Smartnode 1200 Configuration
biztec
11 Mrz 2007
Hallo Zäme
ich versuche schon seit Stunden das Smartnode 1200 zu konfigurieren.
Doch leider komme ich nicht weiter.
Es ist die Firmware 3.20 Sip Installiert. Das Gerät ist am Port ETH1 hinter dem Router Verbunden.
(Router: 192.168.1.2 - ZyXEL P-2602HWL-D1A ADSL-VoIP-Router für Analog)
(smartnode: 192.168.1.1 - intern 192.168.10.1)
Die Zeit Synchronisieren er einwandfrei. Somit denke ich, habe ich eine Verbindung ins Netz.
# SN1200                                                         #
# R3.20 2007-07-13 SIP                                           #
# 2007-12-26T14:26:23                                            #
# Generated configuration file                                   #
cli version 3.20
gui type basic
dns-relay
webserver port 80 language de
sntp-client
sntp-client server primary 134.214.100.6 port 123 version 4
sntp-client gmt-offset + 01:00:00
system
  ic voice 0
profile acl default
  permit 1 ip any any
profile napt default
profile ppp default
profile tone-set default
profile voip default
  codec 1 g711alaw64k rx-length 30 tx-length 30
  codec 2 g711ulaw64k rx-length 30 tx-length 30
  codec 3 g729 rx-length 30 tx-length 30
  dejitter-mode static
  dejitter-max-delay 120
  fax transmission 1 relay t38-udp
profile pstn default
profile sip default
profile dhcp-server DHCPS_LAN
  network 192.168.1.0 255.255.255.0
  include 1 192.168.1.10 192.168.1.19
  lease 2 hours
  default-router 1 192.168.1.2
  domain-name-server 1 192.168.1.2
  domain-name smartnode.local
profile aaa default
  method 1 local
  method 2 none
context ip router
  interface IF_IP_WAN
    ipaddress dhcp
    use profile acl default in
    use profile acl default out
    use profile napt default
  interface IF_IP_LAN
    ipaddress dhcp
    icmp router-discovery
context ip router
  dhcp-server use DHCPS_LAN
subscriber ppp SUB_PPPOE
context cs switch
  routing-table called-e164 RT_CALL_ROUTING
   route default dest-service SER_HG_PSTN_FALLBACK
    route 0T3 dest-service SER_HG_PSTN_FALLBACK
    route 1T3 dest-interface IF_S0_00
    route 090T3 dest-interface IF_S0_00
    route 080T3 dest-interface IF_S0_00
    route 9T3 dest-interface IF_S0_00 MAP_REMOVE_PREFIX
  routing-table called-e164 RT_INCOMING
    route default dest-interface IF_S0_01 MAP_SIP_2_MSN
  routing-table calling-e164 RT_PHONE_2_SIP
    route default dest-interface IF_SIP_SERVICE CPFN_MSN_2_SIP
  mapping-table called-e164 to called-e164 MAP_SIP_2_MSN
    map SIP 1 to MSN 1
    map SIP 2 to MSN 2
  mapping-table calling-e164 to calling-uri MAP_MSN_2_SIPURI
    map MSN 1 to sip:SIP [email protected]
    map MSN 2 to sip:SIP [email protected]
  mapping-table calling-e164 to calling-e164 MAP_MSN_2_SIP
    map MSN 1 to SIP 1
    map MSN 2 to SIP 2
  mapping-table called-e164 to called-e164 MAP_REMOVE_PREFIX
    map 9(.%) to \1
  complex-function CPFN_MSN_2_SIP
    execute 1 MAP_MSN_2_SIP
    execute 2 MAP_MSN_2_SIPURI
  interface isdn IF_S0_00
    route call dest-interface IF_S0_01
  interface isdn IF_S0_01
    route call dest-table RT_CALL_ROUTING
    isdn-date-time
  interface sip IF_SIP_SERVICE
    bind gateway GW_SIP
    service default
    route call dest-table RT_INCOMING
    use profile voip VOIP
  service hunt-group SER_HG_PSTN_FALLBACK
    timeout 5
    drop-cause normal-unspecified
    drop-cause no-circuit-channel-available
    drop-cause network-out-of-order
    drop-cause temporary-failure
    drop-cause switching-equipment-congestion
    drop-cause access-info-discarded
    drop-cause circuit-channel-not-available
    drop-cause resources-unavailable
    drop-cause no-route-to-destination
    route call 1 dest-table RT_PHONE_2_SIP
    route call 2 dest-interface IF_S0_00
context cs switch
  no shutdown
gateway sip GW_SIP
  no transport tcp
  bind interface IF_IP_WAN router
  service default
    domain voipgateway.org
    authentication SIP 1 password pwd
    authentication SIP 2 password pwd
    registration-lifetime 600
    registrar voipgateway.org 5060
    user SIP 1
    user SIP 2
gateway sip GW_SIP
  no shutdown
port ethernet 0 0
  no shutdown
port ethernet 0 1
  bind interface IF_IP_LAN router
  no shutdown
port bri 0 0
  clock auto
  encapsulation q921
  q921
    protocol pmp
    uni-side auto
    encapsulation q931
    q931
      protocol dss1
      uni-side user
      encapsulation cc-isdn
      bind interface IF_S0_00 switch
port bri 0 0
  no shutdown
port bri 0 1
  clock auto
  encapsulation q921
  q921
    protocol pmp
    uni-side auto
    encapsulation q931
    q931
      protocol dss1
      uni-side net
      bind interface IF_S0_01 switch
port bri 0 1
  no shutdown
und das zeigt es mir an:
State:                                 Up
User Agent:                            0xa94268
Local Address:                         192.168.1.1:5060
Registrations
SIP Registration: 4141xxxxxx (Service: default)
  State:                                Registering
  Registrar:                            sip:212.117.200.148:5060                              "geht auch mit voipgateway.org nicht"
  Default Server:                       sip:212.117.200.148:5060
  Logical Address:                      4141xxxxxxx
  Physical Address:                     4141xxxxxxx (Current: 4141xxxxxxxx)
  Expiration Time:                      600 s
  Authenticated:                        no
SIP Registration: 4141xxxxxxxxx (Service: default)
  State:                                Registering
  Logical Address:                      4141xxxxxxxxx
  Physical Address:                     4141xxxxxxx(Current: 4141xxxxxxxx )
  Authenticated:                        no
Allocated Endpoints:                   0
Allocated Sessions:                    0
Allocated Audio Datapath Controllers:  0
Allocated Packets:                     2
Max Allocated Packets:                 2
Max Allocated Timers:                  8
Edit Guard-X: Bitte Code-Tags verwenden und nicht verlinken, sondern direkt einfügen!
kann mir jemand weiterhelfen???
Besten Dank und Frohe Festtage
Markus
Das scheint normal zu sein. Mir geht es ähnlich.
Laut deiner config nein: Lan ist 192.168.1.0, Wan ist 192.168.10.0
Ich steige selbst noch nicht durch, zuviel Handbuch zu lesen.
Hmpf...........
Aber wenn ich via IP auf das smartnode zugreife, dann
brauch ich die 1.1........ Na ja, ich hab dem Teil nun bei
WAN und LAN dhcp zugewiesen und nun steht in der Log-
Datei:
2007-12-26T11:56:06 : LOGINFO    : DSP driver for 4804 created!
2007-12-26T11:56:06 : LOGINFO    : Using PLD in 2 channel mode (user/net).
2007-12-26T11:56:11 : LOGINFO    : Link up on interface ETH00.
2007-12-26T11:56:29 : LOGINFO    : Link up on interface IF_IP_WAN.
2007-12-26T11:56:30 : LOGINFO    : Link up on interface IF_IP_LAN.
2007-12-26T11:56:30 : LOGINFO    : Link down on interface IF_IP_WAN.
2007-12-26T11:56:30 : LOGINFO    : Link up on interface IF_IP_WAN.
2007-12-26T11:56:31 : LOGINFO    : Auto Configuration (DHCP):
IP Address of interface IF_IP_WAN set to 192.168.1.36
Default gateway set to 192.168.1.2
Added name server 195.186.1.108
Added name server 195.186.4.108
Added name server 212.117.200.68
2007-12-26T11:56:31 : LOGINFO    : Link up on interface bri 0 1
2007-12-26T11:56:48 : LOGINFO    : Warm start.
somit geh ich davon aus, dass es nun stimmt und das Ding
online ist. Es hat jetzt sogar die Nameserver von bluewin drin.
Aber unter SIP-Stauts steht immernoch
State: Registering
Na ja, zum Glück bin ich nich der Einzige der Mühe damit hat.
Ich meld mich sobald ich ne Lösung gefunden hab - und
bitte gib mir bescheid, falls Du eine findest.
Greez Markus
Na also !!
ICH BIN REGISTRIERT !!
Habe nun im smartnode bei WAN und LAN den dhcp
zugewiesen und danach die config anhand von
http://www.guest-support.ch/index.php?_m=knowledgebase&_a=viewarticle&kbarticleid=64
angepasst, aber nur den unteren Teil mit den Tel.Nummern.
Jetzt hab ich nur noch das Problem, dass mein Telefon den
Anruf sofort beendet. Also muss die Verbindung zum Tel noch
falsch eingestellt sein.
Und weiter gehts..............
SIP Registration: sip:4141*****@voipgateway.org (Service: default)
State: Registered
Registrar: sip:voipgateway.org:5060
Default Server: (none)
Logical Address: sip:4141*****@voipgateway.org
Physical Address: sip:4141*****@192.168.1.36:5060 (Current: sip:4141*****@192.168.1.36:5060)
Authenticated: yes
Soweit so gut - scheint online zu sein, doch wenn ich anrufen will,
dann hängt mein Tel nach 15 sek auf und im Display steht << Beendet >>.
Und wenn ich mit dem Handy anrufe, dann dauerts ein weilchen und
dann hängt es selber auf. So wie beim ISDN, wenn kein Tel am NT ist.
Liegt es evt. daran, dass ich kein NT mehr habe ?
Ich nutze den smartnode nur für voip (in diesem Büro), danach kommt er
aber auch noch an ein NT.
Wäre cool, wenn einer einen guten Rat hätte.
1. Schritt weiter
So, nach jedem neustart des Smartnode bin ich nun online !
Aber das kurioseste, nach 10 min bin ich wieder OFFLINE !
Es behält nich mal die Verbindung zum Registrar, obwohl ich am
Telefonieren bin. Hat einer von Euch ne Idee, was das sein könnte ?
Das Smartnode ist max. 10min online, dann heissts wieder "registring"
und "idle/wait" aber passieren tut nix.
Hier ist wohl professionelle Hilfe nötig ;-)
Ist da sonst noch was voip im Netz (z.B. das Zyxel, ich kenne das nicht), das dem SN 1200 den Port streitig macht?
Macht da deine Firewall die Türe wieder zu?
niente nix nüschts nada
Hab Firewall ausgeschaltet und wieder dauerte knapp 10 min und aus die Maus.
Auch hab ich nun zum Test SIP ALG ausgeschaltet, wies der Voip-Provider vorschlug, auch da genau das gleiche.
:bluescre:
dann nimm doch mal die registration-lifetime raus
oder mal auf 60 oder 6000 setzen
holh-66
