Jan 2 13:50:32 BS user.warn kernel: BOS: TaskCreate - spawn new task aoAP
Jan 2 13:50:32 BS user.warn kernel: bcmOsTaskCreate:
Jan 2 13:50:32 BS user.warn kernel: TASK NAME = aoAP
Jan 2 13:50:32 BS user.warn kernel: TASK_PRIORITY = 1
Jan 2 13:50:32 BS user.warn kernel: BOS: Exit TaskCreate
Jan 2 13:50:32 BS user.warn kernel: BOS: AppResetDetectionEnable() - Enabled re
set detection.
Jan 2 13:50:32 BS user.warn kernel: TASK NAME = aoRT
Jan 2 13:50:32 BS user.warn kernel: BOS: Exit bosStartApp
Jan 2 13:50:32 BS user.warn kernel: Reseting the 3341
Jan 2 13:50:32 BS user.warn kernel: voipResetGpio = 6
Jan 2 13:50:32 BS user.warn kernel: PASS: mmr
Jan 2 13:50:32 BS user.warn kernel: PASS: chipCtl
Jan 2 13:50:32 BS user.warn kernel: PASS: mspi
Jan 2 13:50:32 BS user.warn kernel: PASS: scratchSram
Jan 2 13:50:32 BS user.warn kernel: PASS: apmregs
Jan 2 13:50:32 BS user.warn kernel: PASS: apm0
Jan 2 13:50:34 BS user.warn kernel: PASS: apm1
Jan 2 13:50:34 BS user.warn kernel: PASS: hvg
Jan 2 13:50:34 BS user.warn kernel: PASS: slic
Jan 2 13:50:34 BS user.warn kernel: PASS: vpm
Jan 2 13:50:34 BS user.warn kernel: PASS: mbox
Jan 2 13:50:34 BS user.warn kernel: 3341 diagnostics passed!
Jan 2 13:50:34 BS user.warn kernel: Reseting the 3341
Jan 2 13:50:34 BS user.warn kernel: voipResetGpio = 6
Jan 2 13:50:34 BS user.warn kernel: Initializing 3341 drivers
Jan 2 13:50:34 BS user.warn kernel: -------------- TDM DMA setup strt ---------
Jan 2 13:50:34 BS user.warn kernel: SAMPLESIZE = 8
Jan 2 13:50:34 BS user.warn kernel: DESCRIPTORP = 0xb7fe6300 INGRESSP = 0xb7fe6
310 EGRESSP = 0xb7fe6330
Jan 2 13:50:34 BS user.warn kernel: Initializing Memory: 8 (16-bit locations)
Jan 2 13:50:34 BS user.warn kernel: Priming TX FIFO....
Jan 2 13:50:34 BS user.warn kernel: Completed TDM3341 init!!!!
Jan 2 13:50:34 BS user.warn kernel: MSPI driver init SUCCESSFUL
Jan 2 13:50:34 BS user.warn kernel: MSPI driver registers update SUCCESSFUL
Jan 2 13:50:34 BS user.warn kernel: BOARDHAL Enabling relays
Jan 2 13:50:34 BS user.warn kernel: Loading 3341 Zsp with Hausware app.
Jan 2 13:50:34 BS user.warn kernel: Loading 3341 overlay to 0xb7fc0000.
Jan 2 13:50:34 BS user.warn kernel: Verifying overlay...
Jan 2 13:50:34 BS user.warn kernel: Done verifying overlay.
Jan 2 13:50:34 BS user.warn kernel: BOS: Enter TaskCreate 3341_ASSERT_IST
Jan 2 13:50:34 BS user.warn kernel: BOS: TaskCreate - spawn new task 3341_ASSER
T_IST
Jan 2 13:50:34 BS user.warn kernel: bcmOsTaskCreate:
Jan 2 13:50:34 BS user.warn kernel: TASK NAME = 3341_ASSERT_IST
Jan 2 13:50:34 BS user.warn kernel: TASK_PRIORITY = 1
Jan 2 13:50:34 BS user.warn kernel: BOS: Exit TaskCreate
Jan 2 13:50:34 BS user.warn kernel: DSP Handshake. Hausware ZSP app initialize
d properly.
Jan 2 13:50:34 BS user.warn kernel: bosMsgQCreate: Created message queue VRGEVQ
at address 0x0
Jan 2 13:50:34 BS user.warn kernel: BOS: Enter TaskCreate VRGEVPR
Jan 2 13:50:34 BS user.warn kernel: BOS: TaskCreate - spawn new task VRGEVPR
Jan 2 13:50:34 BS user.warn kernel: TASK NAME = VRGEVPR
Jan 2 13:50:34 BS user.warn kernel: BOS: Enter TaskCreate HCAS
Jan 2 13:50:34 BS user.warn kernel: BOS: TaskCreate - spawn new task HCAS
Jan 2 13:50:34 BS user.warn kernel: TASK NAME = HCAS
Jan 2 13:50:34 BS user.warn kernel: ENDPT: Creating hausware task
Jan 2 13:50:34 BS user.warn kernel: BOS: Enter TaskCreate HTSK
Jan 2 13:50:34 BS user.warn kernel: BOS: TaskCreate - spawn new task HTSK
Jan 2 13:50:34 BS user.warn kernel: TASK NAME = HTSK
Jan 2 13:50:34 BS user.warn kernel: DAA DBG: MSPI Hdl = 0x500
Jan 2 13:50:34 BS user.warn kernel: DAA DBG: GPIO Hdl = 0xb
Jan 2 13:50:34 BS user.warn kernel: DAA DBG: Successful READ!!!! count = 0
Jan 2 13:50:34 BS user.warn kernel: DAA DBG: ISOCAP lock count = 0
Jan 2 13:50:34 BS user.warn kernel: Si3050 SLAC Initialised, Line side device =
Si: 3019 (0x3)
Jan 2 13:50:34 BS user.warn kernel: System dev rev: 0x4, Line dev rev: 0x3
Jan 2 13:50:34 BS user.warn kernel: Line dev status: FDT:0x1, LCS: 0x0
Jan 2 13:50:34 BS user.warn kernel: DAA Device Init completed
Jan 2 13:50:34 BS user.warn kernel: DAA init successful
Jan 2 13:50:34 BS user.warn kernel: ENDPT: 'HAPI_RM_OPEN_VHD_EVT' (0x80c1), hdl
:0x30, op1:0x50, op2:0x1
Jan 2 13:50:34 BS user.warn kernel: ENDPT: hdspVhdOpen Secondary Connection VHD
success. VHD (0x50) of type: 0x0
:0x30, op1:0x51, op2:0x1
success. VHD (0x51) of type: 0x0
Jan 2 13:50:34 BS user.warn kernel: bosMsgQCreate: Created message queue PSTN_C
TL_EVQ at address 0x8001
Jan 2 13:50:34 BS user.warn kernel: BOS: Enter TaskCreate PSTN
Jan 2 13:50:34 BS user.warn kernel: BOS: TaskCreate - spawn new task PSTN
Jan 2 13:50:34 BS user.warn kernel: TASK NAME = PSTN
Jan 2 13:50:34 BS user.warn kernel: TASK_PRIORITY = 0
Jan 2 13:50:34 BS user.warn kernel: pstnCtlInit successful
Jan 2 13:50:34 BS user.warn kernel: vrgendptCreate: capabilities.endptType = 0
:0x30, op1:0x52, op2:0x1
Jan 2 13:50:34 BS user.warn kernel: ENDPT: hdspVhdOpen Endpt VHD success. VHD (
0x52) of type: 0x2
Jan 2 13:50:34 BS user.warn kernel: ENDPT: TX Gain set to 1000
Jan 2 13:50:34 BS user.warn kernel: ENDPT: RX Gain set to 1000
Jan 2 13:50:34 BS user.warn kernel: ENDPT: 'HAPI_ECAN_STATE_EVT' (0x3ac0), hdl:
0x0, op1:0x7, op2:0x0
Jan 2 13:50:34 BS user.warn kernel: boardHalCasGetDriver: chan = 0
Jan 2 13:50:34 BS user.warn kernel: Default value for provItemId '41' did not e
xist
Jan 2 13:50:34 BS user.warn kernel: ENDPT: Initialization completed successfull
y for endpt 0
:0x30, op1:0x53, op2:0x1
Jan 2 13:50:35 BS user.warn kernel:
Jan 2 13:50:35 BS user.warn kernel: ENDPT: hdspVhdOpen Endpt VHD success. VHD (
0x53) of type: 0x2
Jan 2 13:50:35 BS user.warn kernel: ENDPT: TX Gain set to 1000
Jan 2 13:50:35 BS user.warn kernel: ENDPT: RX Gain set to 1000
Jan 2 13:50:35 BS user.warn kernel: ENDPT: 'HAPI_ECAN_STATE_EVT' (0x3ac0), hdl:
0x1, op1:0x7, op2:0x0
Jan 2 13:50:35 BS user.warn kernel: boardHalCasGetDriver: chan = 1
Jan 2 13:50:35 BS user.warn kernel: Default value for provItemId '41' did not e
xist
Jan 2 13:50:35 BS user.warn kernel: ENDPT: Initialization completed successfull
y for endpt 1
Jan 2 13:50:35 BS user.warn kernel: vrgendptCreate: capabilities.endptType = 1
Jan 2 13:50:35 BS user.warn kernel: ENDPT: 'HAPI_RM_OPEN_VHD_EVT' (0x80c1), hdl
:0x30, op1:0x54, op2:0x1
Jan 2 13:50:35 BS user.warn kernel: ENDPT: hdspVhdOpen PSTN VHD success. VHD (0
x54) of type: 0x6
0x2, op1:0x7, op2:0x0
xist
y for endpt 2
Jan 2 13:50:35 BS user.warn kernel: DAA: Going OnHook
Jan 2 13:50:35 BS user.warn kernel: DAA: Enable on-hook Caller ID receive.
Jan 2 13:50:36 BS user.warn kernel: TCM_GetFXOState, generate cas event = "18"
Jan 2 13:50:45 BS user.warn kernel: Endpt: i=0 cnxId=-1
Jan 2 13:50:45 BS user.warn kernel: Default value for provItemId '30' did not e
xist
Jan 2 13:50:45 BS user.warn kernel: HDSP: Static tone 'VOIP_DIAL'
Jan 2 13:50:45 BS user.warn kernel: ENDPT: 'HAPI_ECAN_STATE_EVT' (0x3ac0), hdl:
0x0, op1:0x3, op2:0x0
Jan 2 13:50:54 BS user.warn kernel: ENDPT: 'HAPI_ECAN_STATE_EVT' (0x3ac0), hdl:
Jan 2 13:51:04 BS user.warn kernel: Default value for provItemId '30' did not e
xist
Jan 2 13:51:04 BS user.warn kernel: HDSP: Static tone 'VOIP_DIAL'
Jan 2 13:51:04 BS user.warn kernel: ENDPT: 'HAPI_ECAN_STATE_EVT' (0x3ac0), hdl:
Jan 2 13:51:05 BS user.warn kernel: ENDPT: 'HAPI_ECAN_STATE_EVT' (0x3ac0), hdl:
Jan 2 13:51:07 BS user.warn kernel: Default value for provItemId '30' did not e
xist
Jan 2 13:51:07 BS user.warn kernel: HDSP: Static tone 'VOIP_DIAL'
Jan 2 13:51:07 BS user.warn kernel: ENDPT: 'HAPI_ECAN_STATE_EVT' (0x3ac0), hdl:
Jan 2 13:51:16 BS user.warn kernel: ENDPT: 'HAPI_ECAN_STATE_EVT' (0x3ac0), hdl:
Jan 2 13:51:21 BS user.warn kernel: Default value for provItemId '30' did not e
xist
Jan 2 13:51:21 BS user.warn kernel: HDSP: Static tone 'VOIP_DIAL'
Jan 2 13:51:21 BS user.warn kernel: ENDPT: 'HAPI_ECAN_STATE_EVT' (0x3ac0), hdl:
Jan 2 13:51:22 BS user.warn kernel: ENDPT: 'HAPI_ECAN_STATE_EVT' (0x3ac0), hdl:
Jan 2 13:51:25 BS user.warn kernel: Default value for provItemId '30' did not e
xist
Jan 2 13:51:25 BS user.warn kernel: HDSP: Static tone 'VOIP_DIAL'
Jan 2 13:51:25 BS user.warn kernel: ENDPT: 'HAPI_ECAN_STATE_EVT' (0x3ac0), hdl:
Jan 2 13:51:34 BS user.warn kernel: ENDPT: 'HAPI_ECAN_STATE_EVT' (0x3ac0), hdl:
Jan 2 13:51:43 BS user.warn kernel: Default value for provItemId '30' did not e
xist
Jan 2 13:51:43 BS user.warn kernel: HDSP: Static tone 'VOIP_DIAL'
Jan 2 13:51:43 BS user.warn kernel: ENDPT: 'HAPI_ECAN_STATE_EVT' (0x3ac0), hdl:
Jan 2 13:51:44 BS user.warn kernel: ENDPT: 'HAPI_ECAN_STATE_EVT' (0x3ac0), hdl:
Jan 2 13:51:47 BS user.warn kernel: Default value for provItemId '30' did not e
xist
Jan 2 13:51:47 BS user.warn kernel: HDSP: Static tone 'VOIP_DIAL'
Jan 2 13:51:47 BS user.warn kernel: ENDPT: 'HAPI_ECAN_STATE_EVT' (0x3ac0), hdl:
Jan 2 13:51:56 BS user.warn kernel: ENDPT: 'HAPI_ECAN_STATE_EVT' (0x3ac0), hdl:
Jan 2 13:52:05 BS user.warn kernel: Default value for provItemId '30' did not e
xist
Jan 2 13:52:05 BS user.warn kernel: HDSP: Static tone 'VOIP_DIAL'
Jan 2 13:52:05 BS user.warn kernel: ENDPT: 'HAPI_ECAN_STATE_EVT' (0x3ac0), hdl:
Jan 2 13:52:07 BS user.warn kernel: ENDPT: 'HAPI_ECAN_STATE_EVT' (0x3ac0), hdl:
Jan 2 13:52:09 BS user.warn kernel: Default value for provItemId '30' did not e
xist
Jan 2 13:52:09 BS user.warn kernel: HDSP: Static tone 'VOIP_DIAL'
Jan 2 13:52:09 BS user.warn kernel: ENDPT: 'HAPI_ECAN_STATE_EVT' (0x3ac0), hdl:
Jan 2 13:52:18 BS user.warn kernel: ENDPT: 'HAPI_ECAN_STATE_EVT' (0x3ac0), hdl:
Jan 2 14:22:41 BS daemon.info thttpd[617]: spawned CGI process 670 for file 'cg
i-bin/voip_index.cgi'
Jan 2 14:22:44 BS daemon.info thttpd[617]: spawned CGI process 685 for file 'cg
i-bin/voip_call_log_out.cgi'
Jan 2 14:22:46 BS daemon.info thttpd[617]: spawned CGI process 698 for file 'cg
Jan 2 14:22:48 BS daemon.info thttpd[617]: spawned CGI process 713 for file 'cg
i-bin/voip_call_log_in.cgi'
Jan 2 14:22:51 BS daemon.info thttpd[617]: spawned CGI process 726 for file 'cg
Jan 2 14:22:53 BS daemon.info thttpd[617]: spawned CGI process 741 for file 'cg
i-bin/index.cgi'
Jan 2 14:22:55 BS daemon.info thttpd[617]: spawned CGI process 820 for file 'cg
i-bin/svg_bar.cgi'
Jan 2 14:22:55 BS daemon.info thttpd[617]: spawned CGI process 821 for file 'cg
i-bin/svg_bar.cgi'
Jan 2 14:22:55 BS daemon.info thttpd[617]: spawned CGI process 826 for file 'cg
i-bin/svg_bar.cgi'
Jan 2 14:22:57 BS daemon.info thttpd[617]: spawned CGI process 876 for file 'cg
i-bin/svg_bar.cgi'
Jan 3 20:46:38 BS daemon.info thttpd[617]: spawned CGI process 883 for file 'cg
i-bin/index.cgi'
Jan 3 20:46:40 BS daemon.info thttpd[617]: spawned CGI process 964 for file 'cg
i-bin/svg_bar.cgi'
Jan 3 20:46:40 BS daemon.info thttpd[617]: spawned CGI process 966 for file 'cg
i-bin/svg_bar.cgi'
Jan 3 20:46:40 BS daemon.info thttpd[617]: spawned CGI process 970 for file 'cg
i-bin/svg_bar.cgi'
Jan 3 20:46:41 BS daemon.info thttpd[617]: spawned CGI process 1018 for file 'c
gi-bin/svg_bar.cgi'
Jan 3 20:46:49 BS daemon.info thttpd[617]: spawned CGI process 1025 for file 'c
gi-bin/admin_index.cgi'
Jan 3 20:46:52 BS daemon.info thttpd[617]: spawned CGI process 1043 for file 'c
gi-bin/custom_script.cgi'
Jan 3 20:47:05 BS daemon.info thttpd[617]: spawned CGI process 1055 for file 'c
gi-bin/additional_index.cgi'
Jan 3 20:47:10 BS daemon.info thttpd[617]: spawned CGI process 1060 for file 'c
gi-bin/dns.cgi'
Jan 3 20:47:15 BS daemon.info thttpd[617]: spawned CGI process 1091 for file 'c
Jan 3 20:47:18 BS daemon.info thttpd[617]: spawned CGI process 1096 for file 'c
gi-bin/plugin.cgi'
Jan 3 20:47:20 BS daemon.info thttpd[617]: spawned CGI process 1098 for file 'c
gi-bin/status_index.cgi'
Jan 3 20:47:26 BS daemon.info thttpd[617]: spawned CGI process 1102 for file 'c
Jan 3 20:47:33 BS daemon.info thttpd[617]: spawned CGI process 1120 for file 'c
gi-bin/web_shell.cgi'
Jan 3 20:48:09 BS daemon.info thttpd[617]: spawned CGI process 1134 for file 'c
Jan 3 20:48:29 BS daemon.info thttpd[617]: spawned CGI process 1160 for file 'c
Jan 3 20:54:07 BS auth.info login[1186]: root login on 'pty/s0'
Jan 3 20:55:29 BS daemon.info thttpd[617]: spawned CGI process 1189 for file 'c
Jan 3 20:55:32 BS daemon.info thttpd[617]: spawned CGI process 1207 for file 'c
Jan 3 20:57:05 BS daemon.info thttpd[617]: spawned CGI process 1219 for file 'c
Jan 3 20:57:09 BS cron.notice crond[1254]: crond 1.9.2 started, log level 8
Jan 3 20:58:05 BS daemon.info thttpd[617]: spawned CGI process 1259 for file 'c
Jan 3 20:58:09 BS cron.notice crond[1293]: crond 1.9.2 started, log level 8
Jan 3 20:59:52 BS daemon.info thttpd[617]: spawned CGI process 1302 for file 'c
Jan 3 20:59:54 BS daemon.info thttpd[617]: spawned CGI process 1306 for file 'c
gi-bin/info_index.cgi'
Jan 3 20:59:57 BS daemon.info thttpd[617]: spawned CGI process 1310 for file 'c
gi-bin/router_info.cgi'
Jan 4 00:17:39 BS auth.info login[1338]: root login on 'pty/s0'
