in my debian squeeze server i do have asterisk 11.4 and i would like to make use of my usb to isdn adapter.
is there a guide to help me please?
the adapter is dlink du128ta+
Check lsusb if the device is HFC based. In that case you have a chance of getting it running with chan_lcr. I remember some trouble with v11, but I think there is a howto for HFC cards in common here in the forum.
as far as i know it is HFC based and i have heard it works with misdn. i am afraid i am stuck where to start with. is there a guide on how to make it work, because i am searching for this howto, but no luck?
Have a close look at the first 6 or 7 threads here in the mISDN area. It's a mix of howto and issues with newer kernel and Asterisk versions. That's how far I can help you, I'm afraid.
