This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
It was created by configure, which was
generated by GNU Autoconf 2.69. Invocation command line was
$ ./configure --cache-file=/freetz/source/target-mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/config.cache --target=mips-linux --host=mips-linux --build=x86_64-pc-linux-gnu --program-prefix= --program-suffix= --prefix=/usr --exec-prefix=/usr --bindir=/usr/bin --datadir=/usr/share --includedir=/usr/include --infodir=/usr/share/info --libdir=/usr/lib --libexecdir=/usr/lib --localstatedir=/var --mandir=/usr/share/man --sbindir=/usr/sbin --sysconfdir=/etc --with-gnu-ld --disable-nls --with-pcre-regex=/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/usr --with-curl=/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/usr --with-gd=/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/usr --enable-gd-native-ttf --with-iconv --with-iconv-dir=/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/usr --enable-json --with-libxml-dir=/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/usr --without-libexpat-dir --enable-xml --enable-libxml --enable-dom --enable-simplexml --enable-xmlreader --enable-xmlwriter --enable-pcntl --enable-session --enable-sockets --without-sqlite --with-sqlite3=/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/usr --with-pdo-sqlite=/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/usr --with-openssl=/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/usr --enable-sysvsem --enable-sysvshm --enable-sysvmsg --with-zlib --with-zlib-dir=/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/usr --enable-zip --enable-exif --enable-mbstring --disable-cli --disable-fileinfo --disable-phar --disable-rpath --with-config-file-path=/tmp/flash --with-config-file-scan-dir=/tmp/flash/php --without-pear
## Platform. ##
hostname = Michael-Ubuntu
uname -m = x86_64
uname -r = 3.13.0-36-generic
uname -s = Linux
uname -v = #63-Ubuntu SMP Wed Sep 3 21:30:07 UTC 2014
/usr/bin/uname -p = unknown
/bin/uname -X = unknown
/bin/arch = unknown
/usr/bin/arch -k = unknown
/usr/convex/getsysinfo = unknown
/usr/bin/hostinfo = unknown
/bin/machine = unknown
/usr/bin/oslevel = unknown
/bin/universe = unknown
PATH: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin
PATH: /freetz/toolchain/build/mips_gcc-4.8.3/mips-unknown-linux-gnu/bin
PATH: /usr/local/sbin
PATH: /usr/local/bin
PATH: /usr/sbin
PATH: /usr/bin
PATH: /sbin
PATH: /bin
PATH: /usr/games
PATH: /usr/local/games
## Core tests. ##
configure:3179: loading site script /freetz/include/site/mips-linux-uclibc
| #!/bin/sh
| . $FREETZ_BASE_DIR/include/site/mips-linux
| # . $FREETZ_BASE_DIR/include/site/linux-uclibc
| . $FREETZ_BASE_DIR/include/site/freetz
configure:3194: loading cache /freetz/source/target-mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/config.cache
configure:3280: checking for grep that handles long lines and -e
configure:3338: result: /bin/grep
configure:3343: checking for egrep
configure:3405: result: /bin/grep -E
configure:3410: checking for a sed that does not truncate output
configure:3464: result: /bin/sed
configure:3569: checking build system type
configure:3583: result: x86_64-pc-linux-gnu
configure:3603: checking host system type
configure:3616: result: mips-unknown-linux-gnu
configure:3636: checking target system type
configure:3649: result: mips-unknown-linux-gnu
configure:3780: checking for mips-linux-cc
configure:3807: result: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc
configure:3882: checking for C compiler version
configure:3891: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc --version >&5
mips-linux-uclibc-gcc (GCC) 4.8.3
Copyright (C) 2013 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
configure:3902: $? = 0
configure:3891: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -v >&5
Using built-in specs.
COLLECT_GCC=/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc
COLLECT_LTO_WRAPPER=/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/../libexec/gcc/mips-linux-uclibc/4.8.3/lto-wrapper
Target: mips-linux-uclibc
Configured with: /home/gene/freetz/freetz-trunk-dev/source/toolchain-mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/gcc-4.8.3/configure --prefix=/home/gene/freetz/freetz-trunk-dev/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc --with-sysroot=/home/gene/freetz/freetz-trunk-dev/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/usr/ --build=x86_64-pc-linux-gnu --host=x86_64-pc-linux-gnu --target=mips-linux-uclibc --enable-languages=c,c++ --enable-shared --enable-threads --with-gmp=/home/gene/freetz/freetz-trunk-dev/tools/build --with-mpfr=/home/gene/freetz/freetz-trunk-dev/tools/build --with-mpc=/home/gene/freetz/freetz-trunk-dev/tools/build --with-gnu-ld --disable-__cxa_atexit --disable-libgomp --disable-libmudflap --disable-multilib --enable-tls --disable-fixed-point --with-float=soft --enable-cxx-flags=-msoft-float --disable-libssp --with-march=24kc --disable-nls --with-mips-plt --disable-decimal-float
Thread model: posix
gcc version 4.8.3 (GCC)
configure:3891: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -V >&5
mips-linux-uclibc-gcc: error: unrecognized command line option '-V'
mips-linux-uclibc-gcc: fatal error: no input files
compilation terminated.
configure:3902: $? = 1
configure:3891: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -qversion >&5
mips-linux-uclibc-gcc: error: unrecognized command line option '-qversion'
configure:3922: checking whether the C compiler works
configure:3944: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 conftest.c >&5
configure:3948: $? = 0
configure:3996: result: yes
configure:3999: checking for C compiler default output file name
configure:4001: result: a.out
configure:4007: checking for suffix of executables
configure:4014: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -o conftest -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 conftest.c >&5
configure:4018: $? = 0
configure:4040: result:
configure:4062: checking whether we are cross compiling
configure:4100: result: yes
configure:4105: checking for suffix of object files
configure:4152: result: o
configure:4156: checking whether we are using the GNU C compiler
configure:4184: result: yes
configure:4193: checking whether /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc accepts -g
configure:4254: result: yes
configure:4271: checking for /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc option to accept ISO C89
configure:4347: result: none needed
configure:4373: checking how to run the C preprocessor
configure:4443: result: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -E
configure:4463: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -E conftest.c
configure:4463: $? = 0
configure:4477: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -E conftest.c
conftest.c:9:28: fatal error: ac_nonexistent.h: No such file or directory
#include <ac_nonexistent.h>
configure:4477: $? = 1
configure: failed program was:
| /* confdefs.h */
| #define PACKAGE_NAME ""
| #define PACKAGE_TARNAME ""
| #define PACKAGE_VERSION ""
| #define PACKAGE_STRING ""
| #define PACKAGE_BUGREPORT ""
| #define PACKAGE_URL ""
| /* end confdefs.h. */
configure:4508: checking for icc
configure:4517: result: no
configure:4531: checking for suncc
configure:4540: result: no
configure:4555: checking whether /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc and cc understand -c and -o together
configure:4655: result: yes
configure:4670: checking how to run the C preprocessor
configure:4740: result: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -E
configure:4760: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -E conftest.c
configure:4760: $? = 0
configure:4774: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -E conftest.c
configure:4774: $? = 1
| /* confdefs.h */
configure:4802: checking for ANSI C header files
configure:4906: result: yes
configure:4919: checking for sys/types.h
configure:4919: result: yes
configure:4919: checking for sys/stat.h
configure:4919: checking for stdlib.h
configure:4919: checking for string.h
configure:4919: checking for memory.h
configure:4919: checking for strings.h
configure:4919: checking for inttypes.h
configure:4919: checking for stdint.h
configure:4919: checking for unistd.h
configure:4932: checking for minix/config.h
configure:4932: result: no
configure:4953: checking whether it is safe to define __EXTENSIONS__
configure:4978: result: yes
configure:4993: checking whether ln -s works
configure:4997: result: yes
configure:5008: checking for system library directory
configure:5023: result: lib
configure:5032: checking whether to enable runpaths
configure:5046: result: no
configure:5053: checking if compiler supports -R
configure:5072: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -o conftest -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 conftest.c -R /usr/lib >&5
configure:5072: $? = 0
configure:5082: result: yes
configure:5134: checking for gawk
configure:5162: result: gawk
configure:5206: checking for bison
configure:5233: result: bison -y
configure:5254: checking for bison version
configure:5274: result: invalid
configure:5280: WARNING: bison versions supported for regeneration of the Zend/PHP parsers: 2.4 2.4.1 2.4.2 2.4.3 2.5 2.5.1 2.6 2.6.1 2.6.2 2.6.3 2.6.4 2.6.5 2.7 (found: 3.0).
configure:5293: checking for re2c
configure:5323: result: no
configure:5348: WARNING: You will need re2c 0.13.4 or later if you want to regenerate PHP parsers.
configure:5369: checking whether to enable computed goto gcc extension with re2c
configure:5383: result: no
configure:5677: checking whether to force non-PIC code in shared modules
configure:5691: result: no
configure:5709: checking whether /dev/urandom exists
configure:5715: result: yes
configure:5817: checking for pthreads_cflags
configure:5880: result:
configure:5883: checking for pthreads_lib
configure:5945: result:
configure:6018: result:
configure:6020: result: [1mConfiguring SAPI modules[m
configure:6048: checking for AOLserver support
configure:6263: result: no
configure:6291: checking for Apache 1.x module support via DSO through APXS
configure:6581: result: no
configure:6607: checking for Apache 1.x module support
configure:7379: result: no
configure:7391: checking whether to enable Apache charset compatibility option
configure:7405: result: no
configure:7555: checking for Apache 2.0 filter-module support via DSO through APXS
configure:8351: result: no
configure:8379: checking for Apache 2.0 handler-module support via DSO through APXS
configure:9175: result: no
configure:9204: checking for Apache 1.x (hooks) module support via DSO through APXS
configure:9494: result: no
configure:9520: checking for Apache 1.x (hooks) module support
configure:10292: result: no
configure:10304: checking whether to enable Apache charset compatibility option
configure:10318: result: no
configure:10469: checking for Caudium support
configure:10783: result: no
configure:10811: checking for setproctitle
configure:10811: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -o conftest -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -fvisibility=hidden -D_XPG_IV conftest.c >&5
/tmp/cczueh3W.o: In function `main':
conftest.c:(.text.startup+0x8): undefined reference to `setproctitle'
collect2: error: ld returned 1 exit status
configure:10811: $? = 1
| /* confdefs.h */
| #define STDC_HEADERS 1
| #define HAVE_SYS_TYPES_H 1
| #define HAVE_SYS_STAT_H 1
| #define HAVE_STDLIB_H 1
| #define HAVE_STRING_H 1
| #define HAVE_MEMORY_H 1
| #define HAVE_STRINGS_H 1
| #define HAVE_INTTYPES_H 1
| #define HAVE_STDINT_H 1
| #define HAVE_UNISTD_H 1
| #define __EXTENSIONS__ 1
| #define _ALL_SOURCE 1
| #define _GNU_SOURCE 1
| #define _POSIX_PTHREAD_SEMANTICS 1
| #define _TANDEM_SOURCE 1
| #define HAVE_DEV_URANDOM 1
| /* Define setproctitle to an innocuous variant, in case <limits.h> declares setproctitle.
| For example, HP-UX 11i <limits.h> declares gettimeofday. */
| #define setproctitle innocuous_setproctitle
| /* System header to define __stub macros and hopefully few prototypes,
| which can conflict with char setproctitle (); below.
| Prefer <limits.h> to <assert.h> if __STDC__ is defined, since
| <limits.h> exists even on freestanding compilers. */
| #ifdef __STDC__
| # include <limits.h>
| #else
| # include <assert.h>
| #endif
| #undef setproctitle
| /* Override any GCC internal prototype to avoid an error.
| Use char because int might match the return type of a GCC
| builtin and then its argument prototype would still apply. */
| #ifdef __cplusplus
| extern "C"
| #endif
| /* The GNU C library defines this for functions which it implements
| to always fail with ENOSYS. Some functions are actually named
| something starting with __ and the normal name is an alias. */
| #if defined __stub_setproctitle || defined __stub___setproctitle
| choke me
| #endif
| int
| main ()
| return setproctitle ();
| return 0;
configure:10811: result: no
configure:10823: checking for sys/pstat.h
configure:10823: result: no
configure:10834: checking for PS_STRINGS
configure:10853: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -o conftest -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -fvisibility=hidden -D_XPG_IV conftest.c >&5
conftest.c:25:29: fatal error: machine/vmparam.h: No such file or directory
#include <machine/vmparam.h>
configure:10853: $? = 1
| /* confdefs.h */
| #include <sys/exec.h>
| int
| main ()
| PS_STRINGS->ps_nargvstr = 1;
| PS_STRINGS->ps_argvstr = "foo";
| return 0;
configure:10861: result: no
configure:10869: checking for CLI build
configure:11031: result: no
configure:11038: checking for Continuity support
configure:11053: result: no
configure:11298: checking for embedded SAPI library support
configure:11497: result: no
configure:11553: checking for FPM build
configure:13170: result: no
configure:13178: checking for Zeus ISAPI support
configure:13193: result: no
configure:13410: checking for LiteSpeed support
configure:13580: result: no
configure:13587: checking for Milter support
configure:13602: result: no
configure:13793: checking for NSAPI support
configure:13808: result: no
configure:14079: checking for PHTTPD support
configure:14094: result: no
configure:14311: checking for Pi3Web support
configure:14326: result: no
configure:14661: checking whether Roxen module is build using ZTS
configure:14675: result: no
configure:14682: checking for Roxen/Pike support
configure:14918: result:
configure:14945: checking for thttpd
configure:15168: result: no
configure:15194: checking for TUX
configure:15374: result: no
configure:15401: checking for webjames
configure:15613: result: no
configure:15639: checking for CGI build
configure:15642: result: yes
configure:15644: checking for socklen_t in sys/socket.h
configure:15653: result: yes
configure:15665: checking for sun_len in sys/un.h
configure:15680: result: no
configure:15686: checking whether cross-process locking is required by accept()
configure:15697: result: no
configure:15847: checking for chosen SAPI module
configure:15849: result: none
configure:15852: checking for executable SAPI binaries
configure:15855: result: cgi
configure:15908: result:
configure:15910: result: [1mRunning system checks[m
configure:15918: checking for sendmail
configure:15952: result: no
configure:15963: checking whether system uses EBCDIC
configure:15996: result: no
configure:16005: checking whether byte ordering is bigendian
configure:16042: result: yes
configure:16052: checking whether writing to stdout works
configure:16096: result: yes
configure:16151: checking for socket
configure:16151: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -o conftest -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -fvisibility=hidden -D_XPG_IV conftest.c >&5
configure:16151: $? = 0
configure:16151: result: yes
configure:16319: checking for socketpair
configure:16319: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -o conftest -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -fvisibility=hidden -D_XPG_IV conftest.c >&5
configure:16319: $? = 0
configure:16319: result: yes
configure:16487: checking for htonl
configure:16487: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -o conftest -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -fvisibility=hidden -D_XPG_IV conftest.c >&5
configure:16487: $? = 0
configure:16487: result: yes
configure:16655: checking for gethostname
configure:16655: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -o conftest -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -fvisibility=hidden -D_XPG_IV conftest.c >&5
configure:16655: $? = 0
configure:16655: result: yes
configure:16823: checking for gethostbyaddr
configure:16823: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -o conftest -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -fvisibility=hidden -D_XPG_IV conftest.c >&5
configure:16823: $? = 0
configure:16823: result: yes
configure:16991: checking for yp_get_default_domain
configure:16991: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -o conftest -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -fvisibility=hidden -D_XPG_IV conftest.c >&5
/tmp/cc6fDdZj.o: In function `main':
conftest.c:(.text.startup+0x8): undefined reference to `yp_get_default_domain'
configure:16991: $? = 1
| /* confdefs.h */
| #define HAVE_SOCKLEN_T 1
| #define WORDS_BIGENDIAN /**/
| #define PHP_WRITE_STDOUT 1
| #define HAVE_SOCKET 1
| #define HAVE_SOCKETPAIR 1
| #define HAVE_HTONL 1
| #define HAVE_GETHOSTNAME 1
| #define HAVE_GETHOSTBYADDR 1
| /* Define yp_get_default_domain to an innocuous variant, in case <limits.h> declares yp_get_default_domain.
| #define yp_get_default_domain innocuous_yp_get_default_domain
| which can conflict with char yp_get_default_domain (); below.
| #ifdef __STDC__
| #else
| #endif
| #undef yp_get_default_domain
| #ifdef __cplusplus
| extern "C"
| #endif
| #if defined __stub_yp_get_default_domain || defined __stub___yp_get_default_domain
| choke me
| #endif
| int
| main ()
| return yp_get_default_domain ();
| return 0;
configure:16991: result: no
configure:16995: checking for __yp_get_default_domain
configure:16995: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -o conftest -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -fvisibility=hidden -D_XPG_IV conftest.c >&5
/tmp/cc4nsTLp.o: In function `main':
conftest.c:(.text.startup+0x8): undefined reference to `__yp_get_default_domain'
configure:16995: $? = 1
| /* confdefs.h */
| /* Define __yp_get_default_domain to an innocuous variant, in case <limits.h> declares __yp_get_default_domain.
| #define __yp_get_default_domain innocuous___yp_get_default_domain
| which can conflict with char __yp_get_default_domain (); below.
| #ifdef __STDC__
| #else
| #endif
| #undef __yp_get_default_domain
| #ifdef __cplusplus
| extern "C"
| #endif
| #if defined __stub___yp_get_default_domain || defined __stub_____yp_get_default_domain
| choke me
| #endif
| int
| main ()
| return __yp_get_default_domain ();
| return 0;
configure:16995: result: no
configure:17018: checking for yp_get_default_domain in -lnsl
configure:17043: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -o conftest -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -fvisibility=hidden -D_XPG_IV conftest.c -lnsl >&5
/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/../lib/gcc/mips-linux-uclibc/4.8.3/../../../../mips-linux-uclibc/bin/ld: cannot find -lnsl
configure:17043: $? = 1
| /* confdefs.h */
| #ifdef __cplusplus
| extern "C"
| #endif
| int
| main ()
| return 0;
configure:17052: result: no
configure:17058: checking for __yp_get_default_domain in -lnsl
configure:17083: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -o conftest -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -fvisibility=hidden -D_XPG_IV conftest.c -lnsl >&5
configure:17083: $? = 1
| /* confdefs.h */
| #ifdef __cplusplus
| extern "C"
| #endif
| int
| main ()
| return 0;
configure:17092: result: no
configure:17160: checking for dlopen
configure:17160: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -o conftest -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -fvisibility=hidden -D_XPG_IV conftest.c >&5
/tmp/cciYsl4y.o: In function `main':
conftest.c:(.text.startup+0x8): undefined reference to `dlopen'
configure:17160: $? = 1
| /* confdefs.h */
| /* Define dlopen to an innocuous variant, in case <limits.h> declares dlopen.
| #define dlopen innocuous_dlopen
| which can conflict with char dlopen (); below.
| #ifdef __STDC__
| #else
| #endif
| #undef dlopen
| #ifdef __cplusplus
| extern "C"
| #endif
| char dlopen ();
| #if defined __stub_dlopen || defined __stub___dlopen
| choke me
| #endif
| int
| main ()
| return dlopen ();
| return 0;
configure:17160: result: no
configure:17164: checking for __dlopen
configure:17164: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -o conftest -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -fvisibility=hidden -D_XPG_IV conftest.c >&5
/tmp/ccY8dykA.o: In function `main':
conftest.c:(.text.startup+0x8): undefined reference to `__dlopen'
configure:17164: $? = 1
| /* confdefs.h */
| /* Define __dlopen to an innocuous variant, in case <limits.h> declares __dlopen.
| #define __dlopen innocuous___dlopen
| which can conflict with char __dlopen (); below.
| #ifdef __STDC__
| #else
| #endif
| #undef __dlopen
| #ifdef __cplusplus
| extern "C"
| #endif
| char __dlopen ();
| #if defined __stub___dlopen || defined __stub_____dlopen
| choke me
| #endif
| int
| main ()
| return __dlopen ();
| return 0;
configure:17164: result: no
configure:17187: checking for dlopen in -ldl
configure:17212: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -o conftest -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -fvisibility=hidden -D_XPG_IV conftest.c -ldl >&5
configure:17212: $? = 0
configure:17221: result: yes
configure:17328: checking for sin in -lm
configure:17362: result: yes
configure:17379: checking for inet_aton
configure:17379: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -o conftest -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -fvisibility=hidden -D_XPG_IV conftest.c -lm >&5
configure:17379: $? = 0
configure:17379: result: yes
configure:17679: checking for ANSI C header files
configure:17783: result: yes
configure:17794: checking for dirent.h that defines DIR
configure:17821: result: yes
configure:17834: checking for library containing opendir
configure:17882: result: none required
configure:18008: checking for inttypes.h
configure:18008: result: yes
configure:18008: checking for stdint.h
configure:18008: checking for dirent.h
configure:18008: checking for ApplicationServices/ApplicationServices.h
configure:18008: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -c -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -fvisibility=hidden -D_XPG_IV conftest.c >&5
conftest.c:58:53: fatal error: ApplicationServices/ApplicationServices.h: No such file or directory
#include <ApplicationServices/ApplicationServices.h>
configure:18008: $? = 1
| /* confdefs.h */
| #define HAVE_LIBM 1
| #define HAVE_INET_ATON 1
| #define HAVE_DIRENT_H 1
| #ifdef HAVE_SYS_PARAM_H
| #include <sys/param.h>
| #endif
| #ifdef HAVE_SYS_TYPES_H
| #include <sys/types.h>
| #endif
| #ifdef HAVE_SYS_TIME_H
| #include <sys/time.h>
| #endif
| #ifdef HAVE_NETINET_IN_H
| #include <netinet/in.h>
| #endif
| #ifdef HAVE_ARPA_NAMESER_H
| #include <arpa/nameser.h>
| #endif
configure:18008: result: no
configure:18008: checking for sys/param.h
configure:18008: checking for sys/types.h
configure:18008: checking for sys/time.h
configure:18008: checking for netinet/in.h
configure:18008: checking for alloca.h
configure:18008: checking for arpa/inet.h
configure:18008: checking for arpa/nameser.h
configure:18008: checking for assert.h
configure:18008: checking for crypt.h
configure:18008: checking for dns.h
conftest.c:67:17: fatal error: dns.h: No such file or directory
#include <dns.h>
| /* confdefs.h */
| #define HAVE_LIBM 1
| #define HAVE_SYS_PARAM_H 1
| #define HAVE_SYS_TIME_H 1
| #define HAVE_NETINET_IN_H 1
| #define HAVE_ALLOCA_H 1
| #define HAVE_ARPA_INET_H 1
| #define HAVE_ARPA_NAMESER_H 1
| #define HAVE_ASSERT_H 1
| #define HAVE_CRYPT_H 1
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <dns.h>
configure:18008: checking for fcntl.h
configure:18008: checking for grp.h
configure:18008: $? = 0
configure:18008: checking for ieeefp.h
configure:18008: checking for langinfo.h
configure:18008: checking for limits.h
configure:18008: checking for locale.h
configure:18008: checking for monetary.h
conftest.c:72:22: fatal error: monetary.h: No such file or directory
#include <monetary.h>
| /* confdefs.h */
| #define HAVE_LIBM 1
| #define HAVE_FCNTL_H 1
| #define HAVE_GRP_H 1
| #define HAVE_LANGINFO_H 1
| #define HAVE_LIMITS_H 1
| #define HAVE_LOCALE_H 1
| #endif
| #endif
| #endif
| #endif
| #endif
configure:18008: checking for netdb.h
configure:18008: checking for pwd.h
configure:18008: checking for resolv.h
configure:18008: checking for signal.h
configure:18008: checking for stdarg.h
configure:18008: checking for stdlib.h
configure:18008: checking for string.h
configure:18008: checking for syslog.h
configure:18008: checking for sysexits.h
configure:18008: checking for sys/ioctl.h
configure:18008: checking for sys/file.h
configure:18008: checking for sys/mman.h
configure:18008: checking for sys/mount.h
configure:18008: checking for sys/poll.h
configure:18008: checking for sys/resource.h
configure:18008: checking for sys/select.h
configure:18008: checking for sys/socket.h
configure:18008: checking for sys/stat.h
configure:18008: checking for sys/statfs.h
configure:18008: checking for sys/statvfs.h
configure:18008: checking for sys/vfs.h
configure:18008: checking for sys/sysexits.h
conftest.c:93:26: fatal error: sys/sysexits.h: No such file or directory
#include <sys/sysexits.h>
| /* confdefs.h */
| #define HAVE_LIBM 1
| #define HAVE_NETDB_H 1
| #define HAVE_PWD_H 1
| #define HAVE_RESOLV_H 1
| #define HAVE_SIGNAL_H 1
| #define HAVE_STDARG_H 1
| #define HAVE_SYSLOG_H 1
| #define HAVE_SYSEXITS_H 1
| #define HAVE_SYS_IOCTL_H 1
| #define HAVE_SYS_FILE_H 1
| #define HAVE_SYS_MMAN_H 1
| #define HAVE_SYS_MOUNT_H 1
| #define HAVE_SYS_POLL_H 1
| #define HAVE_SYS_RESOURCE_H 1
| #define HAVE_SYS_SELECT_H 1
| #define HAVE_SYS_SOCKET_H 1
| #define HAVE_SYS_STATFS_H 1
| #define HAVE_SYS_STATVFS_H 1
| #define HAVE_SYS_VFS_H 1
| #endif
| #endif
| #endif
| #endif
| #endif
configure:18008: checking for sys/varargs.h
conftest.c:93:25: fatal error: sys/varargs.h: No such file or directory
#include <sys/varargs.h>
| /* confdefs.h */
| #define HAVE_LIBM 1
| #endif
| #endif
| #endif
| #endif
| #endif
configure:18008: checking for sys/wait.h
configure:18008: checking for sys/loadavg.h
conftest.c:94:25: fatal error: sys/loadavg.h: No such file or directory
#include <sys/loadavg.h>
| /* confdefs.h */
| #define HAVE_LIBM 1
| #define HAVE_SYS_WAIT_H 1
| #endif
| #endif
| #endif
| #endif
| #endif
configure:18008: checking for termios.h
configure:18008: checking for unistd.h
configure:18008: checking for unix.h
conftest.c:96:18: fatal error: unix.h: No such file or directory
#include <unix.h>
| /* confdefs.h */
| #define HAVE_LIBM 1
| #define HAVE_TERMIOS_H 1
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <unix.h>
configure:18008: checking for utime.h
configure:18008: checking for sys/utsname.h
configure:18008: checking for sys/ipc.h
configure:18008: checking for dlfcn.h
configure:18037: checking for fopencookie
configure:18037: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -o conftest -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -fvisibility=hidden -D_XPG_IV conftest.c -lm >&5
configure:18037: $? = 0
configure:18037: result: yes
configure:18058: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -c -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -fvisibility=hidden -D_XPG_IV conftest.c >&5
conftest.c:84:0: warning: "_GNU_SOURCE" redefined [enabled by default]
#define _GNU_SOURCE
conftest.c:20:0: note: this is the location of the previous definition
configure:18058: $? = 0
configure:18162: checking for broken getcwd
configure:18173: result: no
configure:18178: checking for broken libc stdio
configure:18202: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -c -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -fvisibility=hidden -D_XPG_IV conftest.c >&5
configure:18202: $? = 0
configure:18251: result: yes
configure:18263: checking whether struct tm is in sys/time.h or time.h
configure:18290: result: time.h
configure:18298: checking for struct tm.tm_zone
configure:18298: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -c -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -fvisibility=hidden -D_XPG_IV conftest.c >&5
configure:18298: $? = 0
configure:18298: result: yes
configure:18367: checking for missing declarations of reentrant functions
configure:18380: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -c -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -fvisibility=hidden -D_XPG_IV conftest.c >&5
configure:18380: $? = 0
configure:18403: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -c -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -fvisibility=hidden -D_XPG_IV conftest.c >&5
configure:18403: $? = 0
configure:18426: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -c -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -fvisibility=hidden -D_XPG_IV conftest.c >&5
configure:18426: $? = 0
configure:18449: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -c -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -fvisibility=hidden -D_XPG_IV conftest.c >&5
configure:18449: $? = 0
configure:18472: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -c -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -fvisibility=hidden -D_XPG_IV conftest.c >&5
configure:18472: $? = 0
configure:18484: result: done
configure:18488: checking for fclose declaration
configure:18501: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -c -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -fvisibility=hidden -D_XPG_IV conftest.c >&5
configure:18501: $? = 0
configure:18506: result: ok
configure:18522: checking for tm_gmtoff in struct tm
configure:18539: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -c -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -fvisibility=hidden -D_XPG_IV conftest.c >&5
configure:18539: $? = 0
configure:18546: result: yes
configure:18556: checking for struct flock
configure:18575: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -c -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -fvisibility=hidden -D_XPG_IV conftest.c >&5
configure:18575: $? = 0
configure:18587: result: yes
configure:18596: checking for socklen_t
configure:18617: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -c -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -fvisibility=hidden -D_XPG_IV conftest.c >&5
configure:18617: $? = 0
configure:18628: result: yes
configure:18641: checking size of size_t
configure:18660: result: 4
configure:18674: checking size of long long
configure:18693: result: 8
configure:18707: checking size of long long int
configure:18712: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -c -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -fvisibility=hidden -D_XPG_IV conftest.c >&5
configure:18712: $? = 0
conftest.c: In function 'main':
conftest.c:130:12: error: size of array 'test_array' is negative
static int test_array [1 - 2 * !(((long int) (sizeof (long long int))) <= 0)];
configure:18712: $? = 1
| /* confdefs.h */
| #define HAVE_LIBM 1
| #define HAVE_UTIME_H 1
| #define HAVE_SYS_UTSNAME_H 1
| #define HAVE_SYS_IPC_H 1
| #define HAVE_DLFCN_H 1
| #define HAVE_FOPENCOOKIE 1
| #define COOKIE_IO_FUNCTIONS_T cookie_io_functions_t
| #define HAVE_BROKEN_GLIBC_FOPEN_APPEND 1
| #define HAVE_STRUCT_TM_TM_ZONE 1
| #define HAVE_TM_ZONE 1
| #define MISSING_FCLOSE_DECL 0
| #define HAVE_TM_GMTOFF 1
| #define HAVE_STRUCT_FLOCK 1
| #define SIZEOF_SIZE_T 4
| #define SIZEOF_LONG_LONG 8
| #include <stdio.h>
| # include <sys/types.h>
| #endif
| #ifdef HAVE_SYS_STAT_H
| # include <sys/stat.h>
| #endif
| #ifdef STDC_HEADERS
| # include <stdlib.h>
| # include <stddef.h>
| #else
| # ifdef HAVE_STDLIB_H
| # endif
| #endif
| #ifdef HAVE_STRING_H
| # if !defined STDC_HEADERS && defined HAVE_MEMORY_H
| # include <memory.h>
| # endif
| # include <string.h>
| #endif
| #ifdef HAVE_STRINGS_H
| # include <strings.h>
| #endif
| #ifdef HAVE_INTTYPES_H
| # include <inttypes.h>
| #endif
| #ifdef HAVE_STDINT_H
| # include <stdint.h>
| #endif
| #ifdef HAVE_UNISTD_H
| # include <unistd.h>
| #endif
| int
| main ()
| test_array [0] = 0;
| return test_array [0];
| return 0;
static int test_array [1 - 2 * !(((long int) (sizeof (long long int))) <= 1)];
| /* confdefs.h */
| #define HAVE_LIBM 1
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| int
| main ()
| test_array [0] = 0;
| return 0;
static int test_array [1 - 2 * !(((long int) (sizeof (long long int))) <= 3)];
| /* confdefs.h */
| #define HAVE_LIBM 1
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| int
| main ()
| test_array [0] = 0;
| return 0;
static int test_array [1 - 2 * !(((long int) (sizeof (long long int))) <= 7)];
| /* confdefs.h */
| #define HAVE_LIBM 1
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| int
| main ()
| test_array [0] = 0;
| return 0;
configure:18726: result: 8
configure:18740: checking size of long
configure:18759: result: 4
configure:18773: checking size of int
configure:18792: result: 4
configure:18804: checking size of intmax_t
configure:18879: result: 8
configure:18883: checking size of ssize_t
configure:18958: result: 4
configure:18962: checking size of ptrdiff_t
configure:19037: result: 4
configure:19041: checking for struct stat.st_blksize
configure:19041: result: yes
configure:19055: checking for struct stat.st_blocks
configure:19055: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -c -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -fvisibility=hidden -D_XPG_IV conftest.c >&5
configure:19055: $? = 0
configure:19055: result: yes
configure:19080: checking for struct stat.st_rdev
configure:19080: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -c -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -fvisibility=hidden -D_XPG_IV conftest.c >&5
configure:19080: $? = 0
configure:19080: result: yes
configure:19094: checking for size_t
configure:19094: result: yes
configure:19105: checking for uid_t in sys/types.h
configure:19124: result: yes
configure:19137: checking for struct sockaddr_storage
configure:19154: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -c -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -fvisibility=hidden -D_XPG_IV conftest.c >&5
configure:19154: $? = 0
configure:19162: result: yes
configure:19169: checking for field sa_len in struct sockaddr
configure:19187: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -c -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -fvisibility=hidden -D_XPG_IV conftest.c >&5
conftest.c:115:44: error: 'struct sockaddr' has no member named 'sa_len'
static struct sockaddr sa; int n = (int) sa.sa_len; return n;
configure:19187: $? = 1
| /* confdefs.h */
| #define HAVE_LIBM 1
| #define SIZEOF_LONG_LONG_INT 8
| #define SIZEOF_LONG 4
| #define SIZEOF_INT 4
| #define SIZEOF_INTMAX_T 8
| #define HAVE_INTMAX_T 1
| #define SIZEOF_SSIZE_T 4
| #define HAVE_SSIZE_T 1
| #define SIZEOF_PTRDIFF_T 4
| #define HAVE_PTRDIFF_T 1
| #define HAVE_STRUCT_STAT_ST_BLKSIZE 1
| #define HAVE_ST_BLKSIZE 1
| #define HAVE_STRUCT_STAT_ST_BLOCKS 1
| #define HAVE_ST_BLOCKS 1
| #define HAVE_STRUCT_STAT_ST_RDEV 1
| #define HAVE_ST_RDEV 1
| #define HAVE_SOCKADDR_STORAGE 1
| #include <sys/socket.h>
| int
| main ()
| return 0;
configure:19195: result: no
configure:19204: checking for IPv6 support
configure:19230: result: yes
configure:19236: checking for vprintf
configure:19236: result: yes
configure:19242: checking for _doprnt
configure:19242: result: no
configure:19338: checking for alphasort
configure:19338: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -o conftest -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -fvisibility=hidden -D_XPG_IV conftest.c -lm >&5
configure:19338: $? = 0
configure:19338: result: yes
configure:19338: checking for asctime_r
configure:19338: checking for chroot
configure:19338: checking for ctime_r
configure:19338: checking for cuserid
configure:19338: checking for crypt
/tmp/ccElSaTu.o: In function `main':
conftest.c:(.text.startup+0x8): undefined reference to `crypt'
configure:19338: $? = 1
| /* confdefs.h */
| #define HAVE_LIBM 1
| #define HAVE_VPRINTF 1
| #define HAVE_ALPHASORT 1
| #define HAVE_ASCTIME_R 1
| #define HAVE_CHROOT 1
| #define HAVE_CTIME_R 1
| #define HAVE_CUSERID 1
| /* Define crypt to an innocuous variant, in case <limits.h> declares crypt.
| #define crypt innocuous_crypt
| which can conflict with char crypt (); below.
| #ifdef __STDC__
| #else
| #endif
| #undef crypt
| #ifdef __cplusplus
| extern "C"
| #endif
| char crypt ();
| #if defined __stub_crypt || defined __stub___crypt
| choke me
| #endif
| int
| main ()
| return crypt ();
| return 0;
configure:19338: result: no
configure:19338: checking for flock
configure:19338: checking for ftok
configure:19338: checking for funopen
/tmp/ccYfKD4F.o: In function `main':
conftest.c:(.text.startup+0x8): undefined reference to `funopen'
| /* confdefs.h */
| #define HAVE_LIBM 1
| #define HAVE_FLOCK 1
| #define HAVE_FTOK 1
| /* Define funopen to an innocuous variant, in case <limits.h> declares funopen.
| #define funopen innocuous_funopen
| which can conflict with char funopen (); below.
| #ifdef __STDC__
| #else
| #endif
| #undef funopen
| #ifdef __cplusplus
| extern "C"
| #endif
| char funopen ();
| #if defined __stub_funopen || defined __stub___funopen
| choke me
| #endif
| int
| main ()
| return funopen ();
| return 0;
configure:19338: checking for gai_strerror
configure:19338: checking for gcvt
configure:19338: checking for getloadavg
/tmp/ccAYBKqP.o: In function `main':
conftest.c:(.text.startup+0x8): undefined reference to `getloadavg'
| /* confdefs.h */
| #define HAVE_LIBM 1
| #define HAVE_FTOK 1
| #define HAVE_GAI_STRERROR 1
| #define HAVE_GCVT 1
| /* Define getloadavg to an innocuous variant, in case <limits.h> declares getloadavg.
| #define getloadavg innocuous_getloadavg
| which can conflict with char getloadavg (); below.
| #ifdef __STDC__
| #else
| #endif
| #undef getloadavg
| #ifdef __cplusplus
| extern "C"
| #endif
| char getloadavg ();
| #if defined __stub_getloadavg || defined __stub___getloadavg
| choke me
| #endif
| int
| main ()
| return getloadavg ();
| return 0;
configure:19338: checking for getlogin
configure:19338: checking for getprotobyname
configure:19338: checking for getprotobynumber
configure:19338: checking for getservbyname
configure:19338: checking for getservbyport
configure:19338: checking for gethostname
configure:19338: checking for getrusage
configure:19338: checking for gettimeofday
configure:19338: checking for gmtime_r
configure:19338: checking for getpwnam_r
configure:19338: checking for getgrnam_r
configure:19338: checking for getpwuid_r
configure:19338: checking for grantpt
configure:19338: checking for inet_ntoa
configure:19338: checking for inet_ntop
configure:19338: checking for inet_pton
configure:19338: checking for isascii
configure:19338: checking for link
configure:19338: checking for localtime_r
configure:19338: checking for lockf
configure:19338: checking for lchown
configure:19338: checking for lrand48
configure:19338: checking for memcpy
configure:19338: checking for memmove
configure:19338: checking for mkstemp
configure:19338: checking for mmap
configure:19338: checking for nl_langinfo
configure:19338: checking for perror
configure:19338: checking for poll
configure:19338: checking for ptsname
configure:19338: checking for putenv
configure:19338: checking for realpath
configure:19338: checking for random
configure:19338: checking for rand_r
configure:19338: checking for scandir
configure:19338: checking for setitimer
configure:19338: checking for setlocale
configure:19338: checking for localeconv
configure:19338: checking for setenv
configure:19338: checking for setpgid
configure:19338: checking for setsockopt
configure:19338: checking for setvbuf
configure:19338: checking for shutdown
configure:19338: checking for sin
configure:19338: checking for snprintf
configure:19338: checking for srand48
configure:19338: checking for srandom
configure:19338: checking for statfs
configure:19338: checking for statvfs
configure:19338: checking for std_syslog
/tmp/ccxU1ro8.o: In function `main':
conftest.c:(.text.startup+0x8): undefined reference to `std_syslog'
| /* confdefs.h */
| #define HAVE_LIBM 1
| #define HAVE_FTOK 1
| #define HAVE_GCVT 1
| #define HAVE_GETLOGIN 1
| #define HAVE_GETPROTOBYNAME 1
| #define HAVE_GETPROTOBYNUMBER 1
| #define HAVE_GETSERVBYNAME 1
| #define HAVE_GETSERVBYPORT 1
| #define HAVE_GETRUSAGE 1
| #define HAVE_GETTIMEOFDAY 1
| #define HAVE_GMTIME_R 1
| #define HAVE_GETPWNAM_R 1
| #define HAVE_GETGRNAM_R 1
| #define HAVE_GETPWUID_R 1
| #define HAVE_GRANTPT 1
| #define HAVE_INET_NTOA 1
| #define HAVE_INET_NTOP 1
| #define HAVE_INET_PTON 1
| #define HAVE_ISASCII 1
| #define HAVE_LINK 1
| #define HAVE_LOCALTIME_R 1
| #define HAVE_LOCKF 1
| #define HAVE_LCHOWN 1
| #define HAVE_LRAND48 1
| #define HAVE_MEMCPY 1
| #define HAVE_MEMMOVE 1
| #define HAVE_MKSTEMP 1
| #define HAVE_MMAP 1
| #define HAVE_NL_LANGINFO 1
| #define HAVE_PERROR 1
| #define HAVE_POLL 1
| #define HAVE_PTSNAME 1
| #define HAVE_PUTENV 1
| #define HAVE_REALPATH 1
| #define HAVE_RANDOM 1
| #define HAVE_RAND_R 1
| #define HAVE_SCANDIR 1
| #define HAVE_SETITIMER 1
| #define HAVE_SETLOCALE 1
| #define HAVE_LOCALECONV 1
| #define HAVE_SETENV 1
| #define HAVE_SETPGID 1
| #define HAVE_SETSOCKOPT 1
| #define HAVE_SETVBUF 1
| #define HAVE_SHUTDOWN 1
| #define HAVE_SNPRINTF 1
| #define HAVE_SRAND48 1
| #define HAVE_SRANDOM 1
| #define HAVE_STATFS 1
| #define HAVE_STATVFS 1
| /* Define std_syslog to an innocuous variant, in case <limits.h> declares std_syslog.
| #define std_syslog innocuous_std_syslog
| which can conflict with char std_syslog (); below.
| #ifdef __STDC__
| #else
| #endif
| #undef std_syslog
| #ifdef __cplusplus
| extern "C"
| #endif
| char std_syslog ();
| #if defined __stub_std_syslog || defined __stub___std_syslog
| choke me
| #endif
| int
| main ()
| return std_syslog ();
| return 0;
configure:19338: checking for strcasecmp
configure:19338: checking for strcoll
configure:19338: checking for strdup
configure:19338: checking for strerror
configure:19338: checking for strftime
configure:19338: checking for strnlen
configure:19338: checking for strptime
configure:19338: checking for strstr
configure:19338: checking for strtok_r
configure:19338: checking for symlink
configure:19338: checking for tempnam
configure:19338: checking for tzset
configure:19338: checking for unlockpt
configure:19338: checking for unsetenv
configure:19338: checking for usleep
configure:19338: checking for utime
configure:19338: checking for vsnprintf
configure:19338: checking for vasprintf
configure:19338: checking for asprintf
configure:19338: checking for nanosleep
configure:19353: checking for nanosleep in -lrt
configure:19378: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -o conftest -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -fvisibility=hidden -D_XPG_IV conftest.c -lrt -lm >&5
configure:19378: $? = 0
configure:19387: result: yes
configure:19487: checking for getaddrinfo
configure:19562: result: yes
configure:19570: checking for __sync_fetch_and_add
configure:19586: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -o conftest -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -fvisibility=hidden -D_XPG_IV conftest.c -lm >&5
configure:19586: $? = 0
configure:19594: result: yes
configure:19602: checking for strlcat
configure:19602: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -o conftest -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -fvisibility=hidden -D_XPG_IV conftest.c -lm >&5
configure:19602: $? = 0
configure:19602: result: yes
configure:19615: checking for strlcpy
configure:19615: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -o conftest -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -fvisibility=hidden -D_XPG_IV conftest.c -lm >&5
configure:19615: $? = 0
configure:19615: result: yes
configure:19628: checking for getopt
configure:19628: result: yes
configure:19648: checking for utime.h
configure:19648: result: yes
configure:19662: checking whether utime accepts a null argument
configure:19701: result: no
configure:19713: checking for working alloca.h
configure:19738: result: yes
configure:19746: checking for alloca
configure:19791: result: yes
configure:19898: checking for declared timezone
configure:19923: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -c -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -fvisibility=hidden -D_XPG_IV conftest.c >&5
configure:19923: $? = 0
configure:19934: result: yes
configure:19943: checking for type of reentrant time-related functions
configure:20020: result: POSIX
configure:20032: checking for readdir_r
configure:20032: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -o conftest -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -fvisibility=hidden -D_XPG_IV conftest.c -lm >&5
configure:20032: $? = 0
configure:20032: result: yes
configure:20040: checking for type of readdir_r
configure:20109: result: POSIX
configure:20124: checking for in_addr_t
configure:20149: result: yes
configure:20160: checking for crypt_r
configure:20160: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -o conftest -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -fvisibility=hidden -D_XPG_IV conftest.c -lm >&5
/tmp/ccfPPNXM.o: In function `main':
conftest.c:(.text.startup+0x8): undefined reference to `crypt_r'
configure:20160: $? = 1
| /* confdefs.h */
| #define HAVE_LIBM 1
| #define HAVE_FTOK 1
| #define HAVE_GCVT 1
| #define HAVE_LINK 1
| #define HAVE_MMAP 1
| #define HAVE_POLL 1
| #define HAVE_STRCASECMP 1
| #define HAVE_STRCOLL 1
| #define HAVE_STRDUP 1
| #define HAVE_STRERROR 1
| #define HAVE_STRFTIME 1
| #define HAVE_STRNLEN 1
| #define HAVE_STRPTIME 1
| #define HAVE_STRSTR 1
| #define HAVE_STRTOK_R 1
| #define HAVE_SYMLINK 1
| #define HAVE_TEMPNAM 1
| #define HAVE_TZSET 1
| #define HAVE_UNLOCKPT 1
| #define HAVE_UNSETENV 1
| #define HAVE_USLEEP 1
| #define HAVE_UTIME 1
| #define HAVE_VSNPRINTF 1
| #define HAVE_VASPRINTF 1
| #define HAVE_ASPRINTF 1
| #define HAVE_NANOSLEEP 1
| #define HAVE_GETADDRINFO 1
| #define HAVE_SYNC_FETCH_AND_ADD 1
| #define HAVE_STRLCAT 1
| #define HAVE_STRLCPY 1
| #define HAVE_GETOPT 1
| #define HAVE_ALLOCA 1
| #define HAVE_DECLARED_TIMEZONE 1
| #define HAVE_POSIX_READDIR_R 1
| /* Define crypt_r to an innocuous variant, in case <limits.h> declares crypt_r.
| #define crypt_r innocuous_crypt_r
| which can conflict with char crypt_r (); below.
| #ifdef __STDC__
| #else
| #endif
| #undef crypt_r
| #ifdef __cplusplus
| extern "C"
| #endif
| char crypt_r ();
| #if defined __stub_crypt_r || defined __stub___crypt_r
| choke me
| #endif
| int
| main ()
| return crypt_r ();
| return 0;
configure:20160: result: no
configure:20277: result:
configure:20279: result: [1mGeneral settings[m
configure:20294: checking whether to include gcov symbols
configure:20308: result: no
configure:20469: checking whether to include debugging symbols
configure:20483: result: no
configure:20517: checking layout of installed files
configure:20532: result: PHP
configure:20550: checking path to configuration file
configure:20565: result: /tmp/flash
configure:20582: checking where to scan for configuration files
configure:20608: result: /tmp/flash/php
configure:20616: checking whether to enable PHP's own SIGCHLD handler
configure:20630: result: no
configure:20649: checking whether to explicitly link against libgcc
configure:20663: result: no
configure:20726: checking whether to enable short tags by default
configure:20740: result: yes
configure:20759: checking whether to enable dmalloc
configure:20773: result: no
configure:20844: checking whether to enable IPv6 support
configure:20858: result: yes
configure:20873: checking whether to enable DTrace support
configure:20887: result: no
configure:21018: checking how big to make fd sets
configure:21050: result: using system default
configure:21064: result:
configure:21066: result: [1mConfiguring extensions[m
configure:21088: checking size of long
configure:21107: result: 4
configure:21121: checking size of int
configure:21140: result: 4
configure:21151: checking for int32_t
configure:21180: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -c -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -fvisibility=hidden -D_XPG_IV conftest.c >&5
configure:21180: $? = 0
configure:21188: result: yes
configure:21197: checking for uint32_t
configure:21226: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -c -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -fvisibility=hidden -D_XPG_IV conftest.c >&5
configure:21226: $? = 0
configure:21234: result: yes
configure:21252: checking for sys/types.h
configure:21252: result: yes
configure:21252: checking for inttypes.h
configure:21252: checking for stdint.h
configure:21252: checking for string.h
configure:21252: checking for stdlib.h
configure:21266: checking for strtoll
configure:21266: result: yes
configure:21266: checking for atoll
configure:21266: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -o conftest -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -fvisibility=hidden -D_XPG_IV conftest.c -lm >&5
configure:21266: $? = 0
configure:21266: checking for strftime
configure:21714: checking which regex library to use
configure:21716: result: php
configure:22127: checking whether to enable LIBXML support
configure:22162: result: yes
configure:22172: checking libxml2 install dir
configure:22187: result: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/usr
configure:22199: checking for xml2-config path
configure:22213: result: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/usr/bin/xml2-config
configure:22357: checking whether libxml build works
configure:22408: result:
configure:22745: checking for OpenSSL support
configure:22781: result: yes
configure:22790: checking for Kerberos support
configure:22805: result: no
configure:23484: checking for DSA_get_default_method in -lssl
configure:23509: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -o conftest -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -fvisibility=hidden -D_XPG_IV -L/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/usr/lib conftest.c -lssl -lm -lxml2 -lz -lm >&5
/tmp/ccypKIjf.o: In function `main':
conftest.c:(.text.startup+0x8): undefined reference to `DSA_get_default_method'
configure:23509: $? = 1
| /* confdefs.h */
| #define HAVE_LIBM 1
| #define HAVE_FTOK 1
| #define HAVE_GCVT 1
| #define HAVE_LINK 1
| #define HAVE_MMAP 1
| #define HAVE_POLL 1
| #define PHP_SIGCHILD 0
| #define DEFAULT_SHORT_OPEN_TAG "1"
| #define HAVE_IPV6 1
| #define HAVE_INT32_T 1
| #define HAVE_UINT32_T 1
| #define HAVE_STRTOLL 1
| #define HAVE_ATOLL 1
| #define HAVE_REGEX_T_RE_MAGIC 1
| #define HSREGEX 1
| #define REGEX 1
| #define HAVE_LIBXML 1
| #ifdef __cplusplus
| extern "C"
| #endif
| char DSA_get_default_method ();
| int
| main ()
| return DSA_get_default_method ();
| return 0;
configure:23518: result: no
configure:23526: checking for X509_free in -lcrypto
configure:23551: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -o conftest -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -fvisibility=hidden -D_XPG_IV -L/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/usr/lib conftest.c -lcrypto -lm -lxml2 -lz -lm >&5
configure:23551: $? = 0
configure:23560: result: yes
configure:23586: checking for pkg-config
configure:23617: result: /usr/bin/pkg-config
configure:23798: checking for OpenSSL version
configure:23812: result: >= 0.9.6
configure:23953: checking for CRYPTO_free in -lcrypto
configure:23978: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -o conftest -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -fvisibility=hidden -D_XPG_IV -L/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/usr/lib -L/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/usr/lib conftest.c -lcrypto -lm -lxml2 -lz -lm >&5
configure:23978: $? = 0
configure:23987: result: yes
configure:24130: checking for SSL_CTX_set_ssl_version in -lssl
configure:24155: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -o conftest -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -fvisibility=hidden -D_XPG_IV -L/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/usr/lib -L/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/usr/lib conftest.c -lssl -lcrypto -lm -lxml2 -lz -lm -lcrypto >&5
configure:24155: $? = 0
configure:24164: result: yes
configure:24314: checking for PCRE headers location
configure:24323: result: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/usr/include
configure:24326: checking for PCRE library location
configure:24335: result: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/usr/lib
configure:25088: checking whether to enable the SQLite3 extension
configure:25124: result: yes
configure:25144: checking for sqlite3 files in default path
configure:25149: result: found in /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/usr
configure:25161: checking for SQLite 3.3.9+
configure:25260: checking for sqlite3_prepare_v2 in -lsqlite3
configure:25294: result: yes
configure:25301: result: found
configure:25542: checking for sqlite3_key in -lsqlite3
configure:25567: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -o conftest -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -fvisibility=hidden -D_XPG_IV -L/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/usr/lib conftest.c -lsqlite3 -lsqlite3 -lpcre -lcrypto -lssl -lcrypto -lm -lxml2 -lz -lm >&5
/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/usr/lib/libsqlite3.so: file not recognized: File truncated
configure:25567: $? = 1
| /* confdefs.h */
| #define HAVE_LIBM 1
| #define HAVE_FTOK 1
| #define HAVE_GCVT 1
| #define HAVE_LINK 1
| #define HAVE_MMAP 1
| #define HAVE_POLL 1
| #define HAVE_IPV6 1
| #define HSREGEX 1
| #define REGEX 1
| #define HAVE_DSA_DEFAULT_METHOD 1
| #define HAVE_OPENSSL_EXT 1
| #define HAVE_PCRE 1
| #ifdef __cplusplus
| extern "C"
| #endif
| char sqlite3_key ();
| int
| main ()
| return sqlite3_key ();
| return 0;
configure:25576: result: no
configure:25692: checking for sqlite3_column_table_name in -lsqlite3
configure:25717: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -o conftest -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -fvisibility=hidden -D_XPG_IV -L/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/usr/lib conftest.c -lsqlite3 -lsqlite3 -lpcre -lcrypto -lssl -lcrypto -lm -lxml2 -lz -lm >&5
configure:25717: $? = 1
| /* confdefs.h */
| #define HAVE_LIBM 1
| #define HAVE_FTOK 1
| #define HAVE_GCVT 1
| #define HAVE_LINK 1
| #define HAVE_MMAP 1
| #define HAVE_POLL 1
| #define HAVE_IPV6 1
| #define HSREGEX 1
| #define REGEX 1
| #define HAVE_PCRE 1
| #ifdef __cplusplus
| extern "C"
| #endif
| char sqlite3_column_table_name ();
| int
| main ()
| return sqlite3_column_table_name ();
| return 0;
configure:25726: result: no
configure:25843: checking for sqlite3_load_extension in -lsqlite3
configure:25868: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -o conftest -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -fvisibility=hidden -D_XPG_IV -L/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/usr/lib conftest.c -lsqlite3 -lsqlite3 -lpcre -lcrypto -lssl -lcrypto -lm -lxml2 -lz -lm >&5
configure:25868: $? = 1
| /* confdefs.h */
| #define HAVE_LIBM 1
| #define HAVE_FTOK 1
| #define HAVE_GCVT 1
| #define HAVE_LINK 1
| #define HAVE_MMAP 1
| #define HAVE_POLL 1
| #define HAVE_IPV6 1
| #define HSREGEX 1
| #define REGEX 1
| #define HAVE_PCRE 1
| #ifdef __cplusplus
| extern "C"
| #endif
| char sqlite3_load_extension ();
| int
| main ()
| return sqlite3_load_extension ();
| return 0;
configure:25877: result: no
configure:26256: checking for ZLIB support
configure:26292: result: yes
configure:26301: checking if the location of ZLIB install directory is defined
configure:26316: result: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/usr
configure:26649: checking for zlib version >= 1.2.0.4
configure:26652: result: 1.2.8
configure:26755: checking for gzgets in -lz
configure:26780: /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -o conftest -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -fvisibility=hidden -D_XPG_IV -L/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/usr/lib -L/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/usr/lib conftest.c -lz -lsqlite3 -lpcre -lcrypto -lssl -lcrypto -lm -lxml2 -lz -lm >&5
configure:26780: $? = 1
| /* confdefs.h */
| #define HAVE_LIBM 1
| #define HAVE_FTOK 1
| #define HAVE_GCVT 1
| #define HAVE_LINK 1
| #define HAVE_MMAP 1
| #define HAVE_POLL 1
| #define HAVE_IPV6 1
| #define HSREGEX 1
| #define REGEX 1
| #define HAVE_PCRE 1
| #define SQLITE_OMIT_LOAD_EXTENSION 1
| #define HAVE_SQLITE3 1
| #ifdef __cplusplus
| extern "C"
| #endif
| char gzgets ();
| int
| main ()
| return gzgets ();
| return 0;
configure:26789: result: no
configure:26807: error: ZLIB extension requires gzgets in zlib
## Cache variables. ##
_cv_gnu_make_command=make
_cv_have_broken_glibc_fopen_append=yes
ac_cv_CAN_USE_SYSCTL=no
ac_cv_build=x86_64-pc-linux-gnu
ac_cv_c_bigendian=yes
ac_cv_c_bigendian_php=yes
ac_cv_c_char_unsigned=no
ac_cv_c_compiler_gnu=yes
ac_cv_c_const=yes
ac_cv_c_inline=inline
ac_cv_c_int64_t=yes
ac_cv_c_littleendian=no
ac_cv_c_restrict=__restrict
ac_cv_c_stack_direction=-1
ac_cv_c_stringize=yes
ac_cv_c_uint32_t=yes
ac_cv_c_volatile=yes
ac_cv_cflags_warn_all=-Wall
ac_cv_compiler_option_defnodbg=yes
ac_cv_cpp_func=yes
ac_cv_cxx_compiler_gnu=yes
ac_cv_cygwin=no
ac_cv_decl_map_anon=yes
ac_cv_declared_timezone=yes
ac_cv_e2fsprogs_use_static=yes
ac_cv_ebcdic=no
ac_cv_env_ABI_set=
ac_cv_env_ABI_value=
ac_cv_env_BZIP2_CFLAGS_set=
ac_cv_env_BZIP2_CFLAGS_value=
ac_cv_env_BZIP2_LIBS_set=
ac_cv_env_BZIP2_LIBS_value=
ac_cv_env_CCASFLAGS_set=
ac_cv_env_CCASFLAGS_value=
ac_cv_env_CCAS_set=
ac_cv_env_CCAS_value=
ac_cv_env_CCC_set=
ac_cv_env_CCC_value=
ac_cv_env_CC_FOR_BUILD_set=
ac_cv_env_CC_FOR_BUILD_value=
ac_cv_env_CC_set=set
ac_cv_env_CC_value=/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc
ac_cv_env_CFLAGS_set=set
ac_cv_env_CFLAGS_value='-march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64'
ac_cv_env_CPPFLAGS_set=
ac_cv_env_CPPFLAGS_value=
ac_cv_env_CPP_FOR_BUILD_set=
ac_cv_env_CPP_FOR_BUILD_value=
ac_cv_env_CPP_set=
ac_cv_env_CPP_value=
ac_cv_env_CXXCPP_set=
ac_cv_env_CXXCPP_value=
ac_cv_env_CXXFLAGS_set=set
ac_cv_env_CXXFLAGS_value='-march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64'
ac_cv_env_CXX_set=set
ac_cv_env_CXX_value=/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-g++-wrapper
ac_cv_env_F77_set=
ac_cv_env_F77_value=
ac_cv_env_FAM_CFLAGS_set=
ac_cv_env_FAM_CFLAGS_value=
ac_cv_env_FAM_LIBS_set=
ac_cv_env_FAM_LIBS_value=
ac_cv_env_FFLAGS_set=
ac_cv_env_FFLAGS_value=
ac_cv_env_GENHTML_set=
ac_cv_env_GENHTML_value=
ac_cv_env_HARFBUZZ_CFLAGS_set=
ac_cv_env_HARFBUZZ_CFLAGS_value=
ac_cv_env_HARFBUZZ_LIBS_set=
ac_cv_env_HARFBUZZ_LIBS_value=
ac_cv_env_LCOV_set=
ac_cv_env_LCOV_value=
ac_cv_env_LDFLAGS_set=set
ac_cv_env_LDFLAGS_value=
ac_cv_env_LIBEV_CFLAGS_set=
ac_cv_env_LIBEV_CFLAGS_value=
ac_cv_env_LIBEV_LIBS_set=
ac_cv_env_LIBEV_LIBS_value=
ac_cv_env_LIBFONTCONFIG_CFLAGS_set=
ac_cv_env_LIBFONTCONFIG_CFLAGS_value=
ac_cv_env_LIBFONTCONFIG_LIBS_set=
ac_cv_env_LIBFONTCONFIG_LIBS_value=
ac_cv_env_LIBFREETYPE_CFLAGS_set=
ac_cv_env_LIBFREETYPE_CFLAGS_value=
ac_cv_env_LIBFREETYPE_LIBS_set=
ac_cv_env_LIBFREETYPE_LIBS_value=
ac_cv_env_LIBPNG_CFLAGS_set=
ac_cv_env_LIBPNG_CFLAGS_value=
ac_cv_env_LIBPNG_LIBS_set=
ac_cv_env_LIBPNG_LIBS_value=
ac_cv_env_LIBS_set=
ac_cv_env_LIBS_value=
ac_cv_env_LIBTIFF_CFLAGS_set=
ac_cv_env_LIBTIFF_CFLAGS_value=
ac_cv_env_LIBTIFF_LIBS_set=
ac_cv_env_LIBTIFF_LIBS_value=
ac_cv_env_LIBVPX_CFLAGS_set=
ac_cv_env_LIBVPX_CFLAGS_value=
ac_cv_env_LIBVPX_LIBS_set=
ac_cv_env_LIBVPX_LIBS_value=
ac_cv_env_LIBXPM_CFLAGS_set=
ac_cv_env_LIBXPM_CFLAGS_value=
ac_cv_env_LIBXPM_LIBS_set=
ac_cv_env_LIBXPM_LIBS_value=
ac_cv_env_LUA_CFLAGS_set=
ac_cv_env_LUA_CFLAGS_value=
ac_cv_env_LUA_LIBS_set=
ac_cv_env_LUA_LIBS_value=
ac_cv_env_M4_set=
ac_cv_env_M4_value=
ac_cv_env_PERLCCFLAGS_set=
ac_cv_env_PERLCCFLAGS_value=
ac_cv_env_PERLCC_set=
ac_cv_env_PERLCC_value=
ac_cv_env_PERLLDFLAGS_set=
ac_cv_env_PERLLDFLAGS_value=
ac_cv_env_PERLLD_set=
ac_cv_env_PERLLD_value=
ac_cv_env_PKG_CONFIG_LIBDIR_set=set
ac_cv_env_PKG_CONFIG_LIBDIR_value=/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/../lib/pkgconfig
ac_cv_env_PKG_CONFIG_PATH_set=set
ac_cv_env_PKG_CONFIG_PATH_value=/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/../lib/pkgconfig
ac_cv_env_PKG_CONFIG_set=
ac_cv_env_PKG_CONFIG_value=
ac_cv_env_RRDDOCDIR_set=
ac_cv_env_RRDDOCDIR_value=
ac_cv_env_RRDGRAPH_YLEGEND_ANGLE_set=
ac_cv_env_RRDGRAPH_YLEGEND_ANGLE_value=
ac_cv_env_SQLITE_CFLAGS_set=
ac_cv_env_SQLITE_CFLAGS_value=
ac_cv_env_SQLITE_LIBS_set=
ac_cv_env_SQLITE_LIBS_value=
ac_cv_env_VALGRIND_CFLAGS_set=
ac_cv_env_VALGRIND_CFLAGS_value=
ac_cv_env_VALGRIND_LIBS_set=
ac_cv_env_VALGRIND_LIBS_value=
ac_cv_env_XMKMF_set=
ac_cv_env_XMKMF_value=
ac_cv_env_XML_CFLAGS_set=
ac_cv_env_XML_CFLAGS_value=
ac_cv_env_XML_LIBS_set=
ac_cv_env_XML_LIBS_value=
ac_cv_env_YACC_set=
ac_cv_env_YACC_value=
ac_cv_env_YFLAGS_set=
ac_cv_env_YFLAGS_value=
ac_cv_env_ZLIB_CFLAGS_set=
ac_cv_env_ZLIB_CFLAGS_value=
ac_cv_env_ZLIB_LIBS_set=
ac_cv_env_ZLIB_LIBS_value=
ac_cv_env_build_alias_set=set
ac_cv_env_build_alias_value=x86_64-pc-linux-gnu
ac_cv_env_host_alias_set=set
ac_cv_env_host_alias_value=mips-linux
ac_cv_env_target_alias_set=set
ac_cv_env_target_alias_value=mips-linux
ac_cv_epoll=no
ac_cv_epoll_create1=no
ac_cv_epoll_create=no
ac_cv_epoll_ctl=no
ac_cv_epoll_wait=no
ac_cv_epoll_works=no
ac_cv_exeext=
ac_cv_f77_compiler_gnu=no
ac_cv_file__usr_X11R6_lib64=no
ac_cv_file__usr_X11R6_lib=no
ac_cv_func_CRYPTO_cleanup_all_ex_data=yes
ac_cv_func_ENGINE_cleanup=yes
ac_cv_func_ENGINE_init=yes
ac_cv_func_ENGINE_load_builtin_engines=yes
ac_cv_func_RAND_egd=yes
ac_cv_func_RAND_screen=no
ac_cv_func_RAND_status=yes
ac_cv_func_SSL_CTX_set_alpn_protos=no
ac_cv_func_SSL_CTX_set_alpn_select_cb=no
ac_cv_func_SSL_CTX_set_next_proto_select_cb=no
ac_cv_func_SSL_get_shutdown=yes
ac_cv_func_SSLv2_client_method=yes
ac_cv_func___dlopen=no
ac_cv_func___fsetlocking=yes
ac_cv_func___secure_getenv=no
ac_cv_func___yp_get_default_domain=no
ac_cv_func__doprnt=no
ac_cv_func__exit=yes
ac_cv_func__fstati64=no
ac_cv_func__stat=no
ac_cv_func_abort=yes
ac_cv_func_alarm=yes
ac_cv_func_alloca_works=yes
ac_cv_func_alphasort=yes
ac_cv_func_argz_count=no
ac_cv_func_argz_next=no
ac_cv_func_argz_stringify=no
ac_cv_func_asctime_r=yes
ac_cv_func_asprintf=yes
ac_cv_func_atoi=yes
ac_cv_func_atol=yes
ac_cv_func_atoll=yes
ac_cv_func_attr_get=no
ac_cv_func_backtrace=yes
ac_cv_func_basename=yes
ac_cv_func_bcopy=yes
ac_cv_func_blkid_probe_enable_partitions=no
ac_cv_func_blkid_probe_get_topology=no
ac_cv_func_bzero=yes
ac_cv_func_calloc_0_nonnull=yes
ac_cv_func_chdir=yes
ac_cv_func_chflags=no
ac_cv_func_chroot=yes
ac_cv_func_class=no
ac_cv_func_clock=yes
ac_cv_func_clock_gettime=yes
ac_cv_func_closesocket=no
ac_cv_func_closesocket_camel=no
ac_cv_func_connect=yes
ac_cv_func_cputime=no
ac_cv_func_crypt=no
ac_cv_func_crypt_r=no
ac_cv_func_ctime_r=yes
ac_cv_func_cuserid=yes
ac_cv_func_directio=no
ac_cv_func_dlclose=no
ac_cv_func_dlerror=no
ac_cv_func_dlopen=no
ac_cv_func_dlsym=no
ac_cv_func_dup2=yes
ac_cv_func_epoll_create1=no
ac_cv_func_epoll_create=no
ac_cv_func_epoll_ctl=no
ac_cv_func_epoll_wait=no
ac_cv_func_eventfd=yes
ac_cv_func_fadvise64=no
ac_cv_func_fallocate64=no
ac_cv_func_fallocate=no
ac_cv_func_fchmod=yes
ac_cv_func_fchown=yes
ac_cv_func_fclose=yes
ac_cv_func_fcntl=yes
ac_cv_func_fcntl_o_nonblock=yes
ac_cv_func_fdatasync=yes
ac_cv_func_fdopen=yes
ac_cv_func_fgetc=yes
ac_cv_func_fgets=yes
ac_cv_func_finite=yes
ac_cv_func_flock=yes
ac_cv_func_fnmatch_works=no
ac_cv_func_fopen=yes
ac_cv_func_fopencookie=yes
ac_cv_func_fork=yes
ac_cv_func_fork_works=yes
ac_cv_func_fp_class=no
ac_cv_func_fpclass=no
ac_cv_func_fpclassify=no
ac_cv_func_fprintf=yes
ac_cv_func_freeaddrinfo=yes
ac_cv_func_freeifaddrs=yes
ac_cv_func_fseeko=yes
ac_cv_func_fsetxattr=yes
ac_cv_func_fstat64=yes
ac_cv_func_ftime=yes
ac_cv_func_ftok=yes
ac_cv_func_ftruncate64=yes
ac_cv_func_ftruncate=yes
ac_cv_func_fullfsync=no
ac_cv_func_funopen=no
ac_cv_func_futimes=no
ac_cv_func_fwprintf=yes
ac_cv_func_fwrite=yes
ac_cv_func_gai_strerror=yes
ac_cv_func_gcvt=yes
ac_cv_func_getaddrinfo=yes
ac_cv_func_getaddrinfo_threadsafe=yes
ac_cv_func_getcwd=yes
ac_cv_func_getdtablesize=yes
ac_cv_func_getegid=yes
ac_cv_func_getenv=yes
ac_cv_func_geteuid=yes
ac_cv_func_getgid=yes
ac_cv_func_getgrgid_r=yes
ac_cv_func_getgrnam_r=yes
ac_cv_func_gethostbyaddr=yes
ac_cv_func_gethostbyaddr_r=yes
ac_cv_func_gethostbyname=yes
ac_cv_func_gethostbyname_r=yes
ac_cv_func_gethostname=yes
ac_cv_func_getifaddrs=yes
ac_cv_func_getloadavg=no
ac_cv_func_getlogin=yes
ac_cv_func_getmntinfo=no
ac_cv_func_getnameinfo=yes
ac_cv_func_getopt=yes
ac_cv_func_getpagesize=yes
ac_cv_func_getpass_r=no
ac_cv_func_getppid=yes
ac_cv_func_getprotobyname=yes
ac_cv_func_getprotobynumber=yes
ac_cv_func_getpwent=yes
ac_cv_func_getpwnam=yes
ac_cv_func_getpwnam_r=yes
ac_cv_func_getpwuid=yes
ac_cv_func_getpwuid_r=yes
ac_cv_func_getrlimit=yes
ac_cv_func_getrusage=yes
ac_cv_func_getservbyname=yes
ac_cv_func_getservbyport=yes
ac_cv_func_getservbyport_r=yes
ac_cv_func_getsysinfo=no
ac_cv_func_gettimeofday=yes
ac_cv_func_getttynam=yes
ac_cv_func_getuid=yes
ac_cv_func_gmtime_r=yes
ac_cv_func_grantpt=yes
ac_cv_func_hstrerror=yes
ac_cv_func_htonl=yes
ac_cv_func_if_nametoindex=yes
ac_cv_func_index=yes
ac_cv_func_inet_addr=yes
ac_cv_func_inet_aton=yes
ac_cv_func_inet_ntoa=yes
ac_cv_func_inet_ntoa_r=yes
ac_cv_func_inet_ntop=yes
ac_cv_func_inet_pton=yes
ac_cv_func_inotify_init=yes
ac_cv_func_ioctl=yes
ac_cv_func_ioctl_fionbio=yes
ac_cv_func_ioctl_siocgifaddr=yes
ac_cv_func_ioctlsocket=no
ac_cv_func_ioctlsocket_camel=no
ac_cv_func_isalpha=yes
ac_cv_func_isascii=yes
ac_cv_func_isdigit=yes
ac_cv_func_isinf=yes
ac_cv_func_isnan=yes
ac_cv_func_isnand=no
ac_cv_func_isprint=yes
ac_cv_func_issetugid=no
ac_cv_func_isspace=yes
ac_cv_func_iswctype=yes
ac_cv_func_iswlower=yes
ac_cv_func_iswupper=yes
ac_cv_func_isxdigit=yes
ac_cv_func_jrand48=yes
ac_cv_func_kill=yes
ac_cv_func_kqueue=no
ac_cv_func_lchown=yes
ac_cv_func_link=yes
ac_cv_func_llseek=no
ac_cv_func_locale_charset=no
ac_cv_func_localeconv=yes
ac_cv_func_localtime=yes
ac_cv_func_localtime_r=yes
ac_cv_func_lockf=yes
ac_cv_func_lrand48=yes
ac_cv_func_lseek64=yes
ac_cv_func_lstat=yes
ac_cv_func_lstat_dereferences_slashed_symlink=no
ac_cv_func_madvise=yes
ac_cv_func_mallinfo=yes
ac_cv_func_malloc_0_nonnull=yes
ac_cv_func_mbrlen=yes
ac_cv_func_mbrtowc=yes
ac_cv_func_mbscasecmp=no
ac_cv_func_mbschr=no
ac_cv_func_mbscmp=no
ac_cv_func_mbsnrtowcs=yes
ac_cv_func_mbsrtowcs=yes
ac_cv_func_mbstowcs=yes
ac_cv_func_memalign=yes
ac_cv_func_memcmp=yes
ac_cv_func_memcmp_clean=no
ac_cv_func_memcmp_working=yes
ac_cv_func_memcpy=yes
ac_cv_func_memmove=yes
ac_cv_func_mempcpy=yes
ac_cv_func_memrchr=yes
ac_cv_func_memset=yes
ac_cv_func_mkdir=yes
ac_cv_func_mkstemp=yes
ac_cv_func_mktime=yes
ac_cv_func_mlock=yes
ac_cv_func_mmap=yes
ac_cv_func_mmap_anon=yes
ac_cv_func_mmap_dev_zero=yes
ac_cv_func_mmap_file=yes
ac_cv_func_mmap_fixed_mapped=yes
ac_cv_func_mprotect=yes
ac_cv_func_msync=yes
ac_cv_func_munlock=yes
ac_cv_func_munmap=yes
ac_cv_func_nanosleep=yes
ac_cv_func_newlocale=no
ac_cv_func_nl_langinfo=yes
ac_cv_func_obstack_vprintf=no
ac_cv_func_open64=yes
ac_cv_func_opendir=yes
ac_cv_func_pathconf=yes
ac_cv_func_perror=yes
ac_cv_func_pipe=yes
ac_cv_func_poll=yes
ac_cv_func_popen=yes
ac_cv_func_port_create=no
ac_cv_func_posix_fadvise64=yes
ac_cv_func_posix_fadvise=yes
ac_cv_func_posix_fallocate=no
ac_cv_func_posix_getgrgid_r=yes
ac_cv_func_posix_getpwuid_r=yes
ac_cv_func_posix_madvise=no
ac_cv_func_posix_memalign=yes
ac_cv_func_prctl=yes
ac_cv_func_pread64=yes
ac_cv_func_pread=yes
ac_cv_func_printf=yes
ac_cv_func_processor_info=no
ac_cv_func_pstat_getdynamic=no
ac_cv_func_pstat_getprocessor=no
ac_cv_func_pthread_self=yes
ac_cv_func_pthread_sigqueue=no
ac_cv_func_pthread_yield=yes
ac_cv_func_ptsname=yes
ac_cv_func_putenv=yes
ac_cv_func_pwrite64=yes
ac_cv_func_pwrite=yes
ac_cv_func_qsort=yes
ac_cv_func_raise=yes
ac_cv_func_rand=yes
ac_cv_func_rand_r=yes
ac_cv_func_random=yes
ac_cv_func_read_real_time=no
ac_cv_func_readdir=yes
ac_cv_func_readdir_r=yes
ac_cv_func_readline=yes
ac_cv_func_realloc_0_nonnull=yes
ac_cv_func_realpath=yes
ac_cv_func_recv=yes
ac_cv_func_regcomp=yes
ac_cv_func_remove=yes
ac_cv_func_rename=yes
ac_cv_func_rindex=yes
ac_cv_func_scandir=yes
ac_cv_func_sched_yield=yes
ac_cv_func_secure_getenv=no
ac_cv_func_select=yes
ac_cv_func_sem_init=no
ac_cv_func_send=yes
ac_cv_func_send_file=no
ac_cv_func_sendfile64=yes
ac_cv_func_sendfile=yes
ac_cv_func_setbuf=yes
ac_cv_func_setbuffer=yes
ac_cv_func_setenv=yes
ac_cv_func_setgid=yes
ac_cv_func_setitimer=yes
ac_cv_func_setlocale=yes
ac_cv_func_setmntent=yes
ac_cv_func_setmode=no
ac_cv_func_setpgid=yes
ac_cv_func_setpgrp_void=yes
ac_cv_func_setproctitle=no
ac_cv_func_setresgid=yes
ac_cv_func_setresuid=yes
ac_cv_func_setrlimit=yes
ac_cv_func_setsockopt=yes
ac_cv_func_setsockopt_so_nonblock=no
ac_cv_func_setuid=yes
ac_cv_func_setvbuf=yes
ac_cv_func_shl_load=no
ac_cv_func_shmget=yes
ac_cv_func_shutdown=yes
ac_cv_func_sigaction=yes
ac_cv_func_sigaltstack=yes
ac_cv_func_siginterrupt=yes
ac_cv_func_signal=yes
ac_cv_func_signalfd=yes
ac_cv_func_sigsetjmp=yes
ac_cv_func_sigstack=no
ac_cv_func_sigvec=no
ac_cv_func_sin=no
ac_cv_func_snprintf=yes
ac_cv_func_socket=yes
ac_cv_func_socketpair=yes
ac_cv_func_sprintf=yes
ac_cv_func_srand48=yes
ac_cv_func_srand=yes
ac_cv_func_srandom=yes
ac_cv_func_sscanf=yes
ac_cv_func_stat=yes
ac_cv_func_stat_empty_string_bug=yes
ac_cv_func_statfs=yes
ac_cv_func_statvfs=yes
ac_cv_func_std_syslog=no
ac_cv_func_stpcpy=yes
ac_cv_func_strcasecmp=yes
ac_cv_func_strcat=yes
ac_cv_func_strchr=yes
ac_cv_func_strcmpi=no
ac_cv_func_strcoll=yes
ac_cv_func_strcoll_works=no
ac_cv_func_strdup=yes
ac_cv_func_strerror=yes
ac_cv_func_strerror_r=yes
ac_cv_func_strerror_r_char_p=yes
ac_cv_func_strftime=yes
ac_cv_func_stricmp=no
ac_cv_func_strlcat=yes
ac_cv_func_strlcpy=yes
ac_cv_func_strncasecmp=yes
ac_cv_func_strncat=yes
ac_cv_func_strncmp=yes
ac_cv_func_strncmpi=no
ac_cv_func_strndup=yes
ac_cv_func_strnicmp=no
ac_cv_func_strnlen=yes
ac_cv_func_strpbrk=yes
ac_cv_func_strptime=yes
ac_cv_func_strrchr=yes
ac_cv_func_strsep=yes
ac_cv_func_strstr=yes
ac_cv_func_strtod=yes
ac_cv_func_strtok_r=yes
ac_cv_func_strtol=yes
ac_cv_func_strtoll=yes
ac_cv_func_strtoul=yes
ac_cv_func_strtoull=yes
ac_cv_func_symlink=yes
ac_cv_func_sync_fetch_and_add=yes
ac_cv_func_sync_file_range=yes
ac_cv_func_sysconf=yes
ac_cv_func_sysctl=yes
ac_cv_func_sysctlbyname=no
ac_cv_func_syslog=yes
ac_cv_func_syssgi=no
ac_cv_func_tcgetattr=yes
ac_cv_func_tcgetpgrp=yes
ac_cv_func_tempnam=yes
ac_cv_func_time=yes
ac_cv_func_times=yes
ac_cv_func_towlower=yes
ac_cv_func_towupper=yes
ac_cv_func_tsearch=yes
ac_cv_func_tzset=yes
ac_cv_func_uname=yes
ac_cv_func_unlink=yes
ac_cv_func_unlockpt=yes
ac_cv_func_unsetenv=yes
ac_cv_func_uselocale=no
ac_cv_func_usleep=yes
ac_cv_func_utime=yes
ac_cv_func_utime_null=no
ac_cv_func_utimes=yes
ac_cv_func_valloc=yes
ac_cv_func_vasprintf=yes
ac_cv_func_vfork=yes
ac_cv_func_vfork_works=yes
ac_cv_func_vfprintf=yes
ac_cv_func_vprintf=yes
ac_cv_func_vsnprintf=yes
ac_cv_func_vsprintf=yes
ac_cv_func_wcrtomb=yes
ac_cv_func_wcscoll=yes
ac_cv_func_wcsdup=yes
ac_cv_func_wcslen=yes
ac_cv_func_wcsnlen=yes
ac_cv_func_wcswidth=yes
ac_cv_func_wctype=yes
ac_cv_func_wcwidth=yes
ac_cv_func_writev=yes
ac_cv_func_yield=no
ac_cv_func_yp_get_default_domain=no
ac_cv_gnu_library_2=no
ac_cv_have_decl_AUDIT_USER_TTY=yes
ac_cv_have_decl_TFD_NONBLOCK=yes
ac_cv_have_decl__snprintf=no
ac_cv_have_decl__snwprintf=no
ac_cv_have_decl_fdatasync=yes
ac_cv_have_decl_feof_unlocked=yes
ac_cv_have_decl_fgetc=yes
ac_cv_have_decl_fgets_unlocked=yes
ac_cv_have_decl_fscanf=yes
ac_cv_have_decl_getc_unlocked=yes
ac_cv_have_decl_llseek=no
ac_cv_have_decl_lseek64=yes
ac_cv_have_decl_malloc=yes
ac_cv_have_decl_munmap=yes
ac_cv_have_decl_optarg=yes
ac_cv_have_decl_posix_fadvise=yes
ac_cv_have_decl_strerror_r=yes
ac_cv_have_decl_sys_errlist=no
ac_cv_have_decl_sys_nerr=no
ac_cv_have_decl_ungetc=yes
ac_cv_have_decl_vfprintf=yes
ac_cv_have_optreset=no
ac_cv_have_sig_atomic_t=yes
ac_cv_header_ApplicationServices_ApplicationServices_h=no
ac_cv_header_alloca_h=yes
ac_cv_header_ansidecl_h=no
ac_cv_header_argz_h=no
ac_cv_header_arpa_inet_h=yes
ac_cv_header_arpa_nameser_h=yes
ac_cv_header_arpa_tftp_h=yes
ac_cv_header_asm_types_h=yes
ac_cv_header_assert_h=yes
ac_cv_header_atomic_h=no
ac_cv_header_crypt_h=yes
ac_cv_header_ctype_h=yes
ac_cv_header_dirent_dirent_h=yes
ac_cv_header_dirent_h=yes
ac_cv_header_dl_h=no
ac_cv_header_dlfcn_h=yes
ac_cv_header_dns_h=no
ac_cv_header_errno_h=yes
ac_cv_header_execinfo_h=yes
ac_cv_header_fcntl_h=yes
ac_cv_header_features_h=yes
ac_cv_header_float_h=yes
ac_cv_header_fp_class_h=no
ac_cv_header_ft2build_h=yes
ac_cv_header_getopt_h=yes
ac_cv_header_gpm_h=no
ac_cv_header_grp_h=yes
ac_cv_header_iconv_h=yes
ac_cv_header_ieeefp_h=no
ac_cv_header_ifaddrs_h=yes
ac_cv_header_inttypes_h=yes
ac_cv_header_invent_h=no
ac_cv_header_io_h=no
ac_cv_header_langinfo_h=yes
ac_cv_header_libart_lgpl_libart_h=yes
ac_cv_header_libgen_h=yes
ac_cv_header_libssh2_h=no
ac_cv_header_limits_h=yes
ac_cv_header_linux_falloc_h=yes
ac_cv_header_linux_fd_h=yes
ac_cv_header_linux_filter_h=yes
ac_cv_header_linux_loop_h=yes
ac_cv_header_linux_major_h=yes
ac_cv_header_linux_netlink_h=yes
ac_cv_header_locale_h=yes
ac_cv_header_lzma_h=no
ac_cv_header_machine_hal_sysinfo_h=no
ac_cv_header_malloc_h=yes
ac_cv_header_math_h=yes
ac_cv_header_memory_h=yes
ac_cv_header_minix_config_h=no
ac_cv_header_mntent_h=yes
ac_cv_header_monetary_h=no
ac_cv_header_nan_h=no
ac_cv_header_net_if_dl_h=no
ac_cv_header_net_if_h=yes
ac_cv_header_netdb_h=yes
ac_cv_header_netinet_in_h=yes
ac_cv_header_netinet_tcp_h=yes
ac_cv_header_nl_types_h=yes
ac_cv_header_openssl_crypto_h=yes
ac_cv_header_openssl_engine_h=yes
ac_cv_header_openssl_err_h=yes
ac_cv_header_openssl_pem_h=yes
ac_cv_header_openssl_pkcs12_h=yes
ac_cv_header_openssl_rsa_h=yes
ac_cv_header_openssl_ssl_h=yes
ac_cv_header_openssl_x509_h=yes
ac_cv_header_paths_h=yes
ac_cv_header_png_h=yes
ac_cv_header_poll_h=yes
ac_cv_header_port_h=no
ac_cv_header_pthread_h=yes
ac_cv_header_pwd_h=yes
ac_cv_header_resolv_h=yes
ac_cv_header_semaphore_h=yes
ac_cv_header_setjmp_h=yes
ac_cv_header_sgtty_h=yes
ac_cv_header_signal_h=yes
ac_cv_header_socket_h=no
ac_cv_header_stat_broken=no
ac_cv_header_stdarg_h=yes
ac_cv_header_stdbool_h=yes
ac_cv_header_stdc=yes
ac_cv_header_stddef_h=yes
ac_cv_header_stdint_h=yes
ac_cv_header_stdio_h=yes
ac_cv_header_stdlib_h=yes
ac_cv_header_string_h=yes
ac_cv_header_strings_h=yes
ac_cv_header_stropts_h=no
ac_cv_header_sys_attributes_h=no
ac_cv_header_sys_bsdtypes_h=no
ac_cv_header_sys_devpoll_h=no
ac_cv_header_sys_disk_h=no
ac_cv_header_sys_disklabel_h=no
ac_cv_header_sys_epoll_h=no
ac_cv_header_sys_event_h=no
ac_cv_header_sys_eventfd_h=yes
ac_cv_header_sys_file_h=yes
ac_cv_header_sys_filio_h=no
ac_cv_header_sys_inotify_h=yes
ac_cv_header_sys_ioctl_h=yes
ac_cv_header_sys_iograph_h=no
ac_cv_header_sys_ipc_h=yes
ac_cv_header_sys_loadavg_h=no
ac_cv_header_sys_mkdev_h=no
ac_cv_header_sys_mman_h=yes
ac_cv_header_sys_mount_h=yes
ac_cv_header_sys_param_h=yes
ac_cv_header_sys_poll_h=yes
ac_cv_header_sys_prctl_h=yes
ac_cv_header_sys_processor_h=no
ac_cv_header_sys_pstat_h=no
ac_cv_header_sys_pte_h=no
ac_cv_header_sys_ptem_h=no
ac_cv_header_sys_resource_h=yes
ac_cv_header_sys_select_h=yes
ac_cv_header_sys_sendfile_h=yes
ac_cv_header_sys_signalfd_h=yes
ac_cv_header_sys_socket_h=yes
ac_cv_header_sys_sockio_h=no
ac_cv_header_sys_stat_h=yes
ac_cv_header_sys_statfs_h=yes
ac_cv_header_sys_statvfs_h=yes
ac_cv_header_sys_stream_h=no
ac_cv_header_sys_syscall_h=yes
ac_cv_header_sys_sysctl_h=yes
ac_cv_header_sys_sysexits_h=no
ac_cv_header_sys_sysinfo_h=yes
ac_cv_header_sys_syslimits_h=no
ac_cv_header_sys_sysmacros_h=yes
ac_cv_header_sys_syssgi_h=no
ac_cv_header_sys_systemcfg_h=no
ac_cv_header_sys_time_h=yes
ac_cv_header_sys_timeb_h=yes
ac_cv_header_sys_timerfd_h=yes
ac_cv_header_sys_times_h=yes
ac_cv_header_sys_types_h=yes
ac_cv_header_sys_uio_h=yes
ac_cv_header_sys_un_h=yes
ac_cv_header_sys_utime_h=no
ac_cv_header_sys_utsname_h=yes
ac_cv_header_sys_varargs_h=no
ac_cv_header_sys_vfs_h=yes
ac_cv_header_sys_wait_h=yes
ac_cv_header_sys_xattr_h=yes
ac_cv_header_sysexits_h=yes
ac_cv_header_syslog_h=yes
ac_cv_header_termcap_h=yes
ac_cv_header_termio_h=yes
ac_cv_header_termios_h=yes
ac_cv_header_time=yes
ac_cv_header_time_h=yes
ac_cv_header_ttyent_h=yes
ac_cv_header_unistd_h=yes
ac_cv_header_unix_h=no
ac_cv_header_utime_h=yes
ac_cv_header_uuid_uuid_h=yes
ac_cv_header_varargs_h=no
ac_cv_header_vfork_h=no
ac_cv_header_wchar_h=yes
ac_cv_header_wctype_h=yes
ac_cv_header_winber_h=no
ac_cv_header_windows_h=no
ac_cv_header_winldap_h=no
ac_cv_header_winsock2_h=no
ac_cv_header_winsock_h=no
ac_cv_header_ws2tcpip_h=no
ac_cv_header_zlib_h=yes
ac_cv_host=mips-unknown-linux-gnu
ac_cv_int_type_int32_t=yes
ac_cv_int_type_uint32_t=yes
ac_cv_ipv6_support=yes
ac_cv_lib_art_lgpl_2_art_vpath_add_point=yes
ac_cv_lib_cposix_strerror=no
ac_cv_lib_crypto_BIO_f_base64=yes
ac_cv_lib_crypto_CRYPTO_free=yes
ac_cv_lib_crypto_CRYPTO_lock=yes
ac_cv_lib_crypto_SRP_Calc_client_key=no
ac_cv_lib_crypto_X509_free=yes
ac_cv_lib_dir_opendir=no
ac_cv_lib_dl_dlclose=yes
ac_cv_lib_dl_dlerror=yes
ac_cv_lib_dl_dlopen=yes
ac_cv_lib_dl_dlsym=yes
ac_cv_lib_dld_shl_load=no
ac_cv_lib_fcgi_FCGI_Accept=no
ac_cv_lib_freetype_FT_Init_FreeType=yes
ac_cv_lib_gd_gdImageCreateFromXpm=no
ac_cv_lib_jpeg_jpeg_set_defaults=yes
ac_cv_lib_lex='none needed'
ac_cv_lib_m=ac_cv_lib_m_main
ac_cv_lib_m_cos=yes
ac_cv_lib_m_floor=yes
ac_cv_lib_m_main=yes
ac_cv_lib_m_sin=yes
ac_cv_lib_nsl=ac_cv_lib_nsl_main
ac_cv_lib_nsl___yp_get_default_domain=no
ac_cv_lib_nsl_main=no
ac_cv_lib_nsl_yp_get_default_domain=no
ac_cv_lib_png_png_access_version_number=yes
ac_cv_lib_png_png_write_image=yes
ac_cv_lib_pthread=ac_cv_lib_pthread_main
ac_cv_lib_pthread_main=yes
ac_cv_lib_pthread_pthread_join=yes
ac_cv_lib_pthread_pthread_kill=yes
ac_cv_lib_pthread_sem_init=yes
ac_cv_lib_rt_nanosleep=yes
ac_cv_lib_rtmp_RTMP_Init=no
ac_cv_lib_socket=ac_cv_lib_socket_main
ac_cv_lib_socket_accept=no
ac_cv_lib_socket_main=no
ac_cv_lib_socket_socket=no
ac_cv_lib_sqlite3_sqlite3_prepare_v2=yes
ac_cv_lib_ssh2_libssh2_channel_open_ex=no
ac_cv_lib_ssl_DSA_get_default_method=no
ac_cv_lib_ssl_SSL_CTX_set_ssl_version=yes
ac_cv_lib_ssl_SSL_connect=yes
ac_cv_lib_ssl_SSL_new=yes
ac_cv_lib_util_openpty=yes
ac_cv_lib_z_deflate=yes
ac_cv_lib_z_gzread=yes
ac_cv_lib_z_zlibVersion=yes
ac_cv_linux_vers=2.6.13.1
ac_cv_member_struct_dirent_d_reclen=yes
ac_cv_member_struct_pst_processor_psp_iticksperclktick=no
ac_cv_member_struct_sockaddr_sa_len=no
ac_cv_member_struct_stat_st_atim=yes
ac_cv_member_struct_stat_st_birthtime=no
ac_cv_member_struct_stat_st_birthtimensec=no
ac_cv_member_struct_stat_st_blksize=yes
ac_cv_member_struct_stat_st_blocks=yes
ac_cv_member_struct_stat_st_rdev=yes
ac_cv_member_struct_tm_tm_gmtoff=yes
ac_cv_member_struct_tm_tm_zone=yes
ac_cv_mingw32=no
ac_cv_msg_nosignal=yes
ac_cv_native_windows=no
ac_cv_objext=o
ac_cv_path_AR=/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-ar
ac_cv_path_CHMOD=/bin/chmod
ac_cv_path_CP=/bin/cp
ac_cv_path_EGREP='/bin/grep -E'
ac_cv_path_FGREP='/bin/grep -F'
ac_cv_path_GMSGFMT=/usr/bin/msgfmt
ac_cv_path_GREP=/bin/grep
ac_cv_path_LDCONFIG=/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-ldconfig
ac_cv_path_LN=/bin/ln
ac_cv_path_MSGFMT=/usr/bin/msgfmt
ac_cv_path_MSGMERGE=/usr/bin/msgmerge
ac_cv_path_MV=/bin/mv
ac_cv_path_NROFF=/usr/bin/nroff
ac_cv_path_PCRECONFIG=/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/pcre-config
ac_cv_path_PERL=/usr/bin/perl
ac_cv_path_PKG_CONFIG=/usr/bin/pkg-config
ac_cv_path_RM=/bin/rm
ac_cv_path_RUBY=/usr/bin/ruby
ac_cv_path_SED=/bin/sed
ac_cv_path_TAR=/bin/tar
ac_cv_path_TIC_PATH=/usr/bin/tic
ac_cv_path_TROFF=/usr/bin/groff
ac_cv_path_WGET=/usr/bin/wget
ac_cv_path_XGETTEXT=/usr/bin/xgettext
ac_cv_path_XMLLINT=/usr/bin/xmllint
ac_cv_path_XSLTPROC=/usr/bin/xsltproc
ac_cv_path_ac_pt_PKGCONFIG=/usr/bin/pkg-config
ac_cv_path_ac_pt_PKG_CONFIG=/usr/bin/pkg-config
ac_cv_path_ac_pt_db_cv_path_sh=/bin/sh
ac_cv_path_ax_enable_builddir_sed=sed
ac_cv_path_install='/usr/bin/install -c'
ac_cv_path_mkdir=/bin/mkdir
ac_cv_php_xml2_config_path=/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/usr/bin/xml2-config
ac_cv_prog_AR=mips-linux-ar
ac_cv_prog_AWK=gawk
ac_cv_prog_BUILD_CC=gcc
ac_cv_prog_CC=/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc
ac_cv_prog_CC_BUILD=gcc
ac_cv_prog_CPP='/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -E'
ac_cv_prog_CXXCPP='/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-g++-wrapper -E'
ac_cv_prog_DLLTOOL=dlltool
ac_cv_prog_INTLBISON=bison
ac_cv_prog_LD=mips-linux-ld
ac_cv_prog_LEX=flex
ac_cv_prog_LN_S='ln -s'
ac_cv_prog_MAKEINFO=makeinfo
ac_cv_prog_MAKE_LOWER_TAGS=no
ac_cv_prog_MAKE_UPPER_TAGS=no
ac_cv_prog_OBJDUMP=mips-linux-objdump
ac_cv_prog_PKGCONFIG=pkg-config
ac_cv_prog_PTHREAD_CC=/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc
ac_cv_prog_RANLIB=mips-linux-ranlib
ac_cv_prog_RMDIR=rmdir
ac_cv_prog_SED=/bin/sed
ac_cv_prog_STRIP=mips-linux-strip
ac_cv_prog_YACC='bison -y'
ac_cv_prog_ac_ct_CHMOD=chmod
ac_cv_prog_ac_ct_CP=cp
ac_cv_prog_ac_ct_LN=ln
ac_cv_prog_ac_ct_MANIFEST_TOOL=mt
ac_cv_prog_ac_ct_MKDIR=mkdir
ac_cv_prog_ac_ct_RM=rm
ac_cv_prog_cc__home_michael_freetz_toolchain_build_mips_gcc_4_8_3_uClibc_0_9_33_2_nptl_mips_linux_uclibc_bin_mips_linux_uclibc_gcc_c_o=yes
ac_cv_prog_cc_c89=
ac_cv_prog_cc_c99=-std=gnu99
ac_cv_prog_cc_cross=yes
ac_cv_prog_cc_g=yes
ac_cv_prog_cc_stdc=-std=gnu99
ac_cv_prog_cc_works=yes
ac_cv_prog_cxx_g=yes
ac_cv_prog_egrep='grep -E'
ac_cv_prog_f77_g=no
ac_cv_prog_gcc=yes
ac_cv_prog_gcc_traditional=no
ac_cv_prog_lex_root=lex.yy
ac_cv_prog_lex_yytext_pointer=no
ac_cv_prog_make_make_set=yes
ac_cv_pthreads_cflags=
ac_cv_pthreads_lib=
ac_cv_safe_to_define___extensions__=yes
ac_cv_search_clock_gettime='none required'
ac_cv_search_connect='none required'
ac_cv_search_crypt=-lcrypt
ac_cv_search_dlopen=-ldl
ac_cv_search_fdatasync='none required'
ac_cv_search_floor=-lm
ac_cv_search_getaddrinfo='none required'
ac_cv_search_gethostbyname='none required'
ac_cv_search_gethostent='none required'
ac_cv_search_hstrerror='none required'
ac_cv_search_opendir='none required'
ac_cv_search_pthread_create=-lpthread
ac_cv_search_readline=-lreadline
ac_cv_search_sched_yield='none required'
ac_cv_search_sendfilev=no
ac_cv_search_setsockopt='none required'
ac_cv_search_socket='none required'
ac_cv_search_strerror='none required'
ac_cv_search_tgetent=-lcurses
ac_cv_sig_atomic_t_volatile=no
ac_cv_sizeof_char=1
ac_cv_sizeof_char_p=4
ac_cv_sizeof_double=8
ac_cv_sizeof_fpos_t=24
ac_cv_sizeof_int=4
ac_cv_sizeof_long=4
ac_cv_sizeof_long_double=8
ac_cv_sizeof_long_long=8
ac_cv_sizeof_long_long_int=8
ac_cv_sizeof_mp_limb_t=4
ac_cv_sizeof_off_t=8
ac_cv_sizeof_pid_t=4
ac_cv_sizeof_ptrdiff_t=4
ac_cv_sizeof_short=2
ac_cv_sizeof_signed_char=1
ac_cv_sizeof_size_t=4
ac_cv_sizeof_socklen_t=4
ac_cv_sizeof_ssize_t=4
ac_cv_sizeof_stat_st_size=8
ac_cv_sizeof_time_t=4
ac_cv_sizeof_unsigned=4
ac_cv_sizeof_unsigned_char=1
ac_cv_sizeof_unsigned_int=4
ac_cv_sizeof_unsigned_long=4
ac_cv_sizeof_unsigned_long_long=8
ac_cv_sizeof_unsigned_short=2
ac_cv_sizeof_void_p=4
ac_cv_sizeof_voidp=4
ac_cv_sockaddr_sa_len=no
ac_cv_sockaddr_storage=yes
ac_cv_socklen_t=yes
ac_cv_struct_flock=yes
ac_cv_struct_timeval=yes
ac_cv_struct_tm=time.h
ac_cv_struct_tm_gmtoff=yes
ac_cv_sys_file_offset_bits=no
ac_cv_sys_large_files=no
ac_cv_sys_largefile_CC=no
ac_cv_sys_largefile_source=no
ac_cv_sys_long_file_names=yes
ac_cv_sys_tiocgwinsz_in_sys_ioctl_h=yes
ac_cv_sys_tiocgwinsz_in_termios_h=no
ac_cv_target=mips-unknown-linux-gnu
ac_cv_time_r_type=POSIX
ac_cv_tls=__thread
ac_cv_type_FILE_p=yes
ac_cv_type_bool=yes
ac_cv_type_in_addr_t=yes
ac_cv_type_int16_t=yes
ac_cv_type_int32_t=yes
ac_cv_type_int64_t=yes
ac_cv_type_intmax_t=yes
ac_cv_type_intptr_t=yes
ac_cv_type_long_double=yes
ac_cv_type_long_long=yes
ac_cv_type_long_long_int=yes
ac_cv_type_off_t=yes
ac_cv_type_pid_t=yes
ac_cv_type_pthread_rwlock_t=yes
ac_cv_type_ptrdiff_t=yes
ac_cv_type_quad_t=yes
ac_cv_type_sig_atomic_t=yes
ac_cv_type_signal=void
ac_cv_type_signed_char=yes
ac_cv_type_size_t=yes
ac_cv_type_socklen_t=yes
ac_cv_type_ssize_t=yes
ac_cv_type_stack_t=yes
ac_cv_type_struct_sockaddr_storage=yes
ac_cv_type_struct_timespec=yes
ac_cv_type_time_t=yes
ac_cv_type_u_char=yes
ac_cv_type_u_int16_t=yes
ac_cv_type_u_int32_t=yes
ac_cv_type_u_int64_t=yes
ac_cv_type_u_int8_t=yes
ac_cv_type_u_int=yes
ac_cv_type_u_long=yes
ac_cv_type_u_short=yes
ac_cv_type_uid_t=yes
ac_cv_type_uint_least32_t=yes
ac_cv_type_uintmax_t=yes
ac_cv_type_uintptr_t=yes
ac_cv_type_unsigned_long_long_int=yes
ac_cv_va_copy=C99
ac_cv_what_readdir_r=POSIX
ac_cv_with_dso=yes
ac_cv_with_editline=no
ac_cv_with_file=no
ac_cv_with_perl=no
ac_cv_with_utf8=no
ac_cv_with_version=no
ac_cv_working_alloca_h=yes
ac_cv_working_ni_withscopeid=no
ac_cv_write_stdout=yes
acl_cv_libext=a
acl_cv_path_LD=/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/mips-linux-uclibc/bin/ld
acl_cv_prog_gnu_ld=yes
acl_cv_rpath=done
am_cv_CCAS_dependencies_compiler_type=gcc3
am_cv_CC_dependencies_compiler_type=gcc3
am_cv_CXX_dependencies_compiler_type=gcc3
am_cv_ar_interface=ar
am_cv_func_iconv=yes
am_cv_func_iconv_works='guessing yes'
am_cv_langinfo_codeset=yes
am_cv_lib_iconv=no
am_cv_make_support_nested_variables=yes
am_cv_prog_cc_c_o=yes
am_cv_prog_tar_ustar=gnutar
am_cv_proto_iconv='extern size_t iconv (iconv_t cd, char * *inbuf, size_t *inbytesleft, char * *outbuf, size_t *outbytesleft);'
am_cv_proto_iconv_arg1=
ax_cv_PTHREAD_PRIO_INHERIT=no
ax_cv_c_compiler_vendor=gnu
bash_cv_dirent_has_d_fileno=yes
bash_cv_dirent_has_dino=yes
bash_cv_fionread_in_ioctl=yes
bash_cv_func_ctype_nonascii=no
bash_cv_func_lstat=yes
bash_cv_func_sigsetjmp=present
bash_cv_func_strcoll_broken=no
bash_cv_getpw_declared=yes
bash_cv_langinfo_codeset=yes
bash_cv_must_reinstall_sighandlers=no
bash_cv_signal_vintage=posix
bash_cv_speed_t_in_sys_types=no
bash_cv_struct_winsize_header=ioctl_h
bash_cv_termcap_lib=libncurses
bash_cv_tiocstat_in_ioctl=no
bash_cv_type_wchar_t=yes
bash_cv_type_wctype_t=yes
bash_cv_type_wint_t=yes
bash_cv_void_sighandler=yes
bash_cv_wcwidth_broken=no
cf_cv_1UL=1UL
cf_cv_abi_version=5
cf_cv_ansi_cc=-DCC_HAS_PROTOS
cf_cv_ar_flags=-curv
cf_cv_builtin_bool=1
cf_cv_cc_bool_type=0
cf_cv_dcl_errno=yes
cf_cv_define_sigwinch=yes
cf_cv_do_relink=yes
cf_cv_do_symlinks=yes
cf_cv_enable_lp64=0
cf_cv_enable_opaque=NCURSES_OPAQUE
cf_cv_enable_reentrant=0
cf_cv_enable_rpath=no
cf_cv_func_nanosleep=yes
cf_cv_func_openpty=pty.h
cf_cv_func_vsscanf=vsscanf
cf_cv_gcc_inline=yes
cf_cv_gnu_source=yes
cf_cv_have___va_copy=yes
cf_cv_have_errno=no
cf_cv_have_isascii=yes
cf_cv_have_tcgetattr=yes
cf_cv_have_va_copy=yes
cf_cv_header_stdbool_h=1
cf_cv_lib_util=yes
cf_cv_link_dataonly=yes
cf_cv_makeflags='-${MAKEFLAGS}'
cf_cv_mixedcase=yes
cf_cv_need_libm=yes
cf_cv_prog_CC_c_o=yes
cf_cv_regex_hdrs=regex.h
cf_cv_rel_version=5.9
cf_cv_rm_so_locs=no
cf_cv_shared_soname='`basename $@ .${REL_VERSION}`.${ABI_VERSION}'
cf_cv_shlib_version=rel
cf_cv_shlib_version_infix=no
cf_cv_sig_atomic_t='volatile sig_atomic_t'
cf_cv_sizechange=yes
cf_cv_src_modules='ncurses panel menu form'
cf_cv_struct_dirent64=no
cf_cv_sys_time_select=yes
cf_cv_system_name=linux-gnu
cf_cv_timestamp='Tue Oct 7 10:19:22 CEST 2014'
cf_cv_type_of_bool='unsigned char'
cf_cv_type_sigaction=no
cf_cv_typeof_chtype=long
cf_cv_typeof_mmask_t=long
cf_cv_unsigned_literals=yes
cf_cv_working_poll=no
cl_cv_as_noexecstack=no
cli_cv_var_PS_STRINGS=no
curl_cv_def_OPENSSL_VERSION_NUMBER=0x009081bfL
curl_cv_def_PRId64='"lld"'
curl_cv_def___GNUC__=4
curl_cv_func_getnameinfo_args='const struct sockaddr *,socklen_t,size_t,unsigned int'
curl_cv_func_recv_args='int,void *,size_t,int,int'
curl_cv_func_select_args='int,fd_set *,struct timeval *,int'
curl_cv_func_send_args='int,const void *,size_t,int,int'
curl_cv_gclk_LIBS=
curl_cv_getnameinfo=yes
curl_cv_have_def_OPENSSL_VERSION_NUMBER=yes
curl_cv_have_def_PRId64=yes
curl_cv_have_def__COMPILER_VERSION=no
curl_cv_have_def__SGI_COMPILER_VERSION=no
curl_cv_have_def__WIN32=no
curl_cv_have_def___DECC=no
curl_cv_have_def___DECC_VER=no
curl_cv_have_def___GNUC__=yes
curl_cv_have_def___HP_cc=no
curl_cv_have_def___IBMC__=no
curl_cv_have_def___INTEL_COMPILER=no
curl_cv_have_def___LCC__=no
curl_cv_have_def___SUNPRO_C=no
curl_cv_have_def___TINYC__=no
curl_cv_have_def___WATCOMC__=no
curl_cv_have_def___clang__=no
curl_cv_have_def___sgi=no
curl_cv_have_def_h_errno=yes
curl_cv_need_header_malloc_h=no
curl_cv_need_header_memory_h=no
curl_cv_recv=yes
curl_cv_save_LIBS=
curl_cv_select=yes
curl_cv_send=yes
curl_cv_variadic_macros_c99=yes
curl_cv_variadic_macros_gcc=yes
curl_cv_writable_argv=yes
db_cv_atomic=no
db_cv_build_atomicsupport=yes
db_cv_build_compression=no
db_cv_build_cryptography=no
db_cv_build_hash=no
db_cv_build_mutexsupport=yes
db_cv_build_partition=no
db_cv_build_queue=no
db_cv_build_replication=no
db_cv_build_sequence=yes
db_cv_build_statistics=no
db_cv_build_verify=no
db_cv_clock_monotonic=no
db_cv_compat185=no
db_cv_ctime_r_3arg=2-argument
db_cv_cxx=no
db_cv_debug=no
db_cv_debug_rop=no
db_cv_debug_wop=no
db_cv_diagnostic=no
db_cv_dump185=no
db_cv_exit_defines=yes
db_cv_fcntl_f_setfd=yes
db_cv_gcc_2_96=no
db_cv_getaddrinfo=yes
db_cv_java=no
db_cv_mingw=no
db_cv_mutex=MIPS/gcc-assembly
db_cv_o_direct=no
db_cv_optreset=no
db_cv_posixmutexes=no
db_cv_rpc=no
db_cv_seq_fmt='"%lld"'
db_cv_seq_type='long long'
db_cv_seq_ufmt='"%llu"'
db_cv_shmctl_shm_lock=yes
db_cv_smallbuild=yes
db_cv_stl=no
db_cv_tcl=no
db_cv_test=no
db_cv_uimutexes=no
db_cv_umrw=no
db_cv_uniquename=no
e2fsprogs_cv_struct_st_flags=no
gcc_cv_as_cfi_pseudo_op=yes
gl_cv_cc_vis_werror=yes
gl_cv_cc_visibility=yes
gl_cv_func_malloc_0_nonnull=yes
gl_cv_have_weak='guessing yes'
gl_cv_header_inttypes_h=yes
gl_cv_header_stdint_h=yes
gl_cv_header_working_fcntl_h=cross-compiling
gl_cv_size_max=yes
gmp_cv_asm_align_log=yes
gmp_cv_asm_byte=.byte
gmp_cv_asm_data=.data
gmp_cv_asm_globl=.globl
gmp_cv_asm_globl_attr=
gmp_cv_asm_label_suffix=:
gmp_cv_asm_lsym_prefix=.L
gmp_cv_asm_rodata=' .rdata'
gmp_cv_asm_size='.size $1,$2'
gmp_cv_asm_text=.text
gmp_cv_asm_type='.type $1,@$2'
gmp_cv_asm_underscore=no
gmp_cv_asm_w32=.long
gmp_cv_c_attribute_const=yes
gmp_cv_c_attribute_malloc=yes
gmp_cv_c_attribute_mode=yes
gmp_cv_c_attribute_noreturn=yes
gmp_cv_c_double_format='IEEE big endian'
gmp_cv_c_for_build_ansi=yes
gmp_cv_check_libm_for_build=-lm
gmp_cv_func_alloca=yes
gmp_cv_func_sscanf_writable_input=no
gmp_cv_func_vsnprintf=yes
gmp_cv_header_alloca=yes
gmp_cv_m4_m4wrap_spurious=no
gmp_cv_option_alloca=alloca
gmp_cv_prog_cpp_for_build='cc -E'
gmp_cv_prog_exeext_for_build=
gmp_cv_prog_m4=m4
gt_cv_c_intmax_t=yes
gt_cv_c_wchar_t=yes
gt_cv_c_wint_t=yes
gt_cv_func_CFLocaleCopyCurrent=no
gt_cv_func_CFPreferencesCopyAppValue=no
gt_cv_func_printf_posix=yes
gt_cv_int_divbyzero_sigfpe=no
gt_cv_inttypes_pri_broken=no
gt_cv_val_LC_MESSAGES=yes
ijg_cv_have_prototypes=yes
ijg_cv_inline=__inline__
libffi_cv_hidden_visibility_attribute=yes
libffi_cv_ro_eh_frame=yes
lt_cv_ar_at_file=@
lt_cv_archive_cmds_need_lc=no
lt_cv_compiler_c_o=yes
lt_cv_compiler_o_lo=yes
lt_cv_deplibs_check_method=pass_all
lt_cv_dlopen=dlopen
lt_cv_dlopen_libs=-ldl
lt_cv_dlopen_self=cross
lt_cv_file_magic_cmd='$MAGIC_CMD'
lt_cv_file_magic_test_file=
lt_cv_ld_reload_flag=-r
lt_cv_nm_interface='BSD nm'
lt_cv_objdir=.libs
lt_cv_path_LD=/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/mips-linux-uclibc/bin/ld
lt_cv_path_LDCXX=/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/mips-linux-uclibc/bin/ld
lt_cv_path_NM='/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-nm -B'
lt_cv_path_SED=/bin/sed
lt_cv_path_mainfest_tool=no
lt_cv_prog_cc_can_build_shared=yes
lt_cv_prog_cc_no_builtin=
lt_cv_prog_cc_pic=' -fPIC'
lt_cv_prog_cc_pic_works=yes
lt_cv_prog_cc_shlib=
lt_cv_prog_cc_static=-static
lt_cv_prog_cc_static_works=yes
lt_cv_prog_cc_wl=-Wl,
lt_cv_prog_compiler_c_o=yes
lt_cv_prog_compiler_c_o_CXX=yes
lt_cv_prog_compiler_c_o_RC=yes
lt_cv_prog_compiler_pic='-fPIC -DPIC'
lt_cv_prog_compiler_pic_CXX='-fPIC -DPIC'
lt_cv_prog_compiler_pic_works=yes
lt_cv_prog_compiler_pic_works_CXX=yes
lt_cv_prog_compiler_rtti_exceptions=no
lt_cv_prog_compiler_static_works=yes
lt_cv_prog_compiler_static_works_CXX=yes
lt_cv_prog_gnu_ld=yes
lt_cv_prog_gnu_ldcxx=yes
lt_cv_sharedlib_from_linklib_cmd='printf %s\n'
lt_cv_shlibpath_overrides_runpath=no
lt_cv_sys_global_symbol_pipe='sed -n -e '\''s/^.*[ ]\([ABCDGIRSTW][ABCDGIRSTW]*\)[ ][ ]*\([_A-Za-z][_A-Za-z0-9]*\)$/\1 \2 \2/p'\'''
lt_cv_sys_global_symbol_to_c_name_address='sed -n -e '\''s/^: \([^ ]*\) $/ {\"\1\", (void *) 0},/p'\'' -e '\''s/^[ABCDGIRSTW]* \([^ ]*\) \([^ ]*\)$/ {"\2", (void *) \&\2},/p'\'''
lt_cv_sys_global_symbol_to_c_name_address_lib_prefix='sed -n -e '\''s/^: \([^ ]*\) $/ {\"\1\", (void *) 0},/p'\'' -e '\''s/^[ABCDGIRSTW]* \([^ ]*\) \(lib[^ ]*\)$/ {"\2", (void *) \&\2},/p'\'' -e '\''s/^[ABCDGIRSTW]* \([^ ]*\) \([^ ]*\)$/ {"lib\2", (void *) \&\2},/p'\'''
lt_cv_sys_global_symbol_to_cdecl='sed -n -e '\''s/^T .* \(.*\)$/extern int \1();/p'\'' -e '\''s/^[ABCDGIRSTW]* .* \(.*\)$/extern char \1;/p'\'''
lt_cv_sys_lib_dlsearch_path_spec='/lib /usr/lib /usr/local/lib /lib/x86_64-linux-gnu /usr/lib/x86_64-linux-gnu /usr/lib/x86_64-linux-gnu/mesa-egl /usr/lib/x86_64-linux-gnu/mesa /lib32 /usr/lib32 /libx32 /usr/libx32 '
lt_cv_sys_lib_search_path_spec='/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/lib/gcc/mips-linux-uclibc/4.8.3 /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/lib/gcc /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/mips-linux-uclibc/lib /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/usr/lib /freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/usr/usr/lib'
lt_cv_sys_max_cmd_len=3458764513820540925
lt_cv_sys_path_separator=:
lt_cv_sys_symbol_underscore=no
lt_cv_to_host_file_cmd=func_convert_file_noop
lt_cv_to_tool_file_cmd=func_convert_file_noop
lt_lt_cv_prog_compiler_c_o='"yes"'
lt_lt_cv_prog_compiler_c_o_CXX='"yes"'
lt_lt_cv_sys_global_symbol_pipe='"sed -n -e '\''s/^.*[ ]\\([ABCDGIRSTW][ABCDGIRSTW]*\\)[ ][ ]*\\([_A-Za-z][_A-Za-z0-9]*\\)\$/\\1 \\2 \\2/p'\''"'
lt_lt_cv_sys_global_symbol_to_c_name_address='"sed -n -e '\''s/^: \\([^ ]*\\) \$/ {\\\"\\1\\\", (void *) 0},/p'\'' -e '\''s/^[ABCDGIRSTW]* \\([^ ]*\\) \\([^ ]*\\)\$/ {\"\\2\", (void *) \\&\\2},/p'\''"'
lt_lt_cv_sys_global_symbol_to_cdecl='"sed -n -e '\''s/^T .* \\(.*\\)\$/extern int \\1();/p'\'' -e '\''s/^[ABCDGIRSTW]* .* \\(.*\\)\$/extern char \\1;/p'\''"'
mingw_cv_win32_host=no
nls_cv_header_intl=
nls_cv_header_libgt=
pcre_cv_cc_vis_werror=yes
pcre_cv_cc_visibility=yes
php_cv_bison_version=invalid
php_cv_cc_dashr=yes
php_cv_sizeof_intmax_t=8
php_cv_sizeof_ptrdiff_t=4
php_cv_sizeof_ssize_t=4
pkg_cv_LUA_CFLAGS='-I/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/usr/include/lua '
pkg_cv_LUA_LIBS='-L/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/usr/lib -llua -ldl -lm '
pkg_cv_ZLIB_CFLAGS='-I/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/usr/include '
pkg_cv_ZLIB_LIBS='-L/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/usr/lib -lz '
rd_cv_gcc_flag__W=yes
rd_cv_gcc_flag__Wall=yes
rd_cv_gcc_flag__Wcast_align=yes
rd_cv_gcc_flag__Winline=yes
rd_cv_gcc_flag__Wmissing_declarations=yes
rd_cv_gcc_flag__Wmissing_prototypes=yes
rd_cv_gcc_flag__Wnested_externs=yes
rd_cv_gcc_flag__Wpointer_arith=yes
rd_cv_gcc_flag__Wshadow=yes
rd_cv_gcc_flag__fno_strict_aliasing=yes
rd_cv_gcc_flag__pedantic=yes
rd_cv_gcc_flag__std_gnu__=yes
rd_cv_ieee_works=yes
xml_cv_iconv_arg2=
xml_cv_iconv_decl='extern size_t iconv (iconv_t cd, char * *inbuf, size_t *inbytesleft, char * *outbuf, size_t *outbytesleft);'
## Output variables. ##
ALLOCA=''
AR=''
AWK='gawk'
CC='/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc'
CFLAGS='-march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -fvisibility=hidden'
CONFIGURE_COMMAND=' '\''./configure'\'' '\''--cache-file=/freetz/source/target-mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/config.cache'\'' '\''--target=mips-linux'\'' '\''--host=mips-linux'\'' '\''--build=x86_64-pc-linux-gnu'\'' '\''--program-prefix='\'' '\''--program-suffix='\'' '\''--prefix=/usr'\'' '\''--exec-prefix=/usr'\'' '\''--bindir=/usr/bin'\'' '\''--datadir=/usr/share'\'' '\''--includedir=/usr/include'\'' '\''--infodir=/usr/share/info'\'' '\''--libdir=/usr/lib'\'' '\''--libexecdir=/usr/lib'\'' '\''--localstatedir=/var'\'' '\''--mandir=/usr/share/man'\'' '\''--sbindir=/usr/sbin'\'' '\''--sysconfdir=/etc'\'' '\''--with-gnu-ld'\'' '\''--disable-nls'\'' '\''--with-pcre-regex=/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/usr'\'' '\''--with-curl=/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/usr'\'' '\''--with-gd=/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/usr'\'' '\''--enable-gd-native-ttf'\'' '\''--with-iconv'\'' '\''--with-iconv-dir=/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/usr'\'' '\''--enable-json'\'' '\''--with-libxml-dir=/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/usr'\'' '\''--without-libexpat-dir'\'' '\''--enable-xml'\'' '\''--enable-libxml'\'' '\''--enable-dom'\'' '\''--enable-simplexml'\'' '\''--enable-xmlreader'\'' '\''--enable-xmlwriter'\'' '\''--enable-pcntl'\'' '\''--enable-session'\'' '\''--enable-sockets'\'' '\''--without-sqlite'\'' '\''--with-sqlite3=/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/usr'\'' '\''--with-pdo-sqlite=/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/usr'\'' '\''--with-openssl=/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/usr'\'' '\''--enable-sysvsem'\'' '\''--enable-sysvshm'\'' '\''--enable-sysvmsg'\'' '\''--with-zlib'\'' '\''--with-zlib-dir=/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/usr'\'' '\''--enable-zip'\'' '\''--enable-exif'\'' '\''--enable-mbstring'\'' '\''--disable-cli'\'' '\''--disable-fileinfo'\'' '\''--disable-phar'\'' '\''--disable-rpath'\'' '\''--with-config-file-path=/tmp/flash'\'' '\''--with-config-file-scan-dir=/tmp/flash/php'\'' '\''--without-pear'\'''
CONFIGURE_OPTIONS=' '\''--cache-file=/freetz/source/target-mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/config.cache'\'' '\''--target=mips-linux'\'' '\''--host=mips-linux'\'' '\''--build=x86_64-pc-linux-gnu'\'' '\''--program-prefix='\'' '\''--program-suffix='\'' '\''--prefix=/usr'\'' '\''--exec-prefix=/usr'\'' '\''--bindir=/usr/bin'\'' '\''--datadir=/usr/share'\'' '\''--includedir=/usr/include'\'' '\''--infodir=/usr/share/info'\'' '\''--libdir=/usr/lib'\'' '\''--libexecdir=/usr/lib'\'' '\''--localstatedir=/var'\'' '\''--mandir=/usr/share/man'\'' '\''--sbindir=/usr/sbin'\'' '\''--sysconfdir=/etc'\'' '\''--with-gnu-ld'\'' '\''--disable-nls'\'' '\''--with-pcre-regex=/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/usr'\'' '\''--with-curl=/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/usr'\'' '\''--with-gd=/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/usr'\'' '\''--enable-gd-native-ttf'\'' '\''--with-iconv'\'' '\''--with-iconv-dir=/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/usr'\'' '\''--enable-json'\'' '\''--with-libxml-dir=/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/usr'\'' '\''--without-libexpat-dir'\'' '\''--enable-xml'\'' '\''--enable-libxml'\'' '\''--enable-dom'\'' '\''--enable-simplexml'\'' '\''--enable-xmlreader'\'' '\''--enable-xmlwriter'\'' '\''--enable-pcntl'\'' '\''--enable-session'\'' '\''--enable-sockets'\'' '\''--without-sqlite'\'' '\''--with-sqlite3=/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/usr'\'' '\''--with-pdo-sqlite=/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/usr'\'' '\''--with-openssl=/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/usr'\'' '\''--enable-sysvsem'\'' '\''--enable-sysvshm'\'' '\''--enable-sysvmsg'\'' '\''--with-zlib'\'' '\''--with-zlib-dir=/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/usr'\'' '\''--enable-zip'\'' '\''--enable-exif'\'' '\''--enable-mbstring'\'' '\''--disable-cli'\'' '\''--disable-fileinfo'\'' '\''--disable-phar'\'' '\''--disable-rpath'\'' '\''--with-config-file-path=/tmp/flash'\'' '\''--with-config-file-scan-dir=/tmp/flash/php'\'' '\''--without-pear'\'''
CPPFLAGS=' -D_XPG_IV'
CXX='/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-g++-wrapper'
CXXCPP=''
CXXFLAGS='-march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64'
DEBUG_CFLAGS=''
DEFS=''
DSYMUTIL=''
ECHO='echo'
ECHO_C=''
ECHO_N='-n'
ECHO_T=''
EXEEXT=''
EXPANDED_BINDIR=''
EXPANDED_DATADIR=''
EXPANDED_EXTENSION_DIR=''
EXPANDED_LIBDIR=''
EXPANDED_LOCALSTATEDIR=''
EXPANDED_MANDIR=''
EXPANDED_PEAR_INSTALLDIR=''
EXPANDED_PHP_CONFIG_FILE_PATH=''
EXPANDED_PHP_CONFIG_FILE_SCAN_DIR=''
EXPANDED_SBINDIR=''
EXPANDED_SYSCONFDIR=''
EXTENSION_DIR=''
EXTRA_INCLUDES=''
EXTRA_LDFLAGS=''
EXTRA_LDFLAGS_PROGRAM=''
EXTRA_LIBS=''
GREP='/bin/grep'
ICU_CONFIG=''
INCLUDES=' -I/freetz/source/target-mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/php-5.5.17/ext/date/lib -I/freetz/source/target-mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/php-5.5.17/ext/ereg/regex -I/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/usr/include/libxml2 -I/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/usr/include'
INCLUDE_PATH=''
INLINE_CFLAGS=''
INSTALL_IT=''
KRB5_CONFIG=''
LDFLAGS=' -L/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/usr/lib'
LIBOBJS=''
LIBS='-lsqlite3 -lpcre -lcrypto -lssl -lcrypto -lm -lxml2 -lz -lm'
LIBTOOL=''
LN_S='ln -s'
LTLIBOBJS=''
LTP=''
LTP_GENHTML=''
MYSQL_INCLUDE=''
MYSQL_LIBS=''
MYSQL_MODULE_TYPE=''
NATIVE_RPATHS=''
NMEDIT=''
OBJEXT='o'
OCI8_DIR=''
OCI8_ORACLE_VERSION=''
OCI8_SHARED_LIBADD=''
ODBC_INCLUDE=''
ODBC_LFLAGS=''
ODBC_LIBS=''
ODBC_TYPE=''
OPENSSL_INCDIR_OPT='-I/freetz/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/usr/include'
PACKAGE_BUGREPORT=''
PACKAGE_NAME=''
PACKAGE_STRING=''
PACKAGE_TARNAME=''
PACKAGE_URL=''
PACKAGE_VERSION=''
PATH_SEPARATOR=':'
PDO_MYSQL_MODULE_TYPE=''
PDO_OCI_DIR=''
PDO_OCI_SHARED_LIBADD=''
PDO_OCI_VERSION=''
PEAR_INSTALLDIR=''
PHP_INSTALLED_SAPIS=' cgi'
PHP_LDFLAGS=''
PHP_LIBS=''
PHP_VERSION='5.5.17'
PHP_VERSION_ID='50517'
PKG_CONFIG='/usr/bin/pkg-config'
PROG_SENDMAIL=''
RANLIB=''
RE2C='exit 0;'
SED='/bin/sed'
SHELL='/bin/bash'
SHLIB_DL_SUFFIX_NAME='so'
SHLIB_SUFFIX_NAME='so'
SNMP_CONFIG=''
STRIP=''
YACC='exit 0;'
YFLAGS=''
ZEND_EXTRA_LIBS=''
abs_builddir='/freetz/source/target-mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/php-5.5.17'
abs_srcdir='/freetz/source/target-mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/php-5.5.17'
ac_ct_CC=''
ac_ct_CXX=''
bindir='/usr/bin'
build='x86_64-pc-linux-gnu'
build_alias='x86_64-pc-linux-gnu'
build_cpu='x86_64'
build_os='linux-gnu'
build_vendor='pc'
datadir='/usr/share'
datarootdir='${prefix}/share'
docdir='${datarootdir}/doc/${PACKAGE}'
dvidir='${docdir}'
exec_prefix='/usr'
host='mips-unknown-linux-gnu'
host_alias='mips-linux'
host_cpu='mips'
host_os='linux-gnu'
host_vendor='unknown'
htmldir='${docdir}'
includedir='/usr/include'
infodir='/usr/share/info'
libdir='/usr/lib'
libexecdir='/usr/lib'
localedir='${datarootdir}/locale'
localstatedir='/var'
mandir='/usr/share/man'
oldincludedir='/usr/include'
pdfdir='${docdir}'
php_abs_top_builddir='/freetz/source/target-mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/php-5.5.17'
php_abs_top_srcdir='/freetz/source/target-mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/php-5.5.17'
php_fpm_group=''
php_fpm_localstatedir=''
php_fpm_prefix=''
php_fpm_sysconfdir=''
php_fpm_systemd=''
php_fpm_user=''
prefix='/usr'
program_prefix=''
program_suffix=''
program_transform_name='s,x,x,'
psdir='${docdir}'
sbindir='/usr/sbin'
sharedstatedir='${prefix}/com'
sysconfdir='/etc'
target='mips-unknown-linux-gnu'
target_alias='mips-linux'
target_cpu='mips'
target_os='linux-gnu'
target_vendor='unknown'
## confdefs.h. ##
/* confdefs.h */
#define PACKAGE_NAME ""
#define PACKAGE_TARNAME ""
#define PACKAGE_VERSION ""
#define PACKAGE_STRING ""
#define PACKAGE_BUGREPORT ""
#define PACKAGE_URL ""
#define STDC_HEADERS 1
#define HAVE_SYS_TYPES_H 1
#define HAVE_SYS_STAT_H 1
#define HAVE_STDLIB_H 1
#define HAVE_STRING_H 1
#define HAVE_MEMORY_H 1
#define HAVE_STRINGS_H 1
#define HAVE_INTTYPES_H 1
#define HAVE_STDINT_H 1
#define HAVE_UNISTD_H 1
#define __EXTENSIONS__ 1
#define _ALL_SOURCE 1
#define _GNU_SOURCE 1
#define _POSIX_PTHREAD_SEMANTICS 1
#define _TANDEM_SOURCE 1
#define HAVE_DEV_URANDOM 1
#define HAVE_SOCKLEN_T 1
#define WORDS_BIGENDIAN /**/
#define PHP_WRITE_STDOUT 1
#define HAVE_SOCKET 1
#define HAVE_SOCKETPAIR 1
#define HAVE_HTONL 1
#define HAVE_GETHOSTNAME 1
#define HAVE_GETHOSTBYADDR 1
#define HAVE_LIBM 1
#define HAVE_INET_ATON 1
#define HAVE_DIRENT_H 1
#define HAVE_SYS_PARAM_H 1
#define HAVE_SYS_TIME_H 1
#define HAVE_NETINET_IN_H 1
#define HAVE_ALLOCA_H 1
#define HAVE_ARPA_INET_H 1
#define HAVE_ARPA_NAMESER_H 1
#define HAVE_ASSERT_H 1
#define HAVE_CRYPT_H 1
#define HAVE_FCNTL_H 1
#define HAVE_GRP_H 1
#define HAVE_LANGINFO_H 1
#define HAVE_LIMITS_H 1
#define HAVE_LOCALE_H 1
#define HAVE_NETDB_H 1
#define HAVE_PWD_H 1
#define HAVE_RESOLV_H 1
#define HAVE_SIGNAL_H 1
#define HAVE_STDARG_H 1
#define HAVE_SYSLOG_H 1
#define HAVE_SYSEXITS_H 1
#define HAVE_SYS_IOCTL_H 1
#define HAVE_SYS_FILE_H 1
#define HAVE_SYS_MMAN_H 1
#define HAVE_SYS_MOUNT_H 1
#define HAVE_SYS_POLL_H 1
#define HAVE_SYS_RESOURCE_H 1
#define HAVE_SYS_SELECT_H 1
#define HAVE_SYS_SOCKET_H 1
#define HAVE_SYS_STATFS_H 1
#define HAVE_SYS_STATVFS_H 1
#define HAVE_SYS_VFS_H 1
#define HAVE_SYS_WAIT_H 1
#define HAVE_TERMIOS_H 1
#define HAVE_UTIME_H 1
#define HAVE_SYS_UTSNAME_H 1
#define HAVE_SYS_IPC_H 1
#define HAVE_DLFCN_H 1
#define HAVE_FOPENCOOKIE 1
#define COOKIE_IO_FUNCTIONS_T cookie_io_functions_t
#define HAVE_BROKEN_GLIBC_FOPEN_APPEND 1
#define HAVE_STRUCT_TM_TM_ZONE 1
#define HAVE_TM_ZONE 1
#define MISSING_FCLOSE_DECL 0
#define HAVE_TM_GMTOFF 1
#define HAVE_STRUCT_FLOCK 1
#define SIZEOF_SIZE_T 4
#define SIZEOF_LONG_LONG 8
#define SIZEOF_LONG_LONG_INT 8
#define SIZEOF_LONG 4
#define SIZEOF_INT 4
#define SIZEOF_INTMAX_T 8
#define HAVE_INTMAX_T 1
#define SIZEOF_SSIZE_T 4
#define HAVE_SSIZE_T 1
#define SIZEOF_PTRDIFF_T 4
#define HAVE_PTRDIFF_T 1
#define HAVE_STRUCT_STAT_ST_BLKSIZE 1
#define HAVE_ST_BLKSIZE 1
#define HAVE_STRUCT_STAT_ST_BLOCKS 1
#define HAVE_ST_BLOCKS 1
#define HAVE_STRUCT_STAT_ST_RDEV 1
#define HAVE_ST_RDEV 1
#define HAVE_SOCKADDR_STORAGE 1
#define HAVE_VPRINTF 1
#define HAVE_ALPHASORT 1
#define HAVE_ASCTIME_R 1
#define HAVE_CHROOT 1
#define HAVE_CTIME_R 1
#define HAVE_CUSERID 1
#define HAVE_FLOCK 1
#define HAVE_FTOK 1
#define HAVE_GAI_STRERROR 1
#define HAVE_GCVT 1
#define HAVE_GETLOGIN 1
#define HAVE_GETPROTOBYNAME 1
#define HAVE_GETPROTOBYNUMBER 1
#define HAVE_GETSERVBYNAME 1
#define HAVE_GETSERVBYPORT 1
#define HAVE_GETRUSAGE 1
#define HAVE_GETTIMEOFDAY 1
#define HAVE_GMTIME_R 1
#define HAVE_GETPWNAM_R 1
#define HAVE_GETGRNAM_R 1
#define HAVE_GETPWUID_R 1
#define HAVE_GRANTPT 1
#define HAVE_INET_NTOA 1
#define HAVE_INET_NTOP 1
#define HAVE_INET_PTON 1
#define HAVE_ISASCII 1
#define HAVE_LINK 1
#define HAVE_LOCALTIME_R 1
#define HAVE_LOCKF 1
#define HAVE_LCHOWN 1
#define HAVE_LRAND48 1
#define HAVE_MEMCPY 1
#define HAVE_MEMMOVE 1
#define HAVE_MKSTEMP 1
#define HAVE_MMAP 1
#define HAVE_NL_LANGINFO 1
#define HAVE_PERROR 1
#define HAVE_POLL 1
#define HAVE_PTSNAME 1
#define HAVE_PUTENV 1
#define HAVE_REALPATH 1
#define HAVE_RANDOM 1
#define HAVE_RAND_R 1
#define HAVE_SCANDIR 1
#define HAVE_SETITIMER 1
#define HAVE_SETLOCALE 1
#define HAVE_LOCALECONV 1
#define HAVE_SETENV 1
#define HAVE_SETPGID 1
#define HAVE_SETSOCKOPT 1
#define HAVE_SETVBUF 1
#define HAVE_SHUTDOWN 1
#define HAVE_SNPRINTF 1
#define HAVE_SRAND48 1
#define HAVE_SRANDOM 1
#define HAVE_STATFS 1
#define HAVE_STATVFS 1
#define HAVE_STRCASECMP 1
#define HAVE_STRCOLL 1
#define HAVE_STRDUP 1
#define HAVE_STRERROR 1
#define HAVE_STRFTIME 1
#define HAVE_STRNLEN 1
#define HAVE_STRPTIME 1
#define HAVE_STRSTR 1
#define HAVE_STRTOK_R 1
#define HAVE_SYMLINK 1
#define HAVE_TEMPNAM 1
#define HAVE_TZSET 1
#define HAVE_UNLOCKPT 1
#define HAVE_UNSETENV 1
#define HAVE_USLEEP 1
#define HAVE_UTIME 1
#define HAVE_VSNPRINTF 1
#define HAVE_VASPRINTF 1
#define HAVE_ASPRINTF 1
#define HAVE_NANOSLEEP 1
#define HAVE_GETADDRINFO 1
#define HAVE_SYNC_FETCH_AND_ADD 1
#define HAVE_STRLCAT 1
#define HAVE_STRLCPY 1
#define HAVE_GETOPT 1
#define HAVE_ALLOCA 1
#define HAVE_DECLARED_TIMEZONE 1
#define HAVE_POSIX_READDIR_R 1
#define PHP_SIGCHILD 0
#define DEFAULT_SHORT_OPEN_TAG "1"
#define HAVE_IPV6 1
#define HAVE_INT32_T 1
#define HAVE_UINT32_T 1
#define HAVE_STRTOLL 1
#define HAVE_ATOLL 1
#define HAVE_REGEX_T_RE_MAGIC 1
#define HSREGEX 1
#define REGEX 1
#define HAVE_LIBXML 1
#define HAVE_PCRE 1
configure: exit 1
