Beta- Firmware 1.0.3.18
rsl
Aktives Mitglied
27 Mai 2004
Nach fast 7 Monaten Stillstand :-( eine neue Beta- Firmware
!!! Wie gehabt Beta und auf eigene Gefahr !!!
Aus den Release- Notes:
Firmware release1.0.3.18 is has some major changes compare with 1.0.2.x releases, it may take more than 5 minutes to upgrade from 1.0.2.x to 1.0.3.18.
Make sure all the files in HT386-488-496_Release_1.0.3.18.zip are unzipped into the TFTP server.
Once upgraded to 1.0.3.18, it can NOT be downgraded to any release with 1.0.2.x.
HTTP provisioning and firmware upgrade are supported starting from 1.0.3.18.
Release Notes
1.0.3.18
# New boot loader 1.0.8.9 for better system management
# Added application level TFTP upgrade support
# Added application level HTTP upgrade support
# Added support for firmware encryption
# Added support of HTML image compression
# Added Lucent FS5000 special feature
# Added RNK special feature
# Added DTMF-Brazil/DTMF-Denmark/DTMF-Sweden Caller ID scheme
# Added firmware upgrade logging
# Added firmware validation routine (for HT-386/496)
# Added TFTP/HTTP provision upon DHCP/PPPoE completion if no IP address was available initially
# Added adaptive mechanism to resolve iLBC dual mode 20/30ms
# Added preventive measures from downgrading to any 1.0.2.x builds for all sipp2 models
# Added PPPoE service name configuration field on 386/488/496
# Removed HT488 MWI and T.38 Fax components from FXO port web UI (N/A in this case)
# Change Web UI wording for 488 to indicate call forward on ring-no-answer
# Removed "WAN" word from Status pages for 386
# Fixed fxs2 port (386/496) and fxo (488 ) port UI : silence suppression cannot be set
# Fixed TFTP retry
# Fixed VLAN bug
# Fixed random number generation
# Fixed SDP handling issue on /1 after the port number in the SDP m-line (G729r8 problem)
# Changed to accept both Message-Waiting and Messages-Waiting in MWI NOTIFY (415 problem reported)
# Fixed DHCP server (488/496) fails to work if a DHCP client's MAC address is same as the cloned MAC address.
# Fixed DHCP server always send DHCP NAK when client attempt to renew expired IP lease
# Fixed DHCP client fails to restart DHCP discovery process after receiving DHCP NAK on renewal
# Reduced the DHCP polling interval to 30 seconds from 1 minute (this is the effective minimum DHCP renewal time)
# Fixed a DTMF scaling problem (low DTMF tones )
# Fixed NTP additional CI option issue
# Fixed SIP response fallback (zero IP address)
# Fixed 488 sending INV out upon FXO incoming PSTN call if FXS port has offhook auto dial configured
# Fixed 2nd port using fixed RTP port doesn't seem to work correctly (if set 54008. it uses 5401)
# Fixed HT488 assigned echo canceller to FXS port if FXS call PSTN through FXO
# Adjusted HT488 voice volume on FXS phone
# Fixed early dial issue on 386/488/496
# Fixed # is sent out as dialed number even if Use # as Dial Key is configured
# Fixed subnet issue (customer report.)
# Fixed we respond 200 OK and then a 481 for SIP INFO
# Fixed 386/488/496 cannot process BYE when challenged by 401 unauthorized server response
# Fixed 488/496 router WAN side MAC cloning bug
# Fixed 0 MAC address under PPPoE causes no RTP streams
# Fixed 386/496 FXS 1 calls FS2 crashes under certain scenarios
# Fixed P-Asserted-Header crashes
# Fixed SIP nonce overflow
# Fixed 488 far end disconnect issue
Firmware:
http://www.grandstream.com/BETATEST/HT488_496_386/HT386-488-496_Release_1.0.3.18.zip
Release Notes:
http://www.grandstream.com/BETATEST/HT488_496_386/Release_Note_HT386-488-496_1_0_3_18.pdf
kann man auch nicht-beta Firmware herunterladen, um Update von localem tftp server zu machen ?
Für diese Geräteserie gibt es meines Erachtens noch keine Firmware-Version, die über die Qualitätsstufe "BETA" hinausgekommen ist.
Vielleicht sollte man mal ein paar Kartons 386/496/488 als RMA anmelden :-(
rsl
H350
