Skype for Windows: Aktuelle BETA 1.2.0.21 (10.03.2005)
NA-UND
12 Apr 2004
Beta version available
This beta version contains new features which may not be entirely stable and can include bugs or errors. Before you download it, make a backup of your contact list and all data.
Download Skype for Windows 1.2 Beta (6.4 MB)
Version: 1.2.0.21. Release date: March 10, 2005 File name: SkypeSetup-Beta.exe
http://www.skype.com/go/getskype-1.2
SkypeIn laesst sich ueber die skype webseite im eingeloggten Bereich einstellen.
3 monate skypein kosten 10 eur
12 monate 25 eur.
verfuegbare nummern aus den laendern:
France
Hong Kong S.A.R., China
United Kingdom
United States
Voicemail anrufbeantworter kostet:
3monate fuer 5 eur
12 monate fuer 15 eur
10.03.2005 version 1.2.0.21
* feature: Central Contacts List
* feature: Voicemail
* feature: SkypeIn
* feature: Getting Started Wizard
* feature: Promote Add To Contacts
* feature: toolbar added to call tab
* feature: File Transfer - ability to select multiple files to send
* feature: putting SkypeIn and SkypeOut calls on hold
* feature: Import/Export contactlist from/to vCard
* feature: API: possible to initiate conference
* change: improved voice quality
* change: improved connectivity on XP SP2
* change: Options dialog - usability improvements
* change: new sounds
* change: API: commands BTN_RELEASED UP and BTN_RELEASED DOWN
* change: notification on entering SkypeMe mode changed to confirmation
* change: file transfer: increased relayed transfer speed to 1500 bytes/sec
* change: Send Contacts: possibility to send PSTN numbers
* change: Send Contacts form closed when all selected contacts added
* change: content of user profile phone fields is displayed in Contact List as links only if it's valid Skype contact identity
* change: prank call warning re-designed
* change: the number of simultaneous File Transfers limited to 50
* change: added items to context menu
* change user selectable font size, type, color in chat
* change: Import Contacts - bundled MSN, Microsoft Outlook, Outlook Express and Opera Contact Importers
* bugfix: improved 'Automatically check for updates'
* bugfix: My Skype Picture � files with jpeg extentions were not shown
* bugfix: API: "AUDIO IN" and "AUDIO OUT" commands did not read double byte driver names correctly
* bugfix: 'accept authrization' buttons were not translatable
* bugfix: in some cases API did not deny access properly
* bugfix: API: command BTN_PRESSED E failed with error 71 invalid key
* bugfix: API: command IMHISTORYCHANGED didn't work
* bugfix: mute from UI is communicated to API
* bugfix: API: No notification were shown when the user changed audio device
* bugfix: handling URL links in chat improved
* bugfix: Send Contacts: Add Selected button disabled, if contacts are unchecked
* bugfix: Send Contacts: username was displayed twice, if fullname was not chosen
* bugfix: Send Contacts: username and fullame were placed differently on sender's and receiver's side
* bugfix: unchecking Show Emoticons hides emoticons toolbar in IM windows
* bugfix: override old default sound name
* bugfix: addressbar quickfilter did not show all matches on some cases
* bugfix: avatar browser: select added image by default
* bugfix: doubleclicking on last (partially visible item in contactlist) acted on wrong contact
* bugfix: when conference call host runs out of skypeOut credits during call correct error messages are displayed
* bugfix: SkypeIn/SkypeOut error codes are displayed during conference calls
* bugfix: improved SkypeOut links handling in Chat window
* bugfix: installer now tries to shut down skype 10 times instead of 1 during install and uninstall
* bugfix: does not ask auth when adding SkypeOut contacts
* bugfix: possible to add conference participant from addressbar with conference button
* bugfix: going automatically to 'Not Available' status was not working if AutoAway was set to 0
* bugfix: installer uses command 'getnewestversion'
* bugfix: uninstaller behaviour improved
* bugfix: timestamps added to 'click here to see previous messages' link
* bugfix: calltab subtoolbar is now white on windows 2000
* bugfix: added exitsurvey when Skype is uninstalled
* bugfix: some installer web requests contained invalid data
* bugfix: installer reuses language selection
* bugfix: avatar browser did not work with multiple accounts
* bugfix: unicode character sorting was inconsistent
* bugfix: sometimes after a person had left Multi Chat she was still shown in participants list
* bugfix: default style emoticons have timestamps
* bugfix: sometimes number of copied chars were calculated wrong in chat
* bugfix: file transfer notification had missing content in some cases
* bugfix: text highlighting in chat improved
* bugfix: chat '/alerts* mode' does not react to display names
* bugfix: when chosen '/alertson' mode paints the taskbar button orange
* bugfix: if file was renamed before saving, old filename was shown in dialog
* bugfix: user online notification sounds are played to ringing device now
Quelle:skype-forum.com
Moin!
Danke für die Info...
Tach,
Bitte :-)
Töööööööööt
Cu NA-UND
Junge, Junge!
Die langen aber preislich ganz schön zu finde ich, v.a. im Vergleich zu fast allen anderen VoIP-Providern, wo eine FN-Nummer incl. AB nix kostet.
Gut, Skype ist zwar universeller als jede andere VoIP-Software die ich kenne (voice, chat, file transfer, etc.) und die Sprachqualität sucht seines gleichen.
Aber, der Rechner muss eingeschaltet sein (also nix mit spontan mal die Oma anrufen).
Ich finde 25¤/pro Jahr für eine FN-Nummer mit AB bzw. 15¤/pro Jahr nur für den AB sind einfach nicht konkurrenzfähig, zumal die Minutenpreise ja nicht wesentlich günstiger sind als bei anderen VoIP-Providern. Da es momentan keine deutschen Vorwahlen gibt, kommt SkypeIn für mich nicht in Frage. Wer führt schon ein Auslandsgespräch um mit mir in München zu reden? *rethorischFrage* :wink:
Hoffentlich überdenken die Macher nochmal ihre Preispolitik, sonst war die beste Idee und Entwicklung in diesem Bereich für die Katz.
Grüße,
Fozi
Ja, es ist wirklich teuer. Aber - erstens spiele ich gern und zweitens, kann man einmal den Machern von Skype etwas zukommen lassen für die gute Idee, denn zum kostenlosen Telefonieren und Chatten ist die Software (auch von der Sprachqualität) gut. Deswegen habe ich mir die Voicemail von Skype gekauft (auch wenn es andere, billigere Produkte von Drittanbietern gibt und ich die Voicemailbox eigentlich nicht brauche). Wenn mich jetzt jemand in seiner Kontaktliste hat (vermutlich nur die Mutigen mit der neuen Beta Version), dann sieht er, dass ich eine Voicemail habe ;). So, wer will, kann es bei mir testen. Ich werde alle abweisen, so dass sie auf der Voicemailbox landen (bleibt bitte anständig ;)). Wenn mich jemand sprechen will, dann vorher eine Nachricht, sonst geht die VoiceMailbox dran, weil ich denke, ihr wollt testen. Viel Spaß. Mein Skype Username ist: rovin60
Rovin schrieb:
[..] wer will, kann es bei mir testen. [..]
Hi Rovin,
habe dir grad was auf deine Box gesprochen :) allerdings von der aktuellen Linux-Version aus. Ich denke aber mal das ist egal.
Viele Grüße, Clemens
Hm, und ich habe mich schon so gefreut ;). Irgendwie hat es nicht geklappt :(. Aber vielleicht geht es nur, wenn der jenige auf der Kontaktliste ist. jetzt bist du es ja ;)
Kikii
