unschöne meldungen
freisei
30 Mai 2005
bei meinem * (aktuelle bristuff CVS) geht zwar eigentlich alles, es kommen aber immer so komische meldungen:
Jun 14 14:48:43 NOTICE[1918]: chan_sip.c:8320 handle_response: Failed to authenticate on REGISTER to '<sip:[email protected]>;tag=as5edcbd0d'
Jun 14 14:48:44 WARNING[1918]: chan_sip.c:8304 handle_response: Got 200 OK on REGISTER that isn't a register
sip show registry
Host                            Username       Refresh State
sip-gmx.net:5060                498666xxxxxxx       105 Registered
sipgate.de:5060                 6268xxx            105 Registered
*CLI> Jun 14 14:54:59 NOTICE[1918]: chan_sip.c:8320 handle_response: Failed to authenticate on REGISTER to '<sip:[email protected]>;tag=as5c7654e5'
Jun 14 14:54:59 WARNING[1918]: chan_sip.c:8304 handle_response: Got 200 OK on REGISTER that isn't a register
Jun 14 14:56:02 NOTICE[1918]: chan_sip.c:8139 handle_response: Peer 'sipgate' is now TOO LAGGED! (2112ms / 2000ms)
Jun 14 14:56:12 NOTICE[1918]: chan_sip.c:8133 handle_response: Peer 'sipgate' is now REACHABLE! (95ms / 2000ms)
Jun 14 15:01:17 NOTICE[1918]: chan_sip.c:8320 handle_response: Failed to authenticate on REGISTER to '<sip:[email protected]>;tag=as0e22f94b'
Jun 14 15:01:17 WARNING[1918]: chan_sip.c:8304 handle_response: Got 200 OK on REGISTER that isn't a register
sip show peers
Name/username              Host            Dyn Nat ACL Mask             Port     Status
gmx/498666xxxxxxx          212.227.xx.x       N      255.255.255.255  5060     OK (168 ms)
sipgate/626xxxx            217.10.xx.x                 255.255.255.255  5060     OK (1147 ms)
2 sip peers [2 online , 0 offline]
*CLI> Jun 14 15:05:32 NOTICE[1918]: chan_sip.c:9658 sip_poke_noanswer: Peer 'sipgate' is now UNREACHABLE!  Last qualify: 124
Jun 14 15:05:34 WARNING[1918]: chan_sip.c:887 retrans_pkt: Maximum retries exceeded on call [email protected] for seqno 141 (Critical Request)
macht das was, oder kanns sein, dass druch die ständigen Authentifizierungsversuche irgenwann mein SIP-Account ungültig wird?
mfg Freisei
Also - erstmal hast Du ein SIP-Problem, mit ISDN (diese Rubrik hier) hat das nichts zu tun.
Um zu beurteilen können, ob das "kritisch" ist, solltest Du mal Deine SIP.conf posten.
Gratuliere zu deinem 4000stem Post :)
sip.conf:
[general]
context=intern                  ; Default context for incoming calls
;recordhistory=yes              ; Record SIP history by default
                                ; (see sip history / sip no history)
;realm=mydomain.tld             ; Realm for digest authentication
                                ; defaults to "asterisk"
                                ; Realms MUST be globally unique according to RFC 3261
                                ; Set this to your host name or domain name
port=5060                       ; UDPPort to bind to (SIP standard port is 5060)
bindaddr=0.0.0.0                ; IP address to bind to (0.0.0.0 binds to all)
localnet=192.168.1.0/255.255.255.0
srvlookup=yes                   ; Enable DNS SRV lookups on outbound calls
disallow=all                    ; First disallow all codecs
; allow=gsm
register => 6268xxx:[email protected]/6268xxx
register => 498666xxxxxxx:[email protected]/gmx-incoming
; register => USERNAME:[email protected]/web-de-incomming
canreinvite=no
tos=0x18
insecure=very
nat=no
dtmfmode=info
externip = xxx.homelinux.net        ; Address that we're going to put in outbound SIP messages
externhost = xxx.homelinux.net
[sipgate]
type=friend
username=6268xxx
secret=geheim
host=sipgate.de
fromuser=6268952
fromdomain=sipgate.de
context=default
canreinvite=no
qualify=yes
disallow=all
allow=gsm
insecure=very
nat=no
dtmfmode=info
tos=0x18
[gmx]
type=friend
username=498666xxxxxxx
fromuser=498666xxxxxxx
secret=geheim
host=sip-gmx.net
fromdomain=sip-gmx.net
insecure=very
canreinvite=no
disallow=all
allow=g729
allow=g726
allow=gsm
allow=ulaw
; allow=ilbc
; allow=speex
; allow=g723.1
context=intern
qualify=yes
; nat=no ; works, aber kein registry
nat=yes
[c/ode]
Folgende Fehler:
unter general hast du disallow=all und damit alle codecs für eingehende Gespräche disabled (es fehlen die allow= wie unter sipgate bzw. gmx).
Externhost oder externip schliessen sich gegenseitig aus (entweder oder - Empfehlung: externhost=). Ebenso muss nat=yes gesetzt sein.
In den peer-Definitionen jedoch nat=no und außerdem solltest du das 'qualify=' auf no belassen!
IchBinEsDoch
