SX541 file server
Asxetos
27 Feb 2005
I have a usb hard drive attached on the SX541's usb port. Working OK.
I can access the files inside it with no problem from the local network.
Does someone know if the files in the disk can be somehow accessed over the internet?
Thanks...
Hi Asxetos,
normally you should just open the following ports for NetBIOS/SMB-Connections:
135/TCP
137/UDP
138/UDP
139/TCP
445/TCP
This should be all ports which are necessary to do filesharing via smb.
Greetings,
Rob
Thank you Rob...
I will try it.
With the 135/TCP I'm not very sure - it is the endpoint mapper of MS (epmap). It's comparable to the 111 Portmapper of Unix concerning its functionality and it's involved in (almost) every application that sets RPC-calls (Outlook ...). So I think it also should be involved in SMB calls.
Rob
Asxetos,
nomiso oti ftani 135 mechri 139 TCT/UDP, mipos kai 53 TCP/UDP
then eine kalo na anigis perisotero.
Jassu
Klaus
Hello Asxetos,
seems not so very easy to realize to me. The ports are the ports I posted above (135/TCP, 137-138/UDP, 139/TCP and 445/TCP), but it seems to me that the SX541 doesn't bind the exported filesystem to that ports.
Even with an opened firewall, it is not possible to connect, although in a port scan they are marked "open". I think a solution could be a "Host"-setup for the SX541 (like Jockyw did it for testing it behind a router) which means a use as is (without the features which you would like to use - router, WLAN ...)
If you have any news about that, just post it here, but I think, the developers simply didn't have the requirement to also make resources available via Internet at the moment. This might change.
Rob
Grobiroehre
