Asterisk SRTP Installation
jahsoldier
1 Sep 2006
ich möchte gerne auf meinem SUSE 9.2 System Asterisk mit SRTP-Support installieren. Im Internet habe ich dazu folgende Anleitung gefunden: http://www.e164.org/wiki/AsteriskSRTP
Vor der eigentlichen Installation habe ich bereits folgende Pakete mit YAST nachinstalliert: kernel-source,
openssl, openssl-devel, bison, termcap, ncurses, ncurses-devel, autoconf.
Leider erhalte ich beim Befehl "make menuselect" folgende Fehlermeldung:
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ANSI C... none needed
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking for a BSD-compatible install... /usr/bin/install -c
checking for ranlib... ranlib
checking for ar... /usr/bin/ar
checking for cp... /bin/cp
checking for ln... /bin/ln
checking for mkdir... /bin/mkdir
checking for nroff... /usr/bin/nroff
checking for rm... /bin/rm
checking for strdup... yes
checking for vsnprintf... yes
configure: creating ./config.status
config.status: creating Makefile
config.status: creating mxml.list
config.status: creating mxml.pc
config.status: creating config.h
make -C mxml libmxml.a
make[1]: Entering directory `/home/jahsoldier/downloads/asterisk/securertp-trunk/mxml'
gcc -O -Wall   -c mxml-attr.c
gcc -O -Wall   -c mxml-entity.c
gcc -O -Wall   -c mxml-file.c
gcc -O -Wall   -c mxml-index.c
gcc -O -Wall   -c mxml-node.c
gcc -O -Wall   -c mxml-search.c
gcc -O -Wall   -c mxml-set.c
gcc -O -Wall   -c mxml-private.c
gcc -O -Wall   -c mxml-string.c
/bin/rm -f libmxml.a
/usr/bin/ar crvs libmxml.a mxml-attr.o mxml-entity.o mxml-file.o mxml-index.o mxml-node.o mxml-search.o mxml-set.o mxml-private.o mxml-string.o
a - mxml-attr.o
a - mxml-entity.o
a - mxml-file.o
a - mxml-index.o
a - mxml-node.o
a - mxml-search.o
a - mxml-set.o
a - mxml-private.o
a - mxml-string.o
ranlib libmxml.a
make[1]: Leaving directory `/home/jahsoldier/downloads/asterisk/securertp-trunk/mxml'
make[1]: Entering directory `/home/jahsoldier/downloads/asterisk/securertp-trunk/menuselect'
make[2]: Entering directory `/home/jahsoldier/downloads/asterisk/securertp-trunk/menuselect/mxml'
make[2]: *** No rule to make target `libmxml.a'.  Stop.
make[2]: Leaving directory `/home/jahsoldier/downloads/asterisk/securertp-trunk/menuselect/mxml'
make[1]: *** [mxml/libmxml.a] Error 2
make[1]: Leaving directory `/home/jahsoldier/downloads/asterisk/securertp-trunk/menuselect'
make: *** [menuselect/menuselect] Error 2
Kann mir jemand sagen, wo das Problem liegt? Gibt es hier jemanden, der Asterisk mit SRTP erfolgreich installiert hat?
Über Hilfe wäre ich sehr dankbar...
jahsoldier
Code?
cibi schrieb:
Auf der Seite gibt es den Link zu
http://bugs.digium.com/view.php?id=5413
Dort hat evilbunny denselben Fehler gemeldet (noch keine Antwort) - wohl ein generelles Problem mit der aktuellen svn Version.
Ok, danke. Hat jemand von Euch noch einen funktionsfähigen Code des srtp-trunk oder eine andere Möglichkeit SRTP in Asterisk zu integrieren?
jahsoldier
Cheffo
