* /var/flash/ar7.cfg
* Fri Mar 9 19:12:46 2007
ar7cfg {
mode = dsldmode_bridge;
tsdisabled = no;
igddenabled = yes;
igdd_control_enabled = no;
wan_bridge_with_dhcpc = no;
wan_bridge_gateway = 192.168.2.1;
dhcpc_use_static_dns = yes;
ethmode = ethmode_bridge;
StatisticStartOfMonth = 1;
macdsl_override = 00:00:00:00:00:00;
ethinterfaces {
name = "eth0";
dhcp = no;
ipaddr = 192.168.2.3;
netmask = 255.255.255.0;
dstipaddr = 0.0.0.0;
dhcpenabled = yes;
dhcpstart = 0.0.0.0;
dhcpend = 0.0.0.0;
name = "eth0:0";
dhcp = no;
ipaddr = 192.168.178.254;
dhcpenabled = yes;
dhcpend = 0.0.0.0;
name = "usbrndis";
dhcp = no;
ipaddr = 192.168.179.1;
dhcpenabled = yes;
dhcpend = 0.0.0.0;
name = "wlan";
dhcp = no;
ipaddr = 192.168.1.1;
interfaces = "tiwlan0", "wdsup0", "wdsdw0", "wdsdw1",
"wdsdw2", "wdsdw3";
dhcpenabled = yes;
dhcpend = 0.0.0.0;
brinterfaces {
name = "lan";
dhcp = no;
interfaces = "eth0", "usbrndis", "tiwlan0", "wdsup0",
"wdsdw0", "wdsdw1", "wdsdw2", "wdsdw3";
dhcpenabled = yes;
dhcpend = 0.0.0.0;
name = "lan:0";
dhcp = no;
dhcpenabled = yes;
dhcpend = 0.0.0.0;
dslinterface {
name = "dsl";
dhcp = no;
netmask = 255.255.255.255;
dstipaddr = 192.168.179.1;
dhcpenabled = yes;
dhcpend = 0.0.0.0;
dslinterface_metric = 2;
routes {
enabled = yes;
ipaddr = 192.168.2.0;
gateway = 192.168.1.1;
metric = 0;
ipbridge {
enabled = no;
pppoefw {
interfaces = "usbrndis", "eth0", "tiwlan0", "wdsup0",
nofirewall = yes;
ipnetbiosfilter = yes;
dnsfilter_for_active_directory = yes;
hostuniq_filter = "";
dpconfig {
security = dpsec_host;
lowinput {
policy = "reject";
accesslist =
"permit ip any any connection outgoing-related",
"permit ip any any connection incoming-related",
"permit icmp any any";
lowoutput {
policy = "permit";
highinput {
policy = "permit";
highoutput {
policy = "permit";
accesslist =
"reject ip any 242.0.0.0 255.0.0.0",
"deny ip any host 255.255.255.255",
"reject ip any 169.254.0.0 255.255.0.0",
"reject udp any any eq 135",
"reject tcp any any eq 135",
"reject udp any any range 137 139",
"reject tcp any any range 137 139",
"reject udp any any range 161 162",
"reject udp any any eq 520",
"reject udp any any eq 111",
"reject udp any any eq 22289",
"reject udp any any eq 1710",
"reject udp any any eq 1048",
"reject udp any any eq 158",
"reject udp any any eq 515",
"reject icmp any 149.1.1.0 255.255.255.0";
shaper = "globalshaper";
budget {
Enabled = no;
Period = 2;
VolumeLow = 0;
VolumeHigh = 0;
ConnectionTime = 0;
WarnOnly = yes;
vccs {
VPI = 1;
VCI = 32;
traffic_class = atm_traffic_class_UBR;
pcr = 0;
scr = 0;
priority = 0;
dsl_encap = dslencap_pppoe;
ipbridgeing = no;
pppoeforwarding = no;
connections = "internet", "voip";
mcupstream = "internet";
dslifaces {
enabled = yes;
name = "internet";
dsl_encap = dslencap_inherit;
dslinterfacename = "dsl";
ppptarget = "internet";
etherencapcfg {
use_dhcp = yes;
ipaddr = 0.0.0.0;
netmask = 0.0.0.0;
gateway = 0.0.0.0;
dns1 = 0.0.0.0;
dns2 = 0.0.0.0;
mtu = 0;
is_mcupstream = yes;
stay_always_online = no;
redial_delay_after_auth_failure = 1m;
redial_limit = 3;
redial_after_limit_reached = 1h;
username_prefix_after_auth_failure = "";
redial_delay_after_low_error = 10s;
dsldpconfig {
security = dpsec_firewall;
lowinput {
policy = "permit";
accesslist =
"deny ip any 242.0.0.0 255.0.0.0",
"deny udp any any eq 135",
"deny tcp any any eq 135",
"deny udp any any range 137 139",
"deny tcp any any range 137 139",
"deny udp any any range 161 162",
"deny udp any any eq 520",
"deny udp any any eq 111",
"deny udp any any eq 22289",
"deny udp any any eq 1710",
"deny udp any any eq 1048",
"deny udp any any eq 158",
"deny udp any any eq 515";
lowoutput {
policy = "permit";
highinput {
policy = "permit";
highoutput {
policy = "permit";
accesslist =
forwardrules = "udp 0.0.0.0:5060 0.0.0.0:5060",
"udp 0.0.0.0:7078 0.0.0.0:7078",
"udp 0.0.0.0:7079 0.0.0.0:7079",
"udp 0.0.0.0:7080 0.0.0.0:7080",
"udp 0.0.0.0:7081 0.0.0.0:7081",
"udp 0.0.0.0:7082 0.0.0.0:7082",
"udp 0.0.0.0:7083 0.0.0.0:7083",
"udp 0.0.0.0:7084 0.0.0.0:7084",
"udp 0.0.0.0:7085 0.0.0.0:7085",
"udp 0.0.0.0:7086 0.0.0.0:7086",
"udp 0.0.0.0:7087 0.0.0.0:7087",
"udp 0.0.0.0:7089 0.0.0.0:7089",
"udp 0.0.0.0:7090 0.0.0.0:7090",
"udp 0.0.0.0:7091 0.0.0.0:7091",
"udp 0.0.0.0:7092 0.0.0.0:7092",
"udp 0.0.0.0:7093 0.0.0.0:7093",
"udp 0.0.0.0:7094 0.0.0.0:7094",
"udp 0.0.0.0:7095 0.0.0.0:7095",
"udp 0.0.0.0:7096 0.0.0.0:7096",
"udp 0.0.0.0:7097 0.0.0.0:7097",
"tcp 0.0.0.0:8089 0.0.0.0:8089";
enabled = yes;
name = "voip";
ppptarget = "voip";
etherencapcfg {
use_dhcp = yes;
ipaddr = 0.0.0.0;
netmask = 0.0.0.0;
gateway = 0.0.0.0;
dns1 = 0.0.0.0;
dns2 = 0.0.0.0;
mtu = 0;
is_mcupstream = no;
stay_always_online = yes;
redial_limit = 3;
dsldpconfig {
lowinput {
policy = "permit";
accesslist = "permit udp any any",
"permit icmp any any",
"reject ip any any";
lowoutput {
policy = "permit";
highinput {
policy = "permit";
highoutput {
policy = "permit";
"udp 0.0.0.0:7097 0.0.0.0:7097";
voip_routes = "permit ip any any connection exists",
"permit udp any eq 5060 any",
"permit udp any eq 7077 any eq 53",
"permit udp any range 7078 7097 any";
targets {
type = pppcfg_target_internet;
name = "internet";
only_crypt_auth = no;
local {
username = "";
passwd = "";
remoteauth = pppcfg_authtype_chap;
remoteauth_only_on_incoming = yes;
remote {
inactivity_timeout = 5m;
bUseChargeInterval = no;
nChargeInterval = 1m;
logicaldisconnect_with_physical = yes;
disconnect_timeout = 0w;
finaldisconnectcall = no;
ipnetbiosspoofing = no;
dnsfilter_for_active_directory = no;
no_outgoing_calls = no;
coso = pppcfg_coso_caller;
callback_delay = 1s;
icbmode = pppcfg_icbmode_none;
ocbmode = pppcfg_ocbmode_none;
mscbprefered = no;
multilink {
extra_static_channels = 0;
max_channels = 1;
automatic = no;
automatic_param {
window = 20s;
add_percent = 85;
drop_percent = 70;
sportlich = no;
header_compression = yes;
data_compression = pppcfg_datacomp_auto;
stac_reset_with_history_number = no;
encryption = pppcfg_crypt_none;
inactivity_prevention_interval = 0w;
new_ipaddr_on_connect = no;
my_ipaddr = 0.0.0.0;
his_ipaddr = 0.0.0.0;
bVolumeRoundUp = no;
VolumeRoundUpBytes = 0;
bProviderDisconnectPrevention = yes;
ProviderDisconnectPreventionInterval = 1d;
ProviderDisconnectPreventionHour = 1;
bProviderDisconnectPreventionHourSet = yes;
passiv_on_outgoing = no;
name = "voip";
local {
username = "";
passwd = "";
remote {
inactivity_timeout = 0w;
mscbprefered = no;
multilink {
max_channels = 1;
automatic = no;
automatic_param {
window = 20s;
add_percent = 85;
drop_percent = 70;
sportlich = no;
dslglobalconfig {
autodetect = yes;
pppoeiface = "eth0";
speed_in_netto = 1024;
speed_out_netto = 128;
manual_speed = no;
connect_delay_when_synced = 3s;
templates {
VPI = 1;
VCI = 32;
manu = 0;
VPI = 8;
VCI = 35;
manu = 0;
VPI = 8;
VCI = 48;
manu = 0;
VPI = 8;
VCI = 48;
manu = 0;
encap = dslencap_pppoa;
VPI = 8;
VCI = 48;
manu = 0;
encap = dslencap_pppoa_llc;
VPI = 8;
VCI = 67;
manu = 0;
VPI = 8;
VCI = 67;
manu = 0;
VPI = 8;
VCI = 64;
manu = 0;
VPI = 8;
VCI = 36;
manu = 0;
VPI = 0;
VCI = 35;
manu = 0;
VPI = 0;
VCI = 35;
manu = 0;
VPI = 0;
VCI = 35;
manu = 0;
VPI = 9;
VCI = 35;
manu = 0;
VPI = 1;
VCI = 32;
manu = 0;
VPI = 1;
VCI = 32;
manu = 0;
VPI = 0;
VCI = 32;
manu = 0;
VPI = 0;
VCI = 32;
manu = 0;
VPI = 0;
VCI = 32;
manu = 0;
VPI = 0;
VCI = 34;
manu = 0;
VPI = 0;
VCI = 34;
manu = 0;
VPI = 0;
VCI = 34;
manu = 0;
VPI = 0;
VCI = 33;
manu = 0;
VPI = 8;
VCI = 32;
manu = 0;
VPI = 8;
VCI = 32;
manu = 0;
VPI = 8;
VCI = 32;
manu = 0;
VPI = 0;
VCI = 38;
manu = 0;
VPI = 0;
VCI = 38;
manu = 0;
VPI = 8;
VCI = 35;
manu = 0;
VPI = 8;
VCI = 35;
manu = 0;
VPI = 0;
VCI = 81;
manu = 0;
VPI = 0;
VCI = 81;
manu = 0;
VPI = 0;
VCI = 81;
manu = 0;
VPI = 8;
VCI = 81;
manu = 0;
VPI = 8;
VCI = 81;
manu = 0;
VPI = 8;
VCI = 81;
manu = 0;
VPI = 0;
VCI = 100;
manu = 0;
VPI = 0;
VCI = 100;
manu = 0;
VPI = 0;
VCI = 100;
manu = 0;
VPI = 1;
VCI = 50;
manu = 0;
shapers {
name = "globalshaper";
OutFragmentWhenVoIP = 0;
shaperconnection {
enabled = yes;
targets = "";
name = "Fritz!Box";
limiters {
name = "default-out";
bps_limit {
limit_total = 100;
limit_p0 = 0;
limit_p1 = 95;
limit_p2 = 95;
limit_p3 = 0;
pps_limit {
limit_total = 0;
limit_p0 = 0;
limit_p1 = 0;
limit_p2 = 0;
limit_p3 = 0;
min_priority = 0;
max_priority = 3;
grouping_by_source_ip = no;
grouping_by_dest_ip = no;
grouping_by_source_port = no;
grouping_by_dest_port = no;
dynamic_balancing = no;
bps_child_limit {
limit_total = 0;
limit_p0 = 0;
limit_p1 = 0;
limit_p2 = 0;
limit_p3 = 0;
pps_child_limit {
limit_total = 0;
limit_p0 = 0;
limit_p1 = 0;
limit_p2 = 0;
limit_p3 = 0;
shapeOutgoingOnIncomingCounters = no;
name = "default-in";
bps_limit {
limit_total = 0;
limit_p0 = 0;
limit_p1 = 0;
limit_p2 = 0;
limit_p3 = 0;
pps_limit {
limit_total = 0;
limit_p0 = 0;
limit_p1 = 0;
limit_p2 = 0;
limit_p3 = 0;
min_priority = 0;
max_priority = 0;
bps_child_limit {
limit_total = 0;
limit_p0 = 0;
limit_p1 = 0;
limit_p2 = 0;
limit_p3 = 0;
pps_child_limit {
limit_total = 0;
limit_p0 = 0;
limit_p1 = 0;
limit_p2 = 0;
limit_p3 = 0;
out_rules {
name = "download-tcp-ack";
filter = "tcp and len <= 64";
priority = 2;
limiters = "default-out";
name = "dns";
filter = "udp port 53";
priority = 1;
name = "fon-rtp";
filter = "udp[8] = 0x80 or udp port 5060";
priority = 3;
name = "http-requests";
filter = "(tcp dst port 80 or dst port 8080 or dst port 3128) and (len <= 800)";
priority = 1;
name = "pri-out";
filter = "icmp";
priority = 1;
name = "default";
filter = "";
priority = 0;
in_rules {
name = "default";
filter = "";
priority = 0;
limiters = "default-in";
demasquerade = no;
RunVoIPDSLAutodetect = 0;
saved_non_ata_ip_config {
ipaddr = 192.168.178.1;
dns1 = 192.168.180.1;
dns2 = 192.168.180.2;
servercfg {
hostname = "(none)";
dns1 = 192.168.2.1;
dns2 = 192.168.2.1;
websrv {
port = "80";
read_timeout = 15m;
request_timeout = 30s;
keepalive_timeout = 5m;
nokeepalive = "*";
errordir = "/usr/lib/websrv/errors";
webdir = "/usr/www";
cgidir = "cgi-bin";
indexfn = "index.var", "index.htm", "index.html";
dhcpserver {
saveinterval = 1h;
generic {
default_lease_time = 10d;
max_lease_time = 13d;
dhcpclient {
metric = 9;
dnsserver {
cache_maxKB = 16;
negative_ttl = 5m;
ddns {
accounts {
enabled = no;
domain = "";
iface = 0;
username = "";
passwd = "";
ddnsprovider = "dyndns.org";
types {
type = "dyndns";
url = "/nic/update?system=dyndns&hostname=<domain>&myip=<ipaddr>&wildcard=NOCHG";
type = "dyndns-custom";
url = "/nic/update?system=custom&hostname=<domain>&myip=<ipaddr>&wildcard=NOCHG";
type = "dyndns-statdns";
url = "/nic/update?system=statdns&hostname=<domain>&myip=<ipaddr>&wildcard=NOCHG";
type = "noip";
url = "/ducupdate.php?update=<b64>username=<username>&pass=<pass>&h[]=<domain>&ip=<ipaddr></b64>";
type = "2mydns";
url = "/dyn.asp?username=<username>&password=<pass>&hostname=<domain>&myip=<ipaddr>";
type = "dns4biz";
url = "/nic/update?hostname=<domain>&myip=<ipaddr>";
type = "selfhost";
url = "/nic/update?myip=<ipaddr>&host=<domain>&textmodi=1&http_status=1";
type = "strato";
url = "/nic/update?hostname=<domain>";
type = "userdefined";
url = "";
provider {
name = "dyndns.org";
type = "dyndns";
livedelay = 0w;
touchtime = 30d;
server = "members.dyndns.org";
infourl = "http://www.dyndns.org/";
name = "dyndns.org-custom";
livedelay = 0w;
touchtime = 30d;
name = "dyndns.org-statdns";
livedelay = 0w;
touchtime = 30d;
name = "No-IP.com";
type = "noip";
livedelay = 4m;
touchtime = 0w;
server = "dynupdate.no-ip.com:8245";
infourl = "http://www.no-ip.com/";
name = "2myDNS";
type = "2mydns";
livedelay = 0w;
touchtime = 0w;
server = "dyn.2mydns.com";
infourl = "http://www.2mydns.com/";
name = "DNS4BIZ.DE Premium";
type = "dns4biz";
livedelay = 0w;
touchtime = 0w;
server = "au-eu.dns4biz.net";
infourl = "http://www.dns4biz.com/services_avm.php3";
name = "DNS4BIZ.DE Business";
type = "dns4biz";
livedelay = 0w;
touchtime = 0w;
server = "au-eu.dns4biz.biz";
name = "selfhost.de";
type = "selfhost";
livedelay = 0w;
touchtime = 0w;
server = "carol.selfhost.de";
infourl = "http://www.selfhost.de";
name = "STRATO AG";
type = "strato";
livedelay = 4m;
touchtime = 0w;
server = "dyndns.strato.com";
infourl = "http://www.strato.de/webhosting/index.html";
name = "Benutzerdefiniert";
livedelay = 4m;
touchtime = 0w;
server = "";
infourl = "http://";
webui {
username = "";
password = "";
expertmode = yes;
wizard_completed = no;
event_filter = 0;
capiovertcp {
enabled = no;
maxctrl = 1;
port = 5031;
emailnotify {
enabled = no;
interval = daily;
From = "";
To = "";
SMTPServer = "";
accountname = "";
passwd = "";
show_eventlist = no;
show_voipstat = no;
usbhost {
readonly = no;
password = "";
autoprov_enabled = no;
ftp_internet_enabled = no;
aura_config = 0;
night_time_control {
enabled = no;
time_on = "";
time_off = "";
ring_blocked = no;
ntpclient {
server_list = "0.europe.pool.ntp.org";
led {
infoled_reason = 7;
timezone_manual {
enabled = no;
offset = 0;
dst_enabled = no;
TZ_string = "";
mrouter {
igmp_version_for_upstream = 3;
igmp_version_for_other = 3;
igmp_prio = 48;
rip {
cpu_schedule {
dsl_token = 5000;
// EOF
laut Handbuch von AVM (Seite 71) hätte es aber gehen können. OK wieder was gelernt.doc456 schrieb:@Ecki: Er hat ne 7141. Bei unserer 7050 sind die noch getrennt.
Ich ? Äm, 7050 mit WLANcssoft schrieb:PS: Was hast den du für eine Box, und hat diese auch WLAN?
