[Asterisk-Users] IPSwitchBoard Version 0.76 released
rajo
Admin-Team
31 Mrz 2004
Evtl. für den ein oder anderen hier interessant:
Thorben Jensen schrieb:
Release notes:
• Pop-up on incoming call is now configurable
• Romanian Language updated
• Language can be changed on config page (Remember to restart after changing language)
• Bug fixes
Download here: http://ipswitchboard.thorben.dk
_____________________
IPSwitchBoard is an Operators Panel for the Asterisk PBX. IPSwitchBoard is a FREE Windows.NET application which gives you:
* Unattended/attended transfers.
* Park calls and retrieve/forward them again.
* Organize all your SIP and IAX extensions (automatically retrieved from Asterisk).
* Monitor all extensions.
* Monitor all queues.
* Monitor Agents.
* Monitor Parked Calls.
* Dynamically log extensions in and out of queues.
* Integration with CRM software on the web.
* Drop any active call.
* Import/Export extensions to/from Asterisk Server DB.
* Set Do Not Disturb on Extensions and give a reason.
* Speed Dialling.
* Share Speed Dial files among all users of IPSwitchBoard.
* User selectable ring tones for IPSwitchBoard.
* User selectable button colors.
Anm.: ich kenne es selber nicht und kann nicht sagen ob und wie das tut, habs nur grade auf der Mailinglist gelesen und mir mal die Webseite angeschaut. Evtl. mags ja wer testen und drüber berichten ;)
Beronimus
