ich habe nach folgender Vorlage die VPN Verbindung versucht herzustellen:
http://www.ip-phone-forum.de/showpost.php?p=438150&postcount=66
Server und Client config Dateien sind ähnlich (wie oben). Beim Verbinden werden folgende Meldungen erzeugt:
Wenn ich die Client Config Datei so abändere:
kommt folgende Meldung:
Die letzte Fehlermeldung(en) versteh ich nicht. Selbst googeln hilft nichts. Hat jemand Ahnung und kann mir weiterhelfen?
Fri Feb 24 22:57:58 2006 Warning on use of --daemon/--inetd: this operating system lacks daemon logging features, therefore when I become a daemon, I won't be able to log status or error messages
Fri Feb 24 22:57:58 2006 us=617219 Current Parameter Settings:
Fri Feb 24 22:57:58 2006 us=617245 config = 'fritzbox.ovpn'
Fri Feb 24 22:57:58 2006 us=617263 mode = 0
Fri Feb 24 22:57:58 2006 us=617281 show_ciphers = DISABLED
Fri Feb 24 22:57:58 2006 us=617299 show_digests = DISABLED
Fri Feb 24 22:57:58 2006 us=617317 show_engines = DISABLED
Fri Feb 24 22:57:58 2006 us=617334 genkey = DISABLED
Fri Feb 24 22:57:58 2006 us=617351 key_pass_file = '[UNDEF]'
Fri Feb 24 22:57:58 2006 us=617370 show_tls_ciphers = DISABLED
Fri Feb 24 22:57:58 2006 us=617387 proto = 2
Fri Feb 24 22:57:58 2006 us=617404 local = '[UNDEF]'
Fri Feb 24 22:57:58 2006 us=617425 remote_list[0] = {'xxxxxx.dyndns.org', 1194}
Fri Feb 24 22:57:58 2006 us=617444 remote_random = DISABLED
Fri Feb 24 22:57:58 2006 us=617461 local_port = 1194
Fri Feb 24 22:57:58 2006 us=617479 remote_port = 1194
Fri Feb 24 22:57:58 2006 us=617496 remote_float = DISABLED
Fri Feb 24 22:57:58 2006 us=617514 ipchange = '[UNDEF]'
Fri Feb 24 22:57:58 2006 us=617531 bind_local = ENABLED
Fri Feb 24 22:57:58 2006 us=617548 dev = 'tun'
Fri Feb 24 22:57:58 2006 us=617565 dev_type = '[UNDEF]'
Fri Feb 24 22:57:58 2006 us=617582 dev_node = '[UNDEF]'
Fri Feb 24 22:57:58 2006 us=617600 tun_ipv6 = DISABLED
Fri Feb 24 22:57:58 2006 us=617617 ifconfig_local = '192.168.178.1'
Fri Feb 24 22:57:58 2006 us=617636 ifconfig_remote_netmask = '192.168.178.2'
Fri Feb 24 22:57:58 2006 us=617655 ifconfig_noexec = DISABLED
Fri Feb 24 22:57:58 2006 us=617673 ifconfig_nowarn = DISABLED
Fri Feb 24 22:57:58 2006 us=617691 shaper = 0
Fri Feb 24 22:57:58 2006 us=617708 tun_mtu = 1500
Fri Feb 24 22:57:58 2006 us=617725 tun_mtu_defined = ENABLED
Fri Feb 24 22:57:58 2006 us=617743 link_mtu = 1500
Fri Feb 24 22:57:58 2006 us=617760 link_mtu_defined = DISABLED
Fri Feb 24 22:57:58 2006 us=617778 tun_mtu_extra = 0
Fri Feb 24 22:57:58 2006 us=617796 tun_mtu_extra_defined = DISABLED
Fri Feb 24 22:57:58 2006 us=617813 fragment = 0
Fri Feb 24 22:57:58 2006 us=617830 mtu_discover_type = -1
Fri Feb 24 22:57:58 2006 us=617849 mtu_test = 0
Fri Feb 24 22:57:58 2006 us=617867 mlock = DISABLED
Fri Feb 24 22:57:58 2006 us=617884 keepalive_ping = 0
Fri Feb 24 22:57:58 2006 us=617902 keepalive_timeout = 0
Fri Feb 24 22:57:58 2006 us=617920 inactivity_timeout = 0
Fri Feb 24 22:57:58 2006 us=617938 ping_send_timeout = 15
Fri Feb 24 22:57:58 2006 us=617957 ping_rec_timeout = 120
Fri Feb 24 22:57:58 2006 us=617975 ping_rec_timeout_action = 2
Fri Feb 24 22:57:58 2006 us=617993 ping_timer_remote = DISABLED
Fri Feb 24 22:57:58 2006 us=618011 remap_sigusr1 = 0
Fri Feb 24 22:57:58 2006 us=618030 explicit_exit_notification = 0
Fri Feb 24 22:57:58 2006 us=618049 persist_tun = ENABLED
Fri Feb 24 22:57:58 2006 us=618067 persist_local_ip = DISABLED
Fri Feb 24 22:57:58 2006 us=618086 persist_remote_ip = DISABLED
Fri Feb 24 22:57:58 2006 us=618105 persist_key = ENABLED
Fri Feb 24 22:57:58 2006 us=618122 mssfix = 1450
Fri Feb 24 22:57:58 2006 us=618141 resolve_retry_seconds = 60
Fri Feb 24 22:57:58 2006 us=618160 connect_retry_seconds = 5
Fri Feb 24 22:57:58 2006 us=618187 username = '[UNDEF]'
Fri Feb 24 22:57:58 2006 us=618205 groupname = '[UNDEF]'
Fri Feb 24 22:57:58 2006 us=618223 chroot_dir = '[UNDEF]'
Fri Feb 24 22:57:58 2006 us=618251 cd_dir = '[UNDEF]'
Fri Feb 24 22:57:58 2006 us=618269 writepid = '[UNDEF]'
Fri Feb 24 22:57:58 2006 us=618286 up_script = '[UNDEF]'
Fri Feb 24 22:57:58 2006 us=618305 down_script = '[UNDEF]'
Fri Feb 24 22:57:58 2006 us=618324 down_pre = DISABLED
Fri Feb 24 22:57:58 2006 us=618341 up_restart = DISABLED
Fri Feb 24 22:57:58 2006 us=618359 up_delay = DISABLED
Fri Feb 24 22:57:58 2006 us=618377 daemon = ENABLED
Fri Feb 24 22:57:58 2006 us=618394 inetd = 0
Fri Feb 24 22:57:58 2006 us=764960 log = DISABLED
Fri Feb 24 22:57:58 2006 us=764990 suppress_timestamps = DISABLED
Fri Feb 24 22:57:58 2006 us=765008 nice = 0
Fri Feb 24 22:57:58 2006 us=765025 verbosity = 4
Fri Feb 24 22:57:58 2006 us=765041 mute = 0
Fri Feb 24 22:57:58 2006 us=765057 gremlin = 0
Fri Feb 24 22:57:58 2006 us=765075 status_file = '[UNDEF]'
Fri Feb 24 22:57:58 2006 us=765092 status_file_version = 1
Fri Feb 24 22:57:58 2006 us=765110 status_file_update_freq = 60
Fri Feb 24 22:57:58 2006 us=765127 occ = ENABLED
Fri Feb 24 22:57:58 2006 us=765143 rcvbuf = 0
Fri Feb 24 22:57:58 2006 us=765159 sndbuf = 0
Fri Feb 24 22:57:58 2006 us=765177 socks_proxy_server = '[UNDEF]'
Fri Feb 24 22:57:58 2006 us=765195 socks_proxy_port = 0
Fri Feb 24 22:57:58 2006 us=765213 socks_proxy_retry = DISABLED
Fri Feb 24 22:57:58 2006 us=765230 fast_io = DISABLED
Fri Feb 24 22:57:58 2006 us=765247 comp_lzo = DISABLED
Fri Feb 24 22:57:58 2006 us=765264 comp_lzo_adaptive = ENABLED
Fri Feb 24 22:57:58 2006 us=778593 route_script = '[UNDEF]'
Fri Feb 24 22:57:58 2006 us=778623 route_default_gateway = '[UNDEF]'
Fri Feb 24 22:57:58 2006 us=778641 route_noexec = DISABLED
Fri Feb 24 22:57:58 2006 us=778658 route_delay = 0
Fri Feb 24 22:57:58 2006 us=778676 route_delay_window = 30
Fri Feb 24 22:57:58 2006 us=778693 route_delay_defined = ENABLED
Fri Feb 24 22:57:58 2006 us=778721 route 192.168.178.0/255.255.255.0/nil/nil
Fri Feb 24 22:57:58 2006 us=778741 management_addr = '[UNDEF]'
Fri Feb 24 22:57:58 2006 us=778758 management_port = 0
Fri Feb 24 22:57:58 2006 us=778776 management_user_pass = '[UNDEF]'
Fri Feb 24 22:57:58 2006 us=778795 management_log_history_cache = 250
Fri Feb 24 22:57:58 2006 us=778814 management_echo_buffer_size = 100
Fri Feb 24 22:57:58 2006 us=778832 management_query_passwords = DISABLED
Fri Feb 24 22:57:58 2006 us=778850 management_hold = DISABLED
Fri Feb 24 22:57:58 2006 us=778869 shared_secret_file = 'secret.key'
Fri Feb 24 22:57:58 2006 us=803422 key_direction = 0
Fri Feb 24 22:57:58 2006 us=803448 ciphername_defined = ENABLED
Fri Feb 24 22:57:58 2006 us=803467 ciphername = 'BF-CBC'
Fri Feb 24 22:57:58 2006 us=803485 authname_defined = ENABLED
Fri Feb 24 22:57:58 2006 us=803502 authname = 'SHA1'
Fri Feb 24 22:57:58 2006 us=803519 keysize = 0
Fri Feb 24 22:57:58 2006 us=803536 engine = DISABLED
Fri Feb 24 22:57:58 2006 us=803552 replay = ENABLED
Fri Feb 24 22:57:58 2006 us=803570 mute_replay_warnings = DISABLED
Fri Feb 24 22:57:58 2006 us=803588 replay_window = 0
Fri Feb 24 22:57:58 2006 us=803605 replay_time = 0
Fri Feb 24 22:57:58 2006 us=803622 packet_id_file = '[UNDEF]'
Fri Feb 24 22:57:58 2006 us=803639 use_iv = ENABLED
Fri Feb 24 22:57:58 2006 us=803656 test_crypto = DISABLED
Fri Feb 24 22:57:58 2006 us=803674 tls_server = DISABLED
Fri Feb 24 22:57:58 2006 us=803691 tls_client = DISABLED
Fri Feb 24 22:57:58 2006 us=803708 key_method = 2
Fri Feb 24 22:57:58 2006 us=828896 ca_file = '[UNDEF]'
Fri Feb 24 22:57:58 2006 us=828921 dh_file = '[UNDEF]'
Fri Feb 24 22:57:58 2006 us=828939 cert_file = '[UNDEF]'
Fri Feb 24 22:57:58 2006 us=828957 priv_key_file = '[UNDEF]'
Fri Feb 24 22:57:58 2006 us=828974 pkcs12_file = '[UNDEF]'
Fri Feb 24 22:57:58 2006 us=828991 cryptoapi_cert = '[UNDEF]'
Fri Feb 24 22:57:58 2006 us=829009 cipher_list = '[UNDEF]'
Fri Feb 24 22:57:58 2006 us=829026 tls_verify = '[UNDEF]'
Fri Feb 24 22:57:58 2006 us=829044 tls_remote = '[UNDEF]'
Fri Feb 24 22:57:58 2006 us=829061 crl_file = '[UNDEF]'
Fri Feb 24 22:57:58 2006 us=829078 ns_cert_type = 0
Fri Feb 24 22:57:58 2006 us=829095 tls_timeout = 2
Fri Feb 24 22:57:58 2006 us=829112 renegotiate_bytes = 0
Fri Feb 24 22:57:58 2006 us=829138 renegotiate_packets = 0
Fri Feb 24 22:57:58 2006 us=829156 renegotiate_seconds = 3600
Fri Feb 24 22:57:58 2006 us=829173 handshake_window = 60
Fri Feb 24 22:57:58 2006 us=857103 transition_window = 3600
Fri Feb 24 22:57:58 2006 us=857130 single_session = DISABLED
Fri Feb 24 22:57:58 2006 us=857148 tls_exit = DISABLED
Fri Feb 24 22:57:58 2006 us=857165 tls_auth_file = '[UNDEF]'
Fri Feb 24 22:57:58 2006 us=857200 server_network = 0.0.0.0
Fri Feb 24 22:57:58 2006 us=857220 server_netmask = 0.0.0.0
Fri Feb 24 22:57:58 2006 us=857240 server_bridge_ip = 0.0.0.0
Fri Feb 24 22:57:58 2006 us=857259 server_bridge_netmask = 0.0.0.0
Fri Feb 24 22:57:58 2006 us=857279 server_bridge_pool_start = 0.0.0.0
Fri Feb 24 22:57:58 2006 us=857299 server_bridge_pool_end = 0.0.0.0
Fri Feb 24 22:57:58 2006 us=857318 ifconfig_pool_defined = DISABLED
Fri Feb 24 22:57:58 2006 us=857338 ifconfig_pool_start = 0.0.0.0
Fri Feb 24 22:57:58 2006 us=857357 ifconfig_pool_end = 0.0.0.0
Fri Feb 24 22:57:58 2006 us=857377 ifconfig_pool_netmask = 0.0.0.0
Fri Feb 24 22:57:58 2006 us=857396 ifconfig_pool_persist_filename = '[UNDEF]'
Fri Feb 24 22:57:58 2006 us=894672 ifconfig_pool_persist_refresh_freq = 600
Fri Feb 24 22:57:58 2006 us=894701 ifconfig_pool_linear = DISABLED
Fri Feb 24 22:57:58 2006 us=894720 n_bcast_buf = 256
Fri Feb 24 22:57:58 2006 us=894737 tcp_queue_limit = 64
Fri Feb 24 22:57:58 2006 us=894754 real_hash_size = 256
Fri Feb 24 22:57:58 2006 us=894772 virtual_hash_size = 256
Fri Feb 24 22:57:58 2006 us=894791 client_connect_script = '[UNDEF]'
Fri Feb 24 22:57:58 2006 us=894809 learn_address_script = '[UNDEF]'
Fri Feb 24 22:57:58 2006 us=894827 client_disconnect_script = '[UNDEF]'
Fri Feb 24 22:57:58 2006 us=894846 client_config_dir = '[UNDEF]'
Fri Feb 24 22:57:58 2006 us=894864 ccd_exclusive = DISABLED
Fri Feb 24 22:57:58 2006 us=894881 tmp_dir = '[UNDEF]'
Fri Feb 24 22:57:58 2006 us=894899 push_ifconfig_defined = DISABLED
Fri Feb 24 22:57:58 2006 us=894921 push_ifconfig_local = 0.0.0.0
Fri Feb 24 22:57:58 2006 us=894941 push_ifconfig_remote_netmask = 0.0.0.0
Fri Feb 24 22:57:58 2006 us=919972 enable_c2c = DISABLED
Fri Feb 24 22:57:58 2006 us=919989 duplicate_cn = DISABLED
Fri Feb 24 22:57:58 2006 us=919999 cf_max = 0
Fri Feb 24 22:57:58 2006 us=920007 cf_per = 0
Fri Feb 24 22:57:58 2006 us=920016 max_clients = 1024
Fri Feb 24 22:57:58 2006 us=920025 max_routes_per_client = 256
Fri Feb 24 22:57:58 2006 us=920034 client_cert_not_required = DISABLED
Fri Feb 24 22:57:58 2006 us=920044 username_as_common_name = DISABLED
Fri Feb 24 22:57:58 2006 us=920053 auth_user_pass_verify_script = '[UNDEF]'
Fri Feb 24 22:57:58 2006 us=920063 auth_user_pass_verify_script_via_file = DISABLED
Fri Feb 24 22:57:58 2006 us=920073 client = DISABLED
Fri Feb 24 22:57:58 2006 us=920081 pull = DISABLED
Fri Feb 24 22:57:58 2006 us=920090 auth_user_pass_file = '[UNDEF]'
Fri Feb 24 22:57:58 2006 us=920102 show_net_up = DISABLED
Fri Feb 24 22:57:58 2006 us=920111 route_method = 0
Fri Feb 24 22:57:58 2006 us=939926 ip_win32_defined = DISABLED
Fri Feb 24 22:57:58 2006 us=939941 ip_win32_type = 3
Fri Feb 24 22:57:58 2006 us=939950 dhcp_masq_offset = 0
Fri Feb 24 22:57:58 2006 us=939960 dhcp_lease_time = 31536000
Fri Feb 24 22:57:58 2006 us=939968 tap_sleep = 0
Fri Feb 24 22:57:58 2006 us=939977 dhcp_options = DISABLED
Fri Feb 24 22:57:58 2006 us=939986 dhcp_renew = DISABLED
Fri Feb 24 22:57:58 2006 us=939995 dhcp_pre_release = DISABLED
Fri Feb 24 22:57:58 2006 us=940004 dhcp_release = DISABLED
Fri Feb 24 22:57:58 2006 us=940012 domain = '[UNDEF]'
Fri Feb 24 22:57:58 2006 us=940021 netbios_scope = '[UNDEF]'
Fri Feb 24 22:57:58 2006 us=940030 netbios_node_type = 0
Fri Feb 24 22:57:58 2006 us=940038 disable_nbt = DISABLED
Fri Feb 24 22:57:58 2006 us=940057 OpenVPN 2.0.5 Win32-MinGW [SSL] [LZO] built on Nov 2 2005
Fri Feb 24 22:57:58 2006 us=940551 Static Encrypt: Cipher 'BF-CBC' initialized with 128 bit key
Fri Feb 24 22:57:58 2006 us=963643 Static Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Fri Feb 24 22:57:58 2006 us=963735 Static Decrypt: Cipher 'BF-CBC' initialized with 128 bit key
Fri Feb 24 22:57:58 2006 us=963751 Static Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Fri Feb 24 22:57:59 2006 us=95984 TAP-WIN32 device [OpenVPN Home] opened: \\.\Global\{974C6733-889C-4FE6-9188-91FB6FCF6D54}.tap
Fri Feb 24 22:57:59 2006 us=97295 TAP-Win32 Driver Version 8.1
Fri Feb 24 22:57:59 2006 us=98505 TAP-Win32 MTU=1500
Fri Feb 24 22:57:59 2006 us=99721 Notified TAP-Win32 driver to set a DHCP IP/netmask of 192.168.178.1/255.255.255.252 on interface {974C6733-889C-4FE6-9188-91FB6FCF6D54} [DHCP-serv: 192.168.178.2, lease-time: 31536000]
Fri Feb 24 22:57:59 2006 us=107104 Successful ARP Flush on interface [4] {974C6733-889C-4FE6-9188-91FB6FCF6D54}
Fri Feb 24 22:57:59 2006 us=113972 Data Channel MTU parms [ L:1546 D:1450 EF:46 EB:4 ET:0 EL:0 ]
Fri Feb 24 22:57:59 2006 us=114023 Local Options String: 'V4,dev-type tun,link-mtu 1546,tun-mtu 1500,proto TCPv4_CLIENT,ifconfig 192.168.178.2 192.168.178.1,cipher BF-CBC,auth SHA1,keysize 128,secret'
Fri Feb 24 22:57:59 2006 us=114036 Expected Remote Options String: 'V4,dev-type tun,link-mtu 1546,tun-mtu 1500,proto TCPv4_SERVER,ifconfig 192.168.178.1 192.168.178.2,cipher BF-CBC,auth SHA1,keysize 128,secret'
Fri Feb 24 22:57:59 2006 us=114073 Local Options hash (VER=V4): '71de0147'
Fri Feb 24 22:57:59 2006 us=114090 Expected Remote Options hash (VER=V4): '7e929492'
Fri Feb 24 22:57:59 2006 us=114105 Sorry but I can't become a daemon because this operating system doesn't appear to support either the daemon() or fork() system calls
Fri Feb 24 22:57:59 2006 us=114115 Exiting
dev tun
# dev-node /dev/misc/net/tun
tun-mtu 1500
mssfix
persist-tun
persist-key
#Remote Adresse des Servers angeben
#muss entsprechend geaendert werden
remote tgreisinger.dyndns.org
#Pfad zum Key File
secret secret.key
#Protokoll auf TCP und Port 1194
#Änderungen müssen auf Client und Server Seite gleich sein
proto tcp-client
port 1194
#da die Verbindung alle 24 Stunden getrennt wird
#soll regelmäßig kontrolliert werden ob die Verbindung noch steht
ping 15
ping-restart 120
#der DynDNS Name soll alle 60 Sekunden neu aufgelöst werden
#da OpenVPN sonst ständig versucht über die alte IP
#zu verbinden
resolv-retry 60
#Protokollierungseinstellung
#4 ist optimaler Modus
verb 4
#Daemon sollte erst eingeschaltet werden wenn die
#Konfiguration passt
# daemon (das war vorher drin)
#Route zum Server setzen
route 192.168.178.0 255.255.255.0
Fri Feb 24 23:11:28 2006 us=861715 Current Parameter Settings:
Fri Feb 24 23:11:28 2006 us=861786 config = 'fritzbox.ovpn'
Fri Feb 24 23:11:28 2006 us=861805 mode = 0
Fri Feb 24 23:11:28 2006 us=861824 show_ciphers = DISABLED
Fri Feb 24 23:11:28 2006 us=861842 show_digests = DISABLED
Fri Feb 24 23:11:28 2006 us=861859 show_engines = DISABLED
Fri Feb 24 23:11:28 2006 us=861877 genkey = DISABLED
Fri Feb 24 23:11:28 2006 us=861894 key_pass_file = '[UNDEF]'
Fri Feb 24 23:11:28 2006 us=861912 show_tls_ciphers = DISABLED
Fri Feb 24 23:11:28 2006 us=861929 proto = 2
Fri Feb 24 23:11:28 2006 us=861946 local = '[UNDEF]'
Fri Feb 24 23:11:28 2006 us=861966 remote_list[0] = {'xxxxxxx.dyndns.org', 1194}
Fri Feb 24 23:11:28 2006 us=861985 remote_random = DISABLED
Fri Feb 24 23:11:28 2006 us=862003 local_port = 1194
Fri Feb 24 23:11:28 2006 us=862020 remote_port = 1194
Fri Feb 24 23:11:28 2006 us=862038 remote_float = DISABLED
Fri Feb 24 23:11:28 2006 us=862055 ipchange = '[UNDEF]'
Fri Feb 24 23:11:28 2006 us=862073 bind_local = ENABLED
Fri Feb 24 23:11:28 2006 us=862090 dev = 'tun'
Fri Feb 24 23:11:28 2006 us=862107 dev_type = '[UNDEF]'
Fri Feb 24 23:11:28 2006 us=862131 dev_node = '[UNDEF]'
Fri Feb 24 23:11:28 2006 us=862149 tun_ipv6 = DISABLED
Fri Feb 24 23:11:28 2006 us=862168 ifconfig_local = '192.168.178.1'
Fri Feb 24 23:11:28 2006 us=862187 ifconfig_remote_netmask = '192.168.178.2'
Fri Feb 24 23:11:28 2006 us=862206 ifconfig_noexec = DISABLED
Fri Feb 24 23:11:28 2006 us=862224 ifconfig_nowarn = DISABLED
Fri Feb 24 23:11:28 2006 us=862241 shaper = 0
Fri Feb 24 23:11:28 2006 us=862258 tun_mtu = 1500
Fri Feb 24 23:11:28 2006 us=862276 tun_mtu_defined = ENABLED
Fri Feb 24 23:11:28 2006 us=862294 link_mtu = 1500
Fri Feb 24 23:11:28 2006 us=862312 link_mtu_defined = DISABLED
Fri Feb 24 23:11:28 2006 us=862330 tun_mtu_extra = 0
Fri Feb 24 23:11:28 2006 us=862349 tun_mtu_extra_defined = DISABLED
Fri Feb 24 23:11:28 2006 us=862367 fragment = 0
Fri Feb 24 23:11:28 2006 us=862385 mtu_discover_type = -1
Fri Feb 24 23:11:28 2006 us=862402 mtu_test = 0
Fri Feb 24 23:11:28 2006 us=862419 mlock = DISABLED
Fri Feb 24 23:11:28 2006 us=862436 keepalive_ping = 0
Fri Feb 24 23:11:28 2006 us=862455 keepalive_timeout = 0
Fri Feb 24 23:11:28 2006 us=862473 inactivity_timeout = 0
Fri Feb 24 23:11:28 2006 us=862491 ping_send_timeout = 15
Fri Feb 24 23:11:28 2006 us=862509 ping_rec_timeout = 120
Fri Feb 24 23:11:28 2006 us=862528 ping_rec_timeout_action = 2
Fri Feb 24 23:11:28 2006 us=862546 ping_timer_remote = DISABLED
Fri Feb 24 23:11:28 2006 us=862564 remap_sigusr1 = 0
Fri Feb 24 23:11:28 2006 us=862583 explicit_exit_notification = 0
Fri Feb 24 23:11:28 2006 us=862601 persist_tun = ENABLED
Fri Feb 24 23:11:28 2006 us=862619 persist_local_ip = DISABLED
Fri Feb 24 23:11:28 2006 us=862638 persist_remote_ip = DISABLED
Fri Feb 24 23:11:28 2006 us=862656 persist_key = ENABLED
Fri Feb 24 23:11:28 2006 us=862674 mssfix = 1450
Fri Feb 24 23:11:28 2006 us=862692 resolve_retry_seconds = 60
Fri Feb 24 23:11:28 2006 us=862710 connect_retry_seconds = 5
Fri Feb 24 23:11:28 2006 us=862737 username = '[UNDEF]'
Fri Feb 24 23:11:28 2006 us=862757 groupname = '[UNDEF]'
Fri Feb 24 23:11:28 2006 us=862775 chroot_dir = '[UNDEF]'
Fri Feb 24 23:11:28 2006 us=862793 cd_dir = '[UNDEF]'
Fri Feb 24 23:11:28 2006 us=862811 writepid = '[UNDEF]'
Fri Feb 24 23:11:28 2006 us=862829 up_script = '[UNDEF]'
Fri Feb 24 23:11:28 2006 us=862848 down_script = '[UNDEF]'
Fri Feb 24 23:11:28 2006 us=862866 down_pre = DISABLED
Fri Feb 24 23:11:28 2006 us=862884 up_restart = DISABLED
Fri Feb 24 23:11:28 2006 us=862902 up_delay = DISABLED
Fri Feb 24 23:11:28 2006 us=862920 daemon = DISABLED
Fri Feb 24 23:11:28 2006 us=862937 inetd = 0
Fri Feb 24 23:11:28 2006 us=862954 log = DISABLED
Fri Feb 24 23:11:28 2006 us=862973 suppress_timestamps = DISABLED
Fri Feb 24 23:11:28 2006 us=862991 nice = 0
Fri Feb 24 23:11:28 2006 us=863008 verbosity = 4
Fri Feb 24 23:11:28 2006 us=969263 mute = 0
Fri Feb 24 23:11:28 2006 us=969280 gremlin = 0
Fri Feb 24 23:11:28 2006 us=969289 status_file = '[UNDEF]'
Fri Feb 24 23:11:28 2006 us=969298 status_file_version = 1
Fri Feb 24 23:11:28 2006 us=969308 status_file_update_freq = 60
Fri Feb 24 23:11:28 2006 us=969316 occ = ENABLED
Fri Feb 24 23:11:28 2006 us=969325 rcvbuf = 0
Fri Feb 24 23:11:28 2006 us=969333 sndbuf = 0
Fri Feb 24 23:11:28 2006 us=969343 socks_proxy_server = '[UNDEF]'
Fri Feb 24 23:11:28 2006 us=969352 socks_proxy_port = 0
Fri Feb 24 23:11:28 2006 us=969361 socks_proxy_retry = DISABLED
Fri Feb 24 23:11:28 2006 us=969370 fast_io = DISABLED
Fri Feb 24 23:11:28 2006 us=969378 comp_lzo = DISABLED
Fri Feb 24 23:11:28 2006 us=969387 comp_lzo_adaptive = ENABLED
Fri Feb 24 23:11:28 2006 us=969401 route_script = '[UNDEF]'
Fri Feb 24 23:11:28 2006 us=969411 route_default_gateway = '[UNDEF]'
Fri Feb 24 23:11:28 2006 us=969420 route_noexec = DISABLED
Fri Feb 24 23:11:28 2006 us=974908 route_delay = 0
Fri Feb 24 23:11:28 2006 us=974922 route_delay_window = 30
Fri Feb 24 23:11:28 2006 us=974931 route_delay_defined = ENABLED
Fri Feb 24 23:11:28 2006 us=974948 route 192.168.178.0/255.255.255.0/nil/nil
Fri Feb 24 23:11:28 2006 us=974958 management_addr = '[UNDEF]'
Fri Feb 24 23:11:28 2006 us=974967 management_port = 0
Fri Feb 24 23:11:28 2006 us=974976 management_user_pass = '[UNDEF]'
Fri Feb 24 23:11:28 2006 us=974986 management_log_history_cache = 250
Fri Feb 24 23:11:28 2006 us=974995 management_echo_buffer_size = 100
Fri Feb 24 23:11:28 2006 us=975005 management_query_passwords = DISABLED
Fri Feb 24 23:11:28 2006 us=975014 management_hold = DISABLED
Fri Feb 24 23:11:28 2006 us=975023 shared_secret_file = 'secret.key'
Fri Feb 24 23:11:28 2006 us=975032 key_direction = 0
Fri Feb 24 23:11:28 2006 us=975041 ciphername_defined = ENABLED
Fri Feb 24 23:11:28 2006 us=975050 ciphername = 'BF-CBC'
Fri Feb 24 23:11:28 2006 us=990591 authname_defined = ENABLED
Fri Feb 24 23:11:28 2006 us=990607 authname = 'SHA1'
Fri Feb 24 23:11:28 2006 us=990616 keysize = 0
Fri Feb 24 23:11:28 2006 us=990625 engine = DISABLED
Fri Feb 24 23:11:28 2006 us=990633 replay = ENABLED
Fri Feb 24 23:11:28 2006 us=990642 mute_replay_warnings = DISABLED
Fri Feb 24 23:11:28 2006 us=990651 replay_window = 0
Fri Feb 24 23:11:28 2006 us=990660 replay_time = 0
Fri Feb 24 23:11:28 2006 us=990669 packet_id_file = '[UNDEF]'
Fri Feb 24 23:11:28 2006 us=990677 use_iv = ENABLED
Fri Feb 24 23:11:28 2006 us=990686 test_crypto = DISABLED
Fri Feb 24 23:11:28 2006 us=990695 tls_server = DISABLED
Fri Feb 24 23:11:28 2006 us=990703 tls_client = DISABLED
Fri Feb 24 23:11:28 2006 us=990712 key_method = 2
Fri Feb 24 23:11:28 2006 us=990721 ca_file = '[UNDEF]'
Fri Feb 24 23:11:28 2006 us=990730 dh_file = '[UNDEF]'
Fri Feb 24 23:11:29 2006 us=7992 cert_file = '[UNDEF]'
Fri Feb 24 23:11:29 2006 us=8008 priv_key_file = '[UNDEF]'
Fri Feb 24 23:11:29 2006 us=8017 pkcs12_file = '[UNDEF]'
Fri Feb 24 23:11:29 2006 us=8025 cryptoapi_cert = '[UNDEF]'
Fri Feb 24 23:11:29 2006 us=8034 cipher_list = '[UNDEF]'
Fri Feb 24 23:11:29 2006 us=8043 tls_verify = '[UNDEF]'
Fri Feb 24 23:11:29 2006 us=8052 tls_remote = '[UNDEF]'
Fri Feb 24 23:11:29 2006 us=8061 crl_file = '[UNDEF]'
Fri Feb 24 23:11:29 2006 us=8069 ns_cert_type = 0
Fri Feb 24 23:11:29 2006 us=8078 tls_timeout = 2
Fri Feb 24 23:11:29 2006 us=8086 renegotiate_bytes = 0
Fri Feb 24 23:11:29 2006 us=8095 renegotiate_packets = 0
Fri Feb 24 23:11:29 2006 us=8104 renegotiate_seconds = 3600
Fri Feb 24 23:11:29 2006 us=8112 handshake_window = 60
Fri Feb 24 23:11:29 2006 us=8121 transition_window = 3600
Fri Feb 24 23:11:29 2006 us=8129 single_session = DISABLED
Fri Feb 24 23:11:29 2006 us=8138 tls_exit = DISABLED
Fri Feb 24 23:11:29 2006 us=25456 tls_auth_file = '[UNDEF]'
Fri Feb 24 23:11:29 2006 us=25483 server_network = 0.0.0.0
Fri Feb 24 23:11:29 2006 us=25494 server_netmask = 0.0.0.0
Fri Feb 24 23:11:29 2006 us=25504 server_bridge_ip = 0.0.0.0
Fri Feb 24 23:11:29 2006 us=25514 server_bridge_netmask = 0.0.0.0
Fri Feb 24 23:11:29 2006 us=25524 server_bridge_pool_start = 0.0.0.0
Fri Feb 24 23:11:29 2006 us=25534 server_bridge_pool_end = 0.0.0.0
Fri Feb 24 23:11:29 2006 us=25543 ifconfig_pool_defined = DISABLED
Fri Feb 24 23:11:29 2006 us=25553 ifconfig_pool_start = 0.0.0.0
Fri Feb 24 23:11:29 2006 us=25563 ifconfig_pool_end = 0.0.0.0
Fri Feb 24 23:11:29 2006 us=25573 ifconfig_pool_netmask = 0.0.0.0
Fri Feb 24 23:11:29 2006 us=25582 ifconfig_pool_persist_filename = '[UNDEF]'
Fri Feb 24 23:11:29 2006 us=25592 ifconfig_pool_persist_refresh_freq = 600
Fri Feb 24 23:11:29 2006 us=25602 ifconfig_pool_linear = DISABLED
Fri Feb 24 23:11:29 2006 us=41934 n_bcast_buf = 256
Fri Feb 24 23:11:29 2006 us=41948 tcp_queue_limit = 64
Fri Feb 24 23:11:29 2006 us=41957 real_hash_size = 256
Fri Feb 24 23:11:29 2006 us=41965 virtual_hash_size = 256
Fri Feb 24 23:11:29 2006 us=41975 client_connect_script = '[UNDEF]'
Fri Feb 24 23:11:29 2006 us=41985 learn_address_script = '[UNDEF]'
Fri Feb 24 23:11:29 2006 us=41994 client_disconnect_script = '[UNDEF]'
Fri Feb 24 23:11:29 2006 us=42003 client_config_dir = '[UNDEF]'
Fri Feb 24 23:11:29 2006 us=42012 ccd_exclusive = DISABLED
Fri Feb 24 23:11:29 2006 us=42021 tmp_dir = '[UNDEF]'
Fri Feb 24 23:11:29 2006 us=42031 push_ifconfig_defined = DISABLED
Fri Feb 24 23:11:29 2006 us=42041 push_ifconfig_local = 0.0.0.0
Fri Feb 24 23:11:29 2006 us=42052 push_ifconfig_remote_netmask = 0.0.0.0
Fri Feb 24 23:11:29 2006 us=42061 enable_c2c = DISABLED
Fri Feb 24 23:11:29 2006 us=42070 duplicate_cn = DISABLED
Fri Feb 24 23:11:29 2006 us=57953 cf_max = 0
Fri Feb 24 23:11:29 2006 us=57967 cf_per = 0
Fri Feb 24 23:11:29 2006 us=57976 max_clients = 1024
Fri Feb 24 23:11:29 2006 us=57985 max_routes_per_client = 256
Fri Feb 24 23:11:29 2006 us=57994 client_cert_not_required = DISABLED
Fri Feb 24 23:11:29 2006 us=58004 username_as_common_name = DISABLED
Fri Feb 24 23:11:29 2006 us=58013 auth_user_pass_verify_script = '[UNDEF]'
Fri Feb 24 23:11:29 2006 us=58023 auth_user_pass_verify_script_via_file = DISABLED
Fri Feb 24 23:11:29 2006 us=58032 client = DISABLED
Fri Feb 24 23:11:29 2006 us=58041 pull = DISABLED
Fri Feb 24 23:11:29 2006 us=58050 auth_user_pass_file = '[UNDEF]'
Fri Feb 24 23:11:29 2006 us=58062 show_net_up = DISABLED
Fri Feb 24 23:11:29 2006 us=58071 route_method = 0
Fri Feb 24 23:11:29 2006 us=58080 ip_win32_defined = DISABLED
Fri Feb 24 23:11:29 2006 us=58088 ip_win32_type = 3
Fri Feb 24 23:11:29 2006 us=58097 dhcp_masq_offset = 0
Fri Feb 24 23:11:29 2006 us=58106 dhcp_lease_time = 31536000
Fri Feb 24 23:11:29 2006 us=78485 tap_sleep = 0
Fri Feb 24 23:11:29 2006 us=78500 dhcp_options = DISABLED
Fri Feb 24 23:11:29 2006 us=78509 dhcp_renew = DISABLED
Fri Feb 24 23:11:29 2006 us=78518 dhcp_pre_release = DISABLED
Fri Feb 24 23:11:29 2006 us=78527 dhcp_release = DISABLED
Fri Feb 24 23:11:29 2006 us=78536 domain = '[UNDEF]'
Fri Feb 24 23:11:29 2006 us=78544 netbios_scope = '[UNDEF]'
Fri Feb 24 23:11:29 2006 us=78553 netbios_node_type = 0
Fri Feb 24 23:11:29 2006 us=78562 disable_nbt = DISABLED
Fri Feb 24 23:11:29 2006 us=78581 OpenVPN 2.0.5 Win32-MinGW [SSL] [LZO] built on Nov 2 2005
Fri Feb 24 23:11:29 2006 us=79089 Static Encrypt: Cipher 'BF-CBC' initialized with 128 bit key
Fri Feb 24 23:11:29 2006 us=79118 Static Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Fri Feb 24 23:11:29 2006 us=79199 Static Decrypt: Cipher 'BF-CBC' initialized with 128 bit key
Fri Feb 24 23:11:29 2006 us=79213 Static Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Fri Feb 24 23:11:29 2006 us=187455 TAP-WIN32 device [OpenVPN Home] opened: \\.\Global\{974C6733-889C-4FE6-9188-91FB6FCF6D54}.tap
Fri Feb 24 23:11:29 2006 us=188783 TAP-Win32 Driver Version 8.1
Fri Feb 24 23:11:29 2006 us=189995 TAP-Win32 MTU=1500
Fri Feb 24 23:11:29 2006 us=191203 Notified TAP-Win32 driver to set a DHCP IP/netmask of 192.168.178.1/255.255.255.252 on interface {974C6733-889C-4FE6-9188-91FB6FCF6D54} [DHCP-serv: 192.168.178.2, lease-time: 31536000]
Fri Feb 24 23:11:29 2006 us=194079 Successful ARP Flush on interface [4] {974C6733-889C-4FE6-9188-91FB6FCF6D54}
Fri Feb 24 23:11:29 2006 us=203223 Data Channel MTU parms [ L:1546 D:1450 EF:46 EB:4 ET:0 EL:0 ]
Fri Feb 24 23:11:29 2006 us=203273 Local Options String: 'V4,dev-type tun,link-mtu 1546,tun-mtu 1500,proto TCPv4_CLIENT,ifconfig 192.168.178.2 192.168.178.1,cipher BF-CBC,auth SHA1,keysize 128,secret'
Fri Feb 24 23:11:29 2006 us=203286 Expected Remote Options String: 'V4,dev-type tun,link-mtu 1546,tun-mtu 1500,proto TCPv4_SERVER,ifconfig 192.168.178.1 192.168.178.2,cipher BF-CBC,auth SHA1,keysize 128,secret'
Fri Feb 24 23:11:29 2006 us=203323 Local Options hash (VER=V4): '71de0147'
Fri Feb 24 23:11:29 2006 us=203341 Expected Remote Options hash (VER=V4): '7e929492'
Fri Feb 24 23:11:29 2006 us=203371 Attempting to establish TCP connection with 84.150.203.71:1194
Fri Feb 24 23:18:46 2006 us=440902 TCP: connect to 84.150.203.71:1194 failed, will try again in 5 seconds
