Skype for Windows: Aktuelle Version 1.4.0.71 (28.09.2005)
Moin! Und Danke <Obi>...
Zur schnelleren Übersicht habe ich das Changelog mal hier reinkopiert, obwohl es diesmal recht lang ist.
Außerdem wurde es jetzt mal Zeit für einen neuen Thread, daher habe ich den Beitrag abgetrennt und natürlich auf wichtig gesetzt...
28.09.2005 version 1.4.0.71
* feature: Call Forwarding
* feature: Skype Test Call Service prepopulated to Contact List for new users
* feature: 21 new emoticons
* feature: My Pictures: possibility to choose pictures from Expressive Content
* feature: RingToneManager for Expressive Content of audio files
* feature: Contact List accessible by Microsoft Active Accessibility
* feature: API: application-to-application communication
* feature: API notifications for contactlist selection and focus
* feature: API: set profile information
* feature: API: call forwarding via API
* feature: API: support expressive content files SET RINGTONE and AVATAR
* feature: API: added OPEN [PROFILE | USERINFO <id> | CONFERENCE | SEARCH | OPTIONS | CALLHISTORY | CONTACTS | DIALPAD | SENDCONTACTS | IMPORTCONTACTS | BLOCKEDUSERS | GETTINGSTARTED | AUTHORIZATION <id>] commands
* feature: multilingual EULA
* feature: advanced Skype links
* feature: number of friends displayed in Profile View form
* feature: possibility to set connecting sound from Options
* feature: added dynamic messages for help and tips
* feature: possibility to select and copy profile fields
* change: new layout for Getting Started Wizard
* change: Search window redesigned
* change: Add friend window redesigned
* Change: Import Contacts redesigned
* change: quicksearch on addressbar improved
* change: improved call related error messagas
* change: 'minimize' button minimizes Skype to taskbar
* change: warning dialaog added when calling to SkypeOut using callto: links
* change: option to disable authorization message popups
* change: MSN contact importer removed from Import Contacts
* change: upgrade prompt supressed if installer is launched with SILENT or VERYSILENT option
* change: removed latin spanish language
* change: option to view online release notes after installation removed
* change: option to create a Quick Launch icon removed from installer
* change: explanatory text in Profile View if user has not been online recently
* change: month names in Profile are translatable
* change: options dialog is changed to nonmodal
* change: Send Authorization dialog is changed to nonmodal
* change: main window minimum size changed
* change: new language files - Swedish (Anders Olsson), Finnish (Heino Keränen), Danish (Mathias Schwarz), Norwegian (Stig Auestad), German (Claudius Henrichs & Dick Schiferli), Dutch (Kees Koenders), French (Fabrice Imperial), Italian (Conte Daniele), Portuguese Brazilian(Anna Nyström ), Hebrew (Ronen Ben-Naftali), Russian (Viktoria Randalainen/Tatjana Kruti), Polish (Ewa Czekalska/Karol Szastok), Spanish - (David Reche), Estonian (Eve Loopere), Japanese (Tomo Suzumaru(Livedoor)/Mayu Shimizu), Greek (Panagiotis Sidiropoulos/Magenta LTD), Chinese Traditional (Morden Chen/PChome Online), Chinese Simplified (Leon Yang/TOM Online), Korean - (Daum Communications Corp), Romanian - (Paraschiv Ion & co), Turkish (Emin Dede) Arabic, Korean (Eriksen Translations Inc), Hungarian (Mark Bender), Bulgarian (Nikolina Filipova, Nikolay Filipov) Czech (Petr Silon)
* bugfix: shortcut to desktop - dropped always, despite preferences
* bugfix: changed sound channel usage,therefore improving the stability on older operating systems
* bugfix: improved Multi Chat behaviour on multiple monitors
* bugfix: authrequests do not pop up if your status is Do Not Disturb
* bugfix: optimized loading of user-language file
* bugfix: optimizations to have faster log-in
* bugfix: improved unicode handling on win98
* bugfix: status was incorrect in chat titlebar when disconnected
* bugfix: improved URL parsing in chat
* bugfix: addressbar search updated when new contact added
* bugfix: 'start skype when windows starts' option will revert to default
* bugfix: 'Enable All Sounds' option missed one checkbox in Options dialog
* bugfix: wrong folder created to Documents and Settings when changing avatar
* bugfix: toolbar texts not visible on clean install
* bugfix: improved error handling when selected sound file is too big
* bugfix: keybaord navigation in language editor
* bugfix: Ctrl+F in chat window shows non-active main window
* bugfix: toolbar buttons were not updated on some cases
* bugfix: API: Error is returned if OPEN ADDAFRIEND command has too many parameters
* bugfix: API: Using query id messed up replies to NAME and OPEN FILETRANSFER commands
* bugfix: API: During voicemail recording SEARCH ACTIVECALLS returned call id
* bugfix: API: When offline user tried to make a call with query id, error was returned without query id
* bugfix: API: Contactlist change notifications were sent when focused contact actually did not change
* bugfix: API: Other API messages were sent before “attach success” message
zvae
