Ich habe mal die Start-JFritz-DebugMode.bat gestartet und erhalte eine Debug.txt mit folgenden Inhalt:
(13:59:58) DEBUG: logging to file "D:\Dokumente und Einstellungen\Ronny Brandt\Anwendungsdaten\FRITZ!\Anrufliste\debug.txt" has been enabled
(13:59:58) DEBUG: Save Dir: D:\Dokumente und Einstellungen\Ronny Brandt\Anwendungsdaten\FRITZ!\Anrufliste\
(13:59:59) DEBUG: Multiple instance lock: set lock.
(13:59:59) DEBUG: Operating System : Windows XP
(13:59:59) DEBUG: JFritz runs on Windows
(13:59:59) DEBUG: Urlstr:
http://192.168.1.1:80/cgi-bin/webcm
(13:59:59) DEBUG: Postdata: getpage=../html/de/menus/menu2.html&var%3Alang=de&var%3Amenu=home&var%3Apagename=home&login%3Acommand%2Fpassword=passwort
(14:00:01) DEBUG: Detected Firmware: 29.04.21 de
(14:00:01) DEBUG: Sorting unfiltered data
(14:00:01) DEBUG: updating the filter
(14:00:01) DEBUG: Sorting all filtered Rows
(14:00:01) DEBUG: Start commandline parsing
(14:00:02) DEBUG: New instance of JFrame
(14:00:02) DEBUG: Create JFritz-GUI
(14:00:03) DEBUG: Subdirectory: \lang
(14:00:03) DEBUG: full path: D:\Programme\Tools\FRITZ!\JFritz\lang
(14:00:04) DEBUG: Check Systray-Support
(14:00:04) ERROR: java.lang.IllegalArgumentException: Width (-1) and height (-1) cannot be <= 0
(14:00:04) DEBUG: Searching for FritzBox per UPnP / SSDP
(14:00:05) DEBUG: Timeout for SSDP
(14:00:05) DEBUG: Box found at /192.168.1.1: FRITZ!Box Fon WLAN 7170 UPnP/1.0 AVM FRITZ!Box Fon WLAN 7170 (UI) 29.04.21
(14:00:05) DEBUG: Box found at /192.168.1.2: FRITZ!Box Fon WLAN 7050 UPnP/1.0 AVM FRITZ!Box Fon WLAN 7050 (UI) 14.04.15
(14:00:06) ERROR: Error while retrieving
http://www.jfritz.org/update/current.txt (possibly no connection to the internet)
(14:00:06) DEBUG: CheckVersionThread exiting..
(14:00:07) DEBUG: Action fetchList
(14:00:07) DEBUG: Starting FBoxListener
(14:00:07) DEBUG: FBoxListener V3
(14:00:07) DEBUG: Watchdog enabled
(14:00:07) DEBUG: Trying to connect to 192.168.1.1:1012
(14:00:07) DEBUG: Connected
(14:00:07) DEBUG: box.address: 192.168.1.1
(14:00:07) DEBUG: box.port: 80
(14:00:07) DEBUG: box.password: *******
(14:00:07) DEBUG: box.firmware: 29.04.21 de
(14:00:07) DEBUG: Opening HTML Callerlist page
(14:00:07) DEBUG: Urlstr:
(14:00:07) DEBUG: Postdata: getpage=../html/de/menus/menu2.html&var%3Alang=de&var%3Amenu=fon&var%3Apagename=foncalls&login%3Acommand%2Fpassword=passwort
(14:00:09) DEBUG: Retrieving the CSV list from the box
(14:00:10) DEBUG: Received response, begin processing call list
(14:00:10) DEBUG: CSV-Header: Typ;Datum;Name;Rufnummer;Nebenstelle;Eigene Rufnummer;Dauer
(14:00:10) DEBUG: 17 Lines read from csv file
(14:00:10) DEBUG: 0 New entries processed
(14:00:10) DEBUG: Sorting unfiltered data
(14:00:10) DEBUG: updating the filter
(14:00:10) DEBUG: Sorting all filtered Rows
(14:00:10) DEBUG: Finished processing response
(14:00:13) DEBUG: Starting shutdown thread..
(14:00:13) DEBUG: Multiple instance lock: release lock.
(14:00:13) DEBUG: Save window position
(14:00:13) DEBUG: Save column widths
(14:00:13) DEBUG: Save other properties
(14:00:13) DEBUG: Saving to file D:\Dokumente und Einstellungen\Ronny Brandt\Anwendungsdaten\FRITZ!\Anrufliste\jfritz.properties.xml
(14:00:13) DEBUG: Saving to file D:\Dokumente und Einstellungen\Ronny Brandt\Anwendungsdaten\FRITZ!\Anrufliste\jfritz.quickdials.xml
(14:00:13) DEBUG: Stopping FBoxListener
(14:00:13) DEBUG: IO exception: java.net.SocketException: socket closed
(14:00:13) DEBUG: Shutdown thread done.
Ich hoffe, das ist die richtige.
MfG Ronny
