Saratoga:/home/christopher/downloads/bristuff-0.2.0-RC3a/zaphfc # make loadNT
make -C /usr/src/linux-2.6 SUBDIRS=/home/christopher/downloads/bristuff-0.2.0-RC3a/zaphfc modules
make[1]: Entering directory `/usr/src/linux-2.6.8-24.10'
Building modules, stage 2.
MODPOST
make[1]: Leaving directory `/usr/src/linux-2.6.8-24.10'
modprobe zaptel
insmod ./zaphfc.ko modes=1
ztcfg -v
Zaptel Configuration
SPAN 1: CCS/ AMI Build-out: 399-533 feet (DSX-1)
3 channels configured.
ZT_CHANCONFIG failed on channel 2: Invalid argument (22)
Did you forget that FXS interfaces are configured with FXO signalling
and that FXO interfaces use FXS signalling?
make: *** [loadlinux26NT] Error 1
loadzone=nl
defaultzone=nl
span=1,1,3,ccs,ami
bchan=1-2
dchan=3
enschy schrieb:Der aktuelle bri-stuff geht nicht mehr, da die auf dem ftp Server die aktuelle Version (1.0.3) auf 1.0.4 gewechselt wurde.....
Anpassen der download.sh hilft
13:26:43 (168.94 KB/s) - »asterisk-1.0.4.tar.gz« gespeichert [9582822]
patching file Makefile
Hunk #3 FAILED at 45.
1 out of 3 hunks FAILED -- saving rejects to file Makefile.rej
patching file zaptel.c
Hunk #1 succeeded at 4755 (offset 6 lines).
Hunk #2 succeeded at 4776 (offset 6 lines).
Hunk #3 succeeded at 4850 (offset 6 lines).
Hunk #4 succeeded at 4871 (offset 6 lines).
Hunk #5 succeeded at 4909 (offset 6 lines).
Hunk #6 succeeded at 5579 (offset 6 lines).
Hunk #7 succeeded at 5648 (offset 6 lines).
patching file zaptel.h
patching file libpri.h
patching file pri.c
patching file pri_internal.h
patching file pri_q921.h
patching file pri_q931.h
patching file prisched.c
patching file pritest.c
patching file q921.c
patching file q931.c
patching file README
patching file TODO
patching file apps/app_chanisavail.c
Hunk #1 succeeded at 81 (offset 1 line).
patching file apps/app_dial.c
Hunk #8 succeeded at 366 (offset 3 lines).
Hunk #9 succeeded at 729 (offset 3 lines).
Hunk #10 succeeded at 756 (offset 3 lines).
Hunk #11 succeeded at 785 (offset 3 lines).
Hunk #12 succeeded at 897 (offset 5 lines).
patching file apps/app_meetme.c
patching file apps/app_parkandannounce.c
patching file apps/app_pickup.c
patching file apps/app_qcall.c
patching file apps/app_queue.c
patching file apps/Makefile
patching file astconf.h
patching file asterisk.c
patching file asterisk.h
patching file channel.c
Hunk #13 FAILED at 2451.
Hunk #14 succeeded at 2511 (offset 5 lines).
1 out of 14 hunks FAILED -- saving rejects to file channel.c.rej
patching file channels/chan_agent.c
Hunk #1 succeeded at 1074 (offset 4 lines).
patching file channels/chan_iax2.c
Hunk #2 succeeded at 2404 (offset 4 lines).
Hunk #3 succeeded at 5534 (offset 36 lines).
patching file channels/chan_sip.c
Hunk #1 succeeded at 3799 (offset 17 lines).
Hunk #2 succeeded at 3834 with fuzz 1 (offset 19 lines).
Hunk #3 succeeded at 3873 (offset 19 lines).
Hunk #4 succeeded at 3898 (offset 19 lines).
patching file channels/chan_zap.c
Hunk #5 succeeded at 287 (offset 3 lines).
Hunk #6 succeeded at 336 (offset 3 lines).
Hunk #7 succeeded at 369 (offset 3 lines).
Hunk #8 succeeded at 388 (offset 3 lines).
Hunk #9 succeeded at 417 (offset 3 lines).
Hunk #10 succeeded at 591 (offset 4 lines).
Hunk #11 succeeded at 620 (offset 4 lines).
Hunk #12 succeeded at 676 (offset 4 lines).
Hunk #13 succeeded at 1873 (offset 4 lines).
Hunk #14 succeeded at 1898 (offset 4 lines).
Hunk #15 succeeded at 2083 (offset 4 lines).
Hunk #16 succeeded at 2279 (offset 4 lines).
Hunk #17 succeeded at 2478 (offset 4 lines).
Hunk #18 succeeded at 2739 (offset 4 lines).
Hunk #19 succeeded at 4186 (offset 4 lines).
Hunk #20 succeeded at 4516 (offset 4 lines).
Hunk #21 succeeded at 4598 (offset 4 lines).
Hunk #22 succeeded at 4623 (offset 4 lines).
Hunk #23 succeeded at 4801 (offset 4 lines).
Hunk #24 succeeded at 4851 (offset 4 lines).
Hunk #25 succeeded at 6258 (offset 4 lines).
Hunk #26 succeeded at 6510 (offset 4 lines).
Hunk #27 succeeded at 6542 (offset 4 lines).
Hunk #28 succeeded at 6555 (offset 4 lines).
Hunk #29 succeeded at 6956 (offset 4 lines).
Hunk #30 succeeded at 7001 (offset 4 lines).
Hunk #31 succeeded at 7224 (offset 4 lines).
Hunk #32 succeeded at 7239 (offset 4 lines).
Hunk #33 succeeded at 7255 (offset 4 lines).
Hunk #34 FAILED at 7267.
Hunk #35 succeeded at 7341 (offset 5 lines).
Hunk #36 succeeded at 7414 (offset 5 lines).
Hunk #37 succeeded at 7460 (offset 5 lines).
Hunk #38 succeeded at 7568 (offset 5 lines).
Hunk #39 succeeded at 7702 (offset 5 lines).
Hunk #40 succeeded at 7796 (offset 5 lines).
Hunk #41 succeeded at 7847 (offset 5 lines).
Hunk #42 succeeded at 7863 (offset 5 lines).
Hunk #43 succeeded at 7884 (offset 5 lines).
Hunk #44 succeeded at 7918 (offset 5 lines).
Hunk #45 succeeded at 7942 (offset 5 lines).
Hunk #46 succeeded at 7965 (offset 5 lines).
Hunk #47 succeeded at 8039 (offset 5 lines).
Hunk #48 succeeded at 8085 (offset 5 lines).
Hunk #49 succeeded at 8122 (offset 5 lines).
Hunk #50 succeeded at 8202 (offset 5 lines).
Hunk #51 succeeded at 8220 (offset 5 lines).
Hunk #52 succeeded at 8246 (offset 5 lines).
Hunk #53 succeeded at 8562 (offset 5 lines).
Hunk #54 succeeded at 8586 (offset 5 lines).
Hunk #55 succeeded at 8614 (offset 5 lines).
Hunk #56 succeeded at 8643 (offset 5 lines).
Hunk #57 succeeded at 8664 (offset 5 lines).
Hunk #58 succeeded at 8679 (offset 5 lines).
Hunk #59 succeeded at 8700 (offset 5 lines).
Hunk #60 succeeded at 8899 (offset 5 lines).
Hunk #61 succeeded at 9192 (offset 5 lines).
Hunk #62 succeeded at 9216 (offset 5 lines).
Hunk #63 succeeded at 9788 (offset 5 lines).
Hunk #64 succeeded at 10334 (offset 5 lines).
Hunk #65 succeeded at 10393 (offset 5 lines).
Hunk #66 succeeded at 10449 (offset 5 lines).
Hunk #67 succeeded at 10606 (offset 7 lines).
Hunk #68 succeeded at 10621 (offset 7 lines).
Hunk #69 succeeded at 10909 (offset 7 lines).
Hunk #70 succeeded at 10999 (offset 7 lines).
1 out of 70 hunks FAILED -- saving rejects to file channels/chan_zap.c.rej
patching file codecs/codec_ilbc.c
patching file HARDWARE
patching file include/asterisk/channel.h
patching file include/asterisk/features.h
patching file include/asterisk/pbx.h
patching file manager.c
patching file pbx/pbx_spool.c
patching file pbx/pbx_wilcalu.c
patching file pbx.c
Hunk #3 succeeded at 4053 (offset 15 lines).
Hunk #4 succeeded at 4064 (offset 15 lines).
Hunk #5 succeeded at 4119 (offset 15 lines).
Hunk #6 succeeded at 4155 (offset 15 lines).
Hunk #7 succeeded at 4171 (offset 15 lines).
Hunk #8 succeeded at 4183 (offset 15 lines).
Hunk #9 succeeded at 4229 (offset 15 lines).
Hunk #10 succeeded at 4443 (offset 15 lines).
Hunk #11 succeeded at 4839 (offset 15 lines).
Hunk #12 succeeded at 4849 (offset 15 lines).
Hunk #13 succeeded at 4862 (offset 15 lines).
Hunk #14 succeeded at 4875 (offset 15 lines).
patching file res/res_features.c
Hunk #6 FAILED at 217.
Hunk #7 succeeded at 277 (offset 1 line).
Hunk #8 succeeded at 340 (offset 1 line).
Hunk #9 succeeded at 358 (offset 1 line).
Hunk #10 succeeded at 499 (offset 1 line).
Hunk #11 succeeded at 560 (offset 1 line).
Hunk #12 succeeded at 759 (offset 1 line).
Hunk #13 succeeded at 1188 (offset 1 line).
Hunk #14 succeeded at 1211 (offset 1 line).
Hunk #15 succeeded at 1601 (offset 1 line).
Hunk #16 succeeded at 1656 (offset 1 line).
Hunk #17 succeeded at 1711 (offset 1 line).
1 out of 17 hunks FAILED -- saving rejects to file res/res_features.c.rej
patching file rtp.c
Hunk #1 succeeded at 418 (offset 10 lines).
patching file .version
Hunk #1 FAILED at 1.
1 out of 1 hunk FAILED -- saving rejects to file .version.rej
