xlite - turn off autostart - solved
noex
25 Aug 2005
Hi
Xlite automatically comes up when I log in. To me that's a bit of a pain as I normally have several systems running at the same time, all of them equipped with Xlite.
How can I turn off the autostart?
Thanks
noex
Hi noex,
please RTFM - available for download at www.xten.net
Here goes:
Open the main menu, choose User Settings, choose Features, set Launch the Application when Windows Starts to No.
Done.
Thanks for responding Ghost.
It goes without saying that I have read that f... manual first, made the required adjustment and doubled checked them. However Xliste still comed up uncommanded. There must be a another switch somewhere. Any ideas?
Hi noex,
I didn't mean to insult you. The way I described above works on my system and as it is described in that manual, I just gave a hint.
There are two other places to look: your autorun-folder and the autorun-sections in your registry. In regedit, I searched for X-Lite.exe and it returned this key:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run
Delete the X-Lite entries in both places and you should be fine.
No offence taken. Following your advice I searched the registry and removed a couple of entries. It looks just fine now. Thank you very much for your help Ghostwalker.
noex
No problem, been glad to help.
Could you please edit your first postin in this thread add prefix it with [solved] or something like it? Thank you.
Joeschuetz
