FB 7412 Hardware & Firmware
ELpf
13 Mai 2017
Dieser Thread dient vorwiegend als Informationssammelplatz für die 7412. Wenn jemand diese Infos nützlich findet, ist das schön.
Hardware
Serieller Port:
- 3.3V (LVCMOS33?)
- 115200 8N1
Firmware
- - - Aktualisiert - - -
Bootprotokoll F.OS 6.30:
Erfolgreicher Start:
ROM VER: 1.1.4
CFG 06
NAND
NAND Read OK
(AVM) EVA Revision: 1.2605 Version: 3605
(C) Copyright 2005 AVM Date: Jul 24 2015 Time: 11:09:46 (0) 3 0x0-0x47409
[NAND:] 128MB TOSHIBA 2048 Pagesize 128k Blocksize 1024 Blocks
[SYSTEM:] VR9 on 500MHz/250MHz/250MHz
Eva_AVM >##...............................................ExecuteProgram
Lantiq xDSL CPE VR9
[    0.000000] Linux version 2.6.32.61 (jpluschke@EmbeddedVM) (gcc version 4.8.1 (Buildroot 2013.05) ) #1 SMP Mon Oct 12 17:49:11 CEST 2015
[    0.000000] phym = 08000000, mem = 08000000, max_pfn = 00008000
[    0.000000] Reserving memory for CP1 @0xa8000000, size 0x00000000
[    0.000000] [init_avm_kernel_config] AVM Kernel Config (ptr 806d6000)
[    0.000000] [init_avm_kernel_config] AVM Kernel Config: module memory entry
[    0.000000] bootconsole [early0] enabled
[    0.000000] CPU revision is: 00019556 (MIPS 34Kc)
[    0.000000] Determined physical RAM map:
[    0.000000] Initrd not found or empty - disabling initrd
[    0.000000] Zone PFN ranges:
[    0.000000]   Normal   0x00000000 -> 0x00008000
[    0.000000] Movable zone start PFN for each node
[    0.000000] early_node_map[1] active PFN ranges
[    0.000000]     0: 0x00000000 -> 0x00008000
[    0.000000] [module-alloc-by-name] 'modulemem' not in use, use AVM Kernel Config (7684096 bytes, reserved for module mem)
[    0.000000] [module-alloc] use 0x754000 bytes at 0x81101000
[    0.000000] 1 available secondary CPU TC(s)
[    0.000000] PERCPU: Embedded 7 pages/cpu @81859000 s5760 r8192 d14720 u65536
[    0.000000] pcpu-alloc: s5760 r8192 d14720 u65536 alloc=16*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 32512
[    0.000000] Kernel command line: console=ttyS0,115200n8r nor_size=0MB sflash_size=0KB nand_size=128MB ethaddr=5C:49:79:XX:XX:XX ffsver=3
[    0.000000] [NAND] nand_size = 0x8000000
[    0.000000] [tffs_setup_version] tffs version 3 requested
[    0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
[    0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[    0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[    0.000000] wait instruction: r4k_wait_irqoff
[    0.000000] [avm_cache_set_coherency]: setting cache coherency for HWRevision=209 to write back allocate
[    0.000000] Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes.
[    0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
[    0.000000] Writing ErrCtl register=00051240
[    0.000000] Readback ErrCtl register=00051240
[    0.000000] Memory: 114444k/131072k available (4796k kernel code, 16464k reserved, 2199k data, 212k init, 0k highmem)
[    0.000000] Hierarchical RCU implementation.
[    0.000000] NR_IRQS:181
[    0.000000] [mips_cpu_irq_init] irq_base 0
[    0.000000] SRSConf0 0x3feffbfe: SRS1: 0xffffffff, SRS2 0xffffffff, SRS3 0xffffffff
[    0.000000] Console: colour dummy device 80x25
[    0.000000] console [ttyS0] enabled, bootconsole disabled
[    0.020000] Calibrating delay loop... 332.59 BogoMIPS (lpj=1662976)
[    0.240000] Security Framework initialized
[    0.240000] Mount-cache hash table entries: 512
[    0.250000] kernel_init: started
[    0.250000] kernel_init: kernel locked
[    0.250000] Limit of 2 TCs set
[    0.250000] TLB of 32 entry pairs shared by 2 VPEs
[    0.250000] VPE 0: TC 0, VPE 1: TC 1
[    0.250000] IPI buffer pool of 8 buffers
[    0.260000] CPU revision is: 00019556 (MIPS 34Kc)
[    0.490000] TC 1 going on-line as CPU 1
[    0.500000] Brought up 2 CPUs
[    0.510000] [yield_context_init] cpu=1 tc=2 mask=300
[    0.510000] [yield_context_init] cpu=0 tc=3 mask=410
[power_managment_setup] reset 'DSL, DFE, AFE, VOICE, DSLTC, ARC'
[power_managment_setup] reset 'LDO'
[power_managment_setup] power down 'PPE TC, PPE EMA, LEDC, DFEV1, DFEV0'
[power_managment_setup] power down 'MSI1, PDI1 PCIE1 PCIE1_PHY'
[power_managment_setup] power down 'USB CTRL'
[power_managment_setup] power down 'GPHY'
[power_managment_setup] disable power domain 'DSL + DFE'
[    0.560000] NET: Registered protocol family 16
[    0.560000] Lantiq GPIO driver, version 1.3.2, (c) 2001-2013 Lantiq Deutschland GmbH
[    0.570000] Reboot Status is: Power-On
[    0.570000] [TFFS3_Early_Init] called
[    0.570000] [avmnet] [avmnet_cfg_init] Driver version: 6.136  -  Revision 1496:2706  -  Mo 12. Okt 17:48:42 CEST 2015
[    0.890000] Lantiq PCIe Root Complex driver, version 2.0.0, (c) 2001-2013 Lantiq Deutschland GmbH
[    0.900000] bio: create slab <bio-0> at 0
[    0.900000] ifx_pcie_rc_class_early_fixup port 0: fixed pcie host bridge to pci-pci bridge
[    0.910000] pci 0000:00:00.0: PME# supported from D0 D3hot
[    0.910000] pci 0000:00:00.0: PME# disabled
[    0.920000] pci 0000:01:00.0: PME# supported from D0 D1 D3hot
[    0.920000] pci 0000:01:00.0: PME# disabled
[    0.930000] pci 0000:00:00.0: PCI bridge, secondary bus 0000:01
[    0.930000] pci 0000:00:00.0:   IO window: disabled
[    0.940000] pci 0000:00:00.0:   MEM window: 0x1c000000-0x1c0fffff
[    0.940000] pci 0000:00:00.0:   PREFETCH window: disabled
[    0.950000] NET: Registered protocol family 8
[    0.950000] NET: Registered protocol family 20
[    0.960000] NET: Registered protocol family 2
[    0.960000] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.960000] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[    0.960000] TCP bind hash table entries: 4096 (order: 4, 81920 bytes)
[    0.970000] TCP: Hash tables configured (established 4096 bind 4096)
[    0.990000] TCP reno registered
[    0.990000] NET: Registered protocol family 1
[    1.000000] IFX DMA driver, version ifxmips_dma_core.c:v1.0.17 ,(c)2009 Infineon Technologies AG
[    1.000000]  skb_shared_size:344
[    1.010000] Lantiq CGU driver, version 1.1.32, (c) 2001-2013 Lantiq Deutschland GmbH
[    1.020000] squashfs: version 3.4 (2008/08/26) Phillip Lougher
[    1.020000] fuse init (API version 7.13)
[    1.030000] msgmni has been set to 223
[    1.030000] io scheduler noop registered (default)
[    1.040000] [avm_membench_init]
[    1.300000] avm_net_trace: Up and running.
[    1.300000] [loadcontrol] set auto - scale=1
[    1.300000] [avm] configured: watchdog event debug
[    1.310000] AVM_WATCHDOG: Watchdog Driver for AR7 Hardware (Version 1.0, build: Oct 12 2015 17:48:03)
[    1.320000] ifx_pmu_init: Major 247
[    1.320000] Lantiq PMU driver, version 1.2.6, (c) 2001-2013 Lantiq Deutschland GmbH
[    1.330000] Infineon Technologies RCU driver version 1.0.7
[    1.340000] Lantiq Thermal Sensor driver, version 1.0.3, (c) 2001-2013 Lantiq Deutschland GmbH
[    1.340000] ttyS0 at MMIO 0x1e100c00 (irq = 107) is a PORT_IFX_ASC
[    1.360000] loop: module loaded
[    1.360000] nbd: registered device at major 43
[    1.380000] Generic platform RAM MTD, (c) 2004 Simtec Electronics
[    1.380000] Platform NOR MTD, (c) AVM 2010
[    1.390000] ifx_hsnand_init: ifx_hsnand_chip_init(0)
[    1.390000] [HSNAND] Toshiba-BENAND
[    1.390000] NAND device: Manufacturer ID: 0x98, Chip ID: 0xf1 (Toshiba NAND 128MiB 3,3V 8-bit)
[    1.400000] Scanning device for bad blocks
[    1.470000] {ifx_hsnand_toshiba_read_eccstatus} status 0xe1
[    1.480000] [ifx_hsnand_command] read block failed (column: 0x800 page: 0xc000)
[    1.480000] Bad eraseblock 768 at 0x000006000000 (byte on oob[0-1]=0x0)
[    1.510000] badblock statistics:
[    1.510000] --------------------
[    1.510000]   start block = 0
[    1.510000]   num blocks  = 1024
[    1.510000]   bad blocks  = 1
[    1.530000]
[    1.530000]   >> The following table summarize all badblocks to visualize the distribution
[    1.530000]   block [ start | count | size/kB ] (start block, number of blocks)
[    1.530000]   ---------------------------------
[    1.550000]   block [   768 |     1 |     128 ]
[    1.550000]         [ ======================= ]
[    1.550000]         [      >>     1 |     128 ]
[    1.560000] Creating 8 MTD partitions on "ifx_hsnand":
[    1.570000] 0x000000440000-0x000000840000 : "kernel"
[    1.570000] {ifx_mtd_add_notifier} name kernel
[    1.580000] 0x000000840000-0x000003840000 : "filesystem"
[    1.580000] {ifx_mtd_add_notifier} name filesystem
[    1.590000] 0x000003840000-0x000003c40000 : "reserved-kernel"
[    1.590000] {ifx_mtd_add_notifier} name reserved-kernel
[    1.600000] 0x000003c40000-0x000006c40000 : "reserved-filesystem"
[    1.610000] {ifx_mtd_add_notifier} name reserved-filesystem
[    1.610000] 0x000006c40000-0x000006e40000 : "config"
[    1.620000] {ifx_mtd_add_notifier} name config
[    1.620000] 0x000006e40000-0x000008000000 : "nand-filesystem"
[    1.630000] {ifx_mtd_add_notifier} name nand-filesystem
[    1.630000] 0x000000000000-0x000000040000 : "urlader"
[    1.640000] {ifx_mtd_add_notifier} name urlader
[    1.640000] 0x000000040000-0x000000440000 : "nand-tffs"
[    1.650000] {ifx_mtd_add_notifier} name nand-tffs
[    1.650000] [TFFS3_Register_NAND] Called
[    1.650000] Lantiq SSC driver, version 2.4.1, (c) 2001-2013 Lantiq Deutschland GmbH
[    1.660000] Unknown SPI device: 0xFF 0xFF 0xFF
[    1.670000] ifx_spi_flash_init: Found no serial flash device
[    1.670000] tun: Universal TUN/TAP device driver, 1.6
[    1.680000] tun: (C) 1999-2004 Max Krasnyansky <[email protected]>
[    1.680000] IFX SWITCH API, Version 1.1.8.5
[    1.690000] SWAPI: Registered character device [switch_api] with major no [81]
[    1.690000] Switch API: PCE MicroCode loaded !!
[    1.700000] res = 87925500
[    1.700000] i2c /dev entries driver
[    1.710000] CAPI Subsystem Rev 1.1.2.8
[    1.710000] AVM PA 4.3.10 2014-09-21
[    1.710000] AVM PA skb pktinfo at offset 128 size 196
[    1.720000] [loadcontrol]module avm_pa registered
[    1.720000] IPv4 over IPv4 tunneling driver
[    1.730000] TCP cubic registered
[    1.730000] mcfw: IGMPv3 fast forwarding
[    1.730000] NET: Registered protocol family 10
[    1.740000] IPv6 over IPv4 tunneling driver
[    1.740000] NET: Registered protocol family 17
[    1.750000] NET: Registered protocol family 8
[    1.750000] atmpvc_init() failed with -17
[    1.750000] KOAM is loaded successfully.
[    1.760000] l2tp_core: L2TP core driver, V2.0
[    1.760000] l2tp_ip: L2TP IP encapsulation support (L2TPv3)
[    1.770000] l2tp_netlink: L2TP netlink interface
[    1.770000] l2tp_eth: L2TP ethernet pseudowire support (L2TPv3)
[    1.780000] l2tp_ip6: L2TP IP encapsulation support for IPv6 (L2TPv3)
[    1.790000] 802.1Q VLAN Support v1.8 Ben Greear <[email protected]>
[    1.790000] All bugs added by David S. Miller <[email protected]>
[    1.800000] [tffs_init] different tffs version requested, version 2 not starting
[    1.810000] [prepare_log_proc] TFFS version 2 not running
[    1.810000] [TFFS3-NAND] NAND storage backend for TFFS 3.x
[    1.820000] [TFFS3-NAND] scanning block at address 0x0
[    1.820000] [TFFS3-NAND] found TFFS header magic at address 0x0, version 0x30000
[    1.850000] [TFFS3-NAND] scanning block at address 0x20000
[    1.860000] [TFFS3-NAND] found TFFS header magic at address 0x20000, version 0x30000
[    1.900000] [TFFS3-NAND] scanning block at address 0x40000
[    1.900000] [TFFS3-NAND] found TFFS header magic at address 0x40000, version 0x30000
[    1.950000] [TFFS3-NAND] scanning block at address 0x60000
[    1.950000] [TFFS3-NAND] found TFFS header magic at address 0x60000, version 0x30000
[    1.980000] [TFFS3-NAND] scanning block at address 0x80000
[    1.980000] [TFFS3-NAND] found TFFS header magic at address 0x80000, version 0x30000
[    2.030000] [TFFS3-NAND] scanning block at address 0xa0000
[    2.030000] [TFFS3-NAND] found TFFS header magic at address 0xa0000, version 0x30000
[    2.050000] [TFFS3-NAND] scanning block at address 0xc0000
[    2.050000] [TFFS3-NAND] found TFFS header magic at address 0xc0000, version 0x30000
[    2.070000] [TFFS3-NAND] scanning block at address 0xe0000
[    2.080000] [TFFS3-NAND] found TFFS header magic at address 0xe0000, version 0x30000
[    2.100000] [TFFS3-NAND] scanning block at address 0x100000
[    2.100000] [TFFS3-NAND] found TFFS header magic at address 0x100000, version 0x30000
[    2.120000] [TFFS3-NAND] scanning block at address 0x120000
[    2.130000] [TFFS3-NAND] found TFFS header magic at address 0x120000, version 0x30000
[    2.150000] [TFFS3-NAND] scanning block at address 0x140000
[    2.150000] [TFFS3-NAND] found TFFS header magic at address 0x140000, version 0x30000
[    2.170000] [TFFS3-NAND] scanning block at address 0x160000
[    2.180000] [TFFS3-NAND] found TFFS header magic at address 0x160000, version 0x30000
[    2.190000] [TFFS3-NAND] scanning block at address 0x180000
[    2.200000] [TFFS3-NAND] found TFFS header magic at address 0x180000, version 0x30000
[    2.220000] [TFFS3-NAND] scanning block at address 0x1a0000
[    2.220000] [TFFS3-NAND] found TFFS header magic at address 0x1a0000, version 0x30000
[    2.240000] [TFFS3-NAND] scanning block at address 0x1c0000
[    2.240000] [TFFS3-NAND] found TFFS header magic at address 0x1c0000, version 0x30000
[    2.260000] [TFFS3-NAND] scanning block at address 0x1e0000
[    2.270000] [TFFS3-NAND] found TFFS header magic at address 0x1e0000, version 0x30000
[    2.290000] [TFFS3-NAND] scanning block at address 0x200000
[    2.290000] [TFFS3-NAND] found TFFS header magic at address 0x200000, version 0x30000
[    2.310000] [TFFS3-NAND] scanning block at address 0x220000
[    2.310000] [TFFS3-NAND] found TFFS header magic at address 0x220000, version 0x30000
[    2.330000] [TFFS3-NAND] scanning block at address 0x240000
[    2.340000] [TFFS3-NAND] found TFFS header magic at address 0x240000, version 0x30000
[    2.350000] [TFFS3-NAND] scanning block at address 0x260000
[    2.360000] [TFFS3-NAND] found TFFS header magic at address 0x260000, version 0x30000
[    2.380000] [TFFS3-NAND] scanning block at address 0x280000
[    2.380000] [TFFS3-NAND] found TFFS header magic at address 0x280000, version 0x30000
[    2.400000] [TFFS3-NAND] scanning block at address 0x2a0000
[    2.410000] [TFFS3-NAND] found TFFS header magic at address 0x2a0000, version 0x30000
[    2.420000] [TFFS3-NAND] scanning block at address 0x2c0000
[    2.430000] [TFFS3-NAND] found TFFS header magic at address 0x2c0000, version 0x30000
[    2.450000] [TFFS3-NAND] scanning block at address 0x2e0000
[    2.450000] [TFFS3-NAND] found TFFS header magic at address 0x2e0000, version 0x30000
[    2.470000] [TFFS3-NAND] scanning block at address 0x300000
[    2.470000] [TFFS3-NAND] found TFFS header magic at address 0x300000, version 0x30000
[    2.490000] [TFFS3-NAND] scanning block at address 0x320000
[    2.500000] [TFFS3-NAND] found TFFS header magic at address 0x320000, version 0x30000
[    2.520000] [TFFS3-NAND] scanning block at address 0x340000
[    2.520000] [TFFS3-NAND] found TFFS header magic at address 0x340000, version 0x30000
[    2.540000] [TFFS3-NAND] scanning block at address 0x360000
[    2.540000] [TFFS3-NAND] found TFFS header magic at address 0x360000, version 0x30000
[    2.560000] [TFFS3-NAND] scanning block at address 0x380000
[    2.570000] [TFFS3-NAND] found TFFS header magic at address 0x380000, version 0x30000
[    2.580000] [TFFS3-NAND] scanning block at address 0x3a0000
[    2.590000] [TFFS3-NAND] found TFFS header magic at address 0x3a0000, version 0x30000
[    2.610000] [TFFS3-NAND] scanning block at address 0x3c0000
[    2.610000] [TFFS3-NAND] found TFFS header magic at address 0x3c0000, version 0x30000
[    2.630000] [TFFS3-NAND] scanning block at address 0x3e0000
[    2.630000] [TFFS3-NAND] found TFFS header magic at address 0x3e0000, version 0x30000
[    2.650000] [TFFS3-NAND] Initialisation successful, 32/32 NAND blocks active, fill rate 13%
[    2.660000] TFFS: tiny flash file system driver. GPL (c) AVM Berlin (Version 3.0)
[    2.670000] Adam2 environment variables API installed.
[    2.670000] [simple-profiling]: 2 performance counters implemented, NEW_34K
[    2.680000] Enable Performance Counter 0 for Data cache load/stores (User-Mode enabled Supervisor-Mode enabled Kernel-Mode enabled Exeption-Mode disable)
[    2.690000] Setup tcs=0x1 current_tc_mask=0x1, reg=0
[    2.700000] [simple-profiling]: 2 performance counters implemented, NEW_34K
[    2.710000] Enable Performance Counter 1 for Data cache load/store misses (User-Mode enabled Supervisor-Mode enabled Kernel-Mode enabled Exeption-Mode disable)
[    2.720000] Setup tcs=0x1 current_tc_mask=0x1, reg=1
[    2.730000] AVM Simple Profiling enabled Version 3.0
[    2.730000] {avmnet_cfg_netinit}
[    2.730000] [avmnet] No config found for HWRev 209, HWSubRev 1, Profile-ID 0, trying base config for HWSubRev
[    2.740000] [avmnet] No config found for HWRev 209, HWSubRev 1, trying base config for HWRev
[    2.750000] [avmnet] [avmnet_swi_7port_init] Init on module swi_vr9 called.
[    2.760000] [avmnet] [fix_phy_clock_config]: Could not read external PHY clock pin data from avm_hw_config!
[    2.970000] Loading AVM Net Common Datapath Driver for 7Port Switch......
[    2.970000] [ppe_eth_init] init_hw()
[    2.980000] [init_hw] ppe_hw_init=0xff successful
[    2.980000] [ppe_eth_init] ifx_proc_file_create()
[    2.990000] [ppe_eth_init] dma_setup_init()
���m��������������䇥�ith Version 2 Le
[   10.120000]
[   10.120000]
[   10.120000]
[   10.120000]
[   10.120000]
[   10.120000]
[   10.120000]
[   10.120000] [piglet]===== end of shared usage of UART (DECT and CONSOLE) ====
[   10.120000] n: 17
[    7.130000][0] [piglet]patch_dectfw: RFPI tag found 02965ff4f0
[    7.130000][0] [piglet]patch_dectfw: dectmode 19
[    7.150000][0] [piglet]dect_loader144xx: slow-bootmode
[   10.110000][0] [piglet]dect144xx_file_process: upload of '/lib/modules/dectfw_secondlevel_441.hex' successfull
[   12.150000][0] [piglet]TDM: FS: 8005 Hz CLK: 3711930 Hz  (SPITDM)
modprobe: module nand not found in modules.dep
[yaffs] driver is loaded
[yaffs] nand-mtd: mtd5: 011c0000 00020000 "nand-filesystem"
/etc/init.d/rc.S: /etc/init.d/S15-filesys: line 101: usbcfgctl: not found
[   12.370000][1] yaffs: dev is 32505861 name is "mtdblock5" rw
[   12.370000][1] yaffs: passed flags ""
[yaffs] Internal Memory assigned @ /var/media/ftp
[   12.460000][1] [module-alloc-by-name] give 0x66000 bytes at 0x81128000 to module 'pcmlink' (0x6c7000 bytes left)
[   12.460000][1] [module-alloc-by-name] 0x66000 bytes used, 0x65db8 bytes expected
[pcmlink]svn: 2091
[   12.830000][0] [module-alloc-by-name] give 0xdb000 bytes at 0x8118e000 to module 'isdn_fbox_fon5' (0x5ec000 bytes left)
[   12.830000][0] [module-alloc-by-name] 0xdb000 bytes used, 0xdd72c bytes expected
[isdn]svn:3113
avm_stack_attach: cpu0 -> cpu1
[   13.360000][0] driver params overwritten io_addr=0x0 irq_num=0
lavm_stack_attach_oncpu: cpu1
[   13.370000][1] [pcmlink]chrony-support
lspitdm_programm_mode: 1 STAT=1000002 done
[   13.370000][0] lspitdm_reset: WHBSTATE e54
lspitdm_reset: SPI_CON 5f0050
lspitdm_programm_mode: 0 STAT=1000005 done
PCMLINK: Version 4.209 Codecslots=6 Slics=1 Pots=0 TE=0 NT=0 DECT=4 no HwCross DSP-EC: 0
[   13.680000][1] [module-alloc-by-name] give 0x69000 bytes at 0x81269000 to module 'capi_codec' (0x583000 bytes left)
[   13.680000][1] [module-alloc-by-name] 0x69000 bytes used, 0x6a4d8 bytes expected
capicodec_init()
[capi_codec] support fax
[capi_codec] support Codecs
[   13.860000][0] [module-alloc-by-name] give 0x44000 bytes at 0x812d2000 to module 'avm_dect' (0x53f000 bytes left)
[   13.860000][0] [module-alloc-by-name] 0x44000 bytes used, 0x46008 bytes expected
[DECTDRV_ERR] avm_dect driver init
[DECTDRV_ERR] [avm_dect]avm_dect_thread: start
[   13.920000][0] [module-alloc-by-name] give 0x4000 bytes at 0x81316000 to module 'dect_io' (0x53b000 bytes left)
[   13.920000][0] [module-alloc-by-name] 0x4000 bytes used, 0x483c bytes expected
TAM: create directory /data/tam
exceute files in group 1 ...
/etc/init.d/E15-device
mknod led c 242
mknod tffs c 243
mknod avm_power c 253
mknod debug c 249
mknod avm_event c 251
mknod capi_oslib c 68
mknod dect_io c 227
group 1 done ...
source files in group 2 ...
/etc/init.d/S21-udev
exceute files in group 2 ...
group 2 done ...
source files in group 3 ...
/etc/init.d/S30-ledcfg
exceute files in group 3 ...
group 3 done ...
source files in group 4 ...
/etc/init.d/S42-ptest     /etc/init.d/S46-usb
/etc/init.d/S44-hostname  /etc/init.d/S48-configd
Jan  1 01:00:14 udevd[399]: specified group 'tty' unknown
Jan  1 01:00:14 udevd[399]: specified group 'dialout' unknown
Jan  1 01:00:14 udevd[399]: specified group 'kmem' unknown
Jan  1 01:00:14 udevd[399]: specified group 'video' unknown
Jan  1 01:00:14 udevd[399]: specified group 'audio' unknown
Jan  1 01:00:14 udevd[399]: specified group 'lp' unknown
Jan  1 01:00:14 udevd[399]: specified group 'disk' unknown
Jan  1 01:00:14 udevd[399]: specified group 'floppy' unknown
Jan  1 01:00:14 udevd[399]: specified group 'cdrom' unknown
Jan  1 01:00:14 udevd[399]: specified group 'tape' unknown
exceute files in group 4 ...
/etc/init.d/E40-dsl   /etc/init.d/E46-net   /etc/init.d/E47-voip
[dsl sus] dsl line test calib factory file available
[dsl get xtse] ANNEX=B DSLMODE=0
[dsl get xtse] setting ADSL Annex B/J and VDSL2 oISDN
[dsl get xtse] 10 00 10 40 00 04 01 07
[dsl sus] diagforce enabled
[dsl sus] starting vr9 dsp...
[dsl sus] ANNEX=B DSLMODE=0 DIAGNOSE=no
[   15.640000][0] [module-alloc-by-name] give 0x2d000 bytes at 0x8131a000 to module 'mei_vr9' (0x50e000 bytes left)
[   15.640000][0] [module-alloc-by-name] 0x2d000 bytes used, 0x2e094 bytes expected
[   15.700000][0] [dsl_mei] Lantiq (VRX) DSL CPE MEI driver, version 1.4.4, (c) 2013 Lantiq Deutschland GmbH
[   15.700000][0] [dsl mei] tried to set GDBG Level to 4
[   15.700000][0] [dsl mei] debug_level=4, Global UsrDbgLevel=4 MEI_DRV UsrDbgLevel=4 MEI_MEI_ACCESS UsrDbgLevel=4
[   15.700000][0] [dsl mei] debug_level=4, Global IntDbgLevel=4 MEI_DRV IntDbgLevel=4 MEI_MEI_ACCESS IntDbgLevel=4
[   15.700000][0] [dsl_vr9] AVM_MEI_PowerUpDSLSubsystem enable power domain 'DSL + DFE'
[   15.700000][0] [AVM_MEI_PowerUpDSLSubsystem] power up 'PPE TC, PPE EMA, LEDC, DFEV1, DFEV0'
[   15.720000][0] [dsl_vr9] AVM_MEI_PowerUpDSLSubsystem unreset 'DSL, DFE, AFE, VOICE, DSLTC, ARC'
spi_clc=0x00000200
[dsl sus] loaded vr9 mei driver: mei_vr9.ko with params: , avmDslDiagEnabled=1
[   15.800000][1] [module-alloc-by-name] give 0x4b000 bytes at 0x81347000 to module 'dsl_vr9' (0x4c3000 bytes left)
[   15.800000][1] [module-alloc-by-name] 0x4b000 bytes used, 0x4baf0 bytes expected
[dsl drv] Lantiq CPE API Driver version: DSL CPE API V4.16.6-pd1
[dsl drv] Predefined debug level: 4
[dsl drv] dynamically registered major number 238 for dsl_vr9
[dsl sus] loaded vr9 dsl driver: .ko with params:
[dsl sus] created vr9 dsl device node /dev/dsl_vr9/0 (major: 238 , minor: 0)
[dsl sus] created vr9 mei device node /dev/mei_vr9 (major: 239 , minor: 0)
[dsl sus] invoke /sbin/notify_avmnet --broadband_type DSL hw_start_tm_ptm
[   16.020000][1] [module-alloc-by-name] give 0x27000 bytes at 0x81392000 to module 'ifxmips_ppa_datapath_vr9_e5' (0x49c000 bytes left)
Loading E5 (MII0/1) driver ......
[   16.070000][1] drivers/net/avm_cpmac/switch/ifx/vr9/ifxmips_ppa_datapath_vr9_e5.c:3243:init_local_variables: [init_local_variables] g_eth_wan_mode=0
[   16.070000][1] drivers/net/avm_cpmac/switch/ifx/vr9/ifxmips_ppa_datapath_vr9_e5.c:3302:init_local_variables: g_wan_itf=0x80, g_wanqos_en=8
[   16.090000][1] CPU_TO_WAN_TX_DESC_BASE[0] =0xbe227400
[   16.100000][1] [avmnet] [avmnet_swi_7port_disable_learning] Configuring CPU-port to receive all unknown unicast frames 0x7b
[   16.100000][1] [avmnet] [avmnet_swi_7port_disable_learning] Configuring CPU-port to receive all unknown multicast frames 0x7b
[ppe_e5_init] Succeeded!
PPE datapath driver info:
  Version ID: 64.3.3.1.0.1.1
  Family    : VR9
  DR Type   : Normal Data Path | Indirect-Fast Path
  Interface : MII0 | MII1
  Mode      : Routing
  Release   : 0.1.1
PPE firmware info:
  Version ID: 7.5.2.11.1
  Family    : VR9
  FW Package: D5
  Release   : 2.11.1
PPE firmware feature:
  ATM/PTM TC-Layer Bonding        Support
  L2 Trunking                     Support
  Packet Acceleration             Support
  IPv4                            Support
  IPv6                            Support
  6RD                             Support
  DS-Lite                         Support
FIO_MEI_FW_MODE_STAT_GET failed!: Operation not permitted
[dsl sus] started dsl_control (configuration: -i10_00_10_40_00_04_01_07 -f/lib/modules/dsp_vr9/vr9-B-dsl.bin -n/etc/dsl/notify/dsl_notify.sh  )
[dsl sus] started dsl_monitor
[dsl sus] ....vr9 dsp started
activating IRQ mode
requesting IRQ
request_irq
usedIrq: 57 | usedIsrHandler: 81329820 | usedFlags: 0x4000 | pUsedDevName: mei_vr9 | pUsedDevId: -2036177920
IRQ requested ok
MEI_DRV: MEI_IfxRequestIrq(IRQ = 57, .., ), lock = 1
check this C
about to check device status
MEI_DRV[00]: INIT DEVICE, phy addr = 0x1E116000, virt addr = 0xBE116000 IRQ = 57
[   17.030000][0] [module-alloc-by-name] give 0x184000 bytes at 0x813b9000 to module 'kdsldmod' (0x318000 bytes left)
[   17.030000][0] [module-alloc-by-name] 0x184000 bytes used, 0x184a08 bytes expected
[   17.940000][0] [0]system-load 3  loadavg 0.58 0.13 0.4 - 57 tasks:38 % curr:modprobe(6 %) max:init(23 %, pid:1), readytorun: 2, pgfault 1389/s (max 1 avg 0.6)
DSP: XDU=1( D1 ) OVR=0 MIPS_OVR=0
[   20.250000][0] kdsldmod: init start (Jul 10 2015 13:44:20) sizeof(struct sk_buff)=440
[   20.260000][0] userman: device registerd (userman_url) with major=232
kdsld: ttychannel: ldisc 8 registered
[   20.260000][0] PCP_NL: PCP netlink interface
[   20.260000][0] kdsldmod: init done
Jan  1 01:00:21 l2tpv3d[623]: starting.
Jan  1 01:00:21 l2tpv3d[623]: verbose: DISABLED
[avm_power] eth: port 0 force normal  CON t0
[avm_power] eth: port 1 force throttle  CON t0
[   22.860000][0] [avmnet] [avmnet_power_config] tried to set mode for port 1
[   22.860000][0] [avm_power] : ethernet switch failed
[avm_power] eth: port 2 force throttle  CON t0
[   22.860000][0] [avmnet] [avmnet_power_config] tried to set mode for port 2
[avm_power] eth: port 3 force throttle  CON t0
[   22.860000][0] [avmnet] [avmnet_power_config] tried to set mode for port 3
Jan  1 01:00:22 ctlmgr[631]: WLANLIB: wlan_plugin_init:605: svn revision 2010
Jan  1 01:00:22 ctlmgr[631]: WLANLIB: weak_wlan_check:81: Missing weak 'process_wlanmail'.
Jan  1 01:00:22 ctlmgr[631]: WLANLIB: weak_wlan_check:84: Missing weak 'wlan_enabled_changed'.
Jan  1 01:00:22 ctlmgr[631]: WLANLIB: weak_wlan_check:87: Missing weak 'wlan_wcfgutil_set_output'.
Jan  1 01:00:22 ctlmgr[631]: WLANLIB: weak_wlan_check:88: Missing weak 'wlan_wcfgutil_set_dbg_level'.
rc.wlan: Start WLAN...
WLAND:[00662]:01:00.24/[24.7]:Build = Oct 21 2014 10:59:57
[   24.410000][0] ADDRCONF(NETDEV_UP): lan: link is not ready
[   24.510000][0] [avmnet] [avmnet_mcfw_enable] Device eth0 was enabled already
[   24.510000][0] ADDRCONF(NETDEV_UP): eth0: link is not ready
[   24.510000][0] device eth0 entered promiscuous mode
[   24.940000][1] [module-alloc-by-name] give 0x2e000 bytes at 0x8153d000 to module 'aae' (0x2ea000 bytes left)
[   24.940000][1] [module-alloc-by-name] 0x2e000 bytes used, 0x2c688 bytes expected
Jan  1 01:00:25 dsld[666]: startup ($Revision: 1.160 $$CompileDate: Jul 10 2015 13:43:54 $)
Jan  1 01:00:25 dsld[666]: set_preconfig1
Jan  1 01:00:25 dsld[666]: sync_group in ar7.cfg:
Jan  1 01:00:25 dsld[666]: sync_group:sync_dsl(enabled=1), nr=0
Jan  1 01:00:25 dsld[666]:   vcc:1/32
Jan  1 01:00:25 dsld[666]:     dsliface:internet
Jan  1 01:00:25 dsld[666]:     dsliface:voip
Jan  1 01:00:25 dsld[666]: sync_group: dsl
Jan  1 01:00:25 dsld[666]: sync_dsl is igd_device
Jan  1 01:00:25 dsld[666]: set_preconfig2
Jan  1 01:00:25 dsld[666]: add_vcc_connection: dsl
[   25.150000][1] [wlan_config] Given config is:
[   25.150000][1] [wlan_config]   hw_interface=0 chip_type=3 (kiwi) offload=1 (non)
[   25.150000][1] [wlan_config] hwrev=209 hwsubrev=1 maca=5c:49:79:XX:XX:XX
[   25.150000][1] [wlan_config] country=276 reg_domain_a=12 reg_domain_b=34
[   25.260000][0] [wlan_eeprom] Calibration data blocks found = 1
[   25.270000][0] [wlan_eeprom] EEPROM #1, type "AR92x7":
[   25.270000][0] [wlan_eeprom] Customer data="AVM7412_CAL1_V2"
[   25.270000][0] [wlan_eeprom] MinCCAPwr thresh set to -85,-85
[   25.270000][0] [wlan_eeprom] Build with ART 0.9b27
[   25.270000][0] avm_net_trace: New net trace device 'WLAN Management Traffic' registered with minor 128.
Jan  1 01:00:25 dsld[683]: DSL Mac 5c:49:79:XX:XX:XX
Jan  1 01:00:25 dsld[683]: VOIP Mac 5c:49:79:XX:XX:XX
Jan  1 01:00:25 dsld[683]: VCC2 Mac 5c:49:79:XX:XX:XX
Jan  1 01:00:25 dsld[683]: VCC3 Mac 5c:49:79:XX:XX:XX
kdsld: kdsld_vcc_preunregister: *
[   25.530000][0] ADDRCONF(NETDEV_UP): guest: link is not ready
[   25.590000][1] [module-alloc-by-name] give 0x5000 bytes at 0x8156b000 to module 'adf' (0x2e5000 bytes left)
[   25.590000][1] [module-alloc-by-name] 0x5000 bytes used, 0x488c bytes expected
Jan  1 01:00:25 dsld[683]: voip: ppptarget voip disabled, ignored
Jan  1 01:00:25 dsld[683]: sync_group(prepare_interfaces): dsl: inet_nr=0
Jan  1 01:00:25 dsld[683]: nach prepare_interfaces: dsld.dsliface_default_inet_nr=0, dsld.dsliface_voip_nr=-1
Jan  1 01:00:25 dsld[683]: get_queueindex: none: not found
Jan  1 01:00:25 dsld[683]: queue 0: prio 0 weight 0 shrate 0 shburst 0 wan
Jan  1 01:00:25 dsld[683]: queue 1: prio 10 weight 0 shrate 0 shburst 0 wan
Jan  1 01:00:25 dsld[683]: queue 2: prio 20 weight 0 shrate 0 shburst 0 wan
Jan  1 01:00:25 dsld[683]: queue 3: prio 30 weight 0 shrate 0 shburst 0 wan
[   25.670000][1] kdsld: nr_ipv4 0 nr_ipv6 0 nr_vpn 0
Jan  1 01:00:25 dsld[683]: queue 4: prio 100 weight 90 shrate 0 shburst 0 wan
Jan  1 01:00:25 dsld[683]: queue 5: prio 100 weight 10 shrate 0 shburst 0 wan
Jan  1 01:00:25 dsld[683]: queue 6: prio 200 weight 0 shrate 0 shburst 0 wan
Jan  1 01:00:25 dsld[683]: appl 0: sip-appl result 1
Jan  1 01:00:25 dsld[683]: classifer: local "localmark sip" result 1
Jan  1 01:00:25 dsld[683]: classifer: local "localmark rtp" result 1
Jan  1 01:00:25 dsld[683]: classifer: local "localmark sip_internet" result 1
Jan  1 01:00:25 dsld[683]: classifer: local "localmark rtp_internet" result 1
Jan  1 01:00:25 dsld[683]: classifer: local "localmark sipdns,ntpdns,tr069dns,tr069" result 2
Jan  1 01:00:25 dsld[683]: classifer: local "localmark igmp" result 3
Jan  1 01:00:25 dsld[683]: classifer: local "localmark webdav" result 4
Jan  1 01:00:25 dsld[683]: classifer: local "localmark dns" result 2
Jan  1 01:00:25 dsld[683]: classifer: lan "udp.dport 43962,47806" result 2
Jan  1 01:00:25 dsld[683]: classifer: lan "ip.proto IPv6-ICMP" result 2
Jan  1 01:00:25 dsld[683]: classifer: lan "ip.proto icmp" result 2
Jan  1 01:00:25 dsld[683]: classifer: lan "udp.dport 53" result 2
Jan  1 01:00:25 dsld[683]: classifer: lan "udp.dport 5060" result 5
Jan  1 01:00:25 dsld[683]: classifer: lan "dhcpoption 12 FRITZ!Media* mediatab" result 6
Jan  1 01:00:25 dsld[683]: classifer: lan "ethsrctab mediatab" result 6
Jan  1 01:00:25 dsld[683]: result 0: tos 65535 vprio 65535 queue 5 appl 65535 bridge 65535 forward 65535
Jan  1 01:00:25 dsld[683]: result 1: tos 65535 vprio 65535 queue 2 appl 65535 bridge 65535 forward 65535
Jan  1 01:00:25 dsld[683]: result 2: tos 65535 vprio 65535 queue 1 appl 65535 bridge 65535 forward 65535
Jan  1 01:00:25 dsld[683]: result 3: tos 65535 vprio 65535 queue 0 appl 65535 bridge 65535 forward 65535
Jan  1 01:00:25 dsld[683]: result 4: tos 65535 vprio 65535 queue 6 appl 65535 bridge 65535 forward 65535
Jan  1 01:00:25 dsld[683]: result 5: tos 65535 vprio 65535 queue 2 appl 0 bridge 65535 forward 65535
Jan  1 01:00:25 dsld[683]: result 6: tos 65535 vprio 65535 queue 3 appl 65535 bridge 65535 forward 65535
[   25.750000][1] [module-alloc-by-name] give 0x3000 bytes at 0x81570000 to module 'asf' (0x2e2000 bytes left)
[   25.750000][1] [module-alloc-by-name] 0x3000 bytes used, 0x326c bytes expected
Jan  1 01:00:25 dsld[683]: interface lo added.
Jan  1 01:00:25 dsld[683]: interface lo up.
Jan  1 01:00:25 dsld[683]: interface tunl0 added.
Jan  1 01:00:25 dsld[683]: interface sit0 added.
Jan  1 01:00:25 dsld[683]: interface eth0 added.
Jan  1 01:00:25 dsld[683]: interface eth0 up.
Jan  1 01:00:25 dsld[683]: interface ptm_vr9 added.
Jan  1 01:00:25 dsld[683]: interface adsl added.
Jan  1 01:00:25 dsld[683]: interface lan added.
Jan  1 01:00:25 dsld[683]: interface lan up.
Jan  1 01:00:25 dsld[683]: interface guest added.
Jan  1 01:00:25 dsld[683]: interface guest up.
Jan  1 01:00:25 dsld[683]: start register_vccs_and_ifaces_on_kdsld for sync_dsl
Jan  1 01:00:25 dsld[683]: setup_dslchannel: ifname=
Jan  1 01:00:25 dsld[683]: kdsld_preregister_vcc: predsl1
kdsld: kdsld_vcc_preregister: predsl1
kdsld: kdsld_vcc_preregister: vcc->ifaces=(null)
Jan  1 01:00:25 dsld[683]: kdsld_preregister_vcc: kdsld_vccidx=0
Jan  1 01:00:25 dsld[683]: notify_due_to_pm
Jan  1 01:00:25 dsld[683]: verbose: DISABLED
[   25.970000][1] [module-alloc-by-name] give 0xaa000 bytes at 0x81573000 to module 'ath_hal' (0x238000 bytes left)
[   25.980000][1] [module-alloc-by-name] 0xaa000 bytes used, 0xa7c60 bytes expected
[   26.110000][1] ath_hal: 0.9.17.1 (AR5416, AR9380, REGOPS_FUNC, WRITE_EEPROM, TX_DATA_SWAP, RX_DATA_SWAP, 11D)
[   26.130000][1] [module-alloc-by-name] give 0x8000 bytes at 0x8161d000 to module 'ath_rate_atheros' (0x230000 bytes left)
[   26.130000][1] [module-alloc-by-name] 0x8000 bytes used, 0x8098 bytes expected
[   26.160000][1] ath_rate_atheros: Copyright (c) 2001-2005 Atheros Communications, Inc, All Rights Reserved
Jan  1 01:00:26 multid[645]: DHCPD on lan:0 skipped, is virtual interface
[   26.230000][1] [module-alloc-by-name] give 0x12000 bytes at 0x81625000 to module 'ath_dfs' (0x21e000 bytes left)
[   26.230000][1] [module-alloc-by-name] 0x12000 bytes used, 0x1367c bytes expected
[   26.260000][1] ath_dfs: Version 2.0.0
Copyright (c) 2005-2006 Atheros Communications, Inc. All Rights Reserved
[   26.390000][1] [module-alloc-by-name] give 0x5c000 bytes at 0x81637000 to module 'ath_dev' (0x1c2000 bytes left)
[   26.390000][1] [module-alloc-by-name] 0x5c000 bytes used, 0x5b890 bytes expected
[   26.670000][1] ath_dev: Copyright (c) 2001-2007 Atheros Communications, Inc, All Rights Reserved
Jan  1 01:00:26 ctlmgr[631]: WLANLIB: wland_role_config_init:100: CFG2/API: WLAND configuration file(/var/tmp/wlan_roles) missing.
Jan  1 01:00:26 telefon[730]: use clock_gettime(CLOCK_MONOTONIC)!
Jan  1 01:00:26 telefon[730]: No S0NT!
Jan  1 01:00:26 telefon[730]: NoOldMSNNames
telefon: SIGCHLD PID 739 received!
[   27.150000][0] [module-alloc-by-name] give 0xf7000 bytes at 0x81693000 to module 'umac' (0xcb000 bytes left)
[   27.150000][0] [module-alloc-by-name] 0xf7000 bytes used, 0xf7718 bytes expected
Jan  1 01:00:27 ctlmgr[631]: WLANLIB: wland_role_config_init:100: CFG2/API: WLAND configuration file(/var/tmp/wlan_roles) missing.
[   28.110000][0] [0]system-load 3  loadavg 1.27 0.29 0.9 - 81 tasks:52 % curr:insmod(11 %) max:ctlmgr(22 %, pid:631), readytorun: 5, pgfault 1664/s (max 5 avg 1.5)
[   28.750000][0] ath_pci: 10.2.85 (Atheros/multi-bss)
PCI: Enabling device 0000:01:00.0 (0000 -> 0002)
__ath_attach: Set global_scn[0]
Green-AP : Green-AP : Attached
ath_get_caps[6180] rx chainmask mismatch actual 3 sc_chainmak 0
ath_get_caps[6155] tx chainmask mismatch actual 3 sc_chainmak 0
ic_num_chains=2x2
_avm_ath_ext_attach_ah:115
_avm_ath_ext_attach_ieee:97
ath_attach_dfs[12671] dfsdomain 2
[   28.790000][0] avm_net_trace: New net trace device 'HW (2.4 + 5 GHz, wifi0)' registered with minor 129.
[   28.790000][0] Register net trace device succeeded with minor 129 (wifi0).
[   28.790000][0] wifi0: Atheros ???: mem=0x1c000000, irq=138 hw_base=0xbc000000
[   28.880000][0] [module-alloc-by-name] give 0x6000 bytes at 0x8178a000 to module 'ath_pktlog' (0xc5000 bytes left)
[   28.880000][0] [module-alloc-by-name] 0x6000 bytes used, 0x6654 bytes expected
telefon: SIGCHLD PID 770 received!
Jan  1 01:00:29 telefon[756]: NoOldMSNNames
[   29.510000][1] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   29.510000][1] lan: port 1(eth0) entering forwarding state
Jan  1 01:00:29 ctlmgr[631]: WLANLIB: wland_role_config_init:100: CFG2/API: WLAND configuration file(/var/tmp/wlan_roles) missing.
[DECTDRV_ERR] API_FP_MAC_START_STOP_REQ 255 -> 0
[DECTDRV_ERR] EepromReadExtRecord, record 0 not found (no records)
group 4 done ...
source files in group 5 ...
exceute files in group 5 ...
group 5 done ...
source files in group 6 ...
exceute files in group 6 ...
group 6 done ...
source files in group 7 ...
/etc/init.d/S73-capitcp  /etc/init.d/S75-inetd    /etc/init.d/S76-media
exceute files in group 7 ...
group 7 done ...
source files in group 8 ...
/etc/init.d/S85-apps
exceute files in group 8 ...
group 8 done ...
source files in group 9 ...
/etc/init.d/S99-tail
run_clock demon started
AVM_WATCHDOG: System Init UEberwachung abgeschlossen (95830 ms noch verfuegbar)
[   30.450000][0] SysRq : Changing Loglevel
Loglevel set to 4
Info: have to stop cat /dev/debug.
[    7.040000][0] [module-alloc-by-name] give 0xe000 bytes at 0x8111a000 to module 'Piglet_noemif' (0x72d000 bytes left)
[    7.040000][0] [module-alloc-by-name] 0xe000 bytes used, 0xf9telefon: SIGHUP received!
pbd[724]: received signal Hangup
Please press Enter to activate this console. rc.wlan: Start WLAN...
rc.wlan: WLAN daemon already running
Jan  1 01:00:31 ctlmgr[631]: WLANLIB: wland_role_config_init:100: CFG2/API: WLAND configuration file(/var/tmp/wlan_roles) missing.
Jan  1 01:00:31 telefon[756]: Stop DECT
FP_MAC_STOP_REQ, ignore, already stopped
starting pid 820, tty '/dev/ttyS0': '-/bin/sh'
BusyBox v1.20.2 (2014-09-26 13:25:19 CEST) built-in shell (ash)
Enter 'help' for a list of built-in commands.
ermittle die aktuelle TTY
tty is "/dev/ttyS0"
Serielles Terminal
Festhängen im Boot-Loop
ROM VER: 1.1.4
CFG 06
NAND
NAND Read OK
Lantiq xDSL CPE VR9
[    0.000000] Kernel command line: console=ttyS0,115200n8r nor_size=0MB sflash_size=0KB nand_size=128MB ethaddr=5C:49:79:XX:XX:XX tffsver=3
[    1.530000]
[    1.580000] {ifx_mtd_add_notifier} name kernel
[    1.600000] {ifx_mtd_add_notifier} name reserved-kernel
[    1.660000] Lantiq SSC driver, version 2.4.1, (c) 2001-2013 Lantiq Deutschland GmbH
[    1.700000] Switch API: PCE MicroCode loaded !!
[    1.760000] KOAM is loaded successfully.
[    1.870000] [TFFS3-NAND] scanning block at address 0x20000
[    1.870000] [TFFS3-NAND] found TFFS header magic at address 0x20000, version 0x30000
[    1.910000] [TFFS3-NAND] scanning block at address 0x40000
[    1.920000] [TFFS3-NAND] found TFFS header magic at address 0x40000, version 0x30000
[    1.960000] [TFFS3-NAND] scanning block at address 0x60000
[    1.960000] [TFFS3-NAND] found TFFS header magic at address 0x60000, version 0x30000
[    2.000000] [TFFS3-NAND] scanning block at address 0x80000
[    2.010000] [TFFS3-NAND] found TFFS header magic at address 0x80000, version 0x30000
[    2.050000] [TFFS3-NAND] scanning block at address 0xa0000
[    2.060000] [TFFS3-NAND] found TFFS header magic at address 0xa0000, version 0x30000
[    2.090000] [TFFS3-NAND] scanning block at address 0xc0000
[    2.090000] [TFFS3-NAND] found TFFS header magic at address 0xc0000, version 0x30000
[    2.120000] [TFFS3-NAND] scanning block at address 0xe0000
[    2.120000] [TFFS3-NAND] found TFFS header magic at address 0xe0000, version 0x30000
[    2.140000] [TFFS3-NAND] scanning block at address 0x100000
[    2.140000] [TFFS3-NAND] found TFFS header magic at address 0x100000, version 0x30000
[    2.160000] [TFFS3-NAND] scanning block at address 0x120000
[    2.170000] [TFFS3-NAND] found TFFS header magic at address 0x120000, version 0x30000
[    2.190000] [TFFS3-NAND] scanning block at address 0x140000
[    2.190000] [TFFS3-NAND] found TFFS header magic at address 0x140000, version 0x30000
[    2.210000] [TFFS3-NAND] scanning block at address 0x160000
[    2.210000] [TFFS3-NAND] found TFFS header magic at address 0x160000, version 0x30000
[    2.230000] [TFFS3-NAND] scanning block at address 0x180000
[    2.240000] [TFFS3-NAND] found TFFS header magic at address 0x180000, version 0x30000
[    2.260000] [TFFS3-NAND] scanning block at address 0x1a0000
[    2.260000] [TFFS3-NAND] found TFFS header magic at address 0x1a0000, version 0x30000
[    2.280000] [TFFS3-NAND] scanning block at address 0x1c0000
[    2.280000] [TFFS3-NAND] found TFFS header magic at address 0x1c0000, version 0x30000
[    2.300000] [TFFS3-NAND] scanning block at address 0x1e0000
[    2.310000] [TFFS3-NAND] found TFFS header magic at address 0x1e0000, version 0x30000
[    2.320000] [TFFS3-NAND] scanning block at address 0x200000
[    2.330000] [TFFS3-NAND] found TFFS header magic at address 0x200000, version 0x30000
[    2.350000] [TFFS3-NAND] scanning block at address 0x220000
[    2.350000] [TFFS3-NAND] found TFFS header magic at address 0x220000, version 0x30000
[    2.370000] [TFFS3-NAND] scanning block at address 0x240000
[    2.380000] [TFFS3-NAND] found TFFS header magic at address 0x240000, version 0x30000
[    2.390000] [TFFS3-NAND] scanning block at address 0x260000
[    2.400000] [TFFS3-NAND] found TFFS header magic at address 0x260000, version 0x30000
[    2.420000] [TFFS3-NAND] scanning block at address 0x280000
[    2.420000] [TFFS3-NAND] found TFFS header magic at address 0x280000, version 0x30000
[    2.440000] [TFFS3-NAND] scanning block at address 0x2a0000
[    2.440000] [TFFS3-NAND] found TFFS header magic at address 0x2a0000, version 0x30000
[    2.460000] [TFFS3-NAND] scanning block at address 0x2c0000
[    2.470000] [TFFS3-NAND] found TFFS header magic at address 0x2c0000, version 0x30000
[    2.490000] [TFFS3-NAND] scanning block at address 0x2e0000
[    2.490000] [TFFS3-NAND] found TFFS header magic at address 0x2e0000, version 0x30000
[    2.510000] [TFFS3-NAND] scanning block at address 0x300000
[    2.510000] [TFFS3-NAND] found TFFS header magic at address 0x300000, version 0x30000
[    2.530000] [TFFS3-NAND] scanning block at address 0x320000
[    2.540000] [TFFS3-NAND] found TFFS header magic at address 0x320000, version 0x30000
[    2.550000] [TFFS3-NAND] scanning block at address 0x340000
[    2.560000] [TFFS3-NAND] found TFFS header magic at address 0x340000, version 0x30000
[    2.580000] [TFFS3-NAND] scanning block at address 0x360000
[    2.580000] [TFFS3-NAND] found TFFS header magic at address 0x360000, version 0x30000
[    2.600000] [TFFS3-NAND] scanning block at address 0x380000
[    2.610000] [TFFS3-NAND] found TFFS header magic at address 0x380000, version 0x30000
[    2.620000] [TFFS3-NAND] scanning block at address 0x3a0000
[    2.630000] [TFFS3-NAND] found TFFS header magic at address 0x3a0000, version 0x30000
[    2.650000] [TFFS3-NAND] scanning block at address 0x3c0000
[    2.650000] [TFFS3-NAND] found TFFS header magic at address 0x3c0000, version 0x30000
[    2.670000] [TFFS3-NAND] scanning block at address 0x3e0000
[    2.670000] [TFFS3-NAND] found TFFS header magic at address 0x3e0000, version 0x30000
[    2.690000] [TFFS3-NAND] Initialisation successful, 32/32 NAND blocks active, fill rate 13%
[    2.700000] TFFS: tiny flash file system driver. GPL (c) AVM Berlin (Version 3.0)
[    2.710000] Adam2 environment variables API installed.
[    2.710000] [simple-profiling]: 2 performance counters implemented, NEW_34K
[    2.720000] Enable Performance Counter 0 for Data cache load/stores (User-Mode enabled Supervisor-Mode enabled Kernel-Mode enabled Exeption-Mode disable)
[    2.730000] Setup tcs=0x1 current_tc_mask=0x1, reg=0
[    2.740000] [simple-profiling]: 2 performance counters implemented, NEW_34K
[    2.750000] Enable Performance Counter 1 for Data cache load/store misses (User-Mode enabled Supervisor-Mode enabled Kernel-Mode enabled Exeption-Mode disable)
[    2.760000] Setup tcs=0x1 current_tc_mask=0x1, reg=1
[    2.770000] AVM Simple Profiling enabled Version 3.0
[    2.770000] {avmnet_cfg_netinit}
[    2.770000] [avmnet] No config found for HWRev 209, HWSubRev 1, Profile-ID 0, trying base config for HWSubRev
[    2.780000] [avmnet] No config found for HWRev 209, HWSubRev 1, trying base config for HWRev
[    2.790000] [avmnet] [avmnet_swi_7port_init] Init on module swi_vr9 called.
[    2.800000] [avmnet] [fix_phy_clock_config]: Could not read external PHY clock pin data from avm_hw_config!
[    3.010000] Loading AVM Net Common Datapath Driver for 7Port Switch......
[    3.010000] [ppe_eth_init] init_hw()
[    3.020000] [init_hw] ppe_hw_init=0xff successful
[    3.020000] [ppe_eth_init] ifx_proc_file_create()
[    3.030000] [ppe_eth_init] dma_setup_init[    1.510000] badblock statistics:
[    1.530000]
[    3.030000] [ppe_eth_init] dma_setup_init()
[   12.240000]
[   12.240000]
[   12.240000]
[   12.240000]
[   12.240000]
[   12.240000]
[   12.240000]
[   12.240000] [piglet]===== end of shared usage of UART (DECT and CONSOLE) ====
[   12.240000] Call Trace:
[   12.260000] [<8002a068>] dump_stack+0x8/0x40
[   12.260000] [<800607e4>] panic+0x64/0x1a0
[   12.270000] [<c0180228>] init_module+0x228/0x8ec [Piglet_noemif]
[   12.270000] [<80011a9c>] do_one_initcall+0x3c/0x260
[   12.280000] [<800a3318>] sys_init_module+0xd8/0x280
[   12.280000] [<800059dc>] stack_done+0x20/0x40
[   12.290000]
[   12.290000] Kernel panic - not syncing: [piglet]bye bye - can't load dect-fw!
[   12.290000]
[   12.300000] Rebooting in 5 seconds..n: 17
[    7.170000][0] [piglet]patch_dectfw: RFPI tag found 02965ff4f0
[    7.170000][0] [piglet]patch_dectfw: dectmode 19
[    7.200000][0] [piglet]dect_loader144xx: slow-bootmode
[    8.360000][0] [piglet]dect_loader144xx: error: no error code received
[    8.940000][0] [piglet]dect_loader144xx: slow-bootmode
[   10.000000][0] [piglet]dect_loader144xx: error: no error code received
[   10.580000][0] [piglet]dect_loader144xx: slow-bootmode
[   11.650000][0] [piglet]dect_loader144xx: error: no error code received
[   13.210000] [0]system-load 2  loadavg 0.38 0.8 0.3 - 37 tasks:63 % curr:modprobe(27 %) max:init(32 %, pid:1), readytorun: 2, pgfault 811/s (max 1 avg 0.0)
[   12.240000]
[   12.240000]
[   12.240000]
[   12.240000]
[   12.240000]
[   12.240000]
[   12.240000]
[   12.290000]
[   12.290000]
tty is "/dev/ttyS0"
Serielles Terminal
disable start/stop characters and flowcontrol
# df
Filesystem           1K-blocks      Used Available Use% Mounted on
/dev/root                49152     17640     31512  36% /wrapper
/dev/loop0               15232     15232         0 100% /
tmpfs                    57408       624     56784   1% /var
tmpfs                    57408         8     57400   0% /dev
/var/dev/nand            18176      1160     17016   6% /var/media/ftp
# cat /proc/cpuinfo
system type             : VR9
processor               : 0
cpu model               : MIPS 34Kc V5.6
BogoMIPS                : 332.59
wait instruction        : yes
microsecond timers      : yes
tlb_entries             : 32
extra interrupt vector  : yes
hardware watchpoint     : yes, count: 4, address/irw mask: [0x0ffc, 0x0ffc, 0x0ffb, 0x0ffb]
ASEs implemented        : mips16 dsp mt
shadow register sets    : 1
core                    : 0
VCED exceptions         : not available
VCEI exceptions         : not available
processor               : 1
BogoMIPS                : 249.85
tlb_entries             : 32
core                    : 0
# cat /proc/meminfo
MemTotal:         114820 kB
MemFree:           17996 kB
Buffers:           11408 kB
Cached:            45736 kB
SwapCached:            0 kB
Active:            17720 kB
Inactive:          45920 kB
Active(anon):      10164 kB
Inactive(anon):      788 kB
Active(file):       7556 kB
Inactive(file):    45132 kB
Unevictable:        4380 kB
Mlocked:            4380 kB
SwapTotal:             0 kB
SwapFree:              0 kB
Dirty:                 0 kB
Writeback:             0 kB
AnonPages:         10916 kB
Mapped:            10108 kB
Shmem:              1256 kB
Slab:              27128 kB
SReclaimable:       1976 kB
SUnreclaim:        25152 kB
KernelStack:        1296 kB
PageTables:          392 kB
NFS_Unstable:          0 kB
Bounce:                0 kB
WritebackTmp:          0 kB
CommitLimit:       57408 kB
Committed_AS:      21628 kB
VmallocTotal:    1048308 kB
VmallocUsed:         632 kB
VmallocChunk:    1025368 kB
Reserved:          16252 kB
Oh, es gibt also jemanden mit einer FritzBox aus der "VRX220-Reihe" mit einer per RS232 angeschlossener Konsole, so wäre es natürlich einfach(er) ein Bootlog anzufertigen während ein Freetz-Image geladen wird (was bis jetzt in einem Bootloop endet, die Ursache dafür ist bis jetzt leider unbekannt), hast du das schon probiert? Beziehungsweise stammt dein Bootlog "Festhängen im Boot-Loop" vom Versuch ein Freetz-Image zu starten (und wenn ja von was für einem, also Revision und .config)?
Bootloop ist mit orig FOS 6.30 Firmware. Ursache ist nur die RXi Leitung: sie darf beim FB Booten nicht vom PC getrieben werden, sonst kommt der Telefon Part (DECT Firmware) durcheinander und sie startet sich neu (s. Log).
Zum Flashen des (seit Stunden fertigen) Freetz Images fehlt mir die passende Methode.
Die GUI hat keinen Upload Knopf.
Zum modfs-Entpacken hat die 7412 nicht genügend Speicher.
EVA ist auf der Konsolen-Seite Read-Only, und wie es per FTP geht, weiss ich noch nicht.
Ideen? Vorschläge?
was hast du für nen pegelwandler? noch was anderes im haus? das festhängen bei angeschlossener serieller kenn ich.. hab 2 ftdi adapter, bei einem passiert das bei manchen geräten.
http://shop.in-circuit.de/product_info.php?cPath=40&products_id=112 soll keine schleichwerbung sein, das ding ist einfach gut. usb jtag und 3,3V pegelwandler in einem board...
Einfach die Firmware per "ftpget" von irgendeinem LAN-Client laden, manuell entpacken (tar -xvf <image> -C /) und dann /var/install von Hand aufrufen - installiert praktisch jede Software und Shell-Zugriff ist über die Serielle ja vorhanden. Ich würde mir da aber erst mal ein "normales" Dateisystem nehmen und das nur etwas modifizieren für den ersten Versuch ... Freetz-Images sollen auf der 7412 ja nicht laufen im Moment und @qwertz.asdfgh hat bestimmt auch die Hoffnung, daß Du dabei helfen kannst, das Problem einzugrenzen. Aber ich würde mich erst einmal mit dem Installationsprozess und der Umschaltung zwischen den Systemen vertraut machen, bevor ich an die Fehlersuche in einem Freetz-Image gehe.
Hänge gerade an der Updateprozedur mit der originalen 6.83 FW von AVM (unverändert).
post_install schlägt fehl mit
Copy filesystem image ...
mount: mounting /dev/loop1 on /var/tmp/fs failed: Invalid argument
filesystem.image: cannot mount squashfs, trying ext2 ...
gleiches Symptom auf der Konsole:
# cd /var/tmp
# mkdir fs
# mount -t squashfs filesystem.image fs
mount: mounting /dev/loop1 on fs failed: Invalid argument
Auf dem PC sieht das Image so aus:
> file filesystem.image
filesystem.image: Squashfs filesystem, big endian, version 0.0, 0 bytes, 0 inodes, blocksize: 0 bytes, created: Thu Jan  1 00:00:00 1970
> ls -l filesystem.image
-rw-r--r-- 1 user users 17784840 Mar  7 13:00 filesystem.image
Was schon sehr verdächtig aussieht.
Bei einem selbst gebauten Freetz Image ist es schon vernünftiger:
filesystem.image: Squashfs filesystem, big endian, version 3.0, 19339975 bytes, 299 inodes, blocksize: 65536 bytes, created: Sat May 13 17:52:53 2017
Gibt es denn irgendwo im Netz eine funktionierende originale Firmware von AVM für die 7412?
------------- Update 16.05.2017 ----------------------
Hier noch die Fehlermeldung mit Kontext bei Update von 6.30 auf Freetz 6.83:
[main] exit error 0
dd: writing '/var/tmp/fsimage.ext2': No space left on device
65233+0 records in
65232+0 records out
failed to mount filesystem.image
Setting linux_fs_start skipped due to errors...
umount: can't umount /var/tmp/fs: Invalid argument
The system is going down NOW!
Scheint ein volles tempfs zu sein.
Das kann (und will) ich nicht glauben (schließlich habe ich darüber auch schon manuelle Firmwareupdates durchgeführt bei einer 7412 und Varianten der 7412 von anderen Providern als 1&1 sind mir auch nicht bekannt)! Die manuelle Firmware-Upatefunktion per WebIf müsste verfügbar sein, über diese kann man bei FritzOS 6.30 (welche lt. Beitrag #1 installiert ist/war) auch unsignierte Freetz-Images hochladen.
Bei AVM:
ftp://ftp.avm.de/fritz.box/fritzbox.7412/firmware/deutsch/
https://service.avm.de/downloads/downgrade/fritzbox_7412/
Aber ansonsten kann ich den letzten Satz von Peter aus #5 nur unterstreichen!
Das ist nicht sehr verdächtig, das ist vollkommen normal. Über die Änderungen, die beim Übergang vom 2.6er- zum 3.10er-Kernel von AVM vollzogen wurden, gibt es hier praktisch ganze Bücher. Du suchst im Moment nach Fehlern und Problemen, wo gar keine sind (selbst die Fehlermeldung ist "expected", schließlich gibt es unmittelbar danach die notwendigen Anweisungen in der /var/install, um diese Situation zu behandeln) - vielleicht solltest Du Dich erst einmal schlaumachen und für eine Kernel-Version entscheiden, mit der man dann weitersehen kann. Wenn es tatsächlich ein Problem beim Installieren einer Firmware >= 06.5x auf dem Gerät geben sollte, dann tritt der ziemlich sicher nach dem o.g. "Fehler" mit dem Mounten des FS-Images auf - das ist jedenfalls mal keiner (bzw. kein "echter").
Ich bin mir im Moment nicht so richtig sicher, ob Du der Überzeugung bist, Du wärest der Erste, der jetzt seine 7412 mit einer geänderten Firmware versieht. Das gilt ggf. für ein mit Freetz erzeugtes Image und Du magst auch einer der Ersten (oder meinetwegen sogar der Erste an sich) sein, der sich hier meldet und die serielle Schnittstelle bei seiner 7412 bestückt hat - aber so unbekannt ist der Aufbau und das "Modifizieren" einer 7412 nun auch wieder nicht, daß es da gar keine Erfahrungen gäbe bzw. diese sind weitestgehend identisch mit denen beim Modifizieren anderer VR9-Modelle mit NAND-Flash fürs System und einer "wrapper"-Partition (die hatten ja auch schon die Versionen <= 06.5x).
Es gibt bis zur 06.30 sogar einen (im Vergleich zu Lötarbeiten weniger umfassende Eingriffe erfordernden) Weg, wie man dort auch noch einen Shell-Zugriff erreichen konnte, wenn AVM den Telnet-Daemon in der Firmware bereits gesperrt hatte ... nennt sich "modfs-Starter" (gibt hier irgendwo einen Thread dazu) und installiert über ein "normales Firmware-Update" (bis zur 06.50 geht das nämlich auch noch unsigniert) eine ShellInABox-Instanz, die nach einem Neustart genutzt werden kann. Mit einer solchen Shell haben dann schon mehrere Leute ihre 7412 modifiziert ... bisher scheitern m.W. Freetz-Images (mit 3.10er-Kernel und SquashFS4, das oben ist ja noch ein SquashFS3-Image für < 06.5x) allerdings auf diesem Gerät und das ist eine Stelle, wo Du tatsächlich Neues beitragen könntest, wenn man beim Booten in der Console einen Fehler sehen sollte.
Für das, was Du da im Moment offenbar versuchst, liegen jedenfalls schon genug Erfahrungen vor (wie man mit einem ext2-FS sogar die Box "übernehmen" kann, habe ich erst vor kurzem beschrieben und zwar genau auch am Beispiel der 7412) und wenn Du etwas lesen würdest, könntest Du Dir ggf. ein paar Kopfschmerzen ersparen. Es sei denn, Du willst das alles noch einmal von vorne aufrollen ... auch gut (ich kann "Entdeckergeist" nachvollziehen). Aber wenn #6 Dein aktueller Stand ist, rennst Du gerade mit Volldampf in eine vollkommen falsche Richtung und mehr oder weniger in eine Einbahnstraße.
@qwertz.asdfgh:
Ich bin ja nach wie vor der Ansicht, daß das Problem beim Booten der zwei Modelle (m.W. betrifft das die 7412 und die 7430?) auf das Ersetzen der BusyBox in der Wrapper-Partitition zurückzuführen ist, was m.W. immer noch im Freetz-Build-Prozess passiert, obwohl es nicht notwendig wäre und bei anderen Modellen ja auch schon Probleme bereitete. Oder - als Alternative - auf fehlende Bestandteile, weil diese beiden Modelle kein NAS bereitstellen.
Ich hatte ja mal irgendwo einen Test mit einem von @er13 erzeugten Freetz-Image gemacht ... und dabei kein wirkliches Problem gefunden (Freetz-Images sind halt nicht so meins) - bei mir lief das Image im zweiten Versuch.
Was daraus dann geworden ist bzw. wie sich dieses Image nun von einem mit der Freetz-Toolchain selbst erzeugten unterscheiden würde, weiß ich nicht ... vielleicht ist das alles nur mehr oder weniger versehentlich eingeschlafen und es funktioniert dann doch?
Der ganze oben verlinkte Thread beschäftigt sich ja mit dem Thema und meine These zu den Ursachen des Problems habe ich da auch schon niedergeschrieben. Allerdings ist die eben ungetestet - ich würde damit beginnen, daß ich einfach mal ein Freetz-Image baue, in dem die AVM-Dateien gar nicht ausgetauscht werden (das "pivot_root" erfolgt ja praktisch als allererste Aktion und danach gibt es dann die Freetz-BusyBox auch wieder) und das installieren lasse oder nur das SquashFS-Image mit einem passenden Kernel von Hand installiere und dabei den Inhalt der Wrapper-Partition (sie muß natürlich zur Kernel-Version passen, aber dann ist der Inhalt praktisch "statisch" mit den paar echten Dateien) gar nicht verändere. Wenn das dann starten sollte, liegt die Ursache in einem falschen Wrapper (aka ext2-FS, wenn es von Freetz erzeugt wird) und wenn auch das schon Späne macht, ist zumindest diese Theorie mal falsifiziert.
Ja genau, das sind für mich die "VRX220-Modelle".
Zumindest das könnte man wohl als Ursache ausschließen denn die 7430 stellt ein NAS zur Verfügung (im Gegensatz zur 7412).
Wie der aktuelle Status aussieht weiß ich tatsächlich nicht, ich werde mich hüten Freetz-Images aus der Ferne auf VRX220-Modellen zu testen... ;)
Das sich allerdings seit damals (bzw. auch von >hier<, >hier< oder >hier< aus) was bei Freetz bzgl. der Probleme mit den VRX220-Modellen getan hat bezweifle ich ein wenig, zumindest konnte ich dbzgl. beim Freetz-Projekt keine relevanten Änderungen entdecken die sich diesem Problem direkt angenommen hätten. Könnte höchstens sein, dass andere Änderungen dbzgl. eine (indirekte) Wirkung gehabt hätten aber solange man den Grund für das Problem nicht kennt ist das auch nur Spekulation.
Aber vielleicht funktioniert es ja mittlerweile mit der 7412 und nur die 7430 mach noch Probleme? Alles eben etwas schwer nachvollziehbar/testbar wenn man eben keine 7412 oder 7430 physisch zum Testen zur Verfügung hat...
Ich hatte ja mal (bzw. habe immer noch) das NAND-TFFS in Verdacht denn im Gegensatz zu allen anderen VR9-Modellen ist das m.E. der einzige relevante Unterschied (könnte durchaus sein, dass das Problem indirekt durch die BusyBox von Freetz verursacht wird?). Ansonsten haben ja nur noch die neueren VR10/GRX500-Modelle das TFFS im NAND (anstatt im NOR-Flash) aber diese Modelle haben auch einen anderen Kernel bzw. sind die Unterschiede zu den VR9-Modellen schon etwas umfangreicher (und ein GRX500-Modell startet lt. einem Bericht hier im IPPF mit einem Freetz-Image wohl sogar problemlos).
Grund für die letzte Bearbeitung dieses Beitrages ist das Ersetzen der IPPF-Links als BBCode durch normale URL da die entsprechenden BBCodes seit dem Foren-Update vom 04.07.2017 nicht mehr funktionieren.
Freetz Bootlog
Freetz, trunk, r14252;
.config:
# Automatically generated file; DO NOT EDIT.
# Freetz Configuration
FREETZ_HAVE_DOT_CONFIG=y
# User competence ------------------------
# FREETZ_USER_LEVEL_BEGINNER is not set
# FREETZ_USER_LEVEL_ADVANCED is not set
FREETZ_USER_LEVEL_EXPERT=y
FREETZ_SHOW_ADVANCED=y
FREETZ_SHOW_EXPERT=y
# Hardware/Firmware ----------------------
# FREETZ_TYPE_300IP is not set
# FREETZ_TYPE_FON is not set
# FREETZ_TYPE_WLAN is not set
# FREETZ_TYPE_W501V is not set
# FREETZ_TYPE_2170 is not set
# WLAN
# FREETZ_TYPE_3020 is not set
# FREETZ_TYPE_3030 is not set
# FREETZ_TYPE_3130 is not set
# FREETZ_TYPE_3131 is not set
# FREETZ_TYPE_3170 is not set
# FREETZ_TYPE_3270_V2 is not set
# FREETZ_TYPE_3270_V3 is not set
# FREETZ_TYPE_3272 is not set
# FREETZ_TYPE_3370 is not set
# FREETZ_TYPE_3390 is not set
# FREETZ_TYPE_3490 is not set
# WAN
# FREETZ_TYPE_4020 is not set
# Fon
# FREETZ_TYPE_5010 is not set
# FREETZ_TYPE_5050 is not set
# FREETZ_TYPE_5124 is not set
# FREETZ_TYPE_5140 is not set
# LTE
# FREETZ_TYPE_6810 is not set
# FREETZ_TYPE_6820 is not set
# FREETZ_TYPE_6840 is not set
# FREETZ_TYPE_6842 is not set
# Fon WLAN
# FREETZ_TYPE_7050 is not set
# FREETZ_TYPE_7112 is not set
# FREETZ_TYPE_7113 is not set
# FREETZ_TYPE_7140 is not set
# FREETZ_TYPE_7141 is not set
# FREETZ_TYPE_7150 is not set
# FREETZ_TYPE_7170 is not set
# FREETZ_TYPE_7240 is not set
# FREETZ_TYPE_7270_V1 is not set
# FREETZ_TYPE_7270_V2 is not set
# FREETZ_TYPE_7270_V3 is not set
# FREETZ_TYPE_7272 is not set
# FREETZ_TYPE_7312 is not set
# FREETZ_TYPE_7320 is not set
# FREETZ_TYPE_7330_XL is not set
# FREETZ_TYPE_7330_SL is not set
# FREETZ_TYPE_7340 is not set
# FREETZ_TYPE_7360_V1 is not set
# FREETZ_TYPE_7360_V2 is not set
# FREETZ_TYPE_7360_SL is not set
# FREETZ_TYPE_7362 is not set
# FREETZ_TYPE_7369 is not set
# FREETZ_TYPE_7390 is not set
FREETZ_TYPE_7412=y
# FREETZ_TYPE_7430 is not set
# FREETZ_TYPE_7490 is not set
# FREETZ_TYPE_7560 is not set
# FREETZ_TYPE_7580 is not set
# VDSL
# FREETZ_TYPE_7570 is not set
# Custom
# FREETZ_TYPE_CUSTOM is not set
FREETZ_TYPE_LANG_DE=y
# FREETZ_TYPE_LANG_EN is not set
# FREETZ_TYPE_FIRMWARE_06_0X is not set
FREETZ_TYPE_FIRMWARE_06_2X=y
# FREETZ_TYPE_FIRMWARE_06_5X is not set
# FREETZ_TYPE_FIRMWARE_06_8X is not set
# FREETZ_TYPE_FIRMWARE_LABOR is not set
FREETZ_TYPE_FIRMWARE_FINAL=y
FREETZ_TYPE_LANGUAGE="de"
# Original components --------------------
FREETZ_TARGET_IPV6_SUPPORT=y
# FREETZ_REPLACE_KERNEL is not set
# FREETZ_REPLACE_KERNEL_IMPL is not set
# Removal patches
# Removal patches ------------------------
# FREETZ_REMOVE_MULTI_ANNEX_FIRMWARE_DIFFS is not set
# FREETZ_REMOVE_PIGLET_V1_AVAILABLE is not set
# FREETZ_REMOVE_PIGLET_V2_AVAILABLE is not set
# FREETZ_REMOVE_PIGLET_ISDN_AVAILABLE is not set
# FREETZ_REMOVE_PIGLET_POTS_AVAILABLE is not set
# FREETZ_REMOVE_ASSISTANT is not set
FREETZ_REMOVE_MYFRITZ=y
FREETZ_REMOVE_AVM_VPN=y
# Remove brandings
# FREETZ_REMOVE_BRANDING_1und1 is not set
# FREETZ_REMOVE_BRANDING_avm is not set
# FREETZ_REMOVE_CAPIOVERTCP is not set
# FREETZ_REMOVE_CHRONYD is not set
# FREETZ_REMOVE_DECT is not set
# FREETZ_REMOVE_DSLD is not set
# FREETZ_REMOVE_SHOWDSLDSTAT is not set
FREETZ_REMOVE_DTRACE=y
FREETZ_REMOVE_HELP=y
# FREETZ_REMOVE_RAMZSWAP is not set
# FREETZ_REMOVE_LSOF is not set
# FREETZ_REMOVE_RUNCLOCK is not set
# FREETZ_REMOVE_SUPPORT is not set
FREETZ_REMOVE_TR069=y
FREETZ_REMOVE_TR069_FWUPDATE=y
FREETZ_REMOVE_TR069_HTTPSDL=y
# FREETZ_REMOVE_TR069_PROVIDERS is not set
FREETZ_REMOVE_UMTSD=y
# FREETZ_REMOVE_UPNP is not set
FREETZ_REMOVE_KIDS=y
# FREETZ_REMOVE_QOS is not set
# FREETZ_REMOVE_AVM_E2FSPROGS is not set
# FREETZ_REMOVE_VOIPD is not set
# FREETZ_REMOVE_TELEPHONY is not set
# FREETZ_REMOVE_WLAN is not set
# Other patches
# Web menu patches -----------------------
# FREETZ_PATCH_ATA is not set
FREETZ_PATCH_SIGNED=y
# FREETZ_ENABLE_LED_DEACTIVATION is not set
# FREETZ_CUSTOM_UDEV_RULES is not set
# Replacement patches --------------------
# FREETZ_REPLACE_DTRACE is not set
# FREETZ_REPLACE_ONLINECHANGED is not set
# Additional patches ---------------------
FREETZ_ADD_ETCSERVICES=y
# FREETZ_ENFORCE_URLADER_SETTINGS is not set
# Misc patches ---------------------------
# FREETZ_DISABLE_SERIAL_CONSOLE is not set
FREETZ_RESTORE_DEBUG_CFG_SUPPORT=y
# FREETZ_ASYNCHRONOUS_DEBUG_CFG is not set
# AVM daemons ----------------------------
# FREETZ_AVMDAEMON_DISABLE_IGD is not set
FREETZ_AVMDAEMON_DISABLE_NTP=y
# FREETZ_AVMDAEMON_DISABLE_IGM is not set
FREETZ_AVMDAEMON_DISABLE_TR069=y
FREETZ_AVMDAEMON_DISABLE_MULTIDPORTS=y
FREETZ_AVMDAEMON_DISABLE_DNS=y
FREETZ_AVMDAEMON_DISABLE_DHCP=y
FREETZ_AVMDAEMON_DISABLE_LLMNR=y
# Additional components ------------------
# Packages
# Debug helpers
FREETZ_PACKAGE_GDB=y
# binaries
FREETZ_PACKAGE_GDB_GDB=y
FREETZ_PACKAGE_GDB_GDBSERVER=y
FREETZ_PACKAGE_GDB_HOST=y
# FREETZ_GDB_VERSION_6_8 is not set
FREETZ_GDB_VERSION_7_9=y
# FREETZ_PACKAGE_INOTIFY_TOOLS is not set
FREETZ_PACKAGE_LDD=y
FREETZ_PACKAGE_LTRACE=y
# FREETZ_PACKAGE_NANO_SHELL is not set
# FREETZ_PACKAGE_PCIUTILS is not set
FREETZ_PACKAGE_STRACE=y
# FREETZ_PACKAGE_TARGET_TESTER is not set
# FREETZ_PACKAGE_USBUTILS is not set
# Packages
# FREETZ_PACKAGE_AICCU is not set
# FREETZ_PACKAGE_APACHE is not set
# FREETZ_PACKAGE_APACHE2 is not set
# FREETZ_PACKAGE_ATOP is not set
# FREETZ_PACKAGE_AUTOFS is not set
# FREETZ_PACKAGE_AUTOSSH is not set
# FREETZ_PACKAGE_AVAHI is not set
# FREETZ_PACKAGE_BASH is not set
# FREETZ_PACKAGE_BFTPD is not set
# FREETZ_PACKAGE_BFUSB is not set
# FREETZ_PACKAGE_BIND is not set
# FREETZ_PACKAGE_BIP is not set
# FREETZ_PACKAGE_BIRD is not set
# FREETZ_PACKAGE_BITTWIST is not set
# FREETZ_PACKAGE_BLUEZ_UTILS is not set
# FREETZ_PACKAGE_BR2684CTL is not set
# FREETZ_PACKAGE_BRIDGE_UTILS is not set
# FREETZ_PACKAGE_BVI is not set
# FREETZ_PACKAGE_CALLMONITOR is not set
# FREETZ_PACKAGE_CCID is not set
# FREETZ_PACKAGE_CHECKMAILD is not set
# Cifsmount (not available, needs replace kernel)
# FREETZ_PACKAGE_CLASSPATH is not set
# FREETZ_PACKAGE_CNTLM is not set
# FREETZ_PACKAGE_COMGT is not set
# FREETZ_PACKAGE_CRYPTSETUP is not set
# FREETZ_PACKAGE_CTORRENT is not set
FREETZ_PACKAGE_CURL=y
# FREETZ_PACKAGE_CURL_STATIC is not set
# FREETZ_PACKAGE_DANTE is not set
# FREETZ_PACKAGE_DAVFS2 is not set
# FREETZ_PACKAGE_DBUS is not set
# FREETZ_PACKAGE_DEBOOTSTRAP is not set
# FREETZ_PACKAGE_DECO is not set
# FREETZ_PACKAGE_DECRYPT_FRITZOS_CFG is not set
# FREETZ_PACKAGE_DIGITEMP is not set
# FREETZ_PACKAGE_DNS2TCP is not set
FREETZ_PACKAGE_DNSMASQ=y
# FREETZ_PACKAGE_DNSMASQ_WITH_DNSSEC is not set
# HINT: Don't forget to enable a dns/dhcp server.
FREETZ_PACKAGE_DNSMASQ_DISABLE_DNS=y
FREETZ_PACKAGE_DNSMASQ_DISABLE_DHCP=y
# FREETZ_PACKAGE_DOSFSTOOLS is not set
# FREETZ_PACKAGE_DROPBEAR is not set
# FREETZ_PACKAGE_DTACH is not set
# FREETZ_PACKAGE_DVBSNOOP is not set
# FREETZ_PACKAGE_DVBSTREAM is not set
# FREETZ_PACKAGE_DVBTUNE is not set
# FREETZ_PACKAGE_E2FSPROGS is not set
# E-MailRelay (not available, needs libstdc++ as Standard C++ Library)
# FREETZ_PACKAGE_EMPTY is not set
# FREETZ_PACKAGE_ESPEAK is not set
# FREETZ_PACKAGE_FFMPEG is not set
# FREETZ_PACKAGE_FORTUNE is not set
# FREETZ_PACKAGE_FOWSR is not set
# FREETZ_PACKAGE_FSTYP is not set
# FREETZ_PACKAGE_FUSE is not set
# FREETZ_PACKAGE_GHOSTSCRIPT_FONTS is not set
# FREETZ_PACKAGE_GIT is not set
# FREETZ_PACKAGE_GNTPSEND is not set
# FREETZ_PACKAGE_GNU_MAKE is not set
# FREETZ_PACKAGE_GNUTLS is not set
# FREETZ_PACKAGE_GOCR is not set
# FREETZ_PACKAGE_GW6 is not set
# FREETZ_PACKAGE_HAPROXY is not set
FREETZ_PACKAGE_HASERL=y
# FREETZ_PACKAGE_HASERL_WITH_LUA is not set
# FREETZ_PACKAGE_HOL is not set
# FREETZ_PACKAGE_HTML2TEXT is not set
# FREETZ_PACKAGE_HTOP is not set
# FREETZ_PACKAGE_HTPDATE is not set
# FREETZ_PACKAGE_HTTPRY is not set
# FREETZ_PACKAGE_HTTPTUNNEL is not set
# FREETZ_PACKAGE_ICONV is not set
# FREETZ_PACKAGE_IFSTAT is not set
# FREETZ_PACKAGE_IFTOP is not set
# FREETZ_PACKAGE_IGMPPROXY is not set
# FREETZ_PACKAGE_IMAGEMAGICK is not set
# FREETZ_PACKAGE_INADYN_MT is not set
# FREETZ_PACKAGE_INADYN_OPENDNS is not set
FREETZ_PACKAGE_INETD=y
# FREETZ_PACKAGE_INETD_TIME is not set
# FREETZ_PACKAGE_IODINE is not set
# FREETZ_PACKAGE_IPTRAF is not set
# FREETZ_PACKAGE_IPUTILS is not set
# FREETZ_PACKAGE_IRSSI is not set
# FREETZ_PACKAGE_ISC_DHCP is not set
# FREETZ_PACKAGE_JAMVM is not set
# FREETZ_PACKAGE_JS is not set
# FREETZ_PACKAGE_KNOCK is not set
# FREETZ_PACKAGE_LFTP is not set
# FREETZ_PACKAGE_LIGHTTPD is not set
# FREETZ_PACKAGE_LUA is not set
# FREETZ_PACKAGE_LYNX is not set
# FREETZ_PACKAGE_MADPLAY is not set
# FREETZ_PACKAGE_MC is not set
# FREETZ_PACKAGE_MCABBER is not set
# FREETZ_PACKAGE_MEDIATOMB is not set
# FREETZ_PACKAGE_MICROPERL is not set
# FREETZ_PACKAGE_MINICOM is not set
# FREETZ_PACKAGE_MINIDLNA is not set
# FREETZ_PACKAGE_MINI_SNMPD is not set
FREETZ_PACKAGE_MOD=y
FREETZ_PACKAGE_MOD_ETCSERVICES=y
FREETZ_PACKAGE_MODCGI=y
# FREETZ_PACKAGE_MODULE_INIT_TOOLS is not set
# FREETZ_PACKAGE_MTR is not set
# FREETZ_PACKAGE_NAGIOS is not set
FREETZ_PACKAGE_NANO=y
# Nano additional features
FREETZ_PACKAGE_NANO_TINY=y
# FREETZ_PACKAGE_NANO_MULTIBUFFER is not set
# FREETZ_PACKAGE_NANO_NANORC is not set
# FREETZ_PACKAGE_NANO_COLOR_SYNTAX is not set
# FREETZ_PACKAGE_NC6 is not set
# FREETZ_PACKAGE_NCFTP is not set
# FREETZ_PACKAGE_NDAS is not set
# FREETZ_PACKAGE_NETATALK is not set
# FREETZ_PACKAGE_NETCAT is not set
# FREETZ_PACKAGE_NETPBM is not set
# FREETZ_PACKAGE_NETSNMP is not set
# NFS-root (not available, needs replace kernel)
# FREETZ_PACKAGE_NFS_UTILS is not set
# FREETZ_PACKAGE_NGIRCD is not set
# FREETZ_PACKAGE_NMAP is not set
# FREETZ_PACKAGE_NOIP is not set
# FREETZ_PACKAGE_NTFS is not set
# FREETZ_PACKAGE_NZBGET is not set
# FREETZ_PACKAGE_OBEXFTP is not set
# FREETZ_PACKAGE_OIDENTD is not set
# FREETZ_PACKAGE_OPENCONNECT is not set
# FREETZ_PACKAGE_OPENDD is not set
# FREETZ_PACKAGE_OPENNTPD is not set
# OpenSSH
FREETZ_PACKAGE_OPENSSH=y
FREETZ_PACKAGE_OPENSSH_sshd=y
# FREETZ_PACKAGE_OPENSSH_ssh is not set
# FREETZ_PACKAGE_OPENSSH_scp is not set
# FREETZ_PACKAGE_OPENSSH_CLIENTUTILS is not set
# FREETZ_PACKAGE_OPENSSH_KEYUTILS is not set
# FREETZ_PACKAGE_OPENSSH_sftp is not set
FREETZ_PACKAGE_OPENSSH_sftp_server=y
# OpenSSH configuration ---
# FREETZ_PACKAGE_OPENSSH_INTERNAL_CRYPTO is not set
# FREETZ_PACKAGE_OPENSSH_STATIC is not set
FREETZ_PACKAGE_OPENSSL=y
# FREETZ_PACKAGE_OPENSSL_TRACE is not set
FREETZ_PACKAGE_OPENVPN=y
FREETZ_PACKAGE_OPENVPN_VERSION_2_3=y
# FREETZ_PACKAGE_OPENVPN_VERSION_2_4 is not set
FREETZ_PACKAGE_OPENVPN_OPENSSL=y
# FREETZ_PACKAGE_OPENVPN_POLARSSL is not set
FREETZ_PACKAGE_OPENVPN_WITH_BLOWFISH=y
# FREETZ_PACKAGE_OPENVPN_STATIC is not set
FREETZ_PACKAGE_OPENVPN_WITH_LZO=y
# FREETZ_PACKAGE_OPENVPN_WITH_TRAFFIC_OBFUSCATION is not set
# FREETZ_PACKAGE_OPENVPN_WITH_MGMNT is not set
FREETZ_PACKAGE_OPENVPN_ENABLE_SMALL=y
# FREETZ_PACKAGE_OPENVPN_USE_IPROUTE is not set
# FREETZ_PACKAGE_OPENVPN_USE_V2_CGI is not set
# FREETZ_PACKAGE_OWFS is not set
# FREETZ_PACKAGE_PCSC_LITE is not set
# FREETZ_PACKAGE_PHONEBOOK_TOOLS is not set
# FREETZ_PACKAGE_PHP is not set
# FREETZ_PACKAGE_PINGTUNNEL is not set
# FREETZ_PACKAGE_POLIPO is not set
# FREETZ_PACKAGE_PORTMAP is not set
# FREETZ_PACKAGE_PPP is not set
FREETZ_BOX_CERTIFICATE_SUPPORT_AVAILABLE=y
# FREETZ_PACKAGE_PRIVATEKEYPASSWORD is not set
# FREETZ_PACKAGE_PRIVOXY is not set
# FREETZ_PACKAGE_PYLOAD is not set
# FREETZ_PACKAGE_PYTHON is not set
# FREETZ_PACKAGE_QUAGGA is not set
# FREETZ_PACKAGE_RADVD is not set
# FREETZ_PACKAGE_RCAPID is not set
# FREETZ_PACKAGE_RIPMIME is not set
# FREETZ_PACKAGE_RRDTOOL is not set
# FREETZ_PACKAGE_RSYNC is not set
# FREETZ_PACKAGE_RTMPDUMP is not set
# FREETZ_PACKAGE_RUBY is not set
# FREETZ_PACKAGE_RUSH is not set
# FREETZ_PACKAGE_SABLEVM_SDK is not set
# FREETZ_PACKAGE_SAMBA is not set
FREETZ_PACKAGE_SCREEN=y
# FREETZ_PACKAGE_SER2NET is not set
# FREETZ_PACKAGE_SFK is not set
# FREETZ_PACKAGE_SHELLINABOX is not set
# FREETZ_PACKAGE_SIPROXD is not set
# FREETZ_PACKAGE_SISPMCTL is not set
# FREETZ_PACKAGE_SLANG is not set
# FREETZ_PACKAGE_SLURM is not set
# FREETZ_PACKAGE_SMARTMONTOOLS is not set
# FREETZ_PACKAGE_SMSTOOLS3 is not set
# FREETZ_PACKAGE_SMUSBUTIL is not set
# FREETZ_PACKAGE_SOCAT is not set
# FREETZ_PACKAGE_SPAWN_FCGI is not set
# FREETZ_PACKAGE_SQLITE is not set
# FREETZ_PACKAGE_SQUASHFS3 is not set
# FREETZ_PACKAGE_SQUASHFS4 is not set
# FREETZ_PACKAGE_SSHFS_FUSE is not set
# FREETZ_PACKAGE_SSLH is not set
# FREETZ_PACKAGE_STREAMRIPPER is not set
# FREETZ_PACKAGE_STUNNEL is not set
# FREETZ_PACKAGE_SUBVERSION is not set
# FREETZ_PACKAGE_SUDO is not set
# FREETZ_PACKAGE_SUNDTEK is not set
# FREETZ_PACKAGE_SYNCE_DCCM is not set
# FREETZ_PACKAGE_TCPDUMP is not set
# FREETZ_PACKAGE_TCPPROXY is not set
# FREETZ_PACKAGE_TCP_WRAPPERS is not set
# Tesseract OCR (not available, needs libstdc++ as Standard C++ Library)
# FREETZ_PACKAGE_TICHKSUM is not set
# FREETZ_PACKAGE_TIFF is not set
# FREETZ_PACKAGE_TINC is not set
# FREETZ_PACKAGE_TINYPROXY is not set
# FREETZ_PACKAGE_TMUX is not set
# FREETZ_PACKAGE_TOR is not set
# FREETZ_PACKAGE_TRANSMISSION is not set
# FREETZ_PACKAGE_TRANSMISSION_WITH_OPENSSL is not set
# FREETZ_PACKAGE_TRANSMISSION_WITH_POLARSSL is not set
# FREETZ_PACKAGE_TREE is not set
# FREETZ_PACKAGE_TRICKLE is not set
# FREETZ_PACKAGE_UDPXY is not set
# FREETZ_PACKAGE_UMURMUR is not set
# FREETZ_PACKAGE_UNFS3 is not set
# FREETZ_PACKAGE_UNRAR is not set
# FREETZ_PACKAGE_USBIDS is not set
# FREETZ_PACKAGE_UTIL_LINUX is not set
# FREETZ_PACKAGE_VIM is not set
# FREETZ_PACKAGE_VNSTAT is not set
# FREETZ_PACKAGE_VPNC is not set
# FREETZ_PACKAGE_VSFTPD is not set
# FREETZ_PACKAGE_VTUN is not set
FREETZ_WGET=y
# FREETZ_PACKAGE_WGET is not set
# FREETZ_PACKAGE_WOL is not set
# FREETZ_PACKAGE_WPUT is not set
# FREETZ_PACKAGE_XMAIL is not set
# FREETZ_PACKAGE_XPDF is not set
# FREETZ_PACKAGE_XRELAYD is not set
# FREETZ_PACKAGE_XSLTPROC is not set
# FREETZ_PACKAGE_XZ is not set
# Unstable
# FREETZ_PACKAGE_ASTERISK is not set
# FREETZ_PACKAGE_COLLECTD is not set
# FREETZ_PACKAGE_DTMFBOX is not set
# FREETZ_PACKAGE_GPTFDISK is not set
# FREETZ_PACKAGE_HPLIP is not set
# FREETZ_PACKAGE_HP_UTILS is not set
FREETZ_PACKAGE_IPTABLES=y
FREETZ_PACKAGE_IPTABLES_IS_SELECTABLE=y
# FREETZ_PACKAGE_IPTABLES_SAVE_RESTORE is not set
# FREETZ_PACKAGE_IPTABLES_STATIC is not set
# FREETZ_PACKAGE_IPTABLES_CGI is not set
# FREETZ_PACKAGE_NHIPT is not set
# FREETZ_PACKAGE_IPTABLES_STANDARD_MODULES is not set
FREETZ_PACKAGE_IPTABLES_KERNEL_MODULES=y
# Select kernel modules (IPv4)
FREETZ_MODULE_nf_conntrack=y
# FREETZ_MODULE_nf_conntrack_ftp is not set
# FREETZ_MODULE_nf_conntrack_h323 is not set
# FREETZ_MODULE_nf_conntrack_irc is not set
# FREETZ_MODULE_nf_conntrack_ipv4 is not set
# FREETZ_MODULE_nf_conntrack_pptp is not set
# FREETZ_MODULE_nf_conntrack_proto_gre is not set
# FREETZ_MODULE_nf_conntrack_tftp is not set
# FREETZ_MODULE_nf_defrag_ipv4 is not set
# FREETZ_MODULE_nf_nat is not set
# FREETZ_MODULE_nf_nat_ftp is not set
# FREETZ_MODULE_nf_nat_h323 is not set
# FREETZ_MODULE_nf_nat_irc is not set
# FREETZ_MODULE_nf_nat_pptp is not set
# FREETZ_MODULE_nf_nat_tftp is not set
FREETZ_MODULE_iptable_filter=y
# FREETZ_MODULE_iptable_mangle is not set
FREETZ_MODULE_iptable_nat=y
# FREETZ_MODULE_iptable_raw is not set
FREETZ_MODULE_ip_tables=y
# FREETZ_MODULE_ipt_LOG is not set
FREETZ_MODULE_ipt_REJECT=y
# FREETZ_MODULE_ipt_ttl is not set
# FREETZ_MODULE_ipt_TTL is not set
# x_tables (both IPv4 and IPv6)
FREETZ_MODULE_x_tables=y
# FREETZ_MODULE_xt_CLASSIFY is not set
# FREETZ_MODULE_xt_comment is not set
# FREETZ_MODULE_xt_esp is not set
# FREETZ_MODULE_xt_length is not set
# FREETZ_MODULE_xt_limit is not set
# FREETZ_MODULE_xt_mac is not set
# FREETZ_MODULE_xt_multiport is not set
# FREETZ_MODULE_xt_mark is not set
# FREETZ_MODULE_xt_MARK is not set
# FREETZ_MODULE_xt_NFQUEUE is not set
# FREETZ_MODULE_xt_iprange is not set
# FREETZ_MODULE_xt_pkttype is not set
# FREETZ_MODULE_xt_physdev is not set
# FREETZ_MODULE_xt_quota is not set
# FREETZ_MODULE_xt_realm is not set
# FREETZ_MODULE_xt_statistic is not set
# FREETZ_MODULE_xt_string is not set
# FREETZ_MODULE_xt_tcpudp is not set
# FREETZ_MODULE_xt_tcpmss is not set
# FREETZ_MODULE_xt_time is not set
# Select kernel modules (IPv6)
# FREETZ_MODULE_ip6_queue is not set
# FREETZ_MODULE_ip6_tables is not set
# FREETZ_MODULE_nf_conntrack_ipv6 is not set
FREETZ_PACKAGE_IPTABLES_SHARED_LIBS=y
# Select shared libraries (IPv4)
# FREETZ_LIB_libipt_addrtype is not set
# FREETZ_LIB_libipt_ah is not set
# FREETZ_LIB_libipt_CLUSTERIP is not set
FREETZ_LIB_libipt_DNAT=y
# FREETZ_LIB_libipt_ecn is not set
# FREETZ_LIB_libipt_ECN is not set
# FREETZ_LIB_libipt_icmp is not set
# FREETZ_LIB_libipt_LOG is not set
FREETZ_LIB_libipt_MASQUERADE=y
# FREETZ_LIB_libipt_MIRROR is not set
# FREETZ_LIB_libipt_NETMAP is not set
# FREETZ_LIB_libipt_realm is not set
# FREETZ_LIB_libipt_REDIRECT is not set
# FREETZ_LIB_libipt_REJECT is not set
# FREETZ_LIB_libipt_SAME is not set
# FREETZ_LIB_libipt_SNAT is not set
# FREETZ_LIB_libipt_ttl is not set
# FREETZ_LIB_libipt_TTL is not set
# FREETZ_LIB_libipt_ULOG is not set
# FREETZ_LIB_libipt_unclean is not set
# Select shared libraries (both IPv4 and IPv6)
# FREETZ_LIB_libxt_CLASSIFY is not set
# FREETZ_LIB_libxt_comment is not set
# FREETZ_LIB_libxt_connbytes is not set
# FREETZ_LIB_libxt_connmark is not set
# FREETZ_LIB_libxt_CONNMARK is not set
# FREETZ_LIB_libxt_CONNSECMARK is not set
# FREETZ_LIB_libxt_conntrack is not set
# FREETZ_LIB_libxt_dscp is not set
# FREETZ_LIB_libxt_DSCP is not set
# FREETZ_LIB_libxt_esp is not set
# FREETZ_LIB_libxt_hashlimit is not set
# FREETZ_LIB_libxt_helper is not set
# FREETZ_LIB_libxt_iprange is not set
# FREETZ_LIB_libxt_length is not set
# FREETZ_LIB_libxt_limit is not set
# FREETZ_LIB_libxt_mac is not set
# FREETZ_LIB_libxt_mark is not set
# FREETZ_LIB_libxt_MARK is not set
# FREETZ_LIB_libxt_multiport is not set
# FREETZ_LIB_libxt_NFLOG is not set
# FREETZ_LIB_libxt_NFQUEUE is not set
# FREETZ_LIB_libxt_NOTRACK is not set
# FREETZ_LIB_libxt_owner is not set
# FREETZ_LIB_libxt_physdev is not set
# FREETZ_LIB_libxt_pkttype is not set
# FREETZ_LIB_libxt_quota is not set
# FREETZ_LIB_libxt_rateest is not set
# FREETZ_LIB_libxt_RATEEST is not set
# FREETZ_LIB_libxt_sctp is not set
# FREETZ_LIB_libxt_SECMARK is not set
# FREETZ_LIB_libxt_standard is not set
# FREETZ_LIB_libxt_state is not set
# FREETZ_LIB_libxt_statistic is not set
# FREETZ_LIB_libxt_string is not set
# FREETZ_LIB_libxt_tcpmss is not set
# FREETZ_LIB_libxt_TCPMSS is not set
# FREETZ_LIB_libxt_tcp is not set
# FREETZ_LIB_libxt_time is not set
# FREETZ_LIB_libxt_tos is not set
# FREETZ_LIB_libxt_TOS is not set
# FREETZ_LIB_libxt_TRACE is not set
# FREETZ_LIB_libxt_u32 is not set
# FREETZ_LIB_libxt_udp is not set
# Select shared libraries (IPv6)
# FREETZ_LIB_libip6t_ah is not set
# FREETZ_LIB_libip6t_dst is not set
# FREETZ_LIB_libip6t_eui64 is not set
# FREETZ_LIB_libip6t_frag is not set
# FREETZ_LIB_libip6t_hbh is not set
# FREETZ_LIB_libip6t_hl is not set
# FREETZ_LIB_libip6t_HL is not set
# FREETZ_LIB_libip6t_icmp6 is not set
# FREETZ_LIB_libip6t_ipv6header is not set
# FREETZ_LIB_libip6t_LOG is not set
# FREETZ_LIB_libip6t_mh is not set
# FREETZ_LIB_libip6t_REJECT is not set
# FREETZ_LIB_libip6t_rt is not set
# FREETZ_PACKAGE_MINI_FO is not set
# SANE
# FREETZ_PACKAGE_SANE_BACKENDS is not set
# SCANBUTTOND
# FREETZ_PACKAGE_SCANBUTTOND is not set
# FREETZ_PACKAGE_SQUID is not set
# truecrypt (not available, needs libstdc++ as the Standard C++ Library)
# FREETZ_PACKAGE_USBIP is not set
# FREETZ_PACKAGE_VIRTUALIP_CGI is not set
# FREETZ_PACKAGE_ZABBIX is not set
# Web interfaces
FREETZ_PACKAGE_AUTHORIZED_KEYS=y
# FREETZ_PACKAGE_AVM_FORWARDING is not set
# FREETZ_PACKAGE_DNSD_CGI is not set
# FREETZ_PACKAGE_DOWNLOADER is not set
# FREETZ_PACKAGE_NFSD_CGI is not set
# FREETZ_PACKAGE_ONLINECHANGED_CGI is not set
FREETZ_PACKAGE_OPENVPN_CGI=y
# FREETZ_PACKAGE_PHPXMAIL is not set
# FREETZ_PACKAGE_RRDSTATS is not set
# FREETZ_PACKAGE_SPINDOWN_CGI is not set
FREETZ_PACKAGE_SYSLOGD_CGI=y
# FREETZ_PACKAGE_TRANSMISSION_CGI is not set
# FREETZ_PACKAGE_VNSTAT_CGI is not set
# FREETZ_PACKAGE_WOL_CGI is not set
# Shared libraries
# Apache Portable Runtime libs
# FREETZ_LIB_libapr is not set
# FREETZ_LIB_libapr_WITH_DSO is not set
# FREETZ_LIB_libaprutil is not set
# FREETZ_LIB_libaprutil_WITH_LIBDB is not set
# Avahi libraries
# FREETZ_LIB_libavahi_common is not set
# FREETZ_LIB_libavahi_core is not set
# FREETZ_LIB_libavahi_client is not set
# C++
# FREETZ_LIB_STDCXXLIB is not set
# FREETZ_LIB_STDCXXLIB_WITH_WCHAR is not set
# FREETZ_LIB_libstdc__ is not set
# FREETZ_LIB_libuClibc__ is not set
# FREETZ_LIB_libuClibc__WITH_WCHAR is not set
# Charsets & Internationalization
# FREETZ_LIB_libiconv is not set
# FREETZ_LIB_libintl is not set
# Crypto & SSL
# GnuPG ----------------------------------
# FREETZ_LIB_libgpg_error is not set
# FREETZ_LIB_libgcrypt is not set
# Digests ---
# FREETZ_LIB_libgcrypt_WITH_DIGEST_crc is not set
# FREETZ_LIB_libgcrypt_WITH_DIGEST_gostr3411_94 is not set
# FREETZ_LIB_libgcrypt_WITH_DIGEST_md4 is not set
# FREETZ_LIB_libgcrypt_WITH_DIGEST_md5 is not set
# FREETZ_LIB_libgcrypt_WITH_DIGEST_rmd160 is not set
# FREETZ_LIB_libgcrypt_WITH_DIGEST_sha1 is not set
# FREETZ_LIB_libgcrypt_WITH_DIGEST_sha256 is not set
# FREETZ_LIB_libgcrypt_WITH_DIGEST_sha512 is not set
# FREETZ_LIB_libgcrypt_WITH_DIGEST_stribog is not set
# FREETZ_LIB_libgcrypt_WITH_DIGEST_tiger is not set
# FREETZ_LIB_libgcrypt_WITH_DIGEST_whirlpool is not set
# Symmetric ciphers ---
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_aes is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_arcfour is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_blowfish is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_camellia is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_cast5 is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_des is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_gost28147 is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_idea is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_rfc2268 is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_salsa20 is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_seed is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_serpent is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_twofish is not set
# Asymmetric ciphers ---
# FREETZ_LIB_libgcrypt_WITH_ASYMMETRIC_CIPHER_dsa is not set
# FREETZ_LIB_libgcrypt_WITH_ASYMMETRIC_CIPHER_ecc is not set
# FREETZ_LIB_libgcrypt_WITH_ASYMMETRIC_CIPHER_elgamal is not set
# FREETZ_LIB_libgcrypt_WITH_ASYMMETRIC_CIPHER_rsa is not set
# GnuTLS ---------------------------------
# FREETZ_LIB_libgnutls is not set
# FREETZ_LIB_libtasn1 is not set
# mbed TLS -------------------------------
# FREETZ_LIB_libmbedcrypto is not set
# FREETZ_LIB_libmbedcrypto_WITH_BLOWFISH is not set
# FREETZ_LIB_libmbedcrypto_WITH_GENRSA is not set
# FREETZ_LIB_libmbedtls is not set
# FREETZ_LIB_libmbedx509 is not set
# Nettle ---------------------------------
# FREETZ_LIB_libnettle is not set
# FREETZ_LIB_libhogweed is not set
# OpenSSL --------------------------------
FREETZ_LIB_libcrypto=y
FREETZ_LIB_libssl=y
FREETZ_OPENSSL_VERSION_PROMPT=y
FREETZ_OPENSSL_VERSION_1_REQUIRED=y
# FREETZ_OPENSSL_VERSION_0 is not set
FREETZ_OPENSSL_VERSION_1=y
FREETZ_OPENSSL_SHLIB_VERSION="1.0.0"
# OpenSSL configuration
# FREETZ_LIB_libcrypto_WITH_EC is not set
# FREETZ_LIB_libcrypto_WITH_RC4 is not set
FREETZ_OPENSSL_SMALL_FOOTPRINT=y
FREETZ_OPENSSL_CONFIG_DIR="/mod/etc/ssl"
# PolarSSL -------------------------------
# FREETZ_LIB_libpolarssl12 is not set
# FREETZ_LIB_libpolarssl12_WITH_BLOWFISH is not set
# FREETZ_LIB_libpolarssl12_WITH_GENRSA is not set
# FREETZ_LIB_libpolarssl13 is not set
# FREETZ_LIB_libpolarssl13_WITH_BLOWFISH is not set
# FREETZ_LIB_libpolarssl13_WITH_GENRSA is not set
# Data compression
# FREETZ_LIB_liblz4 is not set
# FREETZ_LIB_liblzma is not set
FREETZ_LIB_liblzo2=y
FREETZ_LIB_libz=y
# Database
# FREETZ_LIB_libdb is not set
# FREETZ_LIB_libsqlite3 is not set
# File systems
# e2fsprogs libraries
# FREETZ_LIB_libblkid is not set
# FREETZ_LIB_libcom_err is not set
# FREETZ_LIB_libe2p is not set
# FREETZ_LIB_libext2fs is not set
# FREETZ_LIB_libss is not set
# FREETZ_LIB_libuuid is not set
# FREETZ_LIB_libfuse is not set
# FREETZ_LIB_libntfs is not set
# GLib
# FREETZ_LIB_libglib_2 is not set
# FREETZ_LIB_libgio_2 is not set
# FREETZ_LIB_libgobject_2 is not set
# FREETZ_LIB_libgmodule_2 is not set
# FREETZ_LIB_libgthread_2 is not set
# Graphics & fonts
# FREETZ_LIB_libfreetype is not set
# FREETZ_LIB_libart_lgpl_2 is not set
# FREETZ_LIB_libexif is not set
# FREETZ_LIB_libjpeg is not set
# FREETZ_LIB_liblept is not set
# FREETZ_LIB_libpng12 is not set
# FREETZ_LIB_libgd is not set
# FREETZ_LIB_libopenjpeg is not set
# FREETZ_LIB_libtiff is not set
# FREETZ_LIB_libtiffxx is not set
# FREETZ_LIB_libnetpbm is not set
# Multi precision arithmetic libs
# FREETZ_LIB_libgmp is not set
# FREETZ_LIB_libmpfr is not set
# FREETZ_LIB_libmpc is not set
# Multimedia
# Audio and video codecs
# Audio codecs
# FREETZ_LIB_libFLAC is not set
# FREETZ_LIB_libmad is not set
# FREETZ_LIB_libogg is not set
# FREETZ_LIB_libopus is not set
# FREETZ_LIB_libspeex is not set
# FREETZ_LIB_libspeexdsp is not set
# FFmpeg libraries
# FREETZ_LIB_libavcodec is not set
# FREETZ_LIB_libavdevice is not set
# FREETZ_LIB_libavfilter is not set
# FREETZ_LIB_libavformat is not set
# FREETZ_LIB_libavutil is not set
# FREETZ_LIB_libpostproc is not set
# FREETZ_LIB_libswresample is not set
# FREETZ_LIB_libswscale is not set
# Video codecs
# Vorbis video codec ---------------------
# FREETZ_LIB_libvorbis is not set
# FREETZ_LIB_libvorbisenc is not set
# FREETZ_LIB_libvorbisfile is not set
# ID3 tag reading libs
# FREETZ_LIB_libid3tag is not set
# FREETZ_LIB_libtag is not set
# ncurses
FREETZ_LIB_libncurses=y
# terminfo database
# Select terminfo database entries to install (see help of 'Show all items')
FREETZ_SHARE_terminfo=y
# FREETZ_SHARE_terminfo_showall is not set
FREETZ_SHARE_terminfo_ansi=y
FREETZ_SHARE_terminfo_gnome=y
FREETZ_SHARE_terminfo_konsole=y
FREETZ_SHARE_terminfo_linux=y
FREETZ_SHARE_terminfo_putty=y
FREETZ_SHARE_terminfo_rxvt=y
FREETZ_SHARE_terminfo_screen=y
FREETZ_SHARE_terminfo_screenMINUSw=y
FREETZ_SHARE_terminfo_sun=y
FREETZ_SHARE_terminfo_vt100=y
FREETZ_SHARE_terminfo_vt102=y
FREETZ_SHARE_terminfo_vt102MINUSnsgr=y
FREETZ_SHARE_terminfo_vt102MINUSw=y
FREETZ_SHARE_terminfo_vt200=y
FREETZ_SHARE_terminfo_vt220=y
FREETZ_SHARE_terminfo_vt52=y
FREETZ_SHARE_terminfo_xterm=y
FREETZ_SHARE_terminfo_xtermMINUS256color=y
FREETZ_SHARE_terminfo_xtermMINUScolor=y
FREETZ_SHARE_terminfo_xtermMINUSxfree86=y
# FREETZ_LIB_libform is not set
# FREETZ_LIB_libmenu is not set
# FREETZ_LIB_libpanel is not set
# Networking
# ATM ------------------------------------
# FREETZ_LIB_libatm is not set
# Bluetooth ------------------------------
# FREETZ_LIB_libbluetooth is not set
# FREETZ_LIB_libopenobex is not set
# ISDN & CAPI ----------------------------
# FREETZ_LIB_libcapi20 is not set
# Misc networking ------------------------
# FREETZ_LIB_libdnet is not set
# FREETZ_LIB_libgsm is not set
# FREETZ_LIB_libiksemel is not set
# FREETZ_LIB_libpcap is not set
# FREETZ_LIB_libnet is not set
# FREETZ_LIB_liboping is not set
# FREETZ_LIB_libosip2 is not set
# FREETZ_LIB_libosipparser2 is not set
# FREETZ_LIB_libspandsp is not set
# FREETZ_LIB_libsrtp is not set
# PJ Project
# FREETZ_LIB_libpj is not set
# FREETZ_LIB_libpjlib_util is not set
# FREETZ_LIB_libpjmedia is not set
# FREETZ_LIB_libpjmedia_audiodev is not set
# FREETZ_LIB_libpjmedia_codec is not set
# FREETZ_LIB_libpjmedia_videodev is not set
# FREETZ_LIB_libpjnath is not set
# FREETZ_LIB_libpjsip is not set
# FREETZ_LIB_libpjsip_simple is not set
# FREETZ_LIB_libpjsip_ua is not set
# FREETZ_LIB_libpjsua is not set
# 3rdparty libraries
# FREETZ_LIB_libg7221codec is not set
# FREETZ_LIB_libilbccodec is not set
# FREETZ_LIB_libmilenage is not set
# Readline
FREETZ_LIB_libreadline=y
# FREETZ_LIB_libhistory is not set
# Regular expressions
# FREETZ_LIB_libpcre is not set
# FREETZ_LIB_libpcreposix is not set
# uClibc
FREETZ_LIB_ld_uClibc=y
FREETZ_LIB_libcrypt=y
FREETZ_LIB_libdl=y
FREETZ_LIB_libm=y
FREETZ_LIB_libpthread=y
FREETZ_LIB_librt=y
FREETZ_LIB_libthread_db=y
FREETZ_LIB_libubacktrace=y
FREETZ_LIB_libuClibc=y
FREETZ_LIB_libutil=y
# USB & FTDI
# FREETZ_LIB_libusb_0 is not set
# FREETZ_LIB_libusb_1 is not set
# FREETZ_LIB_libftdi is not set
# Web and WebDAV
FREETZ_LIB_libcurl=y
FREETZ_LIB_libcurl_WITH_SSL=y
FREETZ_LIB_libcurl_WITH_OPENSSL=y
# FREETZ_LIB_libcurl_WITH_POLARSSL is not set
# FREETZ_LIB_libcurl_WITH_MBEDTLS is not set
# FREETZ_LIB_libcurl_WITH_ZLIB is not set
# FREETZ_LIB_libjansson is not set
# FREETZ_LIB_libjs is not set
# FREETZ_LIB_libneon is not set
# FREETZ_LIB_libneon_WITH_SSL is not set
# FREETZ_LIB_libneon_WITH_ZLIB is not set
# FREETZ_LIB_libserf is not set
# XML & XSLT
# FREETZ_LIB_libexpat is not set
# FREETZ_LIB_libxml2 is not set
# FREETZ_LIB_libxml2_WITH_HTML is not set
# FREETZ_LIB_libxslt is not set
# FREETZ_LIB_libexslt is not set
# FREETZ_LIB_libattr is not set
# FREETZ_LIB_libcap is not set
# FREETZ_LIB_libdbus is not set
FREETZ_LIB_libgcc_s=y
# FREETZ_LIB_libconfig is not set
# FREETZ_LIB_libdaemon is not set
# FREETZ_LIB_libdevmapper is not set
FREETZ_LIB_libelf=y
# FREETZ_LIB_libev is not set
# FREETZ_LIB_libevent is not set
# FREETZ_LIB_libffi is not set
# FREETZ_LIB_libfakefile is not set
FREETZ_LIB_libmultid=y
FREETZ_LIB_libmultid_WITH_ANYIP=y
FREETZ_LIB_libmultid_WITH_DNS=y
FREETZ_LIB_libmultid_WITH_DHCP=y
FREETZ_LIB_libmultid_WITH_LLMNR=y
# FREETZ_LIB_libltdl is not set
# FREETZ_LIB_liblua is not set
# FREETZ_LIB_libpcsclite is not set
# FREETZ_LIB_libpopt is not set
# FREETZ_LIB_libprivatekeypassword is not set
# FREETZ_LIB_libprotobuf_c is not set
# FREETZ_LIB_librrd is not set
# FREETZ_LIB_librrd_th is not set
# FREETZ_LIB_libslang is not set
# FREETZ_LIB_libsynce is not set
# FREETZ_LIB_libsysfs is not set
# FREETZ_LIB_libwx_baseu is not set
# FREETZ_LIB_libyaml is not set
# Kernel modules
# block
# ndas
# FREETZ_MODULE_ndas_block is not set
# FREETZ_MODULE_ndas_core is not set
# FREETZ_MODULE_ndas_sal is not set
# crypto
# FREETZ_MODULE_aes_generic is not set
# FREETZ_MODULE_arc4 is not set
# FREETZ_MODULE_crypto_algapi is not set
# FREETZ_MODULE_aead is not set
# FREETZ_MODULE_cbc is not set
# FREETZ_MODULE_crypto_blkcipher is not set
# FREETZ_MODULE_crypto_hash is not set
# FREETZ_MODULE_crypto_wq is not set
# FREETZ_MODULE_cryptomgr is not set
# FREETZ_MODULE_pcompress is not set
# FREETZ_MODULE_rng is not set
# FREETZ_MODULE_sha1_generic is not set
# FREETZ_MODULE_sha256_generic is not set
# drivers
# FREETZ_MODULE_loop is not set
# FREETZ_MODULE_nbd is not set
# FREETZ_MODULE_cdrom is not set
# FREETZ_MODULE_capiconn is not set
# FREETZ_MODULE_nand is not set
# FREETZ_MODULE_ohio_nand is not set
# FREETZ_MODULE_dummy is not set
# FREETZ_MODULE_ppp_async is not set
# FREETZ_MODULE_ppp_deflate is not set
# FREETZ_MODULE_ppp_generic is not set
# FREETZ_MODULE_pppoe is not set
# FREETZ_MODULE_pppox is not set
# FREETZ_MODULE_ppp_mppe_mppc is not set
# FREETZ_MODULE_scsi_mod is not set
# FREETZ_MODULE_sd_mod is not set
# FREETZ_MODULE_sg is not set
# FREETZ_MODULE_sr_mod is not set
# FREETZ_MODULE_slhc is not set
# FREETZ_MODULE_usblp is not set
# FREETZ_MODULE_usb_storage is not set
# FREETZ_MODULE_usbmon is not set
# FREETZ_MODULE_usbip is not set
# FREETZ_MODULE_usbip_common_mod is not set
# FREETZ_MODULE_usbserial is not set
# FREETZ_MODULE_ipaq is not set
# FREETZ_MODULE_cp210x is not set
# FREETZ_MODULE_pl2303 is not set
# FREETZ_MODULE_ftdi_sio is not set
# FREETZ_MODULE_bfusb is not set
# FREETZ_MODULE_btusb is not set
# FREETZ_MODULE_firmware_class is not set
# FREETZ_MODULE_dm_mod is not set
# FREETZ_MODULE_dm_crypt is not set
# FREETZ_MODULE_option is not set
# fs
# FREETZ_MODULE_autofs4 is not set
# FREETZ_MODULE_coda is not set
# FREETZ_MODULE_fat is not set
# FREETZ_MODULE_hfs is not set
# FREETZ_MODULE_hfsplus is not set
# FREETZ_MODULE_fuse is not set
# FREETZ_MODULE_iso9660 is not set
# FREETZ_MODULE_jbd2 is not set
# FREETZ_MODULE_lockd is not set
# FREETZ_MODULE_mini_fo is not set
# FREETZ_MODULE_minix is not set
# FREETZ_MODULE_nfsd is not set
# FREETZ_MODULE_exportfs is not set
# FREETZ_MODULE_nfs is not set
# FREETZ_MODULE_nls_cp437 is not set
# FREETZ_MODULE_nls_iso8859_1 is not set
# FREETZ_MODULE_nls_iso8859_15 is not set
# FREETZ_MODULE_reiserfs is not set
# FREETZ_MODULE_udf is not set
# FREETZ_MODULE_unionfs is not set
# FREETZ_MODULE_vfat is not set
# FREETZ_MODULE_msdos is not set
# FREETZ_MODULE_jffs2 is not set
# FREETZ_MODULE_mbcache is not set
# lib
# FREETZ_MODULE_crc16 is not set
# FREETZ_MODULE_crc_ccitt is not set
# FREETZ_MODULE_lzo_compress is not set
# FREETZ_MODULE_lzo_decompress is not set
# net
# FREETZ_MODULE_bluetooth is not set
# FREETZ_MODULE_bnep is not set
# FREETZ_MODULE_cls_u32 is not set
# FREETZ_MODULE_l2cap is not set
# network scheduler
# FREETZ_MODULE_sch_cbq is not set
# FREETZ_MODULE_sch_htb is not set
# FREETZ_MODULE_sch_llq is not set
# FREETZ_MODULE_sch_sfq is not set
# FREETZ_MODULE_sch_tbf is not set
# FREETZ_MODULE_rfcomm is not set
# FREETZ_MODULE_sunrpc is not set
# Busybox applets
FREETZ_BUSYBOX__MANDATORY=y
FREETZ_BUSYBOX__MANDATORY_05_XX=y
FREETZ_BUSYBOX__IPV6_UTILS=y
# FREETZ_BUSYBOX__PACKER is not set
FREETZ_BUSYBOX__NETWORK=y
# FREETZ_BUSYBOX__TERMINAL is not set
FREETZ_BUSYBOX__DEVELOPER=y
FREETZ_BUSYBOX_HAVE_DOT_CONFIG=y
# Busybox Settings
# General Configuration
# FREETZ_BUSYBOX_EXTRA_COMPAT is not set
# FREETZ_BUSYBOX_INCLUDE_SUSv2 is not set
# FREETZ_BUSYBOX_USE_PORTABLE_CODE is not set
FREETZ_BUSYBOX_PLATFORM_LINUX=y
# FREETZ_BUSYBOX_FEATURE_BUFFERS_USE_MALLOC is not set
FREETZ_BUSYBOX_FEATURE_BUFFERS_GO_ON_STACK=y
# FREETZ_BUSYBOX_FEATURE_BUFFERS_GO_IN_BSS is not set
FREETZ_BUSYBOX_SHOW_USAGE=y
FREETZ_BUSYBOX_FEATURE_VERBOSE_USAGE=y
# FREETZ_BUSYBOX_FEATURE_COMPRESS_USAGE is not set
# FREETZ_BUSYBOX_FEATURE_INSTALLER is not set
# FREETZ_BUSYBOX_INSTALL_NO_USR is not set
# FREETZ_BUSYBOX_LOCALE_SUPPORT is not set
# FREETZ_BUSYBOX_UNICODE_SUPPORT is not set
# FREETZ_BUSYBOX_PAM is not set
# FREETZ_BUSYBOX_LONG_OPTS is not set
FREETZ_BUSYBOX_FEATURE_DEVPTS=y
# FREETZ_BUSYBOX_FEATURE_CLEAN_UP is not set
# FREETZ_BUSYBOX_FEATURE_UTMP is not set
FREETZ_BUSYBOX_FEATURE_PIDFILE=y
FREETZ_BUSYBOX_PID_FILE_PATH="/var/run"
FREETZ_BUSYBOX_FEATURE_SUID=y
# FREETZ_BUSYBOX_FEATURE_SUID_CONFIG is not set
# FREETZ_BUSYBOX_SELINUX is not set
FREETZ_BUSYBOX_FEATURE_PREFER_APPLETS=y
FREETZ_BUSYBOX_BUSYBOX_EXEC_PATH="/bin/busybox"
FREETZ_BUSYBOX_FEATURE_SYSLOG=y
FREETZ_BUSYBOX_FEATURE_HAVE_RPC=y
# Build Options
# FREETZ_BUSYBOX_STATIC is not set
# FREETZ_BUSYBOX_PIE is not set
# FREETZ_BUSYBOX_NOMMU is not set
FREETZ_BUSYBOX_LFS=y
FREETZ_BUSYBOX_CROSS_COMPILER_PREFIX=""
FREETZ_BUSYBOX_SYSROOT=""
FREETZ_BUSYBOX_EXTRA_CFLAGS=""
FREETZ_BUSYBOX_EXTRA_LDFLAGS=""
FREETZ_BUSYBOX_EXTRA_LDLIBS=""
# Debugging Options
# FREETZ_BUSYBOX_DEBUG is not set
# FREETZ_BUSYBOX_UNIT_TEST is not set
# FREETZ_BUSYBOX_WERROR is not set
FREETZ_BUSYBOX_NO_DEBUG_LIB=y
# FREETZ_BUSYBOX_DMALLOC is not set
# FREETZ_BUSYBOX_EFENCE is not set
# Installation Options ("make install" behavior)
FREETZ_BUSYBOX_INSTALL_APPLET_SYMLINKS=y
# FREETZ_BUSYBOX_INSTALL_APPLET_HARDLINKS is not set
# FREETZ_BUSYBOX_INSTALL_APPLET_SCRIPT_WRAPPERS is not set
# FREETZ_BUSYBOX_INSTALL_APPLET_DONT is not set
FREETZ_BUSYBOX_PREFIX="./_install"
# Busybox Library Tuning
# FREETZ_BUSYBOX_FEATURE_SYSTEMD is not set
# FREETZ_BUSYBOX_FEATURE_RTMINMAX is not set
FREETZ_BUSYBOX_PASSWORD_MINLEN=6
FREETZ_BUSYBOX_MD5_SMALL=1
FREETZ_BUSYBOX_SHA3_SMALL=1
# FREETZ_BUSYBOX_FEATURE_FAST_TOP is not set
# FREETZ_BUSYBOX_FEATURE_ETC_NETWORKS is not set
FREETZ_BUSYBOX_FEATURE_USE_TERMIOS=y
FREETZ_BUSYBOX_FEATURE_EDITING=y
FREETZ_BUSYBOX_FEATURE_EDITING_MAX_LEN=1024
# FREETZ_BUSYBOX_FEATURE_EDITING_VI is not set
FREETZ_BUSYBOX_FEATURE_EDITING_HISTORY=255
# FREETZ_BUSYBOX_FEATURE_EDITING_SAVEHISTORY is not set
FREETZ_BUSYBOX_FEATURE_TAB_COMPLETION=y
# FREETZ_BUSYBOX_FEATURE_USERNAME_COMPLETION is not set
FREETZ_BUSYBOX_FEATURE_EDITING_FANCY_PROMPT=y
# FREETZ_BUSYBOX_FEATURE_EDITING_ASK_TERMINAL is not set
FREETZ_BUSYBOX_FEATURE_NON_POSIX_CP=y
# FREETZ_BUSYBOX_FEATURE_VERBOSE_CP_MESSAGE is not set
FREETZ_BUSYBOX_FEATURE_COPYBUF_KB=64
FREETZ_BUSYBOX_FEATURE_SKIP_ROOTFS=y
FREETZ_BUSYBOX_MONOTONIC_SYSCALL=y
FREETZ_BUSYBOX_IOCTL_HEX2STR_ERROR=y
FREETZ_BUSYBOX_FEATURE_HWIB=y
# Applets
# Archival Utilities
# FREETZ_BUSYBOX_FEATURE_SEAMLESS_XZ is not set
# FREETZ_BUSYBOX_FEATURE_SEAMLESS_LZMA is not set
# FREETZ_BUSYBOX_FEATURE_SEAMLESS_BZ2 is not set
FREETZ_BUSYBOX_FEATURE_SEAMLESS_GZ=y
# FREETZ_BUSYBOX_FEATURE_SEAMLESS_Z is not set
# FREETZ_BUSYBOX_AR is not set
# FREETZ_BUSYBOX_UNCOMPRESS is not set
FREETZ_BUSYBOX_GUNZIP=y
FREETZ_BUSYBOX_BUNZIP2=y
# FREETZ_BUSYBOX_UNLZMA is not set
FREETZ_BUSYBOX_UNXZ=y
FREETZ_BUSYBOX_XZ=y
FREETZ_BUSYBOX_BZIP2=y
# FREETZ_BUSYBOX_CPIO is not set
# FREETZ_BUSYBOX_DPKG is not set
# FREETZ_BUSYBOX_DPKG_DEB is not set
FREETZ_BUSYBOX_GZIP=y
FREETZ_BUSYBOX_GZIP_FAST=0
# FREETZ_BUSYBOX_FEATURE_GZIP_LEVELS is not set
# FREETZ_BUSYBOX_LZOP is not set
# FREETZ_BUSYBOX_RPM2CPIO is not set
# FREETZ_BUSYBOX_RPM is not set
FREETZ_BUSYBOX_TAR=y
FREETZ_BUSYBOX_FEATURE_TAR_CREATE=y
# FREETZ_BUSYBOX_FEATURE_TAR_AUTODETECT is not set
FREETZ_BUSYBOX_FEATURE_TAR_FROM=y
FREETZ_BUSYBOX_FEATURE_TAR_OLDGNU_COMPATIBILITY=y
# FREETZ_BUSYBOX_FEATURE_TAR_OLDSUN_COMPATIBILITY is not set
FREETZ_BUSYBOX_FEATURE_TAR_GNU_EXTENSIONS=y
# FREETZ_BUSYBOX_FEATURE_TAR_UNAME_GNAME is not set
# FREETZ_BUSYBOX_FEATURE_TAR_NOPRESERVE_TIME is not set
FREETZ_BUSYBOX_UNZIP=y
# Coreutils
FREETZ_BUSYBOX_BASENAME=y
FREETZ_BUSYBOX_CAT=y
FREETZ_BUSYBOX_DATE=y
FREETZ_BUSYBOX_FEATURE_DATE_ISOFMT=y
# FREETZ_BUSYBOX_FEATURE_DATE_NANO is not set
FREETZ_BUSYBOX_FEATURE_DATE_COMPAT=y
FREETZ_BUSYBOX_DD=y
FREETZ_BUSYBOX_FEATURE_DD_SIGNAL_HANDLING=y
# FREETZ_BUSYBOX_FEATURE_DD_THIRD_STATUS_LINE is not set
FREETZ_BUSYBOX_FEATURE_DD_IBS_OBS=y
# FREETZ_BUSYBOX_FEATURE_DD_STATUS is not set
# FREETZ_BUSYBOX_HOSTID is not set
FREETZ_BUSYBOX_ID=y
FREETZ_BUSYBOX_GROUPS=y
# FREETZ_BUSYBOX_SHUF is not set
FREETZ_BUSYBOX_SYNC=y
# FREETZ_BUSYBOX_FEATURE_SYNC_FANCY is not set
FREETZ_BUSYBOX_TEST=y
# FREETZ_BUSYBOX_FEATURE_TEST_64 is not set
FREETZ_BUSYBOX_TOUCH=y
# FREETZ_BUSYBOX_FEATURE_TOUCH_NODEREF is not set
FREETZ_BUSYBOX_FEATURE_TOUCH_SUSV3=y
FREETZ_BUSYBOX_TR=y
FREETZ_BUSYBOX_FEATURE_TR_CLASSES=y
FREETZ_BUSYBOX_FEATURE_TR_EQUIV=y
# FREETZ_BUSYBOX_TRUNCATE is not set
# FREETZ_BUSYBOX_UNLINK is not set
# FREETZ_BUSYBOX_BASE64 is not set
# FREETZ_BUSYBOX_CAL is not set
# FREETZ_BUSYBOX_CATV is not set
FREETZ_BUSYBOX_CHGRP=y
FREETZ_BUSYBOX_CHMOD=y
FREETZ_BUSYBOX_CHOWN=y
FREETZ_BUSYBOX_CHROOT=y
# FREETZ_BUSYBOX_CKSUM is not set
# FREETZ_BUSYBOX_COMM is not set
FREETZ_BUSYBOX_CP=y
FREETZ_BUSYBOX_CUT=y
FREETZ_BUSYBOX_DF=y
# FREETZ_BUSYBOX_FEATURE_DF_FANCY is not set
FREETZ_BUSYBOX_DIRNAME=y
FREETZ_BUSYBOX_DOS2UNIX=y
# FREETZ_BUSYBOX_UNIX2DOS is not set
FREETZ_BUSYBOX_DU=y
FREETZ_BUSYBOX_FEATURE_DU_DEFAULT_BLOCKSIZE_1K=y
FREETZ_BUSYBOX_ECHO=y
FREETZ_BUSYBOX_FEATURE_FANCY_ECHO=y
FREETZ_BUSYBOX_ENV=y
# FREETZ_BUSYBOX_EXPAND is not set
FREETZ_BUSYBOX_EXPR=y
# FREETZ_BUSYBOX_EXPR_MATH_SUPPORT_64 is not set
FREETZ_BUSYBOX_FALSE=y
# FREETZ_BUSYBOX_FOLD is not set
# FREETZ_BUSYBOX_FSYNC is not set
FREETZ_BUSYBOX_HEAD=y
FREETZ_BUSYBOX_FEATURE_FANCY_HEAD=y
# FREETZ_BUSYBOX_INSTALL is not set
FREETZ_BUSYBOX_LN=y
FREETZ_BUSYBOX_LOGNAME=y
FREETZ_BUSYBOX_LS=y
FREETZ_BUSYBOX_FEATURE_LS_FILETYPES=y
FREETZ_BUSYBOX_FEATURE_LS_FOLLOWLINKS=y
FREETZ_BUSYBOX_FEATURE_LS_RECURSIVE=y
FREETZ_BUSYBOX_FEATURE_LS_SORTFILES=y
FREETZ_BUSYBOX_FEATURE_LS_TIMESTAMPS=y
FREETZ_BUSYBOX_FEATURE_LS_USERNAME=y
FREETZ_BUSYBOX_MD5SUM=y
FREETZ_BUSYBOX_MKDIR=y
FREETZ_BUSYBOX_MKFIFO=y
FREETZ_BUSYBOX_MKNOD=y
FREETZ_BUSYBOX_MV=y
FREETZ_BUSYBOX_NICE=y
FREETZ_BUSYBOX_NOHUP=y
# FREETZ_BUSYBOX_OD is not set
FREETZ_BUSYBOX_PRINTENV=y
FREETZ_BUSYBOX_PRINTF=y
FREETZ_BUSYBOX_PWD=y
FREETZ_BUSYBOX_READLINK=y
FREETZ_BUSYBOX_FEATURE_READLINK_FOLLOW=y
FREETZ_BUSYBOX_REALPATH=y
FREETZ_BUSYBOX_RM=y
FREETZ_BUSYBOX_RMDIR=y
FREETZ_BUSYBOX_SEQ=y
# FREETZ_BUSYBOX_SHA1SUM is not set
# FREETZ_BUSYBOX_SHA256SUM is not set
# FREETZ_BUSYBOX_SHA512SUM is not set
# FREETZ_BUSYBOX_SHA3SUM is not set
FREETZ_BUSYBOX_SLEEP=y
FREETZ_BUSYBOX_FEATURE_FANCY_SLEEP=y
# FREETZ_BUSYBOX_FEATURE_FLOAT_SLEEP is not set
FREETZ_BUSYBOX_SORT=y
# FREETZ_BUSYBOX_FEATURE_SORT_BIG is not set
# FREETZ_BUSYBOX_SPLIT is not set
FREETZ_BUSYBOX_STAT=y
FREETZ_BUSYBOX_FEATURE_STAT_FORMAT=y
FREETZ_BUSYBOX_STTY=y
# FREETZ_BUSYBOX_SUM is not set
# FREETZ_BUSYBOX_TAC is not set
FREETZ_BUSYBOX_TAIL=y
FREETZ_BUSYBOX_FEATURE_FANCY_TAIL=y
FREETZ_BUSYBOX_TEE=y
FREETZ_BUSYBOX_FEATURE_TEE_USE_BLOCK_IO=y
FREETZ_BUSYBOX_TRUE=y
FREETZ_BUSYBOX_TTY=y
FREETZ_BUSYBOX_UNAME=y
FREETZ_BUSYBOX_UNAME_OSNAME="GNU/Linux"
# FREETZ_BUSYBOX_UNEXPAND is not set
FREETZ_BUSYBOX_UNIQ=y
# FREETZ_BUSYBOX_USLEEP is not set
FREETZ_BUSYBOX_UUDECODE=y
# FREETZ_BUSYBOX_UUENCODE is not set
FREETZ_BUSYBOX_WC=y
# FREETZ_BUSYBOX_FEATURE_WC_LARGE is not set
# FREETZ_BUSYBOX_WHOAMI is not set
FREETZ_BUSYBOX_YES=y
# Common options
# FREETZ_BUSYBOX_FEATURE_VERBOSE is not set
# Common options for cp and mv
# FREETZ_BUSYBOX_FEATURE_PRESERVE_HARDLINKS is not set
# Common options for ls, more and telnet
FREETZ_BUSYBOX_FEATURE_AUTOWIDTH=y
# Common options for df, du, ls
FREETZ_BUSYBOX_FEATURE_HUMAN_READABLE=y
# Common options for md5sum, sha1sum, sha256sum, sha512sum, sha3sum
FREETZ_BUSYBOX_FEATURE_MD5_SHA1_SUM_CHECK=y
# Console Utilities
# FREETZ_BUSYBOX_CHVT is not set
FREETZ_BUSYBOX_FGCONSOLE=y
# FREETZ_BUSYBOX_CLEAR is not set
# FREETZ_BUSYBOX_DEALLOCVT is not set
# FREETZ_BUSYBOX_DUMPKMAP is not set
# FREETZ_BUSYBOX_KBD_MODE is not set
# FREETZ_BUSYBOX_LOADFONT is not set
# FREETZ_BUSYBOX_LOADKMAP is not set
# FREETZ_BUSYBOX_OPENVT is not set
FREETZ_BUSYBOX_RESET=y
# FREETZ_BUSYBOX_RESIZE is not set
FREETZ_BUSYBOX_SETCONSOLE=y
# FREETZ_BUSYBOX_SETFONT is not set
# FREETZ_BUSYBOX_SETKEYCODES is not set
# FREETZ_BUSYBOX_SETLOGCONS is not set
# FREETZ_BUSYBOX_SHOWKEY is not set
# Debian Utilities
# FREETZ_BUSYBOX_MKTEMP is not set
# FREETZ_BUSYBOX_PIPE_PROGRESS is not set
# FREETZ_BUSYBOX_RUN_PARTS is not set
# FREETZ_BUSYBOX_START_STOP_DAEMON is not set
FREETZ_BUSYBOX_WHICH=y
# Editors
FREETZ_BUSYBOX_AWK=y
# FREETZ_BUSYBOX_FEATURE_AWK_LIBM is not set
# FREETZ_BUSYBOX_FEATURE_AWK_GNU_EXTENSIONS is not set
FREETZ_BUSYBOX_CMP=y
FREETZ_BUSYBOX_DIFF=y
FREETZ_BUSYBOX_FEATURE_DIFF_DIR=y
# FREETZ_BUSYBOX_ED is not set
FREETZ_BUSYBOX_PATCH=y
FREETZ_BUSYBOX_SED=y
FREETZ_BUSYBOX_VI=y
FREETZ_BUSYBOX_FEATURE_VI_MAX_LEN=1024
FREETZ_BUSYBOX_FEATURE_VI_8BIT=y
FREETZ_BUSYBOX_FEATURE_VI_COLON=y
FREETZ_BUSYBOX_FEATURE_VI_YANKMARK=y
FREETZ_BUSYBOX_FEATURE_VI_SEARCH=y
# FREETZ_BUSYBOX_FEATURE_VI_REGEX_SEARCH is not set
FREETZ_BUSYBOX_FEATURE_VI_USE_SIGNALS=y
FREETZ_BUSYBOX_FEATURE_VI_DOT_CMD=y
FREETZ_BUSYBOX_FEATURE_VI_READONLY=y
FREETZ_BUSYBOX_FEATURE_VI_SETOPTS=y
FREETZ_BUSYBOX_FEATURE_VI_SET=y
FREETZ_BUSYBOX_FEATURE_VI_WIN_RESIZE=y
FREETZ_BUSYBOX_FEATURE_VI_ASK_TERMINAL=y
# FREETZ_BUSYBOX_FEATURE_VI_UNDO is not set
FREETZ_BUSYBOX_FEATURE_ALLOW_EXEC=y
# Finding Utilities
FREETZ_BUSYBOX_FIND=y
FREETZ_BUSYBOX_FEATURE_FIND_PRINT0=y
FREETZ_BUSYBOX_FEATURE_FIND_MTIME=y
FREETZ_BUSYBOX_FEATURE_FIND_MMIN=y
FREETZ_BUSYBOX_FEATURE_FIND_PERM=y
FREETZ_BUSYBOX_FEATURE_FIND_TYPE=y
FREETZ_BUSYBOX_FEATURE_FIND_XDEV=y
FREETZ_BUSYBOX_FEATURE_FIND_MAXDEPTH=y
FREETZ_BUSYBOX_FEATURE_FIND_NEWER=y
FREETZ_BUSYBOX_FEATURE_FIND_INUM=y
FREETZ_BUSYBOX_FEATURE_FIND_EXEC=y
# FREETZ_BUSYBOX_FEATURE_FIND_EXEC_PLUS is not set
FREETZ_BUSYBOX_FEATURE_FIND_USER=y
FREETZ_BUSYBOX_FEATURE_FIND_GROUP=y
FREETZ_BUSYBOX_FEATURE_FIND_NOT=y
FREETZ_BUSYBOX_FEATURE_FIND_DEPTH=y
FREETZ_BUSYBOX_FEATURE_FIND_PAREN=y
FREETZ_BUSYBOX_FEATURE_FIND_SIZE=y
FREETZ_BUSYBOX_FEATURE_FIND_PRUNE=y
# FREETZ_BUSYBOX_FEATURE_FIND_DELETE is not set
FREETZ_BUSYBOX_FEATURE_FIND_PATH=y
FREETZ_BUSYBOX_FEATURE_FIND_REGEX=y
# FREETZ_BUSYBOX_FEATURE_FIND_LINKS is not set
FREETZ_BUSYBOX_GREP=y
FREETZ_BUSYBOX_FEATURE_GREP_EGREP_ALIAS=y
FREETZ_BUSYBOX_FEATURE_GREP_FGREP_ALIAS=y
FREETZ_BUSYBOX_FEATURE_GREP_CONTEXT=y
FREETZ_BUSYBOX_XARGS=y
FREETZ_BUSYBOX_FEATURE_XARGS_SUPPORT_CONFIRMATION=y
FREETZ_BUSYBOX_FEATURE_XARGS_SUPPORT_QUOTES=y
FREETZ_BUSYBOX_FEATURE_XARGS_SUPPORT_TERMOPT=y
FREETZ_BUSYBOX_FEATURE_XARGS_SUPPORT_ZERO_TERM=y
# FREETZ_BUSYBOX_FEATURE_XARGS_SUPPORT_REPL_STR is not set
# Init Utilities
# FREETZ_BUSYBOX_BOOTCHARTD is not set
FREETZ_BUSYBOX_HALT=y
FREETZ_BUSYBOX_INIT=y
FREETZ_BUSYBOX_FEATURE_USE_INITTAB=y
FREETZ_BUSYBOX_FEATURE_KILL_REMOVED=y
FREETZ_BUSYBOX_FEATURE_KILL_DELAY=0
# FREETZ_BUSYBOX_FEATURE_INIT_SCTTY is not set
FREETZ_BUSYBOX_FEATURE_INIT_SYSLOG=y
# FREETZ_BUSYBOX_FEATURE_EXTRA_QUIET is not set
# FREETZ_BUSYBOX_FEATURE_INIT_COREDUMPS is not set
# FREETZ_BUSYBOX_FEATURE_INITRD is not set
FREETZ_BUSYBOX_INIT_TERMINAL_TYPE="linux"
# FREETZ_BUSYBOX_MESG is not set
# Login/Password Management Utilities
# FREETZ_BUSYBOX_ADD_SHELL is not set
# FREETZ_BUSYBOX_REMOVE_SHELL is not set
FREETZ_BUSYBOX_FEATURE_SHADOWPASSWDS=y
# FREETZ_BUSYBOX_USE_BB_PWD_GRP is not set
FREETZ_BUSYBOX_USE_BB_CRYPT=y
# FREETZ_BUSYBOX_USE_BB_CRYPT_SHA is not set
FREETZ_BUSYBOX_ADDUSER=y
# FREETZ_BUSYBOX_FEATURE_CHECK_NAMES is not set
FREETZ_BUSYBOX_LAST_ID=60000
FREETZ_BUSYBOX_FIRST_SYSTEM_ID=100
FREETZ_BUSYBOX_LAST_SYSTEM_ID=999
FREETZ_BUSYBOX_ADDGROUP=y
FREETZ_BUSYBOX_FEATURE_ADDUSER_TO_GROUP=y
FREETZ_BUSYBOX_DELUSER=y
FREETZ_BUSYBOX_DELGROUP=y
FREETZ_BUSYBOX_FEATURE_DEL_USER_FROM_GROUP=y
# FREETZ_BUSYBOX_GETTY is not set
FREETZ_BUSYBOX_LOGIN=y
# FREETZ_BUSYBOX_LOGIN_SESSION_AS_CHILD is not set
# FREETZ_BUSYBOX_LOGIN_SCRIPTS is not set
# FREETZ_BUSYBOX_FEATURE_NOLOGIN is not set
# FREETZ_BUSYBOX_FEATURE_SECURETTY is not set
FREETZ_BUSYBOX_PASSWD=y
FREETZ_BUSYBOX_FEATURE_PASSWD_WEAK_CHECK=y
FREETZ_BUSYBOX_CRYPTPW=y
# FREETZ_BUSYBOX_CHPASSWD is not set
FREETZ_BUSYBOX_FEATURE_DEFAULT_PASSWD_ALGO="des"
# FREETZ_BUSYBOX_SU is not set
# FREETZ_BUSYBOX_SULOGIN is not set
# FREETZ_BUSYBOX_VLOCK is not set
# Linux Ext2 FS Progs
# FREETZ_BUSYBOX_CHATTR is not set
# FREETZ_BUSYBOX_FSCK is not set
# FREETZ_BUSYBOX_LSATTR is not set
# FREETZ_BUSYBOX_TUNE2FS is not set
# Linux Module Utilities
FREETZ_BUSYBOX_MODINFO=y
# FREETZ_BUSYBOX_MODPROBE_SMALL is not set
FREETZ_BUSYBOX_INSMOD=y
FREETZ_BUSYBOX_RMMOD=y
FREETZ_BUSYBOX_LSMOD=y
FREETZ_BUSYBOX_FEATURE_LSMOD_PRETTY_2_6_OUTPUT=y
FREETZ_BUSYBOX_MODPROBE=y
# FREETZ_BUSYBOX_FEATURE_MODPROBE_BLACKLIST is not set
# FREETZ_BUSYBOX_DEPMOD is not set
# Options common to multiple modutils
# FREETZ_BUSYBOX_FEATURE_2_4_MODULES is not set
# FREETZ_BUSYBOX_FEATURE_INSMOD_TRY_MMAP is not set
FREETZ_BUSYBOX_FEATURE_CHECK_TAINTED_MODULE=y
# FREETZ_BUSYBOX_FEATURE_MODUTILS_ALIAS is not set
# FREETZ_BUSYBOX_FEATURE_MODUTILS_SYMBOLS is not set
FREETZ_BUSYBOX_DEFAULT_MODULES_DIR="/lib/modules"
FREETZ_BUSYBOX_DEFAULT_DEPMOD_FILE="modules.dep"
# Linux System Utilities
# FREETZ_BUSYBOX_BLOCKDEV is not set
# FREETZ_BUSYBOX_FATATTR is not set
# FREETZ_BUSYBOX_FSTRIM is not set
# FREETZ_BUSYBOX_MDEV is not set
FREETZ_BUSYBOX_MOUNT=y
# FREETZ_BUSYBOX_FEATURE_MOUNT_FAKE is not set
FREETZ_BUSYBOX_FEATURE_MOUNT_VERBOSE=y
# FREETZ_BUSYBOX_FEATURE_MOUNT_HELPERS is not set
# FREETZ_BUSYBOX_FEATURE_MOUNT_LABEL is not set
FREETZ_BUSYBOX_FEATURE_MOUNT_NFS=y
FREETZ_BUSYBOX_FEATURE_MOUNT_CIFS=y
FREETZ_BUSYBOX_FEATURE_MOUNT_FLAGS=y
FREETZ_BUSYBOX_FEATURE_MOUNT_FSTAB=y
# FREETZ_BUSYBOX_FEATURE_MOUNT_OTHERTAB is not set
# FREETZ_BUSYBOX_REV is not set
# FREETZ_BUSYBOX_UEVENT is not set
# FREETZ_BUSYBOX_ACPID is not set
# FREETZ_BUSYBOX_BLKID is not set
FREETZ_BUSYBOX_DMESG=y
FREETZ_BUSYBOX_FEATURE_DMESG_PRETTY=y
# FREETZ_BUSYBOX_FBSET is not set
# FREETZ_BUSYBOX_FDFLUSH is not set
# FREETZ_BUSYBOX_FDFORMAT is not set
# FREETZ_BUSYBOX_FDISK is not set
# FREETZ_BUSYBOX_FINDFS is not set
FREETZ_BUSYBOX_FLOCK=y
# FREETZ_BUSYBOX_FREERAMDISK is not set
# FREETZ_BUSYBOX_FSCK_MINIX is not set
# FREETZ_BUSYBOX_MKFS_EXT2 is not set
# FREETZ_BUSYBOX_MKFS_MINIX is not set
# FREETZ_BUSYBOX_MKFS_REISER is not set
# FREETZ_BUSYBOX_MKFS_VFAT is not set
FREETZ_BUSYBOX_GETOPT=y
FREETZ_BUSYBOX_FEATURE_GETOPT_LONG=y
FREETZ_BUSYBOX_HEXDUMP=y
# FREETZ_BUSYBOX_FEATURE_HEXDUMP_REVERSE is not set
# FREETZ_BUSYBOX_HD is not set
# FREETZ_BUSYBOX_HWCLOCK is not set
# FREETZ_BUSYBOX_IPCRM is not set
# FREETZ_BUSYBOX_IPCS is not set
# FREETZ_BUSYBOX_LOSETUP is not set
# FREETZ_BUSYBOX_LSPCI is not set
# FREETZ_BUSYBOX_LSUSB is not set
FREETZ_BUSYBOX_MKSWAP=y
# FREETZ_BUSYBOX_FEATURE_MKSWAP_UUID is not set
FREETZ_BUSYBOX_MORE=y
FREETZ_BUSYBOX_PIVOT_ROOT=y
FREETZ_BUSYBOX_RDATE=y
# FREETZ_BUSYBOX_RDEV is not set
# FREETZ_BUSYBOX_READPROFILE is not set
# FREETZ_BUSYBOX_RTCWAKE is not set
# FREETZ_BUSYBOX_SCRIPT is not set
# FREETZ_BUSYBOX_SCRIPTREPLAY is not set
# FREETZ_BUSYBOX_SETARCH is not set
FREETZ_BUSYBOX_SWAPONOFF=y
# FREETZ_BUSYBOX_FEATURE_SWAPON_DISCARD is not set
# FREETZ_BUSYBOX_FEATURE_SWAPON_PRI is not set
FREETZ_BUSYBOX_SWITCH_ROOT=y
FREETZ_BUSYBOX_UMOUNT=y
FREETZ_BUSYBOX_FEATURE_UMOUNT_ALL=y
# Common options for mount/umount
FREETZ_BUSYBOX_FEATURE_MOUNT_LOOP=y
FREETZ_BUSYBOX_FEATURE_MOUNT_LOOP_CREATE=y
# FREETZ_BUSYBOX_FEATURE_MTAB_SUPPORT is not set
# FREETZ_BUSYBOX_VOLUMEID is not set
# Miscellaneous Utilities
# FREETZ_BUSYBOX_CONSPY is not set
FREETZ_BUSYBOX_CROND=y
# FREETZ_BUSYBOX_FEATURE_CROND_D is not set
# FREETZ_BUSYBOX_FEATURE_CROND_CALL_SENDMAIL is not set
# FREETZ_BUSYBOX_FEATURE_CROND_ROOT_NOLOG is not set
FREETZ_BUSYBOX_FEATURE_CROND_DIR="/var/spool/cron"
# FREETZ_BUSYBOX_I2CGET is not set
# FREETZ_BUSYBOX_I2CSET is not set
# FREETZ_BUSYBOX_I2CDUMP is not set
# FREETZ_BUSYBOX_I2CDETECT is not set
# FREETZ_BUSYBOX_LESS is not set
# FREETZ_BUSYBOX_NANDWRITE is not set
# FREETZ_BUSYBOX_NANDDUMP is not set
# FREETZ_BUSYBOX_RFKILL is not set
FREETZ_BUSYBOX_SETSERIAL=y
# FREETZ_BUSYBOX_TASKSET is not set
# FREETZ_BUSYBOX_UBIATTACH is not set
# FREETZ_BUSYBOX_UBIDETACH is not set
# FREETZ_BUSYBOX_UBIMKVOL is not set
# FREETZ_BUSYBOX_UBIRMVOL is not set
# FREETZ_BUSYBOX_UBIRSVOL is not set
# FREETZ_BUSYBOX_UBIUPDATEVOL is not set
# FREETZ_BUSYBOX_ADJTIMEX is not set
# FREETZ_BUSYBOX_BBCONFIG is not set
# FREETZ_BUSYBOX_BEEP is not set
# FREETZ_BUSYBOX_CHAT is not set
# FREETZ_BUSYBOX_CHRT is not set
FREETZ_BUSYBOX_CRONTAB=y
# FREETZ_BUSYBOX_DC is not set
# FREETZ_BUSYBOX_DEVFSD is not set
# FREETZ_BUSYBOX_FEATURE_DEVFS is not set
# FREETZ_BUSYBOX_DEVMEM is not set
# FREETZ_BUSYBOX_EJECT is not set
# FREETZ_BUSYBOX_FBSPLASH is not set
# FREETZ_BUSYBOX_FLASHCP is not set
# FREETZ_BUSYBOX_FLASH_LOCK is not set
# FREETZ_BUSYBOX_FLASH_UNLOCK is not set
# FREETZ_BUSYBOX_FLASH_ERASEALL is not set
# FREETZ_BUSYBOX_IONICE is not set
# FREETZ_BUSYBOX_INOTIFYD is not set
# FREETZ_BUSYBOX_HDPARM is not set
FREETZ_BUSYBOX_MAKEDEVS=y
# FREETZ_BUSYBOX_FEATURE_MAKEDEVS_LEAF is not set
FREETZ_BUSYBOX_FEATURE_MAKEDEVS_TABLE=y
# FREETZ_BUSYBOX_MAN is not set
# FREETZ_BUSYBOX_MICROCOM is not set
# FREETZ_BUSYBOX_MOUNTPOINT is not set
# FREETZ_BUSYBOX_MT is not set
# FREETZ_BUSYBOX_RAIDAUTORUN is not set
# FREETZ_BUSYBOX_READAHEAD is not set
# FREETZ_BUSYBOX_RX is not set
# FREETZ_BUSYBOX_SETSID is not set
FREETZ_BUSYBOX_STRINGS=y
FREETZ_BUSYBOX_TIME=y
# FREETZ_BUSYBOX_TIMEOUT is not set
# FREETZ_BUSYBOX_TTYSIZE is not set
# FREETZ_BUSYBOX_VOLNAME is not set
# FREETZ_BUSYBOX_WATCHDOG is not set
# Networking Utilities
# FREETZ_BUSYBOX_NAMEIF is not set
FREETZ_BUSYBOX_NBDCLIENT=y
FREETZ_BUSYBOX_NC=y
FREETZ_BUSYBOX_NC_SERVER=y
FREETZ_BUSYBOX_NC_EXTRA=y
# FREETZ_BUSYBOX_NC_110_COMPAT is not set
FREETZ_BUSYBOX_PING=y
FREETZ_BUSYBOX_PING6=y
FREETZ_BUSYBOX_FEATURE_FANCY_PING=y
FREETZ_BUSYBOX_STUN_IP=y
FREETZ_BUSYBOX_WGET=y
FREETZ_BUSYBOX_FEATURE_WGET_STATUSBAR=y
FREETZ_BUSYBOX_FEATURE_WGET_AUTHENTICATION=y
FREETZ_BUSYBOX_FEATURE_WGET_TIMEOUT=y
# FREETZ_BUSYBOX_FEATURE_WGET_OPENSSL is not set
FREETZ_BUSYBOX_WHOIS=y
FREETZ_BUSYBOX_FEATURE_IPV6=y
# FREETZ_BUSYBOX_FEATURE_UNIX_LOCAL is not set
FREETZ_BUSYBOX_FEATURE_PREFER_IPV4_ADDRESS=y
# FREETZ_BUSYBOX_VERBOSE_RESOLUTION_ERRORS is not set
FREETZ_BUSYBOX_ARP=y
FREETZ_BUSYBOX_ARPING=y
FREETZ_BUSYBOX_BRCTL=y
FREETZ_BUSYBOX_FEATURE_BRCTL_FANCY=y
FREETZ_BUSYBOX_FEATURE_BRCTL_SHOW=y
# FREETZ_BUSYBOX_DNSD is not set
FREETZ_BUSYBOX_ETHER_WAKE=y
# FREETZ_BUSYBOX_FAKEIDENTD is not set
# FREETZ_BUSYBOX_FTPD is not set
FREETZ_BUSYBOX_FTPGET=y
FREETZ_BUSYBOX_FTPPUT=y
FREETZ_BUSYBOX_HOSTNAME=y
FREETZ_BUSYBOX_HTTPD=y
# FREETZ_BUSYBOX_FEATURE_HTTPD_RANGES is not set
# FREETZ_BUSYBOX_FEATURE_HTTPD_SETUID is not set
FREETZ_BUSYBOX_FEATURE_HTTPD_BASIC_AUTH=y
FREETZ_BUSYBOX_FEATURE_HTTPD_AUTH_MD5=y
FREETZ_BUSYBOX_FEATURE_HTTPD_CGI=y
FREETZ_BUSYBOX_FEATURE_HTTPD_CONFIG_WITH_SCRIPT_INTERPR=y
# FREETZ_BUSYBOX_FEATURE_HTTPD_SET_REMOTE_PORT_TO_ENV is not set
FREETZ_BUSYBOX_FEATURE_HTTPD_ENCODE_URL_STR=y
# FREETZ_BUSYBOX_FEATURE_HTTPD_ERROR_PAGES is not set
# FREETZ_BUSYBOX_FEATURE_HTTPD_PROXY is not set
# FREETZ_BUSYBOX_FEATURE_HTTPD_GZIP is not set
FREETZ_BUSYBOX_IFCONFIG=y
FREETZ_BUSYBOX_FEATURE_IFCONFIG_STATUS=y
# FREETZ_BUSYBOX_FEATURE_IFCONFIG_SLIP is not set
# FREETZ_BUSYBOX_FEATURE_IFCONFIG_MEMSTART_IOADDR_IRQ is not set
FREETZ_BUSYBOX_FEATURE_IFCONFIG_HW=y
FREETZ_BUSYBOX_FEATURE_IFCONFIG_BROADCAST_PLUS=y
# FREETZ_BUSYBOX_IFENSLAVE is not set
# FREETZ_BUSYBOX_IFPLUGD is not set
FREETZ_BUSYBOX_IFUPDOWN=y
FREETZ_BUSYBOX_IFUPDOWN_IFSTATE_PATH="/var/run/ifstate"
# FREETZ_BUSYBOX_FEATURE_IFUPDOWN_IP is not set
FREETZ_BUSYBOX_FEATURE_IFUPDOWN_IFCONFIG_BUILTIN=y
FREETZ_BUSYBOX_FEATURE_IFUPDOWN_IPV4=y
FREETZ_BUSYBOX_FEATURE_IFUPDOWN_IPV6=y
FREETZ_BUSYBOX_FEATURE_IFUPDOWN_MAPPING=y
# FREETZ_BUSYBOX_FEATURE_IFUPDOWN_EXTERNAL_DHCP is not set
FREETZ_BUSYBOX_INETD=y
# FREETZ_BUSYBOX_FEATURE_INETD_SUPPORT_BUILTIN_ECHO is not set
# FREETZ_BUSYBOX_FEATURE_INETD_SUPPORT_BUILTIN_DISCARD is not set
# FREETZ_BUSYBOX_FEATURE_INETD_SUPPORT_BUILTIN_TIME is not set
# FREETZ_BUSYBOX_FEATURE_INETD_SUPPORT_BUILTIN_DAYTIME is not set
# FREETZ_BUSYBOX_FEATURE_INETD_SUPPORT_BUILTIN_CHARGEN is not set
# FREETZ_BUSYBOX_FEATURE_INETD_RPC is not set
FREETZ_BUSYBOX_IP=y
FREETZ_BUSYBOX_FEATURE_IP_ADDRESS=y
FREETZ_BUSYBOX_FEATURE_IP_LINK=y
FREETZ_BUSYBOX_FEATURE_IP_ROUTE=y
FREETZ_BUSYBOX_FEATURE_IP_ROUTE_DIR="/etc/iproute2"
FREETZ_BUSYBOX_FEATURE_IP_TUNNEL=y
FREETZ_BUSYBOX_FEATURE_IP_RULE=y
FREETZ_BUSYBOX_FEATURE_IP_SHORT_FORMS=y
# FREETZ_BUSYBOX_FEATURE_IP_RARE_PROTOCOLS is not set
# FREETZ_BUSYBOX_IPADDR is not set
# FREETZ_BUSYBOX_IPLINK is not set
# FREETZ_BUSYBOX_IPROUTE is not set
# FREETZ_BUSYBOX_IPTUNNEL is not set
# FREETZ_BUSYBOX_IPRULE is not set
# FREETZ_BUSYBOX_IPCALC is not set
FREETZ_BUSYBOX_NETSTAT=y
# FREETZ_BUSYBOX_FEATURE_NETSTAT_WIDE is not set
FREETZ_BUSYBOX_FEATURE_NETSTAT_PRG=y
FREETZ_BUSYBOX_NSLOOKUP=y
# FREETZ_BUSYBOX_NTPD is not set
# FREETZ_BUSYBOX_PSCAN is not set
FREETZ_BUSYBOX_ROUTE=y
# FREETZ_BUSYBOX_SLATTACH is not set
# FREETZ_BUSYBOX_TCPSVD is not set
# FREETZ_BUSYBOX_TELNET is not set
FREETZ_BUSYBOX_TELNETD=y
FREETZ_BUSYBOX_FEATURE_TELNETD_STANDALONE=y
# FREETZ_BUSYBOX_FEATURE_TELNETD_INETD_WAIT is not set
FREETZ_BUSYBOX_TFTP=y
# FREETZ_BUSYBOX_TFTPD is not set
# Common options for tftp/tftpd
FREETZ_BUSYBOX_FEATURE_TFTP_GET=y
FREETZ_BUSYBOX_FEATURE_TFTP_PUT=y
# FREETZ_BUSYBOX_FEATURE_TFTP_BLOCKSIZE is not set
# FREETZ_BUSYBOX_TFTP_DEBUG is not set
FREETZ_BUSYBOX_TRACEROUTE=y
FREETZ_BUSYBOX_TRACEROUTE6=y
FREETZ_BUSYBOX_FEATURE_TRACEROUTE_VERBOSE=y
FREETZ_BUSYBOX_FEATURE_TRACEROUTE_SOURCE_ROUTE=y
FREETZ_BUSYBOX_FEATURE_TRACEROUTE_USE_ICMP=y
# FREETZ_BUSYBOX_TUNCTL is not set
# FREETZ_BUSYBOX_UDHCPC6 is not set
# FREETZ_BUSYBOX_UDHCPD is not set
# FREETZ_BUSYBOX_UDHCPC is not set
# FREETZ_BUSYBOX_UDPSVD is not set
FREETZ_BUSYBOX_VCONFIG=y
# FREETZ_BUSYBOX_ZCIP is not set
# Print Utilities
# FREETZ_BUSYBOX_LPD is not set
# FREETZ_BUSYBOX_LPR is not set
# FREETZ_BUSYBOX_LPQ is not set
# Mail Utilities
# FREETZ_BUSYBOX_MAKEMIME is not set
# FREETZ_BUSYBOX_POPMAILDIR is not set
# FREETZ_BUSYBOX_REFORMIME is not set
# FREETZ_BUSYBOX_SENDMAIL is not set
# Process Utilities
FREETZ_BUSYBOX_IOSTAT=y
FREETZ_BUSYBOX_LSOF=y
FREETZ_BUSYBOX_MPSTAT=y
# FREETZ_BUSYBOX_NMETER is not set
FREETZ_BUSYBOX_PMAP=y
# FREETZ_BUSYBOX_POWERTOP is not set
FREETZ_BUSYBOX_PSTREE=y
FREETZ_BUSYBOX_PWDX=y
FREETZ_BUSYBOX_SMEMCAP=y
FREETZ_BUSYBOX_TOP=y
FREETZ_BUSYBOX_FEATURE_TOP_CPU_USAGE_PERCENTAGE=y
FREETZ_BUSYBOX_FEATURE_TOP_CPU_GLOBAL_PERCENTS=y
# FREETZ_BUSYBOX_FEATURE_TOP_SMP_CPU is not set
# FREETZ_BUSYBOX_FEATURE_TOP_DECIMALS is not set
# FREETZ_BUSYBOX_FEATURE_TOP_SMP_PROCESS is not set
# FREETZ_BUSYBOX_FEATURE_TOPMEM is not set
FREETZ_BUSYBOX_UPTIME=y
FREETZ_BUSYBOX_FREE=y
# FREETZ_BUSYBOX_FUSER is not set
FREETZ_BUSYBOX_KILL=y
FREETZ_BUSYBOX_KILLALL=y
FREETZ_BUSYBOX_KILLALL5=y
# FREETZ_BUSYBOX_PGREP is not set
FREETZ_BUSYBOX_PIDOF=y
FREETZ_BUSYBOX_FEATURE_PIDOF_SINGLE=y
FREETZ_BUSYBOX_FEATURE_PIDOF_OMIT=y
# FREETZ_BUSYBOX_PKILL is not set
FREETZ_BUSYBOX_PS=y
FREETZ_BUSYBOX_FEATURE_PS_WIDE=y
FREETZ_BUSYBOX_FEATURE_PS_LONG=y
FREETZ_BUSYBOX_RENICE=y
FREETZ_BUSYBOX_BB_SYSCTL=y
FREETZ_BUSYBOX_FEATURE_SHOW_THREADS=y
# FREETZ_BUSYBOX_WATCH is not set
# Runit Utilities
# FREETZ_BUSYBOX_RUNSV is not set
# FREETZ_BUSYBOX_RUNSVDIR is not set
# FREETZ_BUSYBOX_SV is not set
# FREETZ_BUSYBOX_SVLOGD is not set
# FREETZ_BUSYBOX_CHPST is not set
# FREETZ_BUSYBOX_SETUIDGID is not set
# FREETZ_BUSYBOX_ENVUIDGID is not set
# FREETZ_BUSYBOX_ENVDIR is not set
# FREETZ_BUSYBOX_SOFTLIMIT is not set
# Shells
FREETZ_BUSYBOX_ASH=y
FREETZ_BUSYBOX_ASH_BASH_COMPAT=y
# FREETZ_BUSYBOX_ASH_IDLE_TIMEOUT is not set
FREETZ_BUSYBOX_ASH_JOB_CONTROL=y
FREETZ_BUSYBOX_ASH_ALIAS=y
FREETZ_BUSYBOX_ASH_GETOPTS=y
FREETZ_BUSYBOX_ASH_BUILTIN_ECHO=y
FREETZ_BUSYBOX_ASH_BUILTIN_PRINTF=y
FREETZ_BUSYBOX_ASH_BUILTIN_TEST=y
# FREETZ_BUSYBOX_ASH_HELP is not set
FREETZ_BUSYBOX_ASH_CMDCMD=y
# FREETZ_BUSYBOX_ASH_MAIL is not set
FREETZ_BUSYBOX_ASH_OPTIMIZE_FOR_SIZE=y
# FREETZ_BUSYBOX_ASH_RANDOM_SUPPORT is not set
FREETZ_BUSYBOX_ASH_EXPAND_PRMT=y
# FREETZ_BUSYBOX_CTTYHACK is not set
# FREETZ_BUSYBOX_HUSH is not set
# FREETZ_BUSYBOX_MSH is not set
FREETZ_BUSYBOX_FEATURE_SH_IS_ASH=y
# FREETZ_BUSYBOX_FEATURE_SH_IS_NONE is not set
# FREETZ_BUSYBOX_FEATURE_BASH_IS_ASH is not set
FREETZ_BUSYBOX_FEATURE_BASH_IS_NONE=y
FREETZ_BUSYBOX_SH_MATH_SUPPORT=y
# FREETZ_BUSYBOX_SH_MATH_SUPPORT_64 is not set
# FREETZ_BUSYBOX_FEATURE_SH_EXTRA_QUIET is not set
FREETZ_BUSYBOX_FEATURE_SH_STANDALONE=y
FREETZ_BUSYBOX_FEATURE_SH_NOFORK=y
# FREETZ_BUSYBOX_FEATURE_SH_HISTFILESIZE is not set
# System Logging Utilities
FREETZ_BUSYBOX_SYSLOGD=y
FREETZ_BUSYBOX_FEATURE_ROTATE_LOGFILE=y
FREETZ_BUSYBOX_FEATURE_REMOTE_LOG=y
FREETZ_BUSYBOX_FEATURE_SYSLOGD_DUP=y
# FREETZ_BUSYBOX_FEATURE_SYSLOGD_CFG is not set
FREETZ_BUSYBOX_FEATURE_SYSLOGD_READ_BUFFER_SIZE=256
FREETZ_BUSYBOX_FEATURE_IPC_SYSLOG=y
FREETZ_BUSYBOX_FEATURE_IPC_SYSLOG_BUFFER_SIZE=16
FREETZ_BUSYBOX_LOGREAD=y
FREETZ_BUSYBOX_FEATURE_LOGREAD_REDUCED_LOCKING=y
# FREETZ_BUSYBOX_FEATURE_KMSG_SYSLOG is not set
FREETZ_BUSYBOX_KLOGD=y
FREETZ_BUSYBOX_FEATURE_KLOGD_KLOGCTL=y
FREETZ_BUSYBOX_LOGGER=y
# External processing
# EXTERNAL_ENABLED is not set
# Mod customizations ---------------------
# Web Interface
FREETZ_LANG_DE=y
# FREETZ_LANG_EN is not set
FREETZ_LANG_STRING="de"
FREETZ_SECURITY_LEVEL=0
FREETZ_STYLE_COLORED=y
# FREETZ_STYLE_GREY is not set
FREETZ_STYLE="colored"
# Freetz skins
FREETZ_SKIN_legacy=y
# FREETZ_SKIN_newfreetz is not set
# FREETZ_SKIN_phoenix is not set
FREETZ_FAVICON_NONE=y
# FREETZ_FAVICON_ATOMPHIL is not set
# FREETZ_FAVICON_CUMA is not set
# FREETZ_FAVICON_DSL123 is not set
# FREETZ_FAVICON_HANSOLO is not set
FREETZ_FAVICON_STRING="none"
FREETZ_TAGGING_NONE=y
# FREETZ_TAGGING_CUMA is not set
FREETZ_TAGGING_STRING="none"
# Additional image/box information
# FREETZ_REMOVE_BOX_INFO is not set
# FREETZ_REMOVE_FREETZ_INFO is not set
# FREETZ_MODIFY_AVM_VERSION is not set
FREETZ_USER_DEFINED_COMMENT=""
# FREETZ_CUSTOM_IMAGE_NAME is not set
FREETZ_CREATE_SEPARATE_OPTIONS_CFG=y
# FREETZ_REMOVE_DOT_CONFIG is not set
# Build system ---------------------------
# Toolchain options
FREETZ_DOWNLOAD_TOOLCHAIN=y
# FREETZ_BUILD_TOOLCHAIN is not set
# Kernel toolchain options ----------------------------------
FREETZ_KERNEL_BINUTILS_2_22=y
FREETZ_KERNEL_GCC_4_8=y
FREETZ_KERNEL_BINUTILS_VERSION="2.22"
FREETZ_KERNEL_GCC_VERSION="4.8.5"
# Target toolchain options ----------------------------------
FREETZ_TARGET_UCLIBC_0_9_33=y
FREETZ_TARGET_UCLIBC_SUPPORTS_libubacktrace=y
FREETZ_TARGET_UCLIBC_REQUIRES_libubacktrace=y
FREETZ_TARGET_BINUTILS_2_22=y
FREETZ_TARGET_GCC_4_8=y
FREETZ_TARGET_GCC_DEFAULT_AS_NEEDED=y
FREETZ_STDCXXLIB_USE_UCLIBCXX=y
# FREETZ_STDCXXLIB_USE_GNULIBSTDCXX is not set
FREETZ_TARGET_UCLIBC_VERSION="0.9.33.2"
FREETZ_TARGET_BINUTILS_VERSION="2.22"
FREETZ_TARGET_GCC_MAJOR_VERSION="4.8"
FREETZ_TARGET_GCC_MINOR_VERSION="5"
FREETZ_TARGET_GCC_VERSION="${FREETZ_TARGET_GCC_MAJOR_VERSION}.${FREETZ_TARGET_GCC_MINOR_VERSION}"
FREETZ_GNULIBSTDCXX_VERSION="6.0.19"
FREETZ_STDCXXLIB="uclibcxx"
FREETZ_TARGET_CFLAGS="-Os -pipe -Wa,--trap"
FREETZ_RPATH="/usr/lib/freetz"
FREETZ_TARGET_UCLIBC_REDUCED_LOCALE_SET=y
# FREETZ_TARGET_NLS is not set
# FREETZ_TARGET_TOOLCHAIN is not set
# Both kernel and target toolchain related options ----------
FREETZ_TOOLCHAIN_MINIMIZE_REQUIRED_GLIBC_VERSION=y
# FREETZ_TOOLCHAIN_32BIT is not set
# FREETZ_TOOLCHAIN_CCACHE is not set
# Build system options
FREETZ_VERBOSITY_LEVEL=2
FREETZ_SIZEINFO_COMPRESSED=y
# FREETZ_SIZEINFO_UNCOMPRESSED is not set
FREETZ_JLEVEL=2
FREETZ_CHECK_CHANGED=y
# FREETZ_BACKUP_CONFIG_CACHE is not set
# Firmware packaging (fwmod) options
# FREETZ_FWMOD_SKIP_UNPACK is not set
# FREETZ_FWMOD_SKIP_MODIFY is not set
# FREETZ_FWMOD_SKIP_PACK is not set
# FREETZ_FWMOD_FORCE_PACK is not set
# FREETZ_FWMOD_SIGN is not set
# FREETZ_FWMOD_USBROOT is not set
# FREETZ_FWMOD_NFSROOT is not set
# SquashFS options
# FREETZ_SQUASHFS_BLOCKSIZE_ORIG is not set
FREETZ_SQUASHFS_BLOCKSIZE_65536=y
FREETZ_SQUASHFS_BLOCKSIZE=65536
# Strip options
FREETZ_STRIP_BINARIES=y
# FREETZ_STRIP_LIBRARIES is not set
# FREETZ_STRIP_MODULES_NONE is not set
FREETZ_STRIP_MODULES_FREETZ=y
# FREETZ_STRIP_MODULES_ALL is not set
# FREETZ_STRIP_SCRIPTS is not set
# Override options
FREETZ_DL_SITE_USER=""
# FREETZ_DL_TOOLCHAIN_OVERRIDE is not set
FREETZ_DL_TOOLCHAIN_SITE=""
FREETZ_DL_KERNEL_TOOLCHAIN_VERSION="r13747"
FREETZ_DL_KERNEL_TOOLCHAIN_MD5="18bf3175f1b900c7f4256eb5fd78dba8"
FREETZ_DL_TARGET_TOOLCHAIN_VERSION="r13747"
FREETZ_DL_TARGET_TOOLCHAIN_MD5="c9e8a74c52cebafa4c9634e51c86d5d7"
FREETZ_DL_TOOLCHAIN_SUFFIX="shared-glibc"
# FREETZ_DL_OVERRIDE is not set
FREETZ_DL_KERNEL_SITE=""
FREETZ_DL_KERNEL_SOURCE_ID="3490_06.20"
FREETZ_DL_KERNEL_SOURCE="${FREETZ_DL_KERNEL_SOURCE_ID}-release_kernel.tar.xz"
FREETZ_DL_KERNEL_SOURCE_MD5="16ba3988368eeb6c1603490ca2ea3aac"
FREETZ_DL_SITE="@AVM/fritzbox.7412/firmware/deutsch,@1&1/7412"
FREETZ_DL_SOURCE="FRITZ.Box_7412.137.06.30.image"
FREETZ_DL_SOURCE_MD5="a54fd8d38bdb66a7ef0408bbd717092d"
FREETZ_DL_SOURCE_CONTAINER=""
FREETZ_DL_SOURCE_CONTAINER_MD5=""
# FREETZ_AVM_HAS_FIRMWARE_04_XX is not set
# FREETZ_AVM_HAS_FIRMWARE_05_2X is not set
# FREETZ_AVM_HAS_FIRMWARE_05_5X is not set
# FREETZ_AVM_HAS_FIRMWARE_06_0X is not set
FREETZ_AVM_HAS_FIRMWARE_06_2X=y
FREETZ_AVM_HAS_FIRMWARE_06_5X=y
FREETZ_AVM_HAS_FIRMWARE_06_8X=y
# FREETZ_AVM_HAS_FIRMWARE_LABOR is not set
FREETZ_AVM_HAS_LANG_DE=y
# FREETZ_AVM_HAS_LANG_A_CH is not set
# FREETZ_AVM_HAS_LANG_EN is not set
# FREETZ_AVM_HAS_LANG_IT is not set
# FREETZ_AVM_HAS_AHA is not set
FREETZ_AVM_HAS_DECT=y
# FREETZ_AVM_HAS_FHEM is not set
FREETZ_AVM_HAS_MYFRITZ=y
FREETZ_AVM_HAS_MULTI_ANNEX=y
# FREETZ_AVM_HAS_ANNEX_A_AND_B is not set
# FREETZ_AVM_HAS_NAS is not set
# FREETZ_AVM_HAS_NTFS is not set
FREETZ_AVM_HAS_PHONE=y
# FREETZ_AVM_HAS_PLUGINS_UPDATE is not set
FREETZ_AVM_HAS_TAM=y
FREETZ_AVM_HAS_TEMPERATURE_SENSOR=y
FREETZ_AVM_HAS_TR069=y
FREETZ_AVM_HAS_TR069_FWUPDATE=y
FREETZ_AVM_HAS_UDEV=y
FREETZ_AVM_HAS_UMTS=y
# FREETZ_AVM_HAS_USB_HOST is not set
# FREETZ_AVM_HAS_AURA_USB is not set
# FREETZ_AVM_HAS_ETHERNET_OVER_USB is not set
# FREETZ_AVM_HAS_WEBDAV is not set
FREETZ_AVM_HAS_WLAN=y
FREETZ_AVM_SERIAL_CONSOLE_DEVICE="/dev/ttyS0"
FREETZ_AVM_HAS_IPV6=y
FREETZ_AVM_HAS_PTY_SUPPORT=y
FREETZ_AVM_HAS_PRINTK=y
# FREETZ_AVM_HAS_AUTOFS4_BUILTIN is not set
FREETZ_AVM_HAS_EXT2_BUILTIN=y
FREETZ_AVM_HAS_EXT3_BUILTIN=y
FREETZ_AVM_HAS_EXT4_BUILTIN=y
# FREETZ_AVM_HAS_NLS_CP437_BUILTIN is not set
# FREETZ_AVM_HAS_NLS_ISO8859_1_BUILTIN is not set
# FREETZ_AVM_HAS_NLS_ISO8859_15_BUILTIN is not set
FREETZ_AVM_HAS_NLS_UTF8_BUILTIN=y
# FREETZ_AVM_HAS_ISOFS is not set
# FREETZ_AVM_HAS_JFFS2_MODULE is not set
# FREETZ_AVM_HAS_JFFS2_BUILTIN is not set
FREETZ_AVM_HAS_RAMZSWAP=y
# FREETZ_AVM_HAS_CRYPTO_ALGAPI_BUILTIN is not set
# FREETZ_AVM_HAS_CRYPTO_AEAD_BUILTIN is not set
# FREETZ_AVM_HAS_CRYPTO_AES_BUILTIN is not set
# FREETZ_AVM_HAS_CRYPTO_ARC4_BUILTIN is not set
# FREETZ_AVM_HAS_CRYPTO_BLKCIPHER_BUILTIN is not set
# FREETZ_AVM_HAS_CRYPTO_CBC_BUILTIN is not set
# FREETZ_AVM_HAS_CRYPTO_HASH_BUILTIN is not set
# FREETZ_AVM_HAS_CRYPTO_MANAGER_BUILTIN is not set
# FREETZ_AVM_HAS_CRYPTO_PCOMP_BUILTIN is not set
# FREETZ_AVM_HAS_CRYPTO_RNG_BUILTIN is not set
# FREETZ_AVM_HAS_CRYPTO_SHA1_BUILTIN is not set
# FREETZ_AVM_HAS_CRYPTO_SHA256_BUILTIN is not set
# FREETZ_AVM_HAS_CRYPTO_WORKQUEUE_BUILTIN is not set
# FREETZ_AVM_HAS_CDROM_ISO is not set
FREETZ_AVM_HAS_CHRONYD=y
FREETZ_AVM_HAS_E2FSPROGS=y
FREETZ_AVM_HAS_INETD=y
FREETZ_AVM_HAS_LSOF=y
# FREETZ_AVM_HAS_MICROVOIP_DSL is not set
# FREETZ_AVM_HAS_MINID is not set
FREETZ_AVM_HAS_OPENSSL=y
# FREETZ_AVM_HAS_OPENSSL_VERSION_0 is not set
FREETZ_AVM_HAS_OPENSSL_VERSION_1=y
# FREETZ_AVM_HAS_PIGLET_POTS is not set
# FREETZ_AVM_HAS_PIGLET_ISDN is not set
# FREETZ_AVM_HAS_SOCAT is not set
# FREETZ_AVM_HAS_STRACE is not set
FREETZ_AVM_HAS_AR7CFG_V12_MIN=y
# FREETZ_AVM_HAS_ALLCFGCONV_WITH_DECRYPTION_SUPPORT is not set
# FREETZ_AVM_HAS_DEBUG_CFG_SUPPORT is not set
FREETZ_AVM_HAS_MULTID_LEASES_FORMAT_V2=y
FREETZ_AVM_SQUASHFS_VERSION=3
FREETZ_SQUASHFS_VERSION=3
FREETZ_AVM_SQUASHFS_COMPRESSION="gzip"
# FREETZ_AVM_HAS_NMI_VECTOR is not set
FREETZ_AVM_HAS_SEPARATE_FILESYSTEM_IMAGE=y
FREETZ_AVM_HAS_INNER_OUTER_FILESYSTEM=y
FREETZ_AVM_OUTER_FILESYSTEM_TYPE="SquashFS"
FREETZ_AVM_VERSION_06_2X=y
FREETZ_AVM_VERSION_04_XX_MIN=y
FREETZ_AVM_VERSION_05_2X_MIN=y
FREETZ_AVM_VERSION_05_5X_MIN=y
FREETZ_AVM_VERSION_06_0X_MIN=y
FREETZ_AVM_VERSION_06_2X_MIN=y
# FREETZ_AVM_VERSION_06_5X_MIN is not set
# FREETZ_AVM_VERSION_06_8X_MIN is not set
# FREETZ_AVM_VERSION_04_XX_MAX is not set
# FREETZ_AVM_VERSION_05_2X_MAX is not set
# FREETZ_AVM_VERSION_05_5X_MAX is not set
# FREETZ_AVM_VERSION_06_0X_MAX is not set
FREETZ_AVM_VERSION_06_2X_MAX=y
FREETZ_AVM_VERSION_06_5X_MAX=y
FREETZ_AVM_VERSION_06_8X_MAX=y
FREETZ_TARGET_ARCH_BE=y
FREETZ_TARGET_ARCH="mips"
FREETZ_TARGET_CROSS="${FREETZ_TARGET_ARCH}-linux-uclibc-"
FREETZ_KERNEL_CROSS="${FREETZ_TARGET_ARCH}-unknown-linux-gnu-"
# FREETZ_AVM_GCC_3_4 is not set
# FREETZ_AVM_GCC_4_6 is not set
# FREETZ_AVM_GCC_4_7 is not set
FREETZ_AVM_GCC_4_8=y
# FREETZ_AVM_GCC_4_9 is not set
# FREETZ_AVM_GCC_5 is not set
FREETZ_AVM_GCC_3_4_MIN=y
FREETZ_AVM_GCC_4_6_MIN=y
FREETZ_AVM_GCC_4_7_MIN=y
FREETZ_AVM_GCC_4_8_MIN=y
# FREETZ_AVM_GCC_4_9_MIN is not set
# FREETZ_AVM_GCC_5_MIN is not set
# FREETZ_AVM_GCC_3_4_MAX is not set
# FREETZ_AVM_GCC_4_6_MAX is not set
# FREETZ_AVM_GCC_4_7_MAX is not set
FREETZ_AVM_GCC_4_8_MAX=y
FREETZ_AVM_GCC_4_9_MAX=y
FREETZ_AVM_GCC_5_MAX=y
# FREETZ_KERNEL_VERSION_2_6_13 is not set
# FREETZ_KERNEL_VERSION_2_6_19 is not set
# FREETZ_KERNEL_VERSION_2_6_28 is not set
# FREETZ_KERNEL_VERSION_2_6_32_41 is not set
# FREETZ_KERNEL_VERSION_2_6_32_60 is not set
FREETZ_KERNEL_VERSION_2_6_32_61=y
FREETZ_KERNEL_VERSION_2_6_32=y
# FREETZ_KERNEL_VERSION_3_10_12 is not set
# FREETZ_KERNEL_VERSION_3_10_73 is not set
# FREETZ_KERNEL_VERSION_3_10 is not set
FREETZ_KERNEL_VERSION="2.6.32"
FREETZ_KERNEL_VERSION_MAJOR="2.6.32"
FREETZ_KERNEL_VERSION_2_6_13_MIN=y
FREETZ_KERNEL_VERSION_2_6_19_MIN=y
FREETZ_KERNEL_VERSION_2_6_28_MIN=y
FREETZ_KERNEL_VERSION_2_6_32_MIN=y
# FREETZ_KERNEL_VERSION_3_10_MIN is not set
# FREETZ_KERNEL_VERSION_2_6_13_MAX is not set
# FREETZ_KERNEL_VERSION_2_6_19_MAX is not set
# FREETZ_KERNEL_VERSION_2_6_28_MAX is not set
FREETZ_KERNEL_VERSION_2_6_32_MAX=y
FREETZ_KERNEL_VERSION_3_10_MAX=y
FREETZ_KERNEL_LAYOUT_VR9=y
FREETZ_KERNEL_LAYOUT="vr9"
FREETZ_MODULES_KVER="2.6.32.61"
FREETZ_KERNEL_PATCHES="2.6.32.61"
# FREETZ_AVM_UCLIBC_0_9_28 is not set
# FREETZ_AVM_UCLIBC_0_9_29 is not set
# FREETZ_AVM_UCLIBC_0_9_32 is not set
FREETZ_AVM_UCLIBC_0_9_33=y
FREETZ_AVM_UCLIBC_NPTL_ENABLED=y
FREETZ_AVM_SOURCE_3490_06_31=y
FREETZ_AVM_SOURCE_ID="3490_06.31"
FREETZ_AVM_SOURCE_FOR_KERNEL_LAYOUT_VR9=y
FREETZ_GCC_ABI="32"
FREETZ_GCC_ARCH="mips32r2"
FREETZ_GCC_TUNE="24kc"
FREETZ_GCC_FLOAT_ABI="soft"
FREETZ_REPLACE_KERNEL_AVAILABLE=y
FREETZ_REPLACE_KERNEL_EXPERIMENTAL=y
FREETZ_REPLACE_MODULE_AVAILABLE=y
FREETZ_TYPE_PREFIX="7412"
FREETZ_TYPE_PREFIX_SERIES_SUBDIR="06_2X"
FREETZ_INSTALL_BASE=y
FREETZ_REPLACE_BUSYBOX=y
FREETZ_CIFS_SUPPORT_NEEDS_REPLACE_KERNEL=y
# FREETZ_CIFS_SUPPORT_AVAILABLE is not set
# FREETZ_NFS_SUPPORT_NEEDS_REPLACE_KERNEL is not set
FREETZ_NFS_SUPPORT_AVAILABLE=y
FREETZ_NFS_SUPPORT_AVAILABLE_AS_MODULE=y
Bootprotokoll:
ROM VER: 1.1.4
CFG 06
NAND
NAND Read OK
(AVM) EVA Revision: 1.2605 Version: 3605
(C) Copyright 2005 AVM Date: Jul 24 2015 Time: 11:09:46 (0) 3 0x0-0x47409
[NAND:] 128MB TOSHIBA 2048 Pagesize 128k Blocksize 1024 Blocks
[SYSTEM:] VR9 on 500MHz/250MHz/250MHz
Eva_AVM >
Eva_AVM >
Eva_AVM >printenv
HWRevision            209
HWSubRevision         1
ProductID             Fritz_Box_HW209
SerialNumber          0000000000000000
annex                 B
autoload              yes
bootloaderVersion     1.2605
bootserport           tty0
cpufrequency          500000000
firstfreeaddress      0x811FB68C
firmware_info         137.06.30
firmware_version      1und1
flashsize             nor_size=0MB sflash_size=0KB nand_size=128MB
linux_fs_start        1
maca                  5C:49:79:XX:XX:XX
macb                  5C:49:79:XX:XX:XX
macwlan               5C:49:79:XX:XX:XX
macwlan2              5C:49:79:XX:XX:XX
macdsl                5C:49:79:XX:XX:XX
memsize               0x08000000
modetty0              38400,n,8,1,hw
modetty1              38400,n,8,1,hw
mtd0                  0x840000,0x3840000
mtd1                  0x440000,0x840000
mtd2                  0x0,0x40000
mtd3                  0x40000,0x440000
mtd4                  0x0,0x200000
my_ipaddress          192.168.178.1
prompt                Eva_AVM
ptest
req_fullrate_freq     250000000
sysfrequency          250000000
urlader-version       3605
usb_board_mac         5C:49:79:XX:XX:XX
usb_device_id         0x0000
usb_device_name       USB DSL Device
usb_manufacturer_name  AVM
usb_revision_id       0x0000
usb_rndis_mac         5C:49:79:XX:XX:XX
wlan_key              84807311426145206050
Eva_AVM >go
##...............................................ExecuteProgram
Lantiq xDSL CPE VR9
[    0.000000] Linux version 2.6.32.61 (jpluschke@EmbeddedVM) (gcc version 4.8.1 (Buildroot 2013.05) ) #1 SMP Mon Oct 12 17:49:11 CEST 2015
[    0.000000] phym = 08000000, mem = 08000000, max_pfn = 00008000
[    0.000000] Reserving memory for CP1 @0xa8000000, size 0x00000000
[    0.000000] [init_avm_kernel_config] AVM Kernel Config (ptr 806d6000)
[    0.000000] [init_avm_kernel_config] AVM Kernel Config: module memory entry
[    0.000000] bootconsole [early0] enabled
[    0.000000] CPU revision is: 00019556 (MIPS 34Kc)
[    0.000000] Determined physical RAM map:
[    0.000000] Initrd not found or empty - disabling initrd
[    0.000000] Zone PFN ranges:
[    0.000000]   Normal   0x00000000 -> 0x00008000
[    0.000000] Movable zone start PFN for each node
[    0.000000] early_node_map[1] active PFN ranges
[    0.000000]     0: 0x00000000 -> 0x00008000
[    0.000000] [module-alloc-by-name] 'modulemem' not in use, use AVM Kernel Config (7684096 bytes, reserved for module mem)
[    0.000000] [module-alloc] use 0x754000 bytes at 0x81101000
[    0.000000] 1 available secondary CPU TC(s)
[    0.000000] PERCPU: Embedded 7 pages/cpu @81859000 s5760 r8192 d14720 u65536
[    0.000000] pcpu-alloc: s5760 r8192 d14720 u65536 alloc=16*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 32512
[    0.000000] Kernel command line:  console=ttyS0,115200n8r nor_size=0MB sflash_size=0KB nand_size=128MB ethaddr=5C:49:79:XX:XX:XX tffsver=3
[    0.000000] [NAND] nand_size = 0x8000000
[    0.000000] [tffs_setup_version] tffs version 3 requested
[    0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
[    0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[    0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[    0.000000] wait instruction: r4k_wait_irqoff
[    0.000000] [avm_cache_set_coherency]: setting cache coherency for HWRevision=209 to write back allocate
[    0.000000] Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes.
[    0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
[    0.000000] Writing ErrCtl register=00051a4f
[    0.000000] Readback ErrCtl register=00051a4f
[    0.000000] Memory: 114444k/131072k available (4796k kernel code, 16464k reserved, 2199k data, 212k init, 0k highmem)
[    0.000000] Hierarchical RCU implementation.
[    0.000000] NR_IRQS:181
[    0.000000] [mips_cpu_irq_init] irq_base 0
[    0.000000] SRSConf0 0x3feffbfe: SRS1: 0xffffffff, SRS2 0xffffffff, SRS3 0xffffffff
[    0.000000] Console: colour dummy device 80x25
[    0.000000] console [ttyS0] enabled, bootconsole disabled
[    0.020000] Calibrating delay loop... 332.59 BogoMIPS (lpj=1662976)
[    0.240000] Security Framework initialized
[    0.240000] Mount-cache hash table entries: 512
[    0.250000] kernel_init: started
[    0.250000] kernel_init: kernel locked
[    0.250000] Limit of 2 TCs set
[    0.250000] TLB of 32 entry pairs shared by 2 VPEs
[    0.250000] VPE 0: TC 0, VPE 1: TC 1
[    0.250000] IPI buffer pool of 8 buffers
[    0.260000] CPU revision is: 00019556 (MIPS 34Kc)
[    0.490000] TC 1 going on-line as CPU 1
[    0.500000] Brought up 2 CPUs
[    0.510000] [yield_context_init] cpu=1 tc=2 mask=300
[    0.510000] [yield_context_init] cpu=0 tc=3 mask=410
[power_managment_setup] reset 'DSL, DFE, AFE, VOICE, DSLTC, ARC'
[power_managment_setup] reset 'LDO'
[power_managment_setup] power down 'PPE TC, PPE EMA, LEDC, DFEV1, DFEV0'
[power_managment_setup] power down 'MSI1, PDI1 PCIE1 PCIE1_PHY'
[power_managment_setup] power down 'USB CTRL'
[power_managment_setup] power down 'GPHY'
[power_managment_setup] disable power domain 'DSL + DFE'
[    0.560000] NET: Registered protocol family 16
[    0.560000] Lantiq GPIO driver, version 1.3.2, (c) 2001-2013 Lantiq Deutschland GmbH
[    0.570000] Reboot Status is: Power-On
[    0.570000] [TFFS3_Early_Init] called
[    0.570000] [avmnet] [avmnet_cfg_init] Driver version: 6.136  -  Revision 1496:2706  -  Mo 12. Okt 17:48:42 CEST 2015
[    0.890000] Lantiq PCIe Root Complex driver, version 2.0.0, (c) 2001-2013 Lantiq Deutschland GmbH
[    0.900000] bio: create slab <bio-0> at 0
[    0.900000] ifx_pcie_rc_class_early_fixup port 0: fixed pcie host bridge to pci-pci bridge
[    0.910000] pci 0000:00:00.0: PME# supported from D0 D3hot
[    0.910000] pci 0000:00:00.0: PME# disabled
[    0.920000] pci 0000:01:00.0: PME# supported from D0 D1 D3hot
[    0.920000] pci 0000:01:00.0: PME# disabled
[    0.930000] pci 0000:00:00.0: PCI bridge, secondary bus 0000:01
[    0.930000] pci 0000:00:00.0:   IO window: disabled
[    0.940000] pci 0000:00:00.0:   MEM window: 0x1c000000-0x1c0fffff
[    0.940000] pci 0000:00:00.0:   PREFETCH window: disabled
[    0.950000] NET: Registered protocol family 8
[    0.950000] NET: Registered protocol family 20
[    0.960000] NET: Registered protocol family 2
[    0.960000] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.960000] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[    0.960000] TCP bind hash table entries: 4096 (order: 4, 81920 bytes)
[    0.970000] TCP: Hash tables configured (established 4096 bind 4096)
[    0.990000] TCP reno registered
[    0.990000] NET: Registered protocol family 1
[    1.000000] IFX DMA driver, version ifxmips_dma_core.c:v1.0.17 ,(c)2009 Infineon Technologies AG
[    1.000000]  skb_shared_size:344
[    1.010000] Lantiq CGU driver, version 1.1.32, (c) 2001-2013 Lantiq Deutschland GmbH
[    1.020000] squashfs: version 3.4 (2008/08/26) Phillip Lougher
[    1.020000] fuse init (API version 7.13)
[    1.030000] msgmni has been set to 223
[    1.030000] io scheduler noop registered (default)
[    1.040000] [avm_membench_init]
[    1.290000] avm_net_trace: Up and running.
[    1.290000] [loadcontrol] set auto - scale=1
[    1.300000] [avm] configured: watchdog event debug
[    1.300000] AVM_WATCHDOG: Watchdog Driver for AR7 Hardware (Version 1.0, build: Oct 12 2015 17:48:03)
[    1.320000] ifx_pmu_init: Major 247
[    1.320000] Lantiq PMU driver, version 1.2.6, (c) 2001-2013 Lantiq Deutschland GmbH
[    1.330000] Infineon Technologies RCU driver version 1.0.7
[    1.330000] Lantiq Thermal Sensor driver, version 1.0.3, (c) 2001-2013 Lantiq Deutschland GmbH
[    1.340000] ttyS0 at MMIO 0x1e100c00 (irq = 107) is a PORT_IFX_ASC
[    1.350000] loop: module loaded
[    1.360000] nbd: registered device at major 43
[    1.370000] Generic platform RAM MTD, (c) 2004 Simtec Electronics
[    1.380000] Platform NOR MTD, (c) AVM 2010
[    1.380000] ifx_hsnand_init: ifx_hsnand_chip_init(0)
[    1.390000] [HSNAND] Toshiba-BENAND
[    1.390000] NAND device: Manufacturer ID: 0x98, Chip ID: 0xf1 (Toshiba NAND 128MiB 3,3V 8-bit)
[    1.400000] Scanning device for bad blocks
[    1.470000] {ifx_hsnand_toshiba_read_eccstatus} status 0xe1
[    1.470000] [ifx_hsnand_command] read block failed (column: 0x800 page: 0xc000)
[    1.480000] Bad eraseblock 768 at 0x000006000000 (byte on oob[0-1]=0x0)
[    1.510000] badblock statistics:
[    1.510000] --------------------
[    1.510000]   start block = 0
[    1.510000]   num blocks  = 1024
[    1.510000]   bad blocks  = 1
[    1.520000]
[    1.520000]   >> The following table summarize all badblocks to visualize the distribution
[    1.520000]   block [ start | count | size/kB ] (start block, number of blocks)
[    1.520000]   ---------------------------------
[    1.550000]   block [   768 |     1 |     128 ]
[    1.550000]         [ ======================= ]
[    1.550000]         [      >>     1 |     128 ]
[    1.560000] Creating 8 MTD partitions on "ifx_hsnand":
[    1.560000] 0x000000440000-0x000000840000 : "reserved-kernel"
[    1.570000] {ifx_mtd_add_notifier} name reserved-kernel
[    1.570000] 0x000000840000-0x000003840000 : "reserved-filesystem"
[    1.580000] {ifx_mtd_add_notifier} name reserved-filesystem
[    1.590000] 0x000003840000-0x000003c40000 : "kernel"
[    1.590000] {ifx_mtd_add_notifier} name kernel
[    1.600000] 0x000003c40000-0x000006c40000 : "filesystem"
[    1.600000] {ifx_mtd_add_notifier} name filesystem
[    1.610000] 0x000006c40000-0x000006e40000 : "config"
[    1.610000] {ifx_mtd_add_notifier} name config
[    1.620000] 0x000006e40000-0x000008000000 : "nand-filesystem"
[    1.620000] {ifx_mtd_add_notifier} name nand-filesystem
[    1.630000] 0x000000000000-0x000000040000 : "urlader"
[    1.630000] {ifx_mtd_add_notifier} name urlader
[    1.640000] 0x000000040000-0x000000440000 : "nand-tffs"
[    1.640000] {ifx_mtd_add_notifier} name nand-tffs
[    1.650000] [TFFS3_Register_NAND] Called
[    1.650000] Lantiq SSC driver, version 2.4.1, (c) 2001-2013 Lantiq Deutschland GmbH
[    1.660000] Unknown SPI device: 0xFF 0xFF 0xFF
[    1.660000] ifx_spi_flash_init: Found no serial flash device
[    1.670000] tun: Universal TUN/TAP device driver, 1.6
[    1.670000] tun: (C) 1999-2004 Max Krasnyansky <[email protected]>
[    1.680000] IFX SWITCH API, Version 1.1.8.5
[    1.680000] SWAPI: Registered character device [switch_api] with major no [81]
[    1.690000] Switch API: PCE MicroCode loaded !!
[    1.690000] res = 87acb200
[    1.700000] i2c /dev entries driver
[    1.700000] CAPI Subsystem Rev 1.1.2.8
[    1.710000] AVM PA 4.3.10 2014-09-21
[    1.710000] AVM PA skb pktinfo at offset 128 size 196
[    1.710000] [loadcontrol]module avm_pa registered
[    1.720000] IPv4 over IPv4 tunneling driver
[    1.720000] TCP cubic registered
[    1.730000] mcfw: IGMPv3 fast forwarding
[    1.730000] NET: Registered protocol family 10
[    1.730000] IPv6 over IPv4 tunneling driver
[    1.740000] NET: Registered protocol family 17
[    1.740000] NET: Registered protocol family 8
[    1.750000] atmpvc_init() failed with -17
[    1.750000] KOAM is loaded successfully.
[    1.750000] l2tp_core: L2TP core driver, V2.0
[    1.760000] l2tp_ip: L2TP IP encapsulation support (L2TPv3)
[    1.760000] l2tp_netlink: L2TP netlink interface
[    1.770000] l2tp_eth: L2TP ethernet pseudowire support (L2TPv3)
[    1.770000] l2tp_ip6: L2TP IP encapsulation support for IPv6 (L2TPv3)
[    1.780000] 802.1Q VLAN Support v1.8 Ben Greear <[email protected]>
[    1.790000] All bugs added by David S. Miller <[email protected]>
[    1.800000] [tffs_init] different tffs version requested, version 2 not starting
[    1.800000] [prepare_log_proc] TFFS version 2 not running
[    1.810000] [TFFS3-NAND] NAND storage backend for TFFS 3.x
[    1.810000] [TFFS3-NAND] scanning block at address 0x0
[    1.820000] [TFFS3-NAND] found TFFS header magic at address 0x0, version 0x30000
[    1.860000] [TFFS3-NAND] scanning block at address 0x20000
[    1.860000] [TFFS3-NAND] found TFFS header magic at address 0x20000, version 0x30000
[    1.910000] [TFFS3-NAND] scanning block at address 0x40000
[    1.910000] [TFFS3-NAND] found TFFS header magic at address 0x40000, version 0x30000
[    1.950000] [TFFS3-NAND] scanning block at address 0x60000
[    1.950000] [TFFS3-NAND] found TFFS header magic at address 0x60000, version 0x30000
[    1.970000] [TFFS3-NAND] scanning block at address 0x80000
[    1.970000] [TFFS3-NAND] found TFFS header magic at address 0x80000, version 0x30000
[    1.990000] [TFFS3-NAND] scanning block at address 0xa0000
[    1.990000] [TFFS3-NAND] found TFFS header magic at address 0xa0000, version 0x30000
[    2.010000] [TFFS3-NAND] scanning block at address 0xc0000
[    2.020000] [TFFS3-NAND] found TFFS header magic at address 0xc0000, version 0x30000
[    2.040000] [TFFS3-NAND] scanning block at address 0xe0000
[    2.040000] [TFFS3-NAND] found TFFS header magic at address 0xe0000, version 0x30000
[    2.060000] [TFFS3-NAND] scanning block at address 0x100000
[    2.060000] [TFFS3-NAND] found TFFS header magic at address 0x100000, version 0x30000
[    2.080000] [TFFS3-NAND] scanning block at address 0x120000
[    2.080000] [TFFS3-NAND] found TFFS header magic at address 0x120000, version 0x30000
[    2.100000] [TFFS3-NAND] scanning block at address 0x140000
[    2.110000] [TFFS3-NAND] found TFFS header magic at address 0x140000, version 0x30000
[    2.130000] [TFFS3-NAND] scanning block at address 0x160000
[    2.130000] [TFFS3-NAND] found TFFS header magic at address 0x160000, version 0x30000
[    2.150000] [TFFS3-NAND] scanning block at address 0x180000
[    2.150000] [TFFS3-NAND] found TFFS header magic at address 0x180000, version 0x30000
[    2.170000] [TFFS3-NAND] scanning block at address 0x1a0000
[    2.180000] [TFFS3-NAND] found TFFS header magic at address 0x1a0000, version 0x30000
[    2.190000] [TFFS3-NAND] scanning block at address 0x1c0000
[    2.200000] [TFFS3-NAND] found TFFS header magic at address 0x1c0000, version 0x30000
[    2.220000] [TFFS3-NAND] scanning block at address 0x1e0000
[    2.220000] [TFFS3-NAND] found TFFS header magic at address 0x1e0000, version 0x30000
[    2.240000] [TFFS3-NAND] scanning block at address 0x200000
[    2.240000] [TFFS3-NAND] found TFFS header magic at address 0x200000, version 0x30000
[    2.260000] [TFFS3-NAND] scanning block at address 0x220000
[    2.270000] [TFFS3-NAND] found TFFS header magic at address 0x220000, version 0x30000
[    2.280000] [TFFS3-NAND] scanning block at address 0x240000
[    2.290000] [TFFS3-NAND] found TFFS header magic at address 0x240000, version 0x30000
[    2.310000] [TFFS3-NAND] scanning block at address 0x260000
[    2.310000] [TFFS3-NAND] found TFFS header magic at address 0x260000, version 0x30000
[    2.330000] [TFFS3-NAND] scanning block at address 0x280000
[    2.330000] [TFFS3-NAND] found TFFS header magic at address 0x280000, version 0x30000
[    2.350000] [TFFS3-NAND] scanning block at address 0x2a0000
[    2.360000] [TFFS3-NAND] found TFFS header magic at address 0x2a0000, version 0x30000
[    2.370000] [TFFS3-NAND] scanning block at address 0x2c0000
[    2.380000] [TFFS3-NAND] found TFFS header magic at address 0x2c0000, version 0x30000
[    2.400000] [TFFS3-NAND] scanning block at address 0x2e0000
[    2.400000] [TFFS3-NAND] found TFFS header magic at address 0x2e0000, version 0x30000
[    2.420000] [TFFS3-NAND] scanning block at address 0x300000
[    2.420000] [TFFS3-NAND] found TFFS header magic at address 0x300000, version 0x30000
[    2.440000] [TFFS3-NAND] scanning block at address 0x320000
[    2.450000] [TFFS3-NAND] found TFFS header magic at address 0x320000, version 0x30000
[    2.460000] [TFFS3-NAND] scanning block at address 0x340000
[    2.470000] [TFFS3-NAND] found TFFS header magic at address 0x340000, version 0x30000
[    2.490000] [TFFS3-NAND] scanning block at address 0x360000
[    2.490000] [TFFS3-NAND] found TFFS header magic at address 0x360000, version 0x30000
[    2.510000] [TFFS3-NAND] scanning block at address 0x380000
[    2.510000] [TFFS3-NAND] found TFFS header magic at address 0x380000, version 0x30000
[    2.530000] [TFFS3-NAND] scanning block at address 0x3a0000
[    2.540000] [TFFS3-NAND] found TFFS header magic at address 0x3a0000, version 0x30000
[    2.550000] [TFFS3-NAND] scanning block at address 0x3c0000
[    2.560000] [TFFS3-NAND] found TFFS header magic at address 0x3c0000, version 0x30000
[    2.580000] [TFFS3-NAND] scanning block at address 0x3e0000
[    2.580000] [TFFS3-NAND] found TFFS header magic at address 0x3e0000, version 0x30000
[    2.600000] [TFFS3-NAND] Initialisation successful, 32/32 NAND blocks active, fill rate 8%
[    2.610000] TFFS: tiny flash file system driver. GPL (c) AVM Berlin (Version 3.0)
[    2.610000] Adam2 environment variables API installed.
[    2.620000] [simple-profiling]: 2 performance counters implemented, NEW_34K
[    2.630000] Enable Performance Counter 0 for Data cache load/stores (User-Mode enabled Supervisor-Mode enabled Kernel-Mode enabled Exeption-Mode disable)
[    2.640000] Setup tcs=0x1 current_tc_mask=0x1, reg=0
[    2.640000] [simple-profiling]: 2 performance counters implemented, NEW_34K
[    2.650000] Enable Performance Counter 1 for Data cache load/store misses (User-Mode enabled Supervisor-Mode enabled Kernel-Mode enabled Exeption-Mode disable)
[    2.670000] Setup tcs=0x1 current_tc_mask=0x1, reg=1
[    2.670000] AVM Simple Profiling enabled Version 3.0
[    2.680000] {avmnet_cfg_netinit}
[    2.680000] [avmnet] No config found for HWRev 209, HWSubRev 1, Profile-ID 0, trying base config for HWSubRev
[    2.690000] [avmnet] No config found for HWRev 209, HWSubRev 1, trying base config for HWRev
[    2.700000] [avmnet] [avmnet_swi_7port_init] Init on module swi_vr9 called.
[    2.700000] [avmnet] [fix_phy_clock_config]: Could not read external PHY clock pin data from avm_hw_config!
[    2.910000] Loading AVM Net Common Datapath Driver for 7Port Switch......
[    2.920000] [ppe_eth_init] init_hw()
[    2.920000] [init_hw] ppe_hw_init=0xff successful
[    2.930000] [ppe_eth_init] ifx_proc_file_create()
[    2.930000] [ppe_eth_init] dma_setup_init()
[    2.940000] [avmnet] [avmnet_swi_7port_disable_learning] Configuring CPU-port to receive all unknown unicast frames 0x7b
[    2.950000] [avmnet] [avmnet_swi_7port_disable_learning] Configuring CPU-port to receive all unknown multicast frames 0x7b
[    4.410000] [avm_pa_multiplexer_init] start
[    4.420000] [avm_pa_multiplexer_init] init complete
[    4.420000] [avm_pa_multiplexer_register_instance]
[    4.420000]  add:avmnet_7port_pce_add_session+0x0/0x5a0
[    4.420000]  remove:avmnet_7port_pce_remove_session+0x0/0x80
[    4.440000] kernel_init: basic setup done
[    4.450000] SQUASHFS error: Can't find a SQUASHFS superblock on mtdblock3
[    4.450000] yaffs: dev is 32505859 name is "mtdblock3" ro
[    4.460000] yaffs: passed flags ""
[    4.480000] VFS: Mounted root (yaffs filesystem) readonly on device 31:3.
[    4.490000] Freeing unused kernel memory: 212k freed
[    4.540000] trying /sbin/init
init started: BusyBox v1.24.2 (2017-05-13 17:24:06 CEST)
[    4.740000] [squashfs] use zip compression
[VR9-flash] -- Test --
mount: mounting proc on /proc failed: Device or resource busy
tar: removing leading '/' from member names
source files in group 0 ...
/etc/init.d/S00-signal    /etc/init.d/S05-watchdog  /etc/init.d/S09-config
/etc/init.d/S01-head      /etc/init.d/S06-logging   /etc/init.d/S09-rtc
/etc/init.d/S02-led       /etc/init.d/S08-tffs
processing [    5.160000] TFFS Name Table K
processing /etc/init.d/S01-head
processing /etc/init.d/S02-led
[    5.950000] [module-alloc-by-name] give 0x17000 bytes at 0x81101000 to module 'led_modul_Fritz_Box_HW209' (0x73d000 bytes left)
[    5.960000] led_modul_Fritz_Box_HW209: module license '
[    5.960000] (C) Copyright 2012 by AVM
[    5.960000] ' taints kernel.
[    5.970000] Disabling lock debugging due to kernel taint
[    6.000000] [LED] use GPIO 6 for 'gpio_avm_led_power'
[    6.010000] [LED] use GPIO 5 for 'gpio_avm_led_power_red'
[    6.010000] [LED] use GPIO 34 for 'gpio_avm_led_internet'
[    6.020000] [LED] use GPIO 15 for 'gpio_avm_led_dect'
[    6.020000] [LED] use GPIO 0 for 'gpio_avm_led_wlan'
[    6.030000] [LED] use GPIO 35 for 'gpio_avm_led_info'
[    6.030000] [BUTTON] use GPIO 1 for 'gpio_avm_button_wlan'
[    6.040000] [BUTTON] use GPIO 2 for 'gpio_avm_button_dect'
[    6.040000] [register_bug_debug_table] name='led-modul' 0x8110b764 - 0x8110b778
processing /etc/init.d/S05-watchdog
[    6.060000] AVM_WATCHDOG: System Init UEberwachung 120 Sekunden
processing /etc/init.d/S06-logging
processing /etc/init.d/S08-tffs
mknod: /var/flash/ar7.cfg: File exists
P-Defaults: do nothing
processing /etc/init.d/S09-config
processing /etc/init.d/S09-rtc
[    6.540000] [module-alloc-by-name] give 0x2000 bytes at 0x81118000 to module 'rtc_avm' (0x73b000 bytes left)
[    6.570000] rtc-avm rtc-avm.0: rtc core: registered avm as rtc0
[    6.570000] [avm-rtc]: avm_rtc_probe: register: ret=0x8736bc00
[    6.580000] [avm-rtc]: avm_rtc_probe: success
executing files in group 0 ...
/etc/init.d/E05-basemodules
executing /etc/init.d/E05-basemodules
group 0 done ...
source files in group 1 ...
/etc/init.d/S10-html        /etc/init.d/S12-default
/etc/init.d/S10-vm          /etc/init.d/S15-filesys
/etc/init.d/S11-config_def  /etc/init.d/S17-capi
/etc/init.d/S11-piglet      /etc/init.d/S17-tam
processing /etc/init.d/S10-html
processing /etc/init.d/S10-vm
processing /etc/init.d/S11-config_def
processing /etc/[    6.750000]
[    6.750000] [avm_debug] standard kernel-messages
init.d/S11-piglet
[    6.780000] [module-alloc-by-name] give 0xe000 bytes at 0x8111a000 to module 'Piglet_noemif' (0x72d000 bytes left)
[    6.790000] [module-alloc-by-name] 0xe000 bytes used, 0xf954 bytes expected
[    6.810000] set_hw_gpio: gpio_avm_dect_reset = 33
[    6.820000] set_hw_gpio: gpio_avm_dect_rd = 8
[    6.820000] [piglet]use settings for 209(2 gpios from hw_config)
[    6.820000]
[    6.910000] [piglet]patch_dectfw: c021b000, totallen = 42136(a498)
[    6.910000] [piglet]patch_dectfw: patch_adress: a0 max_len: 26 with Version 2 Len: 17
[    6.920000] [piglet]patch_dectfw: RFPI tag found 02965ff4f0
[    6.930000] [piglet]patch_dectfw: dectmode 19
[    6.940000]
[    6.940000]
[    6.940000] [piglet]===== shared usage of UART (DECT and CONSOLE) - unusual characters shown: ====
[    6.940000]
[ ད�5R�[    9.980000] <FE>d<FE><FE>
[   10.530000] [piglet]dect_loader144xx(first): timeout in state dect_wait_for_ack
[   10.530000] [piglet]dect_loader144xx: fast-bootmode
[   11.600000] [1]system-load 1  loadavg 0.23 0.5 0.2 - 36 tasks:79 % curr:busybox(37 %) max:busybox(37 %, pid:287), readytorun: 3, pgfault 803/s (max 1 avg 0.0)
[   12.530000] [piglet]dect_loader144xx: fast-bootmode
[   13.580000] [0]system-load 2  loadavg 0.23 0.5 0.2 - 36 tasks:14 % curr:busybox(14 %) max:busybox(14 %, pid:287), readytorun: 3, pgfault 590/s (max 2 avg 1.9)
[   15.150000] [piglet]dect_loader144xx: fast-bootmode
[   17.140000] [piglet]dect_loader144xx: fast-bootmode
[   19.750000] [piglet]dect_loader144xx: fast-bootmode
[   21.730000] [piglet]dect_loader144xx: fast-bootmode
[   23.780000] [0]system-load 5  loadavg 0.73 0.16 0.5 - 36 tasks:98 % curr:busybox(98 %) max:busybox(98 %, pid:287), readytorun: 3, pgfault 0/s (max 0 avg 0.0)
[   24.350000] [piglet]dect_loader144xx: fast-bootmode
[   25.420000] [1]system-load 3  loadavg 0.99 0.23 0.7 - 36 tasks:11 % curr:busybox(11 %) max:busybox(11 %, pid:287), readytorun: 3, pgfault 0/s (max 0 avg 0.0)
[   26.350000] [piglet]dect_loader144xx: fast-bootmode
[   26.410000] [piglet]dect144xx_file_process: error on upload firstloader '/lib/modules/dectfw_firstlevel_441.hex'
[   26.430000]
[   26.430000]
[   26.430000]
[   26.430000]
[   26.430000]
[   26.430000]
[   26.430000]
[   26.430000] [piglet]===== end of shared usage of UART (DECT and CONSOLE) ====
[   26.430000] Call Trace:
[   26.440000] [<8002a068>] dump_stack+0x8/0x40
[   26.450000] [<800607e4>] panic+0x64/0x1a0
[   26.450000] [<c0180228>] init_module+0x228/0x8ec [Piglet_noemif]
[   26.460000] [<80011a9c>] do_one_initcall+0x3c/0x260
[   26.460000] [<800a3318>] sys_init_module+0xd8/0x280
[   26.470000] [<800059dc>] stack_done+0x20/0x40
[   26.470000]
[   26.470000] Kernel panic - not syncing: [piglet]bye bye - can't load dect-fw!
[   26.470000]
[   26.480000] Rebooting in 5 seconds..
Gleiches verhalten bei zus. Auswahl von
Removal Patches -> Remove DECT
Other Patches -> Disable console on Serial Port (ist wohl das login tty gemeint)
Relevante Auszüge:
F.OS 6.30 orig, RXi auf 3.3V getrieben:
[    7.170000][0] [piglet]patch_dectfw: RFPI tag found 02965ff4f0
[    7.170000][0] [piglet]patch_dectfw: dectmode 19
[    7.200000][0] [piglet]dect_loader144xx: slow-bootmode
[    8.360000][0] [piglet]dect_loader144xx: error: no error code received
[    8.940000][0] [piglet]dect_loader144xx: slow-bootmode
[   10.000000][0] [piglet]dect_loader144xx: error: no error code received
[   10.580000][0] [piglet]dect_loader144xx: slow-bootmode
[   11.650000][0] [piglet]dect_loader144xx: error: no error code received
[   12.240000]
[   12.240000]
[   12.240000]
[   12.240000]
[   12.240000]
[   12.240000]
[   12.240000]
[   12.240000] [piglet]===== end of shared usage of UART (DECT and CONSOLE) ====
[   12.240000] Call Trace:
[   12.260000] [<8002a068>] dump_stack+0x8/0x40
[   12.260000] [<800607e4>] panic+0x64/0x1a0
[   12.270000] [<c0180228>] init_module+0x228/0x8ec [Piglet_noemif]
[   12.270000] [<80011a9c>] do_one_initcall+0x3c/0x260
[   12.280000] [<800a3318>] sys_init_module+0xd8/0x280
[   12.280000] [<800059dc>] stack_done+0x20/0x40
[   12.290000]
[   12.290000] Kernel panic - not syncing: [piglet]bye bye - can't load dect-fw!
[   12.290000]
[   12.300000] Rebooting in 5 seconds
Freetz trunk, r14252 (Basis 6.30), RXi frei (High-Z):
[    6.970000] [module-alloc-by-name] give 0xe000 bytes at 0x8111a000 to module 'Piglet_noemif' (0x72d000 bytes left)
[    6.980000] [module-alloc-by-name] 0xe000 bytes used, 0xf954 bytes expected
[    7.000000] set_hw_gpio: gpio_avm_dect_reset = 33
[    7.010000] set_hw_gpio: gpio_avm_dect_rd = 8
[    7.010000] [piglet]use settings for 209(2 gpios from hw_config)
[    7.010000]
[    7.080000] [piglet]patch_dectfw: c021b000, totallen = 42136(a498)
[    7.080000] [piglet]patch_dectfw: patch_adress: a0 max_len: 26 with Version 2 Len: 17
[    7.090000] [piglet]patch_dectfw: RFPI tag found 02965ff4f0
[    7.100000] [piglet]patch_dectfw: dectmode 19
[    7.110000]
[    7.110000]
[    7.110000] [piglet]===== shared usage of UART (DECT and CONSOLE) - unusual characters shown: ====
[    7.110000]
[ ད�5R�[   10.150000] <FE>d<FE><FE>
[   10.700000] [piglet]dect_loader144xx(first): timeout in state dect_wait_for_ack
[   10.700000] [piglet]dect_loader144xx: fast-bootmode
[   11.760000] [0]system-load 2  loadavg 0.45 0.10 0.3 - 36 tasks:77 % curr:busybox(37 %) max:busybox(37 %, pid:287), readytorun: 3, pgfault 693/s (max 1 avg 1.0)
[   13.330000] [piglet]dect_loader144xx: fast-bootmode
[   14.400000] [1]system-load 1  loadavg 0.45 0.10 0.3 - 36 tasks:18 % curr:busybox(18 %) max:busybox(18 %, pid:287), readytorun: 3, pgfault 684/s (max 1 avg 1.0)
[   15.330000] [piglet]dect_loader144xx: fast-bootmode
[   17.940000] [piglet]dect_loader144xx: fast-bootmode
[   19.920000] [piglet]dect_loader144xx: fast-bootmode
[   21.980000] [0]system-load 5  loadavg 0.84 0.19 0.6 - 36 tasks:72 % curr:busybox(72 %) max:busybox(72 %, pid:287), readytorun: 3, pgfault 0/s (max 0 avg 0.0)
[   22.540000] [piglet]dect_loader144xx: fast-bootmode
[   24.530000] [piglet]dect_loader144xx: fast-bootmode
[   27.140000] [piglet]dect_loader144xx: fast-bootmode
[   27.200000] [piglet]dect144xx_file_process: error on upload firstloader '/lib/modules/dectfw_firstlevel_441.hex'
[   27.230000]
[   27.230000]
[   27.230000]
[   27.230000]
[   27.230000]
[   27.230000]
[   27.230000]
[   27.230000] [piglet]===== end of shared usage of UART (DECT and CONSOLE) ====
[   27.230000] Call Trace:
[   27.240000] [<8002a068>] dump_stack+0x8/0x40
[   27.250000] [<800607e4>] panic+0x64/0x1a0
[   27.250000] [<c0180228>] init_module+0x228/0x8ec [Piglet_noemif]
[   27.260000] [<80011a9c>] do_one_initcall+0x3c/0x260
[   27.260000] [<800a3318>] sys_init_module+0xd8/0x280
[   27.270000] [<800059dc>] stack_done+0x20/0x40
[   27.270000]
[   27.270000] Kernel panic - not syncing: [piglet]bye bye - can't load dect-fw!
[   27.270000]
[   27.280000] Rebooting in 5 seconds..
@qwertz.asdfgh:
Angesichts dessen könnte es sogar sein, daß irgendeine Zeile in der "/etc/inittab" vom Freetz am Ende die Schuld trägt ... wenn dieses "Sharen" absichtlich erfolgt und der Datenübertragung dient (das "unusual characters shown:" zeigt m.E., daß dieses Verhalten erwartet wird), dann könnte eine Änderung durch Freetz an dieser Stelle schon dazu führen (bei "controlling tty" für "/sbin/init"), daß die Daten nicht wie erwartet auftauchen und damit der DECT-Teil nicht richtig initialisiert wird (das "timeout in state dect_wait_for_ack" liest sich ja praktisch so) und die 3,5 bis 4 Sekunden Wartezeit davor deuten m.E. auch in diese Richtung.
Ich habe zwar auch keine Idee, warum da ein UART zwischen der Console und irgendeinem DECT-Chip geshared werden sollte für die Übertragung von Nutzdaten, aber vielleicht reichten irgendwelche anderen Pins nicht aus oder das PCB-Layout ist so leichter zu realisieren oder irgendein Chip kann kein I2C oder was auch immer ... es ist schon komisch, aber offenbar Absicht, wie die Zeichenketten im Treiber zeigen.
Ich habe zwar eine 7412 zum Testen, aber eben kein echtes Interesse an Freetz-Images und mit der 6490 im Moment auch genug andere Aufgaben vor der Brust ... da bleibt praktisch keine Zeit, so etwas in Ruhe zu testen bzw. der Build-Prozess ist mir zu stressig, weil auch mein Freetz-Fork im Moment mit einigen Patches und "version bumps" durch @er13 für einige Pakete kollidiert und erst mal ein paar Anpassungen bräuchte, nachdem ich den dummerweise synchronisiert habe mit dem Upstream. Wenn jemand fertige Images für die 7412 hat, teste ich die gerne ... aber selbst welche zu erzeugen, ist mir zu anstrengend und ich gehöre auch nicht zu dem Klientel, das Freetz-Images benutzt oder braucht, damit ist das eigene Interesse erst recht nicht vorhanden.
Freetz bootet
Die 7412 bootet Freetz r14252, wenn jegliche Initialisierung von Telefon-verwandten Kernel Modulen ausgelassen wird.
ROM VER: 1.1.4
CFG 06
NAND
NAND Read OK
Eva_AVM >
Eva_AVM >printenv
HWRevision            209
HWSubRevision         1
annex                 B
autoload              yes
bootserport           tty0
linux_fs_start        1
memsize               0x08000000
mtd2                  0x0,0x40000
mtd4                  0x0,0x200000
prompt                Eva_AVM
ptest
Eva_AVM >go
Lantiq xDSL CPE VR9
[    0.000000] Writing ErrCtl register=00059a40
[    0.000000] Readback ErrCtl register=00059a40
[    1.300000] avm_net_trace: Up and running.
[    1.300000] [loadcontrol] set auto - scale=1
[    1.310000] AVM_WATCHDOG: Watchdog Driver for AR7 Hardware (Version 1.0, build: Oct 12 2015 17:48:03)
[    1.340000] Lantiq Thermal Sensor driver, version 1.0.3, (c) 2001-2013 Lantiq Deutschland GmbH
[    1.360000] loop: module loaded
[    1.380000] Generic platform RAM MTD, (c) 2004 Simtec Electronics
[    1.390000] ifx_hsnand_init: ifx_hsnand_chip_init(0)
[    1.480000] [ifx_hsnand_command] read block failed (column: 0x800 page: 0xc000)
[    1.530000]
[    1.530000]   >> The following table summarize all badblocks to visualize the distribution
[    1.530000]   block [ start | count | size/kB ] (start block, number of blocks)
[    1.530000]   ---------------------------------
[    1.570000] 0x000000440000-0x000000840000 : "reserved-kernel"
[    1.580000] {ifx_mtd_add_notifier} name reserved-kernel
[    1.580000] 0x000000840000-0x000003840000 : "reserved-filesystem"
[    1.590000] {ifx_mtd_add_notifier} name reserved-filesystem
[    1.600000] {ifx_mtd_add_notifier} name kernel
[    1.610000] {ifx_mtd_add_notifier} name filesystem
[    1.620000] {ifx_mtd_add_notifier} name config
[    1.630000] {ifx_mtd_add_notifier} name nand-filesystem
[    1.640000] {ifx_mtd_add_notifier} name urlader
[    1.650000] {ifx_mtd_add_notifier} name nand-tffs
[    1.660000] Lantiq SSC driver, version 2.4.1, (c) 2001-2013 Lantiq Deutschland GmbH
[    1.670000] ifx_spi_flash_init: Found no serial flash device
[    1.680000] tun: (C) 1999-2004 Max Krasnyansky <[email protected]>
[    1.690000] IFX SWITCH API, Version 1.1.8.5
[    1.690000] SWAPI: Registered character device [switch_api] with major no [81]
[    1.700000] Switch API: PCE MicroCode loaded !!
[    1.700000] res = 87925500
[    1.710000] CAPI Subsystem Rev 1.1.2.8
[    1.720000] [loadcontrol]module avm_pa registered
[    1.730000] TCP cubic registered
[    1.740000] NET: Registered protocol family 10
[    1.740000] IPv6 over IPv4 tunneling driver
[    1.750000] NET: Registered protocol family 8
[    1.760000] KOAM is loaded successfully.
[    1.760000] l2tp_core: L2TP core driver, V2.0
[    1.770000] l2tp_netlink: L2TP netlink interface
[    1.780000] l2tp_ip6: L2TP IP encapsulation support for IPv6 (L2TPv3)
[    1.790000] 802.1Q VLAN Support v1.8 Ben Greear <[email protected]>
[    1.810000] [prepare_log_proc] TFFS version 2 not running
[    1.820000] [TFFS3-NAND] scanning block at address 0x0
[    1.870000] [TFFS3-NAND] scanning block at address 0x20000
[    1.870000] [TFFS3-NAND] found TFFS header magic at address 0x20000, version 0x30000
[    1.920000] [TFFS3-NAND] found TFFS header magic at address 0x40000, version 0x30000
[    1.960000] [TFFS3-NAND] scanning block at address 0x60000
[    1.960000] [TFFS3-NAND] found TFFS header magic at address 0x60000, version 0x30000
[    2.010000] [TFFS3-NAND] scanning block at address 0x80000
[    2.010000] [TFFS3-NAND] found TFFS header magic at address 0x80000, version 0x30000
[    2.050000] [TFFS3-NAND] scanning block at address 0xa0000
[    2.060000] [TFFS3-NAND] found TFFS header magic at address 0xa0000, version 0x30000
[    2.100000] [TFFS3-NAND] scanning block at address 0xc0000
[    2.100000] [TFFS3-NAND] found TFFS header magic at address 0xc0000, version 0x30000
[    2.150000] [TFFS3-NAND] scanning block at address 0xe0000
[    2.150000] [TFFS3-NAND] found TFFS header magic at address 0xe0000, version 0x30000
[    2.190000] [TFFS3-NAND] scanning block at address 0x100000
[    2.200000] [TFFS3-NAND] found TFFS header magic at address 0x100000, version 0x30000
[    2.240000] [TFFS3-NAND] scanning block at address 0x120000
[    2.240000] [TFFS3-NAND] found TFFS header magic at address 0x120000, version 0x30000
[    2.290000] [TFFS3-NAND] scanning block at address 0x140000
[    2.290000] [TFFS3-NAND] found TFFS header magic at address 0x140000, version 0x30000
[    2.330000] [TFFS3-NAND] scanning block at address 0x160000
[    2.340000] [TFFS3-NAND] found TFFS header magic at address 0x160000, version 0x30000
[    2.380000] [TFFS3-NAND] scanning block at address 0x180000
[    2.390000] [TFFS3-NAND] found TFFS header magic at address 0x180000, version 0x30000
[    2.400000] [TFFS3-NAND] scanning block at address 0x1a0000
[    2.410000] [TFFS3-NAND] found TFFS header magic at address 0x1a0000, version 0x30000
[    2.430000] [TFFS3-NAND] scanning block at address 0x1c0000
[    2.430000] [TFFS3-NAND] found TFFS header magic at address 0x1c0000, version 0x30000
[    2.450000] [TFFS3-NAND] scanning block at address 0x1e0000
[    2.450000] [TFFS3-NAND] found TFFS header magic at address 0x1e0000, version 0x30000
[    2.470000] [TFFS3-NAND] scanning block at address 0x200000
[    2.480000] [TFFS3-NAND] found TFFS header magic at address 0x200000, version 0x30000
[    2.490000] [TFFS3-NAND] scanning block at address 0x220000
[    2.500000] [TFFS3-NAND] found TFFS header magic at address 0x220000, version 0x30000
[    2.520000] [TFFS3-NAND] scanning block at address 0x240000
[    2.520000] [TFFS3-NAND] found TFFS header magic at address 0x240000, version 0x30000
[    2.540000] [TFFS3-NAND] scanning block at address 0x260000
[    2.540000] [TFFS3-NAND] found TFFS header magic at address 0x260000, version 0x30000
[    2.560000] [TFFS3-NAND] scanning block at address 0x280000
[    2.570000] [TFFS3-NAND] found TFFS header magic at address 0x280000, version 0x30000
[    2.580000] [TFFS3-NAND] scanning block at address 0x2a0000
[    2.590000] [TFFS3-NAND] found TFFS header magic at address 0x2a0000, version 0x30000
[    2.610000] [TFFS3-NAND] scanning block at address 0x2c0000
[    2.610000] [TFFS3-NAND] found TFFS header magic at address 0x2c0000, version 0x30000
[    2.630000] [TFFS3-NAND] scanning block at address 0x2e0000
[    2.630000] [TFFS3-NAND] found TFFS header magic at address 0x2e0000, version 0x30000
[    2.650000] [TFFS3-NAND] scanning block at address 0x300000
[    2.660000] [TFFS3-NAND] found TFFS header magic at address 0x300000, version 0x30000
[    2.680000] [TFFS3-NAND] scanning block at address 0x320000
[    2.680000] [TFFS3-NAND] found TFFS header magic at address 0x320000, version 0x30000
[    2.700000] [TFFS3-NAND] scanning block at address 0x340000
[    2.700000] [TFFS3-NAND] found TFFS header magic at address 0x340000, version 0x30000
[    2.720000] [TFFS3-NAND] scanning block at address 0x360000
[    2.730000] [TFFS3-NAND] found TFFS header magic at address 0x360000, version 0x30000
[    2.740000] [TFFS3-NAND] scanning block at address 0x380000
[    2.750000] [TFFS3-NAND] found TFFS header magic at address 0x380000, version 0x30000
[    2.770000] [TFFS3-NAND] scanning block at address 0x3a0000
[    2.770000] [TFFS3-NAND] found TFFS header magic at address 0x3a0000, version 0x30000
[    2.790000] [TFFS3-NAND] scanning block at address 0x3c0000
[    2.790000] [TFFS3-NAND] found TFFS header magic at address 0x3c0000, version 0x30000
[    2.810000] [TFFS3-NAND] scanning block at address 0x3e0000
[    2.820000] [TFFS3-NAND] found TFFS header magic at address 0x3e0000, version 0x30000
[    2.840000] [TFFS3-NAND] Initialisation successful, 32/32 NAND blocks active, fill rate 8%
[    2.850000] TFFS: tiny flash file system driver. GPL (c) AVM Berlin (Version 3.0)
[    2.860000] Adam2 environment variables API installed.
[    2.860000] [simple-profiling]: 2 performance counters implemented, NEW_34K
[    2.870000] Enable Performance Counter 0 for Data cache load/stores (User-Mode enabled Supervisor-Mode enabled Kernel-Mode enabled Exeption-Mode disable)
[    2.880000] Setup tcs=0x1 current_tc_mask=0x1, reg=0
[    2.890000] [simple-profiling]: 2 performance counters implemented, NEW_34K
[    2.890000] Enable Performance Counter 1 for Data cache load/store misses (User-Mode enabled Supervisor-Mode enabled Kernel-Mode enabled Exeption-Mode disable)
[    2.910000] Setup tcs=0x1 current_tc_mask=0x1, reg=1
[    2.910000] AVM Simple Profiling enabled Version 3.0
[    2.920000] {avmnet_cfg_netinit}
[    2.920000] [avmnet] No config found for HWRev 209, HWSubRev 1, Profile-ID 0, trying base config for HWSubRev
[    2.930000] [avmnet] No config found for HWRev 209, HWSubRev 1, trying base config for HWRev
[    2.940000] [avmnet] [avmnet_swi_7port_init] Init on module swi_vr9 called.
[    2.950000] [avmnet] [fix_phy_clock_config]: Could not read external PHY clock pin data from avm_hw_config!
[    3.160000] Loading AVM Net Common Datapath Driver for 7Port Switch......
[    3.160000] [ppe_eth_init] init_hw()
[    3.170000] [init_hw] ppe_hw_init=0xff successful
[    3.170000] [ppe_eth_init] ifx_proc_file_create()
[    3.170000] [ppe_eth_init] dma_setup_init()
[    3.180000] [avmnet] [avmnet_swi_7port_disable_learning] Configuring CPU-port to receive all unknown unicast frames 0x7b
[    3.190000] [avmnet] [avmnet_swi_7port_disable_learning] Configuring CPU-port to receive all unknown multicast frames 0x7b
[    4.660000] [avm_pa_multiplexer_init] start
[    4.660000] [avm_pa_multiplexer_init] init complete
[    4.660000] [avm_pa_multiplexer_register_instance]
[    4.660000]  add:avmnet_7port_pce_add_session+0x0/0x5a0
[    4.660000]  remove:avmnet_7port_pce_remove_session+0x0/0x80
[    4.680000] kernel_init: basic setup done
[    4.690000] SQUASHFS error: Can't find a SQUASHFS superblock on mtdblock3
[    4.690000] yaffs: dev is 32505859 name is "mtdblock3" ro
[    4.700000] yaffs: passed flags ""
[    4.720000] VFS: Mounted root (yaffs filesystem) readonly on device 31:3.
[    4.730000] Freeing unused kernel memory: 212k freed
[    4.780000] trying /sbin/init
init started: BusyBox v1.24.2 (2017-05-14 21:32:04 CEST)
[    4.980000] [squashfs] use zip compression
processing /etc/init.d/S00-signal
processing /etc/init.d/S[    5.420000] TFFS Name Table K
01-head
[    6.230000] [module-alloc-by-name] give 0x17000 bytes at 0x81101000 to module 'led_modul_Fritz_Box_HW209' (0x73d000 bytes left)
[    6.240000] led_modul_Fritz_Box_HW209: module license '
[    6.240000] (C) Copyright 2012 by AVM
[    6.240000] ' taints kernel.
[    6.250000] Disabling lock debugging due to kernel taint
[    6.280000] [LED] use GPIO 6 for 'gpio_avm_led_power'
[    6.290000] [LED] use GPIO 5 for 'gpio_avm_led_power_red'
[    6.290000] [LED] use GPIO 34 for 'gpio_avm_led_internet'
[    6.300000] [LED] use GPIO 15 for 'gpio_avm_led_dect'
[    6.300000] [LED] use GPIO 0 for 'gpio_avm_led_wlan'
[    6.310000] [LED] use GPIO 35 for 'gpio_avm_led_info'
[    6.310000] [BUTTON] use GPIO 1 for 'gpio_avm_button_wlan'
[    6.320000] [BUTTON] use GPIO 2 for 'gpio_avm_button_dect'
[    6.320000] [register_bug_debug_table] name='led-modul' 0x8110b764 - 0x8110b778
[    6.340000] AVM_WATCHDOG: System Init UEberwachung 120 Sekunden
[    6.830000] [module-alloc-by-name] give 0x2000 bytes at 0x81118000 to module 'rtc_avm' (0x73b000 bytes left)
[    6.850000] rtc-avm rtc-avm.0: rtc core: registered avm as rtc0
[    6.860000] [avm-rtc]: avm_rtc_probe: register: ret=0x8736e800
[    6.860000] [avm-rtc]: avm_rtc_probe: success
group 0 done ...
processing /etc/init.d/S11-piglet
processing /etc/init.d/S12-default
processing /etc/init.d/S15-filesys
modprobe: module nand not found in modules.dep
[yaffs] driver is loaded
[yaffs] nand-mtd: mtd5: 011c0000 00020000 "nand-filesystem"
/etc/init.d/rc.S: /etc/init.d/S15-filesys: line 101: usbcfgctl: not found
[    7.140000] yaffs: dev is 32505861 name is "mtdblock5" rw
[    7.150000] yaffs: passed flags ""
[yaffs] Internal Memory assigned @ /var/media/ftp
processing /etc/init.d/S17-capi
processing /etc/init.d/S17-tam
TAM: create directory /data/tam
executing files in group 1 ...
/etc/init.d/E15-device
executing /etc/init.d/E15-device
mknod led c 242
mknod tffs c 243
mknod avm_power c 253
mknod debug c 249
mknod avm_event c 251
mknod capi_oslib c 68
group 1 done ...
source files in group 2 ...
/etc/init.d/S20-modload  /etc/init.d/S21-udev
processing /etc/init.d/S20-modload
Loading /var/flash/freetz ... failed.
Creating /var/flash/freetz ... done.
Loading users, groups and passwords ... done.
Loading hosts ... done.
Loading config ... done.
Loading modules ... done.
processing /etc/init.d/S21-udev
executing files in group 2 ...
group 2 done ...
source files in group 3 ...
/etc/init.d/S30-ledcfg
processing /etc/init.d/S30-ledcfg
executing files in group 3 ...
Jan  1 01:00:08 udevd[489]: specified group 'tty' unknown
Jan  1 01:00:08 udevd[489]: specified group 'dialout' unknown
Jan  1 01:00:08 udevd[489]: specified group 'kmem' unknown
group 3 done ...
source files in group 4 ...
Jan  1 01:00:08 udevd[489]: specified group 'video' unknown
Jan  1 01:00:08 udevd[489]: specified group 'audio' unknown
Jan  1 01:00:08 udevd[489]: specified group 'lp' unknown
Jan  1 01:00:08 udevd[489]: specified group 'disk' unknown
Jan  1 01:00:08 udevd[489]: specified group 'floppy' unknown
Jan  1 01:00:08 udevd[489]: specified group 'cdrom' unknown
Jan  1 01:00:08 udevd[489]: specified group 'tape' unknown
/etc/init.d/S42-ptest     /etc/init.d/S46-usb
/etc/init.d/S44-hostname  /etc/init.d/S48-configd
processing /etc/init.d/S42-ptest
processing /etc/init.d/S44-hostname
processing /etc/init.d/S46-usb
processing /etc/init.d/S48-configd
executing files in group 4 ...
/etc/init.d/E40-dsl   /etc/init.d/E46-net   /etc/init.d/E47-voip
executing /etc/init.d/E40-dsl
[dsl sus] dsl line test calib factory file available
[dsl get xtse] ANNEX=B DSLMODE=0
[dsl get xtse] setting ADSL Annex B/J and VDSL2 oISDN
[dsl get xtse] 10 00 10 40 00 04 01 07
[dsl sus] diagforce enabled
[dsl sus] starting vr9 dsp...
[dsl sus] ANNEX=B DSLMODE=0 DIAGNOSE=no
[   10.310000] [module-alloc-by-name] give 0x2d000 bytes at 0x8111a000 to module 'mei_vr9' (0x70e000 bytes left)
[   10.320000] [module-alloc-by-name] 0x2d000 bytes used, 0x2e094 bytes expected
[   10.390000] [dsl_mei] Lantiq (VRX) DSL CPE MEI driver, version 1.4.4, (c) 2013 Lantiq Deutschland GmbH
[   10.400000] [dsl mei] tried to set GDBG Level to 4
[   10.400000]
[   10.400000] [dsl mei] debug_level=4, Global UsrDbgLevel=4 MEI_DRV UsrDbgLevel=4 MEI_MEI_ACCESS UsrDbgLevel=4
[   10.400000]
[   10.410000] [dsl mei] debug_level=4, Global IntDbgLevel=4 MEI_DRV IntDbgLevel=4 MEI_MEI_ACCESS IntDbgLevel=4
[   10.410000]
[   10.430000] [dsl_vr9] AVM_MEI_PowerUpDSLSubsystem enable power domain 'DSL + DFE'
[   10.430000] [AVM_MEI_PowerUpDSLSubsystem] power up 'PPE TC, PPE EMA, LEDC, DFEV1, DFEV0'
[   10.460000] [dsl_vr9] AVM_MEI_PowerUpDSLSubsystem unreset 'DSL, DFE, AFE, VOICE, DSLTC, ARC'
[   10.460000] spi_clc=0x00000200
[dsl sus] loaded vr9 mei driver: mei_vr9.ko with params: , avmDslDiagEnabled=1
[   10.540000] [module-alloc-by-name] give 0x4b000 bytes at 0x81147000 to module 'dsl_vr9' (0x6c3000 bytes left)
[   10.550000] [module-alloc-by-name] 0x4b000 bytes used, 0x4baf0 bytes expected
[   10.640000] [dsl drv] Lantiq CPE API Driver version: DSL CPE API V4.16.6-pd1
[   10.650000] [dsl drv] Predefined debug level: 4
[   10.650000] [dsl drv] dynamically registered major number 238 for dsl_vr9
[dsl sus] loaded vr9 dsl driver: .ko with params:
[dsl sus] created vr9 dsl device node /dev/dsl_vr9/0 (major: 238 , minor: 0)
[dsl sus] created vr9 mei device node /dev/mei_vr9 (major: 239 , minor: 0)
[dsl sus] invoke /sbin/notify_avmnet --broadband_type DSL hw_start_tm_ptm
[   10.750000] [module-alloc-by-name] give 0x27000 bytes at 0x81192000 to module 'ifxmips_ppa_datapath_vr9_e5' (0x69c000 bytes left)
[   10.810000] Loading E5 (MII0/1) driver ......
[   10.820000] drivers/net/avm_cpmac/switch/ifx/vr9/ifxmips_ppa_datapath_vr9_e5.c:3243:init_local_variables: [init_local_variables] g_eth_wan_mode=0
[   10.820000]
[   10.840000] drivers/net/avm_cpmac/switch/ifx/vr9/ifxmips_ppa_datapath_vr9_e5.c:3302:init_local_variables: g_wan_itf=0x80, g_wanqos_en=8
[   10.840000]
[   10.870000] CPU_TO_WAN_TX_DESC_BASE[0] =0xbe227400
[   10.870000] [avmnet] [avmnet_swi_7port_disable_learning] Configuring CPU-port to receive all unknown unicast frames 0x7b
[   10.880000] [avmnet] [avmnet_swi_7port_disable_learning] Configuring CPU-port to receive all unknown multicast frames 0x7b
[   10.890000] [ppe_e5_init] Succeeded!
[   10.900000] PPE datapath driver info:
[   10.900000]   Version ID: 64.3.3.1.0.1.1
[   10.900000]   Family    : VR9
[   10.900000]   DR Type   : Normal Data Path | Indirect-Fast Path
[   10.900000]   Interface : MII0 | MII1
[   10.900000]   Mode      : Routing
[   10.900000]   Release   : 0.1.1
[   10.920000] PPE firmware info:
[   10.920000]   Version ID: 7.5.2.11.1
[   10.920000]   Family    : VR9
[   10.920000]   FW Package: D5
[   10.920000]   Release   : 2.11.1
[   10.920000] PPE firmware feature:
[   10.920000]   ATM/PTM TC-Layer Bonding        Support
[   10.920000]   L2 Trunking                     Support
[   10.920000]   Packet Acceleration             Support
[   10.920000]   IPv4                            Support
[   10.920000]   IPv6                            Support
[   10.920000]   6RD                             Support
[   10.920000]   DS-Lite                         Support
FIO_MEI_FW_MODE_STAT_GET failed!: Operation not permitted
[dsl sus] started dsl_control (configuration: -i10_00_10_40_00_04_01_07 -f/lib/modules/dsp_vr9/vr9-B-dsl.bin -n/etc/dsl/notify/dsl_notify.sh  )
[dsl sus] started dsl_monitor
[dsl sus] ....vr9 dsp started
executing /etc/init.d/E46-net
[   11.720000] activating IRQ mode
[   11.730000] requesting IRQ
[   11.730000] request_irq
[   11.730000] usedIrq: 57 | usedIsrHandler: 81129820 | usedFlags: 0x4000 | pUsedDevName: mei_vr9 | pUsedDevId: -2037474176
[   11.740000] IRQ requested ok
[   11.740000] MEI_DRV: MEI_IfxRequestIrq(IRQ = 57, .., ), lock = 1
check this C0]
[   11.750000] about to check device status
[   11.760000] MEI_DRV[00]: INIT DEVICE, phy addr = 0x1E116000, virt addr = 0xBE116000 IRQ = 57
[   11.760000]
[   11.950000] [module-alloc-by-name] give 0x184000 bytes at 0x811b9000 to module 'kdsldmod' (0x518000 bytes left)
[   11.960000] [module-alloc-by-name] 0x184000 bytes used, 0x184a08 bytes expected
[   12.900000] [0]system-load 2  loadavg 0.38 0.8 0.3 - 49 tasks:53 % curr:busybox(9 %) max:init(32 %, pid:1), readytorun: 3, pgfault 2350/s (max 2 avg 1.0)
[   15.090000] kdsldmod: init start (Jul 10 2015 13:44:20) sizeof(struct sk_buff)=440
[   15.100000] userman: device registerd (userman_url) with major=232
[   15.110000] kdsld: ttychannel: ldisc 8 registered
[   15.110000] PCP_NL: PCP netlink interface
[   15.110000] kdsldmod: init done
Jan  1 01:00:16 l2tpv3d[670]: starting.
Jan  1 01:00:16 l2tpv3d[670]: verbose: DISABLED
[   17.710000] [avm_power] eth: port 0 force normal  CON t0
[   17.720000] [avm_power] eth: port 1 force throttle  CON t0
[   17.720000] [avmnet] [avmnet_power_config] tried to set mode for port 1
[   17.730000] [avm_power] : ethernet switch failed
[   17.730000] [avm_power] eth: port 2 force throttle  CON t0
[   17.740000] [avmnet] [avmnet_power_config] tried to set mode for port 2
[   17.740000] [avm_power] : ethernet switch failed
[   17.750000] [avm_power] eth: port 3 force throttle  CON t0
[   17.750000] [avmnet] [avmnet_power_config] tried to set mode for port 3
[   17.760000] [avm_power] : ethernet switch failed
Jan  1 01:00:17 ctlmgr[677]: WLANLIB: wlan_plugin_init:605: svn revision 2010
Jan  1 01:00:17 ctlmgr[677]: WLANLIB: weak_wlan_check:81: Missing weak 'process_wlanmail'.
Jan  1 01:00:17 ctlmgr[677]: WLANLIB: weak_wlan_check:84: Missing weak 'wlan_enabled_changed'.
Jan  1 01:00:17 ctlmgr[677]: WLANLIB: weak_wlan_check:87: Missing weak 'wlan_wcfgutil_set_output'.
Jan  1 01:00:17 ctlmgr[677]: WLANLIB: weak_wlan_check:88: Missing weak 'wlan_wcfgutil_set_dbg_level'.
AVMMULTID: Starting AVM multid ... done.
[   19.630000] ADDRCONF(NETDEV_UP): lan: link is not ready
rc.wlan: Start WLAN...
WLAND:[00733]:01:00.20/[20.15]:Build = Oct 21 2014 10:59:57
[   20.660000] ADDRCONF(NETDEV_UP): guest: link is not ready
[   20.730000] [module-alloc-by-name] give 0x2e000 bytes at 0x8133d000 to module 'aae' (0x4ea000 bytes left)
[   20.740000] [module-alloc-by-name] 0x2e000 bytes used, 0x2c688 bytes expected
[   20.770000] [avmnet] [avmnet_mcfw_enable] Device eth0 was enabled already
[   20.770000] ADDRCONF(NETDEV_UP): eth0: link is not ready
[   20.790000] device eth0 entered promiscuous mode
Jan  1 01:00:20 dsld[749]: startup ($Revision: 1.160 $$CompileDate: Jul 10 2015 13:43:54 $)
Jan  1 01:00:20 dsld[749]: set_preconfig1
Jan  1 01:00:20 dsld[749]: sync_group in ar7.cfg:
Jan  1 01:00:20 dsld[749]: sync_group:sync_dsl(enabled=1), nr=0
Jan  1 01:00:20 dsld[749]:   vcc[   20.940000] [wlan_config] Given config is:
[   20.950000] [wlan_config]   hw_interface=0 chip_type=3 (kiwi) offload=1 (non)
[   20.950000] [wlan_config] hwrev=209 hwsubrev=1 maca=5c:49:79:XX:XX:XX
[   20.950000] [wlan_config] country=276 reg_domain_a=12 reg_domain_b=34
:1/32
Jan  1 01:00:20 dsld[749[   20.970000] [wlan_eeprom] Calibration data blocks found = 1
]:     dsliface:[   20.980000] [wlan_eeprom] EEPROM #1, type "AR92x7":
[   20.980000] [wlan_eeprom] Customer data="AVM7412_CAL1_V2"
[   20.990000] [wlan_eeprom] MinCCAPwr thresh set to -85,-85
[   20.990000] [wlan_eeprom] Build with ART 0.9b27
[   21.000000] avm_net_trace: New net trace device 'WLAN Management Traffic' registered with minor 128.
internet
Jan  1 01:00:20 dsld[749]:     dsliface:voip
Jan  1 01:00:20 dsld[749]: sync_group: dsl
Jan  1 01:00:20 dsld[749]: sync_dsl is igd_device
Jan  1 01:00:20 dsld[749]: set_preconfig2
Jan  1 01:00:20 dsld[749]: add_vcc_connection: dsl
AVMDSLD: Starting AVM dsld ... done.
executing /etc/init.d/E47-voip
Jan  1 01:00:21 multid[704]: DHCPD on lan:0 skipped, is virtual interface
[   21.230000] [module-alloc-by-name] give 0x5000 bytes at 0x8136b000 to module 'adf' (0x4e5000 bytes left)
[   21.240000] [module-alloc-by-name] 0x5000 bytes used, 0x488c bytes expected
Jan  1 01:00:21 dsld[759]: DSL Mac 5c:49:79:XX:XX:XX
Jan  1 01[   21.270000] kdsld: kdsld_vcc_preunregister: *
:00:21 dsld[759]: VOIP Mac 5c:49:79:XX:XX:XX
Jan  1 01:00:21 dsld[759]: VCC2 Mac 5c:49:79:XX:XX:XX
Jan  1 01:00:21 dsld[759]: VCC3 Mac 5c:49:79:XX:XX:XX
Jan  1 01:00:21 [   21.310000] kdsld: nr_ipv4 0 nr_ipv6 0 nr_vpn 0
dsld[759]: voip: ppptarget voip disabled, ignored
Jan  1 01:00:21 dsld[759]: sync_group(prepare_interfaces): dsl: inet_nr=0
Jan  1 01:00:21 dsld[759]: nach prepare_interfaces: dsld.dsliface_default_inet_nr=0, dsld.dsliface_voip_nr=-1
Jan  1 01:00:21 dsld[759]: get_queue[   21.340000] [module-alloc-by-name] give 0x3000 bytes at 0x81370000 to module 'asf' (0x4e2000 bytes left)
[   21.350000] [module-alloc-by-name] 0x3000 bytes used, 0x326c bytes expected
index: none: not found
Jan  1 01:00:21 dsld[759]: queue 0: prio 0 weight 0 shrate 0 shburst 0 wan
Jan  1 01:00:21 dsld[759]: queue 1: prio 10 weight 0 shrate 0 shburst 0 wan
Jan  1 01:00:21 dsld[759]: queue 2: prio 20 weight 0 shrate 0 shburst 0 wan
Jan  1 01:00:21 dsld[759]: queue 3: prio 30 weight 0 shrate 0 shburst 0 wan
Jan  1 01:00:21 dsld[759]: queue 4: prio 100 weight 90 shrate 0 shburst 0 wan
Jan  1 01:00:21 dsld[759]: queue 5: prio 100 weight 10 shrate 0 shburst 0 wan
Jan  1 01:00:21 dsld[759]: queue 6: prio 200 weight 0 shrate 0 shburst 0 wan
Jan  1 01:00:21 dsld[759]: appl 0: sip-appl result 1
Jan  1 01:00:21 dsld[759]: classifer: local "localmark sip" result 1
Jan  1 01:00:21 dsld[759]: classifer: local "localmark rtp" result 1
Jan  1 01:00:21 dsld[759]: classifer: local "localmark sip_internet" result 1
Jan  1 01:00:21 dsld[759]: classifer: local "localmark rtp_internet" result 1
Jan  1 01:00:21 dsld[759]: classifer: local "localmark sipdns,ntpdns,tr069dns,tr069" result 2
Jan  1 01:00:21 dsld[759]: classifer: local "localmark igmp" result 3
Jan  1 01:00:21 dsld[759]: classifer: local "localmark webdav" result 4
Jan  1 01:00:21 dsld[759]: classifer: local "localmark dns" result 2
Jan  1 01:00:21 dsld[759]: classifer: lan "udp.dport 43962,47806" result 2
Jan  1 01:00:21 dsld[759]: classifer: lan "ip.proto IPv6-ICMP" result 2
Jan  1 01:00:21 dsld[759]: classifer: lan "ip.proto icmp" result 2
Jan  1 01:00:21 dsld[759]: classifer: lan "udp.dport 53" result 2
Jan  1 01:00:21 dsld[759]: classifer: lan "udp.dport 5060" result 5
Jan  1 01:00:21 dsld[759]: classifer: lan "dhcpoption 12 FRIT[   21.500000] kdsld: kdsld_vcc_preregister: predsl1
[   21.500000] kdsld: kdsld_vcc_preregister: vcc->ifaces=(null)
Z!Media* mediatab" result 6
Jan  1 01:00:21 dsld[759]: classifer: lan "ethsrctab mediatab" result 6
Jan  1 01:00:21 dsld[759]: result 0: tos 65535 vprio 65535 queue 5 appl 65535 bridge 65535 forward 65535
Jan  1 01:00:21 dsld[759]: result 1: tos 65535 vprio 65535 queue 2 appl 65535 bridge 65535 forward 65535
Jan  1 01:00:21 dsld[759]: result 2: tos 65535 vprio 65535 queue 1 appl 65535 bridge 65535 forward 65535
Jan  1 01:00:21 dsld[759]: result 3: tos 65535 vprio 65535 queue 0 appl 65535 bridge 65535 forward 65535
Jan  1 01:00:21 dsld[759]: result 4: tos 65535 vprio 65535 queue 6 appl 65535 bridge 65535 forward 65535
Jan  1 01:00:21 dsld[759]: result 5: tos 65535 vprio 65535 queue 2 appl 0 bridge 65535 forward 65535
Jan  1 01:00:21 dsld[759]: result 6: tos 65535 vprio 65535 queue 3 appl 65535 bridge 65535 forward 65535
Jan  1 01:00:21 dsld[759]: interface lo added.
Jan  1 01:00:21 dsld[759]: interface lo up.
Jan  1 01:00:21 dsld[759]: interface tunl0 added.
Jan  1 01:00:21 dsld[759]: i[   21.600000] [module-alloc-by-name] give 0xaa000 bytes at 0x81373000 to module 'ath_hal' (0x438000 bytes left)
[   21.610000] [module-alloc-by-name] 0xaa000 bytes used, 0xa7c60 bytes expected
nterface sit0 added.
Jan  1 01:00:21 dsld[759]: interface eth0 added.
Jan  1 01:00:21 dsld[759]: interface eth0 up.
Jan  1 01:00:21 dsld[759]: interface ptm_vr9 added.
Jan  1 01:00:21 dsld[759]: interface adsl added.
Jan  1 01:00:21 dsld[759]: interface lan added.
Jan  1 01:00:21 dsld[759]: interface lan up.
Jan  1 01:00:21 dsld[759]: interface guest added.
Jan  1 01:00:21 dsld[759]: interface guest up.
Jan  1 01:00:21 dsld[759]: start register_vccs_and_ifaces_on_kdsld for sync_dsl
Jan  1 01:00:21 dsld[759]: setup_dslchannel: ifname=
Jan  1 01:00:21 dsld[759]: kdsld_preregister_vcc: predsl1
Jan  1 01:00:21 dsld[759]: kdsld_preregister_vcc: kdsld_vccidx=0
Jan  1 01:00:21 dsld[759]: notify_due_to_pm
Jan  1 01:00:21 dsld[759]: verbose: DISABLED
Jan  1 01:00:21 ctlmgr[677]: WLANLIB: wland_role_config_init:100: CFG2/API: WLAND configuration file(/var/tmp/wlan_roles) missing.
[   21.750000] ath_hal: 0.9.17.1 (AR5416, AR9380, REGOPS_FUNC, WRITE_EEPROM, TX_DATA_SWAP, RX_DATA_SWAP, 11D)
[   21.780000] [module-alloc-by-name] give 0x8000 bytes at 0x8141d000 to module 'ath_rate_atheros' (0x430000 bytes left)
[   21.780000] [module-alloc-by-name] 0x8000 bytes used, 0x8098 bytes expected
[   21.820000] ath_rate_atheros: Copyright (c) 2001-2005 Atheros Communications, Inc, All Rights Reserved
[   21.920000] [module-alloc-by-name] give 0x12000 bytes at 0x81425000 to module 'ath_dfs' (0x41e000 bytes left)
[   21.930000] [module-alloc-by-name] 0x12000 bytes used, 0x1367c bytes expected
[   21.970000] ath_dfs: Version 2.0.0
[   21.970000] Copyright (c) 2005-2006 Atheros Communications, Inc. All Rights Reserved
[   22.120000] [module-alloc-by-name] give 0x5c000 bytes at 0x81437000 to module 'ath_dev' (0x3c2000 bytes left)
[   22.130000] [module-alloc-by-name] 0x5c000 bytes used, 0x5b890 bytes expected
[   22.420000] ath_dev: Copyright (c) 2001-2007 Atheros Communications, Inc, All Rights Reserved
Jan  1 01:00:22 telefon[811]: use clock_gettime(CLOCK_MONOTONIC)!
Jan  1 01:00:22 telefon[811]: No S0NT!
Jan  1 01:00:22 telefon[811]: NoOldMSNNames
telefon: SIGCHLD PID 813 received!
Jan  1 01:00:22 telefon[811]: kein Capi!
[   23.010000] [module-alloc-by-name] give 0xf7000 bytes at 0x81493000 to module 'umac' (0x2cb000 bytes left)
[   23.020000] [module-alloc-by-name] 0xf7000 bytes used, 0xf7718 bytes expected
Jan  1 01:00:23 ctlmgr[677]: WLANLIB: wland_role_config_init:100: CFG2/API: WLAND configuration file(/var/tmp/wlan_roles) missing.
[   23.940000] [0]system-load 3  loadavg 0.72 0.16 0.5 - 77 tasks:42 % curr:busybox(10 %) max:ctlmgr(17 %, pid:677), readytorun: 5, pgfault 1646/s (max 4 avg 1.7)
[   24.460000] ath_pci: 10.2.85 (Atheros/multi-bss)
[   24.460000] PCI: Enabling device 0000:01:00.0 (0000 -> 0002)
[   24.460000] __ath_attach: Set global_scn[0]
[   24.480000] Green-AP : Green-AP : Attached
[   24.480000]
[   24.480000] ath_get_caps[6180] rx chainmask mismatch actual 3 sc_chainmak 0
[   24.490000] ath_get_caps[6155] tx chainmask mismatch actual 3 sc_chainmak 0
[   24.490000] ic_num_chains=2x2
[   24.500000] _avm_ath_ext_attach_ah:115
[   24.500000] _avm_ath_ext_attach_ieee:97
[   24.510000] ath_attach_dfs[12671] dfsdomain 2
[   24.530000] avm_net_trace: New net trace device 'HW (2.4 + 5 GHz, wifi0)' registered with minor 129.
[   24.540000] Register net trace device succeeded with minor 129 (wifi0).
[   24.540000] wifi0: Atheros ???: mem=0x1c000000, irq=138 hw_base=0xbc000000
[   24.600000] [module-alloc-by-name] give 0x6000 bytes at 0x8158a000 to module 'ath_pktlog' (0x2c5000 bytes left)
[   24.610000] [module-alloc-by-name] 0x6000 bytes used, 0x6654 bytes expected
AVMMULTID: Reloading AVM multid ... done.
group 4 done ...
source files in group 5 ...
executing files in group 5 ...
group 5 done ...
source files in group 6 ...
executing files in group 6 ...
group 6 done ...
source files in group 7 ...
/etc/init.d/S73-capitcp  /etc/init.d/S76-media
processing /etc/init.d/S73-capitcp
processing /etc/init.d/S76-media
executing files in group 7 ...
group 7 done ...
source files in group 8 ...
/etc/init.d/S85-apps
processing /etc/init.d/S85-apps
executing files in group 8 ...
group 8 done ...
source files in group 9 ...
/etc/init.d/S99-tail       /etc/init.d/S99-zzz-rcmod
processing /etc/init.d/S99-tail
Jan  1 01:00:25 multid[704]: DHCPD on lan:0 skipped, is virtual interface
run_clock demon started
[   25.220000] AVM_WATCHDOG: System Init UEberwachung abgeschlossen (101120 ms noch verfuegbar)
[   25.250000] SysRq : Changing Loglevel
[   25.250000] Loglevel set to 4
processing /etc/init.d/S99-zzz-rcmod
Jan  1 01:00:25 ctlmgr[677]: WLANLIB: wland_role_config_init:100: CFG2/API: WLAND configuration file(/var/tmp/wlan_roles) missing.
[   25.740000] [dma_device_write] auto open tx_chan_no:2
rc.mod version freetz-devel-14252M
crond is disabled.
AVM telnetd is disabled.
Starting Freetz webinterface ... done.
swap is disabled.
syslogd is disabled.
Starting inetd ... done.
Jan  1 01:00:27 ctlmgr[677]: WLANLIB: wland_role_config_init:100: CFG2/API: WLAND configuration file(/var/tmp/wlan_roles) missing.
[   27.840000] Register vap net trace device succeeded with minor 131 (ath0).
[   27.840000] Register vap net trace device succeeded with minor 132 (ath0).
[   27.850000] VAP device ath0 created
rc.mod finished.
executing files in group 9 ...
group 9 done ...
System init finished ...
Please press Enter to activate this console. [   31.490000] [module-alloc-by-name] give 0x11000 bytes at 0x81590000 to module 'userman_mod' (0x2b4000 bytes left)
[   31.500000] [module-alloc-by-name] 0x11000 bytes used, 0x121a4 bytes expected
Jan  1 01:00:36 multid[704]: DHCPD on lan:0 skipped, is virtual interface
BusyBox v1.24.2 (2017-05-14 21:32:04 CEST) built-in shell (ash)
Default password detected. Please enter a new password for 'root'.
Changing password for root
New password:
Bad password: too weak
Retype password:
Password for root changed by root
Checking Freetz configuration ... changed.
Writing 402 bytes to /var/flash/freetz ... done.
root@fritz:/var/mod/root#
Patch fuer r14252:
Index: patches/scripts/181-deactivate-piglet.sh
--- patches/scripts/181-deactivate-piglet.sh    (nonexistent)
+++ patches/scripts/181-deactivate-piglet.sh    (working copy)
@@ -0,0 +1,8 @@
+isFreetzType 7270_V1 && return 0
+echo1 "applying piglet remove patch"
+file="$FILESYSTEM_MOD_DIR/etc/init.d/rc.S"
+for file in S11-piglet S17-capi S73-capitcp; do
+    modsed "s/^/#/g" "$FILESYSTEM_MOD_DIR/etc/init.d/$file"
+done
- - - Aktualisiert - - -
Das manuelle Nachladen des Kernel Moduls von der Konsole funktioniert ohne Panic.
root@fritz:/etc/init.d# sleep 3; modprobe Piglet_noemif piglet_dectmode=0x119 dect_secondlevelfile=/lib/modules/dectfw_secondlevel_441.hex dect_firstlevelfile=/lib/modules/dectfw_firstlevel_441.hex
root@fritz:/etc/init.d# dmesg
[ 1395.590000] [module-alloc-by-name] give 0xe000 bytes at 0x815a1000 to module 'Piglet_noemif' (0x2a6000 bytes left)
[ 1395.600000] [module-alloc-by-name] 0xe000 bytes used, 0xf954 bytes expected
[ 1395.630000] set_hw_gpio: gpio_avm_dect_reset = 33
[ 1395.630000] set_hw_gpio: gpio_avm_dect_rd = 8
[ 1395.630000] [piglet]use settings for 209(2 gpios from hw_config)
[ 1395.630000]
[ 1395.690000] [piglet]patch_dectfw: c2af5000, totallen = 42136(a498)
[ 1395.690000] [piglet]patch_dectfw: patch_adress: a0 max_len: 26 with Version 2 Len: 17
[ 1395.700000] [piglet]patch_dectfw: RFPI tag found XXXXXXXX
[ 1395.700000] [piglet]patch_dectfw: dectmode 19
[ 1395.720000]
[ 1395.720000]
[ 1395.720000] [piglet]===== shared usage of UART (DECT and CONSOLE) - unusual characters shown: ====
[ 1395.720000]
[ 1395.720000]
[ 1395.730000] [piglet]dect_loader144xx: slow-bootmode
[ 1396.570000] *
[ 1396.860000] ********************************************
[ 1397.830000] [0]system-load 1  loadavg 1.3 1.1 0.77 - 72 tasks:0 % curr:busybox(0 %) max:busybox(0 %, pid:2321), readytorun: 3, pgfault 64/s (max 5 avg 3.7)
[ 1397.840000] **************************************
[ 1398.700000] [piglet]dect144xx_file_process: upload of '/lib/modules/dectfw_secondlevel_441.hex' successfull
[ 1398.710000]
[ 1398.710000]
[ 1398.710000]
[ 1398.710000]
[ 1398.710000]
[ 1398.710000]
[ 1398.710000]
[ 1398.710000] [piglet]===== end of shared usage of UART (DECT and CONSOLE) ====
[ 1398.710000]
[ 1400.740000] [piglet]TDM: FS: 8005 Hz CLK: 3687120 Hz  (SPITDM)
@PeterPawn
Bei mir steht das auf der Prioritätenliste eigentlich auch ganz unten da bei den entsprechenden Einsatzszenarien Freetz bzw. Freetz-Images nicht von Interesse sind, es ist bzw. war nur reine Neugierde wo die Ursache für die Freetz-Inkompatibilität bei den VRX220-Modellen liegt. Erstaunlich aber, dass es bei dem Freetz-Image welches dir er13 zur Verfügung stellte keine größeren Probleme gab (vom ersten Bootversuch mal abgesehen)...
Wenn das ernst gemeint ist bzw. du wirklich die Zeit dazu erübrigen könntest (sozusagen als "Pausenfüller" :mrgreen:) könnte ich dir Freetz-Images für die 7412 zur Verfügung stellen. Aber evtl. stellt sich auch @ELpf zur Verfügung angepasste und auch aktuellere Versionen (Freetz-Images basierend auf FritzOS 6.83) zu testen (die Ver. 6.30 ist doch schon etwas betagt und es hat sich seitdem einiges getan) die er evtl. auch gleich selbst erstellt. Bei ihm wäre es aufgrund der RS232-Schittstelle auch einfacher bei Misserfolg/Bootloop das Bootlog zu bekommen.
BTW:
Meine eigenen Versuche fanden noch mit FritzOS 6.50 und der 7430 statt i.V.m. Freetz-Trunk r13839, aus dieser Zeit habe ich noch das entsprechende Freetz-Image und habe hier mal die originale /etc/inittab und die aus dem Freetz-Image:
146.06.50:
[highlight]/dev/ttyS0::[/highlight]sysinit:/etc/init.d/rc.S
# Start an "askfirst" shell on ttyS0
/dev/ttyS0::askfirst:-/bin/sh
# Stuff to do before rebooting
[highlight]/dev/ttyS0::[/highlight]shutdown:/bin/sh -c [highlight]/var/post_install[/highlight]
146.06.50-freetz-devel-13839:
[highlight]::[/highlight]sysinit:/etc/init.d/rc.S
# Start an "askfirst" shell on the console (whatever that may be)
[highlight]::[/highlight]shutdown:/bin/sh -c [highlight]/etc/inittab.shutdown[/highlight]
[highlight]::restart:/sbin/init[/highlight]
Und noch ein DIFF für die rc.S:
--- rc.S.avm	2016-05-02 15:33:22.000000000 +0200
+++ rc.S.freetz	2016-07-19 01:27:51.818847000 +0200
@@ -11 +11 @@
-mount -t tmpfs tmpfs /dev
+[ -f /dev/.hotplug-cache ] || mount -o nosuid -t tmpfs dev /dev
@@ -43,0 +44 @@
+echo "processing ${skript}"
@@ -47 +48 @@
-echo "exceute files in group ${gruppe} ...";
+echo "executing files in group ${gruppe} ...";
@@ -49,0 +51 @@
+echo "executing ${skript}"
@@ -51 +53 @@
-echo "exceute ${skript} failed.";
+echo "executing ${skript} failed.";
Das Problem könnte also durch das Fehlen von "/dev/ttyS0" in der 2. Zeile bei den VRX220-Modellen verursacht werden?
Ich weiß es halt auch nicht ... ich stelle mir das im Moment so vor, daß da irgendwie als "Abkürzung" beim Laden von Daten in den DECT-Chip vom Treiber Informationen auf STDOUT oder STDERR (die sind bei AVM halt beide auf "/dev/ttyS0") zu dem Zeitpunkt ausgegeben werden, wo das LKM geladen wird und die irgendwie mit einer Init-Sequenz zum Synchronisieren der DECT-UART-Schnittstelle beginnen, damit die dann "Bescheid weiß", daß da jetzt wichtige Daten kommen, die zu übernehmen sind.
Wenn die wirklich (ohne größere Latches zum Umschalten) an denselben Leitungen hängen (mal elektrische Fragen - wie definierte Pegel - außen vor gelassen), dann könnte so eine Start-Sequenz (ähnlich wie das Prinzip beim Port-Knocking im Netzwerk) ja dazu führen, daß die von einer Schnittstelle ausgegebenen Daten (erst recht dann, wenn da im Normalfall kein weiterer "Verbraucher" vorhanden ist, solange die Schnittstelle nicht weiter bestückt ist) auf der anderen sauber eingelesen werden können - so stelle ich mir diese "shared usage of UART" vor.
Der beim manuellen Laden oben zu sehende "slow mode" (#12) und die dort fehlenden "unusual characters" lassen mich dann vermuten, daß der Treiber irgendwie beim Laden die Umgebung prüft und je nachdem, was er da vorfindet, den direkten Weg über die serielle Schnittstelle nimmt (als "fastmode") oder das irgendwie auf einem anderen Weg überträgt. Der dann ja noch "slower" sein müßte als eine serielle Schnittstelle und da fällt mir dann nur noch ein sehr langsam vom Master getakteter I2C-Bus ein, an dem u.U. auch noch mehr als ein Teilnehmer hängt und wo man vermeiden will, den Bus mit der Übertragung größerer Datenmengen länger zu blockieren für weitere Slaves.
Bei der zweigeteilten Firmware für den DECT-Chip würde ich mir im ersten Teil (das sind ~ 1.800 Byte) so etwas wie einen Loader vorstellen, der dann den größeren Teil (das sind ~ 125 KByte) über die serielle Schnittstelle in Empfang nimmt und daß da auf der Console nur wenige Zeichen und nicht die ganzen 125 KByte angezeigt werden, würde ich auf den verwendeten RS232-Adapter und den eingesetzten Pegelwandler, ggf. noch auf eine andere Taktung als der Adapter sie erwartet, zurückführen.
Aber wie gesagt ... alles nur meine Phantasie und die Überlegung, wie und warum man so etwas machen sollte. Wobei ich die drei Sekunden, die das Laden der 125 KByte im "slow mode" dann dauert, jetzt auch nicht sooo fürchterlich finde ... aber vielleicht wird dieser Bus, über den das dann irgendwie muß, zum Zeitpunkt des Bootens ja auch für irgendetwas anderes gebraucht und darf wirklich nicht so lange belegt sein. Wir können ja mal an AVM schreiben und da nachfragen ... :mrgreen:
Wenn das aber vom Treiber wirklich unbedingt auf "/dev/ttyS0" ausgegeben werden muß, damit das auf dem DECT-Chip am UART-Port ankommt, dann würde das in der "/etc/inittab" beim Freetz-Image nicht zugeordnete Terminal auf "/dev/ttyS0" u.U. genau das sein, was im noch weiter oben zu sehenden Versuch (#10) zu dem "timeout" im "fastmode" führen kann - es kommen einfach keine Daten beim DECT-UART an, weil der Treiber gar nicht wirklich auf "/dev/ttyS0" schreibt (die "dmesg"-Ausgabe oder auch "/dev/console" sind ja nur Duplikate).
Da wäre das Problem mit der bestückten Schnittstelle dann ggf. ein elektrisches (der Pegelwandler ist nicht hochohmig genug bzw. funkt selbst noch dazwischen auf Rx oder Tx) und das Problem ohne die bestückte Schnittstelle dann vielleicht wirklich das fehlende "/dev/ttyS0" in einem Freetz-Image. Einen Versuch ist das allemal wert ... ich weiß auch nicht mehr 100%, was ich damals getestet habe, als ich das Image von @er13 hatte.
Durchaus denkbar, daß ich meine Idee mit dem unmodifizierten Wrapper testen wollte (das war auch zu einem Zeitpunkt, wo es bei einem anderen Modell m.W. wirklich daran lag, daß da der BusyBox im Wrapper irgendwelche Bibliotheken fehlten - iirc war es die libm.so) und daher das Freetz-Image von Hand installierte, genauso wie den Kernel.
Ich würde dann zwar immer noch erwarten, daß die "/etc/inittab" aus dem SquashFS verwendet wird, aber es kann auch gut sein, daß "/sbin/init" direkt beim Aufruf entweder die gesamte Datei einliest und puffert (dann ist es die aus der Wrapper-Partition) oder auch das File-Handle für die Datei dauerhaft offenhält ... dann überlebt das auch ein "pivot_root" und es wird gar nicht und niemals die "/etc/inittab" im SquashFS beim Start verwendet.
Letzteres dürfte nur dann passieren, wenn "init" da die Datei jeweils neu öffnet (wie es einige Shell-Varianten machen und daher nahm/nehme ich auch an, daß das beim "init" genauso läuft, aber man bräuchte ja nur in die Quellen zu sehen) und bei der nächsten Zeile (bzw. am zuvor erreichten Offset in der Datei) mit dem Lesen fortfährt - dann würde das nächste "fopen()" nach dem "pivot_root" halt die aus dem neuen "/etc"-Verzeichnis lesen.
Wobei auch bei AVM ja die Zeilen vor dem Aufruf der "rc.S" ohne "/dev/ttyS0" auskommen ... wenn da für die rc.S auf ein anderes Device gesetzt wird, hat das vielleicht seinen Grund; beim "askfirst" und beim "shutdown" ist das dann wieder etwas anderes - das "askfirst" macht ohne Terminal gar keinen Sinn und die Protokollierung auf der seriellen Schnittstelle beim "shutdown" ist sicherlich auch nachvollziehbar, weil AVM die ganzen neuen Protokolle (inzwischen erzeugt sogar das Flashen auf zusätzlichen File-Handles ein Protokoll) erst in jüngerer Vergangenheit hinzugefügt hat.
Leider nicht. Mit
 /dev/ttyS0::sysinit:/etc/init.d/rc.S
faehrt der 6.30 Kernel ebenfalls in einen Panic mit den gleichen Symptomen wie sonst auch (fast-boot und so weiter).
Die einzige Abhilfe scheint bisher nur das Nicht-Laden von 'Piglet_noemif' im sys-init zu sein.
Der Punkt, um den sich bisher alles dreht, ist wohl die TXo Leitung.
Die 7412 teilt sich offensichtlich die Pins des seriellen Ports mit dem DECT Baustein:
[1395.630000] set_hw_gpio: gpio_avm_dect_reset = 33
Anzeichen dafuer sind:
1. Kernel log
2. Treiben der RXi Leitung auf HIGH durch externen Adapter fuehrt in der orig. FW zum Kernel Panic
3. Ausgabe des Boot-Logs in Freetz auf /dev/ttyS0 (--> TXo wird getrieben) fuehrt in Freetz zum Kernel Panic
4. Abwarten des sys-init und nachtraegliches Laden von Piglet_noemif: Freetz bootet normal
5. Kommentar #16 von Ticket #2820
Dann stimmt aber das "Leider nicht." nur bedingt ... zumindest sprechen die aufgelisteten Anzeichen ja nicht gegen diese Vermutung. Oder wo habe ich da meinen blinden Fleck?
Solange die serielle Schnittstelle nicht vom Besitzer bestückt wird, ist es den Test mit "/dev/ttyS0" in der "/etc/inittab" allemal wert. Ich hatte ja meinerseits deutlich zwischen den Problemen mit und ohne RS232-Hardware differenziert - bei "mit" ist es halt die elektrische Komponente durch "Dazwischenfunken" auf TX und bei "ohne" vielleicht ja doch die fehlende Ausgabe auf "/dev/ttyS0".
zunächst mal Danke an alle, dass Ihr versucht die Ursachen fürs Nicht-Laufen vom Freetz auf der 7412 zu finden. Mir fällt momentan leider die Zeit Euch sinnvoll dabei zu unterstützen.
Nichtsdestotrotz möchte ich Euch an der Stelle kurz auf 102-dont-change-tty-settings.sh Patch (bzw. r12298) und die dazugehörigen Ticket-Einträge - #2518 comment:26 und die Comments rum herum - hinweisen.
Es könnte also sein, dass, allein das controlling tty in inittab anzugeben, nicht ausreichend ist. Versucht bitte zusätzlich, den 102-dont-change-tty-settings.sh Patch auszuschalten.
Generell ist es durchaus möglich, dass die beiden 102-...patches (102-add_inittab.sh und 102-dont-change-tty-settings.sh) überarbeitet gehören. Das im letzten Absatz von #2518 comment:26 angesprochene Problem habe ich zugegebenermaßen immer noch nicht verstanden.
VG, Gene
Danke für den Hinweis auf 102-dont-change... - wenn meine Vermutungen stimmen sollten, daß es irgendeine Synchronisation zwischen Sender und Empfänger gibt, bevor die Daten auf der seriellen Schnittstelle gesendet werden, dann könnten dort ja auch XON und XOFF eine Rolle spielen ... und es funktioniert ja zumindest mit den originalen AVM-Einstellungen.
Ich mache nachher mal schnell einen Test, wo ich bei der 06.83 einfach nur im Wrapper-FS den Eintrag in der "/etc/inittab" von Hand ändere - die Partition ist im Moment ohnehin unbenutzt und wenn die Box dann beim Starten abstürzen sollte, kann ich auf die andere Partition zurückschalten.
Wobei "schnell" relativ zu verstehen ist ... eher als "nachher, wenn ich Zeit dafür habe" - im Moment passe ich gerade mal wieder meine "dropbear"-Patches für das Box-Zertifikat an die neuen Konfigurationen im "dropbear" an, damit die dann auch wieder stimmen. Das habe ich in irgendeinem anderen Thread heute morgen leichtsinnigerweise angekündigt/versprochen und eigentlich brauche ich das selbst auch schon länger, bisher nehme ich halt ein älteres Faultier als (fiktiven) Bären, weil es keine echten Security-Probleme waren, die zum Update vom "dropbear" führten.
Da dabei dann nachher von mir das "stty"-Kommando in der "S01-head" nicht angefaßt wird (Warum gibt es das überhaupt im Freetz, daß da gepatcht wird? Mir fehlt gerade die Phantasie, wen/warum das stören sollte, wenn da ein "stty"-Kommando eben kein Terminal findet, dessen Einstellungen es ändern könnte - dann gibt das eben einen Fehler und gut ist's ... oder was passiert da ansonsten noch, daß Freetz ansonsten aus dem Tritt kommt?), ist das dann auch sauber als Ursache zuzuordnen (bzw. in die beiden Patches zu zerlegen) und notfalls kann ich auch noch eine angepaßte "S01-head" mal probieren (wenn das Problem nur mit der Änderung an der "inittab" nicht reproduzierbar sein sollte) - wobei die "/etc/profile" dann sicherlich vom Freetz auch entsprechend gepatcht werden wird (aber bis zum Zeitpunkt des Fehlers gibt es ja kein "login" und damit sollte die "/etc/profile" da auch noch keinen Zugriff erfahren haben).
Hallo Peter,
das Drin-Lassen von "stty -ixon -ixoff" hat dazu geführt, dass die Box nicht mehr gebootet hat / hängen geblieben ist. Das war auch das eigentlich in #2518 gemeldete Problem.
Diese Lösung von uns (bzw. korrekterweise von mir) war insofern nicht sauber, dass wir die Ursachen nicht richtig verstanden haben, sondern das Ganze über einen Revert einer der AVM-Änderungen workaroundet haben.
Der Grund für diese Vorgehensweise ist wiederum die Tatsache, dass ich es nicht wusste, warum Freetz-inittab so aussieht, wie es aussieht, und konkret, warum es bei keiner bis auf die askfirst-Zeile das controlling tty angegeben wird. Ich habe mich schlicht und ergreifend nicht getraut, es zu ändern, weil es sofort alle Boxen betreffen würde, wohingegen der Revert einer der AVM-Änderungen viel einfacher zu testen war.
Ich kann mir durchaus vorstellen bzw. sogar stark dazu tendiere, dass die korrekte Lösung die folgende wäre:
  • der 102-dont-change-tty-settings.sh Patch gehört komplett raus
  • das controlling tty sollte bei jeder Zeile von 102-add_inittab.sh angegeben werden und nicht wie bisher nur bei der askfirst (das würde mehr dem entsprechen, was AVM macht)
    oder alternativ
    das controlling tty sollte zusätzlich bei der sysinit-Zeile angegeben werden, denn basierend auf dem Kommentar im busybox' Quellcode "If this field is left blank, then the init's stdin/out will be used" nehme ich an, wird das für sysinit angegebene controlling tty bei den anderen inittab-Prozessen vererbt.
Im Anhang bzw. in Code-Tags unten (weil die Anhänge nicht funktionieren) ein die erste Alternative umsetzende Patch für die, die es testen möchten.
VG, Gene
Edit: habe nachgeschaut, Freetz-inittab wurde in r3423 eingeführt, gleich in der Form ohne "controlling tty". Die einzelnen box-spezifischen inittab's, die dabei abgelöst wurden, enthielten auch kein "controlling tty", s. z.B. 7170/110-inittab.sh
Index: patches/scripts/102-add_inittab.sh
--- patches/scripts/102-add_inittab.sh	(revision 14252)
+++ patches/scripts/102-add_inittab.sh	(working copy)
@@ -4,20 +4,20 @@
 # Start Freetz IP watchdog if selected
 [ "$FREETZ_REPLACE_ONLINECHANGED" == "y" ] && ip_watchdog="
 # Freetz replacement for unreliable AVM onlinechanged
-::respawn:/sbin/ip_watchdog
+${FREETZ_AVM_SERIAL_CONSOLE_DEVICE}::respawn:/sbin/ip_watchdog
 # actual filesystem
 cat << EOF > "${FILESYSTEM_MOD_DIR}/etc/inittab"
-::sysinit:/etc/init.d/rc.S
+${FREETZ_AVM_SERIAL_CONSOLE_DEVICE}::sysinit:/etc/init.d/rc.S
 ${FREETZ_AVM_SERIAL_CONSOLE_DEVICE}::askfirst:$shell
 $ip_watchdog
-::shutdown:/bin/sh -c /etc/inittab.shutdown
+${FREETZ_AVM_SERIAL_CONSOLE_DEVICE}::shutdown:/bin/sh -c /etc/inittab.shutdown
-::restart:/sbin/init
+${FREETZ_AVM_SERIAL_CONSOLE_DEVICE}::restart:/sbin/init
 EOF
 # wrapper filesystem
Index: patches/scripts/102-dont-change-tty-settings.sh
--- patches/scripts/102-dont-change-tty-settings.sh	(revision 14252)
+++ patches/scripts/102-dont-change-tty-settings.sh	(working copy)
@@ -1,8 +0,0 @@
-# freetz launches sysinit without controlling tty (s. patches/scripts/102-add_inittab.sh)
-# don't try to set/change tty settings as it won't work
-if [ "$FREETZ_AVM_VERSION_06_0X_MIN" == "y" ]; then
-	modsed -r 's,^([ \t]*stty .*),## disabled by freetz: \1,' "${FILESYSTEM_MOD_DIR}/etc/init.d/S01-head"
-fi
Ich habe mal die 06.83 mit der Änderung an der "/etc/inittab" gebootet (nur bei der Zeile für die "rc.S") und dabei wird dann der "slow-bootmode" für den DECT-Treiber verwendet:
[avm_debug] redirecting kernel-messages (/dev/debug)
[    9.380000] [module-alloc-by-name] give 0xe000 bytes at 0x81121000 to module 'Piglet_noemif' (0xb9f000 bytes left)
[    9.380000] [piglet]use settings for 209(2 gpios from hw_config)
[    9.490000] [piglet]patch_dectfw: c0220000, totallen = 44929(af81)
[    9.490000] [piglet]patch_dectfw: patch_adress: a0 max_len: 26 with Version 2 Len: 17
[    9.490000] [piglet]patch_dectfw: RFPI tag found 02966bfac8
[    9.490000] [piglet]patch_dectfw: dectmode 19
[    9.500000]
[38m
[8m
[    9.510000] [piglet]dect_loader144xx: [COLOR="#FF0000"]slow-bootmode[/COLOR]
[    9.770000] <FE>
[   10.490000] system-load 3 loadavg 0.37 0.8 0.3 - 37 tasks:60 % curr:modprobe(10 %) max:init(30 %, pid:1) pgstat: sum=26658 free=22444 slab=2772 alloc=1610/s fault=2273/s (sleep 1)
[   10.570000] *
[   10.860000] ***************************************************************************************
[   12.820000] [piglet]dect144xx_file_process: upload of '/lib/modules/dectfw_secondlevel_441.hex' successfull
[   12.830000]
[0m
[   14.940000] [piglet]TDM: FS: 8005 Hz CLK: 4601685 Hz  (SPITDM)
Das alleine ist es also noch nicht - das ist auch (bis auf die eine Änderung an der "/etc/inittab") eine unveränderte originale AVM-Version.
Wobei das Witzige an der Situation auch ist, daß es bei der 06.50 (mit /dev/ttyS0 in der rc.S-Zeile) auch nicht anders aussieht, wenn ich die 06.50 booten lasse:
[    9.990000] [module-alloc-by-name] give 0xe000 bytes at 0x81120000 to module 'Piglet_noemif' (0xb2c000 bytes left)
[   10.000000] [piglet]use settings for 209(2 gpios from hw_config)
[   10.100000] [piglet]patch_dectfw: c021a000, totallen = 45653(b255)
[   10.100000] [piglet]patch_dectfw: patch_adress: a0 max_len: 26 with Version 2 Len: 17
[   10.100000] [piglet]patch_dectfw: RFPI tag found 02966bfac8
[   10.100000] [piglet]patch_dectfw: dectmode 19
[   10.110000]
[38m
[8m
[   10.110000] [piglet]dect_loader144xx: [COLOR="#FF0000"]slow-bootmode[/COLOR]
[   10.870000] system-load 100 % loadavg 0.37 0.8 0.3 - 39 tasks:61 % curr:modprobe(7 %) max:init(33 %, pid:1), readytorun: 1, pgfault 1114/s (max 1 avg 0.0)
[   10.940000] *
[   11.240000] *****************************************************************************************
[   13.230000] [piglet]dect144xx_file_process: upload of '/lib/modules/dectfw_secondlevel_441.hex' successfull
[   13.250000]
[0m
[   15.360000] [piglet]TDM: FS: 8005 Hz CLK: 4025840 Hz  (SPITDM)
Da stellt sich dann die Frage, wie ich meine 7412 (interessieren würde mich das aber erst ab 06.5x und dem 3.10er-Kernel - die 06.30 ist für mich "out of sight") überhaupt dazu bringen kann/soll, daß da ein "fast-bootmode" in Erwägung gezogen wird. Ich werde das noch mit einigen Starts verifizieren - im Moment habe ich die DECT-Funktion nicht in Benutzung (der Treiber wird trotzdem geladen) und ich muß mir erst mal ein DECT-Gerät suchen, was ich bei der Aktivierung auch anmelden kann.
Vielleicht hat sich das Problem auch mit der 06.83 bereits generell erledigt? Ich habe keine eigene Toolchain für die 7412 und im Moment auch keine Lust, mir eine (weitere) zuzulegen. Wenn jemand ein Image haben sollte, was bei ihm nicht starten will, mache ich gerne die Gegenprobe - mehr kann ich aber im Moment (abseits von ein paar kleineren Tests mit AVM-Firmware, um erst mal die Auslöser für "fast-bootmode" vs. "slow-bootmode" zu ergründen) nicht anbieten.
Ich habe mal den Teil mit dem Laden des "piglet"-Treibers bei einer 7490 (intl.) herausgesucht ... auch dort gibt es offenbar einen "slow-bootmode"; aber es fehlen die Zeilen zur "shared usage of UART":
[   11.390000] [module-alloc-by-name] give 0xe000 bytes at 0x81225000 to module 'Piglet_noemif' (0xae4000 bytes left)
[   11.400000] [piglet]use settings for 185(7 gpios from hw_config)
[   11.500000] [piglet]patch_dectfw: c07e9000, totallen = 48681(be29)
[   11.500000] [piglet]patch_dectfw: patch_adress: a0 max_len: 26 with Version 2 Len: 17
[   11.500000] [piglet]patch_dectfw: RFPI tag found 02970b1c98
[   11.500000] [piglet]dect_loader144xx: [COLOR="#FF0000"]slow-bootmode[/COLOR]
[   12.310000] system-load 4 loadavg 0.37 0.8 0.3 - 39 tasks:57 % curr:modprobe(4 %) max:init(31 %, pid:1) pgstat: sum=59197 free=54878 slab=2784 alloc=1906/s fault=3454/s (sleep 2)
[   12.390000] *
[   12.680000] ***********************************************************************************************
[   14.800000] [piglet]dect144xx_file_process: upload of '/lib/modules/dectfw_secondlevel_441.hex' successfull
[   16.830000] [piglet]bitfile for autodetect '/lib/modules/bitfile_isdn.bit'
[   16.830000] [piglet]try to preload in progress-context: /lib/modules/bitfile_isdn.bit
[   17.580000] [piglet] bitfile 72761 bytes done
[   22.680000] [piglet]use preload[0] /lib/modules/bitfile_pots.bit
[   23.400000] [piglet] bitfile 72761 bytes done
[   23.400000] [piglet]-> POTS-Mode
[   23.500000] [piglet]TDM: FS: 8005 Hz CLK: 2047890 Hz
Bei der 7490 ist - nur nebenbei - das DECT dann aktiviert und in Benutzung. Ich werde das zwar bei der 7412 noch einmal testen, aber damit sind auch meine Hoffnungen, daß es einen Zusammenhang zur Frage "DECT aktiviert oder nicht" gibt bei der Entscheidung für den "bootmode", wieder deutlich gesunken.
Die Zeilen mit den Sternen würde ich dann auch eher als eine Art Fortschrittsanzeige beim Laden der DECT-Firmware interpretieren ... die besteht ja auch aus zwei Teilen, von denen der erste sehr kurz und der zweite wesentlich länger ist.
Aber wie überredet man die Box nun zu diesem "fast-bootmode" wie in #10 zu sehen? Oder gibt es den (und damit ggf. auch die Probleme damit) in Firmware >= 06.5x gar nicht mehr?
Alles etwas vage ... schon der (angenommene) Zusammenhang zwischen dem Freetz-Absturz bei der 7412 und dem "Piglet_noemif.ko" muß vielleicht erst einmal richtig verifiziert werden und das geht wieder nur dann (ich unterstelle mal, daß die Lösung mit Hardware für die serielle Schnittstelle tatsächlich das Ergebnis verfälscht oder selbst ein Problem darstellt), wenn man ein funktionierendes und ein nicht funktionierendes System auf derselben Box hat und ggf. das Panic-Log des anderen Systems im TFFS wiederfindet.
Ich scheitere jedenfalls regelmäßig schon daran, die Box überhaupt (reproduzierbar) zu einem Problem zu bewegen ... auch beim ersten Versuch mit dem Image von Eugene hatte ich ja nur einen einzigen Absturz und danach keine weiteren Probleme. Das hatte ich zwar schon einmal als Problem (bei der Suche nach diesem dämlichen Fehler mit dem Telefonie-Daemon und den USB-Geräten, der auch als "walking dead" in Erscheinung trat und den ich aus unerklärlichen Gründen nie bei mir reproduzieren konnte), aber dieses Problem hier sollte sich doch irgendwie packen lassen. Sollte also jemand ein Freetz-Image mit einem 3.10er-Kernel haben (wie gesagt, Versionen davor haben Scheunentore anstelle von Lücken und da will ich auch nichts dazu beitragen, daß die noch irgendjemand auf einer 7412 verwenden kann), mit dem seine 7412 reproduzierbar abstürzt, dann nehme ich das gerne mal zum Testen - die bisherigen Versuche (ein Image von @er13, ein paar Modifikationen (wie sie Freetz auch machen würde) an einer originalen AVM-Firmware) haben leider nicht dazu geführt, daß meine Box (dauerhaft) abgestürzt wäre.
EDIT:
Bei der 7412 wird der serielle Port über die Kernel-Commandline gesetzt und da steht bei mir:
[    0.000000] Linux version 3.10.73 (jpluschke@Version_42885_C16_7412) (gcc version 4.8.3 (Buildroot 2014.08) ) #1 SMP Tue Feb 7 16:47:48 CET 2017
[    0.000000] [env_init] 0x8103bf04[0]
[    0.000000] [env_init] 0x8103bf44[1]
[    0.000000] [env_init] 0x8103c044[2]
[    0.000000] [env_init] switch to ram location
[    0.000000] [init_avm_kernel_config] AVM Kernel Config (ptr 80847000)
[    0.000000] [init_avm_kernel_config] AVM Kernel Config: module memory entry
[    0.000000] [init_avm_kernel_config] AVM Kernel Config: version info entry
[    0.000000] [init_avm_kernel_config] AVM Kernel Config: device-tree for subrev 0 found
[    0.000000] [COLOR="#FF0000"]bootconsole [early0] enabled[/COLOR]
[    0.000000] CPU0 revision is: 00019556 (MIPS 34Kc)
[    0.000000] Determined physical RAM map:
[    0.000000]  memory: 08000000 @ 00000000 (usable)
[    0.000000] Initrd not found or empty - disabling initrd
[    0.000000] Zone ranges:
[    0.000000]   Normal   [mem 0x00000000-0x07ffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x00000000-0x07ffffff]
[    0.000000] On node 0 totalpages: 32768
[    0.000000] free_area_init_node: node 0, pgdat 8083dde0, node_mem_map 81003000
[    0.000000]   Normal zone: 256 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 32768 pages, LIFO batch:7
[    0.000000] [module-alloc] use 0xbca000 bytes at 0x81104000
[    0.000000] [0]lsmtc_smp_setup tcstatus=18102400
[    0.000000] 1 available secondary CPU TC(s)
[    0.000000] [avm_cache_set_coherency]: setting cache coherency for HWRevision=209 to write back allocate
[    0.000000] Primary instruction cache 32kB, 4-way, VIPT, linesize 32 bytes.
[    0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
[    0.000000] PERCPU: Embedded 7 pages/cpu @81cd2000 s7072 r8192 d13408 u32768
[    0.000000] pcpu-alloc: s7072 r8192 d13408 u32768 alloc=8*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 32512
[    0.000000] Kernel command line: test1=y test2=n [COLOR="#FF0000"]console=ttyS0,115200n8r[/COLOR] nor_size=0MB sflash_size=0KB nand_size=128MB ethaddr=5C:49:79:57:47:5A tffsver=3
[    0.000000] [NAND] nand_size = 0x8000000
[    0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
[    0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[    0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[    0.000000] Writing ErrCtl register=0000dce0
[    0.000000] Readback ErrCtl register=0000dce0
[    0.000000] Memory: 108388k/131072k available (5583k kernel code, 22684k reserved, 2948k data, 292k init, 0k highmem)
[    0.000000] Hierarchical RCU implementation.
[    0.000000] NR_IRQS:181
[    0.000000] SRSConf0 0x3feffbfe: SRS1: 0xffffffff, SRS2 0xffffffff, SRS3 0xffffffff
[    0.000000] Lantiq ICU driver, version 3.0.1, (c) 2001-2011 Lantiq Deutschland GmbH
[    0.000000] [COLOR="#FF0000"]Console: colour dummy device 80x25[/COLOR]
[    0.000000] [COLOR="#FF0000"]console [ttyS0] [COLOR="#008000"]enabled[/COLOR], bootconsole [COLOR="#008000"]disabled[/COLOR][/COLOR]
[    0.020000] Calibrating delay loop... 331.77 BogoMIPS (lpj=1658880)
[    0.080000] pid_max: default: 32768 minimum: 301
[    0.080000] Security Framework initialized
[    0.080000] Mount-cache hash table entries: 512
[    0.090000] I-cache flushes single-threaded
[    0.090000] D-cache flushes single-threaded
[    0.090000] Limit of 2 TCs set
[    0.090000] TLB of 32 entry pairs shared by 2 VPEs
[    0.090000] VPE 0: TC 0, VPE 1: TC 1
[    0.090000] IPI buffer pool of 8 buffers
[    0.090000] CPU1 revision is: 00019556 (MIPS 34Kc)
[    0.170000] TC 1 going on-line as CPU 1
[    0.170000] Brought up 2 CPUs
[    0.170000] [yield_context_init] cpu=1 tc=2 mask=301
[    0.180000] [yield_context_init] cpu=0 tc=3 mask=2410
[    0.180000] devtmpfs: initialized
[    0.200000] pinctrl core: initialized pinctrl subsystem
[    0.200000] Creating Config Table
[    0.200000] [avm_generate_hw_config_table_from_device_tree] gpio_cnt: 31
[    0.210000] NET: Registered protocol family 16
[    0.220000] FPU Affinity set after 5000 emulations
[    0.220000] avm_check_cpu_features: mips-options: 0x006d638b icache.flags 0x00000000 dcache.flags 0x00000004 isa_level 0x00000063 ases 00000031
[    0.230000] [TFFS3_Early_Init] called
[    0.240000] avm_alloc_page_extension node_extension_table[0] entries=32768 (size=131072)  alloced
[    0.240000] Reboot Status is: Power-On
[    0.250000] [avmnet] [avmnet_cfg_init] Driver version: 6.247  -  Revision 1496:3622  -  Di 7. Feb 16:46:58 CET 2017
[    0.260000] Port 0 PLL REGFILE
[    0.260000] PCIE_PHY_PLL_CTRL1    0x8e39
[    0.260000] PCIE_PHY_PLL_CTRL2    0x0183
[    0.260000] PCIE_PHY_PLL_CTRL3    0x0042
[    0.260000] PCIE_PHY_PLL_CTRL4    0x0000
[    0.260000] PCIE_PHY_PLL_CTRL5    0x0000
[    0.260000] PCIE_PHY_PLL_CTRL6    0x0000
[    0.260000] PCIE_PHY_PLL_CTRL7    0x0000
[    0.260000] PCIE_PHY_PLL_A_CTRL1  0x120e
[    0.260000] PCIE_PHY_PLL_A_CTRL2  0x39d7
[    0.260000] PCIE_PHY_PLL_A_CTRL3  0x0900
[    0.260000] PCIE_PHY_PLL_STATUS   0x0000
[    0.260000] TX1 REGFILE
[    0.260000] PCIE_PHY_TX1_CTRL1    0x0009
[    0.260000] PCIE_PHY_TX1_CTRL2    0x2e00
[    0.260000] PCIE_PHY_TX1_CTRL3    0x1fff
[    0.260000] PCIE_PHY_TX1_A_CTRL1  0x0810
[    0.260000] PCIE_PHY_TX1_A_CTRL2  0x0706
[    0.260000] PCIE_PHY_TX1_MOD1     0x0000
[    0.260000] PCIE_PHY_TX1_MOD2     0x0000
[    0.260000] PCIE_PHY_TX1_MOD3     0x0180
[    0.260000] TX2 REGFILE
[    0.260000] PCIE_PHY_TX2_CTRL1    0x0009
[    0.260000] PCIE_PHY_TX2_CTRL2    0x3096
[    0.260000] PCIE_PHY_TX2_A_CTRL1  0x8010
[    0.260000] PCIE_PHY_TX2_A_CTRL2  0x4707
[    0.260000] PCIE_PHY_TX2_MOD1     0x0000
[    0.260000] PCIE_PHY_TX2_MOD2     0x0000
[    0.260000] PCIE_PHY_TX2_MOD3     0x0180
[    0.260000] RX1 REGFILE
[    0.260000] PCIE_PHY_RX1_CTRL1    0x0001
[    0.260000] PCIE_PHY_RX1_CTRL2    0x3000
[    0.260000] PCIE_PHY_RX1_CDR      0x0235
[    0.260000] PCIE_PHY_RX1_EI       0x0004
[    0.260000] PCIE_PHY_RX1_A_CTRL   0x6803
[    0.270000] Port 0 PLL REGFILE
[    0.270000] PCIE_PHY_PLL_CTRL1    0x38e4
[    0.270000] PCIE_PHY_PLL_CTRL2    0x03ee
[    0.270000] PCIE_PHY_PLL_CTRL3    0x0000
[    0.270000] PCIE_PHY_PLL_CTRL4    0x1b72
[    0.270000] PCIE_PHY_PLL_CTRL5    0xfae3
[    0.270000] PCIE_PHY_PLL_CTRL6    0x3a04
[    0.270000] PCIE_PHY_PLL_CTRL7    0x0002
[    0.270000] PCIE_PHY_PLL_A_CTRL1  0x120e
[    0.270000] PCIE_PHY_PLL_A_CTRL2  0x39d7
[    0.270000] PCIE_PHY_PLL_A_CTRL3  0x2900
[    0.270000] PCIE_PHY_PLL_STATUS   0x0070
[    0.270000] TX1 REGFILE
[    0.270000] PCIE_PHY_TX1_CTRL1    0x0009
[    0.270000] PCIE_PHY_TX1_CTRL2    0x2e00
[    0.270000] PCIE_PHY_TX1_CTRL3    0x1fff
[    0.270000] PCIE_PHY_TX1_A_CTRL1  0x0810
[    0.270000] PCIE_PHY_TX1_A_CTRL2  0x0706
[    0.270000] PCIE_PHY_TX1_MOD1     0x1ffe
[    0.270000] PCIE_PHY_TX1_MOD2     0xfffe
[    0.270000] PCIE_PHY_TX1_MOD3     0x0001
[    0.270000] TX2 REGFILE
[    0.270000] PCIE_PHY_TX2_CTRL1    0x0009
[    0.270000] PCIE_PHY_TX2_CTRL2    0x3096
[    0.270000] PCIE_PHY_TX2_A_CTRL1  0x8010
[    0.270000] PCIE_PHY_TX2_A_CTRL2  0x4707
[    0.270000] PCIE_PHY_TX2_MOD1     0x1ffe
[    0.270000] PCIE_PHY_TX2_MOD2     0xfffe
[    0.270000] PCIE_PHY_TX2_MOD3     0x0001
[    0.270000] RX1 REGFILE
[    0.270000] PCIE_PHY_RX1_CTRL1    0x0001
[    0.270000] PCIE_PHY_RX1_CTRL2    0x3000
[    0.270000] PCIE_PHY_RX1_CDR      0x0235
[    0.270000] PCIE_PHY_RX1_EI       0x0004
[    0.270000] PCIE_PHY_RX1_A_CTRL   0x6803
[    0.870000] Lantiq PCIe Root Complex driver, version 2.0.0, (c) 2001-2011 Lantiq Deutschland GmbH
[    0.920000] bio: create slab <bio-0> at 0
[    0.920000] PCI host bridge to bus 0000:00
[    0.930000] pci_bus 0000:00: root bus resource [mem 0x1c000000-0x1cffffff]
[    0.930000] pci_bus 0000:00: root bus resource [io  0x1d800000-0x1d8fffff]
[    0.940000] pci_bus 0000:00: No busn resource found for root bus, will use [bus 00-ff]
[    0.950000] pci 0000:00:00.0: [1bef:0011] type 01 class 0x060000
[    0.950000] ifx_pcie_rc_class_early_fixup port 0: fixed pcie host bridge to pci-pci bridge
[    0.960000] pci 0000:00:00.0: PME# supported from D0 D3hot
[    0.960000] pci 0000:01:00.0: [168c:ff1c] type 00 class 0x020000
[    0.960000] pci 0000:01:00.0: reg 10: [mem 0x00000000-0x0000ffff 64bit]
[    0.960000] pci 0000:01:00.0: supports D1
[    0.960000] pci 0000:01:00.0: PME# supported from D0 D1 D3hot
[    0.960000] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[    0.960000] pci_bus 0000:00: busn_res: [bus 00-ff] end is updated to 01
[    0.960000] pci 0000:00:00.0: BAR 8: assigned [mem 0x1c000000-0x1c0fffff]
[    0.960000] pci 0000:01:00.0: BAR 0: assigned [mem 0x1c000000-0x1c00ffff 64bit]
[    0.970000] pci 0000:00:00.0: PCI bridge to [bus 01]
[    0.980000] pci 0000:00:00.0:   bridge window [mem 0x1c000000-0x1c0fffff]
[    0.990000] NET: Registered protocol family 8
[    0.990000] NET: Registered protocol family 20
[    0.990000] Switching to clocksource MIPS
[    1.060000] NET: Registered protocol family 2
[    1.060000] TCP established hash table entries: 1024 (order: 1, 8192 bytes)
[    1.070000] TCP bind hash table entries: 1024 (order: 1, 8192 bytes)
[    1.070000] TCP: Hash tables configured (established 1024 bind 1024)
[    1.080000] TCP: reno registered
[    1.080000] UDP hash table entries: 256 (order: 1, 8192 bytes)
[    1.090000] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[    1.100000] avm_pa: try to activate hw accelaration for pid 1 (ipv4)
[    1.100000] NET: Registered protocol family 1
[    1.110000] PCI: CLS 0 bytes, default 32
[    1.110000] Lantiq CGU driver, version 1.1.32, (c) 2001-2011 Lantiq Deutschland GmbH
[    1.130000] IFX DMA driver, version ifxmips_dma_core.c:v1.0.17, (c) 2009 Infineon Technologies AG
 skb_shared_size:184
[    1.140000] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    1.150000] fuse init (API version 7.22)
[    1.150000] yaffs: yaffs built Feb  7 2017 16:46:28 Installing.
[    1.150000] msgmni has been set to 211
[    1.160000] io scheduler noop registered (default)
[    1.160000] [avm_membench_init]
[    1.500000][COLOR="#008000"] ttyS0 at MMIO 0x1e100c00 (irq = 107) is a PORT_IFX_ASC[/COLOR]
[    1.510000] [COLOR="#FF0000"]ifx_usif_uart_init: uart_register_driver failed[/COLOR]
[    1.510000] avm_net_trace: Up and running.
[    1.520000] [loadcontrol] set auto - scale=1
[    1.520000] [avm] configured: watchdog event debug
[    1.520000] AVM_WATCHDOG: Watchdog Driver for AR7 Hardware (Version 1.0, build: Feb  7 2017 16:46:36)
[    1.530000] Lantiq Thermal Sensor driver, version 1.0.3, (c) 2001-2011 Lantiq Deutschland GmbH
[    1.530000] ifx_pmu_init: Major 244
[    1.540000] Lantiq PMU driver, version 1.2.6, (c) 2001-2011 Lantiq Deutschland GmbH
[    1.540000] Lantiq GPIO driver, version 1.3.2, (c) 2001-2011 Lantiq Deutschland GmbH
[    1.550000] Infineon Technologies RCU driver version 1.0.7
[    1.570000] loop: module loaded
[    1.570000] nbd: registered device at major 43
[    1.600000] Generic platform RAM MTD, (c) 2004 Simtec Electronics
[    1.600000] [HSNAND] Toshiba-BENAND
[    1.610000] NAND device: Manufacturer ID: 0x98, Chip ID: 0xf1 (Toshiba NAND 128MiB 3,3V 8-bit), 128MiB, page size: 2048, OOB size: 64
[    1.620000] Scanning device for bad blocks
[    1.650000] {tsh_read_ecc} status 0xe1
[    1.660000] [ifx_hsnand_command] read block failed (column: 0x800 page: 0x5ec0)
[    1.660000] Bad eraseblock 379 at 0x000002f60000
[    1.700000] {tsh_read_ecc} status 0xe1
[    1.710000] [ifx_hsnand_command] read block failed (column: 0x800 page: 0xc000)
[    1.710000] Bad eraseblock 768 at 0x000006000000
[    1.740000] badblock statistics:
  start block = 0
  num blocks  = 1024
  bad blocks  = 2
[    1.760000]
  >> The following table summarize all badblocks to visualize the distribution
  block [ start | count | size/kB ] (start block, number of blocks)
[    1.780000]   block [   379 |     1 |     128 ]
[    1.790000]   block [   768 |     1 |     128 ]
[    1.790000]         [ ======================= ]
        [      >>     2 |     256 ]
[    1.800000] Creating 8 MTD partitions on "ifx_hsnand":
[    1.800000] 0x000000440000-0x000000840000 : "reserved-kernel"
[    1.810000] 0x000000840000-0x000003840000 : "reserved-filesystem"
[    1.820000] 0x000003840000-0x000003c40000 : "kernel"
[    1.830000] 0x000003c40000-0x000006c40000 : "filesystem"
[    1.830000] 0x000006c40000-0x000006e40000 : "config"
[    1.840000] 0x000006e40000-0x000008000000 : "nand-filesystem"
[    1.850000] 0x000000000000-0x000000040000 : "urlader"
[    1.860000] 0x000000040000-0x000000440000 : "nand-tffs"
[    1.860000] [TFFS3_Register_NAND] Called
[    1.870000] [TFFS3_Register_Panic_CB] registering panic callback for mtd ifx_hsnand
[    1.870000] tun: Universal TUN/TAP device driver, 1.6
[    1.880000] tun: (C) 1999-2004 Max Krasnyansky <[email protected]>
[    1.880000] IFX SWITCH API, Version 1.1.8.5
[    1.880000] SWAPI: Registered character device [switch_api] with major no [81]
[    1.890000] Switch API: PCE MicroCode loaded !!
[    1.890000] i2c /dev entries driver
[    1.900000] cpuidle: using governor ladder
[    1.900000] cpuidle: using governor menu
[    1.900000] AVM PA for Linux 3.10.73
[    1.910000] AVM PA skb pktinfo at offset 136 size 208
[    1.910000] [loadcontrol]module avm_pa registered
[    1.920000] u32 classifier
[    1.920000]     Performance counters on
[    1.920000]     Actions configured
[    1.930000] ipip: IPv4 over IPv4 tunneling driver
[    1.930000] TCP: cubic registered
[    1.930000] NET: Registered protocol family 10
[    1.940000] avm_pa: try to activate hw accelaration for pid 2 (ipv6)
[    1.950000] sit: IPv6 over IPv4 tunneling driver
[    1.950000] NET: Registered protocol family 17
[    1.960000] Bridge broadcast ratelimiter registered
[    1.960000] KOAM is loaded successfully.
[    1.960000] l2tp_core: L2TP core driver, V2.0
[    1.960000] l2tp_ip: L2TP IP encapsulation support (L2TPv3)
[    1.970000] l2tp_netlink: L2TP netlink interface
[    1.970000] l2tp_eth: L2TP ethernet pseudowire support (L2TPv3)
[    1.980000] l2tp_ip6: L2TP IP encapsulation support for IPv6 (L2TPv3)
[    1.990000] 8021q: 802.1Q VLAN Support v1.8
[    1.990000] Key type dns_resolver registered
[    2.000000] [TFFS3-NAND] NAND storage backend for TFFS 3.x
[    2.000000] [TFFS3-NAND] scanning block at address 0x0
[    2.010000] [TFFS3-NAND] found TFFS header magic at address 0x0, version 0x30000
[    2.010000] [scan_block] blk_addr: 0x0 blkseq_nr: 0x81 sect_per_pg: 0x1 num_bad_pages: 0x0 erase_cnt: 0x1
[    2.060000] [TFFS3-NAND] scanning block at address 0x20000
[    2.060000] [TFFS3-NAND] found TFFS header magic at address 0x20000, version 0x30000
[    2.070000] [scan_block] blk_addr: 0x20000 blkseq_nr: 0xfe sect_per_pg: 0x1 num_bad_pages: 0x0 erase_cnt: 0x2
[    2.120000] [TFFS3-NAND] scanning block at address 0x40000
[    2.120000] [TFFS3-NAND] found TFFS header magic at address 0x40000, version 0x30000
[    2.130000] [scan_block] blk_addr: 0x40000 blkseq_nr: 0x112 sect_per_pg: 0x1 num_bad_pages: 0x0 erase_cnt: 0xa
[    2.180000] [TFFS3-NAND] scanning block at address 0x60000
[    2.180000] [TFFS3-NAND] found TFFS header magic at address 0x60000, version 0x30000
[    2.190000] [scan_block] blk_addr: 0x60000 blkseq_nr: 0x102 sect_per_pg: 0x1 num_bad_pages: 0x0 erase_cnt: 0x5
[    2.230000] [TFFS3-NAND] scanning block at address 0x80000
[    2.240000] [TFFS3-NAND] found TFFS header magic at address 0x80000, version 0x30000
[    2.240000] [scan_block] blk_addr: 0x80000 blkseq_nr: 0xfc sect_per_pg: 0x1 num_bad_pages: 0x0 erase_cnt: 0x8
[    2.290000] [TFFS3-NAND] scanning block at address 0xa0000
[    2.290000] [TFFS3-NAND] found TFFS header magic at address 0xa0000, version 0x30000
[    2.300000] [scan_block] blk_addr: 0xa0000 blkseq_nr: 0xfd sect_per_pg: 0x1 num_bad_pages: 0x0 erase_cnt: 0x8
[    2.350000] [TFFS3-NAND] scanning block at address 0xc0000
[    2.350000] [TFFS3-NAND] found TFFS header magic at address 0xc0000, version 0x30000
[    2.360000] [scan_block] blk_addr: 0xc0000 blkseq_nr: 0x114 sect_per_pg: 0x1 num_bad_pages: 0x0 erase_cnt: 0x5
[    2.400000] [TFFS3-NAND] scanning block at address 0xe0000
[    2.410000] [TFFS3-NAND] found TFFS header magic at address 0xe0000, version 0x30000
[    2.420000] [scan_block] blk_addr: 0xe0000 blkseq_nr: 0x88 sect_per_pg: 0x1 num_bad_pages: 0x0 erase_cnt: 0x1
[    2.460000] [TFFS3-NAND] scanning block at address 0x100000
[    2.470000] [TFFS3-NAND] found TFFS header magic at address 0x100000, version 0x30000
[    2.470000] [scan_block] blk_addr: 0x100000 blkseq_nr: 0xa9 sect_per_pg: 0x1 num_bad_pages: 0x0 erase_cnt: 0x2
[    2.520000] [TFFS3-NAND] scanning block at address 0x120000
[    2.520000] [TFFS3-NAND] found TFFS header magic at address 0x120000, version 0x30000
[    2.530000] [scan_block] blk_addr: 0x120000 blkseq_nr: 0x106 sect_per_pg: 0x1 num_bad_pages: 0x0 erase_cnt: 0x8
[    2.580000] [TFFS3-NAND] scanning block at address 0x140000
[    2.580000] [TFFS3-NAND] found TFFS header magic at address 0x140000, version 0x30000
[    2.590000] [scan_block] blk_addr: 0x140000 blkseq_nr: 0xf5 sect_per_pg: 0x1 num_bad_pages: 0x0 erase_cnt: 0x7
[    2.640000] [TFFS3-NAND] scanning block at address 0x160000
[    2.640000] [TFFS3-NAND] found TFFS header magic at address 0x160000, version 0x30000
[    2.650000] [scan_block] blk_addr: 0x160000 blkseq_nr: 0xec sect_per_pg: 0x1 num_bad_pages: 0x0 erase_cnt: 0x6
[    2.690000] [TFFS3-NAND] scanning block at address 0x180000
[    2.700000] [TFFS3-NAND] found TFFS header magic at address 0x180000, version 0x30000
[    2.700000] [scan_block] blk_addr: 0x180000 blkseq_nr: 0xf6 sect_per_pg: 0x1 num_bad_pages: 0x0 erase_cnt: 0x7
[    2.750000] [TFFS3-NAND] scanning block at address 0x1a0000
[    2.760000] [TFFS3-NAND] found TFFS header magic at address 0x1a0000, version 0x30000
[    2.760000] [scan_block] blk_addr: 0x1a0000 blkseq_nr: 0x111 sect_per_pg: 0x1 num_bad_pages: 0x0 erase_cnt: 0xb
[    2.810000] [TFFS3-NAND] scanning block at address 0x1c0000
[    2.810000] [TFFS3-NAND] found TFFS header magic at address 0x1c0000, version 0x30000
[    2.820000] [scan_block] blk_addr: 0x1c0000 blkseq_nr: 0x113 sect_per_pg: 0x1 num_bad_pages: 0x0 erase_cnt: 0x4
[    2.860000] [TFFS3-NAND] scanning block at address 0x1e0000
[    2.870000] [TFFS3-NAND] found TFFS header magic at address 0x1e0000, version 0x30000
[    2.870000] [scan_block] blk_addr: 0x1e0000 blkseq_nr: 0xff sect_per_pg: 0x1 num_bad_pages: 0x0 erase_cnt: 0x2
[    2.920000] [TFFS3-NAND] scanning block at address 0x200000
[    2.920000] [TFFS3-NAND] found TFFS header magic at address 0x200000, version 0x30000
[    2.930000] [scan_block] blk_addr: 0x200000 blkseq_nr: 0xf9 sect_per_pg: 0x1 num_bad_pages: 0x0 erase_cnt: 0x7
[    2.980000] [TFFS3-NAND] scanning block at address 0x220000
[    2.980000] [TFFS3-NAND] found TFFS header magic at address 0x220000, version 0x30000
[    2.990000] [scan_block] blk_addr: 0x220000 blkseq_nr: 0x103 sect_per_pg: 0x1 num_bad_pages: 0x0 erase_cnt: 0x4
[    3.040000] [TFFS3-NAND] scanning block at address 0x240000
[    3.040000] [TFFS3-NAND] found TFFS header magic at address 0x240000, version 0x30000
[    3.050000] [scan_block] blk_addr: 0x240000 blkseq_nr: 0x115 sect_per_pg: 0x1 num_bad_pages: 0x0 erase_cnt: 0x5
[    3.070000] [TFFS3-NAND] scanning block at address 0x260000
[    3.080000] [TFFS3-NAND] found TFFS header magic at address 0x260000, version 0x30000
[    3.080000] [scan_block] blk_addr: 0x260000 blkseq_nr: 0xc5 sect_per_pg: 0x1 num_bad_pages: 0x0 erase_cnt: 0x3
[    3.130000] [TFFS3-NAND] scanning block at address 0x280000
[    3.130000] [TFFS3-NAND] found TFFS header magic at address 0x280000, version 0x30000
[    3.140000] [scan_block] blk_addr: 0x280000 blkseq_nr: 0xc6 sect_per_pg: 0x1 num_bad_pages: 0x0 erase_cnt: 0x3
[    3.190000] [TFFS3-NAND] scanning block at address 0x2a0000
[    3.190000] [TFFS3-NAND] found TFFS header magic at address 0x2a0000, version 0x30000
[    3.200000] [scan_block] blk_addr: 0x2a0000 blkseq_nr: 0x100 sect_per_pg: 0x1 num_bad_pages: 0x0 erase_cnt: 0x2
[    3.240000] [TFFS3-NAND] scanning block at address 0x2c0000
[    3.250000] [TFFS3-NAND] found TFFS header magic at address 0x2c0000, version 0x30000
[    3.260000] [scan_block] blk_addr: 0x2c0000 blkseq_nr: 0xc7 sect_per_pg: 0x1 num_bad_pages: 0x0 erase_cnt: 0x3
[    3.300000] [TFFS3-NAND] scanning block at address 0x2e0000
[    3.310000] [TFFS3-NAND] found TFFS header magic at address 0x2e0000, version 0x30000
[    3.310000] [scan_block] blk_addr: 0x2e0000 blkseq_nr: 0xf7 sect_per_pg: 0x1 num_bad_pages: 0x0 erase_cnt: 0x7
[    3.360000] [TFFS3-NAND] scanning block at address 0x300000
[    3.360000] [TFFS3-NAND] found TFFS header magic at address 0x300000, version 0x30000
[    3.370000] [scan_block] blk_addr: 0x300000 blkseq_nr: 0xfa sect_per_pg: 0x1 num_bad_pages: 0x0 erase_cnt: 0x7
[    3.420000] [TFFS3-NAND] scanning block at address 0x320000
[    3.420000] [TFFS3-NAND] found TFFS header magic at address 0x320000, version 0x30000
[    3.430000] [scan_block] blk_addr: 0x320000 blkseq_nr: 0xf1 sect_per_pg: 0x1 num_bad_pages: 0x0 erase_cnt: 0x6
[    3.470000] [TFFS3-NAND] scanning block at address 0x340000
[    3.480000] [TFFS3-NAND] found TFFS header magic at address 0x340000, version 0x30000
[    3.490000] [scan_block] blk_addr: 0x340000 blkseq_nr: 0xfb sect_per_pg: 0x1 num_bad_pages: 0x0 erase_cnt: 0x2
[    3.530000] [TFFS3-NAND] scanning block at address 0x360000
[    3.540000] [TFFS3-NAND] found TFFS header magic at address 0x360000, version 0x30000
[    3.540000] [scan_block] blk_addr: 0x360000 blkseq_nr: 0x104 sect_per_pg: 0x1 num_bad_pages: 0x0 erase_cnt: 0x5
[    3.570000] [TFFS3-NAND] scanning block at address 0x380000
[    3.570000] [TFFS3-NAND] found TFFS header magic at address 0x380000, version 0x30000
[    3.580000] [scan_block] blk_addr: 0x380000 blkseq_nr: 0xe9 sect_per_pg: 0x1 num_bad_pages: 0x0 erase_cnt: 0x3
[    3.600000] [TFFS3-NAND] scanning block at address 0x3a0000
[    3.610000] [TFFS3-NAND] found TFFS header magic at address 0x3a0000, version 0x30000
[    3.610000] [scan_block] blk_addr: 0x3a0000 blkseq_nr: 0xb8 sect_per_pg: 0x1 num_bad_pages: 0x0 erase_cnt: 0x2
[    3.640000] [TFFS3-NAND] scanning block at address 0x3c0000
[    3.640000] [TFFS3-NAND] found TFFS header magic at address 0x3c0000, version 0x30000
[    3.650000] [scan_block] blk_addr: 0x3c0000 blkseq_nr: 0xe3 sect_per_pg: 0x1 num_bad_pages: 0x0 erase_cnt: 0x2
[    3.670000] [TFFS3-NAND] scanning block at address 0x3e0000
[    3.680000] [TFFS3-NAND] found TFFS header magic at address 0x3e0000, version 0x30000
[    3.690000] [scan_block] blk_addr: 0x3e0000 blkseq_nr: 0xa0 sect_per_pg: 0x1 num_bad_pages: 0x0 erase_cnt: 0x1
[    3.740000] [TFFS3-NAND] Initialisation successful, 32/32/32 NAND blocks active, fill rate 14%
[    3.750000] TFFS: tiny flash file system driver. GPL (c) AVM Berlin (Version 3.0)
[    3.750000] Adam2 environment variables API installed.
[    3.760000] AVM Simple Profiling enabled Version 3.0
[    3.760000] [simple-profiling]:2 performance counters implemented, NEW_34K
[    3.770000] [simple-profiling]Enable Performance Counter 0 for Data cache load/stores (User Supervisor Kernel Exception TC-ID=0) all cores tc: 0
[    3.780000] [simple-profiling]Enable Performance Counter 1 for Data cache load/store misses (User Supervisor Kernel Exception TC-ID=0) all cores tc: 0
[    3.790000] [simple-profiling]Enable Performance Counter 0 for Data cache load/stores (User Supervisor Kernel Exception TC-ID=1) all cores tc: 1
[    3.810000] [simple-profiling]Enable Performance Counter 1 for Data cache load/store misses (User Supervisor Kernel Exception TC-ID=1) all cores tc: 1
[    3.820000] [simple-profiling]Enable Performance Counter 0 for Main pipeline stalls (P) (User Supervisor Kernel Exception TC-ID=2) all cores tc: 2
[    3.830000] [simple-profiling]Enable Performance Counter 1 for Cycles (P) (User Supervisor Kernel Exception TC-ID=2) all cores tc: 2
[    3.840000] [simple-profiling]Enable Performance Counter 0 for Data cache load/stores (User Supervisor Kernel Exception TC-ID=3) all cores tc: 3
[    3.860000] [simple-profiling]Enable Performance Counter 1 for Data cache load/store misses (User Supervisor Kernel Exception TC-ID=3) all cores tc: 3
[    3.870000] [simple-profiling]all cores:performance-mode (round-robin):  cpus on
[    3.880000] {avmnet_cfg_netinit}
[    3.880000] [avmnet] No config found for HWRev 209, HWSubRev 1, Profile-ID 0, trying base config for HWSubRev
[    3.890000] [avmnet] No config found for HWRev 209, HWSubRev 1, trying base config for HWRev
[    3.900000] [avmnet] [avmnet_swi_7port_init] Init on module swi_vr9 called.
[    3.910000] [avmnet] [fix_phy_clock_config]: Could not read external PHY clock pin data from avm_hw_config!
[    4.070000] Loading AVM Net Common Datapath Driver for 7Port Switch......
[    4.070000] [ppe_eth_init] init_hw()
[    4.070000] [init_hw] ppe_hw_init=0xff successful
[    4.070000] [ppe_eth_init] ifx_proc_file_create()
[    4.080000] [ppe_eth_init] dma_setup_init()
[    4.090000] [avmnet] [avmnet_swi_7port_disable_learning] Configuring CPU-port to receive all unknown unicast frames 0x7b
[    4.100000] [avmnet] [avmnet_swi_7port_disable_learning] Configuring CPU-port to receive all unknown multicast frames 0x7b
[    5.240000] avm_pa: try to activate hw accelaration for pid 1 (ipv4)
[    5.240000] avm_pa: tx channel activated, pid 1 (ipv4)
[    5.250000] avm_pa: try to activate hw accelaration for pid 2 (ipv6)
[    5.250000] avm_pa: tx channel activated, pid 2 (ipv6)
[    5.260000] [avmnet_set_macaddr] Setup Mac Addr for Device(eth0): 5c:49:79:57:47:5a
[    5.270000] avmnet: avm_pa: register pid eth0
[    5.300000] SQUASHFS error: Can't find a SQUASHFS superblock on mtdblock3
[    5.300000] yaffs: dev is 32505859 name is "mtdblock3" ro
[    5.310000] yaffs: passed flags ""
[    5.310000] yaffs: yaffs: Attempting MTD mount of 31.3,"mtdblock3"
[    5.310000] yaffs: auto selecting yaffs2
[    5.330000] yaffs: yaffs_read_super: is_checkpointed 1
[    5.330000] VFS: Mounted root (yaffs filesystem) readonly on device 31:3.
[    5.340000] devtmpfs: mounted
[    5.340000] Freeing unused kernel memory: 292K (80857000 - 808a0000)
[    6.400000] TFFS Name Table L
[    8.160000] led_modul_Fritz_Box_HW209: module license '
(C) Copyright 2012 by AVM
' taints kernel.
[    8.170000] Disabling lock debugging due to kernel taint
[    8.180000] [module-alloc-by-name] give 0x1a000 bytes at 0x81104000 to module 'led_modul_Fritz_Box_HW209' (0xbb0000 bytes left)
[    8.200000] [LED] use GPIO 6 for 'gpio_avm_led_power'
[    8.210000] [LED] use GPIO 5 for 'gpio_avm_led_power_red'
[    8.210000] [LED] use GPIO 34 for 'gpio_avm_led_internet'
[    8.220000] [LED] use GPIO 15 for 'gpio_avm_led_dect'
[    8.220000] [LED] use GPIO 0 for 'gpio_avm_led_wlan'
[    8.230000] [LED] use GPIO 35 for 'gpio_avm_led_info'
[    8.230000] [BUTTON] use GPIO 1 for 'gpio_avm_button_wlan'
[    8.240000] [BUTTON] use GPIO 2 for 'gpio_avm_button_dect'
[    8.260000] AVM_WATCHDOG: System Init UEberwachung 120 Sekunden
[    9.100000] [module-alloc-by-name] give 0x3000 bytes at 0x8111e000 to module 'rtc_avm' (0xbad000 bytes left)
[    9.120000] rtc-avm rtc-avm.0: rtc core: registered avm as rtc0
[    9.120000] [avm-rtc]: avm_rtc_probe: register: ret=0x876ab000
[    9.130000] [avm-rtc]: avm_rtc_probe: success
[    9.320000]
[    9.500000]
[    9.510000] [piglet]dect_loader144xx: slow-bootmode
[    9.770000] <FE>
[   10.570000] *
[   12.830000]
[   15.060000] yaffs: dev is 32505861 name is "mtdblock5" rw
[   15.060000] yaffs: passed flags ""
[   15.060000] yaffs: yaffs: Attempting MTD mount of 31.5,"mtdblock5"
[   15.080000] yaffs: yaffs_read_super: is_checkpointed 1
[   15.320000] [module-alloc-by-name] give 0x75000 bytes at 0x8112f000 to module 'pcmlink' (0xb2a000 bytes left)
[   15.750000] [module-alloc-by-name] give 0xce000 bytes at 0x811a4000 to module 'isdn_fbox_fon5' (0xa5c000 bytes left)
[   15.810000] [capi_oslib]avm_stack_attach: cpu1 -> cpu1
[   15.810000] [pcmlink]chrony-support
[   15.830000] [isdn]PCMLINK: svnVersion: 2496 (isdn: 3215) Codecslots=6 Slics=1 Pots=0 TE=0 NT=0 DECT=4 no HwCross DSP-EC: 0
[   16.260000] [module-alloc-by-name] give 0x69000 bytes at 0x81272000 to module 'capi_codec' (0x9f3000 bytes left)
[   16.470000] [module-alloc-by-name] give 0x50000 bytes at 0x812db000 to module 'avm_dect' (0x9a3000 bytes left)
[   16.510000] [DECTDRV_ERR] fpCap ext data queueSize 2560, avmTpui 4096/36865, etsiTpui 40961/0
[   16.510000] [module-alloc-by-name] give 0x5000 bytes at 0x8132b000 to module 'dect_io' (0x99e000 bytes left)
[   16.990000] udevd[1219]: starting version 175
[   18.640000] [module-alloc-by-name] give 0x2e000 bytes at 0x81330000 to module 'mei_vr9' (0x970000 bytes left)
[   18.650000] [dsl_mei] Lantiq (VRX) DSL CPE MEI driver, version 1.4.4, (c) 2013 Lantiq Deutschland GmbH
[   18.650000] [dsl mei] tried to set GDBG Level to 4
[   18.650000] [dsl mei] debug_level=4, Global UsrDbgLevel=4 MEI_DRV UsrDbgLevel=4 MEI_MEI_ACCESS UsrDbgLevel=4
[   18.650000] [dsl mei] debug_level=4, Global IntDbgLevel=4 MEI_DRV IntDbgLevel=4 MEI_MEI_ACCESS IntDbgLevel=4
[   18.650000] [dsl_vr9] AVM_MEI_PowerUpDSLSubsystem enable power domain 'DSL + DFE'
[   18.650000] [AVM_MEI_PowerUpDSLSubsystem] power up 'PPE TC, PPE EMA, LEDC, DFEV1, DFEV0'
[   18.670000] [dsl_vr9] AVM_MEI_PowerUpDSLSubsystem unreset 'DSL, DFE, AFE, VOICE, DSLTC, ARC'
[   18.670000] spi_clc=0x00000200
[   18.850000] [module-alloc-by-name] give 0x51000 bytes at 0x8135e000 to module 'dsl_vr9' (0x91f000 bytes left)
[   18.880000] [dsl drv] Lantiq CPE API Driver version: DSL CPE API V4.17.6
[   18.880000] [dsl drv] Predefined debug level: 4
[   18.880000] [dsl drv] dynamically registered major number 237 for dsl_vr9
[   19.100000] [module-alloc-by-name] give 0x27000 bytes at 0x813af000 to module 'ifxmips_ppa_datapath_vr9_e5' (0x8f8000 bytes left)
[   19.110000] Loading E5 (MII0/1) driver ......
[   19.120000] drivers/net/ethernet/avm/avm_cpmac/switch/ifx/vr9/ifxmips_ppa_datapath_vr9_e5.c:3029:init_local_variables: [init_local_variables] g_eth_wan_mode=0
[   19.120000] drivers/net/ethernet/avm/avm_cpmac/switch/ifx/vr9/ifxmips_ppa_datapath_vr9_e5.c:3088:init_local_variables: g_wan_itf=0x80, g_wanqos_en=8
[   19.130000] CPU_TO_WAN_TX_DESC_BASE[0] =0xbe227400
[   19.140000] avmnet: avm_pa: register pid ptm_vr9
[   19.140000] [avmnet] [avmnet_swi_7port_disable_learning] Configuring CPU-port to receive all unknown unicast frames 0x7b
[   19.140000] [avmnet] [avmnet_swi_7port_disable_learning] Configuring CPU-port to receive all unknown multicast frames 0x7b
[   19.140000] [ppe_e5_init] Succeeded!
[   19.140000] PPE datapath driver info:
  Version ID: 64.3.3.1.0.1.1
  Family    : VR9
  DR Type   : Normal Data Path | Indirect-Fast Path
  Interface : MII0 | MII1
  Mode      : Routing
  Release   : 0.1.1
[   19.140000] PPE firmware info:
  Version ID: 7.5.2.11.1
  Family    : VR9
  FW Package: D5
  Release   : 2.11.1
PPE firmware feature:
  ATM/PTM TC-Layer Bonding        Support
  L2 Trunking                     Support
  Packet Acceleration             Support
  IPv4                            Support
  IPv6                            Support
  6RD                             Support
  DS-Lite                         Support
[   20.910000] activating IRQ mode
[   20.910000] requesting IRQ
[   20.910000] request_irq
[   20.910000] usedIrq: 57 | usedIsrHandler: 8133f520 | usedFlags: 0x100 | pUsedDevName: mei_vr9 | pUsedDevId: -2014107712
[   20.910000] IRQ requested ok
[   20.910000] MEI_DRV: MEI_IfxRequestIrq(IRQ = 57, .., ), lock = 1
check this C
[   20.910000] about to check device status
[   21.140000] system-load 6 loadavg 0.71 0.16 0.5 - 58 tasks:44 % curr:modprobe(4 %) max:migration/0(16 %, pid:7) pgstat: sum=25910 free=15990 slab=4264 alloc=1917/s fault=2852/s (sleep 0)
[   21.430000] [module-alloc-by-name] give 0x1cd000 bytes at 0x813d6000 to module 'kdsldmod' (0x72b000 bytes left)
[   21.580000] kdsldmod: init start (Feb 24 2017 10:58:58) sizeof(struct sk_buff)=448
[   21.580000] userman: device registerd (userman_url) with major=231
[   21.580000] kdsld: ttychannel: ldisc 8 registered
[   21.580000] PCP_NL: PCP netlink interface (multicast group 1)
[   21.580000] kdsldmod: init done (Feb 24 2017 10:58:55)
[   26.320000] [avm_power] eth: port 0 force normal  CON t0
[   27.340000] IPv6: ADDRCONF(NETDEV_UP): lan: link is not ready
[   27.340000] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   28.380000] IPv6: ADDRCONF(NETDEV_UP): guest: link is not ready
[   31.150000] system-load 100% loadavg 0.84 0.21 0.7 - 69 tasks:60 % curr:ctlmgr(26 %) max:ctlmgr(26 %, pid:1451) pgstat: sum=27352 free=11315 slab=4964 alloc=1957/s fault=3632/s (sleep 3)
[   20.910000] MEI_DRV[00]: INIT DEVICE, phy addr = 0x1E116000, virt addr = 0xBE116000 IRQ = 57
[   31.490000] Re-init AVM Net Common Datapath Driver 7Port Switch ......
[   31.490000] [init_hw] ppe_hw_init=0xff successful
[   31.490000] [avmnet] [avmnet_swi_7port_disable_learning] Configuring CPU-port to receive all unknown unicast frames 0x7b
[   31.490000] [avmnet] [avmnet_swi_7port_disable_learning] Configuring CPU-port to receive all unknown multicast frames 0x7b
[   31.490000] [reinit_7port_common_eth] Succeeded!
[   31.670000] [module-alloc-by-name] give 0x27000 bytes at 0x815a3000 to module 'aae' (0x704000 bytes left)
[   31.700000] [wlan_config] Given config is:
[   31.700000] [wlan_config]   hw_interface=0 chip_type=3 (kiwi) offload=1 (non)
[   31.700000] [wlan_config] hwrev=209 hwsubrev=1 maca=5c:49:79:57:47:5a
[   31.700000] [wlan_eeprom] Calibration data blocks found = 1
[   31.700000] [wlan_eeprom] EEPROM #1, type "AR92x7":
[   31.700000] [wlan_eeprom] Customer data="AVM7412_CAL1_V2"
[   31.700000] [wlan_eeprom] regDmn=0x8114 - patching to 0
[   31.700000] [wlan_eeprom] MinCCAPwr thresh set to -85,-85
[   31.700000] [wlan_eeprom] Build with ART 0.9b27
[   31.700000] avm_net_trace: New net trace device 'WLAN Management Traffic' registered with minor 128.
[   31.710000] avm_net_trace: udev device avm_net_trace128 created
[   31.730000] Loading E5 (MII0/1) driver ......
[   31.740000] drivers/net/ethernet/avm/avm_cpmac/switch/ifx/vr9/ifxmips_ppa_datapath_vr9_e5.c:3029:init_local_variables: [init_local_variables] g_eth_wan_mode=3
[   31.740000] drivers/net/ethernet/avm/avm_cpmac/switch/ifx/vr9/ifxmips_ppa_datapath_vr9_e5.c:3088:init_local_variables: g_wan_itf=0x2, g_wanqos_en=8
[   31.760000] CPU_TO_WAN_TX_DESC_BASE[0] =0xbe227400
[   31.760000] avmnet: avm_pa: register pid ptm_vr9
[   31.760000] [avmnet] [avmnet_swi_7port_disable_learning] Configuring CPU-port to receive all unknown unicast frames 0x7b
[   31.760000] [avmnet] [avmnet_swi_7port_disable_learning] Configuring CPU-port to receive all unknown multicast frames 0x7b
[   31.760000] [ppe_e5_init] Succeeded!
[   31.760000] PPE datapath driver info:
  Family    : VR9
  Mode      : Routing
  Release   : 0.1.1
[   31.760000] PPE firmware info:
  Family    : VR9
  FW Package: D5
  Release   : 2.11.1
  L2 Trunking                     Support
  IPv4                            Support
  IPv6                            Support
  6RD                             Support
  DS-Lite                         Support
[   31.880000] [module-alloc-by-name] give 0x14000 bytes at 0x815ca000 to module 'ifxmips_ppa_hal_vr9_e5' (0x6f0000 bytes left)
[   31.980000] [module-alloc-by-name] give 0x17000 bytes at 0x815de000 to module 'ifx_ppa_mini_sessions' (0x6d9000 bytes left)
[   31.980000] Register LANTIQ_PA @ AVM_PA
[   31.980000] [ifx_ppa_mini_session_init]
[   31.980000] [ifx_ppa_mini_session_init] avm_pa sessionh_lookup table
[   31.980000] max_lan_entries       192
[   31.980000] max_wan_entries       192
[   31.980000] max_mc_entries        32
[   31.980000] max_bridging_entries  2048
[   31.980000] max_ipv6_addr_entries 128
[   31.980000] max_fw_queue          8
[   31.980000] max_6rd_entries       4
[   31.980000] AVM - Lantiq-PPA: minimalist and slim Session Management: --- init successful
[   31.980000] Session-Table Size: 256 * 200 byte = 50 kb
[   32.030000] [module-alloc-by-name] give 0x3000 bytes at 0x815f5000 to module 'ifx_ppa_mini_qos' (0x6d6000 bytes left)
[   32.040000] AVM - Lantiq-PPA: minimalist and slim QoS Management: --- init successful
[   32.050000] kdsld: flushing internet sessions
[   32.080000] [module-alloc-by-name] give 0x7000 bytes at 0x815f8000 to module 'adf' (0x6cf000 bytes left)
[   32.100000] ****Address of trace_timer :815fb100
[   32.130000] [module-alloc-by-name] give 0x4000 bytes at 0x815ff000 to module 'asf' (0x6cb000 bytes left)
[   32.640000] [module-alloc-by-name] give 0x3000 bytes at 0x81603000 to module 'sch_tbf' (0x6c8000 bytes left)
[   32.810000] [module-alloc-by-name] give 0xb7000 bytes at 0x81606000 to module 'ath_hal' (0x611000 bytes left)
[   32.830000] ath_hal: 0.9.17.1 (AR5416, AR9380, REGOPS_FUNC, WRITE_EEPROM, TX_DATA_SWAP, RX_DATA_SWAP, 11D)
[   32.900000] [module-alloc-by-name] give 0x9000 bytes at 0x816bd000 to module 'ath_rate_atheros' (0x608000 bytes left)
[   32.910000] ath_rate_atheros: Copyright (c) 2001-2005 Atheros Communications, Inc, All Rights Reserved
[   32.990000] [module-alloc-by-name] give 0xc000 bytes at 0x816c6000 to module 'ath_spectral' (0x5fc000 bytes left)
[   33.000000] ath_spectral: Version 2.0.0
Copyright (c) 2005-2009 Atheros Communications, Inc. All Rights Reserved
[   33.000000] SPECTRAL module built on Feb  7 2017 17:11:10
[   33.080000] [module-alloc-by-name] give 0x14000 bytes at 0x816d2000 to module 'ath_dfs' (0x5e8000 bytes left)
[   33.090000] ath_dfs: Version 2.0.0
Copyright (c) 2005-2006 Atheros Communications, Inc. All Rights Reserved
[   33.450000] system-load 4 loadavg 0.84 0.21 0.7 - 81 tasks:8 % curr:insmod(0 %) max:ctlmgr(3 %, pid:1451) pgstat: sum=27401 free=9006 slab=5130 alloc=244/s fault=298/s (sleep 3)
[   33.490000] [module-alloc-by-name] give 0x5f000 bytes at 0x816e6000 to module 'ath_dev' (0x589000 bytes left)
[   33.540000] ath_dev: Copyright (c) 2001-2007 Atheros Communications, Inc, All Rights Reserved
[   34.690000] [module-alloc-by-name] give 0x119000 bytes at 0x81745000 to module 'umac' (0x470000 bytes left)
[   34.810000] ath_pci: SmartAntenna-DRT-0.1 (Atheros/multi-bss)
[   34.810000] PCI: Enabling device 0000:01:00.0 (0000 -> 0002)
[   34.810000] __ath_attach: Set global_scn[0]
[   34.820000] SPECTRAL : get_capability not registered
[   34.820000] HAL_CAP_PHYDIAG : Capable
[   34.820000] SPECTRAL : Need to fix the capablity check for RADAR (spectral_attach : 231)
[   34.820000] HAL_CAP_RADAR   : Capable
[   34.820000] SPECTRAL : Need to fix the capablity check for SPECTRAL
 (spectral_attach : 236)
[   34.820000] HAL_CAP_SPECTRAL_SCAN : Capable
[   34.820000] SPECTRAL : get_tsf64 not registered
[   34.820000] spectral_init_netlink 83 NULL SKB
[   34.820000] SPECTRAL : No ADVANCED SPECTRAL SUPPORT
[   34.820000] SPECTRAL :----- module attached
[   34.820000] GreenAP on wifi%d: Attached
[   34.820000] ath_get_caps[6416] rx chainmask mismatch actual 3 sc_chainmak 0
[   34.820000] ath_get_caps[6391] tx chainmask mismatch actual 3 sc_chainmak 0
[   34.820000] ic_num_chains=2x2
[   34.820000] _avm_ath_ext_attach_ah:169
[   34.820000] band steering initialized for direct attach hardware
[   34.830000] ieee80211_bsteering_attach: Band steering initialized
[   34.830000] ath_attach_dfs[13067] dfsdomain 1
[   34.830000] SPECTRAL : module already attached
[   34.830000] osif_wrap_attach:321 osif wrap attached
[   34.830000] osif_wrap_devt_init:946 osif wrap dev table init done
[   34.840000] request_irq type = 0x80
[   34.850000] avm_net_trace: New net trace device 'HW (2.4 + 5 GHz, wifi0)' registered with minor 129.
[   34.850000] Register net trace device succeeded with minor 129 (wifi0).
[   34.850000] wifi0: Atheros ???: mem=0x1c000000, irq=138 hw_base=0xbc000000
[   34.850000] _avm_ath_ext_attach_ieee:151
[   34.860000] avm_net_trace: udev device avm_net_trace129 created
[   34.900000] [module-alloc-by-name] give 0x6000 bytes at 0x8185e000 to module 'ath_pktlog' (0x46a000 bytes left)
[   35.290000] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   35.290000] IPv6: ADDRCONF(NETDEV_CHANGE): lan: link becomes ready
[   35.680000] ath_attach_dfs[13067] dfsdomain 1
[   35.700000] Requested VPA id 0 and MAC 5c:49:79:57:47:5c
[   35.700000] avm_net_trace: New net trace device 'AP (2.4 + 5 GHz, ath0)' registered with minor 131.
[   35.700000] Register vap net trace device succeeded with minor 131 (ath0).
[   35.700000] avm_net_trace: New net trace device 'AP (2.4 + 5 GHz, ath0)' registered with minor 132.
[   35.700000] Register vap net trace device succeeded with minor 132 (ath0).
[   35.700000] VAP device ath0 created osifp: (85583420) os_if: (87634000)
[   35.710000] avm_net_trace: udev device avm_net_trace131 created
[   35.710000] avm_net_trace: udev device avm_net_trace132 created
[   35.710000] ath0: registered PID at AVM_PA
[   35.710000] avm_pa: try to activate hw accelaration for pid 5 (ath0)
[   35.710000] avm_pa: rx channel activated, pid 5 (ath0)
[   35.710000] avm_pa: tx channel activated, pid 5 (ath0)
[   35.710000] ath0: registered VPID at AVM_PA
[   35.710000]
 DES SSID SET=FRITZ!Box 7412
[   35.720000] ACFG vendor param set fail, AVM mcast-to-ucast deactivated
[   35.830000]  ieee80211_ioctl_siwmode: imr.ifm_active=131712, new mode=3, valid=1
[   35.870000]  DEVICE IS DOWN ifname=ath0
[   36.420000] Warning: node not in table 0x85483000
[   36.570000] 8021q: adding VLAN 0 to HW filter on device ath0
[   37.540000] [DECTDRV_ERR] API_FP_MAC_START_STOP_REQ 255 -> 0
[   37.550000] [TFFS3-NAND] writing TFFS header to address 0x160000. SeqNr: 0x116 EraseCnt: 0x7
[   37.550000] [DECTDRV_ERR] fpCap ext data queueSize 2560, avmTpui 4096/36865, etsiTpui 40961/0
[   37.560000] [TFFS3-NAND] writing TFFS header to address 0x140000. SeqNr: 0x117 EraseCnt: 0x8
[   37.560000] [TFFS3-NAND] writing TFFS header to address 0x180000. SeqNr: 0x118 EraseCnt: 0x8
[   37.560000] [DECTDRV_ERR] fpCap ext data queueSize 2560, avmTpui 4096/36865, etsiTpui 40961/0
[   37.570000] [TFFS3-NAND] writing TFFS header to address 0x200000. SeqNr: 0x119 EraseCnt: 0x8
[   37.760000] [module-alloc-by-name] give 0x26000 bytes at 0x81864000 to module 'krtp' (0x444000 bytes left)
[   37.780000] krtp: rtp_fastpath_register done
[   37.780000] krtp: krtp_init done
[   37.790000] jitterbuffer_set_config: auto_on 1   ms 50   packets 0
[   37.790000] avm_pa: telephony_reduce 65
[   37.790000] avm_pa: mswin 300 400
[   37.940000] [DECTDRV_ERR] API_FP_MAC_START_STOP_REQ 0 -> 0
[   37.960000] [DECTDRV_ERR] fpCap ext data queueSize 2560, avmTpui 4096/36865, etsiTpui 40961/0
[   37.970000] [DECTDRV_ERR] API_FP_MAC_START_STOP_REQ 0 -> 0
[   37.980000] [DECTDRV_ERR] fpCap ext data queueSize 2560, avmTpui 4096/36865, etsiTpui 40961/0
[   38.170000] [dma_device_write] auto open tx_chan_no:2
[   38.530000] AVM_WATCHDOG: System Init UEberwachung abgeschlossen (89950 ms noch verfuegbar)
[   38.550000] [avm_power] pm_ressourceinfo_scriptparse: powerdevice_loadrate: norm_power_rate=100 act_rate=78 mul=15 div=1 offset=0 NormP=1500 mW -> SumNormP=1500 mW
[   38.550000] [avm_power] pm_ressourceinfo_scriptparse: powerdevice_cpuclock: norm_power_rate=100 act_rate=100 mul=0 div=1 offset=0 NormP=0 mW -> SumNormP=1500 mW
[   38.550000] [avm_power] pm_ressourceinfo_scriptparse: powerdevice_dspclock: norm_power_rate=100 act_rate=100 mul=0 div=1 offset=1000 NormP=1000 mW -> SumNormP=2500 mW
[   38.550000] [avm_power] pm_ressourceinfo_scriptparse: powerdevice_systemclock: norm_power_rate=100 act_rate=100 mul=0 div=1 offset=2000 NormP=2000 mW -> SumNormP=4500 mW
[   38.550000] [avm_power] pm_ressourceinfo_scriptparse: powerdevice_dsl: norm_power_rate=100 act_rate=0 mul=15 div=1 offset=0 NormP=1500 mW -> SumNormP=6000 mW
[   38.550000] [avm_power] pm_ressourceinfo_scriptparse: powerdevice_analog: norm_power_rate=100 act_rate=0 mul=141 div=10 offset=100 NormP=1510 mW -> SumNormP=7510 mW
[   38.550000] [avm_power] pm_ressourceinfo_scriptparse: powerdevice_wlan: norm_power_rate=100 act_rate=0 mul=84 div=10 offset=100 NormP=940 mW -> SumNormP=8450 mW
[   38.550000] [avm_power] pm_ressourceinfo_scriptparse: powerdevice_ethernet: norm_power_rate=167 act_rate=16777234 mul=1 div=1 offset=50 NormP=217 mW -> SumNormP=8667 mW
[   38.550000] SysRq : Changing Loglevel
[   38.550000] Loglevel set to 4
[   38.650000] ---> reanimated debugbuffer: read=0 write=12074, written=12074 <---
[   41.250000] system-load 100% loadavg 1.24 0.31 0.11 - 88 tasks:57 % curr:pidof(0 %) max:kworker/1:1H(13 %, pid:1134) pgstat: sum=28033 free=3979 slab=6366 alloc=1747/s fault=2777/s (sleep 1)
[   42.450000] Warning: node not in table 0x85724000
[   42.730000] GreenAP on wifi0: Transition to Power save (WAIT)
[   42.740000] 8021q: adding VLAN 0 to HW filter on device ath0
[   51.490000] system-load 1 loadavg 1.20 0.34 0.12 - 87 tasks:13 % curr:upnpd(6 %) max:upnpd(6 %, pid:1457) pgstat: sum=27881 free=3605 slab=6314 alloc=512/s fault=884/s (sleep 0)
[   65.160000] Module will be unloaded
[   91.770000] system-load 1 loadavg 0.94 0.39 0.14 - 75 tasks:7 % curr:luacgi(1 %) max:ctlmgr(2 %, pid:1451) pgstat: sum=27473 free=6867 slab=6248 alloc=114/s fault=160/s (sleep 0)
[  104.030000] [module-alloc-by-name] give 0x7000 bytes at 0x8188a000 to module 'kspeedtest' (0x43d000 bytes left)
[  104.040000] kspeedtest: kspeedtest_init: second timer started
[  104.040000] kspeedtest: kspeedtest_init done
[  140.920000] Max Lock Time [12825]Sched/[0]Yield 19684 / 0 cycles
[  140.920000] REG_TE_REV            (00): 00000000
[  140.920000] REG_TE_FRM_SAMPLE_CTRL(04): 00000000
[  140.920000] REG_TE_TRANSMIT_CTRL  (08): 00000008
[  140.920000] REG_TE_CMD_STATUS     (0c): 00000000
[  140.920000] REG_NT_REV            (10): 00000000
[  140.920000] REG_NT_FRM_SAMPLE_CTRL(14): 00000000
[  140.920000] REG_NT_TRANSMIT_CTRL  (18): 00000014
[  140.920000] REG_NT_CMD_STATUS     (1c): 00000000
[  140.920000] REG_PCM_CTRL_TE       (20): 00000000
[  140.920000] REG_PCM_CTRL_NT       (24): 00000000
[  140.920000] REG_PCM_CTRL_DECT     (28): 00000000
[  140.920000] REG_GLOBAL_MISC       (2c): 00000000
[  140.920000] REG_IAPOTS            (3c): 00000000
[  140.920000] REG_DIR               (40): 01100076
[  140.920000] REG_ANALOG_IN         (44): 00000088
[  140.920000] REG_ANALOG_OUT        (48): 01100026
[  140.920000] REG_EDGE_CTRL         (4c): 00000000
[  140.920000] REG_EDGE_DETECT       (50): 00000000
[  140.920000] REG_CODEC_POTS        (54): 00000000
[  140.920000] REG_CODEC_SLIC1       (58): 00000000
[  140.920000] REG_CODEC_SLIC2       (5c): 00000000
[  140.920000] REG_CODEC_SLIC3       (60): 00000000
[  140.920000] REG_CODEC_COMMON      (64): 00000000
[  140.920000] [pcmlink]ReadMaskValid=21f10cc 21f10cc
[  140.920000] addr=00 value=00000000 shadow(real: 00000000 shadow: 00000000)
[  140.920000] addr=04 value=00000000 shadow(real: 00000000 shadow: 00000000)
[  140.920000] addr=08 value=00000000 real(real: 00000000 shadow: 00000008)
[  140.920000] addr=0c value=00000000 real(real: 00000000 shadow: 00000000)
[  140.920000] addr=10 value=00000000 shadow(real: 00000000 shadow: 00000000)
[  140.920000] addr=14 value=00000000 shadow(real: 00000000 shadow: 00000000)
[  140.920000] addr=18 value=00000000 real(real: 00000000 shadow: 00000014)
[  140.920000] addr=1c value=00000000 real(real: 00000000 shadow: 00000000)
[  140.920000] addr=20 value=00000000 shadow(real: 00000000 shadow: 00000000)
[  140.920000] addr=24 value=00000000 shadow(real: 00000000 shadow: 00000000)
[  140.920000] addr=28 value=00000000 shadow(real: 00000000 shadow: 00000000)
[  140.920000] addr=2c value=00000000 shadow(real: 00000000 shadow: 00000000)
[  140.920000] addr=30 value=00000000 real(real: 00000000 shadow: 00000000)
[  140.920000] addr=34 value=00000000 shadow(real: 00000000 shadow: 00000000)
[  140.920000] addr=38 value=00000000 shadow(real: 00000000 shadow: 00000000)
[  140.920000] addr=3c value=00000000 shadow(real: 00000000 shadow: 00000000)
[  140.920000] addr=40 value=01100076 real(real: 01100076 shadow: 01100076)
[  140.920000] addr=44 value=0000c088 real(real: 0000c088 shadow: 00000000)
[  140.920000] addr=48 value=01100026 real(real: 01100026 shadow: 01100026)
[  140.920000] addr=4c value=00000000 real(real: 00000000 shadow: 00000001)
[  140.920000] addr=50 value=00000000 real(real: 00000000 shadow: 00000000)
[  140.920000] addr=54 value=00000000 shadow(real: 00000000 shadow: 00000000)
[  140.920000] addr=58 value=00000000 shadow(real: 00000000 shadow: 00000000)
[  140.920000] addr=5c value=00000000 shadow(real: 00000000 shadow: 00000000)
[  140.920000] addr=60 value=00000000 shadow(real: 00000000 shadow: 00000000)
[  140.920000] addr=64 value=00000000 real(real: 00000000 shadow: 00000000)
[  140.920000] TDM: SLOT-RX-DATA[0] 871ff180 : ffff fefe fefe fefe d555 0c08 ffff fefe fefe fefe d555 0c08 ffff fefe fefe
[  140.920000] TDM: SLOT-RX-DATA[1] 871ff480 : ffff fefe fefe fefe d555 0c08 ffff fefe fefe fefe d555 0c08 ffff fefe fefe
[  140.920000] TDM:
[  140.920000] Frame-Violations 0.0 % (diff=2283) from 1000881 triggers irqs max-time between frame-trigger 179 us
[  140.920000] yield-cnt: 1000881
[  140.920000] TDM:
[  140.920000] be100800:SPI_CLC         00000200
[  140.920000] be100804:SPI_PISEL       00000000 CIS=0 SIS=0 MIS=0
[  140.920000] be100808:SPI_ID          08084528 TXFS=8 RXFS=8 ID=0x45 CFG=1 REV=8
[  140.920000] be100810:SPI_CON         005f0050 RX/TX_SWP=0/0 ENBV BM=31 TX/RXENDI=0/0  PO=1 PH=0 MSB first  RX/TXOFF=0/0
[  140.920000] be100814:SPI_STAT        04032005 RXBV=0 TXBV=4 BC=3 BSY SSEL EN
[  140.920000] be100830:SPI_RXFCON      00000301 RXFITL=3 RXFEN=1
[  140.920000] be100834:SPI_TXFCON      00000101 TXFITL=1 TXFEN=1
[  140.920000] be100838:SPI_FSTAT       00000200 TXFFL=2 RXFFL=0
[  140.920000] be100840:SPI_BRT         00000001
[  140.920000] be100844:SPI_BRSTAT      00000000
[  140.920000] be100860:SPI_SFCON       00000000 PLEN=0 STOP=0 ICLK=0 IDAT=0 DLEN=0 IAEN=0 IBEN=0 SFEN=0
[  140.920000] be100864:SPI_SFSTAT      00000000 PCNT=0 DCNT=0 PBSY=0 DBSY=0
[  140.920000] be100870:SPI_GPOCON      00000000 ISCSBn=0x0 INVOUTn=0x0
[  140.920000] be100874:SPI_GPOSTAT     00000000 OUTn=0x0
[  140.920000] be100880:SPI_RXREQ       00000000
[  140.920000] be100884:SPI_RXCNT       00000000
[  140.920000] be1008ec:SPI_DMACON      00000000 RXCLS=0 TXOFF RXOFF
[  140.920000] be1008f4:SPI_IRNEN       00000002 RIREN
[  140.920000] be1008f8:SPI_IRNICR      00000000
[  140.920000] be1008fc:SPI_IRNCR       00000011 TFI TIR
[  140.920000] bf101014: YIELD_EN1 0x10000
[  140.920000] Cycle-Freq: 250 MHz
[  140.920000] [cpu=1 tc=2]yield: mask=0x301 trigger=31279 stack-used=1076(stack-start=87cbff10 gp=87cbc000) from 16144 bytes
[  140.920000] 	[ 0]handler: lspitdm_yield+0x0/0x60 [pcmlink] enable=1 count=31279 unhandled=0
[  140.920000] 			cycle-stat: [31279]consumption: min=1939 max=83636 avg=11824
[  140.920000] 			cycle-stat: [31278]trigger: min=30404 max=1013026 avg=999964
[  140.920000] [cpu=0 tc=3]yield: mask=0x2410 trigger=1290009 stack-used=184(stack-start=87ccff10 gp=87ccc000) from 16144 bytes
[  140.920000] 	[10]handler: lspitdm_frameyield+0x0/0x4a0 [pcmlink] enable=1 count=1290009 unhandled=0
[  140.920000] 			cycle-stat: [1290010]consumption: min=72 max=17119 avg=583
[  140.920000] 			cycle-stat: [1290009]trigger: min=170 max=44304 avg=24246
[  140.920000] [cpu=1]Yield-to-Linux-Statistic:
[  140.920000] 	Max-Burst-Executed:                     3
[  140.920000] 	Max-Trigger-Latency:                   41 us  (since last call)
[  140.920000] 	avg Trigger-Period:                  3679 ms  (since last call)
[  140.920000] [cpu=1]Executed ipi-functions-sum (since last call):
[  140.920000]               wake_up_type:               66 (avm_dect_trigger_thread+0x68/0xe0 [avm_dect])
[  140.920000] max consumption 227 us
[  140.920000] avg consumption 30 us (measurement period 125.116 s)
[  140.920000] max well      delay between irq<->irq 4062 us
[  140.920000] min           delay between irq<->irq 0 us
[  140.920000] [DECTDRV] STUB side status of pcm link ...
[  140.920000] [DECTDRV] n_tx:                    64
[  140.920000] [DECTDRV] n_rx:                    28
[  140.920000] [DECTDRV] n_rx_cs_errors:          0
[  140.920000] [DECTDRV] n_rx_len_errors:         0
[  140.920000] [DECTDRV] n_rx_overflows:          0
[  140.920000] [DECTDRV] n_rx_buffer_overruns:    0
[  140.920000] [DECTDRV] n_phase_info_errors:     0
[  140.920000] [DECTDRV] n_dsp_int_errors:        0
[  140.920000] [DECTDRV] n_dsp_overflows:         0
[  140.920000] [DECTDRV] n_mail_overflow:         0
[  140.920000] [DECTDRV] phase_info:              140
[  140.920000] [DECTDRV] n_lost_messages:         0
[  140.920000] [DECTDRV] DRIVER side status of pcm link ...
[  140.920000] [DECTDRV] tx_n_mails:              28
[  140.920000] [DECTDRV] rx_n_mails:              66
[  140.920000] [DECTDRV] rx_n_cs_errors:          0
[  140.920000] [DECTDRV] rx_n_len_errors:         0
[  140.920000] [DECTDRV] rx_n_mail_cnt_errors:    0
[  140.920000] [DECTDRV] rx_n_lost_mails:         0
[  140.920000] [DECTDRV] tx_max_len:              19
[  140.920000] [DECTDRV] rx_max_len:              34
[  140.920000] [DECTDRV] STUB OS status ...
[  140.920000] [DECTDRV] stub alive:          yes
[  140.920000] [DECTDRV] mail_buffer_usage:   0x3b
[  140.920000] [DECTDRV] heap_usage:          0x0
[  140.920000] [DECTDRV] runtime_error:       code=0x0, line=0, task=0
(ich habe mal die komplette "dmesg"-Ausgabe der originalen 06.83 von AVM oben dringelassen).
Nachdem Freetz ja m.W. keine Änderungen an den Kernel-Parametern vornimmt (iirc werden die vom Bootloader so gesetzt), ist das also bei der 7412 wohl "ttyS0", auch wenn der Bootloader im Environment das als "tty0" verzeichnet (da steht das aber auch als "bootserport") - außerdem stimmt das mit den original von AVM verwendeten Gerätenamen überein:
# [COLOR="#0000FF"][B]cat /etc/inittab[/B][/COLOR]
/dev/ttyS0::sysinit:/etc/init.d/rc.S
# Start an "askfirst" shell on ttyS0
/dev/ttyS0::askfirst:-/bin/sh
# Stuff to do before rebooting
/dev/ttyS0::shutdown:/bin/sh -c /var/post_install
# [COLOR="#0000FF"][B]cat /wrapper/etc/inittab[/B][/COLOR]
null::sysinit:/bin/mount -t squashfs /filesystem_core.squashfs /core -o loop
null::sysinit:/sbin/pivot_root /core/ /core/wrapper/
null::sysinit:/bin/mount /wrapper/dev /dev -o bind
null::sysinit:/wrapper/sbin/flash_update
Bliebe noch die Möglichkeit, daß bei Freetz die "character devices" für die "ttySx" irgendwelche anderen Major- oder Minor-IDs verwenden (und sich von denen von AVM unterscheiden, m.W. werden die im Freetz ja "von Hand" angelegt und nicht kopiert (bzw. nach dem Kopieren von "original" sogar wieder gelöscht), oder?) - für mich aber eine unwahrscheinliche Fehlerquelle.
michaelwarwel
