SN4634/3BIS/UI#01:02:54 CC > [EP isdnif0-00aeefd0/active] Set call-leg prope
rty: E164-Number -> xxxxxxxxx
01:02:54 CC > [EP isdnif0-00aeefd0/active] Set call-leg property: Type-Of-Nu
mber -> National number
01:02:54 CC > [EP isdnif0-00aeefd0/active] Set call-leg property: Numbering-
Plan -> ISDN/Telephony numbering plan
01:02:54 CC > [EP isdnif0-00aeefd0/active] Set call-leg property: Presentati
on-Indicator -> Presentation allowed
01:02:54 CC > [EP isdnif0-00aeefd0/active] Set call-leg property: Screening-
Indicator -> Network provided
01:02:54 CC > [EP isdnif0-00aeefd0/active] Set call-leg property: Name ->
01:02:54 CC > [EP isdnif0-00aeefd0/active] Set call-leg property: Supports O
verlap-Sending -> false
01:02:54 CC > [EP isdnif0-00aeefd0/active] Set call-leg property: Endpoint-I
s-Isdn -> true
01:02:54 CC > [EP isdnif0-00aeefd0/active] Set call-leg property: Network ->
isdnif0
01:02:54 CC > [EP isdnif0-00aeefd0/active] Set call-leg property: Call-Leg-I
D -> 0x009db380
01:02:54 CC > [EP isdnif0-00aeefd0/active] Set call-leg property: State -> C
ONNECTED
01:02:54 CC > Acquired datapath context 00000022
01:02:54 CC > Started datapath context tracking 00000022
01:02:54 CC > [Call 009dd938] Set call property: Context -> 0x00000022
01:02:54 CC > [Call 009dd938] Set call property: Information-Transfer-Capabi
lity -> Speech
01:02:54 CC > [Call 009dd938] Set call property: Hops -> 0x00000010
01:02:54 CC > [EP isdnif0-00aeefd0/active] Dial to provider router (isdnif0-
precall-service) using call 009dd938
01:02:54 CC > [EP router-009e0778/incoming] Accept call 009dd938
01:02:54 CC > [EP router-009e0778/incoming] Set call-leg property: E164-Numb
er -> 10
01:02:54 CC > [EP router-009e0778/incoming] Set call-leg property: Type-Of-N
umber -> Unknown
01:02:54 CC > [EP router-009e0778/incoming] Set call-leg property: Numbering
-Plan -> ISDN/Telephony numbering plan
01:02:54 CC > [EP router-009e0778/incoming] Set call-leg property: Name ->
01:02:54 CC > [EP router-009e0778/incoming] Set call-leg property: Network -
> router
01:02:54 CC > [EP router-009e0778/incoming] Set call-leg property: Call-Leg-
ID -> 0x009dbd68
01:02:54 CC > [EP router-009e0778/incoming] Set call-leg property: State ->
TRYING
01:02:54 CC > [EP router-009e0778] Start route-lookup
01:02:54 CR > [switch] Routing-Lookup:
01:02:54 CR > Execute all entries in table isdnif0-precall-service
01:02:54 CR > Find best-matching called-entry in table fromisdn
01:02:54 CR > 01: Prefix Timeout Expression: called-e164 of 10 completel
y (fully ($)) matches ^(?:10$)
01:02:54 CR > Selecting entry 1
01:02:54 CR > Execute all entries in table isdnif2_fax-dest
01:02:54 CR > Execute all entries in table route-found-place-call
01:02:54 CR > Lookup result: Route found; place call (timeout=0)
01:02:54 CC > [EP router-009e0778] Route found; immediately place call
01:02:54 CC > [EP router-009e0778] Route to provider 'isdnif2_fax'
01:02:54 CC > [EP router-009e0778/outgoing] Set call-leg property: E164-Numb
er -> 6643402419
01:02:54 CC > [EP router-009e0778/outgoing] Set call-leg property: Type-Of-N
umber -> National number
01:02:54 CC > [EP router-009e0778/outgoing] Set call-leg property: Numbering
01:02:54 CC > [EP router-009e0778/outgoing] Set call-leg property: Presentat
ion-Indicator -> Presentation allowed
01:02:54 CC > [EP router-009e0778/outgoing] Set call-leg property: Screening
-Indicator -> Network provided
01:02:54 CC > [EP router-009e0778/outgoing] Set call-leg property: Name ->
01:02:54 CC > [EP router-009e0778/outgoing] Set call-leg property: Supports
Overlap-Sending -> false
01:02:54 CC > [EP router-009e0778/outgoing] Set call-leg property: Endpoint-
Is-Isdn -> true
01:02:54 CC > [EP router-009e0778/outgoing] Set call-leg property: Network -
> router
01:02:54 CC > [EP router-009e0778/outgoing] Set call-leg property: Call-Leg-
ID -> 0x009dcd48
01:02:54 CC > [EP router-009e0778/outgoing] Set call-leg property: State ->
CONNECTED
01:02:54 CC > [Call 009dc8c8] Set call property: Context -> 0x00000022
01:02:54 CC > [Call 009dc8c8] Set call property: Information-Transfer-Capabi
lity -> Speech
01:02:54 CC > [Call 009dc8c8] Set call property: Hops -> 0x0000000f
01:02:54 CC > [EP router-009e0778/outgoing] Dial to provider isdnif2_fax ()
using call 009dc8c8
01:02:54 CC > [EP isdnif2_fax-00cd6488/active] Accept call 009dc8c8
01:02:54 CC > [EP isdnif2_fax-00cd6488/active] Set call-leg property: E164-N
umber -> 10
01:02:54 CC > [EP isdnif2_fax-00cd6488/active] Set call-leg property: Type-O
f-Number -> Unknown
01:02:54 CC > [EP isdnif2_fax-00cd6488/active] Set call-leg property: Number
ing-Plan -> ISDN/Telephony numbering plan
01:02:54 CC > [EP isdnif2_fax-00cd6488/active] Set call-leg property: Name -
01:02:54 CC > [EP isdnif2_fax-00cd6488/active] Set call-leg property: Networ
k -> isdnif2_fax
01:02:54 CC > [EP isdnif2_fax-00cd6488/active] Set call-leg property: Call-L
eg-ID -> 0x009e18b0
01:02:54 CC > [EP isdnif2_fax-00cd6488/active] Set call-leg property: State
-> TRYING
01:02:54 CC > [EP isdnif2_fax-00cd6488/active] Set call-leg property: Endpoi
nt-Is-Isdn -> true
01:02:54 CC > [Call 009dd938] Set call property: Hops -> 0x0000000f
01:02:54 CC > [EP router-009e0778/incoming] Set call-leg property: Endpoint-
Is-Isdn -> true
01:03:00 CC > [EP isdnif2_fax-00cd6488/active] Set call-leg property: Cause
-> Network out of order
01:03:00 CC > [EP isdnif2_fax-00cd6488/active] Drop call 009dc8c8
01:03:00 CC > [EP isdnif2_fax-00cd6488/active] Set call-leg property: State
-> RELEASED
01:03:00 CC > [EP router-009e0778/incoming] Set call-leg property: Cause ->
01:03:00 CC > [EP router-009e0778/incoming] Set call-leg property: State ->
RELEASED
01:03:00 CC > [EP router-009e0778/outgoing] Drop call 009dc8c8
01:03:00 CC > [EP router-009e0778/outgoing] Set call-leg property: Cause ->
Normal call clearing
01:03:00 CC > [EP router-009e0778/outgoing] Set call-leg property: State ->
RELEASED
01:03:00 CC > [EP isdnif0-00aeefd0/active] Set call-leg property: Cause -> N
etwork out of order
ormal call clearing
01:03:00 CC > [EP isdnif0-00aeefd0/active] Drop call 009dd938
01:03:00 CC > [EP isdnif0-00aeefd0/active] Set call-leg property: State -> R
ELEASED
01:03:00 CC > Stopped datapath context tracking 00000022
01:03:00 CC > Released datapath context 00000022
