AR1688 0.14 release
rollo
IPPF-Promi
5 Jul 2004
Newly add program for 0.14 release download.(2007-6-5 update)
Changes and Fixes in 0.14 release:
1. Continue to improve voice quality for G.729 and iLBC, now G.729 passed all ITU-T bit-exactly test vectors.
2. Fixed another out-going packet sequence bug, and "Voice Frames per TX" option is OK to use now.
3. Enlarged all codec out-going packet buffer except for G.711, also enlarged hardware record buffer.
4. Enlarged all codec in-coming packet buffer except for G.711.
5. Added French accented characters display for dot-matrix LCD design like AR168G.
6. Fixed a SIP call transfer bug.
7. Fixed a local generate ringback tone bug.
8. Fixed a ring bug.
9. Updated SDCC compiler to 2.7.0 release version.
10. Alfredo Sorbello added Italian support.
http://aredfox.com/eindex.htm
AR1688 0.34 release
AR series 0.34 release
Changes and Fixes in 0.34 release:
1. Fixed an IAX2 "Send Text" command bug
2. Added load and store default settings function in main program menu
3. Omitted receiving UDP&TCP check sum check to boost performance
4. Added Davicom DM9003 support
5. Fixed an ip fragment memory allocation bug
6. Improved G.726 32kpbs voice quality
7. Added call-waiting tone
8. Changed part of SetHighSpeed() to more detailed SetZ80Speed() function
9. Improved Speex performance
Firmware Downlod:http://www.yntx.com/files/AR_series/0.34.rar
LukasB
