[erledigt] Installation mit Fehlern ALSA
vbbaby
8 Sep 2004
Moin....
habe nach dem Start von Asterisk -vvvvgc folgende Fehlermeldungen:
 [chan_alsa.so] => (ALSA Console Channel Driver)
  == Parsing '/etc/asterisk/alsa.conf': Found
Oct 21 19:17:54 ERROR[1077012448]: chan_alsa.c:298 alsa_card_init: snd_pcm_open failed: No such file or directory
Oct 21 19:17:54 ERROR[1077012448]: chan_alsa.c:433 soundcard_init: Problem opening alsa I/O devices
  == No sound card detected -- console channel will be unavailable
  == Turn off ALSA support by adding 'noload=chan_alsa.so' in /etc/asterisk/modules.conf
Meine modules.conf sieht so aus
; Asterisk configuration file
; Module Loader configuration file
[modules]
autoload=yes
; If you want, load the GTK console right away.
; Don't load the KDE console since
; it's not as sophisticated right now.
noload => pbx_gtkconsole.so
;load => pbx_gtkconsole.so
noload => pbx_kdeconsole.so
; Intercom application is obsoleted by
; chan_oss.  Don't load it.
noload => app_intercom.so
; Explicitly load the chan_modem.so early on to be sure
; it loads before any of the chan_modem_* 's afte rit
load => chan_modem.so
load => res_musiconhold.so
; Load either OSS or ALSA, not both
; By default, load OSS only (automatically) and do not load ALSA
;noload => chan_alsa.so
noload => chan_oss.so
; Module names listed in "global" section will have symbols globally
; exported to modules loaded after them.
[global]
chan_modem.so=yes
chan_oss.so=no
meine Alsa.conf:
; Open Sound System Console Driver Configuration File
[general]
; Automatically answer incoming calls on the console?  Choose yes if
; for example you want to use this as an intercom.
autoanswer=yes
; Default context (is overridden with @context syntax)
context=local
; Default extension to call
extension=s
; Default language
;language=en
; Silence supression can be enabled when sound is over a certain threshold.
; The value for the threshold should probably be between 500 and 2000 or so,
; but your mileage may vary.  Use the echo test to evaluate the best setting.
;silencesuppression = yes
;silencethreshold = 1000
; To set which ALSA device to use, change this parameter
input_device=hw:0,0
output_device=default
Meine Soundkarte läuft auch mit ALSA und funktioniert auch..... :)
brauchst Du Alsa für den Asterisk? Ich vermute mal nicht.
Also mach doch einfach was Asterisk Dir schon beim starten sagt ;)
:?: Keine Ahnung ob ich das brauche ????
Ich dachte es wird irgendwofür gebraucht .......
Wofür kann man das denn gebrauchen ???
Alsa ist ein Treiber-Framework fuer die Nutzung der Soundkarte. Wenn Du nicht direkt auf dem Rechner, auf dem Asterisk laeuft, Sound ausgeben oder "aufnehmen" moechtest, kannst Du getrost auf den Alsa-Support verzichten.
Also kann ich, wenn ich ALSA abschallte keine Ansage abspielen, keine Wartemusik etc ????
Doch. Nur nichts, was über die Soundcard an Boxen oder ähnliches ausgegeben werden soll.
Gut das brauche ich wirklich nicht.....
Danke.... :p
Lebeat
