Telnet to fritz 7050: error with libavmssl.so
Spina
26 Mai 2007
Hi All,
I'm new on this forum and I can not speak in German. So I 'm sorry if maybe I 'm asking for an information already present in the forum.
I have a fritz 7050. When I do a telnet, this following error message periodically is shown:
webcm[...]: couldn't load shared library libavmssl.so. File not found - Succes (0)
I have the last firmware version (14.04.33).
What does it mean? Who can help me ?
Please help me!
Thank you very much.
Ich habe genau die gleiche Meldung
May 27 10:41:06 webcm[762]: Couldn't load shared library libavmssl.so - File not found - Success (0)
Wäre für eine Info dankbar, da diese Meldung alle 30 Sekunden auf der Konsole erscheint (nervtötend, wenn man gerade eine Datei editiert).
@Spina,
found a hint here
If you´re connected with telnet, stop den voip-daemon and then start it again:
voipd -s
voipd -f
In the console ouput you can see your posted error-message.
I think it´s a problem from AVM in the voip-daemon.
No glue to fix it :noidea:
_AAA_
