Chan Capi 4.0 Pre 1
rannseier
Aktives Mitglied
5 Mai 2004
Hi
nicht besonders gut kenntlich gemacht - aber trotzdem gefunden :-D
Hier sind die änderungen:
- ATTENTION! the dialstring syntax now uses the zaptel dialstring syntax
it used to be: Dial(CAPI/[@]<outgoingMSN>:[b|B]<destination>)
now it is: Dial(CAPI/g<group>/[b|B]<destination>)
or: Dial(CAPI/contr<controller>/[b|B]<destination>)
CLIP/CLIR is now uses the calling presentation of the calling channel, this can
be modified using the CallingPres() application. Use CallinPres(32) for CLIR.
That is why the msn= param in capi.conf is now obsolete. The callerID is also
taken from the calling channel.
- fixes for BSD (Jan Stocker)
Thorsten
Hi
also compiliert klieg ich´s nicht. Ich verwende die letzte Brit-Stuff-Version.
beim make bekomme ich
debian:/usr/src/chan_capi-0.4.0-PRE1# make
gcc -pipe -Wall -Wmissing-prototypes -Wmissing-declarations -g  -I/usr/include -D_REENTRANT -D_GNU_SOURCE -O6 -march=i686  -DCAPI_ES -DCAPI_GAIN -DCAPI_SYNC -DASTERISKVERSION=\"\" -DCVS_HEAD -Wno-missing-prototypes -Wno-missing-declarations -DCRYPTO   -c -o chan_capi.o chan_capi.c
chan_capi.c: In function `capi_call':
chan_capi.c:674: error: structure has no member named `cid'
chan_capi.c:730: error: structure has no member named `cid'
chan_capi.c:741: error: structure has no member named `cid'
chan_capi.c: In function `capi_read':
chan_capi.c:864: error: structure has no member named `cid'
chan_capi.c: In function `capi_new':
chan_capi.c:1110: error: structure has no member named `cid'
chan_capi.c:1111: error: structure has no member named `cid'
chan_capi.c: In function `change_callingpres':
chan_capi.c:2637: error: structure has no member named `cid'
chan_capi.c: At top level:
chan_capi.c:2646: error: variable `capi_tech' has initializer but incomplete type
chan_capi.c:2647: error: unknown field `type' specified in initializer
und wenn ich das make-file anpasse (#CFLAGS+=-DCVX_HEAD) dann kommt
gcc -pipe -Wall -Wmissing-prototypes -Wmissing-declarations -g  -I/usr/include -D_REENTRANT -D_GNU_SOURCE -O6 -march=i686  -DCAPI_ES -DCAPI_GAIN -DCAPI_SYNC -DASTERISKVERSION=\"\" -Wno-missing-prototypes -Wno-missing-declarations -DCRYPTO   -c -o chan_capi.o chan_capi.c
chan_capi.c:2647: warning: excess elements in struct initializer
chan_capi.c:2647: warning: (near initialization for `capi_tech')
chan_capi.c:2648: error: unknown field `description' specified in initializer
chan_capi.c:2648: warning: excess elements in struct initializer
chan_capi.c:2648: warning: (near initialization for `capi_tech')
chan_capi.c:2652: error: unknown field `capabilities' specified in initializer
chan_capi.c:2652: warning: excess elements in struct initializer
chan_capi.c:2652: warning: (near initialization for `capi_tech')
chan_capi.c:2654: error: unknown field `requester' specified in initializer
chan_capi.c:2654: warning: excess elements in struct initializer
chan_capi.c:2654: warning: (near initialization for `capi_tech')
chan_capi.c:2655: error: unknown field `send_digit' specified in initializer
chan_capi.c:2655: warning: excess elements in struct initializer
chan_capi.c:2655: warning: (near initialization for `capi_tech')
chan_capi.c:2656: error: unknown field `send_text' specified in initializer
chan_capi.c:2656: warning: excess elements in struct initializer
chan_capi.c:2656: warning: (near initialization for `capi_tech')
chan_capi.c:2657: error: unknown field `call' specified in initializer
chan_capi.c:2657: warning: excess elements in struct initializer
chan_capi.c:2657: warning: (near initialization for `capi_tech')
chan_capi.c:2658: error: unknown field `hangup' specified in initializer
chan_capi.c:2658: warning: excess elements in struct initializer
chan_capi.c:2658: warning: (near initialization for `capi_tech')
chan_capi.c:2659: error: unknown field `answer' specified in initializer
chan_capi.c:2659: warning: excess elements in struct initializer
chan_capi.c:2659: warning: (near initialization for `capi_tech')
chan_capi.c:2660: error: unknown field `read' specified in initializer
chan_capi.c:2660: warning: excess elements in struct initializer
chan_capi.c:2660: warning: (near initialization for `capi_tech')
chan_capi.c:2661: error: unknown field `write' specified in initializer
chan_capi.c:2661: warning: excess elements in struct initializer
chan_capi.c:2661: warning: (near initialization for `capi_tech')
chan_capi.c:2662: error: unknown field `bridge' specified in initializer
chan_capi.c:2662: warning: excess elements in struct initializer
chan_capi.c:2662: warning: (near initialization for `capi_tech')
chan_capi.c:2663: error: unknown field `exception' specified in initializer
chan_capi.c:2663: warning: excess elements in struct initializer
chan_capi.c:2663: warning: (near initialization for `capi_tech')
chan_capi.c:2664: error: unknown field `indicate' specified in initializer
chan_capi.c:2664: warning: excess elements in struct initializer
chan_capi.c:2664: warning: (near initialization for `capi_tech')
chan_capi.c:2665: error: unknown field `fixup' specified in initializer
chan_capi.c:2665: warning: excess elements in struct initializer
chan_capi.c:2665: warning: (near initialization for `capi_tech')
chan_capi.c:2666: error: unknown field `setoption' specified in initializer
chan_capi.c:2666: warning: excess elements in struct initializer
chan_capi.c:2666: warning: (near initialization for `capi_tech')
make: *** [chan_capi.o] Error 1
Any Hints?
Thorsten Gehrig
Es compiliert mit bristuff-RC8a-CVS und damit mit
Asterisk aus dem CVS datum 20.4.2005.
Ah - bisher habe ich die Bristuff-CVS versionen noch nicht wahrgenommen...
Thorsten
@thorsten.gehrig
Mittlerweile gibt es bristuff-RC8b-CVS.
Wie stabiel ist denn bei Dir chan_capi_0.4.0-PRE1?
bei meinem Versuchen wurde asterisk nach kurzer Zeit beendet.
Hi
ich habe derzeit kein "Wartungsfenster" für Exprtimente mit CVS-Bristuffs.... daher auch kein chan_capi (98% meiner Gespräche gehen eh über SIP raus - allerdings verwende ich Intern ISDN...)
Thorsten
DjNorad
IPPF im Überblick
