Zwei Fritz Box Fon WLANs
fredz
14 Sep 2005
(sorry for the English, but you may reply in German)
I have one 7050. I'd like to use another Fritz Box Fon WLAN in a different house just 30 meters away. Can I use a second Fritz Box Fon WLAN in that house and "bridge" both boxes? How? Is there a way to be able to use the VOIP accounts on both boxes?
You may attach the second 7050 as Repeater. The activation will be found unter menu WLAN. There are a lot of experiances in this forum. Search for WDS.
Thanks! Is there a Fritz Box which supports n-draft 802.11n yet?
fredz schrieb:
... n-draft 802.11n ...
The 7050 only supports 802.11b and 802.11g and a 802.11g++ supported by AVM boxes. See WLAN, Funkeinstellungen.
The 7270, supposed to be on market this fall, will be the first 802.11n draft router by AVM.
Is there also a way to forward calls/lines from one Fritz box to another one on the same network? How
nico22de
