fritz 7390 international and Box info
ayakunin
12 Nov 2011
Information about hardware
Box name
    FRITZ!Box Fon WLAN 7390
ANNEX
    B
HWRevision
    156.1.0.0
Flash (ROM)
    16 MB
RAM
    128 MB
CPU family
    Ikanos Fusiv Core
CPU model
    MIPS 24Kc V4.12
Clock frequencies
    CPU
        500 MHz
    SYSTEM
        166666666 Hz
    USB
        12 MHz
    USB2
        48 MHz
    DDR
        333333333 Hz
    EPHY
        125 MHz
    PCI
        33333333 Hz
    PCL66
        66666666 Hz
    AP
        333333332 Hz
    21xx
        228592 KHz
Operating hours counter
    2 hours 7 days 2 months 0 years (13 starts)
Network
Networks: 	IP-Address 	Hostname
Public 	91.77.240.111
Internal 	192.168.178.1 	fritz.fonwlan.box
Boot loader 	192.168.178.1
Interfaces:  	Protocol 	IP address	Names
dsl	Point-to-Point	192.168.178.1	fritz.box; fritz.nas; fritz.fonwlan.box
guest	Ethernet	192.168.179.1
lan	Ethernet	192.168.178.1	fritz.box; fritz.nas; fritz.fonwlan.box
MAC address
    DSL
        BC:05:43:43:6C:2D
    LAN
        BC:05:43:43:6C:2B
    WLAN
        BC:05:43:17:30:C4
Information about firmware
Firmware version
    84.05.06
AVM-Revision
    21062
Language
    en
Compilation date (AVM)
    29.11.2011 11:52:59
Version of bootloader
    1.819
I have a 7390 modem fritz international and he is working on annex A.. The information about the modem, I see annex B, this is a bug or a feature?
Thanks!
Freetz prints the AVM variable $CONFIG_ANNEX. Perhaps this is incorrect?
Regards
Oliver
root@fritz:/var/mod/root# echo $CONFIG_ANNEX
B
root@fritz:/var/mod/root# echo $ANNEX
A
Hm, I don't know if the variable is consistently available for all firmwares.
Regards
Oliver
hi
the CONFIG variables are just fallbacks. there are many ways to alter annex....
would you mind sending me supportdata created at fritz.box/support.lua so we can fix this in freetz?
my adress is [email protected] - the data will not be released - passwords are removed but you can have a look yourself
i will compare it to the german version and forward the resulting info to freetz and to the documentation...
thanks
Es tut mir leid, ich weiß nicht, Deutsch. Ich habe euch gesandt mailen Sie Ihr Modem-Konfiguration finden Sie, wenn Sie nicht erschweren.
Vielen Dank!
Keep speaking english, we are all from Germany but we understand english well. The German translation above is hard to read
Box name
[B]ANNEX
    A[/B]
HWRevision
    156.1.0.0
Flash (ROM)
    16 MB
RAM
    128 MB
CPU family
    Ikanos Fusiv Core
CPU model
    MIPS 24Kc V4.12
Clock frequencies
    CPU
        500 MHz
    SYSTEM
        166666666 Hz
    USB
        12 MHz
    USB2
        48 MHz
    DDR
        333333333 Hz
    EPHY
        125 MHz
    PCI
        33333333 Hz
    PCL66
        66666666 Hz
    AP
        333333332 Hz
    21xx
        228592 KHz
    1 hours 12 days 2 months 0 years (18 starts)
Thank you, now all right!
broekar
