Nach update auf Version 06.03.57
Fritz!Box web password:
so nun habe ich dass update durchgeführt jedoch immer noch keine verbindung! Anbei das Protokoll:
BusyBox v1.00-pre3 (2005.02.25-11:13+0000) Built-in shell (ash)
Enter 'help' for a list of built-in commands.
CONFIG_PRODUKT: Fritz_Box_FON
CONFIG_PRODUKT_NAME: FRITZ!Box Fon (UI)
ANNEX: B
OEM: 1und1
HWRevision: 58
CONFIG_VERSION_MAJOR: 06
CONFIG_INSTALL_TYPE: ar7_4MB_2eth_2ab_isdn_pots_05804
CONFIG_CAPI: y
CONFIG_CAPI_MIPS: y
CONFIG_CAPI_UBIK: n
CONFIG_FON: y
CONFIG_WLAN: n
CONFIG_DSL:
CONFIG_ASSIST: y
CONFIG_ETH_COUNT: 1
CONFIG_AB_COUNT: 2
CONFIG_UBIK2: n
CONFIG_VLYNQ0: 0
CONFIG_VLYNQ1: 0
CONFIG_XILINX: n
CONFIG_USB: y
CONFIG_USB_HOST_TI: n
CONFIG_USB_HOST_AVM: n
CONFIG_CDROM: y
CONFIG_CDROM_FALLBACK: y
CONFIG_FIRMWARE_URL:
http://www.avm.de/fritz_box_fon_firmware
CONFIG_HOSTNAME: fritz.fon.box
Country: 049
Language: de
ermittle die aktuelle TTY
tty is "/dev/pts/0"
Console Ausgaben auf dieses Terminal umgelenkt
# May 1 16:37:12 voipd[366]: incoming(4:appl=2 plci=0x804 ncci=0x0 incoming): 1
1 <- 0
May 1 16:37:12 voipd[366]: disconnected(appl=2 plci=0x804 ncci=0x0 incoming): r
emote: 0x0000 (0x0000) - No additional information
May 1 16:37:24 voipd[366]: incoming(4:appl=2 plci=0x804 ncci=0x0 incoming): 11
07666602311 <- 0
May 1 16:37:24 voipd[366]: allowed bandwidth 432000 for sip:07666602311@sipgate
.de
May 1 16:37:24 voipd[366]: >>> Request: INVITE sip:07666602311@sip
May 1 16:37:24 voipd[366]: <<< Status: 407 Proxy Authentication Required
May 1 16:37:24 voipd[366]: >>> Request: ACK sip:
[email protected]
.de
[email protected]
May 1 16:37:24 voipd[366]: <<< Status: 100 trying -- your call is important to
us
May 1 16:38:03 voipd[366]: <<< Status: 408 Request Timeout
May 1 16:38:03 voipd[366]: >>> Request: ACK sip:07666602311@sipgat
May 1 16:38:03 voipd[366]: ocfree: fail 0 normal 0 small 0 large 0
May 1 16:38:03 voipd[366]: underrun 0 max_ackqueuelen 0
May 1 16:38:03 voipd[366]: small packets merged 0, output 0 and consume
d from CNG 0
May 1 16:38:03 voipd[366]: ocmode: normal 0 merged 0 split 0 delayed 0
May 1 16:38:03 voipd[366]: capiqueue[0]: 0 ( 0.0%)
May 1 16:38:03 voipd[366]: capiqueue[1]: 0 ( 0.0%)
May 1 16:38:03 voipd[366]: capiqueue[2]: 0 ( 0.0%)
May 1 16:38:03 voipd[366]: capiqueue[4]: 0 ( 0.0%)
May 1 16:38:03 voipd[366]: capiqueue[5]: 0 ( 0.0%)
May 1 16:38:03 voipd[366]: capiqueue[6]: 0 ( 0.0%)
May 1 16:38:03 voipd[366]: capiqueue[7]: 0 ( 0.0%)
May 1 16:38:03 voipd[366]: txqueue[0ms]: 0 ( 0.0%)
May 1 16:38:03 voipd[366]: txqueue[10ms]: 0 ( 0.0%)
May 1 16:38:03 voipd[366]: txqueue[20ms]: 0 ( 0.0%)
May 1 16:38:03 voipd[366]: txqueue[30ms]: 0 ( 0.0%)
May 1 16:38:03 voipd[366]: txqueue[40ms]: 0 ( 0.0%)
May 1 16:38:03 voipd[366]: txqueue[50ms]: 0 ( 0.0%)
May 1 16:38:03 voipd[366]: txqueue[60ms]: 0 ( 0.0%)
May 1 16:38:03 voipd[366]: txqueue[70ms]: 0 ( 0.0%)
May 1 16:38:03 voipd[366]: txqueue[80ms]: 0 ( 0.0%)
May 1 16:38:03 voipd[366]: txqueue[90ms]: 0 ( 0.0%)
May 1 16:38:03 voipd[366]: txqueue[100ms]: 0 ( 0.0%)
May 1 16:38:03 voipd[366]: txqueue[110ms]: 0 ( 0.0%)
May 1 16:38:03 voipd[366]: txqueue[120ms]: 0 ( 0.0%)
May 1 16:38:03 voipd[366]: txqueue[130ms]: 0 ( 0.0%)
May 1 16:38:03 voipd[366]: txqueue[140ms]: 0 ( 0.0%)
May 1 16:38:03 voipd[366]: txqueue[150ms]: 0 ( 0.0%)
May 1 16:38:03 voipd[366]: txqueue[160ms]: 0 ( 0.0%)
May 1 16:38:03 voipd[366]: txqueue[170ms]: 0 ( 0.0%)
May 1 16:38:03 voipd[366]: txqueue[180ms]: 0 ( 0.0%)
May 1 16:38:03 voipd[366]: txqueue[190ms]: 0 ( 0.0%)
May 1 16:38:03 voipd[366]: txqueue[200ms]: 0 ( 0.0%)
May 1 16:38:03 voipd[366]: txqueue[210ms]: 0 ( 0.0%)
May 1 16:38:03 voipd[366]: txqueue[220ms]: 0 ( 0.0%)
May 1 16:38:03 voipd[366]: txqueue[230ms]: 0 ( 0.0%)
May 1 16:38:03 voipd[366]: call to sip:
[email protected] terminated (408)
May 1 16:38:03 voipd[366]: EVENT(78): Fehler bei der Internettelefonie bei Verb
indung mit sip:
[email protected]. Fehlergrund: 408
May 1 16:38:03 voipd[366]: disconnected(appl=2 plci=0x804 ncci=0x0 incoming): r
liegt es 407 mit dem Proxy??
