[Problem] Build schlägt fehl
sharbich
30 Aug 2012
Hallo Ihr Lieben,
wenn ich über "make menuconfig" das paket "sudo 1.7.10 (binary only)" auswähle schlägt der Build mit folgender Fehlermeldung fehl.
cmd() { PATH="/home/manitschke/Downloads/freetz/freetz-trunk/toolchain/build/mips_gcc-4.8.5_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin:/home/manitschke/Downloads/freetz/freetz-trunk/toolchain/build/mips_gcc-4.8.5/mips-unknown-linux-gnu/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games" LD_RUN_PATH="/usr/lib/freetz" FREETZ_LIBRARY_DIR="/usr/lib/freetz" make  "$@"  || { printf "\n\\033[33m%s\\033[m\n" "ERROR: Build failed.";  exit 1; } };     if [ -e source/.echo_item_start -a ! -e source/.echo_item_build ]; then echo -n "building... "; touch source/.echo_item_build; fi; cmd -C source/target-mips_gcc-4.8.5_uClibc-0.9.33.2-nptl/sudo-1.7.10p8
make[1]: Entering directory '/home/manitschke/Downloads/freetz/freetz-trunk/source/target-mips_gcc-4.8.5_uClibc-0.9.33.2-nptl/sudo-1.7.10p8'
/home/manitschke/Downloads/freetz/freetz-trunk/toolchain/build/mips_gcc-4.8.5_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -o sudo sudo_auth.o getspwuid.o passwd.o  mkstemps.o exec_pty.o get_pty.o iolog.o audit.o boottime.o check.o env.o exec.o gettime.o goodpath.o fileops.o find_path.o interfaces.o lbuf.o logging.o logwrap.o parse.o parse_args.o set_perms.o sudo.o sudo_edit.o sudo_nss.o tgetpass.o ttyname.o -L.  -Wl,-z,relro -pie  -lsudo -lcrypt
get_pty.o: In function `get_pty':
get_pty.c:(.text+0x68): undefined reference to `openpty'
get_pty.c:(.text+0x7c): undefined reference to `openpty'
collect2: error: ld returned 1 exit status
Makefile:238: recipe for target 'sudo' failed
make[1]: *** [sudo] Error 1
make[1]: Leaving directory '/home/manitschke/Downloads/freetz/freetz-trunk/source/target-mips_gcc-4.8.5_uClibc-0.9.33.2-nptl/sudo-1.7.10p8'
make/sudo/sudo.mk:31: recipe for target 'source/target-mips_gcc-4.8.5_uClibc-0.9.33.2-nptl/sudo-1.7.10p8/sudo' failed
make: *** [source/target-mips_gcc-4.8.5_uClibc-0.9.33.2-nptl/sudo-1.7.10p8/sudo] Error 1
Das passiert beim Build aller meiner Boxen (7320 und 7390). Habt Ihr eine Lösung?
Aktueller trunk "Revision 13651".
Lieben Gruß von Stefan Harbich
hah, genau das gleiche Problem habe ich zur Zeit auch für meine 7270. Ich habe sudo aus der Liste der Pakete herausgewählt, danach ging es :p
michaelwarwel
IPPF im Überblick
