ipcop*CLI> pri debug span 1
Enabled debugging on span 1
1 -- Got SABME from cpe peer.
1 Sending Unnumbered Acknowledgement
1 -- Restarting T203 counter
1 < Protocol Discriminator: Q.931 (8) len=37
1 < Call Ref: len= 1 (reference 1/0x1) (Originator)
1 < Message type: SETUP (5)
1 < [04 03 80 90 a3]
1 < Bearer Capability (len= 5) [ Ext: 1 Q.931 Std: 0 Info transfer capability: Speech (0)
1 < Ext: 1 Trans mode/rate: 64kbps, circuit-mode (16)
1 < Ext: 1 User information layer 1: A-Law (35)
1 < [6c 08 01 80 38 35 34 33 33 34]
1 < Calling Number (len=10) [ Ext: 0 TON: Unknown Number Type (0) NPI: ISDN/Telephony Numbering Plan (E.164/E.163) (1)
1 < Presentation: Presentation permitted, user number not screened (0) 'meine Rufnummer' ]
1 < [70 0c 81 30 33 35 38 31 38 35 34 33 34 38]
1 < Called Number (len=14) [ Ext: 1 TON: Unknown Number Type (0) NPI: ISDN/Telephony Numbering Plan (E.164/E.163) (1) 'angerufene Rufnummer' ]
1 < [7d 02 91 81]
1 < High-layer compatibilty (len= 4) [ 1 0x91 1 0x81 1 ]
1 -- Making new call for cr 1
1 -- Processing Q.931 Call Setup
1 -- Processing IE 4 (cs0, Bearer Capability)
1 -- Processing IE 108 (cs0, Calling Party Number)
1 -- Processing IE 112 (cs0, Called Party Number)
1 -- Processing IE 125 (cs0, High-layer Compatibility)
1 q931.c:4234 q931_receive: call 1 on channel -1 enters state 6 (Call Present)
1 q931.c:3302 q931_setup_ack: call 1 on channel 2 enters state 25 (Overlap Receiving)
1 > Protocol Discriminator: Q.931 (8) len=11
1 > Call Ref: len= 1 (reference 129/0x81) (Terminator)
1 > Message type: SETUP ACKNOWLEDGE (13)
1 > [18 01 8a]
1 > Channel ID (len= 3) [ Ext: 1 IntID: Implicit Other Spare: 0 Exclusive Dchan: 0
1 > ChanSel: B2 channel
1 ]
1 > [1e 02 81 88]
1 > Progress Indicator (len= 4) [ Ext: 1 Coding: CCITT (ITU) standard (0) 0: 0 Location: Private network serving the local user (1)
1 > Ext: 1 Progress Description: Inband information or appropriate pattern now available. (8) ]
1 -- Restarting T203 counter### Hier beginnt der Moment wo ca. 30s nichts zu hören ist
1 -- Restarting T203 counter### Hier enden die ca. 30s man sieht das "Ungültig" und hört das tut tut tut
1 < Protocol Discriminator: Q.931 (8) len=8
1 < Message type: DISCONNECT (69)
1 < [08 02 80 e6]
1 < Cause (len= 4) [ Ext: 1 Coding: CCITT (ITU) standard (0) Spare: 0 Location: User (0)
1 < Ext: 1 Cause: Recover on timer expiry (102), class = Protocol Error (e.g. unknown message) (6) ]
1 -- Processing IE 8 (cs0, Cause)
1 q931.c:4558 q931_receive: call 1 on channel 2 enters state 12 (Disconnect Indication)
1 NEW_HANGUP DEBUG: Calling q931_hangup, ourstate Disconnect Indication, peerstate Disconnect Request
1 q931.c:3435 q931_release: call 1 on channel 2 enters state 19 (Release Request)
1 > Protocol Discriminator: Q.931 (8) len=8
1 > Message type: RELEASE (77)
1 > [08 02 81 e6]
1 > Cause (len= 4) [ Ext: 1 Coding: CCITT (ITU) standard (0) Spare: 0 Location: Private network serving the local user (1)
1 > Ext: 1 Cause: Recover on timer expiry (102), class = Protocol Error (e.g. unknown message) (6) ]
1 < Protocol Discriminator: Q.931 (8) len=4
1 < Message type: RELEASE COMPLETE (90)
1 q931.c:4490 q931_receive: call 1 on channel 2 enters state 0 (Null)
1 NEW_HANGUP DEBUG: Calling q931_hangup, ourstate Null, peerstate Null
1 NEW_HANGUP DEBUG: Destroying the call, ourstate Null, peerstate Null
1 -- Got Disconnect from peer.
1 Stopping T_203 timer for TEI 64
[Aug 2 20:27:51] WARNING[3238]: chan_zap.c:2510 pri_find_dchan: No D-channels available! Using Primary channel 3 as D-channel anyway!
