hi, ploetzlich kompiliert dtmfbox nicht mehr.
$ make
mkdir -p packages/target-mipsel_gcc-4.8.3_uClibc-0.9.28/dtmfbox-0.5.0/root
if test -d make/dtmfbox/files; then tools/tar-gnu -cf - -C make/dtmfbox/files --exclude=.svn --exclude=.gitignore --exclude=.build-prereq-checked --exclude=.unpacked --exclude=.configured --exclude=.compiled --exclude=.installed . | tools/tar-gnu -xf - -C packages/target-mipsel_gcc-4.8.3_uClibc-0.9.28/dtmfbox-0.5.0; fi
chmod 755 source/target-mipsel_gcc-4.8.3_uClibc-0.9.28/dtmfbox-0.5.0/plugins/menu.plugin/.libs/libmenu.plugin.so.0.0.1; mkdir -p packages/target-mipsel_gcc-4.8.3_uClibc-0.9.28/dtmfbox-0.5.0/root/usr/lib/; rm -f ; cp -a packages/target-mipsel_gcc-4.8.3_uClibc-0.9.28/dtmfbox-0.5.0/root/usr/lib/; /home/timo/freetz-trunk/toolchain/build/mipsel_gcc-4.8.3_uClibc-0.9.28/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-strip --remove-section={.comment,.note,.pdr} packages/target-mipsel_gcc-4.8.3_uClibc-0.9.28/dtmfbox-0.5.0/root/usr/lib/libmenu.plugin.so.0.0.1;
cp: Fehlender Zieldatei‐Operand hinter »packages/target-mipsel_gcc-4.8.3_uClibc-0.9.28/dtmfbox-0.5.0/root/usr/lib/“
„cp --help“ liefert weitere Informationen.
/home/timo/freetz-trunk/toolchain/build/mipsel_gcc-4.8.3_uClibc-0.9.28/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-strip: 'packages/target-mipsel_gcc-4.8.3_uClibc-0.9.28/dtmfbox-0.5.0/root/usr/lib/libmenu.plugin.so.0.0.1': No such file
make/dtmfbox/dtmfbox.mk:48: recipe for target 'packages/target-mipsel_gcc-4.8.3_uClibc-0.9.28/dtmfbox-0.5.0/root/usr/lib/libmenu.plugin.so.0.0.1' failed
make: *** [packages/target-mipsel_gcc-4.8.3_uClibc-0.9.28/dtmfbox-0.5.0/root/usr/lib/libmenu.plugin.so.0.0.1] Error 1
