[Apr 18 16:11:16] NOTICE[2977] cdr.c: CDR simple logging enabled.
[Apr 18 16:11:16] NOTICE[2977] loader.c: 150 modules will be loaded.
[Apr 18 16:11:16] WARNING[2977] loader.c: Module 'app_setcidname.so' did not register itself during load
[Apr 18 16:11:16] WARNING[2977] loader.c: Error loading module 'app_enumlookup.so': /usr/lib/asterisk/modules/app_enumlookup.so: undefined symbol: option_priority_jumping
[Apr 18 16:11:16] WARNING[2977] loader.c: Module 'app_setcidnum.so' did not register itself during load
[Apr 18 16:11:16] WARNING[2977] loader.c: Module 'app_cut.so' did not register itself during load
[Apr 18 16:11:16] WARNING[2977] loader.c: Module 'app_eval.so' did not register itself during load
[Apr 18 16:11:16] WARNING[2977] loader.c: Error loading module 'app_groupcount.so': /usr/lib/asterisk/modules/app_groupcount.so: undefined symbol: option_priority_jumping
[Apr 18 16:11:16] WARNING[2977] loader.c: Error loading module 'app_txtcidname.so': /usr/lib/asterisk/modules/app_txtcidname.so: undefined symbol: option_priority_jumping
[Apr 18 16:11:16] WARNING[2977] loader.c: Module 'app_math.so' did not register itself during load
[Apr 18 16:11:16] WARNING[2977] loader.c: Module 'app_setrdnis.so' did not register itself during load
[Apr 18 16:11:16] WARNING[2977] loader.c: Error loading module 'app_md5.so': /usr/lib/asterisk/modules/app_md5.so: undefined symbol: option_priority_jumping
[Apr 18 16:11:16] WARNING[2977] loader.c: Module 'app_callingpres.so' did not register itself during load
[Apr 18 16:11:16] WARNING[2977] loader.c: Module 'app_capiNoES.so' did not register itself during load
[Apr 18 16:11:16] WARNING[2977] loader.c: Module 'format_pcm_alaw.so' did not register itself during load
[Apr 18 16:11:16] WARNING[2977] loader.c: Module 'format_au.so' did not register itself during load
[Apr 18 16:11:16] WARNING[2977] loader.c: Module 'pbx_functions.so' did not register itself during load
[Apr 18 16:11:16] NOTICE[2977] res_smdi.c: Unable to load config smdi.conf: SMDI disabled
[Apr 18 16:11:16] WARNING[2977] res_smdi.c: No SMDI interfaces are available to listen on, not starting SDMI listener.
[Apr 18 16:11:16] WARNING[2977] chan_sip.c: tos value at line 9 is deprecated. See doc/ip-tos.txt for more information.
[Apr 18 16:11:16] WARNING[2977] chan_sip.c: insecure=very at line 10 is deprecated; use insecure=port,invite instead
[Apr 18 16:11:16] WARNING[2977] acl.c: TOS value lowdelay is deprecated. Please see doc/ip-tos.txt for more information.
[Apr 18 16:11:16] DEBUG[2977] chan_zap.c: Failed to read gains: Invalid argument
[Apr 18 16:11:16] DEBUG[2977] chan_zap.c: Updated conferencing on 1, with 0 conference users
[Apr 18 16:11:16] DEBUG[2977] chan_zap.c: Updated conferencing on 2, with 0 conference users
[Apr 18 16:11:16] DEBUG[2977] pbx_dundi.c: Seeding global EID '00:e0:7d:ed:10:06' from 'eth0'
[Apr 18 16:11:16] NOTICE[2977] pbx_ael.c: Starting AEL load process.
[Apr 18 16:11:16] NOTICE[2977] pbx_ael.c: AEL load process: calculated config file name '/etc/asterisk/extensions.ael'.
[Apr 18 16:11:16] NOTICE[2977] pbx_ael.c: AEL load process: parsed config file name '/etc/asterisk/extensions.ael'.
[Apr 18 16:11:16] NOTICE[2977] pbx_ael.c: AEL load process: checked config file name '/etc/asterisk/extensions.ael'.
[Apr 18 16:11:16] NOTICE[2977] pbx_ael.c: AEL load process: compiled config file name '/etc/asterisk/extensions.ael'.
[Apr 18 16:11:16] NOTICE[2977] pbx_ael.c: AEL load process: merged config file name '/etc/asterisk/extensions.ael'.
[Apr 18 16:11:16] NOTICE[2977] pbx_ael.c: AEL load process: verified config file name '/etc/asterisk/extensions.ael'.
[Apr 18 16:11:16] WARNING[2977] loader.c: Module 'app_setcidname.so' could not be loaded.
[Apr 18 16:11:16] WARNING[2977] loader.c: Module 'app_enumlookup.so' could not be loaded.
[Apr 18 16:11:16] WARNING[2977] loader.c: Module 'app_setcidnum.so' could not be loaded.
[Apr 18 16:11:16] WARNING[2977] loader.c: Module 'app_cut.so' could not be loaded.
[Apr 18 16:11:16] WARNING[2977] loader.c: Module 'app_eval.so' could not be loaded.
[Apr 18 16:11:16] WARNING[2977] loader.c: Module 'app_groupcount.so' could not be loaded.
[Apr 18 16:11:16] WARNING[2977] loader.c: Module 'app_txtcidname.so' could not be loaded.
[Apr 18 16:11:16] NOTICE[2987] chan_sip.c: Peer 'sipgate_blabla' is now Reachable. (188ms / 2000ms)
[Apr 18 16:11:16] WARNING[2977] loader.c: Module 'app_math.so' could not be loaded.
[Apr 18 16:11:16] WARNING[2977] loader.c: Module 'app_setrdnis.so' could not be loaded.
[Apr 18 16:11:16] WARNING[2977] loader.c: Module 'app_md5.so' could not be loaded.
[Apr 18 16:11:16] WARNING[2977] loader.c: Module 'app_callingpres.so' could not be loaded.
[Apr 18 16:11:17] WARNING[2977] loader.c: Module 'app_capiNoES.so' did not register itself during load
[Apr 18 16:11:17] WARNING[2977] loader.c: Module 'app_capiNoES.so' could not be loaded.
[Apr 18 16:11:17] WARNING[2977] translate.c: plc_samples 160 format 6
[Apr 18 16:11:17] WARNING[2977] loader.c: Module 'format_pcm_alaw.so' did not register itself during load
[Apr 18 16:11:17] WARNING[2977] loader.c: Module 'format_pcm_alaw.so' could not be loaded.
[Apr 18 16:11:17] WARNING[2977] loader.c: Module 'format_au.so' did not register itself during load
[Apr 18 16:11:17] WARNING[2977] loader.c: Module 'format_au.so' could not be loaded.
[Apr 18 16:11:17] WARNING[2977] loader.c: Module 'pbx_functions.so' did not register itself during load
[Apr 18 16:11:17] WARNING[2977] loader.c: Module 'pbx_functions.so' could not be loaded.
[Apr 18 16:11:17] ERROR[2977] app_amd.c: Configuration file amd.conf missing.
[Apr 18 16:11:17] WARNING[2977] app_followme.c: No follow me config file (followme.conf), so no follow me
