Asterisk 1.2.3 (Critical Update !)
betateilchen
Grandstream-Guru
30 Jun 2004
Hallo !
Die neue Asterisk Version 1.2.3. steht auf http://www.asterisk.org zum Download bereit.
Das Installieren behebt einen kritischen Fehler, der dazu führt, daß seit heute auf dem Server keine Audio-Verbindungen mehr funktionieren.
Das Update sollte also unbedingt durchgeführt werden !
Hier gibt es die Diskussion zum Thema
Changelog ab 1.2.2 schrieb:
2006-01-25 Russell Bryant <[email protected]>
* Asterisk 1.2.3 Released
2006-01-25 09:46 +0000 [r8632] Olle Johansson <[email protected]>
* channel.c: Issue #6439 - the "timebomb" bug. Patch by Markster
over GPRS
2006-01-25 05:38 +0000 [r8619] Russell Bryant <[email protected]>
* utils/astman.c: don't leak almost 200 bytes for each new channel
(issue #6330)
2006-01-25 01:50 +0000 [r8608] Kevin P. Fleming <[email protected]>
* apps/app_dial.c: ensure hangup cause code is handled properly
when channel does not return a frame (issue #6346)
2006-01-24 22:55 +0000 [r8600] Russell Bryant <[email protected]>
* asterisk.c: completely arbitrary whitespace change for testing
something with svnmerge ...
2006-01-24 22:32 +0000 [r8588] Kevin P. Fleming <[email protected]>
* channel.c: ensure that channel cannot become zombie after we
check but before we try to start indications
2006-01-24 20:37 +0000 [r8573] Matt Frederickson <[email protected]>
* channels/chan_zap.c: Backport fix for #6229, hangup on polarity
reversal
2006-01-24 19:21 +0000 [r8537-8562] Olle Johansson <[email protected]>
* channels/chan_sip.c: Issue 6114: Don't hangup on BYE/ALSO with no
channel.
* channels/chan_sip.c: Issue #6308 - never send response to ACK.
(Reported by whiskerp)
2006-01-22 19:03 +0000 [r8437-8445] Russell Bryant <[email protected]>
* apps/app_queue.c: fix memory leak from not freeing the queue
member list when freeing an old queue
* channel.c: fix MixMonitor crash (issue #6321, probably others)
2006-01-22 15:13 +0000 [r8433] BJ Weschke <[email protected]>
* channels/chan_sip.c: Bug fix: Correct some scenarios where
CALL_LIMIT could not be getting adjusted properly allowing
chan_sip to send calls when it really shouldn't. Bug #6111
2006-01-22 08:52 +0000 [r8429] Tilghman Lesher <[email protected]>
* channels/chan_sip.c: Bug 6281 - Cannot set more than a single
header with SIPAddHeader
2006-01-22 02:05 +0000 [r8412-8418] Russell Bryant <[email protected]>
* pbx.c: add a modified fix to prevent writing outside of the
provided workspace when calculating a substring (issue #6271)
2006-01-21 18:29 +0000 [r8394] Tilghman Lesher <[email protected]>
* apps/app_queue.c: Bug 5936 - AddQueueMember fails on realtime
queue, if queue not yet loaded
2006-01-20 18:34 +0000 [r8347] Russell Bryant <[email protected]>
* apps/app_queue.c: fix invalid value of prev_q (issue #6302)
2006-01-20 01:00 +0000 [r8320] Matt O'Gorman <[email protected]>
* channels/chan_iax2.c: solved problem with delayreject and iax
trunking bug 4291
2006-01-19 19:40 +0000 [r8281] Olle Johansson <[email protected]>
* channels/chan_sip.c: Enable "musicclass" setting for sip peers as
per the config sample.
2006-01-19 19:14 +0000 [r8276] Tilghman Lesher <[email protected]>
* ast_expr2.y, ast_expr2.fl: Bug 6072 - Memory leaks in the
expression parser
2006-01-19 04:56 +0000 [r8232-8242] Russell Bryant <[email protected]>
* channels/chan_sip.c: fix Message-Account header to use the ip
address if the fromdomain isn't set (issue #6278)
* apps/app_milliwatt.c: fix a seg fault due to assuming that space
gets allocatted on the stack in the same order that we declare
the variables (issue #6290)
2006-01-18 21:02 +0000 [r8194] Matt O'Gorman <[email protected]>
* apps/app_meetme.c: Solves issue with the login proccess in meetme
patch from 6136
AA-Idealbau
