Log SurfinBird
0d 00:02:14 tMicroCron info DNS query (A) for 'tock.Informatik.fh-augsburg.de' resulted in 141.82.30.252
JUN 09 19:32:27 tMicroCron info SNTP: Uptime 0d 00:02:14 = Real Time JUN 09 19:32:27
JUN 09 19:34:53 tInit info et2: No DHCP lease.
JUN 09 19:40:39 tSip notice SIP 487 response from 63.214.186.6 rejected, no state
JUN 09 19:45:24 tMicroCron info DNS query (A) for 'mail.place4you.ch' resulted in 217.26.53.193
JUN 09 19:49:12 tSip notice SIP 200 response from 63.214.186.6 rejected, no state
JUN 09 19:49:55 tSip notice SIP 200 response from 63.214.186.6 rejected, no state
JUN 09 19:51:25 tSip notice SIP session expired
JUN 09 19:51:47 tSip notice SIP 200 response from 63.214.186.6 rejected, no state
JUN 09 19:59:07 tCfg info QOS config started
JUN 09 19:59:07 tCfg info et2o: QoS uninstalled
JUN 09 19:59:07 tCfg info et2i: QoS uninstalled
JUN 09 19:59:07 tCfg info et2o: QoS installed
JUN 09 19:59:07 tCfg info et2i: QoS installed
JUN 09 19:59:07 tCfg info QOS config finished
JUN 09 19:59:07 tWebs notice User on 192.168.30.31 saved new Advanced SIP settings.
JUN 09 20:00:27 tMicroCron info DNS query (A) for 'mail.place4you.ch' resulted in 217.26.53.193
JUN 09 20:00:36 tWebs notice User on 192.168.30.31 saved new Security Profile "Niedrig" settings.
JUN 09 20:00:36 tCfg info SEC config started
JUN 09 20:00:36 tCfg info SEC config finished
JUN 09 20:00:36 tCfg info Configured proxy; 0 mappings
JUN 09 20:07:22 tSip notice SIP 100 response from 212.55.198.140 rejected, no state
Log Snom190
[8]9/6/2005 19:50:00: Send Packet PRACK
[5]9/6/2005 19:50:02: Dialog 8/7 going to confirmed
[8]9/6/2005 19:50:02: No special routing, routing to sip:[email protected];lr=true
[8]9/6/2005 19:50:02: route_pending_packet 1000093: entry=url ? sip:[email protected];lr=true
[8]9/6/2005 19:50:02: route_pending_packet 1000093: entry=udp 192.168.0.1 5060
[8]9/6/2005 19:50:02: Send Packet ACK
[8]9/6/2005 19:50:06: route_pending_packet 1000094: entry=url udp 192.168.0.1:5060
[8]9/6/2005 19:50:06: route_pending_packet 1000094: entry=udp 192.168.0.1 5060
[8]9/6/2005 19:50:06: Send Packet 200
[8]9/6/2005 19:50:22: route_pending_packet 1000095: entry=url udp 192.168.0.1:5060
[8]9/6/2005 19:50:22: route_pending_packet 1000095: entry=udp 192.168.0.1 5060
[8]9/6/2005 19:50:22: Send Packet 200
[8]9/6/2005 19:50:37: route_pending_packet 1000096: entry=url udp 192.168.0.1:5060
[8]9/6/2005 19:50:37: route_pending_packet 1000096: entry=udp 192.168.0.1 5060
[8]9/6/2005 19:50:37: Send Packet 200
[8]9/6/2005 19:50:52: route_pending_packet 1000097: entry=url udp 192.168.0.1:5060
[8]9/6/2005 19:50:52: route_pending_packet 1000097: entry=udp 192.168.0.1 5060
[8]9/6/2005 19:50:52: Send Packet 200
[8]9/6/2005 19:51:02: No special routing, routing to sip:[email protected];lr=true
[8]9/6/2005 19:51:02: route_pending_packet 1000098: entry=url ? sip:[email protected];lr=true
[8]9/6/2005 19:51:02: route_pending_packet 1000098: entry=udp 192.168.0.1 5060
[8]9/6/2005 19:51:02: Send Packet INVITE
[8]9/6/2005 19:51:03: No special routing, routing to sip:[email protected];lr=true
[8]9/6/2005 19:51:03: route_pending_packet 1000099: entry=url ? sip:[email protected];lr=true
[8]9/6/2005 19:51:03: route_pending_packet 1000099: entry=udp 192.168.0.1 5060
[8]9/6/2005 19:51:03: Send Packet ACK
[8]9/6/2005 19:51:07: route_pending_packet 1000100: entry=url udp 192.168.0.1:5060
[8]9/6/2005 19:51:07: route_pending_packet 1000100: entry=udp 192.168.0.1 5060
[8]9/6/2005 19:51:07: Send Packet 200
[8]9/6/2005 19:51:19: DNS Cache: Removing naptr sip.voipbuster.com
[8]9/6/2005 19:51:19: DNS Cache: Removing srv _sips._tcp.sip.voipbuster.com
[8]9/6/2005 19:51:19: DNS Cache: Removing srv _sip._tcp.sip.voipbuster.com
[8]9/6/2005 19:51:19: DNS Cache: Removing srv _sip._udp.sip.voipbuster.com
[8]9/6/2005 19:51:22: route_pending_packet 1000101: entry=url udp 192.168.0.1:5060
[8]9/6/2005 19:51:22: route_pending_packet 1000101: entry=udp 192.168.0.1 5060
[8]9/6/2005 19:51:22: Send Packet 200
[8]9/6/2005 19:51:38: route_pending_packet 1000102: entry=url udp 192.168.0.1:5060
[8]9/6/2005 19:51:38: route_pending_packet 1000102: entry=udp 192.168.0.1 5060
[8]9/6/2005 19:51:38: Send Packet 200
[8]9/6/2005 19:51:46: No special routing, routing to sip:[email protected];lr=true
[8]9/6/2005 19:51:46: route_pending_packet 1000103: entry=url ? sip:[email protected];lr=true
[8]9/6/2005 19:51:46: route_pending_packet 1000103: entry=udp 192.168.0.1 5060
[8]9/6/2005 19:51:46: Send Packet BYE
[5]9/6/2005 19:51:46: Dialog 8/7 going to terminated
[5]9/6/2005 19:51:46: timeout::callback: Registering with timeout of 0 ms
[8]9/6/2005 19:51:52: DNS Cache: Removing naptr iax.voipbuster.com
[8]9/6/2005 19:51:52: DNS Cache: Removing srv _sips._tcp.iax.voipbuster.com
[8]9/6/2005 19:51:52: DNS Cache: Removing srv _sip._tcp.iax.voipbuster.com
[8]9/6/2005 19:51:52: DNS Cache: Removing srv _sip._udp.iax.voipbuster.com
[8]9/6/2005 19:51:53: route_pending_packet 1000104: entry=url udp 192.168.0.1:5060
[8]9/6/2005 19:51:53: route_pending_packet 1000104: entry=udp 192.168.0.1 5060
[8]9/6/2005 19:51:53: Send Packet 200
[8]9/6/2005 20:09:51: No special routing, routing to sip:[email protected];user=phone
[8]9/6/2005 20:09:51: route_pending_packet 1000013: entry=url ? sip:[email protected];user=phone
[5]9/6/2005 20:09:51: Dialog 2/1 going to trying
[8]9/6/2005 20:09:51: DNS Cache: Add naptr calamar0.nikotel.com = (ttl=3600)
[8]9/6/2005 20:09:51: DNS cache_lookup: naptr calamar0.nikotel.com ->
[8]9/6/2005 20:09:51: route_pending_packet 1000013: entry=srv tls _sips._tcp.calamar0.nikotel.com
[8]9/6/2005 20:09:51: DNS Cache: Add srv _sips._tcp.calamar0.nikotel.com = (ttl=3600)
[8]9/6/2005 20:09:51: DNS cache_lookup: srv _sips._tcp.calamar0.nikotel.com ->
[8]9/6/2005 20:09:51: route_pending_packet 1000013: entry=srv tcp _sip._tcp.calamar0.nikotel.com
[8]9/6/2005 20:09:51: DNS Cache: Add srv _sip._tcp.calamar0.nikotel.com = (ttl=3600)
[8]9/6/2005 20:09:51: DNS cache_lookup: srv _sip._tcp.calamar0.nikotel.com ->
[8]9/6/2005 20:09:51: route_pending_packet 1000013: entry=srv udp _sip._udp.calamar0.nikotel.com
[8]9/6/2005 20:09:51: DNS Cache: Add srv _sip._udp.calamar0.nikotel.com = (ttl=3600)
[8]9/6/2005 20:09:51: DNS cache_lookup: srv _sip._udp.calamar0.nikotel.com ->
[8]9/6/2005 20:09:51: route_pending_packet 1000013: entry=a udp calamar0.nikotel.com 5060
[8]9/6/2005 20:09:52: DNS Cache: Add a calamar0.nikotel.com = 63.214.186.6 (ttl=40702)
[8]9/6/2005 20:09:52: route_pending_packet 1000013: entry=a udp calamar0.nikotel.com 5060
[8]9/6/2005 20:09:52: DNS cache_lookup: a calamar0.nikotel.com -> 63.214.186.6
[8]9/6/2005 20:09:52: route_pending_packet 1000013: entry=udp 63.214.186.6 5060
[8]9/6/2005 20:09:52: Send Packet INVITE
[5]9/6/2005 20:09:52: Dialog 2/1 going to proceeding
[8]9/6/2005 20:09:52: Routing to explicit plan udp 63.214.186.6 5060
[8]9/6/2005 20:09:52: route_pending_packet 1000014: entry=udp 63.214.186.6 5060
[8]9/6/2005 20:09:52: Send Packet ACK
[5]9/6/2005 20:09:52: Match challenge for user=joel_dutler, realm=nikotel.com
[8]9/6/2005 20:09:52: route_pending_packet 1000015: entry=udp 63.214.186.6 5060
[5]9/6/2005 20:09:54: Dialog 2/1 going to early
[8]9/6/2005 20:09:54: No special routing, routing to sip:[email protected];lr=true
[8]9/6/2005 20:09:54: route_pending_packet 1000016: entry=url ? sip:[email protected];lr=true
[8]9/6/2005 20:09:54: route_pending_packet 1000016: entry=udp 192.168.0.1 5060
[8]9/6/2005 20:09:54: Send Packet PRACK
[8]9/6/2005 20:09:56: route_pending_packet 1000017: entry=url udp 192.168.0.1:5060
[8]9/6/2005 20:09:56: route_pending_packet 1000017: entry=udp 192.168.0.1 5060
[8]9/6/2005 20:09:56: Send Packet 200
[5]9/6/2005 20:09:58: Dialog 2/1 going to confirmed
[8]9/6/2005 20:09:58: No special routing, routing to sip:[email protected];lr=true
[8]9/6/2005 20:09:58: route_pending_packet 1000018: entry=url ? sip:[email protected];lr=true
[8]9/6/2005 20:09:58: route_pending_packet 1000018: entry=udp 192.168.0.1 5060
[8]9/6/2005 20:09:58: Send Packet ACK
[8]9/6/2005 20:10:11: route_pending_packet 1000019: entry=url udp 192.168.0.1:5060
[8]9/6/2005 20:10:11: route_pending_packet 1000019: entry=udp 192.168.0.1 5060
[8]9/6/2005 20:10:11: Send Packet 200
[8]9/6/2005 20:10:27: route_pending_packet 1000020: entry=url udp 192.168.0.1:5060
[8]9/6/2005 20:10:27: route_pending_packet 1000020: entry=udp 192.168.0.1 5060
[8]9/6/2005 20:10:27: Send Packet 200
[8]9/6/2005 20:10:42: route_pending_packet 1000021: entry=url udp 192.168.0.1:5060
[8]9/6/2005 20:10:42: route_pending_packet 1000021: entry=udp 192.168.0.1 5060
[8]9/6/2005 20:10:42: Send Packet 200
[8]9/6/2005 20:10:57: route_pending_packet 1000022: entry=url udp 192.168.0.1:5060
[8]9/6/2005 20:10:57: route_pending_packet 1000022: entry=udp 192.168.0.1 5060
[8]9/6/2005 20:10:57: Send Packet 200
[8]9/6/2005 20:10:58: No special routing, routing to sip:[email protected];lr=true
[8]9/6/2005 20:10:58: route_pending_packet 1000023: entry=url ? sip:[email protected];lr=true
[8]9/6/2005 20:10:58: route_pending_packet 1000023: entry=udp 192.168.0.1 5060
[8]9/6/2005 20:10:58: Send Packet INVITE
[8]9/6/2005 20:10:59: No special routing, routing to sip:[email protected];lr=true
[8]9/6/2005 20:10:59: route_pending_packet 1000024: entry=url ? sip:[email protected];lr=true
[8]9/6/2005 20:10:59: route_pending_packet 1000024: entry=udp 192.168.0.1 5060
[8]9/6/2005 20:10:59: Send Packet ACK
[8]9/6/2005 20:11:12: No special routing, routing to sip:[email protected];lr=true
[8]9/6/2005 20:11:12: route_pending_packet 1000025: entry=url ? sip:[email protected];lr=true
[8]9/6/2005 20:11:12: route_pending_packet 1000025: entry=udp 192.168.0.1 5060
[8]9/6/2005 20:11:12: Send Packet BYE
[5]9/6/2005 20:11:12: Dialog 2/1 going to terminated
[5]9/6/2005 20:11:12: timeout::callback: Registering with timeout of 0 ms
[8]9/6/2005 20:11:12: route_pending_packet 1000026: entry=url udp 192.168.0.1:5060
[8]9/6/2005 20:11:12: route_pending_packet 1000026: entry=udp 192.168.0.1 5060
[8]9/6/2005 20:11:12: Send Packet 200
[8]9/6/2005 20:11:28: route_pending_packet 1000027: entry=url udp 192.168.0.1:5060
[8]9/6/2005 20:11:28: route_pending_packet 1000027: entry=udp 192.168.0.1 5060
[8]9/6/2005 20:11:28: Send Packet 200
[8]9/6/2005 20:11:43: route_pending_packet 1000028: entry=url udp 192.168.0.1:5060
[8]9/6/2005 20:11:43: route_pending_packet 1000028: entry=udp 192.168.0.1 5060
[8]9/6/2005 20:11:43: Send Packet 200
[8]9/6/2005 20:11:58: route_pending_packet 1000029: entry=url udp 192.168.0.1:5060
[8]9/6/2005 20:11:58: route_pending_packet 1000029: entry=udp 192.168.0.1 5060
[8]9/6/2005 20:11:58: Send Packet 200
[8]9/6/2005 20:12:13: route_pending_packet 1000030: entry=url udp 192.168.0.1:5060
[8]9/6/2005 20:12:13: route_pending_packet 1000030: entry=udp 192.168.0.1 5060
[8]9/6/2005 20:12:13: Send Packet 200
[8]9/6/2005 20:12:29: route_pending_packet 1000031: entry=url udp 192.168.0.1:5060
[8]9/6/2005 20:12:29: route_pending_packet 1000031: entry=udp 192.168.0.1 5060
[8]9/6/2005 20:12:29: Send Packet 200
[8]9/6/2005 20:12:44: route_pending_packet 1000032: entry=url udp 192.168.0.1:5060
[8]9/6/2005 20:12:44: route_pending_packet 1000032: entry=udp 192.168.0.1 5060
[8]9/6/2005 20:12:44: Send Packet 200
[8]9/6/2005 20:12:59: route_pending_packet 1000033: entry=url udp 192.168.0.1:5060
[8]9/6/2005 20:12:59: route_pending_packet 1000033: entry=udp 192.168.0.1 5060
[8]9/6/2005 20:12:59: Send Packet 200
[8]9/6/2005 20:13:14: route_pending_packet 1000034: entry=url udp 192.168.0.1:5060
[8]9/6/2005 20:13:14: route_pending_packet 1000034: entry=udp 192.168.0.1 5060
[8]9/6/2005 20:13:14: Send Packet 200
