/etc/capi.conf ?
matt_01
12 Okt 2004
Hallo
Kann mir jemand sagen wie ich folgendes File erstellen kann ?
/etc/capi.conf
Hab's mit dem source versucht..
jedoch klapt's noch nicht so ganz ;-)
Nach dem entzippen des files “isdn4k-utils-CVS-2004-10-07” hab ich folgendes gmacht:
1. cd isdn4k-utils-CVS-2004-10-07
2. make config
3. Select from the submenu “Card configuration tools”
4. I only selected “[*] avmcapictrl / capiinit” ( not sure if that’s correct, I have a AVM ISDN Fitz Card )
5. then save end exit.. and seems to be ok till there
checking for sgml2txt... (cached) /usr/bin/sgml2txt
creating ./config.status
creating Makefile
make[1]: Leaving directory `/root/isdn4k-utils-CVS-2004-10-07'
6. nun "make"
gcc -O2 -fomit-frame-pointer -Wall -DHAVE_LZSCOMP_H -c -o environ.o environ.c
gcc -O2 -fomit-frame-pointer -Wall -DHAVE_LZSCOMP_H -c -o readpw.o readpw.c
gcc -O2 -fomit-frame-pointer -Wall -DHAVE_LZSCOMP_H -c -o isexpired.o isexpired.c
gcc -O2 -fomit-frame-pointer -Wall -DHAVE_LZSCOMP_H -o ipppd main.o magic.o fsm.o lcp.o ipcp.o upap.o chap.o md5.o ccp.o auth.o options.o sys-linux.o cbcp.o ipxcp.o environ.o readpw.o isexpired.o -lcrypt -lutil
make[1]: Leaving directory `/root/isdn4k-utils-CVS-2004-10-07/ipppd'
make[1]: Entering directory `/root/isdn4k-utils-CVS-2004-10-07/vbox'
make[2]: Entering directory `/root/isdn4k-utils-CVS-2004-10-07/vbox/src'
/usr/bin/ar cru libvbox.a libvbox.o
/usr/bin/ranlib libvbox.a
make[2]: Leaving directory `/root/isdn4k-utils-CVS-2004-10-07/vbox/src'
make[2]: Entering directory `/root/isdn4k-utils-CVS-2004-10-07/vbox/utils'
make[2]: Nothing to be done for `all'.
make[2]: Leaving directory `/root/isdn4k-utils-CVS-2004-10-07/vbox/utils'
make[2]: Entering directory `/root/isdn4k-utils-CVS-2004-10-07/vbox/doc'
Making all in de
make[3]: Entering directory `/root/isdn4k-utils-CVS-2004-10-07/vbox/doc/de'
make[3]: Nothing to be done for `all'.
make[3]: Leaving directory `/root/isdn4k-utils-CVS-2004-10-07/vbox/doc/de'
make[3]: Entering directory `/root/isdn4k-utils-CVS-2004-10-07/vbox/doc'
make[3]: Nothing to be done for `all-am'.
make[3]: Leaving directory `/root/isdn4k-utils-CVS-2004-10-07/vbox/doc'
make[2]: Leaving directory `/root/isdn4k-utils-CVS-2004-10-07/vbox/doc'
make[1]: Leaving directory `/root/isdn4k-utils-CVS-2004-10-07/vbox'
make[1]: Entering directory `/root/isdn4k-utils-CVS-2004-10-07/rcapid'
make[1]: *** No rule to make target `acinclude.m4', needed by `aclocal.m4'. Stop.
make[1]: Leaving directory `/root/isdn4k-utils-CVS-2004-10-07/rcapid'
make: *** [subtargets] Error 2
Weiss jemand wo das Problem liegt ?
die Datei wird automatisch erzeugt wenn der Capitreiber (hardware) eingebunden/Compiliert wird.
OBELIX
Kommt die /ect/capi.conf nicht von "isdnaktivecards"? Bei debian gibt es das als fertiges Paket. DAnn landet die capi.conf aber in /etc/isdn/capi.conf.
ja
-----schnip-----
# card file proto io irq mem cardnr options
#b1isa b1.t4 DSS1 0x150 7 - - P2P
#b1pci b1.t4 DSS1 - - - -
#c4 c4.bin DSS1 - - - -
#c4 - DSS1 - - - -
#c4 - DSS1 - - - - P2P
#c2 c2.bin DSS1 - - - -
#c2 - DSS1 - - - -
#t1isa t1.t4 DSS1 0x340 9 - 0
#t1pci t1.t4 DSS1 - - - -
#fcpci - - - - - -
fcclassic - - 0x300 5 - -
-----schnap------
versuch es mal hiermit stammt von meiner CD
OBELIX
Naja, selbst wenn Du kein Debian-System nutzt gibt es das Paket "isdnaktivecards" bestimmt auch als rpm-Paket. Du solltest es vielleicht einfach mal installieren.
Im notfall kann man das ja auch selber kompilieren, wenn es kein passendes Paket gibt.
Bei mir wurde nach insatllation des Paketes auf jeden Fall eine capi.conf erstellt (du meinst die mit "fcpci - - - - - ", oder).
obelix schrieb:
ja
-----schnip-----
#c4 - DSS1 - - - -
#c2 - DSS1 - - - -
#fcpci - - - - - -
-----schnap------
OBELIX
Also.. 1facht ein file erstellen mit dem Namen capi.conf und dein Code da rein 'pästen ;-) ?
eastman
IPPF im Überblick
