W900V + freetz problem
lewy0lewy
3 Aug 2009
I have installed default image for "alien" hardware on Freetz 1.1 and trunk but it doesn't work. Device restarts constantly. I didn't change anything except for selecting proper model. Images created with speed-to-fritz are fine.
Is it a known issue? If so may I be redirected to relevant threads? I may use google translate if they are in German.
I did some searching and found info that there are some troubles with ssl libraries. Grepping .config shows:
grep -i ssl .config
FREETZ_HAS_LIBSSL=y
# Crypto & SSL
# SSL ------------------------------------
# FREETZ_LIB_libcyassl is not set
# FREETZ_LIB_libmatrixssl is not set
# FREETZ_LIB_libxyssl is not set
Regards,
grep -i ssl .config
FREETZ_HAS_LIBSSL=y
# Crypto & SSL
Regards,
Of course I tried solution from here
http://www.freetz.org/wiki/FAQ#NachdemFlashenistdasAVM-Webinterfacenichtmehrerreichbar
and id didn't work
maybee the freetz section is better for you.
have you changed the tr69.cfg to:
tr069cfg {
enabled = no;
Problem solved. Searching for info on recovery image I found a recipe for problems like mine.
I had to create an empty file "empty" and add these lines to push_firmware script:
put empty mdt3
put empty mdt4
After that freetz images are stable.
Thanks to everyone involved.
