 01:16:01 voipd[501]: >>> Request: ACK sip:[email protected]
Nov 13 01:16:01 voipd[501]: disconnected(appl=3 plci=0x104 ncci=0x0 incoming): remote: 0x3490 (0x0000) -
Was soll ich machen ?
Gruss Christian
Da in dem Log ein Service unavalable von sipgate.at kommt, könnte es sein das das mit dieser Störung zusammen hängt: http://www.ip-phone-forum.de/forum/viewtopic.php?t=30085
Nach den letzten Posts zu urteilen scheint die Störung immer noch zu bestehen.
Versuchs mal mit einem anderen VoIP-Anbieter, nach Deiner Signatur hast Du ja mehrere.
Volker
Hallo voja,
Bei allen anderen das gleiche, nur Voipbuster geht.
Status:
Status Internetrufnummer sipgate: Registriert
Status Internetrufnummer Purtel: Registriert
Status Internetrufnummer sipsnip: Registriert
Status Internetrufnummer jajah: Registriert
Status Internetrufnummer voipbuster: Registriert
Status Internetrufnummer simply-connect: Registriert
Gruss Christian
Mag sein, dass du folgendes schon probiert hast, aber das hast du leider nicht erwähnt:
- FBF nach FW-Update auf Werkseinstellungen zurückgesetzt?
- FBF stromlos gemacht?
Und was funktioniert denn genau alles nicht mehr? Bzw. was geht? Weil anscheinend geht ja nicht wirklich ALLES NICHT MEHR...
Vielleicht mal Telnet-Logs bei anderen Anbietern? Oder ggf. mal in der Weboberfläche der FBF unter System gucken, was dort angezeigt wird.
Gruss Christian
Hatte dasselbe Problem. Mit dem Recovery Tool von avm (über support erhältlich) kann man die alte Version wiederherstellen. Allerdings ein Tip: vorher die IP-Adresse der Box auf 192.168.178.1 einstellen, sonst kann es schwierig werden.
Benzino
tempuser777
