19:50:09.042432 IP (tos 0x0, ttl 128, id 187, offset 0, flags [none], proto UDP (17), length 44)
169.254.57.22.1032 > 255.255.255.255.5035: UDP, length 16
0x0000: 4500 002c 00bb 0000 8011 56f2 a9fe 3916 E..,......V...9.
0x0010: ffff ffff 0408 13ab 0018 0ef6 0000 1201 ................
0x0020: 0100 0000 a9fe 3901 0000 0000 0000 ......9.......
19:50:09.402090 IP (tos 0x0, ttl 128, id 188, offset 0, flags [none], proto UDP (17), length 44)
0x0000: 4500 002c 00bc 0000 8011 56f1 a9fe 3916 E..,......V...9.
0x0020: 0100 0000 a9fe 3901 0000 0000 4846 ......9.....HF
19:50:09.762608 IP (tos 0x0, ttl 128, id 189, offset 0, flags [none], proto UDP (17), length 44)
0x0000: 4500 002c 00bd 0000 8011 56f0 a9fe 3916 E..,......V...9.
19:50:10.122777 IP (tos 0x0, ttl 128, id 190, offset 0, flags [none], proto UDP (17), length 44)
0x0000: 4500 002c 00be 0000 8011 56ef a9fe 3916 E..,......V...9.
19:50:10.483972 IP (tos 0x0, ttl 128, id 191, offset 0, flags [none], proto UDP (17), length 44)
0x0000: 4500 002c 00bf 0000 8011 56ee a9fe 3916 E..,......V...9.
0x0020: 0100 0000 a9fe 3901 0000 0000 4345 ......9.....CE
19:50:10.834435 IP (tos 0x0, ttl 128, id 192, offset 0, flags [none], proto UDP (17), length 44)
0x0000: 4500 002c 00c0 0000 8011 56ed a9fe 3916 E..,......V...9.
19:50:11.195981 IP (tos 0x0, ttl 128, id 193, offset 0, flags [none], proto UDP (17), length 44)
0x0000: 4500 002c 00c1 0000 8011 56ec a9fe 3916 E..,......V...9.
19:50:11.545959 IP (tos 0x0, ttl 128, id 194, offset 0, flags [none], proto UDP (17), length 44)
0x0000: 4500 002c 00c2 0000 8011 56eb a9fe 3916 E..,......V...9.
19:50:11.905393 IP (tos 0x0, ttl 128, id 195, offset 0, flags [none], proto UDP (17), length 44)
0x0000: 4500 002c 00c3 0000 8011 56ea a9fe 3916 E..,......V...9.
19:50:12.256482 IP (tos 0x0, ttl 128, id 196, offset 0, flags [none], proto UDP (17), length 44)
0x0000: 4500 002c 00c4 0000 8011 56e9 a9fe 3916 E..,......V...9.
19:50:12.616766 IP (tos 0x0, ttl 128, id 197, offset 0, flags [none], proto UDP (17), length 44)
0x0000: 4500 002c 00c5 0000 8011 56e8 a9fe 3916 E..,......V...9.
19:50:12.967985 IP (tos 0x0, ttl 128, id 198, offset 0, flags [none], proto UDP (17), length 44)
0x0000: 4500 002c 00c6 0000 8011 56e7 a9fe 3916 E..,......V...9.
0x0020: 0100 0000 a9fe 3901 0000 0000 4346 ......9.....CF
19:50:13.328008 IP (tos 0x0, ttl 128, id 199, offset 0, flags [none], proto UDP (17), length 44)
0x0000: 4500 002c 00c7 0000 8011 56e6 a9fe 3916 E..,......V...9.
19:50:13.678459 IP (tos 0x0, ttl 128, id 200, offset 0, flags [none], proto UDP (17), length 44)
0x0000: 4500 002c 00c8 0000 8011 56e5 a9fe 3916 E..,......V...9.
19:50:14.038414 IP (tos 0x0, ttl 128, id 201, offset 0, flags [none], proto UDP (17), length 44)
0x0000: 4500 002c 00c9 0000 8011 56e4 a9fe 3916 E..,......V...9.
19:50:14.389533 IP (tos 0x0, ttl 128, id 202, offset 0, flags [none], proto UDP (17), length 44)
0x0000: 4500 002c 00ca 0000 8011 56e3 a9fe 3916 E..,......V...9.
19:50:14.751021 IP (tos 0x0, ttl 128, id 203, offset 0, flags [none], proto UDP (17), length 44)
0x0000: 4500 002c 00cb 0000 8011 56e2 a9fe 3916 E..,......V...9.
19:50:15.110574 IP (tos 0x0, ttl 128, id 204, offset 0, flags [none], proto UDP (17), length 44)
0x0000: 4500 002c 00cc 0000 8011 56e1 a9fe 3916 E..,......V...9.
19:50:15.471269 IP (tos 0x0, ttl 128, id 205, offset 0, flags [none], proto UDP (17), length 44)
0x0000: 4500 002c 00cd 0000 8011 56e0 a9fe 3916 E..,......V...9.
19:50:15.831196 IP (tos 0x0, ttl 128, id 206, offset 0, flags [none], proto UDP (17), length 44)
0x0000: 4500 002c 00ce 0000 8011 56df a9fe 3916 E..,......V...9.
19:50:16.192463 IP (tos 0x0, ttl 128, id 207, offset 0, flags [none], proto UDP (17), length 44)
0x0000: 4500 002c 00cf 0000 8011 56de a9fe 3916 E..,......V...9.
19:50:16.192479 IP (tos 0x0, ttl 128, id 207, offset 0, flags [none], proto UDP (17), length 44)
19:50:16.192931 IP (tos 0x0, ttl 250, id 411, offset 0, flags [none], proto UDP (17), length 44)
169.254.57.1.5035 > 169.254.57.22.5035: UDP, length 16
0x0000: 4500 002c 019b 0000 fa11 f911 a9fe 3901 E..,..........9.
0x0010: a9fe 3916 13ab 13ab 0018 fe6f 0000 1201 ..9........o....
0x0020: 0200 0000 0139 fea9 0000 0000 0000 .....9........
19:50:31.899870 MPCP, Opcode Pause, length 46
0x0000: 0001 ffff 0000 0000 0000 0000 0000 0000 ................
0x0010: 0000 0000 0000 0000 0000 0000 0000 0000 ................
0x0020: 0000 0000 0000 0000 0000 0000 0000 ..............
19:50:32.234075 MPCP, Opcode Pause, length 46
19:50:32.568431 MPCP, Opcode Pause, length 46
19:50:32.902622 MPCP, Opcode Pause, length 46
19:50:33.236804 MPCP, Opcode Pause, length 46
