Hacking the Siemens SX541
cool, weiter so
linux wäre einfach klasse auf der Büchse
SX541 bootlog
heini66 schrieb:
update:
p - 10/Half
IP-Config: Complete:
device=eth0, addr=192.168.2.1, mask=255.255.255.0, gw=255.255.255.255,
host=sinus, domain=, nis-domain=(none),
bootserver=192.168.2.2, rootserver=192.168.2.2, rootpath=
Root-NFS: Mounting /nfsroot on server 192.168.2.2 as root
Root-NFS: rsize = 1024, wsize = 1024, timeo = 0, retrans = 0
Root-NFS: acreg (min,max) = (3,60), acdir (min,max) = (30,60)
Root-NFS: nfsd port = -1, mountd port = 0, flags = 00000200
Looking up port of RPC 100003/2 on 192.168.2.2
portmap: server 192.168.2.2 not responding, timed out
Root-NFS: Unable to get nfsd port number from server, using default
Root-NFS: Portmapper on server returned 2049 as nfsd port
Looking up port of RPC 100005/1 on 192.168.2.2
Root-NFS: Unable to get mountd port number from server, using default
Root-NFS: mountd port is 627
NFS: nfs_mount(c0a80202:/nfsroot)
mount: server 192.168.2.2 not responding, timed out
Root-NFS: Server returned error -5 while mounting /nfsroot
VFS: Unable to mount root fs via NFS, trying floppy.
VFS: Cannot open root device "nfs" or unknown-block(2,0)
Please append a correct "root=" boot option
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(2,0)
<0>Rebooting in 3 seconds..Reboot
[/code]
es fehlt hier noch das weiter zu bootende filesystem das bei diesem kernel auf 192.168.2.2 erwartet wird, hier aber z.zt bei mir noch nicht exportiert wird.
Hello!
I would like to share with my bootlog from running linux (almost) on SX541.
It mounts /nfsroot but then stops, i can`t do anything, my SX541 just answer ping`s.
How you build rootfs? I`ve made make world from SVN openwrt, and ten uncompressed the ~/trunk/bin/openwrt-ar7-2.6-rootfs.tgz into /nfsroot.
I also had problem with mountig /nfsroot, but now it`s working.
Make sure that portmap is working. Also i have this setting in export file:
/nfsroot 192.168.2.0/24(rw,no_root_squash,async).
Here`s mine bootlog
[AR7300 Boot]:y
Go to Memory Address: (default:0xB0020000) : 0x94000000
Jump to address 0x94000000 ...
AR7 loader started...
argc = 16384 = 0x4000
argv = 00000010
envp = 80004000
base = 94001f20
argc = 8 = 0x8
argv = 94301e80
envp = 94301c00
base = b4301f30
argv[] = go
argv[] = console=ttyS0,115200
argv[] = debug
argv[] = mtdparts=sinus:64k(boot)ro,-(flash)
argv[] = root=/dev/nfs
argv[] = rw
argv[] = nfsroot=/nfsroot,nolock,rsize=1024,wsize=1024
argv[] = ip=192.168.2.1:192.168.2.2::255.255.255.0:sinus:eth0:eek:ff
envp[] = nfsroot="nfs"
envp[] = HWRevision="00"
envp[] = flashsize="0x00200000"
envp[] = memsize="0x01000000"
envp[] = maca="00:04:0E:0A:D0:DF"
envp[] = macb="00:04:0E:0A:D0:DE"
envp[] = modetty0="115200,n,8,1,hw"
Launching kernel decompressor.
data = b4301f30
addr = b4301f30
lzma = 0x0000005d
size (in) = 2797701
size (out) = 2797701
Kernel decompressor was successful ... launching kernel.
loader.c:159, press any key to continue
LINUX running...
ar7_init_cmdline(8,94301e80)
ar7_init_cmdline: cmdline=console=ttyS0,115200 debug mtdparts=sinus:64k(boot)ro,-(flash) root=/dev/nfs rw nfsroot=/nfsroot,nolock,rsize=1024,wsize=1024 ip=192.168.2.1:192.168.2.2::255.255.255.0:sinus:eth0:eek:ff
ar7_init_env(94301c00)
ar7_init_env: nfsroot
ar7_init_env: HWRevision
ar7_init_env: flashsize
ar7_init_env: memsize
ar7_init_env: maca
ar7_init_env: macb
ar7_init_env: modetty0
prom_getenv(macb)
prom_getenv(maca)
prom_getenv(maca)
prom_getenv(maca)
Linux version 2.6.19.2 (ar7@linux) (gcc version 4.1.2) #45 PREEMPT Thu Mar 29 20:45:18 CEST 2007
CPU revision is: 00018448
Clocks: prediv: 1, postdiv: 25, mul: 8
Determined physical RAM map:
memory: 02000000 @ 14000000 (usable)
On node 0 totalpages: 8192
DMA zone: 64 pages used for memmap
DMA zone: 0 pages reserved
DMA zone: 8128 pages, LIFO batch:0
Normal zone: 0 pages used for memmap
Built 1 zonelists. Total pages: 8128
Kernel command line: console=ttyS0,115200 debug mtdparts=sinus:64k(boot)ro,-(flash) root=/dev/nfs rw nfsroot=/nfsroot,nolock,rsize=1024,wsize=1024 ip=192.168.2.1:192.168.2.2::255.255.255.0:sinus:eth0:eek:ff
Primary instruction cache 16kB, physically tagged, 4-way, linesize 16 bytes.
Primary data cache 16kB, 4-way, linesize 16 bytes.
Synthesized TLB refill handler (20 instructions).
Synthesized TLB load handler fastpath (32 instructions).
Synthesized TLB store handler fastpath (32 instructions).
Synthesized TLB modify handler fastpath (31 instructions).
PID hash table entries: 128 (order: 7, 512 bytes)
Using 75.000 MHz high precision timer.
Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
Memory: 29608k/32772k available (2196k kernel code, 316k reserved, 396k data, 140k init)
Calibrating delay loop... 6.42 BogoMIPS (lpj=32128)
Mount-cache hash table entries: 512
Checking for 'wait' instruction... available.
NET: Registered protocol family 16
vlynq0: regs 0x08611800, irq 29, mem 0x04000000
vlynq1: regs 0x08611c00, irq 33, mem 0x0c000000
PCI over VLYNQ emulation: probe of vlynq0 failed with error -22
PCI over VLYNQ emulation: probe of vlynq1 failed with error -22
Generic PHY: Registered new driver
NET: Registered protocol family 2
IP route cache hash table entries: 256 (order: -2, 1024 bytes)
TCP established hash table entries: 1024 (order: 0, 4096 bytes)
TCP bind hash table entries: 512 (order: -1, 2048 bytes)
TCP: Hash tables configured (established 1024 bind 512)
TCP reno registered
squashfs: version 3.0 (2006/03/15) Phillip Lougher
io scheduler noop registered
io scheduler deadline registered (default)
ar7_wdt: disabling watchdog timer
ar7_wdt: timer margin 59 seconds (prescale 65535, change 57180, freq 62500000)
Serial: 8250/16550 driver $Revision: 1.90 $ 2 ports, IRQ sharing disabled
serial8250: ttyS0 at MMIO 0x8610e00 (irq = 15) is a TI-AR7
serial8250: ttyS1 at MMIO 0x8610f00 (irq = 16) is a TI-AR7
Fixed PHY: Registered new driver
device_bind_driver: device fixed@100:1 already bound
cpmac-mii: probed
cpmac: device eth0 (regs: 08612800, irq: 41, phy: fixed@100:1, mac: 00:00:00:12:34:56)
cpmac: device eth1 (regs: 08610000, irq: 27, phy: 0:1f, mac: 00:00:00:12:34:56)
physmap platform flash device: 00400000 at 10000000
physmap-flash.0: Found 1 x16 devices at 0x0 in 16-bit bank
physmap-flash.0: Found an alias at 0x200000 for the chip at 0x0
Amd/Fujitsu Extended Query Table at 0x0040
number of CFI chips: 1
cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
RedBoot partition parsing not available
ar7part partition parsing not available
mtd: Giving out device 0 to physmap-flash.0
Registered led device: ar7:status
TCP cubic registered
NET: Registered protocol family 17
Time: MIPS clocksource has been installed.
PHY: fixed@100:1 - Link is Up - 10/Half
Root-NFS: mountd port is 730
VFS: Mounted root (nfs filesystem).
Freeing unused kernel memory: 140k freed
Warning: unable to open an initial console.
Greatz,
Krzysztof
Some succes.
I`ve made /dev/console /dev/zero /dev/null /dev/tty /dev/tty1 /dev/tty2 /dev/tty3 /dev/tty4 with mknod on my rootfs and then i had some succes:
Root-NFS: mountd port is 873
eth0: rx: no free skbs, dropping packet
init started:  BusyBox v1.4.2 (2007-06-01 15:37:56 CEST) multi-call binary
Algorithmics/MIPS FPU Emulator v1.5
Bummer, can't open /dev/tty1
: md5sum: /dev/mtdblock0: No such file or directory
: Unlocking rootfs ...
: Could not open mtd device: rootfs
: vconfig: /proc/net/vlan/config: No such file or directory
so then i`ve eddited /etc/inittab by hashing line with tty1
#tty1::askfirst:/bin/ash --login
and then there`s no more
Yuupi!!!
Ofcourse i recive lot`s of warning regarding iptables, but that`s not importand now.
When i try to telnet to the router - it close the connection. SSH is not working.
Only http works - i`ve index.html i /www and i can see it thru webbroser :)
Can you help me please how to run telnet/ssh(dropbear) ??
Regards
Krzysztof
PS.
Here`s the last bootlog
[AR7300 Boot]:y
argv = 00000010
envp = 80004000
base = 94001f20
argc = 8 = 0x8
argv = 94301e80
envp = 94301c00
base = b4301f30
argv[] = go
argv[] = debug
argv[] = rw
argv[] = ip=192.168.2.1:192.168.2.2::255.255.255.0:sinus:eth0:off
data = b4301f30
addr = b4301f30
lzma = 0x0000005d
size (in) = 2797701
LINUX running...
ar7_init_cmdline: cmdline=console=ttyS0,115200 debug mtdparts=sinus:64k(boot)ro,-(flash) root=/dev/nfs rw nfsroot=/nfsroot,nolock,rsize=1024,wsize=1024 ip=192.168.2.1:192.168.2.2::255.255.255.0:sinus:eth0:off
ar7_init_env: maca
ar7_init_env: macb
prom_getenv(macb)
prom_getenv(maca)
prom_getenv(maca)
prom_getenv(maca)
Kernel command line: console=ttyS0,115200 debug mtdparts=sinus:64k(boot)ro,-(flash) root=/dev/nfs rw nfsroot=/nfsroot,nolock,rsize=1024,wsize=1024 ip=192.168.2.1:192.168.2.2::255.255.255.0:sinus:eth0:off
TCP reno registered
cpmac-mii: probed
: /etc/rc.common: eval: 1: cannot create /proc/sys/kernel/hostname: Directory nonexistent
: awk: /proc/net/dev: No such file or directory
: /etc/rc.common: eval: 1: cannot open /proc/cmdline: No such file
sunrpc: version magic '2.6.21.1 mod_unload MIPS32_R1 32BIT ' should be '2.6.19.2 preempt mod_unload MIPS32_R1 32BIT '
lockd: version magic '2.6.21.1 mod_unload MIPS32_R1 32BIT ' should be '2.6.19.2 preempt mod_unload MIPS32_R1 32BIT '
nfs: version magic '2.6.21.1 mod_unload MIPS32_R1 32BIT ' should be '2.6.19.2 preempt mod_unload MIPS32_R1 32BIT '
crc_ccitt: version magic '2.6.21.1 mod_unload MIPS32_R1 32BIT ' should be '2.6.19.2 preempt mod_unload MIPS32_R1 32BIT '
slhc: version magic '2.6.21.1 mod_unload MIPS32_R1 32BIT ' should be '2.6.19.2 preempt mod_unload MIPS32_R1 32BIT '
ppp_generic: version magic '2.6.21.1 mod_unload MIPS32_R1 32BIT ' should be '2.6.19.2 preempt mod_unload MIPS32_R1 32BIT '
ppp_async: version magic '2.6.21.1 mod_unload MIPS32_R1 32BIT ' should be '2.6.19.2 preempt mod_unload MIPS32_R1 32BIT '
acx: version magic '2.6.21.1 mod_unload MIPS32_R1 32BIT ' should be '2.6.19.2 preempt mod_unload MIPS32_R1 32BIT '
: iptables v1.3.7: can't initialize iptables table `filter': Table does not exist (do you need to insmod?)
: Perhaps iptables or your kernel needs to be upgraded.
: iptables v1.3.7: can't initialize iptables table `nat': Table does not exist (do you need to insmod?)
: iptables v1.3.7: Unknown arg `--clamp-mss-to-pmtu'
: Try `iptables -h' or 'iptables --help' for more information.
: sysctl: error: 'kernel.panic' is an unknown key
: sysctl: error: 'net.ipv4.conf.default.arp_ignore' is an unknown key
: sysctl: error: 'net.ipv4.conf.all.arp_ignore' is an unknown key
: sysctl: error: 'net.ipv4.ip_forward' is an unknown key
: sysctl: error: 'net.ipv4.icmp_echo_ignore_broadcasts' is an unknown key
: sysctl: error: 'net.ipv4.icmp_ignore_bogus_error_responses' is an unknown key
: sysctl: error: 'net.ipv4.tcp_fin_timeout' is an unknown key
: sysctl: error: 'net.ipv4.tcp_keepalive_time' is an unknown key
: sysctl: error: 'net.ipv4.tcp_syncookies' is an unknown key
: sysctl: error: 'net.ipv4.tcp_timestamps' is an unknown key
nfs: server 192.168.2.2 not responding, still trying
sx 551 help
HI
I have siemens sx 551.
I can't upgrade furmware because sx 551 is provisioning by kpn.
I have
TI ADSL AR7300 Loader 0.71.4 build Oct 18 2005 11:13:40
Broad Net Technology, INC.
Plase help me!
I aslo try telnet but i don't have a correct login and paswword.
MArk
