Skype for Linux: Aktuelle Version 1.1.0.3 (22.04.2005)
RB
Aktives Mitglied
22 Jun 2004
Und wieder eine neue Version für das Linux-Lager...
22.04.2005 Skype for Linux version 1.1.0.3
* feature: Skype API (not available on SuSE build)
* feature: SkypeIn privacy options
* change: translations update
* bugfix: While recording VM, hold button should be disabled on toolbar
* bugfix: deleting custom VM greeting
* bugfix: wrong tooltip for voicemail icon on start tab
* bugfix: Skype Me warning dialog fixes
* bugfix: can't use Delete key for clearing About field in profile
* bugfix: wrong button name after password changing
* bugfix: adding Skype Name which contains only dots
* bugfix: tray icon disappeared after kicker restart
* bugfix: VM: playback greeting keeps playing after pressing Cancel
* bugfix: Delete button should be disabled if there is no custom voicemail greeting
* bugfix: skype crashes while sending voicemail
* bugfix: duplicated contacts if you create a new group
* bugfix: contact list changes are not saved to central contactlist
* bugfix: Remember my password option doesn't work correctly
* bugfix: Skype is ringing regardless of call options
* bugfix: online notification doesn't work
* bugfix: calls between Skype for Linux 1.0.0.20 and earlier versions did not work in some rare cases, there may have been silence or noise in both directions
Der Link auf die Download-Seite
Hmm, wenn es jetzt endlich eine API zu Skype gibt, dann sollte doch auch endlich mal ein Asterisk-Plugin folgen können oder? :)
kernig123
