Freetz on 7581 device
DartSteven
21 Jun 2019
Hi everyone
Thanks for the great work you are doing, I wanted to ask you if it is possible to have support for 7581 too
Thanks again
It is very unlikely that 7581 & 7582 will be worked on in the near future. Both use GLIBC (instead of uClibc) as libc, which is not supported by Freetz as of now.
Hello
Has anything changed about the topic?
is there any freetz image available for 7581 or 7582..
was meinst du damit das zu schreiben ?
:confused: So wie ich es geschrieben habe. Oder hilft >das<?
@NDiIPP
now tell me where i can find freetz image with oscam
7581 x 7582
You are in the wrong forum for this question. There are no (illegal) Firmware-Images here in this Forum. And also no links to such.
You cannot find it with oscam, because it is not a search engine.
  • Love
Reaktionen: NDiIPP
Reaktionen: Konti23
michaelwarwel
IPPF im Überblick
