; Static extension configuration file, used by
; the pbx_config module. This is where you configure all your
; inbound and outbound calls in Asterisk.
; The "General" category is for certain variables.
[general]
; If static is set to no, or omitted, then the pbx_config will rewrite
; this file when extensions are modified. Remember that all comments
; made in the file will be lost when that happens.
; XXX Not yet implemented XXX
static=yes
; if static=yes and writeprotect=no, you can save dialplan by
; CLI command 'save dialplan' too
writeprotect=no
; You can include other config files, use the #include command (without the ';')
; Note that this is different from the "include" command that includes contexts within
; other contexts. The #include command works in all asterisk configuration files.
;#include "filename.conf"
; The "Globals" category contains global variables that can be referenced
; in the dialplan with ${VARIABLE} or ${ENV(VARIABLE)} for Environmental variable
; ${${VARIABLE}} or ${text${VARIABLE}} or any hybrid
[globals]
CONSOLE=Console/dsp ; Console interface for demo
;CONSOLE=Zap/1
;CONSOLE=Phone/phone0
IAXINFO=guest ; IAXtel username/password
;IAXINFO=myuser:mypass
TRUNK=Zap/g2 ; Trunk interface
TRUNKMSD=1 ; MSD digits to strip (usually 1 or 0)
;TRUNK=IAX2/user:pass@provider
; Any category other than "General" and "Globals" represent
; extension contexts, which are collections of extensions.
; Extension names may be numbers, letters, or combinations
; thereof. If an extension name is prefixed by a '_'
; character, it is interpreted as a pattern rather than a
; literal. In patterns, some characters have special meanings:
; X - any digit from 0-9
; Z - any digit from 1-9
; N - any digit from 2-9
; [1235-9] - any digit in the brackets (in this example, 1,2,3,5,6,7,8,9)
; . - wildcard, matches anything remaining (e.g. _9011. matches
; anything starting with 9011 excluding 9011 itself)
; For example the extension _NXXXXXX would match normal 7 digit dialings,
; while _1NXXNXXXXXX would represent an area code plus phone number
; preceeded by a one.
; Each step of an extension is ordered by priority, which must
; always start with 1 to be considered a valid extension.
; Contexts contain several lines, one for each step of each
; extension, which can take one of two forms as listed below,
; with the first form being preferred. One may include another
; context in the current one as well, optionally with a
; date and time. Included contexts are included in the order
; they are listed.
;[context]
;exten => someexten,priority,application(arg1,arg2,...)
;exten => someexten,priority,application,arg1|arg2...
; Timing list for includes is
; <time range>|<days of week>|<days of month>|<months>
;include => daytime|9:00-17:00|mon-fri|*|*
; ignorepat can be used to instruct drivers to not cancel dialtone upon
; receipt of a particular pattern. The most commonly used example is
; of course '9' like this:
;ignorepat => 9
; so that dialtone remains even after dialing a 9.
; Here are the entries you need to participate in the IAXTEL
; call routing system. Most IAXTEL numbers begin with 1-700, but
; there are exceptions. For more information, and to sign
; up, please go to [url]www.gnophone.com[/url] or [url]www.iaxtel.com[/url]
[iaxtel700]
exten => _91700XXXXXXX,1,Dial(IAX2/${IAXINFO}@iaxtel.com/${EXTEN:1}@iaxtel)
; The SWITCH statement permits a server to share the dialplain with
; another server. Use with care: Reciprocal switch statements are not
; allowed (e.g. both A -> B and B -> A), and the switched server needs
; to be on-line or else dialing can be severly delayed.
[iaxprovider]
;switch => IAX2/user:[key]@myserver/mycontext
[trunkint]
; International long distance through trunk
exten => _9011.,1,Dial(${TRUNK}/${EXTEN:${TRUNKMSD}})
exten => _9011.,2,Congestion
[trunkld]
; Long distance context accessed through trunk
exten => _91NXXNXXXXXX,1,Dial(${TRUNK}/${EXTEN:${TRUNKMSD}})
exten => _91NXXNXXXXXX,2,Congestion
[trunklocal]
; Local seven-digit dialing accessed through trunk interface
exten => _9NXXXXXX,1,Dial(${TRUNK}/${EXTEN:${TRUNKMSD}})
exten => _9NXXXXXX,2,Congestion
[test]
; Long distance context accessed through trunk interface
exten => _91800NXXXXXX,1,Dial(${TRUNK}/${EXTEN:${TRUNKMSD}})
exten => _91800NXXXXXX,2,Congestion
exten => _91888NXXXXXX,1,Dial(${TRUNK}/${EXTEN:${TRUNKMSD}})
exten => _91888NXXXXXX,2,Congestion
exten => _91877NXXXXXX,1,Dial(${TRUNK}/${EXTEN:${TRUNKMSD}})
exten => _91877NXXXXXX,2,Congestion
exten => _91866NXXXXXX,1,Dial(${TRUNK}/${EXTEN:${TRUNKMSD}})
exten => _91866NXXXXXX,2,Congestion
[international]
; Master context for international long distance
ignorepat => 9
include => longdistance
include => trunkint
[longdistance]
; Master context for long distance
ignorepat => 9
include => local
include => trunkld
[local]
; Master context for local, toll-free, and iaxtel calls only
ignorepat => 9
include => default
include => parkedcalls
include => trunklocal
include => iaxtel700
include => trunktollfree
include => iaxprovider
; You can use an alternative switch type as well, to resolve
; extensions that are not known here, for example with remote
; IAX switching you transparently get access to the remote
; Asterisk PBX
; switch => IAX2/user:password@bigserver/local
[macro-stdexten];
; Standard extension macro:
; ${ARG1} - Extension (we could have used ${MACRO_EXTEN} here as well
; ${ARG2} - Device(s) to ring
exten => s,1,Dial(${ARG2},20) ; Ring the interface, 20 seconds maximum
exten => s,2,Goto(s-${DIALSTATUS},1) ; Jump based on status (NOANSWER,BUSY,CHANUNAVAIL,CONGESTION,ANSWER)
exten => s-NOANSWER,1,Voicemail(u${ARG1}) ; If unavailable, send to voicemail w/ unavail announce
exten => s-NOANSWER,2,Goto(default,s,1) ; If they press #, return to start
exten => s-BUSY,1,Voicemail(b${ARG1}) ; If busy, send to voicemail w/ busy announce
exten => s-BUSY,2,Goto(default,s,1) ; If they press #, return to start
exten => s-.,1,Goto(s-NOANSWER,1) ; Treat anything else as no answer
exten => a,1,VoicemailMain(${ARG1}) ; If they press *, send the user into VoicemailMain
[demo]
; We start with what to do when a call first comes in.
exten => s,1,Wait,1 ; Wait a second, just for fun
exten => s,2,Answer ; Answer the line
exten => s,3,DigitTimeout,5 ; Set Digit Timeout to 5 seconds
exten => s,4,ResponseTimeout,10 ; Set Response Timeout to 10 seconds
exten => s,5,BackGround(demo-congrats) ; Play a congratulatory message
exten => 6,BackGround(demo-instruct) ; Play some instructions
exten => 2,1,BackGround(demo-moreinfo) ; Give some more information.
exten => 2,2,Goto(s,6)
exten => 3,1,SetLanguage(fr) ; Set language to french
exten => 3,2,Goto(s,5) ; Start with the congratulations
exten => 1000,1,Goto(default,s,1)
; We also create an example user, 1234, who is on the console and has
; voicemail, etc.
exten => 1234,1,Playback(transfer,skip) ; "Please hold while..."
; (but skip if channel is not up)
exten => 1234,2,Macro(stdexten,1234,${CONSOLE})
exten => 1235,1,Voicemail(u1234) ; Right to voicemail
exten => 1236,1,Dial(Console/dsp) ; Ring forever
exten => 1236,2,Voicemail(u1234) ; Unless busy
; # for when they're done with the demo
exten => #,1,Playback(demo-thanks) ; "Thanks for trying the demo"
exten => #,2,Hangup ; Hang them up.
; A timeout and "invalid extension rule"
exten => t,1,Goto(#,1) ; If they take too long, give up
exten => i,1,Playback(invalid) ; "That's not valid, try again"
; Create an extension, 500, for dialing the
; Asterisk demo.
exten => 500,1,Playback(demo-abouttotry); Let them know what's going on
exten => 500,2,Dial(IAX2/[email protected]/s@default) ; Call the Asterisk demo
exten => 500,3,Playback(demo-nogo) ; Couldn't connect to the demo site
exten => 500,4,Goto(s,6) ; Return to the start over message.
; Create an extension, 600, for evaulating echo latency.
exten => 600,1,Playback(demo-echotest) ; Let them know what's going on
exten => 600,2,Echo ; Do the echo test
exten => 600,3,Playback(demo-echodone) ; Let them know it's over
exten => 600,4,Goto(s,6) ; Start over
; Give voicemail at extension 8500
exten => 8500,1,VoicemailMain
exten => 8500,2,Goto(s,6)
; Here's what a phone entry would look like (IXJ for example)
;exten => 1265,1,Dial(Phone/phone0,15)
;exten => 1265,2,Goto(s,5)
;[mainmenu]
; Example "main menu" context with submenu
;exten => s,1,Answer
;exten => s,2,Background(thanks) ; "Thanks for calling press 1 for sales, 2 for support, ..."
;exten => 1,1,Goto(submenu,s,1)
;exten => 2,1,Hangup
;include => default
;[submenu]
;exten => s,1,Ringing ; Make them comfortable with 2 seconds of ringback
;exten => s,2,Wait,2
;exten => s,3,Background(submenuopts) ; "Thanks for calling the sales department. Press 1 for steve, 2 for..."
;exten => 1,1,Goto(default,steve,1)
;exten => 2,1,Goto(default,mark,2)
[default]
; By default we include the demo. In a production system, you
; probably don't want to have the demo there.
include => demo
; Extensions like the two below can be used for FWD, Nikotel, sipgate etc.
; Note that you must have a [sipprovider] section in sip.conf whereas
; the otherprovider.net example does not require such a peer definition
;exten => _41X.,1,Dial(SIP/${EXTEN:2}@sipprovider,,r)
;exten => _42X.,1,Dial(SIP/user:passwd@${EXTEN:2}@otherprovider.net,30,rT)
; Real extensions would go here. Generally you want real extensions to be 4 or 5
; digits long (although there is no such requirement) and start with a single
; digit that is fairly large (like 6 or 7) so that you have plenty of room to
; overlap extensions and menu options without conflict. You can alias them with
; names, too and use global variables
;exten => 6245,1,Dial(SIP/Grandstream1,20,rt) ; permit transfer
;exten => 6245,1,Dial(SIP/Grandstream1&SIP/Xlite1,20,rtT)
;exten => 6361,1,Dial(IAX2/JaneDoe,,rm) ; ring without time limit
;exten => 6389,1,Dial(MGCP/aaln/[email protected])
;exten => 6394,1,Dial(Local/6275/n) ; this will dial ${MARK}
;exten => 6275,1,Macro(stdexten,6275,${MARK}) ; assuming ${MARK} is something like Zap/2
;exten => mark,1,Goto(6275|1) ; alias mark to 6275
;exten => 6536,1,Macro(stdexten,6236,${WIL}) ; Ditto for wil
;exten => wil,1,Goto(6236|1)
; Some other handy things are an extension for checking voicemail via
; voicemailmain
;exten => 8500,1,VoicemailMain
;exten => 8500,2,Hangup
; Or a conference room (you'll need to edit meetme.conf to enable this room)
;exten => 8600,1,Meetme(1234)
; Or playing an announcement to the called party, as soon it answers
;exten = 8700,1,Dial(${MARK},30,A(/path/to/my/announcemsg))
; For more information on applications, just type "show applications" at your
; friendly Asterisk CLI prompt.
; 'show application <command>' will show details of how you
; use that particular application in this file, the dial plan.
