SX541 Annex A Swiss Model BOOTLOADER
simmons97
10 Jul 2008
I have a Siemens Gigaset SX541 WLAN Annex A, Swiss Model.
I need the bootloader Vers. 0.69.6.
Someone can help me?
The router is always on the page Recovering Tools and led ONLINE and WLAN continue to flash.
Is there any bootloader compatible with Annex A?
Is there a way to reconstruct the original bootloader?
Thanks very much.
Hi Simmons,
did you have found that bootloader?
I need it too!
I need it too for Swiss Annex A...... where is?
Thanks!
It doesn't work with the boot loader 0.69d: now I have the sx-541 always in recovery mode and I can't load any firmware.
I search the original Swiss boot loader 0.69.6 and after (I hope) I'll load firmware 1.30!
THANKS
I have SX541 firmware:1.27b bootcode 0.69.6
Is it the swiss model?
It is annex a.
IF it's the swiss model and I am in Poland
and I want to use a Polish ISP, will it work i Poland?
or do I have to change the firmware?
If yes, what firmware do you recommend?
yes, SMC-FW 2.12 annex A Neostrada works fine.
Someone told me I have to have bootloader ver. 0.69d.0 before I can flash SMC 2.12.
Is this true?
If yes, Can you tell me step by step how to flash the bootloader ver. 0.69d.0.
One more question:will this bootloader version work on my Swiss model?
Thank you for help.
Someone told me I have to have the newer bootloader version 0.69d.0 before I can flash SMC 2.12. Is this true?
If yes, can you tell me step by step how to flash the 0.69d.0 bootloader.
one more quesion, will this bootloader work well on my Swiss model?
Almgandhi
