Freetz build 7590 Fehler mit nmap
switch-gott
5 Apr 2023
Guten Morgen zusammen,
hat von euch einer eine Idee warum genau das Nmap Paket mit LUA Probleme macht beim Build?
Z_LIBRARY_DIR="/usr/lib/freetz" make "$@" || { [ "2" = "0" ] && echo && cat .build.log 2>/dev/null; kill $$ 2>/dev/null || kill $$$$ 2>/dev/null; printf "\n\\033[33m%s\\033[m\n" "ERROR: Build failed."; exit 1; } }; mkdir -p source; [ -n "" ] && step="/" || step=""; [ -n "" ] && step="$step/"; case "" in BIN) echo -n "package/" >source/.echo_item_tmp ;; LIB) echo -n "library/" >source/.echo_item_tmp ;; HTL) echo -n "tools/" >source/.echo_item_tmp ;; KTC) echo -n "toolchain/kernel$step" >source/.echo_item_tmp ;; TTC) echo -n "toolchain/target$step" >source/.echo_item_tmp ;; KRN) echo -n "kernel" >source/.echo_item_tmp ;; esac; if ! diff -q source/.echo_item_tmp source/.echo_item_new >/dev/null 2>&1 || [ ! -e source/.echo_item_1st ]; then if [ -e source/.echo_item_end -a -e source/.echo_item_new -a -e source/.echo_item_1st ]; then echo -e "\e[48;5;26mdone\e[49m."; rm -f source/.echo_item_end source/.echo_item_1st; fi; [ -s source/.echo_item_tmp ] && cat source/.echo_item_tmp > source/.echo_item_new 2>/dev/null; [ -s source/.echo_item_new ] || cat source/.echo_item_old > source/.echo_item_new 2>/dev/null; if [ -s "source/.echo_item_new" ]; then echo -ne "\e[48;5;90m---> "; cat source/.echo_item_new 2>/dev/null | tee source/.echo_item_old; echo -ne "\e[49m ... "; [ "2" != "0" ] && echo; touch source/.echo_item_end; touch source/.echo_item_1st; fi; fi; echo -ne "\e[48;5;56mbuilding\e[49m ... "; cmd -C source/target-mips_gcc-8.3.0_uClibc-1.0.43-nptl_kernel-4.9/nmap-4.68
---> library/uclibcxx ...
building ... make[2]: *** Keine Regel vorhanden, um das Ziel „liblua/Makefile“,
benötigt von „lua_build“, zu erstellen. Schluss
Danke für eure HIlfe...
LG
Wenn ich [ ] Use system (shared) liblua deaktiviere, dann läuft bei mir unter Freetz-NG der Build durch.
Oh man...wie kann man nur so blind sein :-( ...also ich...
Besten Dank.
Läuft :)
broekar
