IP-Phone-Forum
Zurück   IP-Phone-Forum > VoIP-Hardware > AVM > FRITZ!Box Fon: Modifikationen > Freetz (ehem. ds-mod)
Registrieren Hilfe Benutzerliste Wiki Suchen Heutige Beiträge Alle Foren als gelesen markieren
Freetz (ehem. ds-mod) Paket- und Mod-Entwicklung für die FBF von danisahne
Thema geschlossen
Themen-Optionen Thema durchsuchen Ansicht
Alt 10.10.2005, 02:17   #1
danisahne
Semi-Moderator
Benutzerbild von danisahne
danisahne-mod (outdated)
Hi IP-Phone-Forum!
Developers thread:
danisahne-mod ..::Developer::.. >>
NEW: ds-mod at Sourceforge.net (UNDER CONSTRUCTION; not able to build firmware images yet):
danisahne-mod at Sourceforge.net >>
README:
New Patch available for latest firmwares “Fon WLAN 7170”, “SL WLAN”, “WLAN 3030” and “WLAN 3070”.
-- danisahne, 17.11.2006
ds-mod is currently under heavy development. The next release will be based on ipkg... Therefore the whole buildroot has to be rewritten. This is what I've been doing in my spare-time for the last weeks and that I will continue until it is finished (I plan for this year). Due to new firmware releases the mod does not compile for “300IP as Fon”, “Fon WLAN 7170”, “SL WLAN”, “WLAN 3030” and “WLAN 3070” any more. As I want to focus on the new ds-mod buildroot, patches for ds-0.2.9 fixing these issues are welcome. Please submit these patches via PM.
More details @ software:ds-mod:start (German)
-- danisahne, 13.11.2006
PREAMBLE:
danisahne mod (short: ds-mod) is a bunch of scripts and precompiled binaries for your Fritzbox. It addresses not only linux profis, but also users having no idea how vi works. Therefore ds-mod comes with a webinterface, that runs parallel to the original one, and has cygwin support for compiling a modified image with cygwin.
Special thanks to kay1234 for helping me with the translation.
DISCLAIMER:
This mod is distributed without any warranty (not even the implied warranty of merchantability or fitness for a particular purpose). Use this mod on your own risk! Note, that loading ds-mod will void your warranty
If you don't know howto recover your device in case of failure, you probably should stop reading at this point. Do NOT bother AVM's support with problems caused by the mod.
ATTENTION: For security reasons I do NOT recommend exposing the webinterface of your box (original or ds-mod) to the internet. ds-mod webinterface is designed with respect to functionality not security, although there are some security checks.
ATTENTION: Be careful with iptables firewalls. Always test them in RAM first, before you write the rules to flash. Otherwise you may have to recover your box, because one can lock out himself quite easily (unless you got a serial console).
Table of contents
  1. Features
  2. Install
  3. Uninstall
  4. Todo
  5. Known Bugs
  6. Packages
  7. Configuration
  8. Source Code
1. Features
ds-0.2.9
  • kernel
    + iptables
    + nfs mount
    + lzma support
  • iptables 1.3.5
  • busybox 1.2.1
    + crond
    + ether-wake
  • bftpd 1.3
  • checkmaild 0.2
  • callmonitor 1.5
  • dnsmasq 2.26
  • dropbear 0.48.1
  • telefon 0.3
  • vpnc 0.3.3
  • firewall-cgi 0.5
  • samba 2.0.10
  • screen 4.0.2
  • syslogd-cgi 0.2
  • wol-cgi 0.5
  • openvpn 2.1_beta14
  • transmission 0.5 (binary only)
  • web frontend
  • downgrade mod
Who-is-who
All services provided by packages are accessible from the (W)LAN side by default and not from the internet. You can achieve that by creating appropriate port forwardings (which I do not recommend).
  • bftpd: Small FTP server to easily exchange files. Files are uploaded to RAM, so your box will crash if you try to upload a large file. In order to protect the FTP account with a password, you have to disable anonymous access and define a password with `modpasswd ftp' for the user ftp.
  • checkmaild: Check email accounts for new mails while your PC is turned off (indicated by Fritzbox LEDs)
  • callmonitor: execute any shell command (e.g. wake-on-call) and launch message popups (e.g. on the D-Box or XBox) in the event of an incoming or outgoing call to/from specific telephone numbers.
  • dnsmasq: DNS and DHCP server; can handle static leases (in contrary to the DHCP server of the Box). Furthermore, own local DNS names might be added.
  • dropbear: SSH server for secure remote login (like telnet, but encrypted).
  • telefon: Makes the output of the telephone daemon available to other packages (e.g. callmonitor). This package is usually only required by other packages and not used stand-alone. It is not required by the new callmonitor 1.0 any more.
  • vpnc: Cisco compatible VPN client.
  • firewall-cgi: Scripts to control a iptables firewall.
  • syslogd-cgi (Linux Magazin (German)): Logging of the Box might be sent to remote hosts using syslogd.
  • wol-cgi: Web interface for Wake-on-LAN using ether-wake
RELEASE NOTES: Fixed favicon support and upgraded busybox to 1.2.1. This new Version of busybox is still smaller, even when activating losetup and swaponoff (and thats why i've choosen to select these applets). ptweety's swap patch will be integrated in the next release.
2. Install
The scripts in this mod are based on mod-0.57 from haveaniceday, the fbox buildroot from Enrik and last but not least my own work It should compile for and run on almost all 4MB- and 8MB-flash-boxes.
LINUX
Requires ncurses-devel for `make menuconfig':
  1. Download ds-0.2.x.tar.bz2 (don't use FAT or NTFS partitions for compiling the mod)
  2. Open a shell and change to the directory you just downloaded the tarball to:
    tar -xvjf ds-0.2.x.tar.bz2
    cd ds-0.2.x/
    make menuconfig
    make
    If you don't have ncurses-devel, you can also use `make config' instead of `make menuconfig'
WINDOWS
dsl123 has made a nifty little Howto compile danisahne-mod with Cygwin (German). Thanx dsl123!
Because some users happen to do this error over and over again: Use the Cygwin-tar to unpack the mod tarball in Windows. Never ever use other tools like WinZIP or WinRAR (they can't deal with symlinks). / Weils immer wieder vorkommt: In Cygwin unbedingt wie in der Anleitung beschrieben das Cygwin-tar verwenden, niemals mit einem anderen Programm unter Windows entpacken!
  1. Download Cygwin installer setup.exe from http://www.cygwin.com/
  2. Install Cygwin with the following packages:
    • Archive -> unzip
    • Devel -> gcc, libncurses-devel, make, patchutils
    • Interpreters -> perl
    • Web -> wget
  3. Download ds-0.2.x.tar.bz2 to your Cygwin-home directory (depending on your installation, e.g. C:\Cygwin\home\<Windows-user>\)
  4. Start Cygwin shell and type:
    cd ds-0.2.x/
    make menuconfig
    make
Upload the created image firmware_*.image as firmware update using the webinterface of your box. `make recover' is not supportet in Cygwin. If your debug.cfg is not empty I suggest to empty it (echo > /var/flash/debug.cfg). This file is not used by danisahne-mod and is available as a "autorun script" like before, but make sure your debug.cfg does not interfere with the mod. After a few minutes you should be able to browse http://fritz.box:81/ or http://<ip-of-box>:81/. Follow the instructions on these webpages to complete the installation.
3. Uninstall
The mod saves the whole configuration to /var/flash/ds_mod (0x3c), which is automatically created at boot time. To completely remove danisahne mod you should run 'moduninstall' and upload a unmodified original firmware immediately.
4. Todo
Please send me your feature request as PM to danisahne.
  • dynamic packages (reload mod)
  • ? ipv6 mod von owb ?
  • ? stunnel ?
  • NTP server
  • olsrd
  • Poptop
  • Umfassende Patches von ptweety integrieren: xmail, Swap, knockd
  • openvpn mit lzo von knox
  • tinyproxy mit filter
  • Upgrades: bftpd
5. Known Bugs
Please submit bugs via PM to danisahne.
6. Packages
At the moment, the following packages are being worked on or are available which are not maintained by myself:In case of questions or problems concerning these packages, please contact the corresponding author. The following packages are maintained by myself or are being planned:
  • bftpd (Status: integrated)
  • dnsmasq (Status: integrated)
  • dropbear (Status: integrated)
  • samba (Status: integrated)
  • screen (Status: integrated)
  • wol-cgi - Wake-on-LAN web interface (Status: integrated)
  • firewall-cgi - Firewall-Framework (Status: integrated)
7. Configuration
The configuration is being stored in an own character device /var/flash/ds_mod. It contains a tar archive of the folder /var/tmp/flash (same as /tmp/flash due to symlink, do not mix up with /var/flash !!!). The archive is being unpacked at boot time. Therefore, all files that shall survive a reboot might be copied to /tmp/flash followed by the command 'modsave flash'. I have chosen a hard limit of 30KB as a default, which might be changed with
modconf set mod MOD_LIMIT=<bytes>
modsave
The "security level" is a security barrier which restricts the editing of configuration files over the web interface and can be changed like this:
echo x > /tmp/flash/security
modsave
# with x being one of the following values:
# 0 : no restrictions
# 1 : only configuration files without shell commands might be edited
# 2 : no configuration files might be edited
The default security level is 1.
The security level also defines, which scripts of the category "Extras" are allowed to be executed and which are not.
Wrapper scripts for text files (do not require 'modsave'):
  • Files in /var/flash: use nvi
    e.g. nvi /var/flash/debug.cfg
  • Files in /tmp/flash: use mvi
    e.g. mvi /tmp/flash/my_file.txt
For further information please read the thread danisahne-mod ..::Developer::.. (German)
8. Source Code
Source code can be compiled as follows:
make menuconfig
make precompiled
The toolchain will automtically be build if there was no external compiler specified. The toolchain only can be build with:
make menuconfig
make toolchain
make libs
All source packages and tarballs can be collected with:
make sources
If you just want to compile the tools use:
make tools
Kind regards,
danisahne
ds-0.2.9-opensrc-04.01.tar.bz2 for boxes:
  • Fon ATA
ds-0.2.9-opensrc-04.06.tar.bz2 for boxes:
  • 300IP as Fon
  • Fon
  • Fon 5010
  • Fon 5012
  • Fon 5050
  • Fon WLAN 7050
  • Fon WLAN 7170
  • SL WLAN
  • WLAN 3030
  • WLAN 3050
  • WLAN 3070
  • Please apply patch ds-0.2.9-p2.patch for the new firmwares (thanks olistudent). This also fixes the 300ip firmware (thanks b.sander). Learn here how to apply this patch (German).
  • For b.sander's updates you need to run `make precompiled' after applying the patches.
Angehängte Grafiken
Dateityp: png status.png (22,0 KB, 9327x aufgerufen)
Dateityp: png logs.png (30,0 KB, 7867x aufgerufen)
Dateityp: png dienste.png (41,1 KB, 6611x aufgerufen)
Dateityp: png einstellungen.png (25,2 KB, 6182x aufgerufen)
Dateityp: png bftpd.png (26,3 KB, 6222x aufgerufen)
Dateityp: png dropbear.png (27,4 KB, 6376x aufgerufen)
Dateityp: png wol.png (11,5 KB, 6349x aufgerufen)
Angehängte Dateien
Dateityp: bz2 ds-0.2.8-opensrc-04.01.tar.bz2 (2,86 MB, 550x aufgerufen)
Dateityp: bz2 ds-0.2.8-opensrc-04.06.tar.bz2 (4,35 MB, 1798x aufgerufen)
Dateityp: bz2 ds-0.2.9-opensrc-04.01.tar.bz2 (2,87 MB, 758x aufgerufen)
Dateityp: bz2 ds-0.2.9-opensrc-04.06.tar.bz2 (4,35 MB, 11817x aufgerufen)
Dateityp: bz2 ds-0.2.9-p2.patch.bz2 (8,9 KB, 2577x aufgerufen)
Dateityp: bz2 ds-0.2.9-b.sander-updates.patch.bz2 (98,7 KB, 1494x aufgerufen)
__________________
Router: SMC 7008 BR hinter Fritz!Box Fon WLAN 7050 (UI) FW: 14.04.15ds-0.2.8
Provider: 1und1 DSL 6000 mit (leider nur) 3130/406 kbps (Down/Up)
Geändert von danisahne (29.04.2007 um 00:55 Uhr).
danisahne ist offline
Alt 10.10.2005, 05:32   #2
heini66
Gesperrt
Benutzerbild von heini66
[schild=4 fontcolor=FF0000 shadowcolor=C0C0C0 shieldshadow=1]coole nummer das![/schild]
werd mich gleich noch drann machen...
fürn ne fbf phone wlan mit meiner firmware...
bin ja gespannt.
bericht folgt!
heini66 ist offline
Alt 10.10.2005, 06:10   #3
heini66
Gesperrt
ähhh...
kannst du auch nen script erstellen um da auf eigene firmware files einzubinden? so a la ./modfirmware /.../original.image /.../.../mod.image ?
brech mir sonst noch die finger da nur nen script für ne 7050 dabei ist....
heini66 ist offline
Alt 10.10.2005, 09:07   #4
CyberKing2k
IPPF-Fünfhundert-Club
Benutzerbild von CyberKing2k
währe es nicht sinvoller, die Arbeit für FBF Mods zu bündeln:
siehe Firmware - Modifikationen im Überblick von fritzchen:
http://www.ip-phone-forum.de/forum/v...ic.php?t=26655
Vielleicht kannst du mal Kontakt mit Fritzchen aufnehmen, die die Teile deines Mod in diesen einfließen lassen, die es noch nicht geibt
Gemeinsam sind wir stark!
__________________
Router: AVM FRITZ!Box Fon WLAN 7270 v2 (16MB)
Firmware-Version: 54.04.70 mit freetz-1.1-stable-3189
Router: Linksys WRT54G-DE Rev: 1.1 FW: v23 SP3 dd-wrt.com
ISP: Strato DSL 3+ (powered by FreenetKomplett), 14 Mbit Down, 1 Mbit Up
VSP FB incl. e164.org: VoIPStation.de (Clip: 030)| Sipgate.de (030) | lidl.carpo.de (030) | PBX-Network.de (SIP) | freecalls.com (SIP)
VSP Simply-Connect.de: VoIPbuster.com (0211) | Monduno.com (032) | SparVoIP.de (SIP) | voipstunt.com (SIP) | WEB.de (01212) | DUS.net (FAX) | sipdiscount.com (030) | i-p-tel.com (SIP)
XBox Media Center: XBMC-2006-12-08-PIMPED
PlayStation Portable: Ceramic-Weiss Value-Pack FW: 5.00 M33-3
DSLR Kamera: Canon EOS 400D FW: 1.1.1 mit Canon 28-135/3.5-5.6 EF IS USM
Blog: blog.juber.de
CyberKing2k ist offline
Alt 10.10.2005, 09:51   #5
supamicha
ich habe von owb die ipv6 lösung mit lzma erhalten und demnächst hier online stellen. dann schau ich mir mal an, ob ich die zwei sachen zusammenführen kann.
micha
__________________
2x AVM FRITZ!Box 7270 FW: 54.04.76 - Siemens GIGASET SX455isdn
DSL : MaxiDSL komplett 18/1Mbit DoppelFlat - VoIP : DUS, SIPGATE (DE-AT), PBX-network
supamicha ist offline
Alt 10.10.2005, 10:33   #6
fritzchen
Benutzerbild von fritzchen
Zitat:
Dieser mod wurde für die FRITZ!Box Fon WLAN 7050 geschrieben, sollte aber meines Wissens auch auf den anderen 4MB-Varianten laufen.
Ja, das läuft auch problemlos durch mit meiner .67-Firmware für die alte fbf ohne wlan. Aber kann das denn überhaupt klappen? Ich könnte mir vorstellen dass das nicht passt, alleine schon wegen des neuen Kernels?
__________________
fritzchen ist offline
Alt 10.10.2005, 11:29   #7
danisahne
Semi-Moderator
Zitat:
Zitat von heini66
ähhh...
Das Skript fwmod kannst du mit der original Firmware als Parameter aufrufen. fwmod_fon_wlan_7050.14.03.85 machst auch nichts anderes:
./fwmod <image-name>.image
cd <image-name>.image.mod/
ls -l firmware.image
Das einziges Problem, das ich sehe sind die Patches, die ich für die rc.S usw. geschrieben hab. Bei einer zu alten Firmware funktionieren die nicht, da sich in den Skripten bei AVM zuletzt viel getan hat. Schaut bei der Ausgabe des mod Skripts, ob die Patches alle anstandslos eingespielt wurden. Ich werde da noch einen Check mit einbauen müssen, so dass das mod Skript abbricht, falls ein Patch nicht erfolgreich war.
Zitat:
Hab ich gemacht. Fritzchen macht die Übersicht, supamicha entwickelt zur Zeit den mod-0.57 weiter (m*.*). supamicha und owb sind gerade am Integrieren in diesen mod.
Ich verfolge eine ein wenig andere Richtung, weil ich das ganze mehr Paket-basiert machen will. Ziel ist es die "Pakete" (z.B. dropbear) sowohl statisch ins Image eincompilieren zu können, als auch dynamisch von einem Webspace nachladen zu können. Desweiteren stell ich ein Webinterface zur Konfiguration bereit, was es Leuten mit wenig Linux Know How einfacher macht, aber auch Feintuning über die Shell erlaubt. Standardmäßig läuft es auf Port 81: http://fritz.box:81/
IPv6 würde ich bei Gelegenheit auch gerne zusammen mit owb einbauen.
Mfg,
danisahne
__________________
Alt 10.10.2005, 11:49   #8
supamicha
vor der version 0xx.03.71 und ab der xx.03.73 und höher laufen die versionen bei rc.* wieder zusammen. deshalb habe ich auch eine weile die m3 und m4 parallel gepflegt.
micha
__________________
Alt 10.10.2005, 14:17   #9
danisahne
Semi-Moderator
Zitat:
Da AVM nur einen Kernel für alle 4MB-Varianten bereitstellt, gehe ich davon aus, dass die Boxen alle den selben Kernel haben. Könnte mir bitte jeder, der es erfolgreich auf einer nicht-Fon-WLAN-7050 4MB Fritz!Box getestet hat, mir per PN die Firmware Version mit AVM FTP Link schicken, damit ich auch Skripte ala ./fwmod_fon_wlan_7050.14.03.85 schreiben kann.
Hat die alte fbf ohne wlan 4MB Flash?
Meine Skripte laufen bei einer Firmware für eine 2MB-Variante möglicherweise ohne Fehler durch, jedoch wird die maximale Größe des Kernels und des Filesystems nach den 4MB Abmaßen getestet. Das würde dann eine 2MB-Variante zum Recover Fall machen, wenn die Box nicht vor dem Flashen die Größe checken sollte.
Ein bisschen Mut gehört natürlich dazu, ich kann nicht garantieren, dass nichts schief läuft. Am besten vorher mit den Recovery Tools vertraut machen, da danach möglicherweise kein Internet mehr da ist.
Mfg,
danisahne
__________________
Alt 10.10.2005, 15:06   #10
heini66
Gesperrt
[schild=15 fontcolor=FF0000 shadowcolor=C0C0C0 shieldshadow=1]BOAH[/schild] [schild=11 fontcolor=FFA500 shadowcolor=C0C0C0 shieldshadow=1]SCHOCKT !!![/schild] [schild=1 fontcolor=FF0000 shadowcolor=C0C0C0 shieldshadow=1]THXS !!![/schild]
LÄUFT !!! auf ner fbf fon wlan firmware 08.03.73 und 7050 14.03.73
insbesondere das web-interface auf port 81 !!!
riesen dank!
hoffentlich kommt der rest deines todo's bald!
der heini
heini66 ist offline
Alt 10.10.2005, 15:45   #11
owb
IPPF-Einsteiger
owb eine Nachricht über ICQ schicken owb eine Nachricht über AIM schicken owb eine Nachricht über MSN schicken owb eine Nachricht über Yahoo! schicken
Re: danisahne-mod
ich hab mir dein Mod noch nicht angesehen, daher nur ein kurzer "Kommentar" der mir beim ueberfliegen deiner Beschreibung aufgefallen ist:
Zitat:
Zitat von danisahne
6.) Funktionshinweise
Die Konfiguration wird in einem eigenen Character Device in /var/flash gespeichert. Es enthält ein geziptes tar Archiv
Soweit ich das erkennen kann ist das tffs selbst schon gezipt (im duptffs von erik wird die zlib benoetigt und auch die Quellen im Kernel benutzen die zlib beim schreiben und lesen). Daher duerfte es eigentlich reichen wenn du das ganze nur tarst ohne es zu zippen.
Ansonsten kann ich nur sagen dass deine Beschreibung durchaus interessant klingt. Die Idee mit dem modularen Aufbau sehr gut ist (mal die Umsetzung ansehen). Und dass mein erster Gedanke auch war "ohje, noch ein mod mehr...."
owb ist offline
Alt 10.10.2005, 16:23   #12
ts201
IPPF-Fan
Sehe ich es richtig, und man kein dein mod dann über den webinterface port 81 konfigurieren ? das wäre ja cool
vielleicht sollte ihr mod-entwickler euch mal zusammen packen...
__________________
Anbindung : 1&1 16.000
Router : Fritz Box WLAN 7270
VoIP : Sipgate
Telefon : Nokia N86
ts201 ist offline
Alt 10.10.2005, 16:46   #13
danisahne
Semi-Moderator
Re: danisahne-mod
Zitat:
ok, dann kann ich mir das zippen sparen. Danke für die Info. Kommt aber erst in 2 Wochen.
Zitat:
Also nicht zuviel erwarten, ist sehr rudimentär. Das "dynamische" Nachladen vom Webspace ist noch nicht implementiert, aber vorbereitet.
Jedes "Paket" (ist ein tar, das ins Dateisystem entpackt wird) muss ein paar Vorraussetzungen erfüllen: ein rc Skript, default Konfiguration und ein cgi Skript. Ich werde dann mal noch ein Skelett für so ein "Paket" schreiben und ein kleines Howto, falls es jemanden interessiert. Ich stelle Paket ja auch immer in "", weil es nicht das ist, was man von Distributionen her kennt. Bei mir werden z.B. keine Abhängigkeiten geprüft. Für die Fritzbox reicht es denke ich. Mein Gedanke war eben auch, dass es viel mehr Software gibt, die sinnvoll für die Fritzbox ist, als Speicherplatz auf ihr ist. Außerdem kann man so neue "Pakete" ohne Flashen der Firmware austesten (noch nicht implementiert).
Zitat:
Von mir aus darf es ruhig 1000 mods geben, jeder hat seine Nische. Ich respektiere die Arbeit von haveaniceday und supamicha und baue auch auf einiges davon auf. Ich helf auch gerne bei m*.* mit, wenn was ansteht.
Warum mach ich den mod? Erst hab ich es nur für mich gemacht (lzma, iptables, etc.). Dann dachte ich mir, dass ein Webinterface auch andere Leute glücklich machen könnte, bis jetzt gibt es keinen mod mit Weboberfläche. mod-0.57 als Basis war mir zu wenig modular ... selbstgemacht hält besser (ich will wissen, was ich da mach), dachte ich mir und so kam es dazu.
Das einzige Neue im Vergleich zu mod-0.57 bei den Daemons ist dnsmasq. Ist nicht schwer den bei Bedarf auch in mod-0.57 zu integrieren.
@ts201
Ja, die gängigsten Parameter jedes Daemons kann man übers Webinterface ändern, sowie Daemons starten/stoppen und allgemeine Dateien, wie die crontab, /etc/hosts und /etc/ethers editieren.
Mein Webinterface ist so einfach, weil es auf meinem "Paket"-basierten Skripten aufsetzt. Ich bin aber gerne bereit an einem Webinterface für mod-0.57 bzw. m*.* mitzuarbeiten.
Mfg,
danisahne
PS:
@owb: Hab für mein character device extra eine minor genommen, die deine +1 ist. Vielleicht sollten wir das für alle unsere mods standartisieren, also jedem mod eine feste minor zuweisen, um ein einheitliches uninstall-image anbieten zu können, das sämtliche mod spezifische Änderungen rückgängig macht, egal welcher der mods vorher drauf war. Also debug.cfg leeren und die einzelnen character devices "clearen", falls jemand wieder zur originalen Firmware zurück will.
__________________
Alt 10.10.2005, 16:51   #14
ts201
IPPF-Fan
@ts201
Mein Webinterface ist so einfach, weil es auf meinem "Packet"-basierten Skripten aufsetzt. Ich bin aber gerne bereit an einem Webinterface für mod-0.57 bzw. m*.* mitzuarbeiten.
Das wäre doch genial - super ! Hoffentlich klappt es mit einer Zusammenarbeit zwischen euch !
__________________
VoIP : Sipgate
Telefon : Nokia N86
ts201 ist offline
Alt 10.10.2005, 17:23   #15
danisahne
Semi-Moderator
Wie ich gerade gesehen habe gibt es die .85er garnicht mehr zum Download (oder war die ne Einbildung von mir?). Bin leider nicht mehr zu Hause um es zu testen.
Workaround: Einfach das Skript fwmod_fon_wlan_7050.14.03.85 nach fwmod_fon_wlan_7050.14.03.86 kopieren und die Zeile
DL_SOURCE="fritz.box_fon_wlan_7050.14.03.85.image"
anpassen.
Klappen noch alle Patches während des Erstellens der Firmware? Läuft die Box danach noch? Natürlich wie immer auf eigene Gefahr und erst Recover Tools besorgen. Habs mit der .86er noch nicht ausprobiert.
Gruß,
danisahne
__________________
Alt 10.10.2005, 22:29   #16
buehmann
IPPF-Tausend-VIP
Benutzerbild von buehmann
Zitat:
Klappt mit .86; läuft auch noch -- und sieht gut aus. Nicht nur in der Weboberfläche, sondern auch im Code. Endlich der übersichtliche, modulare, (wahrscheinlich) leicht wartbare und erweiterbare Mod (den ich schon immer mal selbst schreiben wollte ;-)).
Danke, Daniel, tolle Arbeit!
__________________
VoIP mit PBX-network, GMX, sipgate, TelDaFax, dus.net über Good old Fritz!Box 7050 [14.04.33 freetz-devel + Callmonitor 1.16] hinter Kabelmodem [6 Mbit/s]
buehmann ist offline
Alt 11.10.2005, 20:14   #17
prxenon
IPPF-Einsteiger
Loginname beim Webnterface auf Port 81?
Tag,
ich hab das Mod jetzt auf ne FBF 5050 aufgespielt, und das Teil rennt. Hab natürlich auch die Passwörter gesetzt.
Aber ich kan mich jetzt nicht einloggen, weil ich den Benutzernamen für das Webinterface auf Port 81 nicht kenne. admin und root nimmt er nicht, mit allen erdenklichen Paswortkombinationen.
Mein Passwort war länger als 8 Zeichen, aber es kam keine Fehlermeldung - ich gehe davon aus, daß es im schlimmsten Fall auf 8 Zeichen degradiert wurde, aber ich ahne schlimmeres.
Welche Dateien kann ich löschen, damit die Passwörter zurückgesetzt werden?
Vielen Dank für Eure Hilfe
MfG
prx
prxenon ist offline
Alt 11.10.2005, 20:28   #18
prxenon
IPPF-Einsteiger
Sorry, meine Dummheit *aarrgh*
Sorry, hab das Problem behoben... ich sollte schon nach den Paswortänderungen neu starten...
prxenon ist offline
Alt 11.10.2005, 20:42   #19
danisahne
Semi-Moderator
Einfach nochmal
modpasswd dsmod
aufrufen und ein neues Passwort eingeben. Das Passwort ist in der mod.cfg gespeichert. Wie das mit meinen cfg Dateien funktioniert, das muß ich noch in die Funktionshinweise aufnehmen. Nur kurz:
- jedes Paket hat eine Konfigurationsdatei /mod/etc/conf/<paketname>.cfg
- desweiteren hat jedes Paket eine default-Konfiguration in /mod/etc/default.<paketname>/<paketname>.cfg (in dem Ordner sind auch sonstige default Sachen drinnen)
- abgespeichert wird nur alles das, was sich von der default Konfiguration unterscheidet, was in /tmp/flash/<paketname>.diff landet
- das Verzeichnis /tmp/flash/ wird in das character device getared
Am einfachsten ist es, die Dateien in /mod/etc/conf/ zu bearbeiten und dann 'modsave' auszuführen.
modsave
-> bildet alle diff-Dateien und speichert das Verzeichnis /tmp/flash/ ins tffs
modsave flash
-> speichert nur das Verzeichnis /tmp/flash/ ins tffs
Im Skript rc.webcfg wird schließlich die httpd.conf erzeugt, d.h. mit einem '/etc/init.d/rc.webcfg restart' sollte die Weboberfläche das neue Passwort mitbekommen.
Ich habe mich dazu entschlossen, die Konfigurationsdateien der Daemons (httpd.conf, bftpd.conf ...) im rc Skript direkt vor dem Start zu erzeugen, um nicht die ganze Konfig abspeichern zu müssen. so genügt es die übers Webinterface einstellbaren Optionen zu speichern. Das nur als kleiner Exkurs.
'/etc/init.d/rc.webcfg restart' hat bei einem Freund von mir mal nicht funktioniert, weil nach dem Stoppen des httpd der Port 81 immer noch gebunden war. Werden die Daemonen vielleicht durch das 'killall' zu abruppt abgeschossen? Welches Signal ist zum Beenden am besten geeignet?
Gruß,
danisahne
Mfg,
Daniel
PS: Der mod ist noch sehr jung und von mir noch nicht für abschließend stabil befunden (darum rc1). Ich konnte einfach noch zu wenig testen. Wenn euch also Bugs auffallen, dann zögert nicht mir eine PN mit einer Beschreibung zu schreiben.
__________________
Alt 12.10.2005, 17:00   #20
martian
IPPF-Fan
Benutzerbild von martian
Hey danisahne...
Ich würd dich gern motivieren, den WOL-Mod, soweit er denn fertig ist, in deinen Mod zu integrieren...
Den Mod findest du hier,
der könnte ja automatisch eingespielt werden (is ja nurn shellskript), wobei jeder, bevor er den Mod nutzt sich seine eigene MAC-Adresse eintragen müsste.
Vielleicht wirds ja was
Vlg martian
__________________
Boxen: gaanz viele ! z.B. 7270_16mb, 7170, 7050, 2x Eumex 300IP@Fritzbox-GUI, Speedport W501V & W701V@SP2Fritz, teilweise gefreetzt
Telefon: diverse POTS (T-Com) und ISDN (T-Com)
VoIP: 1und1, sipgate, tcom
Anbindung: Alice-DSL Light, 1und1DSL
martian ist offline
Thema geschlossen
Thema durchsuchen:
Erweiterte Suche
Ansicht
Forumregeln
Es ist dir nicht erlaubt, neue Themen zu verfassen.
Es ist dir nicht erlaubt, auf Beiträge zu antworten.
Es ist dir nicht erlaubt, Anhänge anzufügen.
Es ist dir nicht erlaubt, deine Beiträge zu bearbeiten.
vB Code ist An.
Smileys sind An.
[IMG] Code ist An.
HTML-Code ist Aus.
Ähnliche Themen
Thema Erstellt von Forum Antworten Letzter Beitrag
OpenVPN Paket für ds-0.1rc4 Mod (Vorabversion) dksoft2 FRITZ!Box Fon: Modifikationen 27 08.06.2006 22:44
neuer mod - m4.24 supamicha FRITZ!Box Fon: Modifikationen 7 02.10.2005 13:28
neuer mod - 0.57m3.1 + 0.57m4.1 supamicha FRITZ!Box Fon: Modifikationen 11 15.08.2005 13:39
neuer mod - 0.57m3 + 0.57m4 supamicha FRITZ!Box Fon: Modifikationen 30 06.08.2005 19:17
Alle Zeitangaben in WEZ +1. Es ist jetzt 12:28 Uhr.
Powered by vBulletin Version 3.6.8 (Deutsch)
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
