[Problem] Smartnode 4639 Call-Routing
JD_
17 Jul 2012
hier kurz mein Aufbau:
Smartnode 4639 mit SIP-Account, 4 Sprachkanäle, 30 Rufnummern. An BRI0 hängt eine alte AGFEO AS33.
Anrufe funktionieren mit dieser Config wunderbar:
# SN4639/5BIS                                                    #
# R6.1 2012-05-09 H323 SIP BRI                                   #
# 2012-07-17T09:18:42                                            #
# SN/XXX                                                #
# Generated configuration file                                   #
cli version 3.20
administrator admin password XXX encrypted
clock local default-offset +00:00
dns-client server XX.XX.XX.XX
dns-relay
webserver port 80 language en
sntp-client
sntp-client server primary XX.XX.XX.XX port 123 version 4
system
  ic voice 0
    low-bitrate-codec g729
system
  clock-source 1 bri 0 0
  clock-source 2 bri 0 1
  clock-source 3 bri 0 2
  clock-source 4 bri 0 3
  clock-source 5 bri 0 4
profile napt NAPT_WAN
profile ppp default
profile tone-set default
profile voip default
  codec 1 g711alaw64k rx-length 20 tx-length 20
  codec 2 g711ulaw64k rx-length 20 tx-length 20
profile pstn default
profile sip default
  no autonomous-transitioning
profile dhcp-server DHCPS_LAN
  network 192.168.1.0 255.255.255.0
  include 1 192.168.1.10 192.168.1.99
  lease 2 hours
  default-router 1 192.168.1.1
  domain-name-server 1 192.168.1.1
profile aaa default
  method 1 local
  method 2 none
context ip router
  interface WAN
    ipaddress XX.XX.XX.XX 255.255.255.248
    tcp adjust-mss rx mtu
    tcp adjust-mss tx mtu
  interface LAN
    ipaddress 192.168.1.1 255.255.255.0
context ip router
  dhcp-server use profile DHCPS_LAN
  route 0.0.0.0 0.0.0.0 XX.XX.XX.XX 0
context cs switch
  routing-table called-e164 RT_TO_SIP
    route T dest-interface IF_SIP
  interface isdn IF_ISDN
    route call dest-table RT_TO_SIP
  interface sip IF_SIP
    bind context sip-gateway GW_SIP
    route call dest-interface IF_ISDN
    remote sip.XXX.de
    address-translation outgoing-call from-header user-part fix 07XXXXXXX10 host-part call
    address-translation incoming-call called-e164 fix XXXXX10
context cs switch
  no shutdown
authentication-service SER_AUTH_OB
  realm 1 sip.XXX.de
  username 0XXXXXXXX10 password XXX encrypted
location-service SER_LOC_CERT
  imperative foreign
  domain 1 sip.XXX.de
  identity 07XXXXXXXX10
    authentication outbound
      authenticate 1 authentication-service SER_AUTH_OB username 07XXXXXXX10
    registration outbound
      registrar sip.XXX.de
      lifetime 60
      register auto
  interface IF_GW_SIP
    bind interface WAN context router port 5060
  bind location-service SER_LOC_CERT
  no shutdown
port ethernet 0 0
  medium auto
  encapsulation ip
  bind interface WAN router
  no shutdown
port ethernet 0 1
  medium auto
  encapsulation ip
  bind interface LAN router
  no shutdown
port bri 0 0
  clock auto
  power-feed
  encapsulation q921
  q921
    permanent-layer2
    uni-side auto
    encapsulation q931
    q931
      protocol dss1
      uni-side net
      bchan-number-order ascending
      encapsulation cc-isdn
      bind interface IF_ISDN switch
port bri 0 0
  no shutdown
port bri 0 1
  clock auto
  encapsulation q921
  q921
    uni-side auto
    encapsulation q931
    q931
      protocol dss1
      uni-side net
port bri 0 1
  shutdown
port bri 0 2
  clock auto
  encapsulation q921
  q921
    uni-side auto
    encapsulation q931
    q931
      protocol dss1
      uni-side net
port bri 0 2
  shutdown
port bri 0 3
  clock auto
  encapsulation q921
  q921
    uni-side auto
    encapsulation q931
    q931
      protocol dss1
      uni-side net
port bri 0 3
  shutdown
port bri 0 4
  clock auto
  encapsulation q921
  q921
    uni-side auto
    encapsulation q931
    q931
      protocol dss1
      uni-side net
port bri 0 4
  shutdown
Jetzt habe ich aber an der AGFEO 2 Telefone (Nebenstelle 11 und 12). Telefon1 geht mit XXXXX11 aus der AGFEO auf die Patton und Telefon2 mit XXXXX12. Zum jetzigen zeitpunkt wird alles zu XXXXX10 von der Patton übersetzt und raus telefoniert. Eingehende Anrufe auf der XXXXX11 und XXXXX12 sind auf der AGFEO auch schon programmiert, aber von der Patton werden alle Anrufe bisher mit XXXXX10 an die AGFEO weitergegeben.
Hier ist auch mein Problem, stehe zur Zeit, glaube ich, ziemlich auf dem Schlauch. Wie bringe ich der Patton bei, dass sie eingehende Anrufe auf 07XXX/XXXXX11 oder XXXXX11 auch mit dieser Nummer an die AGFEO weiter gibt (Entsprechendes mit der XXXXX12). Also, dass die Rufnummernverwaltung komplett die AGFEO übernehmen kann.
Wäre nett, wenn mir jemand von euch hier behilflich sein könnte.
Danke im Voraus.
Du musst in der routing-table called-e164 ein "route XXXXX11 dest-interface X (da wo die AGFEO dran hängt) hinzufügen
Hallo61Hallo
